path: root/include/video
2019-05-24Add support for DVI monitorsRobert Winkler
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 6877ada3d15adf762cae8b7edce979a77ebc0313) (cherry picked from commit 51394b5f2b7ecfcc87c43c41e630c3e49fce3003)
2019-03-27MLK-20546-2: drm/imx/dcss: check status bit when handling interruptsLaurentiu Palcu
Double check that the DTG IRQ STATUS register bit is set when handling the vblank and CTXLD kick interrupts to make sure we avoid spurious interrupts and kick the CTXLD in a bad moment. Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com> Reviewed-by: Robert Chiras <robert.chiras@nxp.com> (cherry picked from commit cc56e4e07f623d0b831e0f8347f2f3198697ee20)
2019-02-12MLK-17537-9: gpu/imx: dcss: Add support for mode_validRobert Chiras
Implement mode_valid and mode_fixup functions for the dcss-crtc driver so that DCSS can filter-out unsupported modes and save the configuration for the supported ones. Use mode_fixup to apply the saved configuration of a supported mode. The mechanism to determine if a mode is supported or not is made in dcss-dtg. Also, add 2 new clocks: - pll: this is the video PLL that provides the pixel clock; it's rate needs to be set such that the pixel clock can be achieved - pll_src*: this is an oscillator that can be used as source clock for the video pll; currently, there are possible maximum 3 pll sources, defined as pll_src1, pll_src2 and pll_src3. The actual clocks that can be used as pll source are: CLK_25M, CLK_27M and CLK_PHY_27MHZ Removed the pdiv_clk and pout_clk and replaced them with pix_clk, since out of those two only one was used: pdiv_clk, representing the pixel clock. In dcss-dtg, each mode is tested and if we can achieve it's pixel clock we save this mode configuration into an internal list and apply this configuration later on when mode_fixup is called. Signed-off-by: Robert Chiras <robert.chiras@nxp.com> Reviewed-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
2019-02-12MLK-20671-1 gpu: imx: dpu: framegen: Add helpers to get/clear sec chan statusLiu Ying
This patch adds two helpers to get and clear FrameGen secondary channel status respectively. Via the two helpers, users may know if there is empty FIFO read request on this channel or not after getting the status. And, if yes, users may choose to clear the status. According to the IP spec, the empty FIFO read request indicates that data stream from a Fetch unit(e.g., AXI bandwidth not sufficient) fell down. Assuming the display driver sets things up properly, the falling down is very likely caused by the insufficient AXI bandwidth, that is, display underrun. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MGS-4381 [#ccc] Refined the licence for the file viv-metadata.hYong Gan
Change the licence to GPL. Signed-off-by: Yong Gan <yong.gan@nxp.com>
2019-02-12MLK-20301 gpu: imx: dpu: layerblend: Remove several invalid registers & wrappersLiu Ying
The layerblend units don't contain the CONTROLWORD, CURPIXELCNT, LASTPIXELCNT and PERFCOUNTER registers, so let's remove them and their wrappers(no one is calling them), which were introduced accidentally. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19879 drm/imx: dpu: crtc: Support aux stream as master when pc is usedLiu Ying
Pixel combiner uses two display streams to drive a single display. Either of the two display streams can be master stream and the other slave stream. This patch supports auxiliary stream as master stream when pixel combiner is used. The master stream ID can be specified via the newly introduced entry 'master_stream_id' in the device type of the DPU(s) in a particular SoC. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19823 drm/imx: dpu: crtc: Get store resource via platform dataLiu Ying
Store9 unit can be shared bewteen display engine(for sync mode fixup) and blit engine. It's proper to get the store resource in the DPU common driver and then pass it to relevant client drivers. From the CRTC driver point of view, it's straightforward to get the store resource via platform data instead of getting it directly, which avoids the wrong situation where getting it twice(one time for one of the two CRTCs of one DPU, respectively). Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-18848-3: drm: imx: dcss: split vblank irq enable routineLaurentiu Palcu
Currently, when enabling/disabling vblank interrupt, we also enable/disable the CTXLD kick interrupt. Most of the time this is fine, because when vblank gets disabled user-space does not submit any buffers and CTXLD kick interrupt is not needed. There is one case when we actually need to be able to have the CTXLD kick interrupt enabled: when disabling CRTC. Vblank interrupt, in this case, is disabled before the crtc_atomic_disable routine is called. However, we still need CTXLD to push the changes to SUBSAM and DTG. This patch will create a routine just for enabling/disabling CTXLD kick interrupt and move the code from vblank routine to the new one. Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
2019-02-12MLK-19460-2: drm: imx: dcss: remove PM_QoSLaurentiu Palcu
This patch removes PM_QoS request from DCSS driver. This will allow the A-53 cores to go idle even when DCSS is used. Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
2019-02-12MLK-19413-27 gpu: imx: dpu: extdst: Add extdst_pixengcfg_syncmode_master() ↵Liu Ying
helper This patch adds extdst_pixengcfg_syncmode_master() helper support so that the callers may control if a extdst is master or slave when it works in sync mode. The bit16 of extdst's PIXENGCFG_STATIC register controls this and it's a part of sync mode fixup logic. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-26 gpu: imx: dpu: framegen: Support two helpers for secondary ↵Liu Ying
syncup status This patch adds framegen_secondary_is_syncup() and framegen_wait_for_secondary_syncup() helpers support so that the callers may know a framegen's syncup status for the secondary input. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-25 gpu: imx: dpu: framegen: Add framegen_syncmode_fixup() helperLiu Ying
Bit7 of framegen's SECSTATCONFIG register is used to control the sync mode fixup logic implemented in framegen. This patch adds framegen_syncmode_fixup() helper so that the callers may enable/disable the fixup logic for a framegen. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-24 gpu: imx: dpu: common: Add store9 support for sync mode fixupLiu Ying
Bit16 of store9's PIXENGCFG_STATIC register is used to control the sync mode fixup logic implemented in store9. So, let's add store9 support in the DPU core driver and export a function for users to enable/disable the fixup logic. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-23 gpu: imx: dpu: Add constframe_framedimenstions_copy_prim() ↵Liu Ying
helper support This patch adds constframe_framedimenstions_copy_prim() helper support so that callers may may copy frame dimensions from a primary constframe to the relevant secondary constframe. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-22 gpu: imx: dpu: Add pixel combiner supportLiu Ying
This patch adds pixel combiner support in the DPU core driver. Users may get and enable/disable/control a pixel combiner instant via tcon functions and may tell if pixel combiner is available for a particular DPU variant via the dpu_has_pc() helper and if it is needed in a specific usecase via the dpu_get_syncmode_min_prate() and dpu_get_singlemode_max_width() helpers. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-18 gpu: imx: tcon: Add side-by-side supportLiu Ying
This patch adds side-by-side support for tcon so that two tcons can participate in the dual display streams to work with pixel combiner to drive a high pixel rate display. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-17 gpu: imx: dpu: framegen: Add side-by-side supportLiu Ying
This patch adds side-by-side support for framegen so that two framegens can work in sync mode to participate in the dual display streams to drive a high pixel rate display via a pixel combiner. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-16 gpu: imx: dpu: tcon: Add tcon_is_master/slave() helpers supportLiu Ying
This patch adds tcon_is_master/slave() helpers support so that callers may know if a tcon is a master or slave tcon. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-15 gpu: imx: dpu: extdst: Add extdst_is_master() helper supportLiu Ying
This patch adds extdst_is_master() helper support so that callers may know if a extdst is a master extdst or not. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-14 gpu: imx: dpu: framegen: Add framegen_is_master/slave() helper ↵Liu Ying
support This patch adds framegen_is_master/slave() helpers support so that callers may know if a framegen is a master or slave framegen. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-12 gpu: imx: dpu: framegen: Add helper framegen_syncmode() supportLiu Ying
This patch adds helper framegen_syncmode() support so that callers may control the sync mode of a framegen. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-11 gpu: imx: dpu: common: Add di_grp_id in display client pdev's dataLiu Ying
This patch adds a new di_grp_id entry in display client pdev's data so that the relevant display platform driver may know the display group ID of the display device. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-10 gpu: imx: dpu: Add helpers to peek at auxiliary display submodulesLiu Ying
This patch adds dpu_aux_{unit}_peek() helpers so that callers may peek at auxiliary display submodules. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19413-8 gpu: imx: Add imx8 pixel combiner supportLiu Ying
This patch adds i.MX8 pixel combiner driver support. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-19114-2 gpu: imx: imx8-prefetch: Remove has_prefetech_fixup from devtypesLiu Ying
There are prefetch engine fixups embedded in the updated i.MX8QM silicons. So, prefetch engines in all i.MX8 variants should be the same. Let's remove has_prefetech_fixup from devtypes which is no more needed. Signed-off-by: Liu Ying <victor.liu@nxp.com> (cherry picked from commit 875c31a70f3527c59cc597a10a88c39f3a0095df)
2019-02-12MLK-19274: drm: imx: dcss: add rotation functionalityLaurentiu Palcu
This patch will allow userspace to rotate planes by setting the 'rotation' property. Generally, 0 and 180 rotations are allowed for pretty much all 8-bit xRGB and 2-plane YUV420 formats. 90/270 rotations can be performed only for non-compressed tiled GPU xRGB formats. Tiled YUV420 formats do not allow rotations at all because these formats need DTRC for de-tiling and DTRC has no rotation support. For more info, consult the DPR Features chapter in the reference manual. Test example: modetest -M imx-drm -w 27:rotation:4 -w 32:rotation:33 -w 27:alpha:30 -s 42@31:3840x2160-60@XR24 -P 32@31:3840x2160@NV21 The above will perform: * 180 degree rotation of primary plane (XR24); * vertical flip of first overlay plane (rotate-0 | reflect-y); * set primary plane alpha to 30; Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
2019-02-12MLK-19158-2 drm/imx: lcdif: improve output bus format configFancy Fang
According to LCDIF specification, the input pixel data width and the output pixel data width can be different, and this conversion is done by LCDIF automatically. So config the output data width according to the requested bus format from the encoder, instead to be same with the input pixel data width. Signed-off-by: Fancy Fang <chen.fang@nxp.com> (cherry picked from commit bfd27f6d71d86a7f2fc8314f082565db3682b925)
2019-02-12MLK-19152-1 gpu: imx: lcdif: realize fb horizontal crop via Pigeon ModeFancy Fang
According to the LCDIF specification, the Legacy Mode does not support cropping function in the horizontal direction, so add Pigeon Mode which can support this kind of function. And when enable this mode, the legacy horizontal timings configuration should use stride value but not the active width, and related pigeon configuration should use the active width but not the stride value. Signed-off-by: Fancy Fang <chen.fang@nxp.com> (cherry picked from commit e6da9542693dd585972897f62748a101f5726a74)
2019-02-12MLK-18873: drm: imx: dcss: request PM QoS only when VBLANK is onLaurentiu Palcu
DCSS needs PM QoS in order to keep interrupt latency low. Otherwise, page flipping will not work smooth enough because CTXLD will not be triggered in time. Currently, PM QoS is requested all the time but that does not allow the CPUs to go idle. Hence, this leads to increased power consumption. This patch will change how PM QoS is requested by doing it only when VBLANK is enabled/disabled. The VBLANK interrupt is enabled just before a commit takes place and disabled after one second after last commit. This will allow DCSS to function properly and, also, allow CPUs to go idle whenever there's no buffer submitted. Exception to this is when DTRC is used (when DCSS is passed tiled buffers). In this case, PM QoS will always be active, even if no buffer is submitted, because DTRC banks need to be switched in CTXLD ISR, so that DCSS does not underrun. DTRC does not have the REPEAT feature, as the rest of DCSS does. Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
2019-02-12MLK-18680-1: drm: imx: dcss: low latency tracing mechanismLaurentiu Palcu
This patch adds a DCSS tracing mechanism that introduces as low latency as possible, so that it does not affect timings. Instead of text, 64 bit tags will be logged, together with the system time in nanoseconds. Based on these, post-processing can be done on any PC to compute deltas, delays, missed buffers, etc. Example usage: echo 1 > /sys/module/imx_dcss_core/parameters/tracing gplay-1.0 movie.mpg echo 0 > /sys/module/imx_dcss_core/parameters/tracing To dump the trace: cat /sys/kernel/debug/imx-dcss/dump_trace_log > trace.txt With the help of a scripting language (awk), the trace can then be post-processed and analyzed on the PC. Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
2019-02-12MGS-3560 [#imx-913] Enable DRM compression for mscale boardYong Gan
Refine the code for compressed format support. Date: June 29, 2018 Signed-off-by: Yong Gan <yong.gan@nxp.com>
2019-02-12MLK-17925: drm: imx: dcss: fix tearingLaurentiu Palcu
The video tearing appeared only when the application used 2 buffers. That's because, sometimes, the context loader could be armed after the DB event came in the frame trace. That made a buffer submitted in frame N end up on screen in frame N+2 because the context loader waits for the next DB event. Since vblank events are sent at the end of the frame, by the time the buffer lands on screen, the application will reuse it while it's being displayed, hence the tearing effect. This patch moves the CTXLD trigger moment all the way to the end of the frame trace, just before DB event arrives. This will leave the application plenty of time to submit new buffers. In the event that the trigger moment is missed (application submits a buffer right at the end of a frame trace), then we're not signalling the next VBLANK event to application. This way, application will know that the buffer is still needed and will not submit a new one. Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
2019-02-12MLK-18576-3 drm/imx: ldb: Add dual channel mode support for i.MX8dx/dxp/qxpLiu Ying
i.MX8dx/dxp/qxp use two LDBs(one primary, one auxiliary) to support dual channel mode. This patch adds the dual channel mode support for i.MX8dx/dxp/qxp. Note that the drivers contain specific sequence needed by this mode - LDB VSYNC polarity and channel selection settings should be configured into the register a bit earlier in ->atomic_mode_set instead of in ->enable, and DC subsystem pixel link enablement is moved from the DPU driver to the LDB driver to make sure it happens later than LDB clocks enablement in ->enable. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-18560 drm/imx: lcdif: refine bus format sanity check for planeFancy Fang
Add an function to get the LCDIF controller supported bus formats according to the pixel format bpp. And change the bus format sanity check in the plane's atomic check to see if the bus format required by the peripheral attached to LCDIF can be supported by LCDIF. Signed-off-by: Fancy Fang <chen.fang@nxp.com>
2019-02-12MLK-18535-3 gpu: imx: add LCDIF core driverFancy Fang
The LCDIF core driver is responsible to provide controller registers configuration and create the platform devices for the child port nodes. And the platform devices later will attach to the corresponding DRM/KMS drivers via name match. Signed-off-by: Fancy Fang <chen.fang@nxp.com>
2019-02-12MLK-18477-2 gpu: imx: dpu: framegen: Explicitly use bypass clk for TMDS encoderLiu Ying
The framegen driver should get PLL clock, bypass clock and display selection/mux clock via device tree if available. It may use bypass clock when a TMDS encoder is connected with the framegen, otherwise, PLL clock is used. This way, the assigned-clocks and assigned-clock-parents device tree properties can be removed from the dpu device tree node. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-18347 gpu: imx: dpu: Correct baddr and stride for PRG x/y offsetLiu Ying
We use PRG x/y offset to do in-micro-tile cropping for new DPR/PRG IPs. When tile resolving is enabled by using the new IPs, the design team indicates that DPU fetch unit base address and DPU/PRG stride need to be calculated in the below steps: 1) prg_Baddr = dpr_Baddr 2) tmp_dpu_Baddr = prg_Baddr + prg_x_offset * bytes_per_pixel 3) tmp_burst_size = 1 << (ffs(tmp_dpu_Baddr) - 1) tmp_burst_size = round_up(tmp_burst_size, 8) burst_size = min(tmp_burst_size, 128) 4) tmp_dpu_stride = dpu_width * bytes_per_pixel 5) dpu_stride = round_up(tmp_dpu_stride + round_up(tmp_dpu_Baddr % 8, 8), burst_size) 6) dpu_Baddr = tmp_dpu_Baddr + prg_y_offset * dpu_stride 7) prg_stride = dpu_stride The legacy DPR/PRG IPs and linear formats driver logic should not be essentially touched. This patch implements the above calculation method in the drivers so that all valid in-micro-tile x/y cropping arguments can be supported. Without this, at least, some cropping cases with odd x value would fail. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-18211 gpu: imx: layerblend: Zero sec alpha when sec input is from scalerLiu Ying
It turns out that local alpha value of the secondary input is set to 0xFF by the hardware if the secondary input is from scaler(hscaler or vscaler). This makes the layer on this secondary input accidentally cover the layer with higher z-order(if it exists), even though the layer with lower z-order doesn't supply local alpha. This patch zeros the secondary local alpha value to prevent the issue from happening. Users are unlikely to expect local alpha to be correctly scaled, so it looks fine to simply zero the alpha. If we find the unlikely case, the KMS driver may later explicitly do atomic check to invalidate the case. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-18162 gpu: imx: dpu: Abstract fetch unit conceptLiu Ying
This patch abstracts fetch unit concept for all the fetch units we have - fetchdecode, fetcheco, fetchlayer and fetchwarp. They have some similar features and operations which are suitable to be abstracted. A lot of boilerplate code is removed. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-18123-1 gpu: imx: imx8_prg: Rename prg_put_auxilary() to prg_set_primary()Liu Ying
A cosmetic change to rename prg_put_auxilary() to prg_set_primary(). Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-18101-5 gpu: imx: imx8_prg: Add prg_put_auxiliary() helper supportYuchou Gan
This patch adds prg_put_auxiliary() helper support so that users may set a particular PRG not serve as an auxiliary one. Signed-off-by: Yuchou Gan <yuchou.gan@nxp.com>
2019-02-12MLK-18045-1 drm/imx: dcss: define 'struct dma_metadata' for dec400d configFancy Fang
Define a new struct 'dma_metadata' to hold the config parameters for DEC400D. This struct data should be passed in from the fb's first gem_obj's 'dma_buf' field. Signed-off-by: Fancy Fang <chen.fang@nxp.com>
2019-02-12MLK-18009 drm/imx: dpu: plane: Support deinterlacing via fetchdecode & vscalerLiu Ying
Fetchdecode may work together with vscaler to do bob deinterlacing. This patch adds the deinterlacing support for DPU DRM plane by using them. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-17931-3 gpu: imx: dpu: common: Add dpu_has_prefetch_fixup() helper supportLiu Ying
This patch adds dpu_has_prefetch_fixup() helper support. Users may use it to tell if a DPU has fixups for prefetch engines in silicon or not. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-17991-7 drm/imx: dpu: kms: Add basic fetchwarp2 supportLiu Ying
This patch adds the first subsidiary layer0(out of layer0 to layer7) support for the fetchwarp2 fetch unit to be the backend of DRM plane. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-17991-5 gpu: imx: dpu: common: Add basic fetchwarp2 supportLiu Ying
Fetchwarp is a type of dpu fetch unit with the additional warping function. Each fetchwarp contains 8 subsidiary layers. Fetchwarp2 can work with fetcheco2 to fetch planar YUV pixel formats. Also, it may fetch RGB pixel formats. This patch adds basic fetchwarp2 fetch unit support in the dpu common driver so that it may fetch frames in RGB pixel formats. YUV pixel formats and warping function could be supported later. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-17991-4 drm/imx: dpu: kms: Add basic fetchlayer0/1 supportLiu Ying
This patch adds the first subsidiary layer0(out of layer0 to layer7) support for the fetchlayer0/1 fetch units to be the backend of DRM plane. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-17991-2 gpu: imx: dpu: common: Add some prefetch engine helpers supportLiu Ying
This patch adds some prefetch engine helpers support in the dpu common driver so that callers may deal with the prefetch engines of the fetch units the callers are interested in. Signed-off-by: Liu Ying <victor.liu@nxp.com>
2019-02-12MLK-17991-1 gpu: imx: dpu: common: Add basic fetchlayer0/1 supportLiu Ying
Fetchlayer is a type of dpu fetch unit. Each fetchlayer contains 8 subsidiary layers. Fetchlayer cannot work with fetcheco to fetch planar YUV pixel formats. However, it may fetch RGB pixel formats. This patch adds basic fetchlayer0/1 fetch units support in the dpu common driver. Signed-off-by: Liu Ying <victor.liu@nxp.com>
