The percpu code requires more functions to be implemented in the mm core
which nommu currently does not provide. So add inline implementations
since these are largely meaningless on nommu systems.
Signed-off-by: Graf Yang <graf.yang@analog.com>
Acked-by: Greg Ungerer <gerg@uclinux.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'syscore' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
Introduce ARCH_NO_SYSDEV_OPS config option (v2)
cpufreq: Use syscore_ops for boot CPU suspend/resume (v2)
KVM: Use syscore_ops instead of sysdev class and sysdev
PCI / Intel IOMMU: Use syscore_ops instead of sysdev class and sysdev
timekeeping: Use syscore_ops instead of sysdev class and sysdev
x86: Use syscore_ops instead of sysdev classes and sysdevs
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (55 commits)
[SCSI] tcm_loop: Add multi-fabric Linux/SCSI LLD fabric module
[SCSI] qla4xxx: Use polling mode for disable interrupt mailbox completion
[SCSI] Revert "[SCSI] Retrieve the Caching mode page"
[SCSI] bnx2fc: IO completion not processed due to missed wakeup
[SCSI] qla4xxx: Update driver version to 5.02.00-k6
[SCSI] qla4xxx: masking required bits of add_fw_options during initialization
[SCSI] qla4xxx: added new function qla4xxx_relogin_all_devices
[SCSI] qla4xxx: add support for ql4xsess_recovery_tmo cmd line param
[SCSI] qla4xxx: Add support for ql4xmaxqdepth command line parameter
[SCSI] qla4xxx: cleanup function qla4xxx_process_ddb_changed
[SCSI] qla4xxx: Prevent other port reinitialization during remove_adapter
[SCSI] qla4xxx: remove unused ddb flag DF_NO_RELOGIN
[SCSI] qla4xxx: cleanup DDB relogin logic during initialization
[SCSI] qla4xxx: Do not retry ISP82XX initialization if H/W state is failed
[SCSI] qla4xxx: Do not send mbox command if FW is in failed state
[SCSI] qla4xxx: cleanup qla4xxx_initialize_ddb_list()
[SCSI] ses: add subenclosure support
[SCSI] bnx2fc: Bump version to 1.0.1
[SCSI] bnx2fc: Remove unnecessary module state checks
[SCSI] bnx2fc: Fix MTU issue by using static MTU
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits)
route: Take the right src and dst addresses in ip_route_newports
ipv4: Fix nexthop caching wrt. scoping.
ipv4: Invalidate nexthop cache nh_saddr more correctly.
net: fix pch_gbe section mismatch warning
ipv4: fix fib metrics
mlx4_en: Removing HW info from ethtool -i report.
net_sched: fix THROTTLED/RUNNING race
drivers/net/a2065.c: Convert release_resource to release_region/release_mem_region
drivers/net/ariadne.c: Convert release_resource to release_region/release_mem_region
bonding: fix rx_handler locking
myri10ge: fix rmmod crash
mlx4_en: updated driver version to 1.5.4.1
mlx4_en: Using blue flame support
mlx4_core: reserve UARs for userspace consumers
mlx4_core: maintain available field in bitmap allocator
mlx4: Add blue flame support for kernel consumers
mlx4_en: Enabling new steering
mlx4: Add support for promiscuous mode in the new steering model.
mlx4: generalization of multicast steering.
mlx4_en: Reporting HW revision in ethtool -i
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: Disable ASPM when _OSC control is not granted for PCIe services
PCI: Changing ASPM policy, via /sys, to POWERSAVE could cause NMIs
PCI: PCIe links may not get configured for ASPM under POWERSAVE mode
PCI/ACPI: Report ASPM support to BIOS if not disabled from command line
* git://git.infradead.org/battery-2.6: (30 commits)
bq20z75: Fix time and temp units
bq20z75: Fix issues with present and suspend
z2_battery: Fix count of properties
s3c_adc_battery: Fix method names when PM not set
z2_battery: Add MODULE_DEVICE_TABLE
ds2782_battery: Add MODULE_DEVICE_TABLE
bq20z75: Add MODULE_DEVICE_TABLE
power_supply: Update power_supply_is_watt_property
bq20z75: Add i2c retry mechanism
bq20z75: Add optional battery detect gpio
twl4030_charger: Make the driver atomic notifier safe
bq27x00: Use single i2c_transfer call for property read
bq27x00: Cleanup bq27x00_i2c_read
bq27x00: Minor cleanups
bq27x00: Give more specific reports on battery status
bq27x00: Add MODULE_DEVICE_TABLE
bq27x00: Add new properties
bq27x00: Poll battery state
bq27x00: Cache battery registers
bq27x00: Add bq27000 support
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm stripe: implement merge method
dm mpath: allow table load with no priority groups
dm mpath: fail message ioctl if specified path is not valid
dm ioctl: add flag to wipe buffers for secure data
dm ioctl: prepare for crypt key wiping
dm crypt: wipe keys string immediately after key is set
dm: add flakey target
dm: fix opening log and cow devices for read only tables
* 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits)
genirq: Expand generic show_interrupts()
gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler
gpio: Cleanup genirq namespace
arm: ep93xx: Add basic interrupt info
arm/gpio: Remove three copies of broken and racy debug code
xtensa: Use generic show_interrupts()
xtensa: Convert genirq namespace
xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED
xtensa: Convert s6000 gpio irq_chip to new functions
xtensa: Convert main irq_chip to new functions
um: Use generic show_interrupts()
um: Convert genirq namespace
m32r: Use generic show_interrupts()
m32r: Convert genirq namespace
h8300: Use generic show_interrupts()
h8300: Convert genirq namespace
avr32: Cleanup eic_set_irq_type()
avr32: Use generic show_interrupts()
avr: Cleanup genirq namespace
avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED
Fix up trivial conflict in drivers/gpio/timbgpio.c
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched, doc: Update sched-design-CFS.txt
sched: Remove unused 'rq' variable and cpu_rq() call from alloc_fair_sched_group()
sched.h: Fix a typo ("its")
sched: Fix yield_to kernel-doc
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf, x86: Complain louder about BIOSen corrupting CPU/PMU state and continue
perf, x86: P4 PMU - Read proper MSR register to catch unflagged overflows
perf symbols: Look at .dynsym again if .symtab not found
perf build-id: Add quirk to deal with perf.data file format breakage
perf session: Pass evsel in event_ops->sample()
perf: Better fit max unprivileged mlock pages for tools needs
perf_events: Fix stale ->cgrp pointer in update_cgrp_time_from_cpuctx()
perf top: Fix uninitialized 'counter' variable
tracing: Fix set_ftrace_filter probe function display
perf, x86: Fix Intel fixed counters base initialization
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Provide locked setter for chip, handler, name
genirq: Provide a lockdep helper
genirq; Remove the last leftovers of the old sparse irq code
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Fix WARN_ON() test for UP
WARN_ON_SMP(): Allow use in if() statements on UP
x86, dumpstack: Use %pB format specifier for stack trace
vsprintf: Introduce %pB format specifier
lockdep: Remove unused 'factor' variable from lockdep_stats_show()
git://git.linux-nfs.org/projects/trondmy/nfs-2.6
* 'nfs-for-2.6.39' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (28 commits)
Cleanup XDR parsing for LAYOUTGET, GETDEVICEINFO
NFSv4.1 convert layoutcommit sync to boolean
NFSv4.1 pnfs_layoutcommit_inode fixes
NFS: Determine initial mount security
NFS: use secinfo when crossing mountpoints
NFS: Add secinfo procedure
NFS: lookup supports alternate client
NFS: convert call_sync() to a function
NFSv4.1 remove temp code that prevented ds commits
NFSv4.1: layoutcommit
NFSv4.1: filelayout driver specific code for COMMIT
NFSv4.1: remove GETATTR from ds commits
NFSv4.1: add generic layer hooks for pnfs COMMIT
NFSv4.1: alloc and free commit_buckets
NFSv4.1: shift filelayout_free_lseg
NFSv4.1: pull out code from nfs_commit_release
NFSv4.1: pull error handling out of nfs_commit_list
NFSv4.1: add callback to nfs4_commit_done
NFSv4.1: rearrange nfs_commit_rpcsetup
NFSv4.1: don't send COMMIT to ds for data sync writes
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (43 commits)
ext4: fix a BUG in mb_mark_used during trim.
ext4: unused variables cleanup in fs/ext4/extents.c
ext4: remove redundant set_buffer_mapped() in ext4_da_get_block_prep()
ext4: add more tracepoints and use dev_t in the trace buffer
ext4: don't kfree uninitialized s_group_info members
ext4: add missing space in printk's in __ext4_grp_locked_error()
ext4: add FITRIM to compat_ioctl.
ext4: handle errors in ext4_clear_blocks()
ext4: unify the ext4_handle_release_buffer() api
ext4: handle errors in ext4_rename
jbd2: add COW fields to struct jbd2_journal_handle
jbd2: add the b_cow_tid field to journal_head struct
ext4: Initialize fsync transaction ids in ext4_new_inode()
ext4: Use single thread to perform DIO unwritten convertion
ext4: optimize ext4_bio_write_page() when no extent conversion is needed
ext4: skip orphan cleanup if fs has unknown ROCOMPAT features
ext4: use the nblocks arg to ext4_truncate_restart_trans()
ext4: fix missing iput of root inode for some mount error paths
ext4: make FIEMAP and delayed allocation play well together
ext4: suppress verbose debugging information if malloc-debug is off
Fi up conflicts in fs/ext4/super.c due to workqueue changes
Some archs want to print extra information for certain irq_chips which
is per irq and not per chip. Allow them to provide a chip callback to
print the chip name and the extra information.
PowerPC wants to print the LEVEL/EDGE type information. Make it configurable.
Both WARN_ON() and WARN_ON_SMP() should be able to be used in
an if statement.
if (WARN_ON_SMP(foo)) { ... }
Because WARN_ON_SMP() is defined as a do { } while (0) on UP,
it can not be used this way.
Convert it to the same form that WARN_ON() is, even when
CONFIG_SMP is off.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Darren Hart <dvhart@linux.intel.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <20110317192208.444147791@goodmis.org>
When we set up the flow informations in ip_route_newports(), we take
the address informations from the the rt_key_src and rt_key_dst fields
of the rtable. They appear to be empty. So take the address
informations from rt_src and rt_dst instead. This issue was introduced
by commit 5e2b61f78411be25f0b84f97d5b5d312f184dfd1 ("ipv4: Remove
flowi from struct rtable.")
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
All that remains of the inode_lock is protecting the inode hash list
manipulation and traversals. Rename the inode_lock to
inode_hash_lock to reflect it's actual function.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Protect the inode writeback list with a new global lock
inode_wb_list_lock and use it to protect the list manipulations and
traversals. This lock replaces the inode_lock as the inodes on the
list can be validity checked while holding the inode->i_lock and
hence the inode_lock is no longer needed to protect the list.
Protect inode state transitions and validity checks with the
inode->i_lock. This enables us to make inode state transitions
independently of the inode_lock and is the first step to peeling
away the inode_lock from the code.
This requires that __iget() is done atomically with i_state checks
during list traversals so that we don't race with another thread
marking the inode I_FREEING between the state check and grabbing the
reference.
Also remove the unlock_new_inode() memory barrier optimisation
required to avoid taking the inode_lock when clearing I_NEW.
Simplify the code by simply taking the inode->i_lock around the
state change and wakeup. Because the wakeup is no longer tricky,
remove the wake_up_inode() function and open code the wakeup where
necessary.
Move the scope value out of the fib alias entries and into fib_info,
so that we always use the correct scope when recomputing the nexthop
cached source address.
Reported-by: Julian Anastasov <ja@ssi.bg>
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: David Rientjes <rientjes@google.com>
Any operation that:
1) Brings up an interface
2) Adds an IP address to an interface
3) Deletes an IP address from an interface
can potentially invalidate the nh_saddr value, requiring
it to be recomputed.
Perform the recomputation lazily using a generation ID.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/vblank: update recently added vbl interface to be more future proof.
drm radeon: Return -EINVAL on wrong pm sysfs access
drm/radeon/kms: fix hardcoded EDID handling
Revert "drm/i915: Don't save/restore hardware status page address register"
drm/i915: Avoid unmapping pages from a NULL address space
drm/i915: Fix use after free within tracepoint
drm/i915: Restore missing command flush before interrupt on BLT ring
drm/i915: Disable pagefaults along execbuffer relocation fast path
drm/i915: Fix computation of pitch for dumb bo creator
drm/i915: report correct render clock frequencies on SNB
drm/i915/dp: Correct the order of deletion for ghost eDP devices
drm/i915: Fix tiling corruption from pipelined fencing
drm/i915: Re-enable self-refresh
drm/i915: Prevent racy removal of request from client list
drm/i915: skip redundant operations whilst enabling pipes and planes
drm/i915: Remove surplus POSTING_READs before wait_for_vblank
drm/radeon/kms: prefer legacy pll algo for tv-out
drm: check for modesetting on modeset ioctls
drm/kernel: vblank wait on crtc > 1
drm: Fix use-after-free in drm_gem_vm_close()
changes LAYOUTGET and GETDEVICEINFO XDR parsing to:
- not use vmap, which doesn't work on incoherent archs
- use xdr_stream parsing for all xdr
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
When sec=<something> is not presented as a mount option,
we should attempt to determine what security flavor the
server is using.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
A submount may use different security than the parent
mount does. We should figure out what sec flavor the
submount uses at mount time.
This patch adds the nfs4 operation secinfo as a
valid nfs rpc operation.
A later patch will need to perform a lookup using an
alternate client with a different security flavor.
This patch adds support for doing that on NFS v4.
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300:
MN10300: gcc 4.6 vs am33 inline assembly
MN10300: Deprecate gdbstub
MN10300: Allow KGDB to use the MN10300 serial ports
MN10300: Emulate single stepping in KGDB on MN10300
MN10300: Generalise kernel debugger kernel halt, reboot or power off hook
KGDB: Notify GDB of machine halt, reboot or power off
MN10300: Use KGDB
MN10300: Create generic kernel debugger hooks
MN10300: Create general kernel debugger cache flushing
MN10300: Introduce a general config option for kernel debugger hooks
MN10300: The icache invalidate functions should disable the icache first
MN10300: gdbstub: Restrict single-stepping to non-preemptable non-SMP configs
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'rmobile-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
mmc: Add MMC_PROGRESS_*
mmc, ARM: Rename SuperH Mobile ARM zboot helpers
ARM: mach-shmobile: add coherent DMA mask to CEU camera devices
ARM: mach-shmobile: Dynamic backlight control for Mackerel
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits)
[media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t
[media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly
[media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE
[media] v4l: soc-camera: Store negotiated buffer settings
[media] rc: interim support for 32-bit NEC-ish scancodes
[media] mceusb: topseed 0x0011 needs gen3 init for tx to work
[media] lirc_zilog: error out if buffer read bytes != chunk size
[media] lirc: silence some compile warnings
[media] hdpvr: use same polling interval as other OS
[media] ir-kbd-i2c: pass device code w/key in hauppauge case
[media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap
[media] remove the old RC_MAP_HAUPPAUGE_NEW RC map
[media] rc/keymaps: Rename Hauppauge table as rc-hauppauge
[media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping
[media] rc-rc5-hauppauge-new: Add support for the old Black RC
[media] rc-rc5-hauppauge-new: Add the old control to the table
[media] rc-winfast: Fix the keycode tables
[media] a800: Fix a few wrong IR key assignments
[media] opera1: Use multimedia keys instead of an app-specific mapping
[media] dw2102: Use multimedia keys instead of an app-specific mapping
Fix up trivial conflicts (remove/modify and some real conflicts) in:
arch/arm/mach-omap2/devices.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/dabusb/dabusb.c
drivers/staging/dabusb/dabusb.h
drivers/staging/easycap/easycap_ioctl.c
drivers/staging/usbvideo/usbvideo.c
drivers/staging/usbvideo/vicam.c
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6:
spi/pl022: Add loopback support for the SPI on 5500
spi/omap_mcspi: Fix broken last word xfer
of/flattree: minor cleanups
dt: eliminate OF_NO_DEEP_PROBE and test for NULL match table
dt: protect against NULL matches passed to of_match_node()
dt: Refactor of_platform_bus_probe()
This is my second attempt to make this enum generally available.
The first attempt added MMCIF_PROGRESS_* to include/linux/mmc/sh_mmcif.h.
However this is not sufficiently generic as the enum will be
used by SDHI boot code.
Signed-off-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (42 commits)
ACPI: minor printk format change in acpi_pad
ACPI: make acpi_pad /sys output more readable
ACPICA: Update version to 20110316
ACPICA: Header support for SLIC table
ACPI: Make sure the FADT is at least rev 2 before using the reset register
ACPI: Bug compatibility for Windows on the ACPI reboot vector
ACPICA: Fix access width for reset vector
ACPI battery: fribble sysfs files from a resume notifier
ACPI button: remove unused procfs I/F
ACPI, APEI, Add PCIe AER error information printing support
PCIe, AER, use pre-generated prefix in error information printing
ACPI, APEI, Add ERST record ID cache
ACPI: Use syscore_ops instead of sysdev class and sysdev
ACPI: Remove the unused EC sysdev class
ACPI: use __cpuinit for the acpi_processor_set_pdc() call tree
ACPI: use __init where possible in processor driver
Thermal_Framework-Fix_crash_during_hwmon_unregister
ACPICA: Update version to 20110211.
ACPICA: Add mechanism to defer _REG methods for some installed handlers
ACPICA: Add support for FunctionalFixedHW in acpi_ut_get_region_name
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (90 commits)
mfd: Push byte swaps out of wm8994 bulk read path
mfd: Rename ab8500 gpadc header
mfd: Constify WM8994 write path
mfd: Push byte swap out of WM8994 bulk I/O
mfd: Avoid copying data in WM8994 I2C write
mfd: Remove copy from WM831x I2C write function
mfd: Staticise WM8994 PM ops
regulator: Add a subdriver for TI TPS6105x regulator portions v2
mfd: Add a core driver for TI TPS61050/TPS61052 chips v2
gpio: Add Tunnel Creek support to sch_gpio
mfd: Add Tunnel Creek support to lpc_sch
pci_ids: Add Intel Tunnel Creek LPC Bridge device ID.
regulator: MAX8997/8966 support
mfd: Add WM8994 bulk register write operation
mfd: Append additional read write on 88pm860x
mfd: Adopt mfd_data in 88pm860x input driver
mfd: Adopt mfd_data in 88pm860x regulator
mfd: Adopt mfd_data in 88pm860x led
mfd: Adopt mfd_data in 88pm860x backlight
mfd: Fix MAX8997 Kconfig entry typos
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: (140 commits)
MAINTAINERS: de-orphan fbdev.
MAINTAINERS: Add file pattern for fb dt bindings.
video: Move sm501fb devicetree binding documentation to a better place.
fbcon: fix situation where fbcon gets deinitialised and can't reinit.
video, sm501: add OF binding to support SM501
video, sm501: add edid and commandline support
video, sm501: add I/O functions for use on powerpc
video: Fix EDID macros H_SYNC_WIDTH and H_SYNC_OFFSET
fbcon: Bugfix soft cursor detection in Tile Blitting
video: add missing framebuffer_release in error path
video: metronomefb: add __devexit_p around reference to metronomefb_remove
video: hecubafb: add __devexit_p around reference to hecubafb_remove
drivers:video:aty:radeon_base Fix typo occationally to occasionally
atmel_lcdfb: add fb_blank function
atmel_lcdfb: implement inverted contrast pwm
video: s3c-fb: return proper error if clk_get fails
uvesafb,vesafb: create WC or WB PAT-entries
video: ffb: fix ffb_probe error path
radeonfb: Let hwmon driver probe the "monid" I2C bus
fbdev: sh_mobile_lcdc: checking NULL instead of IS_ERR()
Add DM_SECURE_DATA_FLAG which userspace can use to ensure
that all buffers allocated for dm-ioctl are wiped
immediately after use.
The user buffer is wiped as well (we do not want to keep
and return sensitive data back to userspace if the flag is set).
Wiping is useful for cryptsetup to ensure that the key
is present in memory only in defined places and only
for the time needed.
(For crypt, key can be present in table during load or table
status, wait and message commands).
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
This makes the interface a bit cleaner by leaving a single gap in the
vblank bit space instead of creating two gaps.
Suggestions from Michel on mailing list/irc.
Reviewed-by: Michel Dänzer <michel@daenzer.net>
The %pB format specifier is for stack backtrace. Its handler
sprint_backtrace() does symbol lookup using (address-1) to
ensure the address will not point outside of the function.
If there is a tail-call to the function marked "noreturn",
gcc optimized out the code after the call then causes saved
return address points outside of the function (i.e. the start
of the next function), so pollutes call trace somewhat.
This patch adds the %pB printk mechanism that allows architecture
call-trace printout functions to improve backtrace printouts.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1300934550-21394-1-git-send-email-namhyung@gmail.com>
commit fd245a4adb52 (net_sched: move TCQ_F_THROTTLED flag)
added a race.
qdisc_watchdog() is run from softirq, so special care should be taken or
we can lose one state transition (THROTTLED/RUNNING)
Prior to fd245a4adb52, we were manipulating q->flags (qdisc->flags &=
~TCQ_F_THROTTLED;) and this manipulation could only race with
qdisc_warn_nonwc().
Since we want to avoid atomic ops in qdisc fast path - it was the
meaning of commit 371121057607e (QDISC_STATE_RUNNING dont need atomic
bit ops) - fix is to move THROTTLE bit into 'state' field, this one
being manipulated with SMP and IRQ safe operations.
deal with races in /proc/*/{syscall,stack,personality}
proc: enable writing to /proc/pid/mem
proc: make check_mem_permission() return an mm_struct on success
proc: hold cred_guard_mutex in check_mem_permission()
proc: disable mem_write after exec
mm: implement access_remote_vm
mm: factor out main logic of access_process_vm
mm: use mm_struct to resolve gate vma's in __get_user_pages
mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm
mm: arch: make in_gate_area take an mm_struct instead of a task_struct
mm: arch: make get_gate_vma take an mm_struct instead of a task_struct
x86: mark associated mm when running a task in 32 bit compatibility mode
x86: add context tag to mark mm when running a task in 32-bit compatibility mode
auxv: require the target to be tracable (or yourself)
close race in /proc/*/environ
report errors in /proc/*/*map* sanely
pagemap: close races with suid execve
make sessionid permissions in /proc/*/task/* match those in /proc/*
fix leaks in path_lookupat()
Fix up trivial conflicts in fs/proc/base.c
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (35 commits)
ARM: Update (and cut down) mach-types
ARM: 6771/1: vexpress: add support for multiple core tiles
ARM: 6797/1: hw_breakpoint: Fix newlines in WARNings
ARM: 6751/1: vexpress: select applicable errata workarounds in Kconfig
ARM: 6753/1: omap4: Enable ARM local timers with OMAP4430 es1.0 exception
ARM: 6759/1: smp: Select local timers vs broadcast timer support runtime
ARM: pgtable: add pud-level code
ARM: 6673/1: LPAE: use phys_addr_t instead of unsigned long for start of membanks
ARM: Use long long format when printing meminfo physical addresses
ARM: integrator: add Integrator/CP sched_clock support
ARM: realview/vexpress: consolidate SMP bringup code
ARM: realview/vexpress: consolidate localtimer support
ARM: integrator/versatile: consolidate FPGA IRQ handling code
ARM: rationalize versatile family Kconfig/Makefile
ARM: realview: remove old AMBA device DMA definitions
ARM: versatile: remove old AMBA device DMA definitions
ARM: vexpress: use new init_early for clock tree and sched_clock init
ARM: realview: use new init_early for clock tree and sched_clock init
ARM: versatile: use new init_early for clock tree and sched_clock init
ARM: integrator: use new init_early for clock tree init
setup_elfcorehdr and saved_max_pfn
The Xen PV drivers in a crashed HVM guest can not connect to the dom0
backend drivers because both frontend and backend drivers are still in
connected state. To run the connection reset function only in case of a
crashdump, the is_kdump_kernel() function needs to be available for the PV
driver modules.
Consolidate elfcorehdr_addr, setup_elfcorehdr and saved_max_pfn into
kernel/crash_dump.c Also export elfcorehdr_addr to make is_kdump_kernel()
usable for modules.
Leave 'elfcorehdr' as early_param(). This changes powerpc from __setup()
to early_param(). It adds an address range check from x86 also on ia64
and powerpc.
[akpm@linux-foundation.org: additional #includes]
[akpm@linux-foundation.org: remove elfcorehdr_addr export]
[akpm@linux-foundation.org: fix for Tejun's mm/nobootmem.c changes]
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cheat for now and say all files belong to init_user_ns. Next step will be
to let superblocks belong to a user_ns, and derive inode_userns(inode)
from inode->i_sb->s_user_ns. Finally we'll introduce more flexible
arrangements.
Changelog:
Feb 15: make is_owner_or_cap take const struct inode
Feb 23: make is_owner_or_cap bool
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(),
because the resource comes from current's own ipc namespace.
setuid/setgid are to uids in own namespace, so again checks can be against
current_user_ns().
Changelog:
Jan 11: Use task_ns_capable() in place of sched_capable().
Jan 11: Use nsown_capable() as suggested by Bastian Blank.
Jan 11: Clarify (hopefully) some logic in futex and sched.c
Feb 15: use ns_capable for ipc, not nsown_capable
Feb 23: let copy_ipcs handle setting ipc_ns->user_ns
Feb 23: pass ns down rather than taking it from current
