path: root/include
2010-10-11neigh: reorder struct neighbour fieldsEric Dumazet
Le mardi 12 octobre 2010 à 00:02 +0200, Eric Dumazet a écrit : > Here is the followup patch. > > Thanks ! > Oops, this was an old version, the up2date ones also took care of "used" field. I guess its time for a sleep, sorry again. [PATCH net-next V2] neigh: reorder struct neighbour fields (refcnt) and (ha_lock, ha, used, dev, output, ops, primary_key) should be placed on a separate cache lines. refcnt can be often written, while other fields are mostly read. This gave me good result on stress test : before: real 0m45.570s user 0m15.525s sys 9m56.669s After: real 0m41.841s user 0m15.261s sys 8m45.949s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11net dst: use a percpu_counter to track entriesEric Dumazet
struct dst_ops tracks number of allocated dst in an atomic_t field, subject to high cache line contention in stress workload. Switch to a percpu_counter, to reduce number of time we need to dirty a central location. Place it on a separate cache line to avoid dirtying read only fields. Stress test : (Sending 160.000.000 UDP frames, IP route cache disabled, dual E5540 @2.53GHz, 32bit kernel, FIB_TRIE, SLUB/NUMA) Before: real 0m51.179s user 0m15.329s sys 10m15.942s After: real 0m45.570s user 0m15.525s sys 9m56.669s With a small reordering of struct neighbour fields, subject of a following patch, (to separate refcnt from other read mostly fields) real 0m41.841s user 0m15.261s sys 8m45.949s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11neigh: Protect neigh->ha[] with a seqlockEric Dumazet
Add a seqlock in struct neighbour to protect neigh->ha[], and avoid dirtying neighbour in stress situation (many different flows / dsts) Dirtying takes place because of read_lock(&n->lock) and n->used writes. Switching to a seqlock, and writing n->used only on jiffies changes permits less dirtying. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/ethtool.c
2010-10-11neigh: speedup neigh_hh_init()Eric Dumazet
When a new dst is used to send a frame, neigh_resolve_output() tries to associate an struct hh_cache to this dst, calling neigh_hh_init() with the neigh rwlock write locked. Most of the time, hh_cache is already known and linked into neighbour, so we find it and increment its refcount. This patch changes the logic so that we call neigh_hh_init() with neighbour lock read locked only, so that fast path can be run in parallel by concurrent cpus. This brings part of the speedup we got with commit c7d4426a98a5f (introduce DST_NOCACHE flag) for non cached dsts, even for cached ones, removing one of the contention point that routers hit on multiqueue enabled machines. Further improvements would need to use a seqlock instead of an rwlock to protect neigh->ha[], to not dirty neigh too often and remove two atomic ops. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Phonet: cleanup pipe enable socket optionRémi Denis-Courmont
The current code works like this: int garbage, status; socklen_t len = sizeof(status); /* enable pipe */ setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &garbage, sizeof(garbage)); /* disable pipe */ setsockopt(fd, SOL_PNPIPE, PNPIPE_DISABLE, &garbage, sizeof(garbage)); /* get status */ getsockopt(fd, SOL_PNPIPE, PNPIPE_INQ, &status, &len); ...which does not follow the usual socket option pattern. This patch merges all three "options" into a single gettable&settable option, before Linux 2.6.37 gets out: int status; socklen_t len = sizeof(status); /* enable pipe */ status = 1; setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status)); /* disable pipe */ status = 0; setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status)); /* get status */ getsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, &len); This also fixes the error code from EFAULT to ENOTCONN. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Cc: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-10-08Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ipw2x00/ipw2200.c
2010-10-07cfg80211: constify WDS addressJohannes Berg
There's no need for the WDS peer address to not be const, so make it const. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-07Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
2010-10-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/pcmcia/pcnet_cs.c net/caif/caif_socket.c
2010-10-06neigh: RCU conversion of struct neighbourEric Dumazet
This is the second step for neighbour RCU conversion. (first was commit d6bf7817 : RCU conversion of neigh hash table) neigh_lookup() becomes lockless, but still take a reference on found neighbour. (no more read_lock()/read_unlock() on tbl->lock) struct neighbour gets an additional rcu_head field and is freed after an RCU grace period. Future work would need to eventually not take a reference on neighbour for temporary dst (DST_NOCACHE), but this would need dst->_neighbour to use a noref bit like we did for skb->_dst. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06nl80211/mac80211: Add retry and failed transmission count to station infoBruno Randolf
This information is already available in mac80211, we just need to export it via cfg80211 and nl80211. Signed-off-by: Bruno Randolf <br1@einfach.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06cfg80211/mac80211: allow per-station GTKsJohannes Berg
This adds API to allow adding per-station GTKs, updates mac80211 to support it, and also allows drivers to remove a key from hwaccel again when this may be necessary due to multiple GTKs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05fib: RCU conversion of fib_lookup()Eric Dumazet
fib_lookup() converted to be called in RCU protected context, no reference taken and released on a contended cache line (fib_clntref) fib_table_lookup() and fib_semantic_match() get an additional parameter. struct fib_info gets an rcu_head field, and is freed after an rcu grace period. Stress test : (Sending 160.000.000 UDP frames on same neighbour, IP route cache disabled, dual E5540 @2.53GHz, 32bit kernel, FIB_HASH) (about same results for FIB_TRIE) Before patch : real 1m31.199s user 0m13.761s sys 23m24.780s After patch: real 1m5.375s user 0m14.997s sys 15m50.115s Before patch Profile : 13044.00 15.4% __ip_route_output_key vmlinux 8438.00 10.0% dst_destroy vmlinux 5983.00 7.1% fib_semantic_match vmlinux 5410.00 6.4% fib_rules_lookup vmlinux 4803.00 5.7% neigh_lookup vmlinux 4420.00 5.2% _raw_spin_lock vmlinux 3883.00 4.6% rt_set_nexthop vmlinux 3261.00 3.9% _raw_read_lock vmlinux 2794.00 3.3% fib_table_lookup vmlinux 2374.00 2.8% neigh_resolve_output vmlinux 2153.00 2.5% dst_alloc vmlinux 1502.00 1.8% _raw_read_lock_bh vmlinux 1484.00 1.8% kmem_cache_alloc vmlinux 1407.00 1.7% eth_header vmlinux 1406.00 1.7% ipv4_dst_destroy vmlinux 1298.00 1.5% __copy_from_user_ll vmlinux 1174.00 1.4% dev_queue_xmit vmlinux 1000.00 1.2% ip_output vmlinux After patch Profile : 13712.00 15.8% dst_destroy vmlinux 8548.00 9.9% __ip_route_output_key vmlinux 7017.00 8.1% neigh_lookup vmlinux 4554.00 5.3% fib_semantic_match vmlinux 4067.00 4.7% _raw_read_lock vmlinux 3491.00 4.0% dst_alloc vmlinux 3186.00 3.7% neigh_resolve_output vmlinux 3103.00 3.6% fib_table_lookup vmlinux 2098.00 2.4% _raw_read_lock_bh vmlinux 2081.00 2.4% kmem_cache_alloc vmlinux 2013.00 2.3% _raw_spin_lock vmlinux 1763.00 2.0% __copy_from_user_ll vmlinux 1763.00 2.0% ip_output vmlinux 1761.00 2.0% ipv4_dst_destroy vmlinux 1631.00 1.9% eth_header vmlinux 1440.00 1.7% _raw_read_unlock_bh vmlinux Reference results, if IP route cache is enabled : real 0m29.718s user 0m10.845s sys 7m37.341s 25213.00 29.5% __ip_route_output_key vmlinux 9011.00 10.5% dst_release vmlinux 4817.00 5.6% ip_push_pending_frames vmlinux 4232.00 5.0% ip_finish_output vmlinux 3940.00 4.6% udp_sendmsg vmlinux 3730.00 4.4% __copy_from_user_ll vmlinux 3716.00 4.4% ip_route_output_flow vmlinux 2451.00 2.9% __xfrm_lookup vmlinux 2221.00 2.6% ip_append_data vmlinux 1718.00 2.0% _raw_spin_lock_bh vmlinux 1655.00 1.9% __alloc_skb vmlinux 1572.00 1.8% sock_wfree vmlinux 1345.00 1.6% kfree vmlinux Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05bonding: add retransmit membership reports tunableFlavio Leitner
Allow sysadmins to configure the number of multicast membership report sent on a link failure event. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net neigh: RCU conversion of neigh hash tableEric Dumazet
David This is the first step for RCU conversion of neigh code. Next patches will convert hash_buckets[] and "struct neighbour" to RCU protected objects. Thanks [PATCH net-next] net neigh: RCU conversion of neigh hash table Instead of storing hash_buckets, hash_mask and hash_rnd in "struct neigh_table", a new structure is defined : struct neigh_hash_table { struct neighbour **hash_buckets; unsigned int hash_mask; __u32 hash_rnd; struct rcu_head rcu; }; And "struct neigh_table" has an RCU protected pointer to such a neigh_hash_table. This means the signature of (*hash)() function changed: We need to add a third parameter with the actual hash_rnd value, since this is not anymore a neigh_table field. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: add a core netdev->rx_dropped counterEric Dumazet
In various situations, a device provides a packet to our stack and we drop it before it enters protocol stack : - softnet backlog full (accounted in /proc/net/softnet_stat) - bad vlan tag (not accounted) - unknown/unregistered protocol (not accounted) We can handle a per-device counter of such dropped frames at core level, and automatically adds it to the device provided stats (rx_dropped), so that standard tools can be used (ifconfig, ip link, cat /proc/net/dev) This is a generalization of commit 8990f468a (net: rx_dropped accounting), thus reverting it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: rcu_read_lock_bh_held(): disabling irqs also disables bh generic-ipi: Fix deadlock in __smp_call_function_single
2010-10-05wait: using uninitialized member of wait queueEvgeny Kuznetsov
The "flags" member of "struct wait_queue_t" is used in several places in the kernel code without beeing initialized by init_wait(). "flags" is used in bitwise operations. If "flags" not initialized then unexpected behaviour may take place. Incorrect flags might used later in code. Added initialization of "wait_queue_t.flags" with zero value into "init_wait". Signed-off-by: Evgeny Kuznetsov <EXT-Eugeny.Kuznetsov@nokia.com> [ The bit we care about does end up being initialized by both prepare_to_wait() and add_to_wait_queue(), so this doesn't seem to cause actual bugs, but is definitely the right thing to do -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05Merge branch 'wireless-next' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/luca/wl12xx
2010-10-05nl80211: fix remain-on-channel documentationJohannes Berg
The documentation for NL80211_CMD_REMAIN_ON_CHANNEL isn't accurate, an interface index is required by the command. Update it accordingly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05genetlink: introduce pre_doit/post_doit hooksJohannes Berg
Each family may have some amount of boilerplate locking code that applies to most, or even all, commands. This allows a family to handle such things in a more generic way, by allowing it to a) include private flags in each operation b) specify a pre_doit hook that is called, before an operation's doit() callback and may return an error directly, c) specify a post_doit hook that can undo locking or similar things done by pre_doit, and finally d) include two private pointers in each info struct passed between all these operations including doit(). (It's two because I'll need two in nl80211 -- can be extended.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05mac80211: distinct between max rates and the number of rates the hw can reportHelmut Schaa
Some drivers cannot handle multiple retry rates specified by the rc algorithm but instead use their own retry table (for example rt2800). However, if such a device registers itself with a max_rates value of 1 the rc algorithm cannot make use of the extended information the device can provide about retried rates. On the other hand, if a device registers itself with a max_rates value > 1 the rc algorithm assumes that the device can handle multi rate retries. Fix this issue by introducing another hw parameter max_report_rates that can be set to a different value then max_rates to indicate if a device is capable of reporting more rates then specified in max_rates. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05cfg80211: patches to allow setting the WDS peerBill Jordan
Added a nl interface to set the peer bssid of a WDS interface. Signed-off-by: Bill Jordan <bjordan@rajant.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05cfg80211: remove spurious __KERNEL__ ifdefJohannes Berg
The net/cfg80211.h header file isn't exported to userspace, so there's no need for any kind of __KERNEL__ protection in it. If it was exported, everything else in it would need protection as well, not just the logging stuff ... Cc:Joe Perches <joe@perches.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05nl80211: allow drivers to indicate whether the survey data channel is in useFelix Fietkau
Some user space applications only want to display survey data for the operating channel, however there is no API to get that yet. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05ipv6: make __ipv6_isatap_ifid staticstephen hemminger
Another exported symbol only used in one file Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05fib: fib_rules_cleanup can be staticstephen hemminger
fib_rules_cleanup_ups is only defined and used in one place. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: relax rtnl_dereference()David S. Miller
rtnl_dereference() is used in contexts where RTNL is held, to fetch an RCU protected pointer. Updates to this pointer are prevented by RTNL, so we dont need smp_read_barrier_depends() and the ACCESS_ONCE() provided in rcu_dereference_check(). rtnl_dereference() is mainly a macro to document the locking invariant. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: dynamic ingress_queue allocationEric Dumazet
ingress being not used very much, and net_device->ingress_queue being quite a big object (128 or 256 bytes), use a dynamic allocation if needed (tc qdisc add dev eth0 ingress ...) dev_ingress_queue(dev) helper should be used only with RTNL taken. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-10-03net: introduce DST_NOCACHE flagEric Dumazet
While doing stress tests with IP route cache disabled, and multi queue devices, I noticed a very high contention on one rwlock used in neighbour code. When many cpus are trying to send frames (possibly using a high performance multiqueue device) to the same neighbour, they fight for the neigh->lock rwlock in order to call neigh_hh_init(), and fight on hh->hh_refcnt (a pair of atomic_inc/atomic_dec_and_test()) But we dont need to call neigh_hh_init() for dst that are used only once. It costs four atomic operations at least, on two contended cache lines, plus the high contention on neigh->lock rwlock. Introduce a new dst flag, DST_NOCACHE, that is set when dst was not inserted in route cache. With the stress test bench, sending 160000000 frames on one neighbour, results are : Before patch: real 2m28.406s user 0m11.781s sys 36m17.964s After patch: real 1m26.532s user 0m12.185s sys 20m3.903s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03Merge branch 'for-davem' of ↵David S. Miller
2010-10-03ipmr: RCU protection for mfc_cache_arrayEric Dumazet
Use RCU & RTNL protection for mfc_cache_array[] ipmr_cache_find() is called under rcu_read_lock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-01Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: vmwgfx: Fix fb VRAM pinning failure due to fragmentation vmwgfx: Remove initialisation of dev::devname vmwgfx: Enable use of the vblank system vmwgfx: vt-switch (master drop) fixes drm/vmwgfx: Fix breakage introduced by commit "drm: block userspace under allocating buffer and having drivers overwrite it (v2)" drm: Hold the mutex when dropping the last GEM reference (v2) drm/gem: handlecount isn't really a kref so don't make it one. drm: i810/i830: fix locked ioctl variant drm/radeon/kms: add quirk for MSI K9A2GM motherboard drm/radeon/kms: fix potential segfault in r600_ioctl_wait_idle drm: Prune GEM vma entries drm/radeon/kms: fix up encoder info messages for DFP6 drm/radeon: fix PCI ID 5657 to be an RV410
2010-10-01Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: invoke DSDT corruption workaround on all Toshiba Satellite ACPI, APEI, Fix ERST MOVE_DATA instruction implementation ACPI: fan: Fix more unbalanced code block ACPI: acpi_pad: simplify code to avoid false gcc build warning ACPI, APEI, Fix error path for memory allocation ACPI, APEI, HEST Fix the unsuitable usage of platform_data ACPI, APEI, Fix acpi_pre_map() return value ACPI, APEI, Fix APEI related table size checking ACPI: Disable Windows Vista compatibility for Toshiba P305D ACPI: Kconfig: fix typo. ACPI: add missing __percpu markup in arch/x86/kernel/acpi/cstate.c ACPI: Fix typos ACPI video: fix a poor warning message ACPI: fix build warnings resulting from merge window conflict ACPI: EC: add Vista incompatibility DMI entry for Toshiba Satellite L355 ACPI: expand Vista blacklist to include SP1 and SP2 ACPI: delete ZEPTO idle=nomwait DMI quirk ACPI: enable repeated PCIEXP wakeup by clearing PCIEXP_WAKE_STS on resume PM / ACPI: Blacklist systems known to require acpi_sleep=nonvs ACPI: Don't report current_now if battery reports in mWh
2010-10-01Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: Voluntary leave_mm before entering deeper acpi_idle: add missing \n to printk intel_idle: add missing __percpu markup intel_idle: Change mode 755 => 644 cpuidle: Fix typos intel_idle: PCI quirk to prevent Lenovo Ideapad s10-3 boot hang
2010-10-01Merge branch 'master' of ↵John W. Linville
2010-10-01drm: Hold the mutex when dropping the last GEM reference (v2)Chris Wilson
In order to be fully threadsafe we need to check that the drm_gem_object refcount is still 0 after acquiring the mutex in order to call the free function. Otherwise, we may encounter scenarios like: Thread A: Thread B: drm_gem_close unreference_unlocked kref_put mutex_lock ... i915_gem_evict ... kref_get -> BUG ... i915_gem_unbind ... kref_put ... i915_gem_object_free ... mutex_unlock mutex_lock i915_gem_object_free -> BUG i915_gem_object_unbind kfree mutex_unlock Note that no driver is currently using the free_unlocked vfunc and it is scheduled for removal, hasten that process. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=30454 Reported-and-Tested-by: Magnus Kessler <Magnus.Kessler@gmx.net> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-01neigh: reorder fields in struct neighbourEric Dumazet
On 64bit arches, there are two 32bit holes that we can remove. sizeof(struct neighbour) shrinks from 0xf8 to 0xf0 bytes Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-30ipv4: introduce __ip_dev_find()Eric Dumazet
ip_dev_find(net, addr) finds a device given an IPv4 source address and takes a reference on it. Introduce __ip_dev_find(), taking a third argument, to optionally take the device reference. Callers not asking the reference to be taken should be in an rcu_read_lock() protected section. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-30intel_idle: Voluntary leave_mm before entering deeperSuresh Siddha
Avoid TLB flush IPIs for the cores in deeper c-states by voluntary leave_mm() before entering into that state. CPUs tend to flush TLB in those c-states anyways. acpi_idle does this with C3-type states, but it was not caried over when intel_idle was introduced. intel_idle can apply it to C-states in addition to those that ACPI might export as C3... Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-01drm/gem: handlecount isn't really a kref so don't make it one.Dave Airlie
There were lots of places being inconsistent since handle count looked like a kref but it really wasn't. Fix this my just making handle count an atomic on the object, and have it increase the normal object kref. Now i915/radeon/nouveau drivers can drop the normal reference on userspace object creation, and have the handle hold it. This patch fixes a memory leak or corruption on unload, because the driver had no way of knowing if a handle had been actually added for this object, and the fbcon object needed to know this to clean itself up properly. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-30Bluetooth: Fix deadlock in the ERTM logicGustavo F. Padovan
The Enhanced Retransmission Mode(ERTM) is a realiable mode of operation of the Bluetooth L2CAP layer. Think on it like a simplified version of TCP. The problem we were facing here was a deadlock. ERTM uses a backlog queue to queue incomimg packets while the user is helding the lock. At some moment the sk_sndbuf can be exceeded and we can't alloc new skbs then the code sleep with the lock to wait for memory, that stalls the ERTM connection once we can't read the acknowledgements packets in the backlog queue to free memory and make the allocation of outcoming skb successful. This patch actually affect all users of bt_skb_send_alloc(), i.e., all L2CAP modes and SCO. We are safe against socket states changes or channels deletion while the we are sleeping wait memory. Checking for the sk->sk_err and sk->sk_shutdown make the code safe, since any action that can leave the socket or the channel in a not usable state set one of the struct members at least. Then we can check both of them when getting the lock again and return with the proper error if something unexpected happens. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Ulisses Furquim <ulisses@profusion.mobi>
2010-09-30wl12xx: fix non-wl12xx build scenariosOhad Ben-Cohen
Support building wl1271-equipped boards without building the wl1271 driver itself, e.g.: CONFIG_MACH_OMAP_ZOOM3=y CONFIG_WL12XX is not set Reported-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
2010-09-29tcp: tcp_enter_quickack_mode can be staticstephen hemminger
Function only used in tcp_input.c Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29arp: remove unnecessary export of arp_broken_opsstephen hemminger
arp_broken_ops is only used in arp.c Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: dmaengine: fix interrupt clearing for mv_xor missing inline keyword for static function in linux/dmaengine.h dma/shdma: move dereference below the NULL check
