path: root/include/xen
2011-08-15xen: allow enable use of VGA console on dom0Jeremy Fitzhardinge
commit c2419b4a4727f67af2fc2cd68b0d878b75e781bb upstream. Get the information about the VGA console hardware from Xen, and put it into the form the bootloader normally generates, so that the rest of the kernel can deal with VGA as usual. [ Impact: make VGA console work in dom0 ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> [v1: Rebased on 2.6.39] [v2: Removed incorrect comments and fixed compile warnings] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26xen: cleancache shim to Xen Transcendent MemoryDan Magenheimer
This patch provides a shim between the kernel-internal cleancache API (see Documentation/mm/cleancache.txt) and the Xen Transcendent Memory ABI (see http://oss.oracle.com/projects/tmem). Xen tmem provides "hypervisor RAM" as an ephemeral page-oriented pseudo-RAM store for cleancache pages, shared cleancache pages, and frontswap pages. Tmem provides enterprise-quality concurrency, full save/restore and live migration support, compression and deduplication. A presentation showing up to 8% faster performance and up to 52% reduction in sectors read on a kernel compile workload, despite aggressive in-kernel page reclamation ("self-ballooning") can be found at: http://oss.oracle.com/projects/tmem/dist/documentation/presentations/TranscendentMemoryXenSummit2010.pdf Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-25Merge branch 'for-2.6.40/drivers' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.40/drivers' of git://git.kernel.dk/linux-2.6-block: (110 commits) loop: handle on-demand devices correctly loop: limit 'max_part' module param to DISK_MAX_PARTS drbd: fix warning drbd: fix warning drbd: Fix spelling drbd: fix schedule in atomic drbd: Take a more conservative approach when deciding max_bio_size drbd: Fixed state transitions after async outdate-peer-handler returned drbd: Disallow the peer_disk_state to be D_OUTDATED while connected drbd: Fix for the connection problems on high latency links drbd: fix potential activity log refcount imbalance in error path drbd: Only downgrade the disk state in case of disk failures drbd: fix disconnect/reconnect loop, if ping-timeout == ping-int drbd: fix potential distributed deadlock lru_cache.h: fix comments referring to ts_ instead of lc_ drbd: Fix for application IO with the on-io-error=pass-on policy xen/p2m: Add EXPORT_SYMBOL_GPL to the M2P override functions. xen/p2m/m2p/gnttab: Support GNTMAP_host_map in the M2P override. xen/blkback: don't fail empty barrier requests xen/blkback: fix xenbus_transaction_start() hang caused by double xenbus_transaction_end() ...
2011-05-12xen-blkfront: Provide for 'feature-flush-cache' the ↵Konrad Rzeszutek Wilk
BLKIF_OP_WRITE_FLUSH_CACHE operation. The operation BLKIF_OP_WRITE_FLUSH_CACHE has existed in the Xen tree header file for years but it was never present in the Linux tree because the frontend (nor the backend) supported this interface. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-04-14xen/irq: Export 'xen_pirq_from_irq' function.Konrad Rzeszutek Wilk
We need this to find the real Xen PIRQ value for a device that requests an MSI or MSI-X. In the past we used 'xen_gsi_from_irq' since that function would return an Xen PIRQ or GSI depending on the provided IRQ. Now that we have seperated that we need to use the correct function. [v2: Deal with rebase on stable/irq.cleanup] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-04-14xen/irq: Add support to check if IRQ line is shared with other domains.Konrad Rzeszutek Wilk
We do this via the PHYSDEVOP_irq_status_query support hypervisor call. We will get a positive value if another domain has binded its PIRQ to the specified GSI (IRQ line). [v2: Deal with v2.6.37-rc1 rebase fallout] [v3: Deal with stable/irq.cleanup fallout] [v4: xen_ignore_irq->xen_test_irq_shared] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-04-14xen/irq: Check if the PCI device is owned by a domain different than DOMID_SELF.Konrad Rzeszutek Wilk
We check if there is a domain owner for the PCI device. In case of failure (meaning no domain has registered for this device) we make DOMID_SELF the owner. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [v2: deal with rebasing on v2.6.37-1] [v3: deal with rebasing on stable/irq.cleanup] [v4: deal with rebasing on stable/irq.ween_of_nr_irqs] [v5: deal with rebasing on v2.6.39-rc3] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com>
2011-03-17Merge branch 'stable/xen.pm.bug-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xen.pm.bug-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: use freeze/restore/thaw PM events for suspend/resume/chkpt xen: xenbus PM events support
2011-03-17Merge branches 'stable/irq.fairness' and 'stable/irq.ween_of_nr_irqs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.fairness' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Remove redundant clear of l2i at end of round-robin loop xen: events: Make round-robin scan fairer by snapshotting each l2 word once only xen: events: Clean up round-robin evtchn scan. xen: events: Make last processed event channel a per-cpu variable. xen: events: Process event channels notifications in round-robin order. * 'stable/irq.ween_of_nr_irqs' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Fix compile error if CONFIG_SMP is not defined. xen: events: correct locking in xen_irq_from_pirq xen: events: propagate irq allocation failure instead of panicking xen: events: do not workaround too-small nr_irqs xen: events: remove use of nr_irqs as upper bound on number of pirqs xen: events: dynamically allocate irq info structures xen: events: maintain a list of Xen interrupts xen: events: push setup of irq<->{evtchn,ipi,virq,pirq} maps into irq_info init functions xen: events: turn irq_info constructors into initialiser functions xen: events: use per-cpu variable for cpu_evtchn_mask xen: events: refactor GSI pirq bindings functions xen: events: rename restore_cpu_pirqs -> restore_pirqs xen: events: remove unused public functions xen: events: fix xen_map_pirq_gsi error return xen: events: simplify comment xen: events: separate two unrelated halves of if condition Fix up trivial conflicts in drivers/xen/events.c
2011-03-17Merge branches 'stable/hvc-console', 'stable/gntalloc.v6' and ↵Linus Torvalds
'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/hvc-console' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/hvc: Disable probe_irq_on/off from poking the hvc-console IRQ line. * 'stable/gntalloc.v6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: gntdev: fix build warning xen/p2m/m2p/gnttab: do not add failed grant maps to m2p override xen-gntdev: Add cast to pointer xen-gntdev: Fix incorrect use of zero handle xen: change xen/[gntdev/gntalloc] to default m xen-gntdev: prevent using UNMAP_NOTIFY_CLEAR_BYTE on read-only mappings xen-gntdev: Avoid double-mapping memory xen-gntdev: Avoid unmapping ranges twice xen-gntdev: Use map->vma for checking map validity xen-gntdev: Fix unmap notify on PV domains xen-gntdev: Fix memory leak when mmap fails xen/gntalloc,gntdev: Add unmap notify ioctl xen-gntalloc: Userspace grant allocation driver xen-gntdev: Support mapping in HVM domains xen-gntdev: Add reference counting to maps xen-gntdev: Use find_vma rather than iterating our vma list manually xen-gntdev: Change page limit to be global instead of per-open * 'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (24 commits) xen-gntdev: Use ballooned pages for grant mappings xen-balloon: Add interface to retrieve ballooned pages xen-balloon: Move core balloon functionality out of module xen/balloon: Remove pr_info's and don't alter retry_count xen/balloon: Protect against CPU exhaust by event/x process xen/balloon: Migration from mod_timer() to schedule_delayed_work() xen/balloon: Removal of driver_pages
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: watchdog: booke_wdt: clean up status messages watchdog: cleanup spaces before tabs watchdog: convert to DEFINE_PCI_DEVICE_TABLE watchdog: Xen watchdog driver watchdog: Intel SCU Watchdog Timer Driver for Moorestown and Medfield platforms. watchdog: jz4740_wdt - fix magic character checking watchdog: add JZ4740 watchdog driver watchdog: it87_wdt: Add support for IT8721F watchdog watchdog: hpwdt: build hpwdt as module by default with NMI_DECODING enabled watchdog: hpwdt: Fix a couple of typos
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16xen: xenbus PM events supportKazuhiro SUZUKI
Make xenbus frontend device subscribe to PM events to receive suspend/resume/freeze/thaw/restore notifications. Signed-off-by: Kenji Wakamiya <wkenji@jp.fujitsu.com> Signed-off-by: Kazuhiro Suzuki <kaz@jp.fujitsu.com> Signed-off-by: Shriram Rajagopalan <rshriram@cs.ubc.ca> Acked-by: Ian Campbell <ian.campbell@citrix.com> [shriram--minor mods and improved commit message] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-16xen-balloon: Add interface to retrieve ballooned pagesKonrad Rzeszutek Wilk
Pages that have been ballooned are useful for other Xen drivers doing grant table actions, because these pages have valid struct page/PFNs but have no valid MFN so are available for remapping. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> [v2: Deal with rebasing on top of modified balloon code] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-16xen-balloon: Move core balloon functionality out of moduleDaniel De Graaf
The basic functionality of ballooning pages is useful for Xen drivers in general. Rather than require a dependency on the balloon module, split the functionality that is reused into the core. The balloon module is still required to follow ballooning requests from xenstore or to view balloon statistics in sysfs. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-15xen network backend driverIan Campbell
netback is the host side counterpart to the frontend driver in drivers/net/xen-netfront.c. The PV protocol is also implemented by frontend drivers in other OSes too, such as the BSDs and even Windows. The patch is based on the driver from the xen.git pvops kernel tree but has been put through the checkpatch.pl wringer plus several manual cleanup passes and review iterations. The driver has been moved from drivers/xen/netback to drivers/net/xen-netback. One major change from xen.git is that the guest transmit path (i.e. what looks like receive to netback) has been significantly reworked to remove the dependency on the out of tree PageForeign page flag (a core kernel patch which enables a per page destructor callback on the final put_page). This page flag was used in order to implement a grant map based transmit path (where guest pages are mapped directly into SKB frags). Instead this version of netback uses grant copy operations into regular memory belonging to the backend domain. Reinstating the grant map functionality is something which I would like to revisit in the future. Note that this driver depends on 2e820f58f7ad "xen/irq: implement bind_interdomain_evtchn_to_irqhandler for backend drivers" which is in linux next via the "xen-two" tree and is intended for the 2.6.39 merge window: git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen.git stable/backends this branch has only that single commit since 2.6.38-rc2 and is safe for cross merging into the net branch. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15Merge branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvmLinus Torvalds
* 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: suspend: remove xen_hvm_suspend xen: suspend: pull pre/post suspend hooks out into suspend_info xen: suspend: move arch specific pre/post suspend hooks into generic hooks xen: suspend: refactor non-arch specific pre/post suspend hooks xen: suspend: add "arch" to pre/post suspend hooks xen: suspend: pass extra hypercall argument via suspend_info struct xen: suspend: refactor cancellation flag into a structure xen: suspend: use HYPERVISOR_suspend for PVHVM case instead of open coding xen: switch to new schedop hypercall by default. xen: use new schedop interface for suspend xen: do not respond to unknown xenstore control requests xen: fix compile issue if XEN is enabled but XEN_PVHVM is disabled xen: PV on HVM: support PV spinlocks and IPIs xen: make the ballon driver work for hvm domains xen-blkfront: handle Xen major numbers other than XENVBD xen: do not use xen_info on HVM, set pv_info name to "Xen HVM" xen: no need to delay xen_setup_shutdown_event for hvm guests anymore
2011-03-15Merge branches 'stable/ia64', 'stable/blkfront-cleanup' and 'stable/cleanup' ↵Linus Torvalds
of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/ia64' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: ia64 build broken due to "xen: switch to new schedop hypercall by default." * 'stable/blkfront-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: Union the blkif_request request specific fields * 'stable/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: annotate functions which only call into __init at start of day xen p2m: annotate variable which appears unused xen: events: mark cpu_evtchn_mask_p as __refdata
2011-03-15watchdog: Xen watchdog driverJan Beulich
While the hypervisor change adding SCHEDOP_watchdog support included a daemon to make use of the new functionality, having a kernel driver for /dev/watchdog so that user space code doesn't need to distinguish non-Xen and Xen seems to be preferable. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-10xen: events: refactor GSI pirq bindings functionsIan Campbell
Following the example set by xen_allocate_pirq_msi and xen_bind_pirq_msi_to_irq: xen_allocate_pirq becomes xen_allocate_pirq_gsi and now only allocates a pirq number and does not bind it. xen_map_pirq_gsi becomes xen_bind_pirq_gsi_to_irq and binds an existing pirq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: remove unused public functionsIan Campbell
I was unable to find any user of these functions in either the functionality pending for 2.6.39 or the xen/next-2.6.32 branch of xen.git An exception to this was xen_gsi_from_irq which did appear to be used in xen/next-2.6.32's pciback. However in the 2.6.39 version of pciback xen_pirq_from_irq is, correctly AFAICT, used instead. Only a minority of functions in events.h use "extern" so drop it from those places for consistency. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: simplify commentIan Campbell
It is never valid assume any particular relationship between a Xen PIRQ number and and Linux IRQ number so there is no need to hedge when saying so. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: remove dom0 specific xen_create_msi_irqIan Campbell
The function name does not distinguish it from xen_allocate_pirq_msi (which operates on domU and pvhvm domains rather than dom0). Hoist domain 0 specific functionality up into the only caller leaving functionality common to all guest types in xen_bind_pirq_msi_to_irq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: use xen_bind_pirq_msi_to_irq from xen_create_msi_irqIan Campbell
2011-03-10xen: events: separate MSI PIRQ allocation from PIRQ binding to IRQIan Campbell
Split the binding aspect of xen_allocate_pirq_msi out into a new xen_bind_pirq_to_irq function. In xen_hvm_setup_msi_irq when allocating a pirq write the MSI message to signal the PIRQ as soon as the pirq is obtained. There is no way to free the pirq back so if the subsequent binding to an IRQ fails we want to ensure that we will reuse the PIRQ next time rather than leak it. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: return irq from xen_allocate_pirq_msiIan Campbell
consistent with other similar functions. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: drop XEN_ALLOC_IRQ flag to xen_allocate_pirq_msiIan Campbell
All callers pass this flag so it is pointless. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-08xen: Union the blkif_request request specific fieldsOwen Smith
Prepare for extending the block device ring to allow request specific fields, by moving the request specific fields for reads, writes and barrier requests to a union member. Acked-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Owen Smith <owen.smith@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-28xen/irq: implement bind_interdomain_evtchn_to_irqhandler for backend driversIan Campbell
Impact: new Xen-internal API Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-25xen: suspend: add "arch" to pre/post suspend hooksIan Campbell
xen_pre_device_suspend is unused on ia64. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-25xen: switch to new schedop hypercall by default.Ian Campbell
Rename old interface to sched_op_compat and rename sched_op_new to simply sched_op. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-25xen-blkfront: handle Xen major numbers other than XENVBDStefano Stabellini
This patch makes sure blkfront handles correctly virtual device numbers corresponding to Xen emulated IDE and SCSI disks: in those cases blkfront translates the major number to XENVBD and the minor number to a low xvd minor. Note: this behaviour is different from what old xenlinux PV guests used to do: they used to steal an IDE or SCSI major number and use it instead. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
2011-02-14xen/gntalloc,gntdev: Add unmap notify ioctlDaniel De Graaf
This ioctl allows the users of a shared page to be notified when the other end exits abnormally. [v2: updated description in structs] Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-14xen-gntalloc: Userspace grant allocation driverDaniel De Graaf
This allows a userspace application to allocate a shared page for implementing inter-domain communication or device drivers. These shared pages can be mapped using the gntdev device or by the kernel in another domain. Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-13Merge branch 'stable/gntdev' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/gntdev' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/p2m: Fix module linking error. xen p2m: clear the old pte when adding a page to m2p_override xen gntdev: use gnttab_map_refs and gnttab_unmap_refs xen: introduce gnttab_map_refs and gnttab_unmap_refs xen p2m: transparently change the p2m mappings in the m2p override xen/gntdev: Fix circular locking dependency xen/gntdev: stop using "token" argument xen: gntdev: move use of GNTMAP_contains_pte next to the map_op xen: add m2p override mechanism xen: move p2m handling to separate file xen/gntdev: add VM_PFNMAP to vma xen/gntdev: allow usermode to map granted pages xen: define gnttab_set_map_op/unmap_op Fix up trivial conflict in drivers/xen/Kconfig
2011-01-12Merge branch 'stable/xenbus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xenbus' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/xenbus: making backend support modular is too complex xen/pci: Make xen-pcifront be dependent on XEN_XENBUS_FRONTEND xen/xenbus: fixup checkpatch issues in xenbus_probe* xen/netfront: select XEN_XENBUS_FRONTEND xen/xenbus: clean up noise in xenbus_probe_frontend.c xen/xenbus: clean up noise in xenbus_probe_backend.c xen/xenbus: clean up noise in xenbus_probe.c xen/xenbus: cleanup debug noise in xenbus_comms.c xen/xenbus: clean up error handling xen/xenbus: make frontend bus GPL xen/xenbus: make sure backend bus is registered earlier xenbus/frontend: register bus earlier xen: remove xen/evtchn.h xen: add backend driver support xen: separate out frontend xenbus
2011-01-11xen: introduce gnttab_map_refs and gnttab_unmap_refsStefano Stabellini
gnttab_map_refs maps some grant refs and uses the new m2p override to set a proper m2p mapping for the granted pages. gnttab_unmap_refs unmaps the granted refs and removes th mappings from the m2p override. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-11xen/gntdev: allow usermode to map granted pagesGerd Hoffmann
The gntdev driver allows usermode to map granted pages from other domains. This is typically used to implement a Xen backend driver in user mode. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Stefano Stabellini <Stefano.Stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-11xen: define gnttab_set_map_op/unmap_opIan Campbell
Impact: hypercall definitions These functions populate the gnttab data structures used by the granttab map and unmap ops and are used in the backend drivers. Originally xen-unstable.hg 9625:c3bb51c443a7 [ Include Stefano's fix for phys_addr_t ] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-05xen: add backend driver supportIan Campbell
Impact: backend device support Add the basic machinery to support backend drivers. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> [corresponds to 79727b851bac in git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen.git] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-12-15xen: Provide a variant of __RING_SIZE() that is an integer constant expressionJeremy Fitzhardinge
Without this, gcc 4.5 won't compile xen-netfront and xen-blkfront, where this is being used to specify array sizes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: David Miller <davem@davemloft.net> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-02xen: fix MSI setup and teardown for PV on HVM guestsStefano Stabellini
When remapping MSIs into pirqs for PV on HVM guests, qemu is responsible for doing the actual mapping and unmapping. We only give qemu the desired pirq number when we ask to do the mapping the first time, after that we should be reading back the pirq number from qemu every time we want to re-enable the MSI. This fixes a bug in xen_hvm_setup_msi_irqs that manifests itself when trying to enable the same MSI for the second time: the old MSI to pirq mapping is still valid at this point but xen_hvm_setup_msi_irqs would try to assign a new pirq anyway. A simple way to reproduce this bug is to assign an MSI capable network card to a PV on HVM guest, if the user brings down the corresponding ethernet interface and up again, Linux would fail to enable MSIs on the device. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2010-12-02xen: use PHYSDEVOP_get_free_pirq to implement find_unbound_pirqStefano Stabellini
Use the new hypercall PHYSDEVOP_get_free_pirq to ask Xen to allocate a pirq. Remove the unsupported PHYSDEVOP_get_nr_pirqs hypercall to get the amount of pirq available. This fixes find_unbound_pirq that otherwise would return a number starting from nr_irqs that might very well be out of range in Xen. The symptom of this bug is that when you passthrough an MSI capable pci device to a PV on HVM guest, Linux would fail to enable MSIs on the device. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2010-11-22Merge branches 'upstream/core', 'upstream/xenfs' and 'upstream/evtchn' into ↵Jeremy Fitzhardinge
upstream/for-linus * upstream/core: xen/events: Use PIRQ instead of GSI value when unmapping MSI/MSI-X irqs. xen: set IO permission early (before early_cpu_init()) xen: re-enable boot-time ballooning xen/balloon: make sure we only include remaining extra ram xen/balloon: the balloon_lock is useless xen: add extra pages to balloon xen/events: use locked set|clear_bit() for cpu_evtchn_mask xen/evtchn: clear secondary CPUs' cpu_evtchn_mask[] after restore xen: implement XENMEM_machphys_mapping * upstream/xenfs: Revert "xen/privcmd: create address space to allow writable mmaps" xen/xenfs: update xenfs_mount for new prototype xen: fix header export to userspace xen: set vma flag VM_PFNMAP in the privcmd mmap file_op xen: xenfs: privcmd: check put_user() return code * upstream/evtchn: xen: make evtchn's name less generic xen/evtchn: the evtchn device is non-seekable xen/evtchn: add missing static xen/evtchn: Fix name of Xen event-channel device xen/evtchn: don't do unbind_from_irqhandler under spinlock xen/evtchn: remove spurious barrier xen/evtchn: ports start enabled xen/evtchn: dynamically allocate port_user array xen/evtchn: track enabled state for each port
2010-11-19xen: add extra pages to balloonJeremy Fitzhardinge
Add extra pages in the pseudo-physical address space to the balloon so we can extend into them later. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-11-16Merge commit 'v2.6.37-rc2' into upstream/xenfsJeremy Fitzhardinge
* commit 'v2.6.37-rc2': (10093 commits) Linux 2.6.37-rc2 capabilities/syslog: open code cap_syslog logic to fix build failure i2c: Sanity checks on adapter registration i2c: Mark i2c_adapter.id as deprecated i2c: Drivers shouldn't include <linux/i2c-id.h> i2c: Delete unused adapter IDs i2c: Remove obsolete cleanup for clientdata include/linux/kernel.h: Move logging bits to include/linux/printk.h Fix gcc 4.5.1 miscompiling drivers/char/i8k.c (again) hwmon: (w83795) Check for BEEP pin availability hwmon: (w83795) Clear intrusion alarm immediately hwmon: (w83795) Read the intrusion state properly hwmon: (w83795) Print the actual temperature channels as sources hwmon: (w83795) List all usable temperature sources hwmon: (w83795) Expose fan control method hwmon: (w83795) Fix fan control mode attributes hwmon: (lm95241) Check validity of input values hwmon: Change mail address of Hans J. Koch PCI: sysfs: fix printk warnings GFS2: Fix inode deallocation race ...
2010-11-16xen: fix header export to userspaceRandy Dunlap
scripts/headers_install.pl prevents "__user" from being exported to userspace headers, so just use compiler.h to make sure that __user is defined and avoid the error. unifdef: linux-next-20101112/xx64/usr/include/xen/privcmd.h.tmp: 79: Premature EOF (#if line 33 depth 1) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: xen-devel@lists.xensource.com (moderated for non-subscribers) Cc: virtualization@lists.osdl.org Cc: Tony Finch <dot@dotat.at> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-11-12xen: implement XENMEM_machphys_mappingIan Campbell
This hypercall allows Xen to specify a non-default location for the machine to physical mapping. This capability is used when running a 32 bit domain 0 on a 64 bit hypervisor to shrink the hypervisor hole to exactly the size required. [ Impact: add Xen hypercall definitions ] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
