commit bb24153a3f13dd0dbc1f8055ad97fe346d598f66 upstream.
The default delay 5 jiffies is too much when the kernel is compiled with
HZ=100 - it results in jumpy cursor in Xwindow.
In order to find out the optimal delay, I benchmarked the driver on
1280x720x30fps video. I found out that with HZ=1000, 10ms is acceptable,
but with HZ=250 or HZ=300, we need 4ms, so that the video is played
without any frame skips.
This patch changes the delay to this value.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Fix race conditions with unplug/replug behavior, in particular
take care not to hold up USB probe/disconnect for long-running
framebuffer operations and rely on usb to handle teardown.
Fix for kernel panic reported with new F17 multiseat support.
Reported-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Bernie Thompson <bernie@plugable.com>
Fixes earlier problems where monitor would not return from blank
Test with any DisplayLink-based USB 2.0 graphics adapter
sudo nano /sys/class/graphics/fb?/blank
and write out single digit FB_BLANK_* code from include/linux/fb.h
Supports on (0), blank (1), suspend (2,3), powerdown (4)
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
This kills off all of the dl_xxx() printk wrappers and simply stubs in a
pr_fmt() definition to accomplish the same thing.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The edid length is fixed, so use the standard definition consistently.
udlfb has undergone a fair bit of cleanup recently and is effectively at
the point where it can be liberated from staging purgatory and promoted
to a real driver.
The outstanding cleanups are all minor, with some of them dependent on
drivers/video headers, so these will be done incrementally from udlfb's
new home.
Requested-by: Bernie Thompson <bernie@plugable.com>
