path: root/include/video/sh_mobile_lcdc.h
2010-05-25fbdev: move FBIO_WAITFORVSYNC to linux/fb.hGrazvydas Ignotas
FBIO_WAITFORVSYNC is currently implemented by matroxfb, atyfb, intelfb and more. All of them keep redefining the same FBIO_WAITFORVSYNC macro over and over again, so move it to linux/fb.h and clean up those duplicate defines. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Maik Broemme <mbroemme@plusserver.de> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Hiremath, Vaibhav" <hvaibhav@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-16video: sh_mobile_lcdcfb: Add wait for vsync.Phil Edworthy
Added FBIO_WAITFORVSYNC ioctl for SH-Mobile devices. Tested on MS7724 and MigoR boards against 2.6.33-rc7. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-09sh: add a start_transfer() callback to the LCDC driverMagnus Damm
This patch adds a ->start_transfer() callback to the driver sh_mobile_lcdcfb.c. The callback is used to program the LCDC panel in the case of one-shot mode. Needed by the LCD controller used on the KFR2R09 board. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22video: sh_mobile_lcdcfb deferred io supportMagnus Damm
This patch adds sh_mobile_lcdcfb deferred io support for SYS panels. The LCDC hardware block managed by the sh_mobile_lcdcfb driver supports RGB or SYS panel configurations. SYS panels come with an external display controller that is resposible for refreshing the actual LCD panel. RGB panels are controlled directly by the LCDC and they need to be refreshed by the LCDC hardware. In the case of SYS panels we can save some power by configuring the LCDC hardware block in one-shot mode. In this one-shot mode panel refresh is managed by software. This works well together with deferred io since it allows us to stop clocks for most of the time and only enable clocks when we actually want to trigger an update. When there is no fbdev activity the clocks are kept stopped which allows us to deep sleep. The refresh rate in deferred io mode is set using platform data. The same platform data can also be used to disable deferred io mode. As with other deferred io frame buffers user space code should use fsync() on the frame buffer device to trigger an update. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-20video: add sh_mobile_lcdc platform flagsMagnus Damm
Add platform data flags for detailed lcd display configuration. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-20video: remove unused sh_mobile_lcdc platform dataMagnus Damm
Remove lddckr from the platform data, these days we calculate the register value from clock source and clock dividers anyway. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-01video: sh_mobile_lcdcfb: Support HAVE_CLK=n configurations.Paul Mundt
This provides a workaround for users of sh_mobile_lcdcfb that don't define HAVE_CLK and have otherwise sane clock initialization. At the same time, move the sh_mobile_lcdc.h header to include/video/. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
