path: root/include/xen/interface/xen.h
2013-02-20xen: event channel arrays are xen_ulong_t and not unsigned longIan Campbell
On ARM we want these to be the same size on 32- and 64-bit. This is an ABI change on ARM. X86 does not change. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jan Beulich <JBeulich@suse.com> Cc: Keir (Xen.org) <keir@xen.org> Cc: Tim Deegan <tim@xen.org> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: linux-arm-kernel@lists.infradead.org Cc: xen-devel@lists.xen.org Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-24xen/vga: add the xen EFI video mode supportJan Beulich
In order to add xen EFI frambebuffer video support, it is required to add xen-efi's new video type (XEN_VGATYPE_EFI_LFB) case and handle it in the function xen_init_vga and set the video type to VIDEO_TYPE_EFI to enable efi video mode. The original patch from which this was broken out from: http://marc.info/?i=4E099AA6020000780004A4C6@nat28.tlf.novell.com Signed-off-by: Jan Beulich <JBeulich@novell.com> Signed-off-by: Tang Liang <liang.tang@oracle.com> [v2: The original author is Jan Beulich and Liang Tang ported it to upstream] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-12Merge branch 'x86/platform' of ↵Konrad Rzeszutek Wilk
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into stable/for-linus-3.7 * 'x86/platform' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (9690 commits) x86: Document x86_init.paging.pagetable_init() x86: xen: Cleanup and remove x86_init.paging.pagetable_setup_done() x86: Move paging_init() call to x86_init.paging.pagetable_init() x86: Rename pagetable_setup_start() to pagetable_init() x86: Remove base argument from x86_init.paging.pagetable_setup_start Linux 3.6-rc5 HID: tpkbd: work even if the new Lenovo Keyboard driver is not configured Remove user-triggerable BUG from mpol_to_str xen/pciback: Fix proper FLR steps. uml: fix compile error in deliver_alarm() dj: memory scribble in logi_dj Fix order of arguments to compat_put_time[spec|val] xen: Use correct masking in xen_swiotlb_alloc_coherent. xen: fix logical error in tlb flushing xen/p2m: Fix one-off error in checking the P2M tree directory. powerpc: Don't use __put_user() in patch_instruction powerpc: Make sure IPI handlers see data written by IPI senders powerpc: Restore correct DSCR in context switch powerpc: Fix DSCR inheritance in copy_thread() powerpc: Keep thread.dscr and thread.dscr_inherit in sync ...
2012-08-23xen: Introduce xen_pfn_t for pfn and mfn typesStefano Stabellini
All the original Xen headers have xen_pfn_t as mfn and pfn type, however when they have been imported in Linux, xen_pfn_t has been replaced with unsigned long. That might work for x86 and ia64 but it does not for arm. Bring back xen_pfn_t and let each architecture define xen_pfn_t as they see fit. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-08-21xen: missing includesStefano Stabellini
Changes in v2: - remove pvclock hack; - remove include linux/types.h from xen/interface/xen.h. v3: - Compile under IA64 Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19xen/pcpu: Xen physical cpus online/offline sys interfaceLiu, Jinsong
This patch provide Xen physical cpus online/offline sys interface. User can use it for their own purpose, like power saving: by offlining some cpus when light workload it save power greatly. Its basic workflow is, user online/offline cpu via sys interface, then hypercall xen to implement, after done xen inject virq back to dom0, and then dom0 sync cpu status. Signed-off-by: Jiang, Yunhong <yunhong.jiang@intel.com> Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-11-22xen/granttable: Introducing grant table V2 stuctureAnnie Li
This patch introduces new structures of grant table V2, grant table V2 is an extension from V1. Grant table is shared between guest and Xen, and Xen is responsible to do corresponding work for grant operations, such as: figure out guest's grant table version, perform different actions based on different grant table version, etc. Although full-page structure of V2 is different from V1, it play the same role as V1. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Annie Li <annie.li@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-11-06Merge branch 'upstream/xen-settime' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/xen-settime' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen/dom0: set wallclock time in Xen xen: add dom0_op hypercall xen/acpi: Domain0 acpi parser related platform hypercall
2011-09-26xen/acpi: Domain0 acpi parser related platform hypercallYu Ke
This patches implements the xen_platform_op hypercall, to pass the parsed ACPI info to hypervisor. Signed-off-by: Yu Ke <ke.yu@intel.com> Signed-off-by: Tian Kevin <kevin.tian@intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> [v1: Added DEFINE_GUEST.. in appropiate headers] [v2: Ripped out typedefs] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-21Merge branch 'stable/vga.support' into stable/driversKonrad Rzeszutek Wilk
* stable/vga.support: xen: allow enable use of VGA console on dom0
2011-06-06xen: allow enable use of VGA console on dom0Jeremy Fitzhardinge
Get the information about the VGA console hardware from Xen, and put it into the form the bootloader normally generates, so that the rest of the kernel can deal with VGA as usual. [ Impact: make VGA console work in dom0 ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> [v1: Rebased on 2.6.39] [v2: Removed incorrect comments and fixed compile warnings] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-26xen: cleancache shim to Xen Transcendent MemoryDan Magenheimer
This patch provides a shim between the kernel-internal cleancache API (see Documentation/mm/cleancache.txt) and the Xen Transcendent Memory ABI (see http://oss.oracle.com/projects/tmem). Xen tmem provides "hypervisor RAM" as an ephemeral page-oriented pseudo-RAM store for cleancache pages, shared cleancache pages, and frontswap pages. Tmem provides enterprise-quality concurrency, full save/restore and live migration support, compression and deduplication. A presentation showing up to 8% faster performance and up to 52% reduction in sectors read on a kernel compile workload, despite aggressive in-kernel page reclamation ("self-ballooning") can be found at: http://oss.oracle.com/projects/tmem/dist/documentation/presentations/TranscendentMemoryXenSummit2010.pdf Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-02-25xen: switch to new schedop hypercall by default.Ian Campbell
Rename old interface to sched_op_compat and rename sched_op_new to simply sched_op. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2008-06-25xen: implement ptep_modify_prot_start/commitJeremy Fitzhardinge
Xen has a pte update function which will update a pte while preserving its accessed and dirty bits. This means that ptep_modify_prot_start() can be implemented as a simple read of the pte value. The hardware may update the pte in the meantime, but ptep_modify_prot_commit() updates it while preserving any changes that may have happened in the meantime. The updates in ptep_modify_prot_commit() are batched if we're currently in lazy mmu mode. The mmu_update hypercall can take a batch of updates to perform, but this code doesn't make particular use of that feature, in favour of using generic multicall batching to get them all into the hypervisor. The net effect of this is that each mprotect pte update turns from two expensive trap-and-emulate faults into they hypervisor into a single hypercall whose cost is amortized in a batched multicall. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-24x86: Make xen use the paravirt clocksource structs and functionsGerd Hoffmann
This patch updates the xen guest to use the pvclock structs and helper functions. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-24xen: definitions which ia64/xen needsIsaku Yamahata
Add xen VIRQ numbers defined for arch specific use. ia64/xen domU uses VIRQ_ARCH_0 for virtual itc timer. Although all those constants aren't used yet by ia64 at this moment, add all arch specific VIRQ numbers. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: definisions which ia64 needsIsaku Yamahata
Add xen hypercall numbers defined for arch specific use. ia64/xen domU uses __HYPERVISOR_arch_1 to manipulate paravirtualized IOSAPIC. Although all those constants aren't used yet by IA64 at this moment, add all arch specific hypercall numbers. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-07-18xen: Add Xen interface header filesJeremy Fitzhardinge
Add Xen interface header files. These are taken fairly directly from the Xen tree, but somewhat rearranged to suit the kernel's conventions. Define macros and inline functions for doing hypercalls into the hypervisor. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ian Pratt <ian.pratt@xensource.com> Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
