commit c9ddbac9c89110f77cb0fa07e634aaf1194899aa upstream.
09a2c73ddfc7 ("PCI: Remove unused PCI_MSIX_FLAGS_BIRMASK definition")
removed PCI_MSIX_FLAGS_BIRMASK from an exported header because it was
unused in the kernel. But that breaks user programs that were using it
(QEMU in particular).
Restore the PCI_MSIX_FLAGS_BIRMASK definition.
[bhelgaas: changelog]
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 648a9bc5308d952f2c80772301b339f73026f013 upstream.
Since the hardware sometimes mysteriously totally flummoxes the 64bit
read of a 64bit register when read using a single instruction, split the
read into two instructions. Since the read here is of automatically
incrementing timestamp counters, we also have to be very careful in
order to make sure that it does not increment between the two
instructions.
However, since userspace tried to workaround this issue and so enshrined
this ABI for a broken hardware read and in the process neglected that
the read only fails in some environments, we have to introduce a new
uABI flag for userspace to request the 2x32 bit accurate read of the
timestamp.
v2: Fix alignment check and include details of the workaround for
userspace.
Reported-by: Karol Herbst <freedesktop@karolherbst.de>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=91317
Testcase: igt/gem_reg_read
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Michał Winiarski <michal.winiarski@intel.com>
Tested-by: Michał Winiarski <michal.winiarski@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This tells userspace that it's safe to use the RADEON_VA_UNMAP operation
of the DRM_RADEON_GEM_VA ioctl.
Cc: stable@vger.kernel.org
(NOTE: Backporting this commit requires at least backports of commits
26d4d129b6042197b4cbc8341c0618f99231af2f,
48afbd70ac7b6aa62e8d452091023941d8085f8a and
c29c0876ec05d51a93508a39b90b92c29ba6423d as well, otherwise using
RADEON_VA_UNMAP runs into trouble)
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Christian König <christian.koenig@amd.com>
Fixes userspace compilation error:
error: unknown type name ‘__virtio16’
__virtio16 tag;
Signed-off-by: Mikko Rapeli <mikko.rapeli@iki.fi>
Pablo Neira Ayuso says:
The following patchset contains Netfilter fixes for your net tree, they are:
1) Fix a leak in IPVS, the sysctl table is not released accordingly when
destroying a netns, patch from Tommi Rantala.
2) Fix a build error when TPROXY and socket are built-in but IPv6 defrag is
compiled as module, from Florian Westphal.
3) Fix TCP tracket wrt. RFC5961 challenge ACK when in LAST_ACK state, patch
from Jesper Dangaard Brouer.
4) Fix a bogus WARN_ON() in nf_tables when deleting a set element that stores
a map, from Mirek Kratochvil.
In compliance with RFC5961, the network stack send challenge ACK in
response to spurious SYN packets, since commit 0c228e833c88 ("tcp:
Restore RFC5961-compliant behavior for SYN packets").
This pose a problem for netfilter conntrack in state LAST_ACK, because
this challenge ACK is (falsely) seen as ACKing last FIN, causing a
false state transition (into TIME_WAIT).
The challenge ACK is hard to distinguish from real last ACK. Thus,
solution introduce a flag that tracks the potential for seeing a
challenge ACK, in case a SYN packet is let through and current state
is LAST_ACK.
When conntrack transition LAST_ACK to TIME_WAIT happens, this flag is
used for determining if we are expecting a challenge ACK.
Scapy based reproducer script avail here:
https://github.com/netoptimizer/network-testing/blob/master/scapy/tcp_hacks_3WHS_LAST_ACK.py
Fixes: 0c228e833c88 ("tcp: Restore RFC5961-compliant behavior for SYN packets")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
RTNH_F_EXTERNAL today is printed as "offload" in iproute2 output.
This patch renames the flag to be consistent with what the user sees.
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Pull networking fixes from David Miller:
1) Handle max TX power properly wrt VIFs and the MAC in iwlwifi, from
Avri Altman.
2) Use the correct FW API for scan completions in iwlwifi, from Avraham
Stern.
3) FW monitor in iwlwifi accidently uses unmapped memory, fix from Liad
Kaufman.
4) rhashtable conversion of mac80211 station table was buggy, the
virtual interface was not taken into account. Fix from Johannes
Berg.
5) Fix deadlock in rtlwifi by not using a zero timeout for
usb_control_msg(), from Larry Finger.
6) Update reordering state before calculating loss detection, from
Yuchung Cheng.
7) Fix off by one in bluetooth firmward parsing, from Dan Carpenter.
8) Fix extended frame handling in xiling_can driver, from Jeppe
Ledet-Pedersen.
9) Fix CODEL packet scheduler behavior in the presence of TSO packets,
from Eric Dumazet.
10) Fix NAPI budget testing in fm10k driver, from Alexander Duyck.
11) macvlan needs to propagate promisc settings down the the lower
device, from Vlad Yasevich.
12) igb driver can oops when changing number of rings, from Toshiaki
Makita.
13) Source specific default routes not handled properly in ipv6, from
Markus Stenberg.
14) Use after free in tc_ctl_tfilter(), from WANG Cong.
15) Use softirq spinlocking in netxen driver, from Tony Camuso.
16) Two ARM bpf JIT fixes from Nicolas Schichan.
17) Handle MSG_DONTWAIT properly in ring based AF_PACKET sends, from
Mathias Kretschmer.
18) Fix x86 bpf JIT implementation of FROM_{BE16,LE16,LE32}, from Alexei
Starovoitov.
19) ll_temac driver DMA maps TX packet header with incorrect length, fix
from Michal Simek.
20) We removed pm_qos bits from netdevice.h, but some indirect
references remained. Kill them. From David Ahern.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
net: Remove remaining remnants of pm_qos from netdevice.h
e1000e: Add pm_qos header
net: phy: micrel: Fix regression in kszphy_probe
net: ll_temac: Fix DMA map size bug
x86: bpf_jit: fix FROM_BE16 and FROM_LE16/32 instructions
netns: return RTM_NEWNSID instead of RTM_GETNSID on a get
Update be2net maintainers' email addresses
net_sched: gred: use correct backlog value in WRED mode
pppoe: drop pppoe device in pppoe_unbind_sock_work
net: qca_spi: Fix possible race during probe
net: mdio-gpio: Allow for unspecified bus id
af_packet / TX_RING not fully non-blocking (w/ MSG_DONTWAIT).
bnx2x: limit fw delay in kdump to 5s after boot
ARM: net: delegate filter to kernel interpreter when imm_offset() return value can't fit into 12bits.
ARM: net fix emit_udiv() for BPF_ALU | BPF_DIV | BPF_K intruction.
mpls: Change reserved label names to be consistent with netbsd
usbnet: avoid integer overflow in start_xmit
netxen_nic: use spin_[un]lock_bh around tx_clean_lock (2)
net: xgene_enet: Set hardware dependency
net: amd-xgbe: Add hardware dependency
Since these are now visible to userspace it is nice to be consistent
with BSD (sys/netmpls/mpls.h in netBSD).
Signed-off-by: Tom Herbert <tom@herbertland.com>
Move to include/uapi/linux/mpls.h to be externally visibile.
connecting peer to its clients
Add functionality to enable the port mapper on the passive side to provide to its
clients the actual (non-mapped) ip/tcp address information of the connecting peer
1) Adding remote_info_cb() to process the address info of the connecting peer
The address info is provided by the user space port mapper service when
the connection is initiated by the peer
2) Adding a hash list to store the remote address info
3) Adding functionality to add/remove the remote address info
After the info has been provided to the port mapper client,
it is removed from the hash list
Signed-off-by: Tatyana Nikolova <tatyana.e.nikolova@intel.com>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-05-04
Here's the first bluetooth-next pull request for 4.2:
- Various fixes for at86rf230 driver
- ieee802154: trace events support for rdev->ops
- HCI UART driver refactoring
- New Realtek IDs added to btusb driver
- Off-by-one fix for rtl8723b in btusb driver
- Refactoring of btbcm driver for both UART & USB use
Please let me know if there are any issues pulling. Thanks.
Here the "other side" refers to the guest or host.
Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com>
Some Congestion Control modules can provide per flow information,
but current way to get this information is to use netlink.
Like TCP_INFO, let's add TCP_CC_INFO so that applications can
issue a getsockopt() if they have a socket file descriptor,
instead of playing complex netlink games.
Sample usage would be :
union tcp_cc_info info;
socklen_t len = sizeof(info);
if (getsockopt(fd, SOL_TCP, TCP_CC_INFO, &info, &len) == -1)
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Yuchung Cheng <ycheng@google.com>
We would like that optional info provided by Congestion Control
modules using netlink can also be read using getsockopt()
This patch changes get_info() to put this information in a buffer,
instead of skb, like tcp_get_info(), so that following patch
can reuse this common infrastructure.
This patch tracks total number of payload bytes received on a TCP socket.
This is the sum of all changes done to tp->rcv_nxt
RFC4898 named this : tcpEStatsAppHCThruOctetsReceived
This is a 64bit field, and can be fetched both from TCP_INFO
getsockopt() if one has a handle on a TCP socket, or from inet_diag
netlink facility (iproute2/ss patch will follow)
Note that tp->bytes_received was placed near tp->rcv_nxt for
best data locality and minimal performance impact.
Cc: Matt Mathis <mattmathis@google.com>
Cc: Eric Salo <salo@google.com>
Cc: Martin Lau <kafai@fb.com>
Cc: Chris Rapier <rapier@psc.edu>
This patch tracks total number of bytes acked for a TCP socket.
This is the sum of all changes done to tp->snd_una, and allows
for precise tracking of delivered data.
RFC4898 named this : tcpEStatsAppHCThruOctetsAcked
Note that tp->bytes_acked was placed near tp->snd_una for
Pull NFS client updates from Trond Myklebust:
"Another set of mainly bugfixes and a couple of cleanups. No new
functionality in this round.
Highlights include:
Stable patches:
- Fix a regression in /proc/self/mountstats
- Fix the pNFS flexfiles O_DIRECT support
- Fix high load average due to callback thread sleeping
Bugfixes:
- Various patches to fix the pNFS layoutcommit support
- Do not cache pNFS deviceids unless server notifications are enabled
- Fix a SUNRPC transport reconnection regression
- make debugfs file creation failure non-fatal in SUNRPC
- Another fix for circular directory warnings on NFSv4 "junctioned"
mountpoints
- Fix locking around NFSv4.2 fallocate() support
- Truncating NFSv4 file opens should also sync O_DIRECT writes
- Prevent infinite loop in rpcrdma_ep_create()
Features:
- Various improvements to the RDMA transport code's handling of
memory registration
- Various code cleanups"
* tag 'nfs-for-4.1-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (55 commits)
fs/nfs: fix new compiler warning about boolean in switch
nfs: Remove unneeded casts in nfs
NFS: Don't attempt to decode missing directory entries
Revert "nfs: replace nfs_add_stats with nfs_inc_stats when add one"
NFS: Rename idmap.c to nfs4idmap.c
NFS: Move nfs_idmap.h into fs/nfs/
NFS: Remove CONFIG_NFS_V4 checks from nfs_idmap.h
NFS: Add a stub for GETDEVICELIST
nfs: remove WARN_ON_ONCE from nfs_direct_good_bytes
nfs: fix DIO good bytes calculation
nfs: Fetch MOUNTED_ON_FILEID when updating an inode
sunrpc: make debugfs file creation failure non-fatal
nfs: fix high load average due to callback thread sleeping
NFS: Reduce time spent holding the i_mutex during fallocate()
NFS: Don't zap caches on fallocate()
xprtrdma: Make rpcrdma_{un}map_one() into inline functions
xprtrdma: Handle non-SEND completions via a callout
xprtrdma: Add "open" memreg op
xprtrdma: Add "destroy MRs" memreg op
xprtrdma: Add "reset MRs" memreg op
Pull second batch of KVM changes from Paolo Bonzini:
"This mostly includes the PPC changes for 4.1, which this time cover
Book3S HV only (debugging aids, minor performance improvements and
some cleanups). But there are also bug fixes and small cleanups for
ARM, x86 and s390.
The task_migration_notifier revert and real fix is still pending
review, but I'll send it as soon as possible after -rc1"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (29 commits)
KVM: arm/arm64: check IRQ number on userland injection
KVM: arm: irqfd: fix value returned by kvm_irq_map_gsi
KVM: VMX: Preserve host CR4.MCE value while in guest mode.
KVM: PPC: Book3S HV: Use msgsnd for signalling threads on POWER8
KVM: PPC: Book3S HV: Translate kvmhv_commence_exit to C
KVM: PPC: Book3S HV: Streamline guest entry and exit
KVM: PPC: Book3S HV: Use bitmap of active threads rather than count
KVM: PPC: Book3S HV: Use decrementer to wake napping threads
KVM: PPC: Book3S HV: Don't wake thread with no vcpu on guest IPI
KVM: PPC: Book3S HV: Get rid of vcore nap_count and n_woken
KVM: PPC: Book3S HV: Move vcore preemption point up into kvmppc_run_vcpu
KVM: PPC: Book3S HV: Minor cleanups
KVM: PPC: Book3S HV: Simplify handling of VCPUs that need a VPA update
KVM: PPC: Book3S HV: Accumulate timing information for real-mode code
KVM: PPC: Book3S HV: Create debugfs file for each guest's HPT
KVM: PPC: Book3S HV: Add ICP real mode counters
KVM: PPC: Book3S HV: Move virtual mode ICP functions to real-mode
KVM: PPC: Book3S HV: Convert ICS mutex lock to spin lock
KVM: PPC: Book3S HV: Add guest->host real mode completion counters
KVM: PPC: Book3S HV: Add helpers for lock/unlock hpte
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Here are a few fixes that have been pending since the previous pull
request: a regression fix for HD-audio multiple SPDIF / HDMI devices,
several ALC256 codec fixes, a couple of i915 HDMI audio fixes, and
various small fixes.
Nothing exciting, just boring, but things good to have"
* tag 'sound-fix-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - fix headset mic detection problem for one more machine
ALSA: hda/realtek - Fix Headphone Mic doesn't recording for ALC256
ALSA: hda - fix "num_steps = 0" error on ALC256
ALSA: usb-audio: Fix audio output on Roland SC-D70 sound module
ALSA: hda - add AZX_DCAPS_I915_POWERWELL to Baytrail
ALSA: hda - only sync BCLK to the display clock for Haswell & Broadwell
ALSA: hda - Mute headphone pin on suspend on XPS13 9333
sound/oss: fix deadlock in sequencer_ioctl(SNDCTL_SEQ_OUTOFBAND)
ALSA: asound.h - use SNDRV_CTL_ELEM_ID_NAME_MAXLEN
ALSA: hda - potential (but unlikely) uninitialized variable
ALSA: hda - Fix regression for slave SPDIF setups
ALSA: intel8x0: Check pci_iomap() success for DEVICE_ALI
ALSA: hda - simplify azx_has_pm_runtime
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Lots of activity in target land the last months.
The highlights include:
- Convert fabric drivers tree-wide to target_register_template() (hch
+ bart)
- iser-target hardening fixes + v1.0 improvements (sagi)
- Convert iscsi_thread_set usage to kthread.h + kill
iscsi_target_tq.c (sagi + nab)
- Add support for T10-PI WRITE_STRIP + READ_INSERT operation (mkp +
sagi + nab)
- DIF fixes for CONFIG_DEBUG_SG=y + UNMAP file emulation (akinobu +
sagi + mkp)
- Extended TCMU ABI v2 for future BIDI + DIF support (andy + ilias)
- Fix COMPARE_AND_WRITE handling for NO_ALLLOC drivers (hch + nab)
Thanks to everyone who contributed this round with new features,
bug-reports, fixes, cleanups and improvements.
Looking forward, it's currently shaping up to be a busy v4.2 as well"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (69 commits)
target: Put TCMU under a new config option
target: Version 2 of TCMU ABI
target: fix tcm_mod_builder.py
target/file: Fix UNMAP with DIF protection support
target/file: Fix SG table for prot_buf initialization
target/file: Fix BUG() when CONFIG_DEBUG_SG=y and DIF protection enabled
target: Make core_tmr_abort_task() skip TMFs
target/sbc: Update sbc_dif_generate pr_debug output
target/sbc: Make internal DIF emulation honor ->prot_checks
target/sbc: Return INVALID_CDB_FIELD if DIF + sess_prot_type disabled
target: Ensure sess_prot_type is saved across session restart
target/rd: Don't pass incomplete scatterlist entries to sbc_dif_verify_*
target: Remove the unused flag SCF_ACK_KREF
target: Fix two sparse warnings
target: Fix COMPARE_AND_WRITE with SG_TO_MEM_NOALLOC handling
target: simplify the target template registration API
target: simplify target_xcopy_init_pt_lun
target: remove the unused SCF_CMD_XCOPY_PASSTHROUGH flag
target/rd: reduce code duplication in rd_execute_rw()
tcm_loop: fixup tpgt string to integer conversion
Pull md updates from Neil Brown:
"More updates that usual this time. A few have performance impacts
which hould mostly be positive, but RAID5 (in particular) can be very
work-load ensitive... We'll have to wait and see.
Highlights:
- "experimental" code for managing md/raid1 across a cluster using
DLM. Code is not ready for general use and triggers a WARNING if
used. However it is looking good and mostly done and having in
mainline will help co-ordinate development.
- RAID5/6 can now batch multiple (4K wide) stripe_heads so as to
handle a full (chunk wide) stripe as a single unit.
- RAID6 can now perform read-modify-write cycles which should help
performance on larger arrays: 6 or more devices.
- RAID5/6 stripe cache now grows and shrinks dynamically. The value
set is used as a minimum.
- Resync is now allowed to go a little faster than the 'mininum' when
there is competing IO. How much faster depends on the speed of the
devices, so the effective minimum should scale with device speed to
some extent"
* tag 'md/4.1' of git://neil.brown.name/md: (58 commits)
md/raid5: don't do chunk aligned read on degraded array.
md/raid5: allow the stripe_cache to grow and shrink.
md/raid5: change ->inactive_blocked to a bit-flag.
md/raid5: move max_nr_stripes management into grow_one_stripe and drop_one_stripe
md/raid5: pass gfp_t arg to grow_one_stripe()
md/raid5: introduce configuration option rmw_level
md/raid5: activate raid6 rmw feature
md/raid6 algorithms: xor_syndrome() for SSE2
md/raid6 algorithms: xor_syndrome() for generic int
md/raid6 algorithms: improve test program
md/raid6 algorithms: delta syndrome functions
raid5: handle expansion/resync case with stripe batching
raid5: handle io error of batch list
RAID5: batch adjacent full stripe write
raid5: track overwrite disk count
raid5: add a new flag to track if a stripe can be batched
raid5: use flex_array for scribble data
md raid0: access mddev->queue (request queue member) conditionally because it is not set when accessed from dm-raid
md: allow resync to go faster when there is competing IO.
md: remove 'go_faster' option from ->sync_request()
Pull nfsd updates from Bruce Fields:
"A quiet cycle this time; this is basically entirely bugfixes.
The few that aren't cc'd to stable are cleanup or seemed unlikely to
affect anyone much"
* 'for-4.1' of git://linux-nfs.org/~bfields/linux:
uapi: Remove kernel internal declaration
nfsd: fix nsfd startup race triggering BUG_ON
nfsd: eliminate NFSD_DEBUG
nfsd4: fix READ permission checking
nfsd4: disallow SEEK with special stateids
nfsd4: disallow ALLOCATE with special stateids
nfsd: add NFSEXP_PNFS to the exflags array
nfsd: Remove duplicate macro define for max sec label length
nfsd: allow setting acls with unenforceable DENYs
nfsd: NFSD_FAULT_INJECTION depends on DEBUG_FS
nfsd: remove unused status arg to nfsd4_cleanup_open_state
nfsd: remove bogus setting of status in nfsd4_process_open2
NFSD: Use correct reply size calculating function
NFSD: Using path_equal() for checking two paths
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs update from Dave Chinner:
"This update contains:
- RENAME_WHITEOUT support
- conversion of per-cpu superblock accounting to use generic counters
- new inode mmap lock so that we can lock page faults out of
truncate, hole punch and other direct extent manipulation functions
to avoid racing mmap writes from causing data corruption
- rework of direct IO submission and completion to solve data
corruption issue when running concurrent extending DIO writes.
Also solves problem of running IO completion transactions in
interrupt context during size extending AIO writes.
- FALLOC_FL_INSERT_RANGE support for inserting holes into a file via
direct extent manipulation to avoid needing to copy data within the
file
- attribute block header field overflow fix for 64k block size
filesystems
- Lots of changes to log messaging to be more informative and concise
when errors occur. Also prevent a lot of unnecessary log spamming
due to cascading failures in error conditions.
- lots of cleanups and bug fixes
One thing of note is the direct IO fixes that we merged last week
after the window opened. Even though a little late, they fix a user
reported data corruption and have been pretty well tested. I figured
there was not much point waiting another 2 weeks for -rc1 to be
released just so I could send them to you..."
* tag 'xfs-for-linus-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (49 commits)
xfs: using generic_file_direct_write() is unnecessary
xfs: direct IO EOF zeroing needs to drain AIO
xfs: DIO write completion size updates race
xfs: DIO writes within EOF don't need an ioend
xfs: handle DIO overwrite EOF update completion correctly
xfs: DIO needs an ioend for writes
xfs: move DIO mapping size calculation
xfs: factor DIO write mapping from get_blocks
xfs: unlock i_mutex in xfs_break_layouts
xfs: kill unnecessary firstused overflow check on attr3 leaf removal
xfs: use larger in-core attr firstused field and detect overflow
xfs: pass attr geometry to attr leaf header conversion functions
xfs: disallow ro->rw remount on norecovery mount
xfs: xfs_shift_file_space can be static
xfs: Add support FALLOC_FL_INSERT_RANGE for fallocate
xfs: Fix incorrect positive ENOMEM return
xfs: xfs_mru_cache_insert() should use GFP_NOFS
xfs: %pF is only for function pointers
xfs: fix shadow warning in xfs_da3_root_split()
NFS: NFSoRDMA Client Changes
This patch series creates an operation vector for each of the different
memory registration modes. This should make it easier to one day increase
credit limit, rsize, and wsize.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
This file is only used internally to the NFS v4 module, so it doesn't
need to be in the global include path. I also renamed it from
nfs_idmap.h to nfs4idmap.h to emphasize that it's an NFSv4-only include
file.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Some virtio internal cleanups, a new virtio device "virtio input", and
a change to allow the legacy virtio balloon.
Most excitingly, some lguest work! No seriously, I got some cleanup
patches"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio: drop virtio_device_is_legacy_only
virtio_pci: support non-legacy balloon devices
virtio_mmio: support non-legacy balloon devices
virtio_ccw: support non-legacy balloon devices
virtio: balloon might not be a legacy device
virtio_balloon: transitional interface
virtio_ring: Update weak barriers to use dma_wmb/rmb
virtio_pci_modern: switch to type-safe io accessors
virtio_pci_modern: type-safe io accessors
lguest: handle traps on the "interrupt suppressed" iret instruction.
virtio: drop a useless config read
virtio_config: reorder functions
Add virtio-input driver.
lguest: suppress interrupts for single insn, not range.
lguest: simplify lguest_iret
lguest: rename i386_head.S in the comments
lguest: explicitly set miscdevice's private_data NULL
lguest: fix pending interrupt test.
The enum nfs4_acl_whotype is only used in nfs4d's internal nfs4 acl
representation. No longer expose it to user space.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Commit f895b252d4edf ("sunrpc: eliminate RPC_DEBUG") introduced
use of IS_ENABLED() in a uapi header which leads to a build
failure for userspace apps trying to use <linux/nfsd/debug.h>:
linux/nfsd/debug.h:18:15: error: missing binary operator before token "("
#if IS_ENABLED(CONFIG_SUNRPC_DEBUG)
Since this was only used to define NFSD_DEBUG if CONFIG_SUNRPC_DEBUG
is enabled, replace instances of NFSD_DEBUG with CONFIG_SUNRPC_DEBUG.
Fixes: f895b252d4edf "sunrpc: eliminate RPC_DEBUG"
Signed-off-by: Mark Salter <msalter@redhat.com>
Reviewed-by: Jeff Layton <jlayton@primarydata.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- a new frontend driver for new ATSC devices: lgdt3306a
- a new sensor driver: ov2659
- a new platform driver: xilinx
- the m88ts2022 tuner driver was merged at ts2020 driver
- the media controller gained experimental support for DVB and hybrid
devices
- lots of random cleanups, fixes and improvements on media drivers
* tag 'media/v4.1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (404 commits)
[media] uvcvideo: add support for VIDIOC_QUERY_EXT_CTRL
[media] uvcvideo: fix cropcap v4l2-compliance failure
[media] media: omap3isp: remove unused clkdev
[media] coda: Add tracing support
[media] coda: drop dma_sync_single_for_device in coda_bitstream_queue
[media] coda: fix fill bitstream errors in nonstreaming case
[media] coda: call SEQ_END when the first queue is stopped
[media] coda: fail to start streaming if userspace set invalid formats
[media] coda: remove duplicate error messages for buffer allocations
[media] coda: move parameter buffer in together with context buffer allocation
[media] coda: allocate bitstream buffer from REQBUFS, size depends on the format
[media] coda: allocate per-context buffers from REQBUFS
[media] coda: use strlcpy instead of snprintf
[media] coda: bitstream payload is unsigned
[media] coda: fix double call to debugfs_remove
[media] coda: check kasprintf return value in coda_open
[media] coda: bitrate can only be set in kbps steps
[media] v4l2-mem2mem: no need to initialize b in v4l2_m2m_next_buf and v4l2_m2m_buf_remove
[media] s5p-mfc: set allow_zero_bytesused flag for vb2_queue_init
[media] coda: set allow_zero_bytesused flag for vb2_queue_init
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial updates from Greg KH:
"Here's the big tty/serial driver update for 4.1-rc1.
It was delayed for a bit due to some questions surrounding some of the
console command line parsing changes that are in here. There's still
one tiny regression for people who were previously putting multiple
console command lines and expecting them all to be ignored for some
odd reason, but Peter is working on fixing that. If not, I'll send a
revert for the offending patch, but I have faith that Peter can
address it.
Other than the console work here, there's the usual serial driver
updates and changes, and a buch of 8250 reworks to try to make that
driver easier to maintain over time, and have it support more devices
in the future.
All of these have been in linux-next for a while"
* tag 'tty-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (119 commits)
n_gsm: Drop unneeded cast on netdev_priv
sc16is7xx: expose RTS inversion in RS-485 mode
serial: 8250_pci: port failed after wakeup from S3
earlycon: 8250: Document kernel command line options
earlycon: 8250: Fix command line regression
earlycon: Fix __earlycon_table stride
tty: clean up the tty time logic a bit
serial: 8250_dw: only get the clock rate in one place
serial: 8250_dw: remove useless ACPI ID check
dmaengine: hsu: move memory allocation to GFP_NOWAIT
dmaengine: hsu: remove redundant pieces of code
serial: 8250_pci: add Intel Tangier support
dmaengine: hsu: add Intel Tangier PCI ID
serial: 8250_pci: replace switch-case by formula for Intel MID
tty: cpm_uart: replace CONFIG_8xx by CONFIG_CPM1
serial: jsm: some off by one bugs
serial: xuartps: Fix check in console_setup().
serial: xuartps: Get rid of register access macros.
serial: xuartps: Fix iobase use.
Some PowerNV systems include a hardware random-number generator.
This HWRNG is present on POWER7+ and POWER8 chips and is capable of
generating one 64-bit random number every microsecond. The random
numbers are produced by sampling a set of 64 unstable high-frequency
oscillators and are almost completely entropic.
PAPR defines an H_RANDOM hypercall which guests can use to obtain one
64-bit random sample from the HWRNG. This adds a real-mode
implementation of the H_RANDOM hypercall. This hypercall was
implemented in real mode because the latency of reading the HWRNG is
generally small compared to the latency of a guest exit and entry for
all the threads in the same virtual core.
Userspace can detect the presence of the HWRNG and the H_RANDOM
implementation by querying the KVM_CAP_PPC_HWRNG capability. The
H_RANDOM hypercall implementation will only be invoked when the guest
does an H_RANDOM hypercall if userspace first enables the in-kernel
H_RANDOM implementation using the KVM_CAP_PPC_ENABLE_HCALL capability.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
git://people.freedesktop.org/~airlied/linux into v4l_for_linus
* 'drm-next-merged' of git://people.freedesktop.org/~airlied/linux: (9717 commits)
media-bus: Fixup RGB444_1X12, RGB565_1X16, and YUV8_1X24 media bus format
hexdump: avoid warning in test function
fs: take i_mutex during prepare_binprm for set[ug]id executables
smp: Fix error case handling in smp_call_function_*()
iommu-common: Fix PARISC compile-time warnings
sparc: Make LDC use common iommu poll management functions
sparc: Make sparc64 use scalable lib/iommu-common.c functions
Break up monolithic iommu table/lock into finer graularity pools and lock
sparc: Revert generic IOMMU allocator.
tools/power turbostat: correct dumped pkg-cstate-limit value
tools/power turbostat: calculate TSC frequency from CPUID(0x15) on SKL
tools/power turbostat: correct DRAM RAPL units on recent Xeon processors
tools/power turbostat: Initial Skylake support
tools/power turbostat: Use $(CURDIR) instead of $(PWD) and add support for O= option in Makefile
tools/power turbostat: modprobe msr, if needed
tools/power turbostat: dump MSR_TURBO_RATIO_LIMIT2
tools/power turbostat: use new MSR_TURBO_RATIO_LIMIT names
Bluetooth: hidp: Fix regression with older userspace and flags validation
config: Enable NEED_DMA_MAP_STATE by default when SWIOTLB is selected
perf/x86/intel/pt: Fix and clean up error handling in pt_event_add()
That solves several merge conflicts:
Documentation/DocBook/media/v4l/subdev-formats.xml
Documentation/devicetree/bindings/vendor-prefixes.txt
drivers/staging/media/mn88473/mn88473.c
include/linux/kconfig.h
include/uapi/linux/media-bus-format.h
The ones at subdev-formats.xml and media-bus-format.h are not trivial.
That's why we opted to merge from DRM.
The initial version of TCMU (in 3.18) does not properly handle
bidirectional SCSI commands -- those with both an in and out buffer. In
looking to fix this it also became clear that TCMU's support for adding
new types of entries (opcodes) to the command ring was broken. We need
to fix this now, so that future issues can be handled properly by adding
new opcodes.
We make the most of this ABI break by enabling bidi cmd handling within
TCMP_OP_CMD opcode. Add an iov_bidi_cnt field to tcmu_cmd_entry.req.
This enables TCMU to describe bidi commands, but further kernel work is
needed for full bidi support.
Enlarge tcmu_cmd_entry_hdr by 32 bits by pulling in cmd_id and __pad1. Turn
__pad1 into two 8 bit flags fields, for kernel-set and userspace-set flags,
"kflags" and "uflags" respectively.
Update version fields so userspace can tell the interface is changed.
Update tcmu-design.txt with details of how new stuff works:
- Specify an additional requirement for userspace to set UNKNOWN_OP
(bit 0) in hdr.uflags for unknown/unhandled opcodes.
- Define how Data-In and Data-Out fields are described in req.iov[]
Changed in v2:
- Change name of SKIPPED bit to UNKNOWN bit
- PAD op does not set the bit any more
- Change len_op helper functions to take just len_op, not the whole struct
- Change version to 2 in missed spots, and use defines
- Add 16 unused bytes to cmd_entry.req, in case additional SAM cmd
parameters need to be included
- Add iov_dif_cnt field to specify buffers used for DIF info in iov[]
- Rearrange fields to naturally align cdb_off
- Handle if userspace sets UNKNOWN_OP by indicating failure of the cmd
- Wrap some overly long UPDATE_HEAD lines
(Add missing req.iov_bidi_cnt + req.iov_dif_cnt zeroing - Ilias)
Signed-off-by: Andy Grover <agrover@redhat.com>
Reviewed-by: Ilias Tsitsimpis <iliastsi@arrikto.com>
The merge is clean, but the arm build fails afterwards,
due to API changes in the regulator tree.
I've included the patch into the merge to fix the build.
Change the constant values for RGB444_1X12, RGB565_1X16, and YUV8_1X24 media
bus formats in anticipation of a merge conflict with the media tree, where
the old values are already taken by RBG888_1X24, RGB888_1X32_PADHI, and
VUY8_1X24, respectively.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper updates from Mike Snitzer:
- the most extensive changes this cycle are the DM core improvements to
add full blk-mq support to request-based DM.
- disabled by default but user can opt-in with CONFIG_DM_MQ_DEFAULT
- depends on some blk-mq changes from Jens' for-4.1/core branch so
that explains why this pull is built on linux-block.git
- update DM to use name_to_dev_t() rather than open-coding a less
capable device parser.
- includes a couple small improvements to name_to_dev_t() that offer
stricter constraints that DM's code provided.
- improvements to the dm-cache "mq" cache replacement policy.
- a DM crypt crypt_ctr() error path fix and an async crypto deadlock
fix
- a small efficiency improvement for DM crypt decryption by leveraging
immutable biovecs
- add error handling modes for corrupted blocks to DM verity
- a new "log-writes" DM target from Josef Bacik that is meant for file
system developers to test file system integrity at particular points
in the life of a file system
- a few DM log userspace cleanups and fixes
- a few Documentation fixes (for thin, cache, crypt and switch)
* tag 'dm-4.1-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: (34 commits)
dm crypt: fix missing error code return from crypt_ctr error path
dm crypt: fix deadlock when async crypto algorithm returns -EBUSY
dm crypt: leverage immutable biovecs when decrypting on read
dm crypt: update URLs to new cryptsetup project page
dm: add log writes target
dm table: use bool function return values of true/false not 1/0
dm verity: add error handling modes for corrupted blocks
dm thin: remove stale 'trim' message documentation
dm delay: use msecs_to_jiffies for time conversion
dm log userspace base: fix compile warning
dm log userspace transfer: match wait_for_completion_timeout return type
dm table: fall back to getting device using name_to_dev_t()
init: stricter checking of major:minor root= values
init: export name_to_dev_t and mark name argument as const
dm: add 'use_blk_mq' module param and expose in per-device ro sysfs attr
dm: optimize dm_mq_queue_rq to _not_ use kthread if using pure blk-mq
dm: add full blk-mq support to request-based DM
dm: impose configurable deadline for dm_request_fn's merge heuristic
dm sysfs: introduce ability to add writable attributes
dm: don't start current request if it would've merged with the previous
we have defined SNDRV_CTL_ELEM_ID_NAME_MAXLEN as size of name array so use
this define instead of numeric value
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
1) Fix verifier memory corruption and other bugs in BPF layer, from
Alexei Starovoitov.
2) Add a conservative fix for doing BPF properly in the BPF classifier
of the packet scheduler on ingress. Also from Alexei.
3) The SKB scrubber should not clear out the packet MARK and security
label, from Herbert Xu.
4) Fix oops on rmmod in stmmac driver, from Bryan O'Donoghue.
5) Pause handling is not correct in the stmmac driver because it
doesn't take into consideration the RX and TX fifo sizes. From
Vince Bridgers.
6) Failure path missing unlock in FOU driver, from Wang Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits)
net: dsa: use DEVICE_ATTR_RW to declare temp1_max
netns: remove BUG_ONs from net_generic()
IB/ipoib: Fix ndo_get_iflink
sfc: Fix memcpy() with const destination compiler warning.
altera tse: Fix network-delays and -retransmissions after high throughput.
net: remove unused 'dev' argument from netif_needs_gso()
act_mirred: Fix bogus header when redirecting from VLAN
inet_diag: fix access to tcp cc information
tcp: tcp_get_info() should fetch socket fields once
net: dsa: mv88e6xxx: Add missing initialization in mv88e6xxx_set_port_state()
skbuff: Do not scrub skb mark within the same name space
Revert "net: Reset secmark when scrubbing packet"
bpf: fix two bugs in verification logic when accessing 'ctx' pointer
bpf: fix bpf helpers to use skb->mac_header relative offsets
stmmac: Configure Flow Control to work correctly based on rxfifo size
stmmac: Enable unicast pause frame detect in GMAC Register 6
stmmac: Read tx-fifo-depth and rx-fifo-depth from the devicetree
stmmac: Add defines and documentation for enabling flow control
stmmac: Add properties for transmit and receive fifo sizes
stmmac: fix oops on rmmod after assigning ip addr
Merge third patchbomb from Andrew Morton:
- various misc things
- a couple of lib/ optimisations
- provide DIV_ROUND_CLOSEST_ULL()
- checkpatch updates
- rtc tree
- befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs
- ptrace fixes
- fork() fixes
- seccomp cleanups
- more mmap_sem hold time reductions from Davidlohr
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits)
proc: show locks in /proc/pid/fdinfo/X
docs: add missing and new /proc/PID/status file entries, fix typos
drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic
Documentation/spi/spidev_test.c: fix warning
drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type
.gitignore: ignore *.tar
MAINTAINERS: add Mediatek SoC mailing list
tomoyo: reduce mmap_sem hold for mm->exe_file
powerpc/oprofile: reduce mmap_sem hold for exe_file
oprofile: reduce mmap_sem hold for mm->exe_file
mips: ip32: add platform data hooks to use DS1685 driver
lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text
x86: switch to using asm-generic for seccomp.h
sparc: switch to using asm-generic for seccomp.h
powerpc: switch to using asm-generic for seccomp.h
parisc: switch to using asm-generic for seccomp.h
mips: switch to using asm-generic for seccomp.h
microblaze: use asm-generic for seccomp.h
arm: use asm-generic for seccomp.h
seccomp: allow COMPAT sigreturn overrides
ENOSYS is the mechanism used by user code to detect whether the running
kernel implements a given system call. It should not be returned by
anything except an unimplemented system call.
Unfortunately, it is rather frequently used in the kernel to indicate that
various new functions of existing system calls are not implemented. This
should be discouraged.
Improve the comment in errno.h to help clarify ENOSYS's purpose.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Joe Perches <joe@perches.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull quota and udf updates from Jan Kara:
"The pull contains quota changes which complete unification of XFS and
VFS quota interfaces (so tools can use either interface to manipulate
any filesystem). There's also a patch to support project quotas in
VFS quota subsystem from Li Xi.
Finally there's a bunch of UDF fixes and cleanups and tiny cleanup in
reiserfs & ext3"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: (21 commits)
udf: Update ctime and mtime when directory is modified
udf: return correct errno for udf_update_inode()
ext3: Remove useless condition in if statement.
vfs: Add general support to enforce project quota limits
reiserfs: fix __RASSERT format string
udf: use int for allocated blocks instead of sector_t
udf: remove redundant buffer_head.h includes
udf: remove else after return in __load_block_bitmap()
udf: remove unused variable in udf_table_free_blocks()
quota: Fix maximum quota limit settings
quota: reorder flags in quota state
quota: paranoia: check quota tree root
quota: optimize i_dquot access
quota: Hook up Q_XSETQLIM for id 0 to ->set_info
xfs: Add support for Q_SETINFO
quota: Make ->set_info use structure with neccesary info to VFS and XFS
quota: Remove ->get_xstate and ->get_xstatev callbacks
gfs2: Convert to using ->get_state callback
xfs: Convert to using ->get_state callback
quota: Wire up Q_GETXSTATE and Q_GETXSTATV calls to work with ->get_state
For the short-term solution, lets fix bpf helper functions to use
skb->mac_header relative offsets instead of skb->data in order to
get the same eBPF programs with cls_bpf and act_bpf work on ingress
and egress qdisc path. We need to ensure that mac_header is set
before calling into programs. This is effectively the first option
from below referenced discussion.
More long term solution for LD_ABS|LD_IND instructions will be more
intrusive but also more beneficial than this, and implemented later
as it's too risky at this point in time.
I.e., we plan to look into the option of moving skb_pull() out of
eth_type_trans() and into netif_receive_skb() as has been suggested
as second option. Meanwhile, this solution ensures ingress can be
used with eBPF, too, and that we won't run into ABI troubles later.
For dealing with negative offsets inside eBPF helper functions,
we've implemented bpf_skb_clone_unwritable() to test for unwriteable
headers.
Reference: http://thread.gmane.org/gmane.linux.network/359129/focus=359694
Fixes: 608cd71a9c7c ("tc: bpf: generalize pedit action")
Fixes: 91bc4822c3d6 ("tc: bpf: add checksum helpers")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Pull sound updates from Takashi Iwai:
"There have been major modernization with the standard bus: in ALSA
sequencer core and HD-audio. Also, HD-audio receives the regmap
support replacing the in-house cache register cache code. These
changes shouldn't impact the existing behavior, but rather
refactoring.
In addition, HD-audio got the code split to a core library part and
the "legacy" driver parts. This is a preliminary work for adapting
the upcoming ASoC HD-audio driver, and the whole transition is still
work in progress, likely finished in 4.1.
Along with them, there are many updates in ASoC area as usual, too:
lots of cleanups, Intel code shuffling, etc.
Here are some highlights:
ALSA core:
- PCM: the audio timestamp / wallclock enhancement
- PCM: fixes in DPCM management
- Fixes / cleanups of user-space control element management
- Sequencer: modernization using the standard bus
HD-audio:
- Modernization using the standard bus
- Regmap support
- Use standard runtime PM for codec power saving
- Widget-path based power-saving for IDT, VIA and Realtek codecs
- Reorganized sysfs entries for each codec object
- More Dell headset support
ASoC:
- Move of jack registration to the card level
- Lots of ASoC cleanups, mainly moving things from the CODEC level to
the card level
- Support for DAPM routes specified by both the machine driver and DT
- Continuing improvements to rcar
- pcm512x enhacements
- Intel platforms updates
- rt5670 updates / fixes
- New platforms / devices: some non-DSP Qualcomm platforms, Google's
Storm platform, Maxmim MAX98925 CODECs and the Ingenic JZ4780 SoC
Misc:
- ice1724: Improved ESI W192M support
- emu10k1: Emu 1010 fixes/enhancement"
* tag 'sound-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (411 commits)
ALSA: hda - set GET bit when adding a vendor verb to the codec regmap
ALSA: hda/realtek - Enable the ALC292 dock fixup on the Thinkpad T450
ALSA: hda - Fix another race in runtime PM refcounting
ALSA: hda - Expose codec type sysfs
ALSA: ctl: fix to handle several elements added by one operation for userspace element
ASoC: Intel: fix array_size.cocci warnings
ASoC: n810: Automatically disconnect non-connected pins
ASoC: n810: Consistently pass the card DAPM context to n810_ext_control()
ASoC: davinci-evm: Use card DAPM context to access widgets
ASoC: mop500_ab8500: Use card DAPM context to access widgets
ASoC: wm1133-ev1: Use card DAPM context to access widgets
ASoC: atmel: Improve machine driver compile test coverage
ASoC: atmel: Add dependency to SND_SOC_I2C_AND_SPI where necessary
ALSA: control: Fix a typo of SNDRV_CTL_ELEM_ACCESS_TLV_* with SNDRV_CTL_TLV_OP_*
ALSA: usb-audio: Don't attempt to get Microsoft Lifecam Cinema sample rate
ASoC: rnsd: fix build regression without CONFIG_OF
ALSA: emu10k1: add toggles for E-mu 1010 optical ports
ALSA: ctl: fill identical information to return value when adding userspace elements
ALSA: ctl: fix a bug to return no identical information in info operation for userspace controls
ALSA: ctl: confirm to return all identical information in 'activate' event
Commit e5863d9ad ("dm: allocate requests in target when stacking on
blk-mq devices") served as the first step toward fully utilizing blk-mq
in request-based DM -- it enabled stacking an old-style (request_fn)
request_queue ontop of the underlying blk-mq device(s). That first step
didn't improve performance of DM multipath ontop of fast blk-mq devices
(e.g. NVMe) because the top-level old-style request_queue was severely
limited by the queue_lock.
The second step offered here enables stacking a blk-mq request_queue
ontop of the underlying blk-mq device(s). This unlocks significant
performance gains on fast blk-mq devices, Keith Busch tested on his NVMe
testbed and offered this really positive news:
"Just providing a performance update. All my fio tests are getting
roughly equal performance whether accessed through the raw block
device or the multipath device mapper (~470k IOPS). I could only push
~20% of the raw iops through dm before this conversion, so this latest
tree is looking really solid from a performance standpoint."
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Tested-by: Keith Busch <keith.busch@intel.com>
Pull networking updates from David Miller:
1) Add BQL support to via-rhine, from Tino Reichardt.
2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers
can support hw switch offloading. From Floria Fainelli.
3) Allow 'ip address' commands to initiate multicast group join/leave,
from Madhu Challa.
4) Many ipv4 FIB lookup optimizations from Alexander Duyck.
5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel
Borkmann.
6) Remove the ugly compat support in ARP for ugly layers like ax25,
rose, etc. And use this to clean up the neigh layer, then use it to
implement MPLS support. All from Eric Biederman.
7) Support L3 forwarding offloading in switches, from Scott Feldman.
8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed
up route lookups even further. From Alexander Duyck.
9) Many improvements and bug fixes to the rhashtable implementation,
from Herbert Xu and Thomas Graf. In particular, in the case where
an rhashtable user bulk adds a large number of items into an empty
table, we expand the table much more sanely.
10) Don't make the tcp_metrics hash table per-namespace, from Eric
Biederman.
11) Extend EBPF to access SKB fields, from Alexei Starovoitov.
12) Split out new connection request sockets so that they can be
established in the main hash table. Much less false sharing since
hash lookups go direct to the request sockets instead of having to
go first to the listener then to the request socks hashed
underneath. From Eric Dumazet.
13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk.
14) Support stable privacy address generation for RFC7217 in IPV6. From
Hannes Frederic Sowa.
15) Hash network namespace into IP frag IDs, also from Hannes Frederic
Sowa.
16) Convert PTP get/set methods to use 64-bit time, from Richard
Cochran.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits)
fm10k: Bump driver version to 0.15.2
fm10k: corrected VF multicast update
fm10k: mbx_update_max_size does not drop all oversized messages
fm10k: reset head instead of calling update_max_size
fm10k: renamed mbx_tx_dropped to mbx_tx_oversized
fm10k: update xcast mode before synchronizing multicast addresses
fm10k: start service timer on probe
fm10k: fix function header comment
fm10k: comment next_vf_mbx flow
fm10k: don't handle mailbox events in iov_event path and always process mailbox
fm10k: use separate workqueue for fm10k driver
fm10k: Set PF queues to unlimited bandwidth during virtualization
fm10k: expose tx_timeout_count as an ethtool stat
fm10k: only increment tx_timeout_count in Tx hang path
fm10k: remove extraneous "Reset interface" message
fm10k: separate PF only stats so that VF does not display them
fm10k: use hw->mac.max_queues for stats
fm10k: only show actual queues, not the maximum in hardware
fm10k: allow creation of VLAN on default vid
fm10k: fix unused warnings
Virtio 1.0 doesn't include a modern balloon device.
But it's not a big change to support a transitional
balloon device: this has the advantage of supporting
existing drivers, transparently.
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"You will get the following new drivers:
- Qualcomm PM8941 power key drver
- ChipOne icn8318 touchscreen controller driver
- Broadcom iProc touchscreen and keypad drivers
- Semtech SX8654 I2C touchscreen controller driver
ALPS driver now supports newer SS4 devices; Elantech got a fix that
should make it work on some ASUS laptops; and a slew of other
enhancements and random fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (51 commits)
Input: alps - non interleaved V2 dualpoint has separate stick button bits
Input: alps - fix touchpad buttons getting stuck when used with trackpoint
Input: atkbd - document "no new force-release quirks" policy
Input: ALPS - make alps_get_pkt_id_ss4_v2() and others static
Input: ALPS - V7 devices can report 5-finger taps
Input: ALPS - add support for SS4 touchpad devices
Input: ALPS - refactor alps_set_abs_params_mt()
Input: elantech - fix absolute mode setting on some ASUS laptops
Input: atmel_mxt_ts - split out touchpad initialisation logic
Input: atmel_mxt_ts - implement support for T100 touch object
Input: cros_ec_keyb - fix clearing keyboard state on wakeup
Input: gscps2 - drop pci_ids dependency
Input: synaptics - allocate 3 slots to keep stability in image sensors
Input: Revert "Revert "synaptics - use dmax in input_mt_assign_slots""
Input: MT - make slot assignment work for overcovered solutions
mfd: tc3589x: enforce device-tree only mode
Input: tc3589x - localize platform data
Input: tsc2007 - Convert msecs to jiffies only once
Input: edt-ft5x06 - remove EV_SYN event report
Input: edt-ft5x06 - allow to setting the maximum axes value through the DT
Pull VFIO updates from Alex Williamson:
- VFIO platform bus driver support (Baptiste Reynal, Antonios Motakis,
testing and review by Eric Auger)
- Split VFIO irqfd support to separate module (Alex Williamson)
- vfio-pci VGA arbiter client (Alex Williamson)
- New vfio-pci.ids= module option (Alex Williamson)
- vfio-pci D3 power state support for idle devices (Alex Williamson)
* tag 'vfio-v4.1-rc1' of git://github.com/awilliam/linux-vfio: (30 commits)
vfio-pci: Fix use after free
vfio-pci: Move idle devices to D3hot power state
vfio-pci: Remove warning if try-reset fails
vfio-pci: Allow PCI IDs to be specified as module options
vfio-pci: Add VGA arbiter client
vfio-pci: Add module option to disable VGA region access
vgaarb: Stub vga_set_legacy_decoding()
vfio: Split virqfd into a separate module for vfio bus drivers
vfio: virqfd_lock can be static
vfio: put off the allocation of "minor" in vfio_create_group
vfio/platform: implement IRQ masking/unmasking via an eventfd
vfio: initialize the virqfd workqueue in VFIO generic code
vfio: move eventfd support code for VFIO_PCI to a separate file
vfio: pass an opaque pointer on virqfd initialization
vfio: add local lock for virqfd instead of depending on VFIO PCI
vfio: virqfd: rename vfio_pci_virqfd_init and vfio_pci_virqfd_exit
vfio: add a vfio_ prefix to virqfd_enable and virqfd_disable and export
vfio/platform: support for level sensitive interrupts
vfio/platform: trigger an interrupt via eventfd
vfio/platform: initial interrupts support code
