path: root/include/xen/grant_table.h
2015-10-23xen/grant-table: Add an helper to iterate over a specific number of grantsJulien Grall
With the 64KB page granularity support on ARM64, a Linux page may be split accross multiple grant. Currently we have the helper gnttab_foreach_grant_in_grant to break a Linux page based on an offset and a len, but it doesn't fit when we only have a number of grants in hand. Introduce a new helper which take an array of Linux page and a number of grant and will figure out the address of each grant. Signed-off-by: Julien Grall <julien.grall@citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-10-23xen/grant: Add helper gnttab_page_grant_foreign_access_ref_oneJulien Grall
Many PV drivers contain the idiom: pfn = page_to_gfn(...) /* Or similar */ gnttab_grant_foreign_access_ref Replace it by a new helper. Note that when Linux is using a different page granularity than Xen, the helper only gives access to the first 4KB grant. This is useful where drivers are allocating a full Linux page for each grant. Also include xen/interface/grant_table.h rather than xen/grant_table.h in asm/page.h for x86 to fix a compilation issue [1]. Only the former is useful in order to get the structure definition. [1] Interdependency between asm/page.h and xen/grant_table.h which result to page_mfn not being defined when necessary. Signed-off-by: Julien Grall <julien.grall@citrix.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-10-23xen/grant: Introduce helpers to split a page into grantJulien Grall
Currently, a grant is always based on the Xen page granularity (i.e 4KB). When Linux is using a different page granularity, a single page will be split between multiple grants. The new helpers will be in charge of splitting the Linux page into grants and call a function given by the caller on each grant. Also provide an helper to count the number of grants within a given contiguous region. Note that the x86/include/asm/xen/page.h is now including xen/interface/grant_table.h rather than xen/grant_table.h. It's necessary because xen/grant_table.h depends on asm/xen/page.h and will break the compilation. Furthermore, only definition in interface/grant_table.h is required. Signed-off-by: Julien Grall <julien.grall@citrix.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-04-27xen/grant: introduce func gnttab_unmap_refs_sync()Bob Liu
There are several place using gnttab async unmap and wait for completion, so move the common code to a function gnttab_unmap_refs_sync(). Signed-off-by: Bob Liu <bob.liu@oracle.com> Acked-by: Roger Pau Monné <roger.pau@citrix.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-01-28xen/grant-table: add a mechanism to safely unmap pages that are in useJennifer Herbert
Introduce gnttab_unmap_refs_async() that can be used to safely unmap pages that may be in use (ref count > 1). If the pages are in use the unmap is deferred and retried later. This polling is not very clever but it should be good enough if the cases where the delay is necessary are rare. The initial delay is 5 ms and is increased linearly on each subsequent retry (to reduce load if the page is in use for a long time). This is needed to allow block backends using grant mapping to safely use network storage (block or filesystem based such as iSCSI or NFS). The network storage driver may complete a block request whilst there is a queued network packet retry (because the ack from the remote end races with deciding to queue the retry). The pages for the retried packet would be grant unmapped and the network driver (or hardware) would access the unmapped page. Signed-off-by: Jennifer Herbert <jennifer.herbert@citrix.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-01-28xen: mark grant mapped pages as foreignJennifer Herbert
Use the "foreign" page flag to mark pages that have a grant map. Use page->private to store information of the grant (the granting domain and the grant reference). Signed-off-by: Jennifer Herbert <jennifer.herbert@citrix.com> Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-01-28xen/grant-table: add helpers for allocating pagesDavid Vrabel
Add gnttab_alloc_pages() and gnttab_free_pages() to allocate/free pages suitable to for granted maps. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2015-01-28xen/grant-table: pre-populate kernel unmap ops for xen_gnttab_unmap_refs()David Vrabel
When unmapping grants, instead of converting the kernel map ops to unmap ops on the fly, pre-populate the set of unmap ops. This allows the grant unmap for the kernel mappings to be trivially batched in the future. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2014-07-14xen/grant-table: remove support for V2 tablesDavid Vrabel
Since 11c7ff17c9b6dbf3a4e4f36be30ad531a6cf0ec9 (xen/grant-table: Force to use v1 of grants.) the code for V2 grant tables is not used. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-07-14x86/xen: safely map and unmap grant frames when in atomic contextDavid Vrabel
arch_gnttab_map_frames() and arch_gnttab_unmap_frames() are called in atomic context but were calling alloc_vm_area() which might sleep. Also, if a driver attempts to allocate a grant ref from an interrupt and the table needs expanding, then the CPU may already by in lazy MMU mode and apply_to_page_range() will BUG when it tries to re-enable lazy MMU mode. These two functions are only used in PV guests. Introduce arch_gnttab_init() to allocates the virtual address space in advance. Avoid the use of apply_to_page_range() by using saving and using the array of PTE addresses from the alloc_vm_area() call. N.B. 'alloc_vm_area' pre-allocates the pagetable so there is no need to worry about having to do a PGD/PUD/PMD walk (like apply_to_page_range does) and we can instead do set_pte. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> ---- [v2: Add comment about alloc_vm_area] [v3: Fix compile error found by 0-day bot]
2014-02-03Revert "xen/grant-table: Avoid m2p_override during mapping"Konrad Rzeszutek Wilk
This reverts commit 08ece5bb2312b4510b161a6ef6682f37f4eac8a1. As it breaks ARM builds and needs more attention on the ARM side. Acked-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-31xen/grant-table: Avoid m2p_override during mappingZoltan Kiss
The grant mapping API does m2p_override unnecessarily: only gntdev needs it, for blkback and future netback patches it just cause a lock contention, as those pages never go to userspace. Therefore this series does the following: - the original functions were renamed to __gnttab_[un]map_refs, with a new parameter m2p_override - based on m2p_override either they follow the original behaviour, or just set the private flag and call set_phys_to_machine - gnttab_[un]map_refs are now a wrapper to call __gnttab_[un]map_refs with m2p_override false - a new function gnttab_[un]map_refs_userspace provides the old behaviour It also removes a stray space from page.h and change ret to 0 if XENFEAT_auto_translated_physmap, as that is the only possible return value there. v2: - move the storing of the old mfn in page->index to gnttab_map_refs - move the function header update to a separate patch v3: - a new approach to retain old behaviour where it needed - squash the patches into one v4: - move out the common bits from m2p* functions, and pass pfn/mfn as parameter - clear page->private before doing anything with the page, so m2p_find_override won't race with this v5: - change return value handling in __gnttab_[un]map_refs - remove a stray space in page.h - add detail why ret = 0 now at some places v6: - don't pass pfn to m2p* functions, just get it locally Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com> Suggested-by: David Vrabel <david.vrabel@citrix.com> Acked-by: David Vrabel <david.vrabel@citrix.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-30xen/gnttab: Use phys_addr_t to describe the grant frame base addressJulien Grall
On ARM, address size can be 32 bits or 64 bits (if CONFIG_ARCH_PHYS_ADDR_T_64BIT is enabled). We can't assume that the grant frame base address will always fits in an unsigned long. Use phys_addr_t instead of unsigned long as argument for gnttab_setup_auto_xlat_frames. Signed-off-by: Julien Grall <julien.grall@linaro.org> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-01-06xen/grant: Implement an grant frame array struct (v3).Konrad Rzeszutek Wilk
The 'xen_hvm_resume_frames' used to be an 'unsigned long' and contain the virtual address of the grants. That was OK for most architectures (PVHVM, ARM) were the grants are contiguous in memory. That however is not the case for PVH - in which case we will have to do a lookup for each virtual address for the PFN. Instead of doing that, lets make it a structure which will contain the array of PFNs, the virtual address and the count of said PFNs. Also provide a generic functions: gnttab_setup_auto_xlat_frames and gnttab_free_auto_xlat_frames to populate said structure with appropriate values for PVHVM and ARM. To round it off, change the name from 'xen_hvm_resume_frames' to a more descriptive one - 'xen_auto_xlat_grant_frames'. For PVH, in patch "xen/pvh: Piggyback on PVHVM for grant driver" we will populate the 'xen_auto_xlat_grant_frames' by ourselves. v2 moves the xen_remap in the gnttab_setup_auto_xlat_frames and also introduces xen_unmap for gnttab_free_auto_xlat_frames. Suggested-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [v3: Based on top of 'asm/xen/page.h: remove redundant semicolon'] Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2012-10-19Merge commit 'v3.7-rc1' into stable/for-linus-3.7Konrad Rzeszutek Wilk
* commit 'v3.7-rc1': (10892 commits) Linux 3.7-rc1 x86, boot: Explicitly include autoconf.h for hostprogs perf: Fix UAPI fallout ARM: config: make sure that platforms are ordered by option string ARM: config: sort select statements alphanumerically UAPI: (Scripted) Disintegrate include/linux/byteorder UAPI: (Scripted) Disintegrate include/linux UAPI: Unexport linux/blk_types.h UAPI: Unexport part of linux/ppp-comp.h perf: Handle new rbtree implementation procfs: don't need a PATH_MAX allocation to hold a string representation of an int vfs: embed struct filename inside of names_cache allocation if possible audit: make audit_inode take struct filename vfs: make path_openat take a struct filename pointer vfs: turn do_path_lookup into wrapper around struct filename variant audit: allow audit code to satisfy getname requests from its names_list vfs: define struct filename and have getname() return it btrfs: Fix compilation with user namespace support enabled userns: Fix posix_acl_file_xattr_userns gid conversion userns: Properly print bluetooth socket uids ...
2012-10-19xen: grant: use xen_pfn_t type for frame_list.Ian Campbell
This correctly sizes it as 64 bit on ARM but leaves it as unsigned long on x86 (therefore no intended change on x86). The long and ulong guest handles are now unused (and a bit dangerous) so remove them. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-02Merge tag 'stable/for-linus-3.7-x86-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen update from Konrad Rzeszutek Wilk: "Features: - When hotplugging PCI devices in a PV guest we can allocate Xen-SWIOTLB later. - Cleanup Xen SWIOTLB. - Support pages out grants from HVM domains in the backends. - Support wild cards in xen-pciback.hide=(BDF) arguments. - Update grant status updates with upstream hypervisor. - Boot PV guests with more than 128GB. - Cleanup Xen MMU code/add comments. - Obtain XENVERS using a preferred method. - Lay out generic changes to support Xen ARM. - Allow privcmd ioctl for HVM (used to do only PV). - Do v2 of mmap_batch for privcmd ioctls. - If hypervisor saves the LED keyboard light - we will now instruct the kernel about its state. Fixes: - More fixes to Xen PCI backend for various calls/FLR/etc. - With more than 4GB in a 64-bit PV guest disable native SWIOTLB. - Fix up smatch warnings. - Fix up various return values in privmcmd and mm." * tag 'stable/for-linus-3.7-x86-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (48 commits) xen/pciback: Restore the PCI config space after an FLR. xen-pciback: properly clean up after calling pcistub_device_find() xen/vga: add the xen EFI video mode support xen/x86: retrieve keyboard shift status flags from hypervisor. xen/gndev: Xen backend support for paged out grant targets V4. xen-pciback: support wild cards in slot specifications xen/swiotlb: Fix compile warnings when using plain integer instead of NULL pointer. xen/swiotlb: Remove functions not needed anymore. xen/pcifront: Use Xen-SWIOTLB when initting if required. xen/swiotlb: For early initialization, return zero on success. xen/swiotlb: Use the swiotlb_late_init_with_tbl to init Xen-SWIOTLB late when PV PCI is used. xen/swiotlb: Move the error strings to its own function. xen/swiotlb: Move the nr_tbl determination in its own function. xen/arm: compile and run xenbus xen: resynchronise grant table status codes with upstream xen/privcmd: return -EFAULT on error xen/privcmd: Fix mmap batch ioctl error status copy back. xen/privcmd: add PRIVCMD_MMAPBATCH_V2 ioctl xen/mm: return more precise error from xen_remap_domain_range() xen/mmu: If the revector fails, don't attempt to revector anything else. ...
2012-09-21xen/gndev: Xen backend support for paged out grant targets V4.Andres Lagar-Cavilla
Since Xen-4.2, hvm domains may have portions of their memory paged out. When a foreign domain (such as dom0) attempts to map these frames, the map will initially fail. The hypervisor returns a suitable errno, and kicks an asynchronous page-in operation carried out by a helper. The foreign domain is expected to retry the mapping operation until it eventually succeeds. The foreign domain is not put to sleep because itself could be the one running the pager assist (typical scenario for dom0). This patch adds support for this mechanism for backend drivers using grant mapping and copying operations. Specifically, this covers the blkback and gntdev drivers (which map foreign grants), and the netback driver (which copies foreign grants). * Add a retry method for grants that fail with GNTST_eagain (i.e. because the target foreign frame is paged out). * Insert hooks with appropriate wrappers in the aforementioned drivers. The retry loop is only invoked if the grant operation status is GNTST_eagain. It guarantees to leave a new status code different from GNTST_eagain. Any other status code results in identical code execution as before. The retry loop performs 256 attempts with increasing time intervals through a 32 second period. It uses msleep to yield while waiting for the next retry. V2 after feedback from David Vrabel: * Explicit MAX_DELAY instead of wrap-around delay into zero * Abstract GNTST_eagain check into core grant table code for netback module. V3 after feedback from Ian Campbell: * Add placeholder in array of grant table error descriptions for unrelated error code we jump over. * Eliminate single map and retry macro in favor of a generic batch flavor. * Some renaming. * Bury most implementation in grant_table.c, cleaner interface. V4 rebased on top of sync of Xen grant table interface headers. Signed-off-by: Andres Lagar-Cavilla <andres@lagarcavilla.org> Acked-by: Ian Campbell <ian.campbell@citrix.com> [v5: Fixed whitespace issues] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-12xen/m2p: do not reuse kmap_op->dev_bus_addrStefano Stabellini
If the caller passes a valid kmap_op to m2p_add_override, we use kmap_op->dev_bus_addr to store the original mfn, but dev_bus_addr is part of the interface with Xen and if we are batching the hypercalls it might not have been written by the hypervisor yet. That means that later on Xen will write to it and we'll think that the original mfn is actually what Xen has written to it. Rather than "stealing" struct members from kmap_op, keep using page->index to store the original mfn and add another parameter to m2p_remove_override to get the corresponding kmap_op instead. It is now responsibility of the caller to keep track of which kmap_op corresponds to a particular page in the m2p_override (gntdev, the only user of this interface that passes a valid kmap_op, is already doing that). CC: stable@kernel.org Reported-and-Tested-By: Sander Eikelenboom <linux@eikelenboom.it> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-21xenbus: Add support for xenbus backend in stub domainDaniel De Graaf
Add an ioctl to the /dev/xen/xenbus_backend device allowing the xenbus backend to be started after the kernel has booted. This allows xenstore to run in a different domain from the dom0. Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-12-20xen/grant-table: Support mappings required by blkbackDaniel De Graaf
Add support for mappings without GNTMAP_contains_pte. This was not supported because the unmap operation assumed that this flag was being used; adding a parameter to the unmap operation to allow the PTE clearing to be disabled is sufficient to make unmap capable of supporting either mapping type. Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> [v1: Fix cleanpatch warnings] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-12-16xen/granttable: Support transitive grantsAnnie Li
These allow a domain A which has been granted access on a page of domain B's memory to issue domain C with a copy-grant on the same page. This is useful e.g. for forwarding packets between domains. Signed-off-by: Annie Li <annie.li@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-12-16xen/granttable: Support sub-page grantsAnnie Li
- They can't be used to map the page (so can only be used in a GNTTABOP_copy hypercall). - It's possible to grant access with a finer granularity than whole pages. - Xen guarantees that they can be revoked quickly (a normal map grant can only be revoked with the cooperation of the domain which has been granted access). Signed-off-by: Annie Li <annie.li@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-11-22xen/granttable: Keep code format cleanAnnie Li
Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Annie Li <annie.li@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-11-22xen/granttable: Grant tables V2 implementationAnnie Li
Receiver-side copying of packets is based on this implementation, it gives better performance and better CPU accounting. It totally supports three types: full-page, sub-page and transitive grants. However this patch does not cover sub-page and transitive grants, it mainly focus on Full-page part and implements grant table V2 interfaces corresponding to what already exists in grant table V1, such as: grant table V2 initialization, mapping, releasing and exported interfaces. Each guest can only supports one type of grant table type, every entry in grant table should be the same version. It is necessary to set V1 or V2 version before initializing the grant table. Grant table exported interfaces of V2 are same with those of V1, Xen is responsible to judge what grant table version guests are using in every grant operation. V2 fulfills the same role of V1, and it is totally backwards compitable with V1. If dom0 support grant table V2, the guests runing on it can run with either V1 or V2. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Annie Li <annie.li@oracle.com> [v1: Modified alloc_vm_area call (new parameters), indentation, and cleanpatch warnings] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-11-22xen/granttable: Introducing grant table V2 stuctureAnnie Li
This patch introduces new structures of grant table V2, grant table V2 is an extension from V1. Grant table is shared between guest and Xen, and Xen is responsible to do corresponding work for grant operations, such as: figure out guest's grant table version, perform different actions based on different grant table version, etc. Although full-page structure of V2 is different from V1, it play the same role as V1. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Annie Li <annie.li@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-11-06Merge branch 'stable/vmalloc-3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/vmalloc-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: net: xen-netback: use API provided by xenbus module to map rings block: xen-blkback: use API provided by xenbus module to map rings xen: use generic functions instead of xen_{alloc, free}_vm_area()
2011-09-29xen: use generic functions instead of xen_{alloc, free}_vm_area()David Vrabel
Replace calls to the Xen-specific xen_alloc_vm_area() and xen_free_vm_area() functions with the generic equivalent (alloc_vm_area() and free_vm_area()). On x86, these were identical already. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-09-29xen: modify kernel mappings corresponding to granted pagesStefano Stabellini
If we want to use granted pages for AIO, changing the mappings of a user vma and the corresponding p2m is not enough, we also need to update the kernel mappings accordingly. Currently this is only needed for pages that are created for user usages through /dev/xen/gntdev. As in, pages that have been in use by the kernel and use the P2M will not need this special mapping. However there are no guarantees that in the future the kernel won't start accessing pages through the 1:1 even for internal usage. In order to avoid the complexity of dealing with highmem, we allocated the pages lowmem. We issue a HYPERVISOR_grant_table_op right away in m2p_add_override and we remove the mappings using another HYPERVISOR_grant_table_op in m2p_remove_override. Considering that m2p_add_override and m2p_remove_override are called once per page we use multicalls and hypercall batching. Use the kmap_op pointer directly as argument to do the mapping as it is guaranteed to be present up until the unmapping is done. Before issuing any unmapping multicalls, we need to make sure that the mapping has already being done, because we need the kmap->handle to be set correctly. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> [v1: Removed GRANT_FRAME_BIT usage] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-11xen: introduce gnttab_map_refs and gnttab_unmap_refsStefano Stabellini
gnttab_map_refs maps some grant refs and uses the new m2p override to set a proper m2p mapping for the granted pages. gnttab_unmap_refs unmaps the granted refs and removes th mappings from the m2p override. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-11xen: define gnttab_set_map_op/unmap_opIan Campbell
Impact: hypercall definitions These functions populate the gnttab data structures used by the granttab map and unmap ops and are used in the backend drivers. Originally xen-unstable.hg 9625:c3bb51c443a7 [ Include Stefano's fix for phys_addr_t ] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-07-22xen: Xen PCI platform device driver.Stefano Stabellini
Add the xen pci platform device driver that is responsible for initializing the grant table and xenbus in PV on HVM mode. Few changes to xenbus and grant table are necessary to allow the delayed initialization in HVM mode. Grant table needs few additional modifications to work in HVM mode. The Xen PCI platform device raises an irq every time an event has been delivered to us. However these interrupts are only delivered to vcpu 0. The Xen PCI platform interrupt handler calls xen_hvm_evtchn_do_upcall that is a little wrapper around __xen_evtchn_do_upcall, the traditional Xen upcall handler, the very same used with traditional PV guests. When running on HVM the event channel upcall is never called while in progress because it is a normal Linux irq handler (and we cannot switch the irq chip wholesale to the Xen PV ones as we are running QEMU and might have passed in PCI devices), therefore we cannot be sure that evtchn_upcall_pending is 0 when returning. For this reason if evtchn_upcall_pending is set by Xen we need to loop again on the event channels set pending otherwise we might loose some event channel deliveries. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2008-05-27xen: implement save/restoreJeremy Fitzhardinge
This patch implements Xen save/restore and migration. Saving is triggered via xenbus, which is polled in drivers/xen/manage.c. When a suspend request comes in, the kernel prepares itself for saving by: 1 - Freeze all processes. This is primarily to prevent any partially-completed pagetable updates from confusing the suspend process. If CONFIG_PREEMPT isn't defined, then this isn't necessary. 2 - Suspend xenbus and other devices 3 - Stop_machine, to make sure all the other vcpus are quiescent. The Xen tools require the domain to run its save off vcpu0. 4 - Within the stop_machine state, it pins any unpinned pgds (under construction or destruction), performs canonicalizes various other pieces of state (mostly converting mfns to pfns), and finally 5 - Suspend the domain Restore reverses the steps used to save the domain, ending when all the frozen processes are thawed. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: make grant table arch portableIsaku Yamahata
split out x86 specific part from grant-table.c and allow ia64/xen specific initialization. ia64/xen grant table is based on pseudo physical address (guest physical address) unlike x86/xen. On ia64 init_mm doesn't map identity straight mapped area. ia64/xen specific grant table initialization is necessary. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: replace callers of alloc_vm_area()/free_vm_area() with xen_ prefixed oneIsaku Yamahata
Don't use alloc_vm_area()/free_vm_area() directly, instead define xen_alloc_vm_area()/xen_free_vm_area() and use them. alloc_vm_area()/free_vm_area() are used to allocate/free area which are for grant table mapping. Xen/x86 grant table is based on virtual address so that alloc_vm_area()/free_vm_area() are suitable. On the other hand Xen/ia64 (and Xen/powerpc) grant table is based on pseudo physical address (guest physical address) so that allocation should be done differently. The original version of xenified Linux/IA64 have its own allocate_vm_area()/free_vm_area() definitions which don't allocate vm area contradictory to those names. Now vanilla Linux already has its definitions so that it's impossible to have IA64 definitions of allocate_vm_area()/free_vm_area(). Instead introduce xen_allocate_vm_area()/xen_free_vm_area() and use them. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-07-18xen: Add grant table supportJeremy Fitzhardinge
Add Xen 'grant table' driver which allows granting of access to selected local memory pages by other virtual machines and, symmetrically, the mapping of remote memory pages which other virtual machines have granted access to. This driver is a prerequisite for many of the Xen virtual device drivers, which grant the 'device driver domain' restricted and temporary access to only those memory pages that are currently involved in I/O operations. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ian Pratt <ian.pratt@xensource.com> Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
