path: root/include/uapi/linux/uhid.h
2014-04-01HID: uhid: Add UHID_CREATE2 + UHID_INPUT2Petri Gynther
UHID_CREATE2: HID report descriptor data (rd_data) is an array in struct uhid_create2_req, instead of a pointer. Enables use from languages that don't support pointers, e.g. Python. UHID_INPUT2: Data array is the last field of struct uhid_input2_req. Enables userspace to write only the required bytes to kernel (ev.type + ev.u.input2.size + the part of the data array that matters), instead of the entire struct uhid_input2_req. Note: UHID_CREATE2 increases the total size of struct uhid_event slightly, thus increasing the size of messages that are queued for userspace. However, this won't affect the userspace processing of these events. [Jiri Kosina <jkosina@suse.cz>: adjust to hid_get_raw_report() and hid_output_raw_report() API changes] Signed-off-by: Petri Gynther <pgynther@google.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-31HID: uhid: use generic hidinput_input_event()David Herrmann
HID core provides the same functionality and can convert the input event to a raw output report. We can thus drop UHID_OUTPUT_EV and rely on the mandatory UHID_OUTPUT. User-space wasn't able to do anything with UHID_OUTPUT_EV, anyway. They don't have access to the report fields. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-03HID: uhid: use __packed__ for uhid_feature_answer_reqDavid Herrmann
We use __packed__ for all API structures so we can extend them without breaking alignment rules. We do try to explicitly align the structures, but to be safe we also use __packed__. uhid_feature_answer_req is already 64bit aligned so we can add __packed__ without breaking ABI. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
