To be able to use an initially unmapped initrd with xen the following
header files must be synced to a newer version from the xen tree:
include/xen/interface/elfnote.h
include/xen/interface/xen.h
As the KEXEC and DUMPCORE related ELFNOTES are not relevant for the
kernel they are omitted from elfnote.h.
Signed-off-by: Juergen Gross <jgross@suse.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
As part of this make the usual change to xen_ulong_t in place of unsigned long.
This change has no impact on x86.
The Linux definition of struct multicall_entry.result differs from the Xen
definition, I think for good reasons, and used a long rather than an unsigned
long. Therefore introduce a xen_long_t, which is a long on x86 architectures
and a signed 64-bit integer on ARM.
Use uint32_t nr_calls on x86 for consistency with the ARM definition.
Build tested on amd64 and i386 builds. Runtime tested on ARM.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Add the hypercall sub-ops and the structures for the shared data used
in the FIFO-based event channel ABI.
The design document for this new ABI is available here:
http://xenbits.xen.org/people/dvrabel/event-channels-H.pdf
In summary, events are reported using a per-domain shared event array
of event words. Each event word has PENDING, LINKED and MASKED bits
and a LINK field for pointing to the next event in the event queue.
There are 16 event queues (with different priorities) per-VCPU.
Key advantages of this new ABI include:
- Support for over 100,000 events (2^17).
- 16 different event priorities.
- Improved fairness in event latency through the use of FIFOs.
The ABI is available in Xen 4.4 and later.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
On ARM we want these to be the same size on 32- and 64-bit.
This is an ABI change on ARM. X86 does not change.
Cc: Jan Beulich <JBeulich@suse.com>
Cc: Keir (Xen.org) <keir@xen.org>
Cc: Tim Deegan <tim@xen.org>
Cc: xen-devel@lists.xen.org
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
In order to add xen EFI frambebuffer video support, it is required to add
xen-efi's new video type (XEN_VGATYPE_EFI_LFB) case and handle it in the
function xen_init_vga and set the video type to VIDEO_TYPE_EFI to enable
efi video mode.
The original patch from which this was broken out from:
http://marc.info/?i=4E099AA6020000780004A4C6@nat28.tlf.novell.com
Signed-off-by: Jan Beulich <JBeulich@novell.com>
Signed-off-by: Tang Liang <liang.tang@oracle.com>
[v2: The original author is Jan Beulich and Liang Tang ported it to upstream]
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into stable/for-linus-3.7
* 'x86/platform' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (9690 commits)
x86: Document x86_init.paging.pagetable_init()
x86: xen: Cleanup and remove x86_init.paging.pagetable_setup_done()
x86: Move paging_init() call to x86_init.paging.pagetable_init()
x86: Rename pagetable_setup_start() to pagetable_init()
x86: Remove base argument from x86_init.paging.pagetable_setup_start
Linux 3.6-rc5
HID: tpkbd: work even if the new Lenovo Keyboard driver is not configured
Remove user-triggerable BUG from mpol_to_str
xen/pciback: Fix proper FLR steps.
uml: fix compile error in deliver_alarm()
dj: memory scribble in logi_dj
Fix order of arguments to compat_put_time[spec|val]
xen: Use correct masking in xen_swiotlb_alloc_coherent.
xen: fix logical error in tlb flushing
xen/p2m: Fix one-off error in checking the P2M tree directory.
powerpc: Don't use __put_user() in patch_instruction
powerpc: Make sure IPI handlers see data written by IPI senders
powerpc: Restore correct DSCR in context switch
powerpc: Fix DSCR inheritance in copy_thread()
powerpc: Keep thread.dscr and thread.dscr_inherit in sync
All the original Xen headers have xen_pfn_t as mfn and pfn type, however
when they have been imported in Linux, xen_pfn_t has been replaced with
unsigned long. That might work for x86 and ia64 but it does not for arm.
Bring back xen_pfn_t and let each architecture define xen_pfn_t as they
see fit.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Changes in v2:
- remove pvclock hack;
- remove include linux/types.h from xen/interface/xen.h.
v3:
- Compile under IA64
This patch provide Xen physical cpus online/offline sys interface.
User can use it for their own purpose, like power saving:
by offlining some cpus when light workload it save power greatly.
Its basic workflow is, user online/offline cpu via sys interface,
then hypercall xen to implement, after done xen inject virq back to dom0,
and then dom0 sync cpu status.
Signed-off-by: Jiang, Yunhong <yunhong.jiang@intel.com>
Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com>
This patch introduces new structures of grant table V2, grant table V2 is an
extension from V1. Grant table is shared between guest and Xen, and Xen is
responsible to do corresponding work for grant operations, such as: figure
out guest's grant table version, perform different actions based on
different grant table version, etc. Although full-page structure of V2
is different from V1, it play the same role as V1.
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Annie Li <annie.li@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/xen-settime' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen/dom0: set wallclock time in Xen
xen: add dom0_op hypercall
xen/acpi: Domain0 acpi parser related platform hypercall
This patches implements the xen_platform_op hypercall, to pass the parsed
ACPI info to hypervisor.
Signed-off-by: Yu Ke <ke.yu@intel.com>
Signed-off-by: Tian Kevin <kevin.tian@intel.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
[v1: Added DEFINE_GUEST.. in appropiate headers]
[v2: Ripped out typedefs]
* stable/vga.support:
xen: allow enable use of VGA console on dom0
Get the information about the VGA console hardware from Xen, and put
it into the form the bootloader normally generates, so that the rest
of the kernel can deal with VGA as usual.
[ Impact: make VGA console work in dom0 ]
[v1: Rebased on 2.6.39]
[v2: Removed incorrect comments and fixed compile warnings]
This patch provides a shim between the kernel-internal cleancache
API (see Documentation/mm/cleancache.txt) and the Xen Transcendent
Memory ABI (see http://oss.oracle.com/projects/tmem).
Xen tmem provides "hypervisor RAM" as an ephemeral page-oriented
pseudo-RAM store for cleancache pages, shared cleancache pages,
and frontswap pages. Tmem provides enterprise-quality concurrency,
full save/restore and live migration support, compression
and deduplication.
A presentation showing up to 8% faster performance and up to 52%
reduction in sectors read on a kernel compile workload, despite
aggressive in-kernel page reclamation ("self-ballooning") can be
found at:
http://oss.oracle.com/projects/tmem/dist/documentation/presentations/TranscendentMemoryXenSummit2010.pdf
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Rik Van Riel <riel@redhat.com>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Andreas Dilger <adilger@sun.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Rename old interface to sched_op_compat and rename sched_op_new to
simply sched_op.
Xen has a pte update function which will update a pte while preserving
its accessed and dirty bits. This means that ptep_modify_prot_start() can be
implemented as a simple read of the pte value. The hardware may
update the pte in the meantime, but ptep_modify_prot_commit() updates it while
preserving any changes that may have happened in the meantime.
The updates in ptep_modify_prot_commit() are batched if we're currently in lazy
mmu mode.
The mmu_update hypercall can take a batch of updates to perform, but
this code doesn't make particular use of that feature, in favour of
using generic multicall batching to get them all into the hypervisor.
The net effect of this is that each mprotect pte update turns from two
expensive trap-and-emulate faults into they hypervisor into a single
hypercall whose cost is amortized in a batched multicall.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Hugh Dickins <hugh@veritas.com>
This patch updates the xen guest to use the pvclock structs
and helper functions.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
Add xen VIRQ numbers defined for arch specific use.
ia64/xen domU uses VIRQ_ARCH_0 for virtual itc timer.
Although all those constants aren't used yet by ia64
at this moment, add all arch specific VIRQ numbers.
Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp>
Add xen hypercall numbers defined for arch specific use.
ia64/xen domU uses __HYPERVISOR_arch_1 to manipulate paravirtualized
IOSAPIC. Although all those constants aren't used yet by IA64 at this
moment, add all arch specific hypercall numbers.
Add Xen interface header files. These are taken fairly directly from
the Xen tree, but somewhat rearranged to suit the kernel's conventions.
Define macros and inline functions for doing hypercalls into the
hypervisor.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Signed-off-by: Ian Pratt <ian.pratt@xensource.com>
Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
