[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d
and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter
adds an assertion to genetlink to prevent this from happening
again in the future. ]
The original name is too long.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
commit 3e515705a1f46beb1c942bb8043c16f8ac7b1e9e upstream.
If some vcpus are created before KVM_CREATE_IRQCHIP, then
irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading
to potential NULL pointer dereferences.
Fix by:
- ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called
- ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP
This is somewhat long winded because vcpu->arch.apic is created without
kvm->lock held.
Based on earlier patch by Michael Ellerman.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 331818f1c468a24e581aedcbe52af799366a9dfe upstream.
Commit bf118a342f10dafe44b14451a1392c3254629a1f (NFSv4: include bitmap
in nfsv4 get acl data) introduces the 'acl_scratch' page for the case
where we may need to decode multi-page data. However it fails to take
into account the fact that the variable may be NULL (for the case where
we're not doing multi-page decode), and it also attaches it to the
encoding xdr_stream rather than the decoding one.
The immediate result is an Oops in nfs4_xdr_enc_getacl due to the
call to page_address() with a NULL page pointer.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Andy Adamson <andros@netapp.com>
commit bf118a342f10dafe44b14451a1392c3254629a1f upstream.
The NFSv4 bitmap size is unbounded: a server can return an arbitrary
sized bitmap in an FATTR4_WORD0_ACL request. Replace using the
nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server
with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data
xdr length to the (cached) acl page data.
This is a general solution to commit e5012d1f "NFSv4.1: update
nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead
when getting ACLs.
Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr
was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved.
Signed-off-by: Andy Adamson <andros@netapp.com>
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
commit d740269867021faf4ce38a449353d2b986c34a67 upstream.
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ]
This patch introduces a constant limit of the fragment queue hash
table bucket list lengths. Currently the limit 128 is choosen somewhat
arbitrary and just ensures that we can fill up the fragment cache with
empty packets up to the default ip_frag_high_thresh limits. It should
just protect from list iteration eating considerable amounts of cpu.
If we reach the maximum length in one hash bucket a warning is printed.
This is implemented on the caller side of inet_frag_find to distinguish
between the different users of inet_fragment.c.
I dropped the out of memory warning in the ipv4 fragment lookup path,
because we already get a warning by the slab allocator.
Cc: Jesper Dangaard Brouer <jbrouer@redhat.com>
[ Upstream commit 5b9e12dbf92b441b37136ea71dac59f05f2673a9 ]
a long time ago by the commit
commit 93456b6d7753def8760b423ac6b986eb9d5a4a95
Author: Denis V. Lunev <den@openvz.org>
Date: Thu Jan 10 03:23:38 2008 -0800
[IPV4]: Unify access to the routing tables.
the defenition of FIB_HASH_TABLE size has obtained wrong dependency:
it should depend upon CONFIG_IP_MULTIPLE_TABLES (as was in the original
code) but it was depended from CONFIG_IP_ROUTE_MULTIPATH
This patch returns the situation to the original state.
The problem was spotted by Tingwei Liu.
Signed-off-by: Denis V. Lunev <den@openvz.org>
CC: Tingwei Liu <tingw.liu@gmail.com>
CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
commit 6c4d3bc99b3341067775efd4d9d13cc8e655fd7c upstream.
Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after
suspend/resume") introduces a link failure since
perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL:
arch/x86/power/built-in.o: In function `restore_processor_state':
(.text+0x45c): undefined reference to `perf_restore_debug_store'
Fix it by defining the dummy function appropriately.
Signed-off-by: David Rientjes <rientjes@google.com>
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream.
This patch fixes a kernel crash when using precise sampling (PEBS)
after a suspend/resume. Turns out the CPU notifier code is not invoked
on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly
by the kernel and keeps it power-on/resume value of 0 causing any PEBS
measurement to crash when running on CPU0.
The workaround is to add a hook in the actual resume code to restore
the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0,
the DS_AREA will be restored twice but this is harmless.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Stephane Eranian <eranian@google.com>
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
commit 4f4ffc3a5398ef9bdbb32db04756d7d34e356fcf upstream.
automount-support is broken on the parisc architecture, because the existing
#if list does not include a check for defined(__hppa__). The HPPA (parisc)
architecture is similiar to other 64bit Linux targets where we have to define
autofs_wqt_t (which is passed back and forth to user space) as int type which
has a size of 32bit across 32 and 64bit kernels.
During the discussion on the mailing list, H. Peter Anvin suggested to invert
the #if list since only specific platforms (specifically those who do not have
a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned
long type.
This suggestion is probably the best way to go, since Arm64 (and maybe others?)
seems to have a non-working automounter. So in the long run even for other new
upcoming architectures this inverted check seem to be the best solution, since
it will not require them to change this #if again (unless they are 64bit only).
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
CC: James Bottomley <James.Bottomley@HansenPartnership.com>
CC: Rolf Eike Beer <eike-kernel@sf-tec.de>
Upstream commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82.
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream.
Otherwise, ext4 file systems with the quota featured enable will get a
very confusing "No such process" error message if the quota code is
built as a module and the quota_v2 module has not been loaded.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Acked-by: Jan Kara <jack@suse.cz>
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ]
It looks like its possible to open thousands of TCP IPv6
sessions on a server, all landing in a single slot of TCP hash
table. Incoming packets have to lookup sockets in a very
long list.
We should hash all bits from foreign IPv6 addresses, using
a salt and hash mix, not a simple XOR.
inet6_ehashfn() can also separately use the ports, instead
of xoring them.
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream.
I've still got lockdep warnings even after Alan's patch, and it seems that
yet more band aids are required to paper over similar paths for
unbind_con_driver() and unregister_con_driver(). After this hack, lockdep
warnings are finally gone.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream.
Adjust the console layer to allow a take over call where the caller
already holds the locks. Make the fb layer lock in order.
This is partly a band aid, the fb layer is terminally confused about the
locking rules it uses for its notifiers it seems.
[akpm@linux-foundation.org: remove stray non-ascii char, tidy comment]
[akpm@linux-foundation.org: export do_take_over_console()]
[airlied: cleanup another non-ascii char]
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 0720a06a7518c9d0c0125bd5d1f3b6264c55c3dd upstream.
The utf8s_to_utf16s conversion routine needs to be improved. Unlike
its utf16s_to_utf8s sibling, it doesn't accept arguments specifying
the maximum length of the output buffer or the endianness of its
16-bit output.
This patch (as1501) adds the two missing arguments, and adjusts the
only two places in the kernel where the function is called. A
follow-on patch will add a third caller that does utilize the new
capabilities.
The two conversion routines are still annoyingly inconsistent in the
way they handle invalid byte combinations. But that's a subject for a
different patch.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Clemens Ladisch <clemens@ladisch.de>
commit b531f81b0d70ffbe8d70500512483227cc532608 upstream.
Commit 99fc86450c439039d2ef88d06b222fd51a779176 "ALSA: usb-mixer:
parse descriptors with structs" introduced a set of useful parsers
for descriptors. Unfortunately the parses for the Processing Unit
Descriptor came with a very subtle bug...
Functions uac_processing_unit_iProcessing() and
uac_processing_unit_specific() were indexing the baSourceID array
forgetting the fields before the iProcessing and process-specific
descriptors.
The problem was observed with Sound Blaster Extigy mixer,
where nNrModes in Up/Down-mix Processing Unit Descriptor
was accessed at offset 10 of the descriptor (value 0)
instead of offset 15 (value 7). In result the resulting
control had interesting limit values:
Simple mixer control 'Channel Routing Mode Select',0
Capabilities: volume volume-joined penum
Playback channels: Mono
Capture channels: Mono
Limits: 0 - -1
Mono: -1 [100%]
Fixed by starting from the bmControls, which was calculated
correctly, instead of baSourceID.
Now the mentioned control is fine:
Limits: 0 - 6
Mono: 0 [0%]
Signed-off-by: Pawel Moll <mail@pawelmoll.com>
schedule
commit 21a92735f660eaecf69a6f2e777f18463760ec32 upstream.
With an RCU based mmu_notifier implementation, any callout to
mmu_notifier_invalidate_range_{start,end}() or
mmu_notifier_invalidate_page() would not be allowed to call schedule()
as that could potentially allow a modification to the mmu_notifier
structure while it is currently being used.
Since srcu allocs 4 machine words per instance per cpu, we may end up
with memory exhaustion if we use srcu per mm. So all mms share a global
srcu. Note that during large mmu_notifier activity exit & unregister
paths might hang for longer periods, but it is tolerable for current
mmu_notifier clients.
Signed-off-by: Sagi Grimberg <sagig@mellanox.co.il>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Haggai Eran <haggaie@mellanox.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
call_console_drivers
This patch corrects a buffer overflow in kernels from 3.0 to 3.4 when calling
log_prefix() function from call_console_drivers().
This bug existed in previous releases but has been revealed with commit
162a7e7500f9664636e649ba59defe541b7c2c60 (2.6.39 => 3.0) that made changes
about how to allocate memory for early printk buffer (use of memblock_alloc).
It disappears with commit 7ff9554bb578ba02166071d2d487b7fc7d860d62 (3.4 => 3.5)
that does a refactoring of printk buffer management.
In log_prefix(), the access to "p[0]", "p[1]", "p[2]" or
"simple_strtoul(&p[1], &endp, 10)" may cause a buffer overflow as this
function is called from call_console_drivers by passing "&LOG_BUF(cur_index)"
where the index must be masked to do not exceed the buffer's boundary.
The trick is to prepare in call_console_drivers() a buffer with the necessary
data (PRI field of syslog message) to be safely evaluated in log_prefix().
This patch can be applied to stable kernel branches 3.0.y, 3.2.y and 3.4.y.
Without this patch, one can freeze a server running this loop from shell :
$ export DUMMY=`cat /dev/urandom | tr -dc '12345AZERTYUIOPQSDFGHJKLMWXCVBNazertyuiopqsdfghjklmwxcvbn' | head -c255`
$ while true do ; echo $DUMMY > /dev/kmsg ; done
The "server freeze" depends on where memblock_alloc does allocate printk buffer :
if the buffer overflow is inside another kernel allocation the problem may not
be revealed, else the server may hangs up.
Signed-off-by: Alexandre SIMON <Alexandre.Simon@univ-lorraine.fr>
commit 7b4f6ecacb14f384adc1a5a67ad95eb082c02bd1 upstream.
They don't always appear as AHCI class devices but instead as IDE class.
Based on an initial patch by Hiroaki Nito
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=42804
Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
commit 115c9b81928360d769a76c632bae62d15206a94a upstream.
Implement a new netlink attribute type IFLA_EXT_MASK. The mask
is a 32 bit value that can be used to indicate to the kernel that
certain extended ifinfo values are requested by the user application.
At this time the only mask value defined is RTEXT_FILTER_VF to
indicate that the user wants the ifinfo dump to send information
about the VFs belonging to the interface.
This patch fixes a bug in which certain applications do not have
large enough buffers to accommodate the extra information returned
by the kernel with large numbers of SR-IOV virtual functions.
Those applications will not send the new netlink attribute with
the interface info dump request netlink messages so they will
not get unexpectedly large request buffers returned by the kernel.
Modifies the rtnl_calcit function to traverse the list of net
devices and compute the minimum buffer size that can hold the
info dumps of all matching devices based upon the filter passed
in via the new netlink attribute filter mask. If no filter
mask is sent then the buffer allocation defaults to NLMSG_GOODSIZE.
With this change it is possible to add yet to be defined netlink
attributes to the dump request which should make it fairly extensible
in the future.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Acked-by: Greg Rose <gregory.v.rose@intel.com>
[bwh: Backported to 3.0:
- Adjust context
- Drop the change in do_setlink() that reverts commit f18da1456581
('net: RTNETLINK adjusting values of min_ifinfo_dump_size'), which
was never applied here]
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit c7ac8679bec9397afe8918f788cbcef88c38da54 upstream.
The message size allocated for rtnl ifinfo dumps was limited to
a single page. This is not enough for additional interface info
available with devices that support SR-IOV and caused a bug in
which VF info would not be displayed if more than approximately
40 VFs were created per interface.
Implement a new function pointer for the rtnl_register service that will
calculate the amount of data required for the ifinfo dump and allocate
enough data to satisfy the request.
Cc: Ben Hutchings <bhutchings@solarflare.com>
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream.
Since commit e303297e6c3a ("mm: extended batches for generic
mmu_gather") we are batching pages to be freed until either
tlb_next_batch cannot allocate a new batch or we are done.
This works just fine most of the time but we can get in troubles with
non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY)
on large machines where too aggressive batching might lead to soft
lockups during process exit path (exit_mmap) because there are no
scheduling points down the free_pages_and_swap_cache path and so the
freeing can take long enough to trigger the soft lockup.
The lockup is harmless except when the system is setup to panic on
softlockup which is not that unusual.
The simplest way to work around this issue is to limit the maximum
number of batches in a single mmu_gather. 10k of collected pages should
be safe to prevent from soft lockups (we would have 2ms for one) even if
they are all freed without an explicit scheduling point.
This patch doesn't add any new explicit scheduling points because it
relies on zap_pmd_range during page tables zapping which calls
cond_resched per PMD.
The following lockup has been reported for 3.0 kernel with a huge
process (in order of hundreds gigs but I do know any more details).
BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053]
Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod
Supported: Yes
CPU 56
Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7
RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10
RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206
RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80
RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206
RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400
R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e
R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e
FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0
Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100)
Call Trace:
release_pages+0xc5/0x260
free_pages_and_swap_cache+0x9d/0xc0
tlb_flush_mmu+0x5c/0x80
tlb_finish_mmu+0xe/0x50
exit_mmap+0xbd/0x120
mmput+0x49/0x120
exit_mm+0x122/0x160
do_exit+0x17a/0x430
do_group_exit+0x3d/0xb0
get_signal_to_deliver+0x247/0x480
do_signal+0x71/0x1b0
do_notify_resume+0x98/0xb0
int_signal+0x12/0x17
DWARF2 unwinder stuck at int_signal+0x12/0x17
commit 812089e01b9f65f90fc8fc670d8cce72a0e01fbb upstream.
Otherwise it fails like this on cards like the Transcend 16GB SDHC card:
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 15.0 GiB
mmcblk0: error -110 sending status command, retrying
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0
Tested on my Lenovo x200 laptop.
[bhelgaas: changelog]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Chris Ball <cjb@laptop.org>
CC: Manoj Iyer <manoj.iyer@canonical.com>
[ Upstream commit 0c24604b68fc7810d429d6c3657b6f148270e528 ]
Implement the RFC 5691 mitigation against Blind
Reset attack using SYN bit.
Section 4.2 of RFC 5961 advises to send a Challenge ACK and drop
incoming packet, instead of resetting the session.
Add a new SNMP counter to count number of challenge acks sent
in response to SYN packets.
(netstat -s | grep TCPSYNChallenge)
Remove obsolete TCPAbortOnSyn, since we no longer abort a TCP session
because of a SYN flag.
Cc: Kiran Kumar Kella <kkiran@broadcom.com>
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ]
Reset attack using RST bit.
Idea is to validate incoming RST sequence,
to match RCV.NXT value, instead of previouly accepted
window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND)
If sequence is in window but not an exact match, send
a "challenge ACK", so that the other part can resend an
RST with the appropriate sequence.
Add a new sysctl, tcp_challenge_ack_limit, to limit
number of challenge ACK sent per second.
Add a new SNMP counter to count number of challenge acks sent.
(netstat -s | grep TCPChallengeACK)
commit 45959ee7aa645815a5ce303a0ea1e48a21e67c6a upstream.
When gcc inlines a function, it does not mark it with the mcount
prologue, which in turn means that inlined functions are not traced
by the function tracer. But if CONFIG_OPTIMIZE_INLINING is set, then
gcc is allowed not to inline a function that is marked inline.
Depending on the options and the compiler, a function may or may
not be traced by the function tracer, depending on whether gcc
decides to inline a function or not. This has caused several
problems in the pass becaues gcc is not always consistent with
what it decides to inline between different gcc versions.
Some places should not be traced (like paravirt native_* functions)
and these are mostly marked as inline. When gcc decides not to
inline the function, and if that function should not be traced, then
the ftrace function tracer will suddenly break when it use to work
fine. This becomes even harder to debug when different versions of
gcc will not inline that function, making the same kernel and config
work for some gcc versions and not work for others.
By making all functions marked inline to not be traced will remove
the ambiguity that gcc adds when it comes to tracing functions marked
inline. All gcc versions will be consistent with what functions are
traced and having volatile working code will be removed.
Note, only the inline macro when CONFIG_OPTIMIZE_INLINING is set needs
to have notrace added, as the attribute __always_inline will force
the function to be inlined and then not traced.
commit ad4b3fb7ff9940bcdb1e4cd62bd189d10fa636ba upstream.
Unfortunately with !CONFIG_PAGEFLAGS_EXTENDED, (!PageHead) is false, and
(PageHead) is true, for tail pages. If this is indeed the intended
behavior, which I doubt because it breaks cache cleaning on some ARM
systems, then the nomenclature is highly problematic.
This patch makes sure PageHead is only true for head pages and PageTail
is only true for tail pages, and neither is true for non-compound pages.
[ This buglet seems ancient - seems to have been introduced back in Apr
2008 in commit 6a1e7f777f61: "pageflags: convert to the use of new
macros". And the reason nobody noticed is because the PageHead()
tests are almost all about just sanity-checking, and only used on
pages that are actual page heads. The fact that the old code returned
true for tail pages too was thus not really noticeable. - Linus ]
Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Will Deacon <Will.Deacon@arm.com>
Cc: Steve Capper <Steve.Capper@arm.com>
Cc: Christoph Lameter <cl@linux.com>
commit b66c5984017533316fd1951770302649baf1aa33 upstream.
If a series of scripts are executed, each triggering module loading via
unprintable bytes in the script header, kernel stack contents can leak
into the command line.
Normally execution of binfmt_script and binfmt_misc happens recursively.
However, when modules are enabled, and unprintable bytes exist in the
bprm->buf, execution will restart after attempting to load matching
binfmt modules. Unfortunately, the logic in binfmt_script and
binfmt_misc does not expect to get restarted. They leave bprm->interp
pointing to their local stack. This means on restart bprm->interp is
left pointing into unused stack memory which can then be copied into the
userspace argv areas.
After additional study, it seems that both recursion and restart remains
the desirable way to handle exec with scripts, misc, and modules. As
such, we need to protect the changes to interp.
This changes the logic to require allocation for any changes to the
bprm->interp. To avoid adding a new kmalloc to every exec, the default
value is left as-is. Only when passing through binfmt_script or
binfmt_misc does an allocation take place.
For a proof of concept, see DoTest.sh from:
http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/
commit 18a2f371f5edf41810f6469cb9be39931ef9deb9 upstream.
This fixes a regression in 3.7-rc, which has since gone into stable.
Commit 00442ad04a5e ("mempolicy: fix a memory corruption by refcount
imbalance in alloc_pages_vma()") changed get_vma_policy() to raise the
refcount on a shmem shared mempolicy; whereas shmem_alloc_page() went
on expecting alloc_page_vma() to drop the refcount it had acquired.
This deserves a rework: but for now fix the leak in shmem_alloc_page().
Hugh: shmem_swapin() did not need a fix, but surely it's clearer to use
the same refcounting there as in shmem_alloc_page(), delete its onstack
mempolicy, and the strange mpol_cond_copy() and __mpol_cond_copy() -
those were invented to let swapin_readahead() make an unknown number of
calls to alloc_pages_vma() with one mempolicy; but since 00442ad04a5e,
alloc_pages_vma() has kept refcount in balance, so now no problem.
Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com>
commit 2bbc6942273b5b3097bd265d82227bdd84b351b2 upstream.
Currently pci-bridges are allocated enough resources to satisfy their immediate
requirements. Any additional resource-requests fail if additional free space,
contiguous to the one already allocated, is not available. This behavior is not
reasonable since sufficient contiguous resources, that can satisfy the request,
are available at a different location.
This patch provides the ability to expand and relocate a allocated resource.
v2: Changelog: Fixed size calculation in pci_reassign_resource()
v3: Changelog : Split this patch. The resource.c changes are already
upstream. All the pci driver changes are in here.
Signed-off-by: Ram Pai <linuxram@us.ibm.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Andrew Worsley <amworsley@gmail.com>
commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 upstream.
For more strict protection for wild disconnections, a refcount is
introduced to the card instance, and let it up/down when an object is
referred via snd_lookup_*() in the open ops.
The free-after-last-close check is also changed to check this refcount
instead of the empty list, too.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
commit a007c4c3e943ecc054a806c259d95420a188754b upstream.
I don't think there's a practical difference for the range of values
these interfaces should see, but it would be safer to be unambiguous.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
commit 9e33ce453f8ac8452649802bee1f410319408f4b upstream.
IPVS should not reset skb->nf_bridge in FORWARD hook
by calling nf_reset for NAT replies. It triggers oops in
br_nf_forward_finish.
[ 579.781508] BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
[ 579.781669] IP: [<ffffffff817b1ca5>] br_nf_forward_finish+0x58/0x112
[ 579.781792] PGD 218f9067 PUD 0
[ 579.781865] Oops: 0000 [#1] SMP
[ 579.781945] CPU 0
[ 579.781983] Modules linked in:
[ 579.782047]
[ 579.782080]
[ 579.782114] Pid: 4644, comm: qemu Tainted: G W 3.5.0-rc5-00006-g95e69f9 #282 Hewlett-Packard /30E8
[ 579.782300] RIP: 0010:[<ffffffff817b1ca5>] [<ffffffff817b1ca5>] br_nf_forward_finish+0x58/0x112
[ 579.782455] RSP: 0018:ffff88007b003a98 EFLAGS: 00010287
[ 579.782541] RAX: 0000000000000008 RBX: ffff8800762ead00 RCX: 000000000001670a
[ 579.782653] RDX: 0000000000000000 RSI: 000000000000000a RDI: ffff8800762ead00
[ 579.782845] RBP: ffff88007b003ac8 R08: 0000000000016630 R09: ffff88007b003a90
[ 579.782957] R10: ffff88007b0038e8 R11: ffff88002da37540 R12: ffff88002da01a02
[ 579.783066] R13: ffff88002da01a80 R14: ffff88002d83c000 R15: ffff88002d82a000
[ 579.783177] FS: 0000000000000000(0000) GS:ffff88007b000000(0063) knlGS:00000000f62d1b70
[ 579.783306] CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b
[ 579.783395] CR2: 0000000000000004 CR3: 00000000218fe000 CR4: 00000000000027f0
[ 579.783505] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 579.783684] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 579.783795] Process qemu (pid: 4644, threadinfo ffff880021b20000, task ffff880021aba760)
[ 579.783919] Stack:
[ 579.783959] ffff88007693cedc ffff8800762ead00 ffff88002da01a02 ffff8800762ead00
[ 579.784110] ffff88002da01a02 ffff88002da01a80 ffff88007b003b18 ffffffff817b26c7
[ 579.784260] ffff880080000000 ffffffff81ef59f0 ffff8800762ead00 ffffffff81ef58b0
[ 579.784477] Call Trace:
[ 579.784523] <IRQ>
[ 579.784562]
[ 579.784603] [<ffffffff817b26c7>] br_nf_forward_ip+0x275/0x2c8
[ 579.784707] [<ffffffff81704b58>] nf_iterate+0x47/0x7d
[ 579.784797] [<ffffffff817ac32e>] ? br_dev_queue_push_xmit+0xae/0xae
[ 579.784906] [<ffffffff81704bfb>] nf_hook_slow+0x6d/0x102
[ 579.784995] [<ffffffff817ac32e>] ? br_dev_queue_push_xmit+0xae/0xae
[ 579.785175] [<ffffffff8187fa95>] ? _raw_write_unlock_bh+0x19/0x1b
[ 579.785179] [<ffffffff817ac417>] __br_forward+0x97/0xa2
[ 579.785179] [<ffffffff817ad366>] br_handle_frame_finish+0x1a6/0x257
[ 579.785179] [<ffffffff817b2386>] br_nf_pre_routing_finish+0x26d/0x2cb
[ 579.785179] [<ffffffff817b2cf0>] br_nf_pre_routing+0x55d/0x5c1
[ 579.785179] [<ffffffff81704b58>] nf_iterate+0x47/0x7d
[ 579.785179] [<ffffffff817ad1c0>] ? br_handle_local_finish+0x44/0x44
[ 579.785179] [<ffffffff81704bfb>] nf_hook_slow+0x6d/0x102
[ 579.785179] [<ffffffff81551525>] ? sky2_poll+0xb35/0xb54
[ 579.785179] [<ffffffff817ad62a>] br_handle_frame+0x213/0x229
[ 579.785179] [<ffffffff817ad417>] ? br_handle_frame_finish+0x257/0x257
[ 579.785179] [<ffffffff816e3b47>] __netif_receive_skb+0x2b4/0x3f1
[ 579.785179] [<ffffffff816e69fc>] process_backlog+0x99/0x1e2
[ 579.785179] [<ffffffff816e6800>] net_rx_action+0xdf/0x242
[ 579.785179] [<ffffffff8107e8a8>] __do_softirq+0xc1/0x1e0
[ 579.785179] [<ffffffff8135a5ba>] ? trace_hardirqs_off_thunk+0x3a/0x6c
[ 579.785179] [<ffffffff8188812c>] call_softirq+0x1c/0x30
The steps to reproduce as follow,
1. On Host1, setup brige br0(192.168.1.106)
2. Boot a kvm guest(192.168.1.105) on Host1 and start httpd
3. Start IPVS service on Host1
ipvsadm -A -t 192.168.1.106:80 -s rr
ipvsadm -a -t 192.168.1.106:80 -r 192.168.1.105:80 -m
4. Run apache benchmark on Host2(192.168.1.101)
ab -n 1000 http://192.168.1.106/
ip_vs_reply4
ip_vs_out
handle_response
ip_vs_notrack
nf_reset()
skb->nf_bridge = NULL;
Actually, IPVS wants in this case just to replace nfct
with untracked version. So replace the nf_reset(skb) call
in ip_vs_notrack() with a nf_conntrack_put(skb->nfct) call.
Signed-off-by: Lin Ming <mlin@ss.pku.edu.cn>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
Acked-by: David Miller <davem@davemloft.net>
commit 5b423f6a40a0327f9d40bc8b97ce9be266f74368 upstream.
Existing code assumes that del_timer returns true for alive conntrack
entries. However, this is not true if reliable events are enabled.
In that case, del_timer may return true for entries that were
just inserted in the dying list. Note that packets / ctnetlink may
hold references to conntrack entries that were just inserted to such
list.
This patch fixes the issue by adding an independent timer for
event delivery. This increases the size of the ecache extension.
Still we can revisit this later and use variable size extensions
to allocate this area on demand.
Tested-by: Oliver Smith <olipro@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa>
commit b22d127a39ddd10d93deee3d96e643657ad53a49 upstream.
shared_policy_replace() use of sp_alloc() is unsafe. 1) sp_node cannot
be dereferenced if sp->lock is not held and 2) another thread can modify
sp_node between spin_unlock for allocating a new sp node and next
spin_lock. The bug was introduced before 2.6.12-rc2.
Kosaki's original patch for this problem was to allocate an sp node and
policy within shared_policy_replace and initialise it when the lock is
reacquired. I was not keen on this approach because it partially
duplicates sp_alloc(). As the paths were sp->lock is taken are not that
performance critical this patch converts sp->lock to sp->mutex so it can
sleep when calling sp_alloc().
[kosaki.motohiro@jp.fujitsu.com: Original patch]
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Josh Boyer <jwboyer@gmail.com>
[ Upstream commit ecd7918745234e423dd87fcc0c077da557909720 ]
The current code fails to ensure that the netlink message actually
contains as many bytes as the header indicates. If a user creates a new
state or updates an existing one but does not supply the bytes for the
whole ESN replay window, the kernel copies random heap bytes into the
replay bitmap, the ones happen to follow the XFRMA_REPLAY_ESN_VAL
netlink attribute. This leads to following issues:
1. The replay window has random bits set confusing the replay handling
code later on.
2. A malicious user could use this flaw to leak up to ~3.5kB of heap
memory when she has access to the XFRM netlink interface (requires
CAP_NET_ADMIN).
Known users of the ESN replay window are strongSwan and Steffen's
iproute2 patch (<http://patchwork.ozlabs.org/patch/85962/>). The latter
uses the interface with a bitmap supplied while the former does not.
strongSwan is therefore prone to run into issue 1.
To fix both issues without breaking existing userland allow using the
XFRMA_REPLAY_ESN_VAL netlink attribute with either an empty bitmap or a
fully specified one. For the former case we initialize the in-kernel
bitmap with zero, for the latter we copy the user supplied bitmap. For
state updates the full bitmap must be supplied.
To prevent overflows in the bitmap length calculation the maximum size
of bmp_len is limited to 128 by this patch -- resulting in a maximum
replay window of 4096 packets. This should be sufficient for all real
life scenarios (RFC 4303 recommends a default replay window size of 64).
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Martin Willi <martin@revosec.ch>
[ Upstream commit 3b59df46a449ec9975146d71318c4777ad086744 ]
ESN for esp is defined in RFC 4303. This RFC assumes that the
sequence number counters are always up to date. However,
this is not true if an async crypto algorithm is employed.
If the sequence number counters are not up to date on sequence
number check, we may incorrectly update the upper 32 bit of
the sequence number. This leads to a DOS.
We workaround this by comparing the upper sequence number,
(used for authentication) with the upper sequence number
computed after the async processing. We drop the packet
if these numbers are different.
To do this, we introduce a recheck function that does this
check in the ESN case.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit 26e8220adb0aec43b7acafa0f1431760eee28522 upstream.
Apparently the same card model has two IDs, so this patch
complements the commit 39aced68d664291db3324d0fcf0985ab5626aac2
adding the missing one.
Signed-off-by: Flavio Leitner <fbl@redhat.com>
commit cee58483cf56e0ba355fdd97ff5e8925329aa936 upstream
Andreas Bombe reported that the added ktime_t overflow checking added to
timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of
timekeeping inputs") was causing problems with X.org because it caused
timeouts larger then KTIME_T to be invalid.
Previously, these large timeouts would be clamped to KTIME_MAX and would
never expire, which is valid.
This patch splits the ktime_t overflow checking into a new
timespec_valid_strict function, and converts the timekeeping codes
internal checking to use this more strict function.
Reported-and-tested-by: Andreas Bombe <aeb@debian.org>
Cc: Zhouping Liu <zliu@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 4e8b14526ca7fb046a81c94002c1c43b6fdf0e9b upstream
Unexpected behavior could occur if the time is set to a value large
enough to overflow a 64bit ktime_t (which is something larger then the
year 2262).
Also unexpected behavior could occur if large negative offsets are
injected via adjtimex.
So this patch improves the sanity check timekeeping inputs by
improving the timespec_valid() check, and then makes better use of
timespec_valid() to make sure we don't set the time to an invalid
negative value or one that overflows ktime_t.
Note: This does not protect from setting the time close to overflowing
ktime_t and then letting natural accumulation cause the overflow.
Reported-by: CAI Qian <caiqian@redhat.com>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Link: http://lkml.kernel.org/r/1344454580-17031-1-git-send-email-john.stultz@linaro.org
commit 8323f26ce3425460769605a6aece7a174edaa7d1 upstream.
Stefan reported a crash on a kernel before a3e5d1091c1 ("sched:
Don't call task_group() too many times in set_task_rq()"), he
found the reason to be that the multiple task_group()
invocations in set_task_rq() returned different values.
Looking at all that I found a lack of serialization and plain
wrong comments.
The below tries to fix it using an extra pointer which is
updated under the appropriate scheduler locks. Its not pretty,
but I can't really see another way given how all the cgroup
stuff works.
Reported-and-tested-by: Stefan Bader <stefan.bader@canonical.com>
Link: http://lkml.kernel.org/r/1340364965.18025.71.camel@twins
commit 0bce9c46bf3b15f485d82d7e81dabed6ebcc24b1 upstream.
ARM recently moved to asm-generic/mutex-xchg.h for its mutex
implementation after the previous implementation was found to be missing
some crucial memory barriers. However, this has revealed some problems
running hackbench on SMP platforms due to the way in which the
MUTEX_SPIN_ON_OWNER code operates.
The symptoms are that a bunch of hackbench tasks are left waiting on an
unlocked mutex and therefore never get woken up to claim it. This boils
down to the following sequence of events:
Task A Task B Task C Lock value
0 1
1 lock() 0
2 lock() 0
3 spin(A) 0
4 unlock() 1
5 lock() 0
6 cmpxchg(1,0) 0
7 contended() -1
8 lock() 0
9 spin(C) 0
10 unlock() 1
11 cmpxchg(1,0) 0
12 unlock() 1
At this point, the lock is unlocked, but Task B is in an uninterruptible
sleep with nobody to wake it up.
This patch fixes the problem by ensuring we put the lock into the
contended state if we fail to acquire it on the fastpath, ensuring that
any blocked waiters are woken up when the mutex is released.
Cc: Chris Mason <chris.mason@fusionio.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Link: http://lkml.kernel.org/n/tip-6e9lrw2avczr0617fzl5vqb8@git.kernel.org
commit c3f52af3e03013db5237e339c817beaae5ec9e3a upstream.
When the NFS_COOKIEVERF helper macro was converted into a static
inline function in commit 99fadcd764 (nfs: convert NFS_*(inode)
helpers to static inline), we broke the initialisation of the
readdir cookies, since that depended on doing a memset with an
argument of 'sizeof(NFS_COOKIEVERF(inode))' which therefore
changed from sizeof(be32 cookieverf[2]) to sizeof(be32 *).
At this point, NFS_COOKIEVERF seems to be more of an obfuscation
than a helper, so the best thing would be to just get rid of it.
Also see: https://bugzilla.kernel.org/show_bug.cgi?id=46881
Reported-by: Andi Kleen <andi@firstfloor.org>
Reported-by: David Binderman <dcb314@hotmail.com>
commit 85f2a2ef1d0ab99523e0b947a2b723f5650ed6aa upstream.
When allocating memory fails, page is NULL. page_to_pfn() will
cause the kernel panicked if we don't use sparsemem vmemmap.
Link: http://lkml.kernel.org/r/505AB1FF.8020104@cn.fujitsu.com
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
commit 05cf96398e1b6502f9e191291b715c7463c9d5dd upstream.
I found following definition in include/linux/memory.h, in my IA64
platform, SECTION_SIZE_BITS is equal to 32, and MIN_MEMORY_BLOCK_SIZE
will be 0.
#define MIN_MEMORY_BLOCK_SIZE (1 << SECTION_SIZE_BITS)
Because MIN_MEMORY_BLOCK_SIZE is int type and length of 32bits,
so MIN_MEMORY_BLOCK_SIZE(1 << 32) will will equal to 0.
Actually when SECTION_SIZE_BITS >= 31, MIN_MEMORY_BLOCK_SIZE will be wrong.
This will cause wrong system memory infomation in sysfs.
I think it should be:
#define MIN_MEMORY_BLOCK_SIZE (1UL << SECTION_SIZE_BITS)
And "echo offline > memory0/state" will cause following call trace:
kernel BUG at mm/memory_hotplug.c:885!
sh[6455]: bugcheck! 0 [1]
Pid: 6455, CPU 0, comm: sh
psr : 0000101008526030 ifs : 8000000000000fa4 ip : [<a0000001008c40f0>] Not tainted (3.6.0-rc1)
ip is at offline_pages+0x210/0xee0
Call Trace:
show_stack+0x80/0xa0
show_regs+0x640/0x920
die+0x190/0x2c0
die_if_kernel+0x50/0x80
ia64_bad_break+0x3d0/0x6e0
ia64_native_leave_kernel+0x0/0x270
alloc_pages_current+0x180/0x2a0
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 60e233a56609fd963c59e99bd75c663d63fa91b6 upstream.
Fengguang Wu <fengguang.wu@intel.com> writes:
> After the __devinit* removal series, I can still get kernel panic in
> show_uevent(). So there are more sources of bug..
> Debug patch:
> @@ -343,8 +343,11 @@ static ssize_t show_uevent(struct device
> goto out;
> /* copy keys to file */
> - for (i = 0; i < env->envp_idx; i++)
> + dev_err(dev, "uevent %d env[%d]: %s/.../%s\n", env->buflen, env->envp_idx, top_kobj->name, dev->kobj.name);
> + for (i = 0; i < env->envp_idx; i++) {
> + printk(KERN_ERR "uevent %d env[%d]: %s\n", (int)count, i, env->envp[i]);
> count += sprintf(&buf[count], "%s\n", env->envp[i]);
> Oops message, the env[] is again not properly initilized:
> [ 44.068623] input input0: uevent 61 env[805306368]: input0/.../input0
> [ 44.069552] uevent 0 env[0]: (null)
This is a completely different CONFIG_HOTPLUG problem, only
demonstrating another reason why CONFIG_HOTPLUG should go away. I had a
hard time trying to disable it anyway ;-)
The problem this time is lots of code assuming that a call to
add_uevent_var() will guarantee that env->buflen > 0. This is not true
if CONFIG_HOTPLUG is unset. So things like this end up overwriting
env->envp_idx because the array index is -1:
if (add_uevent_var(env, "MODALIAS="))
return -ENOMEM;
len = input_print_modalias(&env->buf[env->buflen - 1],
sizeof(env->buf) - env->buflen,
dev, 0);
Don't know what the best action is, given that there seem to be a *lot*
of this around the kernel. This patch "fixes" the problem for me, but I
don't know if it can be considered an appropriate fix.
[ It is the correct fix for now, for 3.7 forcing CONFIG_HOTPLUG to
always be on is the longterm fix, but it's too late for 3.6 and older
kernels to resolve this that way - gregkh ]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit a6fa941d94b411bbd2b6421ffbde6db3c93e65ab upstream.
Don't mess with file refcounts (or keep a reference to file, for
that matter) in perf_event. Use explicit refcount of its own
instead. Deal with the race between the final reference to event
going away and new children getting created for it by use of
atomic_long_inc_not_zero() in inherit_event(); just have the
latter free what it had allocated and return NULL, that works
out just fine (children of siblings of something doomed are
created as singletons, same as if the child of leader had been
created and immediately killed).
Link: http://lkml.kernel.org/r/20120820135925.GG23464@ZenIV.linux.org.uk
commit b161dfa6937ae46d50adce8a7c6b12233e96e7bd upstream.
IBM reported a soft lockup after applying the fix for the rename_lock
deadlock. Commit c83ce989cb5f ("VFS: Fix the nfs sillyrename regression
in kernel 2.6.38") was found to be the culprit.
The nfs sillyrename fix used DCACHE_DISCONNECTED to indicate that the
dentry was killed. This flag can be set on non-killed dentries too,
which results in infinite retries when trying to traverse the dentry
tree.
This patch introduces a separate flag: DCACHE_DENTRY_KILLED, which is
only set in d_kill() and makes try_to_ascend() test only this flag.
IBM reported successful test results with this patch.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
