commit 1e77d0a1ed7417d2a5a52a7b8d32aea1833faa6c upstream.
Till reported that the spurious interrupt detection of threaded
interrupts is broken in two ways:
- note_interrupt() is called for each action thread of a shared
interrupt line. That's wrong as we are only interested whether none
of the device drivers felt responsible for the interrupt, but by
calling multiple times for a single interrupt line we account
IRQ_NONE even if one of the drivers felt responsible.
- note_interrupt() when called from the thread handler is not
serialized. That leaves the members of irq_desc which are used for
the spurious detection unprotected.
To solve this we need to defer the spurious detection of a threaded
interrupt to the next hardware interrupt context where we have
implicit serialization.
If note_interrupt is called with action_ret == IRQ_WAKE_THREAD, we
check whether the previous interrupt requested a deferred check. If
not, we request a deferred check for the next hardware interrupt and
return.
If set, we check whether one of the interrupt threads signaled
success. Depending on this information we feed the result into the
spurious detector.
If one primary handler of a shared interrupt returns IRQ_HANDLED we
disable the deferred check of irq threads on the same line, as we have
found at least one device driver who cared.
Reported-by: Till Straumann <strauman@slac.stanford.edu>
Tested-by: Austin Schuh <austin@peloton-tech.com>
Cc: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: linux-can@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1303071450130.22263@ionos
commit 2426bd456a61407388b6e61fc5f98dbcbebc50e2 upstream.
When an initiator sends an allocation length bigger than what its
command consumes, the target should only return the actual response data
and set the residual length to the unused part of the allocation length.
Add a helper function that command handlers (INQUIRY, READ CAPACITY,
etc) can use to do this correctly, and use this code to get the correct
residual for commands that don't use the full initiator allocation in the
handlers for READ CAPACITY, READ CAPACITY(16), INQUIRY, MODE SENSE and
REPORT LUNS.
This addresses a handful of failures as reported by Christophe with
the Windows Certification Kit:
http://permalink.gmane.org/gmane.linux.scsi.target.devel/6515
Signed-off-by: Roland Dreier <roland@purestorage.com>
Tested-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr>
commit 4e52365f279564cef0ddd41db5237f0471381093 upstream.
When tracing a process in another pid namespace, it's important for fork
event messages to contain the child's pid as seen from the tracer's pid
namespace, not the parent's. Otherwise, the tracer won't be able to
correlate the fork event with later SIGTRAP signals it receives from the
child.
We still risk a race condition if a ptracer from a different pid
namespace attaches after we compute the pid_t value. However, sending a
bogus fork event message in this unlikely scenario is still a vast
improvement over the status quo where we always send bogus fork event
messages to debuggers in a different pid namespace than the forking
process.
Signed-off-by: Matthew Dempsky <mdempsky@chromium.org>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Julien Tinnes <jln@chromium.org>
Cc: Roland McGrath <mcgrathr@chromium.org>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
commit 07f4d9d74a04aa7c72c5dae0ef97565f28f17b92 upstream.
The user-control put and get handlers as well as the tlv do not protect against
concurrent access from multiple threads. Since the state of the control is not
updated atomically it is possible that either two write operations or a write
and a read operation race against each other. Both can lead to arbitrary memory
disclosure. This patch introduces a new lock that protects user-controls from
concurrent access. Since applications typically access controls sequentially
than in parallel a single lock per card should be fine.
Acked-by: Jaroslav Kysela <perex@perex.cz>
struct for all platform.
commit 2bd0ae464a6cf7363bbf72c8545e0aa43caa57f0 upstream.
Cancel the optimization of compiler for struct snd_compr_avail
which size will be 0x1c in 32bit kernel while 0x20 in 64bit
kernel under the optimizer. That will make compaction between
32bit and 64bit. So add packed to fix the size of struct
snd_compr_avail to 0x1c for all platform.
Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com>
Signed-off-by: xiaoming wang <xiaoming.wang@intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 9d0d68faea6962d62dd501cd6e71ce5cc8ed262b ]
Now it is not possible to set mtu to team device which has a port
enslaved to it. The reason is that when team_change_mtu() calls
dev_set_mtu() for port device, notificator for NETDEV_PRECHANGEMTU
event is called and team_device_event() returns NOTIFY_BAD forbidding
the change. So fix this by returning NOTIFY_DONE here in case team is
changing mtu in team_change_mtu().
Introduced-by: 3d249d4c "net: introduce ethernet teaming device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 39c36094d78c39e038c1e499b2364e13bce36f54 ]
I noticed we were sending wrong IPv4 ID in TCP flows when MTU discovery
is disabled.
Note how GSO/TSO packets do not have monotonically incrementing ID.
06:37:41.575531 IP (id 14227, proto: TCP (6), length: 4396)
06:37:41.575534 IP (id 14272, proto: TCP (6), length: 65212)
06:37:41.575544 IP (id 14312, proto: TCP (6), length: 57972)
06:37:41.575678 IP (id 14317, proto: TCP (6), length: 7292)
06:37:41.575683 IP (id 14361, proto: TCP (6), length: 63764)
It appears I introduced this bug in linux-3.1.
inet_getid() must return the old value of peer->ip_id_count,
not the new one.
Lets revert this part, and remove the prevention of
a null identification field in IPv6 Fragment Extension Header,
which is dubious and not even done properly.
Fixes: 87c48fa3b463 ("ipv6: make fragment identifications less predictable")
[ Upstream commit 2d7a85f4b06e9c27ff629f07a524c48074f07f81 ]
It was possible to get a setuid root or setcap executable to write to
it's stdout or stderr (which has been set made a netlink socket) and
inadvertently reconfigure the networking stack.
To prevent this we check that both the creator of the socket and
the currentl applications has permission to reconfigure the network
stack.
Unfortunately this breaks Zebra which always uses sendto/sendmsg
and creates it's socket without any privileges.
To keep Zebra working don't bother checking if the creator of the
socket has privilege when a destination address is specified. Instead
rely exclusively on the privileges of the sender of the socket.
Note from Andy: This is exactly Eric's code except for some comment
clarifications and formatting fixes. Neither I nor, I think, anyone
else is thrilled with this approach, but I'm hesitant to wait on a
better fix since 3.15 is almost here.
Note to stable maintainers: This is a mess. An earlier series of
patches in 3.15 fix a rather serious security issue (CVE-2014-0181),
but they did so in a way that breaks Zebra. The offending series
includes:
commit aa4cf9452f469f16cea8c96283b641b4576d4a7b
Author: Eric W. Biederman <ebiederm@xmission.com>
Date: Wed Apr 23 14:28:03 2014 -0700
net: Add variants of capable for use on netlink messages
If a given kernel version is missing that series of fixes, it's
probably worth backporting it and this patch. if that series is
present, then this fix is critical if you care about Zebra.
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit aa4cf9452f469f16cea8c96283b641b4576d4a7b ]
netlink_net_capable - The common case use, for operations that are safe on a network namespace
netlink_capable - For operations that are only known to be safe for the global root
netlink_ns_capable - The general case of capable used to handle special cases
__netlink_ns_capable - Same as netlink_ns_capable except taking a netlink_skb_parms instead of
the skbuff of a netlink message.
[ Upstream commit a3b299da869d6e78cf42ae0b1b41797bcb8c5e4b ]
sk_net_capable - The common case, operations that are safe in a network namespace.
sk_capable - Operations that are not known to be safe in a network namespace
sk_ns_capable - The general case for special cases.
[ Upstream commit a53b72c83a4216f2eb883ed45a0cbce014b8e62d ]
The permission check in sock_diag_put_filterinfo is wrong, and it is so removed
from it's sources it is not clear why it is wrong. Move the computation
into packet_diag_dump and pass a bool of the result into sock_diag_filterinfo.
This does not yet correct the capability check but instead simply moves it to make
it clear what is going on.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream.
This patch keeps track of how long perf's NMI handler is taking,
and also calculates how many samples perf can take a second. If
the sample length times the expected max number of samples
exceeds a configurable threshold, it drops the sample rate.
This way, we don't have a runaway sampling process eating up the
CPU.
This patch can tend to drop the sample rate down to level where
perf doesn't work very well. *BUT* the alternative is that my
system hangs because it spends all of its time handling NMIs.
I'll take a busted performance tool over an entire system that's
busted and undebuggable any day.
BTW, my suspicion is that there's still an underlying bug here.
Using the HPET instead of the TSC is definitely a contributing
factor, but I suspect there are some other things going on.
But, I can't go dig down on a bug like that with my machine
hanging all the time.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: paulus@samba.org
Cc: acme@ghostprotocols.net
Cc: Dave Hansen <dave@sr71.net>
[ Prettified it a bit. ]
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit 7ac3764fcafc06e72e1a79a9d998b9fdd900b2a6 upstream.
The file include/uapi/linux/usb/cdc-wdm.h uses a __u16 so it needs to
include types.h as well to make the build system happy.
Fixes: 3edce1cf813a ("USB: cdc-wdm: implement IOCTL_WDM_MAX_COMMAND")
Cc: Bjørn Mork <bjorn@mork.no>
commit 7d1896360f4d055d68565ef8ed56a677580f1a39 upstream.
The include/uapi/linux/usb/cdc-wdm.h header defines cdc-wdm
userspace APIs and should be exported by make headers_install.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 4c88d7f9b0d5fb0588c3386be62115cc2eaa8f9f upstream.
Patch 01f8fa4f01d "genirq: Allow forcing cpu affinity of interrupts" added
an irq_force_affinity() function, and 30ccf03b4a6 "clocksource: Exynos_mct:
Use irq_force_affinity() in cpu bringup" subsequently uses it. However, the
driver can be used with CONFIG_SMP disabled, but the function declaration
is only available for CONFIG_SMP, leading to this build error:
drivers/clocksource/exynos_mct.c:431:3: error: implicit declaration of function 'irq_force_affinity' [-Werror=implicit-function-declaration]
irq_force_affinity(mct_irqs[MCT_L0_IRQ + cpu], cpumask_of(cpu));
This patch introduces a dummy helper function for the non-SMP case
that always returns success, to get rid of the build error.
Since the patches causing the problem are marked for stable backports,
this one should be as well.
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Link: http://lkml.kernel.org/r/5619084.0zmrrIUZLV@wuerfel
commit 098507ae3ec2331476fb52e85d4040c1cc6d0ef4 upstream.
The replacement of the 'count' variable by two variables 'incs' and
'decs' to resolve some race conditions during module unloading was done
in parallel with some cleanup in the trace subsystem, and was integrated
as a merge.
Unfortunately, the formula for this replacement was wrong in the tracing
code, and the refcount in the traces was not usable as a result.
Use 'count = incs - decs' to compute the user count.
Link: http://lkml.kernel.org/p/1393924179-9147-1-git-send-email-romain.izard.pro@gmail.com
Acked-by: Ingo Molnar <mingo@kernel.org>
Fixes: c1ab9cab7509 "merge conflict resolution"
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
commit 03367ef5ea811475187a0732aada068919e14d61 upstream.
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality
is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the
VMBUS protocol.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit cbfbbabb89b37f6bad05f478d906a385149f288d upstream.
The version of the drm_tegra_submit structure that was merged all the
way back in 3.10 contains a pad field that was originally intended to
properly pad the following __u64 field. Unfortunately it seems like a
different field was dropped during review that caused this padding to
become unnecessary, but the pad field wasn't removed at that time.
One possible side-effect of this is that since the __u64 following the
pad is now no longer properly aligned, the compiler may (or may not)
introduce padding itself, which results in no predictable ABI.
Rectify this by removing the pad field so that all fields are again
naturally aligned. Technically this is breaking existing userspace ABI,
but given that there aren't any (released) userspace drivers that make
use of this yet, the fallout should be minimal.
Fixes: d43f81cbaf43 ("drm/tegra: Add gr2d device")
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream.
The current implementation of irq_set_affinity() refuses rightfully to
route an interrupt to an offline cpu.
But there is a special case, where this is actually desired. Some of
the ARM SoCs have per cpu timers which require setting the affinity
during cpu startup where the cpu is not yet in the online mask.
If we can't do that, then the local timer interrupt for the about to
become online cpu is routed to some random online cpu.
The developers of the affected machines tried to work around that
issue, but that results in a massive mess in that timer code.
We have a yet unused argument in the set_affinity callbacks of the irq
chips, which I added back then for a similar reason. It was never
required so it got not used. But I'm happy that I never removed it.
That allows us to implement a sane handling of the above scenario. So
the affected SoC drivers can add the required force handling to their
interrupt chip, switch the timer code to irq_force_affinity() and
things just work.
This does not affect any existing user of irq_set_affinity().
Tagged for stable to allow a simple fix of the affected SoC clock
event drivers.
Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>,
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>,
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: linux-arm-kernel@lists.infradead.org,
Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de
commit a949ae560a511fe4e3adf48fa44fefded93e5c2b upstream.
A race exists between module loading and enabling of function tracer.
CPU 1 CPU 2
load_module()
module->state = MODULE_STATE_COMING
register_ftrace_function()
mutex_lock(&ftrace_lock);
ftrace_startup()
update_ftrace_function();
ftrace_arch_code_modify_prepare()
set_all_module_text_rw();
<enables-ftrace>
ftrace_arch_code_modify_post_process()
set_all_module_text_ro();
[ here all module text is set to RO,
including the module that is
loading!! ]
blocking_notifier_call_chain(MODULE_STATE_COMING);
ftrace_init_module()
[ tries to modify code, but it's RO, and fails!
ftrace_bug() is called]
When this race happens, ftrace_bug() will produces a nasty warning and
all of the function tracing features will be disabled until reboot.
The simple solution is to treate module load the same way the core
kernel is treated at boot. To hardcode the ftrace function modification
of converting calls to mcount into nops. This is done in init/main.c
there's no reason it could not be done in load_module(). This gives
a better control of the changes and doesn't tie the state of the
module to its notifiers as much. Ftrace is special, it needs to be
treated as such.
The reason this would work, is that the ftrace_module_init() would be
called while the module is in MODULE_STATE_UNFORMED, which is ignored
by the set_all_module_text_ro() call.
Link: http://lkml.kernel.org/r/1395637826-3312-1-git-send-email-indou.takao@jp.fujitsu.com
Reported-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
[ Upstream commit 78541c1dc60b65ecfce5a6a096fc260219d6784e ]
The caller needs capabilities on the namespace being queried, not on
their own namespace. This is a security bug, although it likely has
only a minor impact.
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit b14878ccb7fac0242db82720b784ab62c467c0dc ]
Currently, it is possible to create an SCTP socket, then switch
auth_enable via sysctl setting to 1 and crash the system on connect:
Oops[#1]:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.1-mipsgit-20140415 #1
task: ffffffff8056ce80 ti: ffffffff8055c000 task.ti: ffffffff8055c000
Call Trace:
[<ffffffff8043c4e8>] sctp_auth_asoc_set_default_hmac+0x68/0x80
[<ffffffff8042b300>] sctp_process_init+0x5e0/0x8a4
[<ffffffff8042188c>] sctp_sf_do_5_1B_init+0x234/0x34c
[<ffffffff804228c8>] sctp_do_sm+0xb4/0x1e8
[<ffffffff80425a08>] sctp_endpoint_bh_rcv+0x1c4/0x214
[<ffffffff8043af68>] sctp_rcv+0x588/0x630
[<ffffffff8043e8e8>] sctp6_rcv+0x10/0x24
[<ffffffff803acb50>] ip6_input+0x2c0/0x440
[<ffffffff8030fc00>] __netif_receive_skb_core+0x4a8/0x564
[<ffffffff80310650>] process_backlog+0xb4/0x18c
[<ffffffff80313cbc>] net_rx_action+0x12c/0x210
[<ffffffff80034254>] __do_softirq+0x17c/0x2ac
[<ffffffff800345e0>] irq_exit+0x54/0xb0
[<ffffffff800075a4>] ret_from_irq+0x0/0x4
[<ffffffff800090ec>] rm7k_wait_irqoff+0x24/0x48
[<ffffffff8005e388>] cpu_startup_entry+0xc0/0x148
[<ffffffff805a88b0>] start_kernel+0x37c/0x398
Code: dd0900b8 000330f8 0126302d <dcc60000> 50c0fff1 0047182a a48306a0
03e00008 00000000
---[ end trace b530b0551467f2fd ]---
Kernel panic - not syncing: Fatal exception in interrupt
What happens while auth_enable=0 in that case is, that
ep->auth_hmacs is initialized to NULL in sctp_auth_init_hmacs()
when endpoint is being created.
After that point, if an admin switches over to auth_enable=1,
the machine can crash due to NULL pointer dereference during
reception of an INIT chunk. When we enter sctp_process_init()
via sctp_sf_do_5_1B_init() in order to respond to an INIT chunk,
the INIT verification succeeds and while we walk and process
all INIT params via sctp_process_param() we find that
net->sctp.auth_enable is set, therefore do not fall through,
but invoke sctp_auth_asoc_set_default_hmac() instead, and thus,
dereference what we have set to NULL during endpoint
initialization phase.
The fix is to make auth_enable immutable by caching its value
during endpoint initialization, so that its original value is
being carried along until destruction. The bug seems to originate
from the very first days.
Fix in joint work with Daniel Borkmann.
Reported-by: Joshua Kinard <kumba@gentoo.org>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Joshua Kinard <kumba@gentoo.org>
[ Upstream commit 30f78d8ebf7f514801e71b88a10c948275168518 ]
Francois reported that setting big mtu on loopback device could prevent
tcp sessions making progress.
We do not support (yet ?) IPv6 Jumbograms and cook corrupted packets.
We must limit the IPv6 MTU to (65535 + 40) bytes in theory.
Tested:
ifconfig lo mtu 70000
netperf -H ::1
Before patch : Throughput : 0.05 Mbits
After patch : Throughput : 35484 Mbits
Reported-by: Francois WELLENREITER <f.wellenreiter@gmail.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 008208c6b26f21c2648c250a09c55e737c02c5f8 ]
Add two trivial helpers list_next_entry() and list_prev_entry(), they
can have a lot of users including list.h itself. In fact the 1st one is
already defined in events/core.c and bnx2x_sp.c, so the patch simply
moves the definition to list.h.
Cc: Eilon Greenstein <eilong@broadcom.com>
commit 29c7787075c92ca8af353acd5301481e6f37082f upstream.
David Vrabel identified a regression when using automatic NUMA balancing
under Xen whereby page table entries were getting corrupted due to the
use of native PTE operations. Quoting him
Xen PV guest page tables require that their entries use machine
addresses if the preset bit (_PAGE_PRESENT) is set, and (for
successful migration) non-present PTEs must use pseudo-physical
addresses. This is because on migration MFNs in present PTEs are
translated to PFNs (canonicalised) so they may be translated back
to the new MFN in the destination domain (uncanonicalised).
pte_mknonnuma(), pmd_mknonnuma(), pte_mknuma() and pmd_mknuma()
set and clear the _PAGE_PRESENT bit using pte_set_flags(),
pte_clear_flags(), etc.
In a Xen PV guest, these functions must translate MFNs to PFNs
when clearing _PAGE_PRESENT and translate PFNs to MFNs when setting
_PAGE_PRESENT.
His suggested fix converted p[te|md]_[set|clear]_flags to using
paravirt-friendly ops but this is overkill. He suggested an alternative
of using p[te|md]_modify in the NUMA page table operations but this is
does more work than necessary and would require looking up a VMA for
protections.
This patch modifies the NUMA page table operations to use paravirt
friendly operations to set/clear the flags of interest. Unfortunately
this will take a performance hit when updating the PTEs on
CONFIG_PARAVIRT but I do not see a way around it that does not break
Xen.
Acked-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Steven Noonan <steven@uplinklabs.net>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
commit 223b02d923ecd7c84cf9780bb3686f455d279279 upstream.
"len" contains sizeof(nf_ct_ext) and size of extensions. In a worst
case it can contain all extensions. Bellow you can find sizes for all
types of extensions. Their sum is definitely bigger than 256.
nf_ct_ext_types[0]->len = 24
nf_ct_ext_types[1]->len = 32
nf_ct_ext_types[2]->len = 24
nf_ct_ext_types[3]->len = 32
nf_ct_ext_types[4]->len = 152
nf_ct_ext_types[5]->len = 2
nf_ct_ext_types[6]->len = 16
nf_ct_ext_types[7]->len = 8
I have seen "len" up to 280 and my host has crashes w/o this patch.
The right way to fix this problem is reducing the size of the ecache
extension (4) and Florian is going to do this, but these changes will
be quite large to be appropriate for a stable tree.
Fixes: 5b423f6a40a0 (netfilter: nf_conntrack: fix racy timer handling with reliable)
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
commit af5040da01ef980670b3741b3e10733ee3e33566 upstream.
trace_block_rq_complete does not take into account that request can
be partially completed, so we can get the following incorrect output
of blkparser:
C R 232 + 240 [0]
C R 240 + 232 [0]
C R 248 + 224 [0]
C R 256 + 216 [0]
but should be:
C R 232 + 8 [0]
C R 240 + 8 [0]
C R 248 + 8 [0]
C R 256 + 8 [0]
Also, the whole output summary statistics of completed requests and
final throughput will be incorrect.
This patch takes into account real completion size of the request and
fixes wrong completion accounting.
Signed-off-by: Roman Pen <r.peniaev@gmail.com>
CC: Steven Rostedt <rostedt@goodmis.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
CC: Ingo Molnar <mingo@redhat.com>
CC: linux-kernel@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
commit e63ed0d7a98014fdfc2cfeb3f6dada313dcabb59 upstream.
This patch eliminates the reap_ref and replaces it with a proper kref.
On last put of this kref, the target is removed from visibility in
sysfs. The final call to scsi_target_reap() for the device is done from
__scsi_remove_device() and only if the device was made visible. This
ensures that the target disappears as soon as the last device is gone
rather than waiting until final release of the device (which is often
too long).
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 8a4aeec8d2d6a3edeffbdfae451cdf05cbf0fefd upstream.
The AHCI spec allows implementations to issue commands in tag order
rather than FIFO order:
5.3.2.12 P:SelectCmd
HBA sets pSlotLoc = (pSlotLoc + 1) mod (CAP.NCS + 1)
or HBA selects the command to issue that has had the
PxCI bit set to '1' longer than any other command
pending to be issued.
The result is that commands posted sequentially (time-wise) may play out
of sequence when issued by hardware.
This behavior has likely been hidden by drives that arrange for commands
to complete in issue order. However, it appears recent drives (two from
different vendors that we have found so far) inflict out-of-order
completions as a matter of course. So, we need to take care to maintain
ordered submission, otherwise we risk triggering a drive to fall out of
sequential-io automation and back to random-io processing, which incurs
large latency and degrades throughput.
This issue was found in simple benchmarks where QD=2 seq-write
performance was 30-50% *greater* than QD=32 seq-write performance.
Tagging for -stable and making the change globally since it has a low
risk-to-reward ratio. Also, word is that recent versions of an unnamed
OS also does it this way now. So, drives in the field are already
experienced with this tag ordering scheme.
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Ed Ciechanowski <ed.ciechanowski@intel.com>
Reviewed-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
commit 3064639423c48d6e0eb9ecc27c512a58e38c6c57 upstream.
There could be a case, when NFSd file system is mounted in network, different
to socket's one, like below:
"ip netns exec" creates new network and mount namespace, which duplicates NFSd
mount point, created in init_net context. And thus NFS server stop in nested
network context leads to RPCBIND client destruction in init_net.
Then, on NFSd start in nested network context, rpc.nfsd process creates socket
in nested net and passes it into "write_ports", which leads to RPCBIND sockets
creation in init_net context because of the same reason (NFSd monut point was
created in init_net context). An attempt to register passed socket in nested
net leads to panic, because no RPCBIND client present in nexted network
namespace.
This patch add check that passed socket's net matches NFSd superblock's one.
And returns -EINVAL error to user psace otherwise.
v2: Put socket on exit.
Reported-by: Weng Meiling <wengmeiling.weng@huawei.com>
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5acda9d12dcf1ad0d9a5a2a7c646de3472fa7555 upstream.
After commit 839a8e8660b6 ("writeback: replace custom worker pool
implementation with unbound workqueue") when device is removed while we
are writing to it we crash in bdi_writeback_workfn() ->
set_worker_desc() because bdi->dev is NULL.
This can happen because even though bdi_unregister() cancels all pending
flushing work, nothing really prevents new ones from being queued from
balance_dirty_pages() or other places.
Fix the problem by clearing BDI_registered bit in bdi_unregister() and
checking it before scheduling of any flushing work.
Fixes: 839a8e8660b6777e7fe4e80af1a048aebe2b5977
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: Derek Basehore <dbasehore@chromium.org>
commit 95731ebb114c5f0c028459388560fc2a72fe5049 upstream.
Cpufreq governors' stop and start operations should be carried out
in sequence. Otherwise, there will be unexpected behavior, like in
the example below.
Suppose there are 4 CPUs and policy->cpu=CPU0, CPU1/2/3 are linked
to CPU0. The normal sequence is:
1) Current governor is userspace. An application tries to set the
governor to ondemand. It will call __cpufreq_set_policy() in
which it will stop the userspace governor and then start the
ondemand governor.
2) Current governor is userspace. The online of CPU3 runs on CPU0.
It will call cpufreq_add_policy_cpu() in which it will first
stop the userspace governor, and then start it again.
If the sequence of the above two cases interleaves, it becomes:
1) Application stops userspace governor
2) Hotplug stops userspace governor
which is a problem, because the governor shouldn't be stopped twice
in a row. What happens next is:
3) Application starts ondemand governor
4) Hotplug starts a governor
In step 4, the hotplug is supposed to start the userspace governor,
but now the governor has been changed by the application to ondemand,
so the ondemand governor is started once again, which is incorrect.
The solution is to prevent policy governors from being stopped
multiple times in a row. A governor should only be stopped once for
one policy. After it has been stopped, no more governor stop
operations should be executed.
Also add a mutex to serialize governor operations.
[rjw: Changelog. And you owe me a beverage of my choice.]
Signed-off-by: Xiaoguang Chen <chenxg@marvell.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream.
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
[geert: Backported to v3.10..v3.13]
[ Upstream commit 14a0d635d18d0fb552dcc979d6d25106e6541f2e ]
This fixes a race which happens by freeing an object on the stack.
Quoting Julius:
> The issue is
> that it calls usbnet_terminate_urbs() before that, which temporarily
> installs a waitqueue in dev->wait in order to be able to wait on the
> tasklet to run and finish up some queues. The waiting itself looks
> okay, but the access to 'dev->wait' is totally unprotected and can
> race arbitrarily. I think in this case usbnet_bh() managed to succeed
> it's dev->wait check just before usbnet_terminate_urbs() sets it back
> to NULL. The latter then finishes and the waitqueue_t structure on its
> stack gets overwritten by other functions halfway through the
> wake_up() call in usbnet_bh().
The fix is to just not allocate the data structure on the stack.
As dev->wait is abused as a flag it also takes a runtime PM change
to fix this bug.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Reported-by: Grant Grundler <grundler@google.com>
Tested-by: Grant Grundler <grundler@google.com>
[ Upstream commit c3f9b01849ef3bc69024990092b9f42e20df7797 ]
Lars Persson reported following deadlock :
-000 |M:0x0:0x802B6AF8(asm) <-- arch_spin_lock
-001 |tcp_v4_rcv(skb = 0x8BD527A0) <-- sk = 0x8BE6B2A0
-002 |ip_local_deliver_finish(skb = 0x8BD527A0)
-003 |__netif_receive_skb_core(skb = 0x8BD527A0, ?)
-004 |netif_receive_skb(skb = 0x8BD527A0)
-005 |elk_poll(napi = 0x8C770500, budget = 64)
-006 |net_rx_action(?)
-007 |__do_softirq()
-008 |do_softirq()
-009 |local_bh_enable()
-010 |tcp_rcv_established(sk = 0x8BE6B2A0, skb = 0x87D3A9E0, th = 0x814EBE14, ?)
-011 |tcp_v4_do_rcv(sk = 0x8BE6B2A0, skb = 0x87D3A9E0)
-012 |tcp_delack_timer_handler(sk = 0x8BE6B2A0)
-013 |tcp_release_cb(sk = 0x8BE6B2A0)
-014 |release_sock(sk = 0x8BE6B2A0)
-015 |tcp_sendmsg(?, sk = 0x8BE6B2A0, ?, ?)
-016 |sock_sendmsg(sock = 0x8518C4C0, msg = 0x87D8DAA8, size = 4096)
-017 |kernel_sendmsg(?, ?, ?, ?, size = 4096)
-018 |smb_send_kvec()
-019 |smb_send_rqst(server = 0x87C4D400, rqst = 0x87D8DBA0)
-020 |cifs_call_async()
-021 |cifs_async_writev(wdata = 0x87FD6580)
-022 |cifs_writepages(mapping = 0x852096E4, wbc = 0x87D8DC88)
-023 |__writeback_single_inode(inode = 0x852095D0, wbc = 0x87D8DC88)
-024 |writeback_sb_inodes(sb = 0x87D6D800, wb = 0x87E4A9C0, work = 0x87D8DD88)
-025 |__writeback_inodes_wb(wb = 0x87E4A9C0, work = 0x87D8DD88)
-026 |wb_writeback(wb = 0x87E4A9C0, work = 0x87D8DD88)
-027 |wb_do_writeback(wb = 0x87E4A9C0, force_wait = 0)
-028 |bdi_writeback_workfn(work = 0x87E4A9CC)
-029 |process_one_work(worker = 0x8B045880, work = 0x87E4A9CC)
-030 |worker_thread(__worker = 0x8B045880)
-031 |kthread(_create = 0x87CADD90)
-032 |ret_from_kernel_thread(asm)
Bug occurs because __tcp_checksum_complete_user() enables BH, assuming
it is running from softirq context.
Lars trace involved a NIC without RX checksum support but other points
are problematic as well, like the prequeue stuff.
Problem is triggered by a timer, that found socket being owned by user.
tcp_release_cb() should call tcp_write_timer_handler() or
tcp_delack_timer_handler() in the appropriate context :
BH disabled and socket lock held, but 'owned' field cleared,
as if they were running from timer handlers.
Fixes: 6f458dfb4092 ("tcp: improve latencies of timer triggered events")
Reported-by: Lars Persson <lars.persson@axis.com>
Tested-by: Lars Persson <lars.persson@axis.com>
commit 668f9abbd4334e6c29fa8acd71635c4f9101caa7 upstream.
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit d29adb34a94715174c88ca93e8aba955850c9bde upstream.
The PAUSEWR and PAUSERD flags are meant to stop the cluster from
processing writes and reads, respectively. The FULL flag is set when
the cluster determines that it is out of space, and will no longer
process writes. PAUSEWR and PAUSERD are purely client-side settings
already implemented in userspace clients. The osd does nothing special
with these flags.
When the FULL flag is set, however, the osd responds to all writes
with -ENOSPC. For cephfs, this makes sense, but for rbd the block
layer translates this into EIO. If a cluster goes from full to
non-full quickly, a filesystem on top of rbd will not behave well,
since some writes succeed while others get EIO.
Fix this by blocking any writes when the FULL flag is set in the osd
client. This is the same strategy used by userspace, so apply it by
default. A follow-on patch makes this configurable.
__map_request() is called to re-target osd requests in case the
available osds changed. Add a paused field to a ceph_osd_request, and
set it whenever an appropriate osd map flag is set. Avoid queueing
paused requests in __map_request(), but force them to be resent if
they become unpaused.
Also subscribe to the next osd map from the monitor if any of these
flags are set, so paused requests can be unblocked as soon as
possible.
Fixes: http://tracker.ceph.com/issues/6079
Reviewed-by: Sage Weil <sage@inktank.com>
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
commit 87291347c49dc40aa339f587b209618201c2e527 upstream.
In event format strings, the array size is reported in two locations.
One in array subscript and then via the "size:" attribute. The values
reported there have a mismatch.
For e.g., in sched:sched_switch the prev_comm and next_comm character
arrays have subscript values as [32] where as the actual field size is
16.
format:
field:unsigned short common_type; offset:0; size:2; signed:0;
field:unsigned char common_flags; offset:2; size:1; signed:0;
field:unsigned char common_preempt_count; offset:3; size:1;signed:0;
field:int common_pid; offset:4; size:4; signed:1;
field:char prev_comm[32]; offset:8; size:16; signed:1;
field:pid_t prev_pid; offset:24; size:4; signed:1;
field:int prev_prio; offset:28; size:4; signed:1;
field:long prev_state; offset:32; size:8; signed:1;
field:char next_comm[32]; offset:40; size:16; signed:1;
field:pid_t next_pid; offset:56; size:4; signed:1;
field:int next_prio; offset:60; size:4; signed:1;
After bisection, the following commit was blamed:
92edca0 tracing: Use direct field, type and system names
This commit removes the duplication of strings for field->name and
field->type assuming that all the strings passed in
__trace_define_field() are immutable. This is not true for arrays, where
the type string is created in event_storage variable and field->type for
all array fields points to event_storage.
Use __stringify() to create a string constant for the type string.
Also, get rid of event_storage and event_storage_mutex that are not
needed anymore.
also, an added benefit is that this reduces the overhead of events a bit more:
8424787 2036472 1302528 11763787 b3804b vmlinux
8420814 2036408 1302528 11759750 b37086 vmlinux.patched
Link: http://lkml.kernel.org/r/1392349908-29685-1-git-send-email-vnagarnaik@google.com
Cc: Laurent Chavey <chavey@google.com>
Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com>
commit defd884845297fd5690594bfe89656b01f16d87e upstream.
This patch addresses a couple of different hug shutdown issues
related to wait_event() + isert_conn->state. First, it changes
isert_conn->conn_wait + isert_conn->conn_wait_comp_err from
waitqueues to completions, and sets ISER_CONN_TERMINATING from
within isert_disconnect_work().
Second, it splits isert_free_conn() into isert_wait_conn() that
is called earlier in iscsit_close_connection() to ensure that
all outstanding commands have completed before continuing.
Finally, it breaks isert_cq_comp_err() into seperate TX / RX
related code, and adds logic in isert_cq_rx_comp_err() to wait
for outstanding commands to complete before setting ISER_CONN_DOWN
and calling complete(&isert_conn->conn_wait_comp_err).
Acked-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
commit 5a581b367b5df0531265311fc681c2abd377e5e6 upstream.
According to the C standard 3.4.3p3, overflow of a signed integer results
in undefined behavior. This commit therefore changes the definitions
of time_after(), time_after_eq(), time_after64(), and time_after_eq64()
to avoid this undefined behavior. The trick is that the subtraction
is done using unsigned arithmetic, which according to 6.2.5p9 cannot
overflow because it is defined as modulo arithmetic. This has the added
(though admittedly quite small) benefit of shortening four lines of code
by four characters each.
Note that the C standard considers the cast from unsigned to
signed to be implementation-defined, see 6.3.1.3p3. However, on a
two's-complement system, an implementation that defines anything other
than a reinterpretation of the bits is free to come to me, and I will be
happy to act as a witness for its being committed to an insane asylum.
(Although I have nothing against saturating arithmetic or signals in some
cases, these things really should not be the default when compiling an
operating-system kernel.)
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kevin Easton <kevin@guarana.org>
[ paulmck: Included time_after64() and time_after_eq64(), as suggested
by Eric Dumazet, also fixed commit message.]
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Ruchi Kandoi <kandoiruchi@google.com>
commit 70044d71d31d6973665ced5be04ef39ac1c09a48 upstream.
PREPARE_[DELAYED_]WORK() are being phased out. They have few users
and a nasty surprise in terms of reentrancy guarantee as workqueue
considers work items to be different if they don't have the same work
function.
firewire core-device and sbp2 have been been multiplexing work items
with multiple work functions. Introduce fw_device_workfn() and
sbp2_lu_workfn() which invoke fw_device->workfn and
sbp2_logical_unit->workfn respectively and always use the two
functions as the work functions and update the users to set the
->workfn fields instead of overriding work functions using
PREPARE_DELAYED_WORK().
This fixes a variety of possible regressions since a2c1c57be8d9
"workqueue: consider work function when searching for busy work items"
due to which fw_workqueue lost its required non-reentrancy property.
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: linux1394-devel@lists.sourceforge.net
commit 45ab2813d40d88fc575e753c38478de242d03f88 upstream.
If a module fails to add its tracepoints due to module tainting, do not
create the module event infrastructure in the debugfs directory. As the events
will not work and worse yet, they will silently fail, making the user wonder
why the events they enable do not display anything.
Having a warning on module load and the events not visible to the users
will make the cause of the problem much clearer.
Link: http://lkml.kernel.org/r/20140227154923.265882695@goodmis.org
Fixes: 6d723736e472 "tracing/events: add support for modules to TRACE_EVENT"
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
[ Upstream commit f5ddcbbb40aa0ba7fbfe22355d287603dbeeaaac ]
This patch fixes two bugs in fastopen :
1) The tcp_sendmsg(..., @size) argument was ignored.
Code was relying on user not fooling the kernel with iovec mismatches
2) When MTU is about 64KB, tcp_send_syn_data() attempts order-5
allocations, which are likely to fail when memory gets fragmented.
Fixes: 783237e8daf13 ("net-tcp: Fast Open client - sending SYN-data")
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Tested-by: Yuchung Cheng <ycheng@google.com>
commit f3713fd9cff733d9df83116422d8e4af6e86b2bb upstream.
Commit 93e6f119c0ce ("ipc/mqueue: cleanup definition names and
locations") added global hardcoded limits to the amount of message
queues that can be created. While these limits are per-namespace,
reality is that it ends up breaking userspace applications.
Historically users have, at least in theory, been able to create up to
INT_MAX queues, and limiting it to just 1024 is way too low and dramatic
for some workloads and use cases. For instance, Madars reports:
"This update imposes bad limits on our multi-process application. As
our app uses approaches that each process opens its own set of queues
(usually something about 3-5 queues per process). In some scenarios
we might run up to 3000 processes or more (which of-course for linux
is not a problem). Thus we might need up to 9000 queues or more. All
processes run under one user."
Other affected users can be found in launchpad bug #1155695:
https://bugs.launchpad.net/ubuntu/+source/manpages/+bug/1155695
Instead of increasing this limit, revert it entirely and fallback to the
original way of dealing queue limits -- where once a user's resource
limit is reached, and all memory is used, new queues cannot be created.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Reported-by: Madars Vitolins <m@silodev.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream.
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
commit d206940319c41df4299db75ed56142177bb2e5f6 upstream.
Will be used by upcoming ipv4 forward path change that needs to
determine feature mask using skb->dst->dev instead of skb->dev.
commit de960aa9ab4decc3304959f69533eef64d05d8e8 upstream.
[ no skb_gso_seglen helper in 3.10, leave tbf alone ]
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
[ Upstream commit 0ae89beb283a0db5980d1d4781c7d7be2f2810d6 ]
Self generated skbuffs in net/can/bcm.c are setting a skb->sk reference but
no explicit destructor which is enforced since Linux 3.11 with commit
376c7311bdb6 (net: add a temporary sanity check in skb_orphan()).
This patch adds some helper functions to make sure that a destructor is
properly defined when a sock reference is assigned to a CAN related skb.
To create an unshared skb owned by the original sock a common helper function
has been introduced to replace open coded functions to create CAN echo skbs.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Tested-by: Andre Naujoks <nautsch2@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
