commit fe1ae7fdd2ee603f2d95f04e09a68f7f79045127 upstream.
Various drivers have hacks to mangle termios structures. This stems from
the fact there is no nice setup hook for configuring the termios settings
when the port is created
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 7ca0ff9ab3218ec443a7a9ad247e4650373ed41e upstream.
Now we are extracting out methods for shutdown and the like we can add a
proper tty_port_close method that knows all the innards of the tty closing
process and hides the lot from the caller.
At some point in the future this will be paired with a similar open()
helper and the drivers can stick to hardware management.
commit 827b4649d4626bf97b203b4bcd69476bb9b4e760 upstream.
pcmcia_socket_dev_suspend() doesn't use its second argument, so it
may be dropped safely.
This change is necessary for the subsequent yenta suspend/resume fix.
commit 07708c4af1346ab1521b26a202f438366b7bcffd upstream.
So far unprivileged guest callers running in ring 3 can issue, e.g., MMU
hypercalls. Normally, such callers cannot provide any hand-crafted MMU
command structure as it has to be passed by its physical address, but
they can still crash the guest kernel by passing random addresses.
To close the hole, this patch considers hypercalls valid only if issued
from guest ring 0. This may still be relaxed on a per-hypercall base in
the future once required.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
tc: Fix unitialized kernel memory leak
pkt_sched: Revert tasklet_hrtimer changes.
net: sk_free() should be allowed right after sk_alloc()
gianfar: gfar_remove needs to call unregister_netdev()
ipw2200: firmware DMA loading rework
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: skcipher - Fix skcipher_dequeue_givcrypt NULL test
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm snapshot: fix on disk chunk size validation
dm exception store: split set_chunk_size
dm snapshot: fix header corruption race on invalidation
dm snapshot: refactor zero_disk_area to use chunk_io
dm log: userspace add luid to distinguish between concurrent log instances
dm raid1: do not allow log_failure variable to unset after being set
dm log: remove incorrect field from userspace table output
dm log: fix userspace status output
dm stripe: expose correct io hints
dm table: add more context to terse warning messages
dm table: fix queue_limit checking device iterator
dm snapshot: implement iterate devices
dm multipath: fix oops when request based io fails when no paths
Tom Horsley reports that his debugger hangs when it tries to read
/proc/pid_of_tracee/maps, this happens since
"mm_for_maps: take ->cred_guard_mutex to fix the race with exec"
04b836cbf19e885f8366bccb2e4b0474346c02d
commit in 2.6.31.
But the root of the problem lies in the fact that do_execve() path calls
tracehook_report_exec() which can stop if the tracer sets PT_TRACE_EXEC.
The tracee must not sleep in TASK_TRACED holding this mutex. Even if we
remove ->cred_guard_mutex from mm_for_maps() and proc_pid_attr_write(),
another task doing PTRACE_ATTACH should not hang until it is killed or the
tracee resumes.
With this patch do_execve() does not use ->cred_guard_mutex directly and
we do not hold it throughout, instead:
- introduce prepare_bprm_creds() helper, it locks the mutex
and calls prepare_exec_creds() to initialize bprm->cred.
- install_exec_creds() drops the mutex after commit_creds(),
and thus before tracehook_report_exec()->ptrace_stop().
or, if exec fails,
free_bprm() drops this mutex when bprm->cred != NULL which
indicates install_exec_creds() was not called.
Reported-by: Tom Horsley <tom.horsley@att.net>
Cc: Roland McGrath <roland@redhat.com>
cancel_delayed_work() has to use del_timer_sync() to guarantee the timer
function is not running after return. But most users doesn't actually
need this, and del_timer_sync() has problems: it is not useable from
interrupt, and it depends on every lock which could be taken from irq.
Introduce __cancel_delayed_work() which calls del_timer() instead.
The immediate reason for this patch is
http://bugzilla.kernel.org/show_bug.cgi?id=13757
but hopefully this helper makes sense anyway.
As for 13757 bug, actually we need requeue_delayed_work(), but its
semantics are not yet clear.
Merge this patch early to resolves cross-tree interdependencies between
input and infiniband.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Device-mapper userspace logs (like the clustered log) are
identified by a universally unique identifier (UUID). This
identifier is used to associate requests from the kernel to
a specific log in userspace. The UUID must be unique everywhere,
since multiple machines may use this identifier when communicating
about a particular log, as is the case for cluster logs.
Sometimes, device-mapper/LVM may re-use a UUID. This is the
case during pvmoves, when moving from one segment of an LV
to another, or when resizing a mirror, etc. In these cases,
a new log is created with the same UUID and loaded in the
"inactive" slot. When a device-mapper "resume" is issued,
the "live" table is deactivated and the new "inactive" table
becomes "live". (The "inactive" table can also be removed
via a device-mapper 'clear' command.)
The above two issues were colliding. More than one log was being
created with the same UUID, and there was no way to distinguish
between them. So, sometimes the wrong log would be swapped
out during the exchange.
The solution is to create a locally unique identifier,
'luid', to go along with the UUID. This new identifier is used
to determine exactly which log is being referenced by the kernel
when the log exchange is made. The identifier is not
universally safe, but it does not need to be, since
create/destroy/suspend/resume operations are bound to a specific
machine; and these are the operations that make up the exchange.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Set sensible I/O hints for striped DM devices in the topology
infrastructure added for 2.6.31 for userspace tools to
obtain via sysfs.
Add .io_hints to 'struct target_type' to allow the I/O hints portion
(io_min and io_opt) of the 'struct queue_limits' to be set by each
target and implement this for dm-stripe.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
These are full of unresolved problems, mainly that conversions don't
work 1-1 from hrtimers to tasklet_hrtimers because unlike hrtimers
tasklets can't be killed from softirq context.
And when a qdisc gets reset, that's exactly what we need to do here.
We'll work this out in the net-next-2.6 tree and if warranted we'll
backport that work to -stable.
This reverts the following 3 changesets:
a2cb6a4dd470d7a64255a10b843b0d188416b78f
("pkt_sched: Fix bogon in tasklet_hrtimer changes.")
38acce2d7983632100a9ff3fd20295f6e34074a8
("pkt_sched: Convert CBQ to tasklet_hrtimer.")
ee5f9757ea17759e1ce5503bdae2b07e48e32af9
("pkt_sched: Convert qdisc_watchdog to tasklet_hrtimer")
My previous patch (commit 4f8ee2c9cc: "lmb: Remove __init from
lmb_end_of_DRAM()") removed __init in lmb.c but missed the fact that it
was also marked as such in the .h
As struct skcipher_givcrypt_request includes struct crypto_request
at a non-zero offset, testing for NULL after converting the pointer
returned by crypto_dequeue_request does not work. This can result
in IPsec crashes when the queue is depleted.
This patch fixes it by doing the pointer conversion only when the
return value is non-NULL. In particular, we create a new function
__crypto_dequeue_request that does the pointer conversion.
Reported-by: Brad Bosch <bradbosch@comcast.net>
If the BIOS reports an invalid throttling state (which seems to be
fairly common after system boot), a reset is done to state T0.
Because of a check in acpi_processor_get_throttling_ptc(), the reset
never actually gets executed, which results in the error reoccurring
on every access of for example /proc/acpi/processor/CPU0/throttling.
Add a 'force' option to acpi_processor_set_throttling() to ensure
the reset really takes effect.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13389
This patch, together with the next one, fixes a regression introduced in
2.6.30, listed on the regression list. They have been available for 2.5
months now in bugzilla, but have not been picked up, despite various
reminders and without any reason given.
Google shows that numerous people are hitting this issue. The issue is in
itself relatively minor, but the bug in the code is clear.
The patches have been in all my kernels and today testing has shown that
throttling works correctly with the patches applied when the system
overheats (http://bugzilla.kernel.org/show_bug.cgi?id=13918#c14).
Signed-off-by: Frans Pop <elendil@planet.nl>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
It's problematic to allow signed element_nr's or total's to be passed as
part of the flex array API.
flex_array_alloc() allows total_nr_elements to be set to a negative
quantity, which is obviously erroneous.
flex_array_get() and flex_array_put() allows negative array indices in
dereferencing an array part, which could address memory mapped before
struct flex_array.
The fix is to convert all existing element_nr formals to be qualified as
unsigned. Existing checks to compare it to total_nr_elements or the max
array size based on element_size need not be changed.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
The `parts' member of struct flex_array should evaluate to an incomplete
type so that sizeof() cannot be used and C99 does not require the
zero-length specification.
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed
user_shm_lock() calls in hugetlb_file_setup() but left the
user_shm_unlock call in shm_destroy().
In detail:
Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock()
is not called in hugetlb_file_setup(). However, user_shm_unlock() is
called in any case in shm_destroy() and in the following
atomic_dec_and_lock(&up->__count) in free_uid() is executed and if
up->__count gets zero, also cleanup_user_struct() is scheduled.
Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set.
However, the ref counter up->__count gets unexpectedly non-positive and
the corresponding structs are freed even though there are live
references to them, resulting in a kernel oops after a lots of
shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set.
Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the
time of shm_destroy() may give a different answer from at the time
of hugetlb_file_setup(). And fixed newseg()'s no_id error path,
which has missed user_shm_unlock() ever since it came in 2.6.9.
Reported-by: Stefan Huber <shuber2@gmail.com>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Tested-by: Stefan Huber <shuber2@gmail.com>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: ucb1400_ts - enable interrupt unconditionally
Input: ucb1400_ts - enable ADC Filter
Input: wacom - don't use on-stack memory for report buffers
Input: iforce - support new revision of ACT LABS Force RS
Input: joydev - decouple axis and button map ioctls from input constants
smc91x: let smc91x work well under netpoll
pxaficp-ir: remove incorrect net_device_ops
NET: llc, zero sockaddr_llc struct
drivers/net: fixed drivers that support netpoll use ndo_start_xmit()
netpoll: warning for ndo_start_xmit returns with interrupts enabled
net: Fix Micrel KSZ8842 Kconfig description
netfilter: xt_quota: fix wrong return value (error case)
ipv6: Fix commit 63d9950b08184e6531adceb65f64b429909cc101 (ipv6: Make v4-mapped bindings consistent with IPv4)
E100: fix interaction with swiotlb on X86.
rtl8187: always set MSR_LINK_ENEDCA flag with RTL8187B
ibm_newemac: emac_close() needs to call netif_carrier_off()
net: fix ks8851 build errors
net: Rename MAC platform driver for w90p910 platform
yellowfin: Fix buffer underrun after dev_alloc_skb() failure
orinoco: correct key bounds check in orinoco_hw_get_tkip_iv
mac80211: fix todo lock
vfs_read() offset is defined as loff_t, but kernel_read()
offset is only defined as unsigned long. Redefine
kernel_read() offset as loff_t.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
None of this stuff should execute in hw IRQ context, therefore
use a tasklet_hrtimer so that it runs in softirq context.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon: add GET_PARAM/INFO support for Z pipes
drm/radeon/kms: add r100/r200 OQ support.
drm: Fix sysfs device confusion.
drm/radeon/kms: implement the bo busy ioctl properly.
When 'and'ing two bitmasks (where 'andnot' is a variation on it), some
cases want to know whether the result is the empty set or not. In
particular, the TLB IPI sending code wants to do cpumask operations and
determine if there are any CPU's left in the final set.
So this just makes the bitmask (and cpumask) functions return a boolean
for whether the result has any bits set.
Cc: stable@kernel.org (2.6.30, needed by TLB shootdown fix)
Needed for occlusion queries on rv530 chips.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
This patch enables ADC filtering on UCB1400 codec by default. The
benefit from this change is mostly on some Colibri boards where
the ADCSYNC pin of the UCB1400 codec isn't connected causing the
touchscreen to jitter very badly. This change has no visible
effect on boards where the ADCSYNC pin is connected.
Tested-by: Palo Revak <palo@bielyvlk.sk>
The previous patch assumes the ioctl already existed, when
it actually didn't.
It also didn't return the correct error code.
drm/kms: teardown crtc correctly when fb is destroyed.
drm/kms/radeon: cleanup combios TV table like DDX.
drm/radeon/kms: memset the allocated framebuffer before using it.
drm/radeon/kms: although LVDS might be possible on crtc 1 don't do it.
drm/radeon/kms: implement bo busy check + current domain
drm/radeon/kms: cut down indirects in register accesses.
drm/radeon/kms: Fix up vertical blank interrupt support.
drm/radeon/kms: add rv530 R300_SU_REG_DEST + reloc for ZPASS_ADDR
drm/edid: fixup detailed timings like the X server.
drm/radeon/kms: Add specific rs690 authorized register table
The commit 2ff05b2b (oom: move oom_adj value) moveed the oom_adj value to
the mm_struct. It was a very good first step for sanitize OOM.
However Paul Menage reported the commit makes regression to his job
scheduler. Current OOM logic can kill OOM_DISABLED process.
Why? His program has the code of similar to the following.
set_oom_adj(OOM_DISABLE); /* The job scheduler never killed by oom */
if (vfork() == 0) {
set_oom_adj(0); /* Invoked child can be killed */
execve("foo-bar-cmd");
vfork() parent and child are shared the same mm_struct. then above
set_oom_adj(0) doesn't only change oom_adj for vfork() child, it's also
change oom_adj for vfork() parent. Then, vfork() parent (job scheduler)
lost OOM immune and it was killed.
Actually, fork-setting-exec idiom is very frequently used in userland program.
We must not break this assumption.
Then, this patch revert commit 2ff05b2b and related commit.
Reverted commit list
- commit 2ff05b2b4e (oom: move oom_adj value from task_struct to mm_struct)
- commit 4d8b9135c3 (oom: avoid unnecessary mm locking and scanning for OOM_DISABLE)
- commit 8123681022 (oom: only oom kill exiting tasks with attached memory)
- commit 933b787b57 (mm: copy over oom_adj value at fork time)
Cc: Paul Menage <menage@google.com>
Cc: Nick Piggin <npiggin@suse.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (60 commits)
net: restore gnet_stats_basic to previous definition
NETROM: Fix use of static buffer
e1000e: fix use of pci_enable_pcie_error_reporting
e1000e: WoL does not work on 82577/82578 with manageability enabled
cnic: Fix locking in init/exit calls.
cnic: Fix locking in start/stop calls.
bnx2: Use mutex on slow path cnic calls.
cnic: Refine registration with bnx2.
cnic: Fix symbol_put_addr() panic on ia64.
gre: Fix MTU calculation for bound GRE tunnels
pegasus: Add new device ID.
via-velocity: Fix test of mii_status bit VELOCITY_DUPLEX_FULL
rt2x00: fix memory corruption in rf cache, add a sanity check
ixgbe: Fix receive on real device when VLANs are configured
ixgbe: Do not return 0 in ixgbe_fcoe_ddp() upon FCP_RSP in DDP completion
netxen: free napi resources during detach
netxen: remove netxen workqueue
ixgbe: fix issues setting rx-usecs with legacy interrupts
can: fix oops caused by wrong rtnl newlink usage
In 5e140dfc1fe87eae27846f193086724806b33c7d "net: reorder struct Qdisc
for better SMP performance" the definition of struct gnet_stats_basic
changed incompatibly, as copies of this struct are shipped to
userland via netlink.
Restoring old behavior is not welcome, for performance reason.
Fix is to use a private structure for kernel, and
teach gnet_stats_copy_basic() to convert from kernel to user land,
using legacy structure (struct gnet_stats_basic)
Based on a report and initial patch from Michael Spang.
Reported-by: Michael Spang <mspang@csclub.uwaterloo.ca>
Fix the header files to define round_hint_to_min() and to define
mmap_min_addr_handler() in the !CONFIG_SECURITY case.
Built and tested with !CONFIG_SECURITY
Signed-off-by: Eric Paris <eparis@redhat.com>
Currently SELinux enforcement of controls on the ability to map low memory
is determined by the mmap_min_addr tunable. This patch causes SELinux to
ignore the tunable and instead use a seperate Kconfig option specific to how
much space the LSM should protect.
The tunable will now only control the need for CAP_SYS_RAWIO and SELinux
permissions will always protect the amount of low memory designated by
CONFIG_LSM_MMAP_MIN_ADDR.
This allows users who need to disable the mmap_min_addr controls (usual reason
being they run WINE as a non-root user) to do so and still have SELinux
controls preventing confined domains (like a web server) from being able to
map some area of low memory.
Currently we duplicate the mmap_min_addr test in cap_file_mmap and in
security_file_mmap if !CONFIG_SECURITY. This patch moves cap_file_mmap
into commoncap.c and then calls that function directly from
security_file_mmap ifndef CONFIG_SECURITY like all of the other capability
checks are done.
Acked-by: Serge Hallyn <serue@us.ibm.com>
This implements the busy ioctl along with a current domain check.
returns 0 or -EBUSY
puts the current domain no matter what the answer.
* 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf_counter: Report the cloning task as parent on perf_counter_fork()
perf_counter: Fix an ipi-deadlock
perf: Rework/fix the whole read vs group stuff
perf_counter: Fix swcounter context invariance
perf report: Don't show unresolved DSOs and symbols when -S/-d is used
perf tools: Add a general option to enable raw sample records
perf tools: Add a per tracepoint counter attribute to get raw sample
perf_counter: Provide hw_perf_counter_setup_online() APIs
perf list: Fix large list output by using the pager
perf_counter, x86: Fix/improve apic fallback
perf record: Add missing -C option support for specifying profile cpu
perf tools: Fix dso__new handle() to handle deleted DSOs
perf tools: Fix fallback to cplus_demangle() when bfd_demangle() is not available
perf report: Show the tid too in -D
perf record: Fix .tid and .pid fill-in when synthesizing events
perf_counter, x86: Fix generic cache events on P6-mobile CPUs
perf_counter, x86: Fix lapic printk message
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Fix handling of bad requeue syscall pairing
futex: Fix compat_futex to be same as futex for REQUEUE_PI
locking, sched: Give waitqueue spinlocks their own lockdep classes
futex: Update futex_q lock_ptr on requeue proxy lock
Replace PERF_SAMPLE_GROUP with PERF_SAMPLE_READ and introduce
PERF_FORMAT_GROUP to deal with group reads in a more generic
way.
This allows you to get group reads out of read() as well.
Cc: Corey J Ashford <cjashfor@us.ibm.com>
Cc: stephane eranian <eranian@googlemail.com>
LKML-Reference: <20090813103655.117411814@chello.nl>
Provide weak aliases for hw_perf_counter_setup_online(). This is
used by the BTS patches (for v2.6.32), but it interacts with
fixes so propagate this upstream. (it has no effect as of yet)
Also export perf_counter_output() to architecture code.
LKML-Reference: <new-submission>
We can't call nfs_readdata_release()/nfs_writedata_release() without
first initialising and referencing args.context. Doing so inside
nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment()
causes an Oops.
We should rather be calling nfs_readdata_free()/nfs_writedata_free() in
those cases.
Looking at the O_DIRECT code, the "struct nfs_direct_req" is already
referencing the nfs_open_context for us. Since the readdata and writedata
structures carry a reference to that, we can simplify things by getting rid
of the extra nfs_open_context references, so that we can replace all
instances of nfs_readdata_release()/nfs_writedata_release().
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
* 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits)
perf_counter: Zero dead bytes from ftrace raw samples size alignment
perf_counter: Subtract the buffer size field from the event record size
perf_counter: Require CAP_SYS_ADMIN for raw tracepoint data
perf_counter: Correct PERF_SAMPLE_RAW output
perf tools: callchain: Fix bad rounding of minimum rate
perf_counter tools: Fix libbfd detection for systems with libz dependency
perf: "Longum est iter per praecepta, breve et efficax per exempla"
perf_counter: Fix a race on perf_counter_ctx
perf_counter: Fix tracepoint sampling to be part of generic sampling
perf_counter: Work around gcc warning by initializing tracepoint record unconditionally
perf tools: callchain: Fix sum of percentages to be 100% by displaying amount of ignored chains in fractal mode
perf tools: callchain: Fix 'perf report' display to be callchain by default
perf tools: callchain: Fix spurious 'perf report' warnings: ignore empty callchains
perf record: Fix the -A UI for empty or non-existent perf.data
perf util: Fix do_read() to fail on EOF instead of busy-looping
perf list: Fix the output to not include tracepoints without an id
perf_counter/powerpc: Fix oops on cpus without perf_counter hardware support
perf stat: Fix tool option consistency: rename -S/--scale to -c/--scale
perf report: Add debug help for the finding of symbol bugs - show the symtab origin (DSO, build-id, kernel, etc)
perf report: Fix per task mult-counter stat reporting
After aligning the ftrace raw samples, there are dead bytes storing
random data from the stack. We don't want to leak these to userspace,
then zero these out.
Before:
0x2de88 [0x50]: event: 9
. ... raw event: size 80 bytes
. 0000: 09 00 00 00 01 00 50 00 d0 c7 00 81 ff ff ff ff ......P........
. 0010: 68 01 00 00 68 01 00 00 2c 00 00 00 00 00 00 00 h...h...,......
. 0020: 2c 00 00 00 2b 00 01 02 68 01 00 00 68 01 00 00 ,...+...h...h..
. 0030: 6b 6f 6e 64 65 6d 61 6e 64 2f 30 00 00 00 00 00 kondemand/0....
. 0040: 68 01 00 00 40 7f 46 81 ff ff ff ff 00 10 1b 7f h...@.F........
Leak
After:
0x2d318 [0x50]: event: 9
. 0010: 68 01 00 00 68 01 00 00 68 14 00 00 00 00 00 00 h...h...h......
. 0040: 68 01 00 00 a0 80 46 81 ff ff ff ff 00 00 00 00 h.....F........
Fixed
Reported-by: Peter Zijlstra <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1249915116-5210-1-git-send-email-fweisbec@gmail.com>
We compute the perf raw sample size by aligning the raw ftrace
event size plus the buffer size field itself. We do that
instead of aligning only the perf raw sample size, so that we
might economize some in some cases.
But this buffer size field is not stored in the perf raw
sample, we must then substract its size from the buffer once we
computed the alignment unless we may get a useless u32 field in
the buffer.
Acked-by: Peter Zijlstra <peterz@infradead.org>
LKML-Reference: <20090810141129.GA5124@nowhere>
Give waitqueue spinlocks their own lockdep classes when they
are initialised from init_waitqueue_head(). This means that
struct wait_queue::func functions can operate other waitqueues.
This is used by CacheFiles to catch the page from a backing fs
being unlocked and to wake up another thread to take a copy of
it.
Tested-by: Takashi Iwai <tiwai@suse.de>
Cc: linux-cachefs@redhat.com
Cc: torvalds@osdl.org
Cc: akpm@linux-foundation.org
LKML-Reference: <20090810113305.17284.81508.stgit@warthog.procyon.org.uk>
PERF_SAMPLE_* output switches should unconditionally output the
correct format, as they are the only way to unambiguously parse
the PERF_EVENT_SAMPLE data.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1249896447.17467.74.camel@twins>
* 'kvm-updates/2.6.31' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: Avoid redelivery of edge interrupt before next edge
KVM: MMU: limit rmap chain length
KVM: ia64: fix build failures due to ia64/unsigned long mismatches
KVM: Make KVM_HPAGES_PER_HPAGE unsigned long to avoid build error on powerpc
KVM: fix ack not being delivered when msi present
KVM: s390: fix wait_queue handling
KVM: VMX: Fix locking imbalance on emulation failure
KVM: VMX: Fix locking order in handle_invalid_guest_state
KVM: MMU: handle n_free_mmu_pages > n_alloc_mmu_pages in kvm_mmu_change_mmu_pages
KVM: SVM: force new asid on vcpu migration
KVM: x86: verify MTRR/PAT validity
KVM: PIT: fix kpit_elapsed division by zero
KVM: Fix KVM_GET_MSR_INDEX_LIST
Based on Peter's comments, make tracepoint sampling generic
just like all the other sampling bits are. This is a rename
with no code changes:
- PERF_SAMPLE_TP_RECORD to PERF_SAMPLE_RAW
- struct perf_tracepoint_record to perf_raw_record
We want the system in place that transport tracepoints raw
samples events into the perf ring buffer to be generalized and
usable by any type of counter.
Reported-by; Peter Zijlstra <peterz@infradead.org>
LKML-Reference: <1249698400-5441-4-git-send-email-fweisbec@gmail.com>
This patch implements the kernel side support for ftrace event
record sampling.
A new counter sampling attribute is added:
which requests ftrace events record sampling. In this case
if a PERF_TYPE_TRACEPOINT counter is active and a tracepoint
fires, we emit the tracepoint binary record to the
perfcounter event buffer, as a sample.
Result, after setting PERF_SAMPLE_TP_RECORD attribute from perf
record:
perf record -f -F 1 -a -e workqueue:workqueue_execution
perf report -D
0x21e18 [0x48]: event: 9
. ... raw event: size 72 bytes
. 0000: 09 00 00 00 01 00 48 00 d0 c7 00 81 ff ff ff ff ......H........
. 0010: 0a 00 00 00 0a 00 00 00 21 00 00 00 00 00 00 00 ........!......
. 0020: 2b 00 01 02 0a 00 00 00 0a 00 00 00 65 76 65 6e +...........eve
. 0030: 74 73 2f 31 00 00 00 00 00 00 00 00 0a 00 00 00 ts/1...........
. 0040: e0 b1 31 81 ff ff ff ff .......
0x21e18 [0x48]: PERF_EVENT_SAMPLE (IP, 1): 10: 0xffffffff8100c7d0 period: 33
The raw ftrace binary record starts at offset 0020.
Translation:
struct trace_entry {
type = 0x2b = 43;
flags = 1;
preempt_count = 2;
pid = 0xa = 10;
tgid = 0xa = 10;
thread_comm = "events/1"
thread_pid = 0xa = 10;
func = 0xffffffff8131b1e0 = flush_to_ldisc()
What will come next?
- Userspace support ('perf trace'), 'flight data recorder' mode
for perf trace, etc.
- The unconditional copy from the profiling callback brings
some costs however if someone wants no such sampling to
occur, and needs to be fixed in the future. For that we need
to have an instant access to the perf counter attribute.
This is a matter of a flag to add in the struct ftrace_event.
- Take care of the events recursivity! Don't ever try to record
a lock event for example, it seems some locking is used in
the profiling fast path and lead to a tracing recursivity.
That will be fixed using raw spinlock or recursivity
protection.
- Profit! :-)
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Adds possible second part to the assign argument of TP_EVENT().
TP_perf_assign(
__perf_count(foo);
__perf_addr(bar);
Which, when specified make the swcounter increment with @foo instead
of the usual 1, and report @bar for PERF_SAMPLE_ADDR (data address
associated with the event) when this triggers a counter overflow.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jason Baron <jbaron@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/hch/xfs-icache-races:
xfs: fix freeing of inodes not yet added to the inode cache
vfs: add __destroy_inode
vfs: fix inode_init_always calling convention
