path: root/include/video/tdfx.h
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: mtrr supportKrzysztof Helt
This patch adds mtrr support to the tdfxfb driver. It also kills one redundant include and initialization value. [akpm@linux-foundation.org: cleanups] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: hardware cursorKrzysztof Helt
This patch adds hardware cursor support to the tdfxfb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: code improvementsKrzysztof Helt
This patch improves source code mainly by killing redundant variable loads, reducing number of variables, simplifying conditional branches, etc. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tdfxfb: coding style improvementKrzysztof Helt
This patch contains coding style improvements to the tdfxfb driver (white spaces, indentations, long lines). It also moves fb_ops structure to the end of file, so forward declarations of ops functions are redundant. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-10[PATCH] fbdev: tdfxfb: Driver cleanupsAntonino A. Daplas
- remove unneeded casts - move memory for pseudo_palette inside struct tdfxfb_par - whitespace changes Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Clean-up and bug fix for tdfxfb framebuffer size detectionRichard Drummond
Attached is a patch against 2.6.11.7 which tidies up the tdfxfb framebuffer size detection code a little and fixes the broken support for Voodoo4/5 cards. (I haven't tested this on a Voodoo5, however, because I don't have the hardware). Signed-off-by: Richard Drummond <evilrich@rcdrummond.net> Cc: <linux-fbdev-devel@lists.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
