path: root/include/video/trident.h
2008-07-24tridentfb: add imageblit acceleration for Blade3D familyKrzysztof Helt
Add imageblit acceleration for the Blade3D family of cores. The code is based on code from the cyblafb driver. It is a step toward assimilating back the cyblafb driver into the tridentfb driver. The cyblafb driver handles a subfamily of the Trident Blade3d cores. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: source code improvementsKrzysztof Helt
This patch contains general source code improvments: - more simple functions are inline - removes some meaningless output and the VERSION string as it is no use - eng_par is moved into the tridentfb_par - removed small section of code for CyberBladeXPAi1 which is maybe right for only one resolution and refresh rate and is probably redundant now - other minor improvements Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: acceleration code improvementsKrzysztof Helt
This patch brings various acceleration improvements: - set copyarea/fillrect for non-accelerated framebuffer (fix) - remove 15 bpp depth handling to simplify code as it hardly works (15 bpp handling was obviously missing in some switches) - add fb_sync call and move waiting before accelerated function to make acceleration more asynchronous to cpu (few % of speed improvement) - add cpu_relax() call in waiting loops - make longer register names and name more registers - move registers' definition to header - general code improvements (shortening, simplifying) Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: add TGUI 9440 supportKrzysztof Helt
Add support for TGUI 9440 chip. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: improved register values on TGUI 9680Krzysztof Helt
Improved values for some registers after Xorg Trident driver. The main problem was that values set by BIOS have been ignored. This patch completely remove random pixels ("snow") on the TGUI 9680 and 9440 (not supported yet by the driver). It does not help with the "snow" on 3DImage and Blade3D cards. There is also small improvement in timing calculations (hblank start and vblank start) Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: make use of functions and constants from the vga.hKrzysztof Helt
Make use of functions and constants from the vga.h header to compact the code and make it more readable. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: convert is_blade and is_xp macros into functionsKrzysztof Helt
This patch converts the is_blade() and is_xp() macros into local functions. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: move global flat panel variable into structureKrzysztof Helt
This patch moves flat panel indicator into tridentfb_par structure and removes related global variables and macros. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
