Return the appropriate error code and handle the case when the target
file exists correctly. This fixes a bug.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Cc: <stable@vger.kernel.org> [3.14]
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"A series of bug fix patches for v3.15-rc1. Most are just driver
fixes. There are some changes at remote controller core level, fixing
some definitions on a new API added for Kernel v3.15.
It also adds the missing include at include/uapi/linux/v4l2-common.h,
to allow its compilation on userspace, as pointed by you"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (24 commits)
[media] gpsca: remove the risk of a division by zero
[media] stk1160: warrant a NUL terminated string
[media] v4l: ti-vpe: retain v4l2_buffer flags for captured buffers
[media] v4l: ti-vpe: Set correct field parameter for output and capture buffers
[media] v4l: ti-vpe: zero out reserved fields in try_fmt
[media] v4l: ti-vpe: Fix initial configuration queue data
[media] v4l: ti-vpe: Use correct bus_info name for the device in querycap
[media] v4l: ti-vpe: report correct capabilities in querycap
[media] v4l: ti-vpe: Allow usage of smaller images
[media] v4l: ti-vpe: Use video_device_release_empty
[media] v4l: ti-vpe: Make sure in job_ready that we have the needed number of dst_bufs
[media] lgdt3305: include sleep functionality in lgdt3304_ops
[media] drx-j: use customise option correctly
[media] m88rs2000: fix sparse static warnings
[media] r820t: fix size and init values
[media] rc-core: remove generic scancode filter
[media] rc-core: split dev->s_filter
[media] rc-core: do not change 32bit NEC scancode format for now
[media] rtl28xxu: remove duplicate ID 0458:707f Genius TVGo DVB-T03
[media] xc2028: add missing break to switch
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
Pull NVMe driver updates from Matthew Wilcox:
"Various updates to the NVMe driver. The most user-visible change is
that drive hotplugging now works and CPU hotplug while an NVMe drive
is installed should also work better"
* git://git.infradead.org/users/willy/linux-nvme:
NVMe: Retry failed commands with non-fatal errors
NVMe: Add getgeo to block ops
NVMe: Start-stop nvme_thread during device add-remove.
NVMe: Make I/O timeout a module parameter
NVMe: CPU hot plug notification
NVMe: per-cpu io queues
NVMe: Replace DEFINE_PCI_DEVICE_TABLE
NVMe: Fix divide-by-zero in nvme_trans_io_get_num_cmds
NVMe: IOCTL path RCU protect queue access
NVMe: RCU protected access to io queues
NVMe: Initialize device reference count earlier
NVMe: Add CONFIG_PM_SLEEP to suspend/resume functions
For commands returned with failed status, queue these for resubmission
and continue retrying them until success or for a limited amount of
time. The final timeout was arbitrarily chosen so requests can't be
retried indefinitely.
Since these are requeued on the nvmeq that submitted the command, the
callbacks have to take an nvmeq instead of an nvme_dev as a parameter
so that we can use the locked queue to append the iod to retry later.
The nvme_iod conviently can be used to track how long we've been trying
to successfully complete an iod request. The nvme_iod also provides the
nvme prp dma mappings, so I had to move a few things around so we can
keep those mappings.
Signed-off-by: Keith Busch <keith.busch@intel.com>
[fixed checkpatch issue with long line]
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Add VM_INIT_DEF_MASK, to allow us to set the default flags for VMs. It
also adds a prctl control which allows us to set the THP disable bit in
mm->def_flags so that VMs will pick up the setting as they are created.
Signed-off-by: Alex Thorlton <athorlton@sgi.com>
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
As reported by Linus, make headers_check is reporting:
usr/include/linux/v4l2-common.h:72: found __[us]{8,16,32,64} type without #include <linux/types.h>
which seems to have come in through commits 777f4f85b75f1 and
254a47770163f.
That happens because struct v4l2_edid should be visible by both
subdev and V4L2 APIs. So, it was moved to v4l2-common.h.
As Linus pointed, the proper fix is to just add an include for
linux/types.h at v4l2-common.h.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Pull xfs update from Dave Chinner:
"There are a couple of new fallocate features in this request - it was
decided that it was easiest to push them through the XFS tree using
topic branches and have the ext4 support be based on those branches.
Hence you may see some overlap with the ext4 tree merge depending on
how they including those topic branches into their tree. Other than
that, there is O_TMPFILE support, some cleanups and bug fixes.
The main changes in the XFS tree for 3.15-rc1 are:
- O_TMPFILE support
- allowing AIO+DIO writes beyond EOF
- FALLOC_FL_COLLAPSE_RANGE support for fallocate syscall and XFS
implementation
- FALLOC_FL_ZERO_RANGE support for fallocate syscall and XFS
implementation
- IO verifier cleanup and rework
- stack usage reduction changes
- vm_map_ram NOIO context fixes to remove lockdep warings
- various bug fixes and cleanups"
* tag 'xfs-for-linus-3.15-rc1' of git://oss.sgi.com/xfs/xfs: (34 commits)
xfs: fix directory hash ordering bug
xfs: extra semi-colon breaks a condition
xfs: Add support for FALLOC_FL_ZERO_RANGE
fs: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
xfs: inode log reservations are still too small
xfs: xfs_check_page_type buffer checks need help
xfs: avoid AGI/AGF deadlock scenario for inode chunk allocation
xfs: use NOIO contexts for vm_map_ram
xfs: don't leak EFSBADCRC to userspace
xfs: fix directory inode iolock lockdep false positive
xfs: allocate xfs_da_args to reduce stack footprint
xfs: always do log forces via the workqueue
xfs: modify verifiers to differentiate CRC from other errors
xfs: print useful caller information in xfs_error_report
xfs: add xfs_verifier_error()
xfs: add helper for updating checksums on xfs_bufs
xfs: add helper for verifying checksums on xfs_bufs
xfs: Use defines for CRC offsets in all cases
xfs: skip pointless CRC updates after verifier failures
xfs: Add support FALLOC_FL_COLLAPSE_RANGE for fallocate
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse update from Miklos Szeredi:
"This series adds cached writeback support to fuse, improving write
throughput"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: fix "uninitialized variable" warning
fuse: Turn writeback cache on
fuse: Fix O_DIRECT operations vs cached writeback misorder
fuse: fuse_flush() should wait on writeback
fuse: Implement write_begin/write_end callbacks
fuse: restructure fuse_readpage()
fuse: Flush files on wb close
fuse: Trust kernel i_mtime only
fuse: Trust kernel i_size only
fuse: Connection bit for enabling writeback
fuse: Prepare to handle short reads
fuse: Linking file to inode helper
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw
Pull GFS2 updates from Steven Whitehouse:
"One of the main highlights this time, is not the patches themselves
but instead the widening contributor base. It is good to see that
interest is increasing in GFS2, and I'd like to thank all the
contributors to this patch set.
In addition to the usual set of bug fixes and clean ups, there are
patches to improve inode creation performance when xattrs are required
and some improvements to the transaction code which is intended to
help improve scalability after further changes in due course.
Journal extent mapping is also updated to make it more efficient and
again, this is a foundation for future work in this area.
The maximum number of ACLs has been increased to 300 (for a 4k block
size) which means that even with a few additional xattrs from selinux,
everything should fit within a single fs block.
There is also a patch to bring GFS2's own copy of the writepages code
up to the same level as the core VFS. Eventually we may be able to
merge some of this code, since it is fairly similar.
The other major change this time, is bringing consistency to the
printing of messages via fs_<level>, pr_<level> macros"
* tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw: (29 commits)
GFS2: Fix address space from page function
GFS2: Fix uninitialized VFS inode in gfs2_create_inode
GFS2: Fix return value in slot_get()
GFS2: inline function gfs2_set_mode
GFS2: Remove extraneous function gfs2_security_init
GFS2: Increase the max number of ACLs
GFS2: Re-add a call to log_flush_wait when flushing the journal
GFS2: Ensure workqueue is scheduled after noexp request
GFS2: check NULL return value in gfs2_ok_to_move
GFS2: Convert gfs2_lm_withdraw to use fs_err
GFS2: Use fs_<level> more often
GFS2: Use pr_<level> more consistently
GFS2: Move recovery variables to journal structure in memory
GFS2: global conversion to pr_foo()
GFS2: return -E2BIG if hit the maximum limits of ACLs
GFS2: Clean up journal extent mapping
GFS2: replace kmalloc - __vmalloc / memset 0
GFS2: Remove extra "if" in gfs2_log_flush()
fs: NULL dereference in posix_acl_to_xattr()
GFS2: Move log buffer accounting to transaction
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull renameat2 system call from Miklos Szeredi:
"This adds a new syscall, renameat2(), which is the same as renameat()
but with a flags argument.
The purpose of extending rename is to add cross-rename, a symmetric
variant of rename, which exchanges the two files. This allows
interesting things, which were not possible before, for example
atomically replacing a directory tree with a symlink, etc... This
also allows overlayfs and friends to operate on whiteouts atomically.
Andy Lutomirski also suggested a "noreplace" flag, which disables the
overwriting behavior of rename.
These two flags, RENAME_EXCHANGE and RENAME_NOREPLACE are only
implemented for ext4 as an example and for testing"
* 'cross-rename' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ext4: add cross rename support
ext4: rename: split out helper functions
ext4: rename: move EMLINK check up
ext4: rename: create ext4_renament structure for local vars
vfs: add cross-rename
vfs: lock_two_nondirectories: allow directory args
security: add flags to rename hooks
vfs: add RENAME_NOREPLACE flag
vfs: add renameat2 syscall
vfs: rename: use common code for dir and non-dir
vfs: rename: move d_move() up
vfs: add d_is_dir()
Pull media updates from Mauro Carvalho Chehab:
"The main set of series of patches for media subsystem, including:
- document RC sysfs class
- added an API to setup scancode to allow waking up systems using the
Remote Controller
- add API for SDR devices. Drivers are still on staging
- some API improvements for getting EDID data from media
inputs/outputs
- new DVB frontend driver for drx-j (ATSC)
- one driver (it913x/it9137) got removed, in favor of an improvement
on another driver (af9035)
- added a skeleton V4L2 PCI driver at documentation
- added a dual flash driver (lm3646)
- added a new IR driver (img-ir)
- added an IR scancode decoder for the Sharp protocol
- some improvements at the usbtv driver, to allow its core to be
reused.
- added a new SDR driver (rtl2832u_sdr)
- added a new tuner driver (msi001)
- several improvements at em28xx driver to fix PM support, device
removal and to split the V4L2 specific bits into a separate
sub-driver
- one driver got converted to videobuf2 (s2255drv)
- the e4000 tuner driver now follows an improved binding model
- some fixes at V4L2 compat32 code
- several fixes and enhancements at videobuf2 code
- some cleanups at V4L2 API documentation
- usual driver enhancements, new board additions and misc fixups"
[ NOTE! This merge effective drops commit 4329b93b283c ("of: Reduce
indentation in of_graph_get_next_endpoint").
The of_graph_get_next_endpoint() function was moved and renamed by
commit fd9fdb78a9bf ("[media] of: move graph helpers from
drivers/media/v4l2-core to drivers/of"). It was originally called
v4l2_of_get_next_endpoint() and lived in the file
drivers/media/v4l2-core/v4l2-of.c.
In that original location, it was then fixed to support empty port
nodes by commit b9db140c1e46 ("[media] v4l: of: Support empty port
nodes"), and that commit clashes badly with the dropped "Reduce
intendation" commit. I had to choose one or the other, and decided
that the "Support empty port nodes" commit was more important ]
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (426 commits)
[media] em28xx-dvb: fix PCTV 461e tuner I2C binding
Revert "[media] em28xx-dvb: fix PCTV 461e tuner I2C binding"
[media] em28xx: fix PCTV 290e LNA oops
[media] m88ds3103: fix bug on .set_tone()
[media] saa7134: fix WARN_ON during resume
[media] v4l2-dv-timings: add module name, description, license
[media] videodev2.h: add parenthesis around macro arguments
[media] saa6752hs: depends on CRC32
[media] si4713: fix Kconfig dependencies
[media] Sensoray 2255 uses videobuf2
[media] adv7180: free an interrupt on failure paths in init_device()
[media] e4000: make VIDEO_V4L2 dependency optional
[media] af9033: Don't export functions for the hardware filter
[media] af9035: use af9033 PID filters
[media] af9033: implement PID filter
[media] rtl2832_sdr: do not use dynamic stack allocation
[media] e4000: fix 32-bit build error
[media] em28xx-audio: make sure audio is unmuted on open()
[media] DocBook media: v4l2_format_sdr was renamed to v4l2_sdr_format
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"The first round of updates for the input subsystem.
Just new drivers and existing driver fixes, no core changes except for
the new uinput IOCTL to allow userspace to fetch sysfs name of the
input device that was created"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (43 commits)
Input: edt-ft5x06 - add a missing condition
Input: appletouch - fix jumps when additional fingers are detected
Input: appletouch - implement sensor data smoothing
Input: add driver for SOC button array
Input: pm8xxx-vibrator - add DT match table
Input: pmic8xxx-pwrkey - migrate to DT
Input: pmic8xxx-keypad - migrate to DT
Input: pmic8xxx-keypad - migrate to regmap APIs
Input: pmic8xxx-keypad - migrate to devm_* APIs
Input: pmic8xxx-keypad - fix build by removing gpio configuration
Input: add new driver for ARM CLPS711X keypad
Input: edt-ft5x06 - add support for M09 firmware version
Input: edt-ft5x06 - ignore touchdown events
Input: edt-ft5x06 - adjust delays to conform datasheet
Input: edt-ft5x06 - add DT support
Input: edt-ft5x06 - several cleanups; no functional change
Input: appletouch - dial back fuzz setting
Input: remove obsolete tnetv107x drivers
Input: sirfsoc-onkey - set the capability of reporting KEY_POWER
Input: da9052_onkey - use correct register bit for key status
Merge first patch-bomb from Andrew Morton:
- Various misc bits
- kmemleak fixes
- small befs, codafs, cifs, efs, freexxfs, hfsplus, minixfs, reiserfs things
- fanotify
- I appear to have become SuperH maintainer
- ocfs2 updates
- direct-io tweaks
- a bit of the MM queue
- printk updates
- MAINTAINERS maintenance
- some backlight things
- lib/ updates
- checkpatch updates
- the rtc queue
- nilfs2 updates
- Small Documentation/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (237 commits)
Documentation/SubmittingPatches: remove references to patch-scripts
Documentation/SubmittingPatches: update some dead URLs
Documentation/filesystems/ntfs.txt: remove changelog reference
Documentation/kmemleak.txt: updates
fs/reiserfs/super.c: add __init to init_inodecache
fs/reiserfs: move prototype declaration to header file
fs/hfsplus/attributes.c: add __init to hfsplus_create_attr_tree_cache()
fs/hfsplus/extents.c: fix concurrent acess of alloc_blocks
fs/hfsplus/extents.c: remove unused variable in hfsplus_get_block
nilfs2: update project's web site in nilfs2.txt
nilfs2: update MAINTAINERS file entries fix
nilfs2: verify metadata sizes read from disk
nilfs2: add FITRIM ioctl support for nilfs2
nilfs2: add nilfs_sufile_trim_fs to trim clean segs
nilfs2: implementation of NILFS_IOCTL_SET_SUINFO ioctl
nilfs2: add nilfs_sufile_set_suinfo to update segment usage
nilfs2: add struct nilfs_suinfo_update and flags
fs/coda/inode.c: add __init to init_inodecache()
BEFS: logging cleanup
If the glibc xattr.h header is included after the uapi header,
compilation fails due to an enum re-using a #define from the uapi
header.
Protect against this by guarding the define and enum inclusions against
each other.
(See https://lists.debian.org/debian-glibc/2014/03/msg00029.html
and https://sourceware.org/glibc/wiki/Synchronizing_Headers
for more information.)
Signed-off-by: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Allan McRae <allan@archlinux.org>
Pull VFIO updates from Alex Williamson:
"VFIO updates for v3.15 include:
- Allow the vfio-type1 IOMMU to support multiple domains within a
container
- Plumb path to query whether all domains are cache-coherent
- Wire query into kvm-vfio device to avoid KVM x86 WBINVD emulation
- Always select CONFIG_ANON_INODES, vfio depends on it (Arnd)
The first patch also makes the vfio-type1 IOMMU driver completely
independent of the bus_type of the devices it's handling, which
enables it to be used for both vfio-pci and a future vfio-platform
(and hopefully combinations involving both simultaneously)"
* tag 'vfio-v3.15-rc1' of git://github.com/awilliam/linux-vfio:
vfio: always select ANON_INODES
kvm/vfio: Support for DMA coherent IOMMUs
vfio: Add external user check extension interface
vfio/type1: Add extension to test DMA cache coherence of IOMMU
vfio/iommu_type1: Multi-IOMMU domain support
Pull networking updates from David Miller:
"Here is my initial pull request for the networking subsystem during
this merge window:
1) Support for ESN in AH (RFC 4302) from Fan Du.
2) Add full kernel doc for ethtool command structures, from Ben
Hutchings.
3) Add BCM7xxx PHY driver, from Florian Fainelli.
4) Export computed TCP rate information in netlink socket dumps, from
Eric Dumazet.
5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas
Dichtel.
6) Convert many drivers to pci_enable_msix_range(), from Alexander
Gordeev.
7) Record SKB timestamps more efficiently, from Eric Dumazet.
8) Switch to microsecond resolution for TCP round trip times, also
from Eric Dumazet.
9) Clean up and fix 6lowpan fragmentation handling by making use of
the existing inet_frag api for it's implementation.
10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss.
11) Auto size SKB lengths when composing netlink messages based upon
past message sizes used, from Eric Dumazet.
12) qdisc dumps can take a long time, add a cond_resched(), From Eric
Dumazet.
13) Sanitize netpoll core and drivers wrt. SKB handling semantics.
Get rid of never-used-in-tree netpoll RX handling. From Eric W
Biederman.
14) Support inter-address-family and namespace changing in VTI tunnel
driver(s). From Steffen Klassert.
15) Add Altera TSE driver, from Vince Bridgers.
16) Optimizing csum_replace2() so that it doesn't adjust the checksum
by checksumming the entire header, from Eric Dumazet.
17) Expand BPF internal implementation for faster interpreting, more
direct translations into JIT'd code, and much cleaner uses of BPF
filtering in non-socket ocntexts. From Daniel Borkmann and Alexei
Starovoitov"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits)
netpoll: Use skb_irq_freeable to make zap_completion_queue safe.
net: Add a test to see if a skb is freeable in irq context
qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port'
net: ptp: move PTP classifier in its own file
net: sxgbe: make "core_ops" static
net: sxgbe: fix logical vs bitwise operation
net: sxgbe: sxgbe_mdio_register() frees the bus
Call efx_set_channels() before efx->type->dimension_resources()
xen-netback: disable rogue vif in kthread context
net/mlx4: Set proper build dependancy with vxlan
be2net: fix build dependency on VxLAN
mac802154: make csma/cca parameters per-wpan
mac802154: allow only one WPAN to be up at any given time
net: filter: minor: fix kdoc in __sk_run_filter
netlink: don't compare the nul-termination in nla_strcmp
can: c_can: Avoid led toggling for every packet.
can: c_can: Simplify TX interrupt cleanup
can: c_can: Store dlc private
can: c_can: Reduce register access
can: c_can: Make the code readable
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
- substantial cleanup of the generic and transport layers, in the
direction of an ultimate goal of making struct hid_device completely
transport independent, by Benjamin Tissoires
- cp2112 driver from David Barksdale
- a lot of fixes and new hardware support (Dualshock 4) to hid-sony
driver, by Frank Praznik
- support for Win 8.1 multitouch protocol by Andrew Duggan
- other smaller fixes / device ID additions
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (75 commits)
HID: sony: fix force feedback mismerge
HID: sony: Set the quriks flag for Bluetooth controllers
HID: sony: Fix Sixaxis cable state detection
HID: uhid: Add UHID_CREATE2 + UHID_INPUT2
HID: hyperv: fix _raw_request() prototype
HID: hyperv: Implement a stub raw_request() entry point
HID: hid-sensor-hub: fix sleeping function called from invalid context
HID: multitouch: add support for Win 8.1 multitouch touchpads
HID: remove hid_output_raw_report transport implementations
HID: sony: do not rely on hid_output_raw_report
HID: cp2112: remove the last hid_output_raw_report() call
HID: cp2112: remove various hid_out_raw_report calls
HID: multitouch: add support of other generic collections in hid-mt
HID: multitouch: remove pen special handling
HID: multitouch: remove registered devices with default behavior
HID: hidp: Add a comment that some devices depend on the current behavior of uniq
HID: sony: Prevent duplicate controller connections.
HID: sony: Perform a boundry check on the sixaxis battery level index.
HID: sony: Fix work queue issues
HID: sony: Fix multi-line comment styling
Pull trivial tree updates from Jiri Kosina:
"Usual rocket science -- mostly documentation and comment updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
sparse: fix comment
doc: fix double words
isdn: capi: fix "CAPI_VERSION" comment
doc: DocBook: Fix typos in xml and template file
Bluetooth: add module name for btwilink
driver core: unexport static function create_syslog_header
mmc: core: typo fix in printk specifier
ARM: spear: clean up editing mistake
net-sysfs: fix comment typo 'CONFIG_SYFS'
doc: Insert MODULE_ in module-signing macros
Documentation: update URL to hfsplus Technote 1150
gpio: update path to documentation
ixgbe: Fix format string in ixgbe_fcoe.
Kconfig: Remove useless "default N" lines
user_namespace.c: Remove duplicated word in comment
CREDITS: fix formatting
treewide: Fix typo in Documentation/DocBook
mm: Fix warning on make htmldocs caused by slab.c
ata: ata-samsung_cf: cleanup in header file
idr: remove unused prototype of idr_free()
Pull kvm updates from Paolo Bonzini:
"PPC and ARM do not have much going on this time. Most of the cool
stuff, instead, is in s390 and (after a few releases) x86.
ARM has some caching fixes and PPC has transactional memory support in
guests. MIPS has some fixes, with more probably coming in 3.16 as
QEMU will soon get support for MIPS KVM.
For x86 there are optimizations for debug registers, which trigger on
some Windows games, and other important fixes for Windows guests. We
now expose to the guest Broadwell instruction set extensions and also
Intel MPX. There's also a fix/workaround for OS X guests, nested
virtualization features (preemption timer), and a couple kvmclock
refinements.
For s390, the main news is asynchronous page faults, together with
improvements to IRQs (floating irqs and adapter irqs) that speed up
virtio devices"
* tag 'kvm-3.15-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (96 commits)
KVM: PPC: Book3S HV: Save/restore host PMU registers that are new in POWER8
KVM: PPC: Book3S HV: Fix decrementer timeouts with non-zero TB offset
KVM: PPC: Book3S HV: Don't use kvm_memslots() in real mode
KVM: PPC: Book3S HV: Return ENODEV error rather than EIO
KVM: PPC: Book3S: Trim top 4 bits of physical address in RTAS code
KVM: PPC: Book3S HV: Add get/set_one_reg for new TM state
KVM: PPC: Book3S HV: Add transactional memory support
KVM: Specify byte order for KVM_EXIT_MMIO
KVM: vmx: fix MPX detection
KVM: PPC: Book3S HV: Fix KVM hang with CONFIG_KVM_XICS=n
KVM: PPC: Book3S: Introduce hypervisor call H_GET_TCE
KVM: PPC: Book3S HV: Fix incorrect userspace exit on ioeventfd write
KVM: s390: clear local interrupts at cpu initial reset
KVM: s390: Fix possible memory leak in SIGP functions
KVM: s390: fix calculation of idle_mask array size
KVM: s390: randomize sca address
KVM: ioapic: reinject pending interrupts on KVM_SET_IRQCHIP
KVM: Bump KVM_MAX_IRQ_ROUTES for s390
KVM: s390: irq routing for adapter interrupts.
KVM: s390: adapter interrupt sources
1000-1099 is for configuring things. So auditd ignored such messages.
This is about actually logging what was configured. Move it into the
range for such types of messages.
Reported-by: Steve Grubb <sgrubb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Introduce a bit kernel and userspace exchange between each-other on
the init stage and turn writeback on if the userspace want this and
mount option 'allow_wbcache' is present (controlled by fusermount).
Also add each writable file into per-inode write list and call the
generic_file_aio_write to make use of the Linux page cache engine.
Signed-off-by: Maxim Patlasov <MPatlasov@parallels.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg KH:
"Here's the big USB pull request for 3.15-rc1.
The normal set of patches, lots of controller driver updates, and a
smattering of individual USB driver updates as well.
All have been in linux-next for a while"
* tag 'usb-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (249 commits)
xhci: Transition maintainership to Mathias Nyman.
USB: disable reset-resume when USB_QUIRK_RESET is set
USB: unbind all interfaces before rebinding any
usb: phy: Add ulpi IDs for SMSC USB3320 and TI TUSB1210
usb: gadget: tcm_usb_gadget: stop format strings
usb: gadget: f_fs: add missing spinlock and mutex unlock
usb: gadget: composite: switch over to ERR_CAST()
usb: gadget: inode: switch over to memdup_user()
usb: gadget: f_subset: switch over to PTR_RET
usb: gadget: lpc32xx_udc: fix wrong clk_put() sequence
USB: keyspan: remove dead debugging code
USB: serial: add missing newlines to dev_<level> messages.
USB: serial: add missing braces
USB: serial: continue to write on errors
USB: serial: continue to read on errors
USB: serial: make bulk_out_size a lower limit
USB: cypress_m8: fix potential scheduling while atomic
devicetree: bindings: document lsi,zevio-usb
usb: chipidea: add support for USB OTG controller on LSI Zevio SoCs
usb: chipidea: imx: Use dev_name() for ci_hdrc name to distinguish USBs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg KH:
"Here's the big char/misc driver updates for 3.15-rc1.
Lots of various things here, including the new mcb driver subsystem.
All of these have been in linux-next for a while"
* tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits)
extcon: Move OF helper function to extcon core and change function name
extcon: of: Remove unnecessary function call by using the name of device_node
extcon: gpio: Use SIMPLE_DEV_PM_OPS macro
extcon: palmas: Use SIMPLE_DEV_PM_OPS macro
mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro
mei: amthif: fix checkpatch error
mei: client.h fix checkpatch errors
mei: use cl_dbg where appropriate
mei: fix Unnecessary space after function pointer name
mei: report consistently copy_from/to_user failures
mei: drop pr_fmt macros
mei: make me hw headers private to me hw.
mei: fix memory leak of pending write cb objects
mei: me: do not reset when less than expected data is received
drivers: mcb: Fix build error discovered by 0-day bot
cs5535-mfgpt: Simplify dependencies
spmi: pm: drop bus-level PM suspend/resume routines
spmi: pmic_arb: make selectable on ARCH_QCOM
Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle
pch_phub: Report error writing MAC back to user
UHID_CREATE2:
HID report descriptor data (rd_data) is an array in struct uhid_create2_req,
instead of a pointer. Enables use from languages that don't support pointers,
e.g. Python.
UHID_INPUT2:
Data array is the last field of struct uhid_input2_req. Enables userspace to
write only the required bytes to kernel (ev.type + ev.u.input2.size + the part
of the data array that matters), instead of the entire struct uhid_input2_req.
Note:
UHID_CREATE2 increases the total size of struct uhid_event slightly, thus
increasing the size of messages that are queued for userspace. However, this
won't affect the userspace processing of these events.
[Jiri Kosina <jkosina@suse.cz>: adjust to hid_get_raw_report() and
hid_output_raw_report() API changes]
Signed-off-by: Petri Gynther <pgynther@google.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
If flags contain RENAME_EXCHANGE then exchange source and destination files.
There's no restriction on the type of the files; e.g. a directory can be
exchanged with a symlink.
Reviewed-by: J. Bruce Fields <bfields@redhat.com>
If this flag is specified and the target of the rename exists then the
rename syscall fails with EEXIST.
The VFS does the existence checking, so it is trivial to enable for most
local filesystems. This patch only enables it in ext4.
For network filesystems the VFS check is not enough as there may be a race
between a remote create and the rename, so these filesystems need to handle
this flag in their ->rename() implementations to ensure atomicity.
Andy writes about why this is useful:
"The trivial answer: to eliminate the race condition from 'mv -i'.
Another answer: there's a common pattern to atomically create a file
with contents: open a temporary file, write to it, optionally fsync
it, close it, then link(2) it to the final name, then unlink the
temporary file.
The reason to use link(2) is because it won't silently clobber the destination.
This is annoying:
- It requires an extra system call that shouldn't be necessary.
- It doesn't work on (IMO sensible) filesystems that don't support
hard links (e.g. vfat).
- It's not atomic -- there's an intermediate state where both files exist.
- It's ugly.
The new rename flag will make this totally sensible.
To be fair, on new enough kernels, you can also use O_TMPFILE and
linkat to achieve the same thing even more cleanly."
Suggested-by: Andy Lutomirski <luto@amacapital.net>
This allows to monitor carrier on/off transitions and detect link
flapping issues:
- new /sys/class/net/X/carrier_changes
- new rtnetlink IFLA_CARRIER_CHANGES (getlink)
Tested:
- grep . /sys/class/net/*/carrier_changes
+ ip link set dev X down/up
+ plug/unplug cable
- updated iproute2: prints IFLA_CARRIER_CHANGES
- iproute2 20121211-2 (debian): unchanged behavior
Signed-off-by: David Decotigny <decot@googlers.com>
NET_ADDR_* values are exported in the
/sys/class/net/<iface>/addr_assign_type sysfs attributes, and as such
constitutes an user-space ABI. Move the NET_ADDR_* definitions from
include/linux/netdevice.h to include/uapi/linux/netdevice.h
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
'spi/topic/sh-hspi', 'spi/topic/sh-msiof', 'spi/topic/sh-sci', 'spi/topic/sirf' and 'spi/topic/spidev' into spi-next
bt->width should be (bt)->width, and same for the other fields.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Cc: stable@vger.kernel.org # For 3.12 or upper
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next
John W. Linville says:
Please pull this batch of wireless updates intended for 3.15!
For the mac80211 bits, Johannes says:
"This has a whole bunch of bugfixes for things that went into -next
previously as well as some other bugfixes I didn't want to rush into
3.14 at this point. The rest of it is some cleanups and a few small
features, the biggest of which is probably Janusz's regulatory DFS CAC
time code."
For the Bluetooth bits, Gustavo says:
"One more pull request to 3.15. This is mostly and bug fix pull request, it
contains several fixes and clean up all over the tree, plus some small new
features."
For the NFC bits, Samuel says:
"This is the NFC pull request for 3.15. With this one we have:
- Support for ISO 15693 a.k.a. NFC vicinity a.k.a. Type 5 tags. ISO
15693 are long range (1 - 2 meters) vicinity tags/cards. The kernel
now supports those through the NFC netlink and digital APIs.
- Support for TI's trf7970a chipset. This chipset relies on the NFC
digital layer and the driver currently supports type 2, 4A and 5 tags.
- Support for NXP's pn544 secure firmare download. The pn544 C3 chipsets
relies on a different firmware download protocal than the C2 one. We
now support both and use the right one depending on the version we
detect at runtime.
- Support for 4A tags from the NFC digital layer.
- A bunch of cleanups and minor fixes from Axel Lin and Thierry Escande."
For the iwlwifi bits, Emmanuel says:
"We were sending a host command while the mutex wasn't held. This
led to hard-to-catch races."
And...
"I have a fix for a "merge damage" which is not really a merge
damage: it enables scheduled scan which has been disabled in
wireless.git. Since you merged wireless.git into wireless-next.git,
this can now be fixed in wireless-next.git.
Besides this, Alex made a workaround for a hardware bug. This fix
allows us to consume less power in S3. Arik and Eliad continue to
work on D0i3 which is a run-time power saving feature. Eliad also
contributes a few bits to the rate scaling logic to which Eyal adds his
own contribution. Avri dives deep in the power code - newer firmware
will allow to enable power save in newer scenarios. Johannes made a few
clean-ups. I have the regular amount of BT Coex boring stuff. I disable
uAPSD since we identified firmware bugs that cause packet loss. One
thing that do stand out is the udev event that we now send when the
FW asserts. I hope it will allow us to debug the FW more easily."
Also included is one last iwlwifi pull for a build breakage fix...
For the Atheros bits, Kalle says:
"Michal now did some optimisations and was able to improve throughput by
100 Mbps on our MIPS based AP135 platform. Chun-Yeow added some
workarounds to be able to better use ad-hoc mode. Ben improved log
messages and added support for MSDU chaining. And, as usual, also some
smaller fixes."
Beyond that...
Andrea Merello continues his rtl8180 refactoring, in preparation for
a long-awaited rtl8187 driver. We get a new driver (rsi) for the
RS9113 chip, from Fariya Fatima. And, of course, we get the usual
round of updates for ath9k, brcmfmac, mwifiex, wil6210, etc. as well.
We were exposing a function based on kernel config options to userspace.
This is wrong. Move it to the audit internal header.
Suggested-by: Chris Metcalf <cmetcalf@tilera.com>
This patch adds a pair of new ioctls to the PTP Hardware Clock device
interface. Using the ioctls, user space programs can query each pin to
find out its current function and also reprogram a different function
if desired.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
Introduce a new interrupt class for s390 adapter interrupts and enable
irqfds for s390.
This is depending on a new s390 specific vm capability, KVM_CAP_S390_IRQCHIP,
that needs to be enabled by userspace.
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Allow KVM_ENABLE_CAP to act on a vm as well as on a vcpu. This makes more
sense when the caller wants to enable a vm-related capability.
s390 will be the first user; wire it up.
Reviewed-by: Thomas Huth <thuth@linux.vnet.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
This patch adds the MBIM extended functional descriptor structure
defined in "Universal Serial Bus Communications Class Subclass
Specification for Mobile Broadband Interface Model, Revision 1.0,
Errata-1" published by USB-IF.
Signed-off-by: Ben Chan <benchan@chromium.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
lib/audit.c provides a generic function for auditing system calls.
This patch extends it for compat syscall support on bi-architectures
(32/64-bit) by adding lib/compat_audit.c.
What is required to support this feature are:
* add asm/unistd32.h for compat system call names
* select CONFIG_AUDIT_ARCH_COMPAT_GENERIC
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Acked-by: Richard Guy Briggs <rgb@redhat.com>
During an audit event, cache and print the value of the process's
proctitle value (proc/<pid>/cmdline). This is useful in situations
where processes are started via fork'd virtual machines where the
comm field is incorrect. Often times, setting the comm field still
is insufficient as the comm width is not very wide and most
virtual machine "package names" do not fit. Also, during execution,
many threads have their comm field set as well. By tying it back to
the global cmdline value for the process, audit records will be more
complete in systems with these properties. An example of where this
is useful and applicable is in the realm of Android. With Android,
their is no fork/exec for VM instances. The bare, preloaded Dalvik
VM listens for a fork and specialize request. When this request comes
in, the VM forks, and the loads the specific application (specializing).
This was done to take advantage of COW and to not require a load of
basic packages by the VM on very app spawn. When this spawn occurs,
the package name is set via setproctitle() and shows up in procfs.
Many of these package names are longer then 16 bytes, the historical
width of task->comm. Having the cmdline in the audit records will
couple the application back to the record directly. Also, on my
Debian development box, some audit records were more useful then
what was printed under comm.
The cached proctitle is tied to the life-cycle of the audit_context
structure and is built on demand.
Proctitle is controllable by userspace, and thus should not be trusted.
It is meant as an aid to assist in debugging. The proctitle event is
emitted during syscall audits, and can be filtered with auditctl.
Example:
type=AVC msg=audit(1391217013.924:386): avc: denied { getattr } for pid=1971 comm="mkdir" name="/" dev="selinuxfs" ino=1 scontext=system_u:system_r:consolekit_t:s0-s0:c0.c255 tcontext=system_u:object_r:security_t:s0 tclass=filesystem
type=SYSCALL msg=audit(1391217013.924:386): arch=c000003e syscall=137 success=yes exit=0 a0=7f019dfc8bd7 a1=7fffa6aed2c0 a2=fffffffffff4bd25 a3=7fffa6aed050 items=0 ppid=1967 pid=1971 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="mkdir" exe="/bin/mkdir" subj=system_u:system_r:consolekit_t:s0-s0:c0.c255 key=(null)
type=UNKNOWN[1327] msg=audit(1391217013.924:386): proctitle=6D6B646972002D70002F7661722F72756E2F636F6E736F6C65
Acked-by: Steve Grubb <sgrubb@redhat.com> (wrt record formating)
Signed-off-by: William Roberts <wroberts@tresys.com>
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
One patch to rename a newly introduced struct. The rest is
the rework of the IPsec virtual tunnel interface for ipv6 to
support inter address family tunneling and namespace crossing.
1) Rename the newly introduced struct xfrm_filter to avoid a
conflict with iproute2. From Nicolas Dichtel.
2) Introduce xfrm_input_afinfo to access the address family
dependent tunnel callback functions properly.
3) Add and use a IPsec protocol multiplexer for ipv6.
4) Remove dst_entry caching. vti can lookup multiple different
dst entries, dependent of the configured xfrm states. Therefore
it does not make to cache a dst_entry.
5) Remove caching of flow informations. vti6 does not use the the
tunnel endpoint addresses to do route and xfrm lookups.
6) Update the vti6 to use its own receive hook.
7) Remove the now unused xfrm_tunnel_notifier. This was used from vti
and is replaced by the IPsec protocol multiplexer hooks.
8) Support inter address family tunneling for vti6.
9) Check if the tunnel endpoints of the xfrm state and the vti interface
are matching and return an error otherwise.
10) Enable namespace crossing for vti devices.
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next
Pablo Neira Ayuso says:
Netfilter/IPVS updates for net-next
The following patchset contains Netfilter/IPVS updates for net-next,
most relevantly they are:
* cleanup to remove double semicolon from stephen hemminger.
* calm down sparse warning in xt_ipcomp, from Fan Du.
* nf_ct_labels support for nf_tables, from Florian Westphal.
* new macros to simplify rcu dereferences in the scope of nfnetlink
and nf_tables, from Patrick McHardy.
* Accept queue and drop (including reason for drop) to verdict
parsing in nf_tables, also from Patrick.
* Remove unused random seed initialization in nfnetlink_log, from
Florian Westphal.
* Allow to attach user-specific information to nf_tables rules, useful
to attach user comments to rule, from me.
* Return errors in ipset according to the manpage documentation, from
Jozsef Kadlecsik.
* Fix coccinelle warnings related to incorrect bool type usage for ipset,
from Fengguang Wu.
* Add hash:ip,mark set type to ipset, from Vytas Dauksa.
* Fix message for each spotted by ipset for each netns that is created,
from Ilia Mirkin.
* Add forceadd option to ipset, which evicts a random entry from the set
if it becomes full, from Josh Hunt.
* Minor IPVS cleanups and fixes from Andi Kleen and Tingwei Liu.
* Improve conntrack scalability by removing a central spinlock, original
work from Eric Dumazet. Jesper Dangaard Brouer took them over to address
remaining issues. Several patches to prepare this change come in first
place.
* Rework nft_hash to resolve bugs (leaking chain, missing rcu synchronization
on element removal, etc. from Patrick McHardy.
* Restore context in the rule deletion path, as we now release rule objects
synchronously, from Patrick McHardy. This gets back event notification for
anonymous sets.
* Fix NAT family validation in nft_nat, also from Patrick.
* Improve scalability of xt_connlimit by using an array of spinlocks and
by introducing a rb-tree of hashtables for faster lookup of accounted
objects per network. This patch was preceded by several patches and
refactorizations to accomodate this change including the use of kmem_cache,
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/nfc-next
Samuel Ortiz <sameo@linux.intel.com> says:
"NFC: 3.15: First pull request
detect at runtime.
Per IEEE 802.3*, the correct packet type for loopback 0x9000. There's
already one ETH_P_LOOP 0x0060, which has been there for ages, however it's
plainly wrong as anything that small is considered a length field.
We can't remove it because legacy, so add a new type which corresponds to
the correct id.
http://www.iana.org/assignments/ieee-802-numbers/ieee-802-numbers.xhtml
CC: "David S. Miller" <davem@davemloft.net>
CC: Stefan Richter <stefanr@s5r6.in-berlin.de>
CC: Simon Wunderlich <sw@simonwunderlich.de>
CC: Neil Jerram <Neil.Jerram@metaswitch.com>
CC: Simon Horman <horms@verge.net.au>
CC: Arvid Brodin <Arvid.Brodin@xdin.com>
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
drivers/net/wireless/ath/ath9k/recv.c
Rename v4l2_format_sdr to v4l2_sdr_format in order to keep it in
line with other formats.
Reported-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Antti Palosaari <crope@iki.fi>
Add volatile boolean control to indicate if tuner frequency synthesizer
is locked to requested frequency. That means tuner is able to receive
given frequency. Control is named as "PLL lock", since frequency
synthesizers are based of phase-locked-loop. Maybe more general name
could be wise still?
Cc: Hans Verkuil <hverkuil@xs4all.nl>
V4L2_SDR_FMT_CU8 — Complex unsigned 8-bit IQ sample
V4L2_SDR_FMT_CU16LE — Complex unsigned 16-bit little endian IQ sample
