commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream.
The some platforms (e.g., ARM) initializes their clocks as
late_initcalls for some unknown reason. So make sure
random_int_secret_init() is run after all of the late_initcalls are
run.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 4b59e6c4730978679b414a8da61514a2518da512 upstream.
On large systems with a lot of memory, walking all RAM to determine page
types may take a half second or even more.
In non-blockable contexts, the page allocator will emit a page allocation
failure warning unless __GFP_NOWARN is specified. In such contexts, irqs
are typically disabled and such a lengthy delay may even result in NMI
watchdog timeouts.
To fix this, suppress the page walk in such contexts when printing the
page allocation failure warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ]
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
commit 3f1f33206c16c7b3839d71372bc2ac3f305aa802 upstream.
Stephane thought the perf_cpu_context::active_pmu name confusing and
suggested using 'unique_pmu' instead.
This pointer is a pointer to a 'random' pmu sharing the cpuctx
instance, therefore limiting a for_each_pmu loop to those where
cpuctx->unique_pmu matches the pmu we get a loop over unique cpuctx
instances.
Suggested-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-kxyjqpfj2fn9gt7kwu5ag9ks@git.kernel.org
Cc: Li Zefan <lizefan@huawei.com>
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream.
Many drivers need to validate the characteristics of their HID report
during initialization to avoid misusing the reports. This adds a common
helper to perform validation of the report exisitng, the field existing,
and the expected number of values within the field.
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit a19dec6ea94c036af68c31930c1c92681f55af41 upstream.
This patch fixes following error:
include/media/v4l2-ctrls.h:193:15: error: field ‘_lock’ has incomplete type
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_lock’:
include/media/v4l2-ctrls.h:570:2: error: implicit declaration of
function ‘mutex_lock’ [-Werror=implicit-function-declaration]
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_unlock’:
include/media/v4l2-ctrls.h:579:2: error: implicit declaration of
function ‘mutex_unlock’ [-Werror=implicit-function-declaration]
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit 43622021d2e2b82ea03d883926605bdd0525e1d1 upstream.
The "Report ID" field of a HID report is used to build indexes of
reports. The kernel's index of these is limited to 256 entries, so any
malicious device that sets a Report ID greater than 255 will trigger
memory corruption on the host:
[ 1347.156239] BUG: unable to handle kernel paging request at ffff88094958a878
[ 1347.156261] IP: [<ffffffff813e4da0>] hid_register_report+0x2a/0x8b
CVE-2013-2888
commit c34ac00caefbe49d40058ae7200bd58725cebb45 upstream.
list_first_or_null() should test whether the list is empty and return
pointer to the first entry if not in a RCU safe manner. It's broken
in several ways.
* It compares __kernel @__ptr with __rcu @__next triggering the
following sparse warning.
net/core/dev.c:4331:17: error: incompatible types in comparison expression (different address spaces)
* It doesn't perform rcu_dereference*() and computes the entry address
using container_of() directly from the __rcu pointer which is
inconsitent with other rculist interface. As a result, all three
in-kernel users - net/core/dev.c, macvlan, cgroup - are buggy. They
dereference the pointer w/o going through read barrier.
* While ->next dereference passes through list_next_rcu(), the
compiler is still free to fetch ->next more than once and thus
nullify the "__ptr != __next" condition check.
Fix it by making list_first_or_null_rcu() dereference ->next directly
using ACCESS_ONCE() and then use list_entry_rcu() on it like other
rculist accessors.
v2: Paul pointed out that the compiler may fetch the pointer more than
once nullifying the condition check. ACCESS_ONCE() added on
->next dereference.
v3: Restored () around macro param which was accidentally removed.
Spotted by Paul.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
[ Upstream commit 61e76b178dbe7145e8d6afa84bb4ccea71918994 ]
RFC 4443 has defined two additional codes for ICMPv6 type 1 (destination
unreachable) messages:
5 - Source address failed ingress/egress policy
6 - Reject route to destination
Now they are treated as protocol error and icmpv6_err_convert() converts them
to EPROTO.
RFC 4443 says:
"Codes 5 and 6 are more informative subsets of code 1."
Treat codes 5 and 6 as code 1 (EACCES)
Btw, connect() returning -EPROTO confuses firefox, so that fallback to
other/IPv4 addresses does not work:
https://bugzilla.mozilla.org/show_bug.cgi?id=910773
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit f46078cfcd77fa5165bf849f5e568a7ac5fa569c ]
It is not allowed for an ipv6 packet to contain multiple fragmentation
headers. So discard packets which were already reassembled by
fragmentation logic and send back a parameter problem icmp.
The updates for RFC 6980 will come in later, I have to do a bit more
research here.
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
commit d79ff142624e1be080ad8d09101f7004d79c36e1 upstream.
This patch adds wait_event_interruptible_lock_irq_timeout(), which is a
straight-forward descendant of wait_event_interruptible_timeout() and
wait_event_interruptible_lock_irq().
The zfcp driver used to call wait_event_interruptible_timeout()
in combination with some intricate and error-prone locking. Using
wait_event_interruptible_lock_irq_timeout() as a replacement
nicely cleans up that locking.
This rework removes a situation that resulted in a locking imbalance
in zfcp_qdio_sbal_get():
BUG: workqueue leaked lock or atomic: events/1/0xffffff00/10
last function: zfcp_fc_wka_port_offline+0x0/0xa0 [zfcp]
It was introduced by commit c2af7545aaff3495d9bf9a7608c52f0af86fb194
"[SCSI] zfcp: Do not wait for SBALs on stopped queue", which had a new
code path related to ZFCP_STATUS_ADAPTER_QDIOUP that took an early exit
without a required lock being held. The problem occured when a
special, non-SCSI I/O request was being submitted in process context,
when the adapter's queues had been torn down. In this case the bug
surfaced when the Fibre Channel port connection for a well-known address
was closed during a concurrent adapter shut-down procedure, which is a
rare constellation.
This patch also fixes these warnings from the sparse tool (make C=1):
drivers/s390/scsi/zfcp_qdio.c:224:12: warning: context imbalance in
'zfcp_qdio_sbal_check' - wrong count at exit
drivers/s390/scsi/zfcp_qdio.c:244:5: warning: context imbalance in
'zfcp_qdio_sbal_get' - unexpected unlock
Last but not least, we get rid of that crappy lock-unlock-lock
sequence at the beginning of the critical section.
It is okay to call zfcp_erp_adapter_reopen() with req_q_lock held.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com>
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream.
The futex_keys of process shared futexes are generated from the page
offset, the mapping host and the mapping index of the futex user space
address. This should result in an unique identifier for each futex.
Though this is not true when futexes are located in different subpages
of an hugepage. The reason is, that the mapping index for all those
futexes evaluates to the index of the base page of the hugetlbfs
mapping. So a futex at offset 0 of the hugepage mapping and another
one at offset PAGE_SIZE of the same hugepage mapping have identical
futex_keys. This happens because the futex code blindly uses
page->index.
Steps to reproduce the bug:
1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0
and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs
mapping.
The mutexes must be initialized as PTHREAD_PROCESS_SHARED because
PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as
their keys solely depend on the user space address.
2. Lock mutex1 and mutex2
3. Create thread1 and in the thread function lock mutex1, which
results in thread1 blocking on the locked mutex1.
4. Create thread2 and in the thread function lock mutex2, which
results in thread2 blocking on the locked mutex2.
5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2
still blocks on mutex2 because the futex_key points to mutex1.
To solve this issue we need to take the normal page index of the page
which contains the futex into account, if the futex is in an hugetlbfs
mapping. In other words, we calculate the normal page mapping index of
the subpage in the hugetlbfs mapping.
Mappings which are not based on hugetlbfs are not affected and still
use page->index.
Thanks to Mel Gorman who provided a patch for adding proper evaluation
functions to the hugetlbfs code to avoid exposing hugetlbfs specific
details to the futex code.
[ tglx: Massaged changelog ]
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn>
Reviewed-by: 'Mel Gorman' <mgorman@suse.de>
Acked-by: 'Darren Hart' <dvhart@linux.intel.com>
Cc: 'Peter Zijlstra' <peterz@infradead.org>
Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com
Cc: Mike Galbraith <mgalbraith@suse.de>
commit ed5467da0e369e65b247b99eb6403cb79172bcda upstream.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
commit cc229884d3f77ec3b1240e467e0236c3e0647c0c upstream.
This adds a way to check ring empty state after enable_cb outside any
locks. Will be used by virtio_net.
Note: there's room for more optimization: caller is likely to have a
memory barrier already, which means we might be able to get rid of a
barrier here. Deferring this optimization until we do some
benchmarking.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[wg: Backported to 3.2]
Signed-off-by: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
[bwh: Backported to 3.4: adjust context]
commit 0699a73af3811b66b1ab5650575acee5eea841ab upstream.
Commit 18d627113b83 (firewire: prevent dropping of completed iso packet
header data) was intended to be an obvious bug fix, but libdc1394 and
FlyCap2 depend on the old behaviour by ignoring all returned information
and thus not noticing that not all packets have been received yet. The
result was that the video frame buffers would be saved before they
contained the correct data.
Reintroduce the old behaviour for old clients.
Tested-by: Stepan Salenikovich <stepan.salenikovich@gmail.com>
Tested-by: Josep Bosch <jep250@gmail.com>
Cc: <stable@vger.kernel.org> # 3.4+
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
pending data
[ Upstream commit 8822b64a0fa64a5dd1dfcf837c5b0be83f8c05d1 ]
We accidentally call down to ip6_push_pending_frames when uncorking
pending AF_INET data on a ipv6 socket. This results in the following
splat (from Dave Jones):
skbuff: skb_under_panic: text:ffffffff816765f6 len:48 put:40 head:ffff88013deb6df0 data:ffff88013deb6dec tail:0x2c end:0xc0 dev:<NULL>
kernel BUG at net/core/skbuff.c:126!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in: dccp_ipv4 dccp 8021q garp bridge stp dlci mpoa snd_seq_dummy sctp fuse hidp tun bnep nfnetlink scsi_transport_iscsi rfcomm can_raw can_bcm af_802154 appletalk caif_socket can caif ipt_ULOG x25 rose af_key pppoe pppox ipx phonet irda llc2 ppp_generic slhc p8023 psnap p8022 llc crc_ccitt atm bluetooth
+netrom ax25 nfc rfkill rds af_rxrpc coretemp hwmon kvm_intel kvm crc32c_intel snd_hda_codec_realtek ghash_clmulni_intel microcode pcspkr snd_hda_codec_hdmi snd_hda_intel snd_hda_codec snd_hwdep usb_debug snd_seq snd_seq_device snd_pcm e1000e snd_page_alloc snd_timer ptp snd pps_core soundcore xfs libcrc32c
CPU: 2 PID: 8095 Comm: trinity-child2 Not tainted 3.10.0-rc7+ #37
task: ffff8801f52c2520 ti: ffff8801e6430000 task.ti: ffff8801e6430000
RIP: 0010:[<ffffffff816e759c>] [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP: 0018:ffff8801e6431de8 EFLAGS: 00010282
RAX: 0000000000000086 RBX: ffff8802353d3cc0 RCX: 0000000000000006
RDX: 0000000000003b90 RSI: ffff8801f52c2ca0 RDI: ffff8801f52c2520
RBP: ffff8801e6431e08 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000001 R12: ffff88022ea0c800
R13: ffff88022ea0cdf8 R14: ffff8802353ecb40 R15: ffffffff81cc7800
FS: 00007f5720a10740(0000) GS:ffff880244c00000(0000) knlGS:0000000000000000
CR2: 0000000005862000 CR3: 000000022843c000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600
Stack:
ffff88013deb6dec 000000000000002c 00000000000000c0 ffffffff81a3f6e4
ffff8801e6431e18 ffffffff8159a9aa ffff8801e6431e90 ffffffff816765f6
ffffffff810b756b 0000000700000002 ffff8801e6431e40 0000fea9292aa8c0
Call Trace:
[<ffffffff8159a9aa>] skb_push+0x3a/0x40
[<ffffffff816765f6>] ip6_push_pending_frames+0x1f6/0x4d0
[<ffffffff810b756b>] ? mark_held_locks+0xbb/0x140
[<ffffffff81694919>] udp_v6_push_pending_frames+0x2b9/0x3d0
[<ffffffff81694660>] ? udplite_getfrag+0x20/0x20
[<ffffffff8162092a>] udp_lib_setsockopt+0x1aa/0x1f0
[<ffffffff811cc5e7>] ? fget_light+0x387/0x4f0
[<ffffffff816958a4>] udpv6_setsockopt+0x34/0x40
[<ffffffff815949f4>] sock_common_setsockopt+0x14/0x20
[<ffffffff81593c31>] SyS_setsockopt+0x71/0xd0
[<ffffffff816f5d54>] tracesys+0xdd/0xe2
Code: 00 00 48 89 44 24 10 8b 87 d8 00 00 00 48 89 44 24 08 48 8b 87 e8 00 00 00 48 c7 c7 c0 04 aa 81 48 89 04 24 31 c0 e8 e1 7e ff ff <0f> 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55
RIP [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP <ffff8801e6431de8>
This patch adds a check if the pending data is of address family AF_INET
and directly calls udp_push_ending_frames from udp_v6_push_pending_frames
if that is the case.
This bug was found by Dave Jones with trinity.
(Also move the initialization of fl6 below the AF_INET check, even if
not strictly necessary.)
Cc: Dave Jones <davej@redhat.com>
[ Upstream commit 8965779d2c0e6ab246c82a405236b1fb2adae6b2, with
some bits from commit b7b1bfce0bb68bd8f6e62a28295922785cc63781
("ipv6: split duplicate address detection and router solicitation timer")
to get the __ipv6_get_lladdr() used by this patch. ]
dingtianhong reported the following deadlock detected by lockdep:
[ INFO: possible circular locking dependency detected ]
3.4.24.05-0.1-default #1 Not tainted
ksoftirqd/0/3 is trying to acquire lock:
(&ndev->lock){+.+...}, at: [<ffffffff8147f804>] ipv6_get_lladdr+0x74/0x120
but task is already holding lock:
(&mc->mca_lock){+.+...}, at: [<ffffffff8149d130>] mld_send_report+0x40/0x150
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&mc->mca_lock){+.+...}:
[<ffffffff810a8027>] validate_chain+0x637/0x730
[<ffffffff810a8417>] __lock_acquire+0x2f7/0x500
[<ffffffff810a8734>] lock_acquire+0x114/0x150
[<ffffffff814f691a>] rt_spin_lock+0x4a/0x60
[<ffffffff8149e4bb>] igmp6_group_added+0x3b/0x120
[<ffffffff8149e5d8>] ipv6_mc_up+0x38/0x60
[<ffffffff81480a4d>] ipv6_find_idev+0x3d/0x80
[<ffffffff81483175>] addrconf_notify+0x3d5/0x4b0
[<ffffffff814fae3f>] notifier_call_chain+0x3f/0x80
[<ffffffff81073471>] raw_notifier_call_chain+0x11/0x20
[<ffffffff813d8722>] call_netdevice_notifiers+0x32/0x60
[<ffffffff813d92d4>] __dev_notify_flags+0x34/0x80
[<ffffffff813d9360>] dev_change_flags+0x40/0x70
[<ffffffff813ea627>] do_setlink+0x237/0x8a0
[<ffffffff813ebb6c>] rtnl_newlink+0x3ec/0x600
[<ffffffff813eb4d0>] rtnetlink_rcv_msg+0x160/0x310
[<ffffffff814040b9>] netlink_rcv_skb+0x89/0xb0
[<ffffffff813eb357>] rtnetlink_rcv+0x27/0x40
[<ffffffff81403e20>] netlink_unicast+0x140/0x180
[<ffffffff81404a9e>] netlink_sendmsg+0x33e/0x380
[<ffffffff813c4252>] sock_sendmsg+0x112/0x130
[<ffffffff813c537e>] __sys_sendmsg+0x44e/0x460
[<ffffffff813c5544>] sys_sendmsg+0x44/0x70
[<ffffffff814feab9>] system_call_fastpath+0x16/0x1b
-> #0 (&ndev->lock){+.+...}:
[<ffffffff810a798e>] check_prev_add+0x3de/0x440
[<ffffffff814f6c82>] rt_read_lock+0x42/0x60
[<ffffffff8149b036>] mld_newpack+0xb6/0x160
[<ffffffff8149b18b>] add_grhead+0xab/0xc0
[<ffffffff8149d03b>] add_grec+0x3ab/0x460
[<ffffffff8149d14a>] mld_send_report+0x5a/0x150
[<ffffffff8149f99e>] igmp6_timer_handler+0x4e/0xb0
[<ffffffff8105705a>] call_timer_fn+0xca/0x1d0
[<ffffffff81057b9f>] run_timer_softirq+0x1df/0x2e0
[<ffffffff8104e8c7>] handle_pending_softirqs+0xf7/0x1f0
[<ffffffff8104ea3b>] __do_softirq_common+0x7b/0xf0
[<ffffffff8104f07f>] __thread_do_softirq+0x1af/0x210
[<ffffffff8104f1c1>] run_ksoftirqd+0xe1/0x1f0
[<ffffffff8106c7de>] kthread+0xae/0xc0
[<ffffffff814fff74>] kernel_thread_helper+0x4/0x10
actually we can just hold idev->lock before taking pmc->mca_lock,
and avoid taking idev->lock again when iterating idev->addr_list,
since the upper callers of mld_newpack() already take
read_lock_bh(&idev->lock).
Reported-by: dingtianhong <dingtianhong@huawei.com>
Cc: dingtianhong <dingtianhong@huawei.com>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Tested-by: Ding Tianhong <dingtianhong@huawei.com>
Tested-by: Chen Weilong <chenweilong@huawei.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit b1a5a34bd0b8767ea689e68f8ea513e9710b671e ]
Ver and type in pppoe_hdr should be swapped as defined by RFC2516
section-4.
commit 26cb63ad11e04047a64309362674bcbbd6a6f246 upstream.
Vince reported a problem found by his perf specific trinity
fuzzer.
Al noticed 2 problems with perf's mmap():
- it has issues against fork() since we use vma->vm_mm for accounting.
- it has an rb refcount leak on double mmap().
We fix the issues against fork() by using VM_DONTCOPY; I don't
think there's code out there that uses this; we didn't hear
about weird accounting problems/crashes. If we do need this to
work, the previously proposed VM_PINNED could make this work.
Aside from the rb reference leak spotted by Al, Vince's example
prog was indeed doing a double mmap() through the use of
perf_event_set_output().
This exposes another problem, since we now have 2 events with
one buffer, the accounting gets screwy because we account per
event. Fix this by making the buffer responsible for its own
accounting.
[Backporting for 3.4-stable.
VM_RESERVED flag was replaced with pair 'VM_DONTEXPAND | VM_DONTDUMP' in
314e51b9 since 3.7.0-rc1, and 314e51b9 comes from a big patchset, we didn't
backport the patchset, so I restored 'VM_DNOTEXPAND | VM_DONTDUMP' as before:
- vma->vm_flags |= VM_DONTCOPY | VM_DONTEXPAND | VM_DONTDUMP;
+ vma->vm_flags |= VM_DONTCOPY | VM_RESERVED;
-- zliu]
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20130528085548.GA12193@twins.programming.kicks-ass.net
Signed-off-by: Zhouping Liu <zliu@redhat.com>
[ Upstream commit c87a124a5d5e8cf8e21c4363c3372bcaf53ea190 ]
Roman Gushchin discovered that udp4_lib_lookup2() was not reloading
first item in the rcu protected list, in case the loop was restarted.
This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37
rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is
ptr->field :
In some cases, gcc caches the value or ptr->field in a register.
Use a barrier() to disallow such caching, as documented in
Documentation/atomic_ops.txt line 114
Thanks a lot to Roman for providing analysis and numerous patches.
Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru>
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit e9966076cdd952e19f2dd4854cd719be0d7cbebc upstream.
The auth code is called from a variety of contexts, include the mon_client
(protected by the monc's mutex) and the messenger callbacks (currently
protected by nothing). Avoid chaos by protecting all auth state with a
mutex. Nothing is blocking, so this should be simple and lightweight.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
commit 27859f9773e4a0b2042435b13400ee2c891a61f4 upstream.
Use wrapper functions that check whether the auth op exists so that callers
do not need a bunch of conditional checks. Simplifies the external
interface.
commit 0bed9b5c523d577378b6f83eab5835fe30c27208 upstream.
Currently the messenger calls out to a get_authorizer con op, which will
create a new authorizer if it doesn't yet have one. In the meantime, when
we rotate our service keys, the authorizer doesn't get updated. Eventually
it will be rejected by the server on a new connection attempt and get
invalidated, and we will then rebuild a new authorizer, but this is not
ideal.
Instead, if we do have an authorizer, call a new update_authorizer op that
will verify that the current authorizer is using the latest secret. If it
is not, we will build a new one that does. This avoids the transient
failure.
This fixes one of the sorry sequence of events for bug
http://tracker.ceph.com/issues/4282
commit 30dad30922ccc733cfdbfe232090cf674dc374dc upstream.
When we have a page fault for the address which is backed by a hugepage
under migration, the kernel can't wait correctly and do busy looping on
hugepage fault until the migration finishes. As a result, users who try
to kick hugepage migration (via soft offlining, for example) occasionally
experience long delay or soft lockup.
This is because pte_offset_map_lock() can't get a correct migration entry
or a correct page table lock for hugepage. This patch introduces
migration_entry_wait_huge() to solve this.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 16e53dbf10a2d7e228709a7286310e629ede5e45 upstream.
There are instances in the kernel where we would like to disable CPU
hotplug (from sysfs) during some important operation. Today the freezer
code depends on this and the code to do it was kinda tailor-made for
that.
Restructure the code and make it generic enough to be useful for other
usecases too.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Shawn Guo <shawn.guo@linaro.org>
commit 96570ffcca0b872dc8626e97569d2697f374d868 upstream.
If hci_dev_open fails we need to ensure that the corresponding
mgmt_set_powered command gets an appropriate response. This patch fixes
the missing response by adding a new mgmt_set_powered_failed function
that's used to indicate a power on failure to mgmt. Since a situation
with the device being rfkilled may require special handling in user
space the patch uses a new dedicated mgmt status code for this.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream.
As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to
be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the
ftrace_pid_fops is defined when DYNAMIC_FTRACE is not.
Cc: Namhyung Kim <namhyung@kernel.org>
[ lizf: adjust context ]
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream.
Currently set_ftrace_pid and set_graph_function files use seq_lseek
for their fops. However seq_open() is called only for FMODE_READ in
the fops->open() so that if an user tries to seek one of those file
when she open it for writing, it sees NULL seq_file and then panic.
It can be easily reproduced with following command:
$ cd /sys/kernel/debug/tracing
$ echo 1234 | sudo tee -a set_ftrace_pid
In this example, GNU coreutils' tee opens the file with fopen(, "a")
and then the fopen() internally calls lseek().
Link:
http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Namhyung Kim <namhyung.kim@lge.com>
commit 4c663cfc523a88d97a8309b04a089c27dc57fd7e upstream.
Many callers of the wait_event_timeout() and
wait_event_interruptible_timeout() expect that the return value will be
positive if the specified condition becomes true before the timeout
elapses. However, at the moment this isn't guaranteed. If the wake-up
handler is delayed enough, the time remaining until timeout will be
calculated as 0 - and passed back as a return value - even if the
condition became true before the timeout has passed.
Fix this by returning at least 1 if the condition becomes true. This
semantic is in line with what wait_for_condition_timeout() does; see
commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious
failure under heavy load").
Daniel said "We have 3 instances of this bug in drm/i915. One case even
where we switch between the interruptible and not interruptible
wait_event_timeout variants, foolishly presuming they have the same
semantics. I very much like this."
One such bug is reported at
https://bugs.freedesktop.org/show_bug.cgi?id=64133
Signed-off-by: Imre Deak <imre.deak@intel.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: Lukas Czerner <lczerner@redhat.com>
commit af73e4d9506d3b797509f3c030e7dcd554f7d9c4 upstream.
The current kernel returns -EINVAL unless a given mmap length is
"almost" hugepage aligned. This is because in sys_mmap_pgoff() the
given length is passed to vm_mmap_pgoff() as it is without being aligned
with hugepage boundary.
This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix
alignment of huge page requests"), where alignment code is pushed into
hugetlb_file_setup() and the variable len in caller side is not changed.
To fix this, this patch partially reverts that commit, and adds
alignment code in caller side. And it also introduces hstate_sizelog()
in order to get proper hstate to specified hugepage size.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881
[akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n]
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: <iceman_dvd@yahoo.com>
Cc: Steven Truelove <steven.truelove@utoronto.ca>
Cc: Jianguo Wu <wujianguo@huawei.com>
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ]
We have seen multiple NULL dereferences in __inet6_lookup_established()
After analysis, I found that inet6_sk() could be NULL while the
check for sk_family == AF_INET6 was true.
Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP
and TCP stacks.
Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash
table, we no longer can clear pinet6 field.
This patch extends logic used in commit fcbdf09d9652c891
("net: fix nulls list corruptions in sk_prot_alloc")
TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method
to make sure we do not clear pinet6 field.
At socket clone phase, we do not really care, as cloning the parent (non
NULL) pinet6 is not adding a fatal race.
[ Upstream commit 233c7df0821c4190e2d3f4be0f2ca0ab40a5ed8c, note
that I had to add list_first_or_null_rcu to rculist.h in order
to accomodate this fix. ]
Currently, if macvlan in passthru mode is created and data are rxed and
you remove this device, following panic happens:
NULL pointer dereference at 0000000000000198
IP: [<ffffffffa0196058>] macvlan_handle_frame+0x153/0x1f7 [macvlan]
I'm using following script to trigger this:
<script>
while [ 1 ]
do
ip link add link e1 name macvtap0 type macvtap mode passthru
ip link set e1 up
ip link set macvtap0 up
IFINDEX=`ip link |grep macvtap0 | cut -f 1 -d ':'`
cat /dev/tap$IFINDEX >/dev/null &
ip link del dev macvtap0
done
</script>
I run this script while "ping -f" is running on another machine to send
packets to e1 rx.
Reason of the panic is that list_first_entry() is blindly called in
macvlan_handle_frame() even if the list was empty. vlan is set to
incorrect pointer which leads to the crash.
I'm fixing this by protecting port->vlans list by rcu and by preventing
from getting incorrect pointer in case the list is empty.
Introduced by: commit eb06acdc85585f2 "macvlan: Introduce 'passthru' mode to takeover the underlying device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 4f924b2aa4d3cb30f07e57d6b608838edcbc0d88 ]
Protect the SIOCGCM* ioctl macros with parenthesis.
Reported-by: Paul Wouters <pwouters@redhat.com>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
[ Upstream commit 093162553c33e9479283e107b4431378271c735d ]
Before escaping RCU protected section and adding packet into
prequeue, make sure the dst is refcounted.
Reported-by: Mike Galbraith <bitbucket@online.de>
commit cdee3904b4ce7c03d1013ed6dd704b43ae7fc2e9 upstream.
Commit b05d8447e782 (audit: inline audit_syscall_entry to reduce
burden on archs) changed audit_syscall_entry to check for a dummy
context before calling __audit_syscall_entry. Unfortunately the dummy
context state is maintained in __audit_syscall_entry so once set it
never gets cleared, even if the audit rules change.
As a result, if there are no auditing rules when a process starts
then it will never be subject to any rules added later. x86 doesn't
see this because it has an assembly fast path that calls directly into
I noticed this issue when working on audit performance optimisations.
I wrote a set of simple test cases available at:
http://ozlabs.org/~anton/junkcode/audit_tests.tar.gz
02_new_rule.py fails without the patch and passes with it. The
test case clears all rules, starts a process, adds a rule then
verifies the process produces a syscall audit record.
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 62d1f92e06aef9665d71ca7e986b3047ecf0b3c7 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 18932a28419596bc9403770f5d8a108c5433fe59 upstream.
commit 794446c6946513c684d448205fbd76fa35f38b72 upstream.
The following race is possible:
[kjournald2] other_task
jbd2_journal_commit_transaction()
j_state = T_FINISHED;
spin_unlock(&journal->j_list_lock);
->jbd2_journal_remove_checkpoint()
->jbd2_journal_free_transaction();
->kmem_cache_free(transaction)
->j_commit_callback(journal, transaction);
-> USE_AFTER_FREE
WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250()
Hardware name:
list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107
Call Trace:
[<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0
[<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0
[<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250
[<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0
[<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570
[<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0
[<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0
[<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0
[<ffffffff810ad630>] ? wake_up_bit+0x40/0x40
[<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80
[<ffffffff810ac6be>] kthread+0x10e/0x120
[<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70
[<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0
In order to demonstrace this issue one should mount ext4 with mount -o
discard option on SSD disk. This makes callback longer and race
window becomes wider.
In order to fix this we should mark transaction as finished only after
callbacks have completed
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream.
Trying to run an application which was trying to put data into half of
memory using shmget(), we found that having a shmall value below 8EiB-8TiB
would prevent us from using anything more than 8TiB. By setting
kernel.shmall greater than 8EiB-8TiB would make the job work.
In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX.
ipc/shm.c:
458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params)
459 {
465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT;
474 if (ns->shm_tot + numpages > ns->shm_ctlall)
475 return -ENOSPC;
[akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int]
Reported-by: Alex Thorlton <athorlton@sgi.com>
commit 6ee8630e02be6dd89926ca0fbc21af68b23dc087 upstream.
On architectures where a pgd entry may be shared between user and kernel
(e.g. ARM+LPAE), freeing page tables needs a ceiling other than 0.
This patch introduces a generic USER_PGTABLES_CEILING that arch code can
override. It is the responsibility of the arch code setting the ceiling
to ensure the complete freeing of the page tables (usually in
pgd_free()).
[catalin.marinas@arm.com: commit log; shift_arg_pages(), asm-generic/pgtables.h changes]
[ Upstream commit 83f1b4ba917db5dc5a061a44b3403ddb6e783494 ]
Commit 257b5358b32f ("scm: Capture the full credentials of the scm
sender") changed the credentials passing code to pass in the effective
uid/gid instead of the real uid/gid.
Obviously this doesn't matter most of the time (since normally they are
the same), but it results in differences for suid binaries when the wrong
uid/gid ends up being used.
This just undoes that (presumably unintentional) part of the commit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge@hallyn.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit 124dff01afbdbff251f0385beca84ba1b9adda68 ]
Commit 130549fe ("netfilter: reset nf_trace in nf_reset") added code
to reset nf_trace in nf_reset(). This is wrong and unnecessary.
nf_reset() is used in the following cases:
- when passing packets up the the socket layer, at which point we want to
release all netfilter references that might keep modules pinned while
the packet is queued. nf_trace doesn't matter anymore at this point.
- when encapsulating or decapsulating IPsec packets. We want to continue
tracing these packets after IPsec processing.
- when passing packets through virtual network devices. Only devices on
that encapsulate in IPv4/v6 matter since otherwise nf_trace is not
used anymore. Its not entirely clear whether those packets should
be traced after that, however we've always done that.
- when passing packets through virtual network devices that make the
packet cross network namespace boundaries. This is the only cases
where we clearly want to reset nf_trace and is also what the
original patch intended to fix.
Add a new function nf_reset_trace() and use it in dev_forward_skb() to
fix this properly.
[ Upstream commit 4543fbefe6e06a9e40d9f2b28d688393a299f079 ]
A few drivers use dev_uc_sync/unsync to synchronize the
address lists from master down to slave/lower devices. In
some cases (bond/team) a single address list is synched down
to multiple devices. At the time of unsync, we have a leak
in these lower devices, because "synced" is treated as a
boolean and the address will not be unsynced for anything after
the first device/call.
Treat "synced" as a count (same as refcount) and allow all
unsync calls to work.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e upstream.
Various drivers end up replicating the code to mmap() their memory
buffers into user space, and our core memory remapping function may be
very flexible but it is unnecessarily complicated for the common cases
to use.
Our internal VM uses pfn's ("page frame numbers") which simplifies
things for the VM, and allows us to pass physical addresses around in a
denser and more efficient format than passing a "phys_addr_t" around,
and having to shift it up and down by the page size. But it just means
that drivers end up doing that shifting instead at the interface level.
It also means that drivers end up mucking around with internal VM things
like the vma details (vm_pgoff, vm_start/end) way more than they really
need to.
So this just exports a function to map a certain physical memory range
into user space (using a phys_addr_t based interface that is much more
natural for a driver) and hides all the complexity from the driver.
Some drivers will still end up tweaking the vm_page_prot details for
things like prefetching or cacheability etc, but that's actually
relevant to the driver, rather than caring about what the page offset of
the mapping is into the particular IO memory region.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 46fc4c909339f5a84d1679045297d9d2fb596987 upstream.
And make use of it in b43. This fixes a regression introduced with
49d55cef5b1925a5c1efb6aaddaa40fc7c693335
b43: N-PHY: implement spurious tone avoidance
This commit made BCM4322 use only MCS 0 on channel 13, which of course
resulted in performance drop (down to 0.7Mb/s).
Reported-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
commit 8f964525a121f2ff2df948dac908dcc65be21b5b upstream.
This patch adds support for kvm_gfn_to_hva_cache_init functions for
reads and writes that will cross a page. If the range falls within
the same memslot, then this will be a fast operation. If the range
is split between two memslots, then the slower kvm_read_guest and
kvm_write_guest are used.
Tested: Test against kvm_clock unit tests.
Signed-off-by: Andrew Honig <ahonig@google.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 4b20db3de8dab005b07c74161cb041db8c5ff3a7 upstream.
This function is intended to simplify locking around refcounting for
objects that can be looked up from a lookup structure, and which are
removed from that lookup structure in the object destructor.
Operations on such objects require at least a read lock around
lookup + kref_get, and a write lock around kref_put + remove from lookup
structure. Furthermore, RCU implementations become extremely tricky.
With a lookup followed by a kref_get_unless_zero *with return value check*
locking in the kref_put path can be deferred to the actual removal from
the lookup structure and RCU lookups become trivial.
v2: Formatting fixes.
v3: Invert the return value.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
commit 386afc91144b36b42117b0092893f15bc8798a80 upstream.
In UP and non-preempt respectively, the spinlocks and preemption
disable/enable points are stubbed out entirely, because there is no
regular code that can ever hit the kind of concurrency they are meant to
protect against.
However, while there is no regular code that can cause scheduling, we
_do_ end up having some exceptional (literally!) code that can do so,
and that we need to make sure does not ever get moved into the critical
region by the compiler.
In particular, get_user() and put_user() is generally implemented as
inline asm statements (even if the inline asm may then make a call
instruction to call out-of-line), and can obviously cause a page fault
and IO as a result. If that inline asm has been scheduled into the
middle of a preemption-safe (or spinlock-protected) code region, we
obviously lose.
Now, admittedly this is *very* unlikely to actually ever happen, and
we've not seen examples of actual bugs related to this. But partly
exactly because it's so hard to trigger and the resulting bug is so
subtle, we should be extra careful to get this right.
So make sure that even when preemption is disabled, and we don't have to
generate any actual *code* to explicitly tell the system that we are in
a preemption-disabled region, we need to at least tell the compiler not
to move things around the critical region.
This patch grew out of the same discussion that caused commits
79e5f05edcbf ("ARC: Add implicit compiler barrier to raw_local_irq*
functions") and 3e2e0d2c222b ("tile: comment assumption about
__insn_mtspr for <asm/irqflags.h>") to come about.
Note for stable: use discretion when/if applying this. As mentioned,
this bug may never have actually bitten anybody, and gcc may never have
done the required code motion for it to possibly ever trigger in
practice.
Cc: Steven Rostedt <srostedt@redhat.com>
commit a32450e127fc6e5ca6d958ceb3cfea4d30a00846 upstream.
The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than
65535, and the blow backtrace is observed on locking up:
INFO: task flush-8:32:1130 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000
ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000
ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000
ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000
Call Trace:
[<ffffffff8168fc2d>] schedule+0x5d/0x70
[<ffffffff8168fccc>] io_schedule+0x8c/0xd0
[<ffffffff81324461>] get_request+0x731/0x7d0
[<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90
[<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40
[<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110
[<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0
[<ffffffff81322176>] generic_make_request+0xc6/0x120
[<ffffffff81322308>] submit_bio+0x138/0x160
[<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120
[<ffffffff811d1f61>] submit_bh+0x1f1/0x220
[<ffffffff811d48b8>] __block_write_full_page+0x228/0x340
[<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0
[<ffffffff811d8960>] ? I_BDEV+0x10/0x10
[<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100
[<ffffffff811d4ae5>] block_write_full_page+0x15/0x20
[<ffffffff811d9268>] blkdev_writepage+0x18/0x20
[<ffffffff81142527>] __writepage+0x17/0x40
[<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0
[<ffffffff81142510>] ? set_page_dirty+0x70/0x70
[<ffffffff81143a61>] generic_writepages+0x51/0x80
[<ffffffff81143ab0>] do_writepages+0x20/0x50
[<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0
[<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0
[<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0
[<ffffffff811cad43>] wb_writeback+0x1a3/0x330
[<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50
[<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70
[<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260
[<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240
[<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0
[<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260
[<ffffffff81083550>] kthread+0xc0/0xd0
[<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0
[<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0
The above trace was triggered by
"dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768"
It was previously working by accident, since another bug introduced
by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused
all drives to use maxsect=65535.
Signed-off-by: Shan Hai <shan.hai@windriver.com>
