path: root/include
2013-03-17perf,x86: fix link failure for non-Intel configsDavid Rientjes
Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after suspend/resume") introduces a link failure since perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL: arch/x86/power/built-in.o: In function `restore_processor_state': (.text+0x45c): undefined reference to `perf_restore_debug_store' Fix it by defining the dummy function appropriately. Signed-off-by: David Rientjes <rientjes@google.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-15Merge tag 'for-3.9-rc3' of git://openrisc.net/jonas/linuxLinus Torvalds
Pull OpenRISC bug fixes from Jonas Bonn: - The GPIO descriptor work has exposed how broken the non-GPIOLIB bits for OpenRISC were. We now require GPIOLIB as this is the preferred way forward. - The system.h split introduced a bug in llist.h for arches using asm-generic/cmpxchg.h directly, which is currently only OpenRISC. The patch here moves two defines from asm-generic/atomic.h to asm-generic/cmpxchg.h to make things work as they should. - The VIRT_TO_BUS selector was added for OpenRISC, but OpenRISC does not have the virt_to_bus methods, so there's a patch to remove it again. * tag 'for-3.9-rc3' of git://openrisc.net/jonas/linux: openrisc: remove HAVE_VIRT_TO_BUS asm-generic: move cmpxchg*_local defs to cmpxchg.h openrisc: require gpiolib
2013-03-15Merge tag 'mfd-fixes-3.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes Pull MFD fixes from Samuel Ortiz: "This is the first batch of MFD fixes for 3.9. With this one we have: - An ab8500 build failure fix. - An ab8500 device tree parsing fix. - A fix for twl4030_madc remove routine to work properly (when built-in). - A fix for properly registering palmas interrupt handler. - A fix for omap-usb init routine to actually write into the hostconfig register. - A couple of warning fixes for ab8500-gpadc and tps65912" * tag 'mfd-fixes-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes: mfd: twl4030-madc: Remove __exit_p annotation mfd: ab8500: Kill "reg" property from binding mfd: ab8500-gpadc: Complain if we fail to enable vtvout LDO mfd: wm831x: Don't forward declare enum wm831x_auxadc mfd: twl4030-audio: Fix argument type for twl4030_audio_disable_resource() mfd: tps65912: Declare and use tps65912_irq_exit() mfd: palmas: Provide irq flags through DT/platform data mfd: Make AB8500_CORE select POWER_SUPPLY to fix build error mfd: omap-usb-host: Actually update hostconfig
2013-03-15perf,x86: fix kernel crash with PEBS/BTS after suspend/resumeStephane Eranian
This patch fixes a kernel crash when using precise sampling (PEBS) after a suspend/resume. Turns out the CPU notifier code is not invoked on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly by the kernel and keeps it power-on/resume value of 0 causing any PEBS measurement to crash when running on CPU0. The workaround is to add a hook in the actual resume code to restore the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0, the DS_AREA will be restored twice but this is harmless. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-14Merge branch 'rcu/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu Pull fix for hlist_entry_safe() regression from Paul McKenney: "This contains a single commit that fixes a regression in hlist_entry_safe(). This macro references its argument twice, which can cause NULL-pointer errors. This commit applies a gcc statement expression, creating a temporary variable to avoid the double reference. This has been posted to LKML at https://lkml.org/lkml/2013/3/9/75. Kudos to CAI Qian, whose testing uncovered this, to Eric Dumazet, who spotted root cause, and to Li Zefan, who tested this commit." * 'rcu/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu: list: Fix double fetch of pointer in hlist_entry_safe()
2013-03-14list: Fix double fetch of pointer in hlist_entry_safe()Paul E. McKenney
The current version of hlist_entry_safe() fetches the pointer twice, once to test for NULL and the other to compute the offset back to the enclosing structure. This is OK for normal lock-based use because in that case, the pointer cannot change. However, when the pointer is protected by RCU (as in "rcu_dereference(p)"), then the pointer can change at any time. This use case can result in the following sequence of events: 1. CPU 0 invokes hlist_entry_safe(), fetches the RCU-protected pointer as sees that it is non-NULL. 2. CPU 1 invokes hlist_del_rcu(), deleting the entry that CPU 0 just fetched a pointer to. Because this is the last entry in the list, the pointer fetched by CPU 0 is now NULL. 3. CPU 0 refetches the pointer, obtains NULL, and then gets a NULL-pointer crash. This commit therefore applies gcc's "({ })" statement expression to create a temporary variable so that the specified pointer is fetched only once, avoiding the above sequence of events. Please note that it is the caller's responsibility to use rcu_dereference() as needed. This allows RCU-protected uses to work correctly without imposing any additional overhead on the non-RCU case. Many thanks to Eric Dumazet for spotting root cause! Reported-by: CAI Qian <caiqian@redhat.com> Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Li Zefan <lizefan@huawei.com>
2013-03-13Merge branch 'akpm' (fixes from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: - A bunch of fixes - Finish off the idr API conversions before someone starts to use the old interfaces again. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: idr: idr_alloc() shouldn't trigger lowmem warning when preloaded UAPI: fix endianness conditionals in M32R's asm/stat.h UAPI: fix endianness conditionals in linux/raid/md_p.h UAPI: fix endianness conditionals in linux/acct.h UAPI: fix endianness conditionals in linux/aio_abi.h decompressors: fix typo "POWERPC" mm/fremap.c: fix oops on error path idr: deprecate idr_pre_get() and idr_get_new[_above]() tidspbridge: convert to idr_alloc() zcache: convert to idr_alloc() mlx4: remove leftover idr_pre_get() call workqueue: convert to idr_alloc() nfsd: convert to idr_alloc() nfsd: remove unused get_new_stid() kernel/signal.c: use __ARCH_HAS_SA_RESTORER instead of SA_RESTORER signal: always clear sa_restorer on execve mm: remove_memory(): fix end_pfn setting include/linux/res_counter.h needs errno.h
2013-03-13UAPI: fix endianness conditionals in linux/raid/md_p.hDavid Howells
In the UAPI header files, __BIG_ENDIAN and __LITTLE_ENDIAN must be compared against __BYTE_ORDER in preprocessor conditionals where these are exposed to userspace (that is they're not inside __KERNEL__ conditionals). However, in the main kernel the norm is to check for "defined(__XXX_ENDIAN)" rather than comparing against __BYTE_ORDER and this has incorrectly leaked into the userspace headers. The definition of struct mdp_superblock_s in linux/raid/md_p.h is wrong in this way. Note that userspace will likely interpret the ordering of the fields incorrectly as the big-endian variant on a little-endian machines - depending on header inclusion order. [!!!] NOTE [!!!] This patch may adversely change the userspace API. It might be better to fix the ordering of events_hi, events_lo, cp_events_hi and cp_events_lo in struct mdp_superblock_s / typedef mdp_super_t. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13UAPI: fix endianness conditionals in linux/acct.hDavid Howells
In the UAPI header files, __BIG_ENDIAN and __LITTLE_ENDIAN must be compared against __BYTE_ORDER in preprocessor conditionals where these are exposed to userspace (that is they're not inside __KERNEL__ conditionals). However, in the main kernel the norm is to check for "defined(__XXX_ENDIAN)" rather than comparing against __BYTE_ORDER and this has incorrectly leaked into the userspace headers. The definition of ACCT_BYTEORDER in linux/acct.h is wrong in this way. Note that userspace will likely interpret this incorrectly as the big-endian variant on little-endian machines - depending on header inclusion order. [!!!] NOTE [!!!] This patch may adversely change the userspace API. It might be better to fix the value of ACCT_BYTEORDER. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13UAPI: fix endianness conditionals in linux/aio_abi.hDavid Howells
In the UAPI header files, __BIG_ENDIAN and __LITTLE_ENDIAN must be compared against __BYTE_ORDER in preprocessor conditionals where these are exposed to userspace (that is they're not inside __KERNEL__ conditionals). However, in the main kernel the norm is to check for "defined(__XXX_ENDIAN)" rather than comparing against __BYTE_ORDER and this has incorrectly leaked into the userspace headers. The definition of PADDED() in linux/aio_abi.h is wrong in this way. Note that userspace will likely interpret this and thus the order of fields in struct iocb incorrectly as the little-endian variant on big-endian machines - depending on header inclusion order. [!!!] NOTE [!!!] This patch may adversely change the userspace API. It might be better to fix the ordering of aio_key and aio_reserved1 in struct iocb. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13idr: deprecate idr_pre_get() and idr_get_new[_above]()Tejun Heo
Now that all in-kernel users are converted to ues the new alloc interface, mark the old interface deprecated. We should be able to remove these in a few releases. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13include/linux/res_counter.h needs errno.hAndrew Morton
alpha allmodconfig: In file included from mm/memcontrol.c:28: include/linux/res_counter.h: In function 'res_counter_set_limit': include/linux/res_counter.h:203: error: 'EBUSY' undeclared (first use in this function) include/linux/res_counter.h:203: error: (Each undeclared identifier is reported only once include/linux/res_counter.h:203: error: for each function it appears in.) Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: Frederic Weisbecker <fweisbec@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13Merge tag 'usb-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg Kroah-Hartman: "Here are a number of tiny USB fixes and new USB device ids for your 3.9 tree. The "largest" one here is a revert of a usb-storage patch that turned out to be incorrect, breaking existing users, which is never a good thing. Everything else is pretty simple and small" * tag 'usb-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (43 commits) USB: quatech2: only write to the tty if the port is open. qcserial: bind to DM/DIAG port on Gobi 1K devices USB: cdc-wdm: fix buffer overflow usb: serial: Add Rigblaster Advantage to device table qcaux: add Franklin U600 usb: musb: core: fix possible build error with randconfig usb: cp210x new Vendor/Device IDs usb: gadget: pxa25x: fix disconnect reporting usb: dwc3: ep0: fix sparc64 build usb: c67x00 RetryCnt value in c67x00 TD should be 3 usb: Correction to c67x00 TD data length mask usb: Makefile: fix drivers/usb/phy/ Makefile entry USB: added support for Cinterion's products AH6 and PLS8 usb: gadget: fix omap_udc build errors USB: storage: fix Huawei mode switching regression USB: storage: in-kernel modeswitching is deprecated tools: usb: ffs-test: Fix build failure USB: option: add Huawei E5331 usb: musb: omap2430: fix sparse warning usb: musb: omap2430: fix omap_musb_mailbox glue check again ...
2013-03-13Merge tag 'tty-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg Kroah-Hartman: "Here are some tty/serial driver fixes for 3.9 We finally mute the annoying WARN_ON that lots of people are hitting and it turns out isn't needed anymore. Also add a few new device ids and a some other minor fixes." * tag 'tty-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: serial: fix typo "SERIAL_S3C2412" serial: 8250: Keep 8250.<xxxx> module options functional after driver rename tty: serial: fix typo "ARCH_S5P6450" tty/8250_pnp: serial port detection regression since v3.7 serial: bcm63xx_uart: fix compilation after "TTY: switch tty_insert_flip_char" serial: 8250_pci: add support for another kind of NetMos Technology PCI 9835 Multi-I/O Controller Fix 4 port and add support for 8 port 'Unknown' PCI serial port cards tty/serial: Add support for Altera serial port tty: serial: vt8500: Unneccessary duplicated clock code removed tty: serial: mpc5xxx: fix PSC clock name bug TTY: disable debugging warning
2013-03-13Merge tag 'staging-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree fixes from Greg Kroah-Hartman: "Here are some drivers/staging and drivers/iio fixes for 3.9 (the two are still pretty intertwined, hence them coming both from my tree still.) Nothing major, just a few things that have been reported by users, all of these have been in linux-next for a while." * tag 'staging-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: comedi: dt9812: use CR_CHAN() for channel number staging/vt6656: Fix too large integer constant warning on 32-bit staging: comedi: drivers: usbduxsigma.c: fix DMA buffers on stack staging: imx/drm: request irq only after adding the crtc staging: comedi: drivers: usbduxfast.c: fix for DMA buffers on stack staging: comedi: drivers: usbdux.c: fix DMA buffers on stack staging: vt6656: Fix oops on resume from suspend. iio:common:st_sensors fixed all warning messages about uninitialized variables iio: Fix build error seen if IIO_TRIGGER is defined but IIO_BUFFER is not iio/imu: inv_mpu6050 depends on IIO_BUFFER iio:ad5064: Initialize register cache correctly iio:ad5064: Fix off by one in DAC value range check iio:ad5064: Fix address of the second channel for ad5065/ad5045/ad5025
2013-03-13asm-generic: move cmpxchg*_local defs to cmpxchg.hJonas Bonn
asm/cmpxchg.h can be included on its own and needs to be self-consistent. The definitions for the cmpxchg*_local macros, as such, need to be part of this file. This fixes a build issue on OpenRISC since the system.h smashing patch 96f951edb1f1bdbbc99b0cd458f9808bb83d58ae that introdued the direct inclusion asm/cmpxchg.h into linux/llist.h. CC: David Howells <dhowells@redhat.com> Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-03-12idr: fix new kernel-doc warningsRandy Dunlap
Fix new kernel-doc warnings in idr: Warning(include/linux/idr.h:113): No description found for parameter 'idr' Warning(include/linux/idr.h:113): Excess function parameter 'idp' description in 'idr_find' Warning(lib/idr.c:232): Excess function parameter 'id' description in 'sub_alloc' Warning(lib/idr.c:232): Excess function parameter 'id' description in 'sub_alloc' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-12Merge tag 'stable/for-linus-3.9-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen fixes from Konrad Rzeszutek Wilk: - Compile warnings and errors (one on x86, two on ARM) - WARNING in xen-pciback - Use the acpi_processor_get_performance_info instead of the 'register' version * tag 'stable/for-linus-3.9-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/acpi: remove redundant acpi/acpi_drivers.h include xen: arm: mandate EABI and use generic atomic operations. acpi: Export the acpi_processor_get_performance_info xen/pciback: Don't disable a PCI device that is already disabled.
2013-03-12tty/serial: Add support for Altera serial portLey Foon Tan
Add support for Altera 8250/16550 compatible serial port. Signed-off-by: Ley Foon Tan <lftan@altera.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12mfd: wm831x: Don't forward declare enum wm831x_auxadcMark Brown
We can't forward declare enums. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-03-12mfd: tps65912: Declare and use tps65912_irq_exit()Mark Brown
Clean up interrupts on exit, silencing a sparse warning caused by tps65912_irq_exit() being defined but not prototyped as we go. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-03-12mfd: palmas: Provide irq flags through DT/platform dataLaxman Dewangan
Currently driver sets the irq type to IRQF_TRIGGER_LOW which is causing interrupt registration failure in ARM based SoCs as: [ 0.208479] genirq: Setting trigger mode 8 for irq 118 failed (gic_set_type+0x0/0xf0) [ 0.208513] dummy 0-0059: Failed to request IRQ 118: -22 Provide the irq flags through platform data if device is registered through board file or get the irq type from DT node property in place of hardcoding the irq flag in driver to support multiple platforms. Also configure the device to generate the interrupt signal according to flag type. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-03-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull namespace bugfixes from Eric Biederman: "This is three simple fixes against 3.9-rc1. I have tested each of these fixes and verified they work correctly. The userns oops in key_change_session_keyring and the BUG_ON triggered by proc_ns_follow_link were found by Dave Jones. I am including the enhancement for mount to only trigger requests of filesystem modules here instead of delaying this for the 3.10 merge window because it is both trivial and the kind of change that tends to bit-rot if left untouched for two months." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: proc: Use nd_jump_link in proc_ns_follow_link fs: Limit sys_mount to only request filesystem modules (Part 2). fs: Limit sys_mount to only request filesystem modules. userns: Stop oopsing in key_change_session_keyring
2013-03-08Input: atmel_mxt_ts - Support for touchpad variantDaniel Kurtz
This same driver can be used by atmel based touchscreens and touchpads (buttonpads). Platform data may specify a device is a touchpad using the is_tp flag. This will cause the driver to perform some touchpad specific initializations, such as: * register input device name "Atmel maXTouch Touchpad" instead of Touchscreen. * register BTN_LEFT & BTN_TOOL_* event types. * register axis resolution (as a fixed constant, for now) * register BUTTONPAD property * process GPIO buttons using reportid T19 Input event GPIO mapping is done by the platform data key_map array. key_map[x] should contain the KEY or BTN code to send when processing GPIOx from T19. To specify a GPIO as not an input source, populate with KEY_RESERVED, or 0. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Benson Leung <bleung@chromium.org> Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-07Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Misc radeon, nouveau, mgag200 and intel fixes. The intel fixes should contain the fix for the touchpad on the Chromebook - hey I'm an input maintainer now!" Hate to pee on your parade, Dave, but I don't think being an input maintainer is necessarily something to strive for.. * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (25 commits) drm/tegra: drop "select DRM_HDMI" drm: Documentation typo fixes drm/mgag200: Bug fix: Renesas board now selects native resolution. drm/mgag200: Reject modes that are too big for VRAM drm/mgag200: 'fbdev_list' in 'struct mga_fbdev' is not used drm/radeon: don't check mipmap alignment if MIP_ADDRESS is FMASK drm/radeon: skip MC reset as it's probably not hung drm/radeon: add primary dac adj quirk for R200 board drm/radeon: don't set hpd, afmt interrupts when interrupts are disabled drm/i915: Turn off hsync and vsync on ADPA when disabling crt drm/i915: Fix incorrect definition of ADPA HSYNC and VSYNC bits drm/i915: also disable south interrupts when handling them drm/i915: enable irqs earlier when resuming drm/i915: Increase the RC6p threshold. DRM/i915: On G45 enable cursor plane briefly after enabling the display plane. drm/nv50-: prevent some races between modesetting and page flipping drm/nouveau/i2c: drop parent refcount when creating ports drm/nv84: fix regression in page flipping drm/nouveau: Fix typo in init_idx_addr_latched(). drm/nouveau: Disable AGP on PowerPC again. ...
2013-03-07Merge tag 'pm+acpi-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael J Wysocki: - Two fixes for the new intel_pstate driver from Dirk Brandewie. - Fix for incorrect usage of the .find_bridge() callback from struct acpi_bus_type in the USB core and subsequent removal of that callback from Rafael J Wysocki. - ACPI processor driver cleanups from Chen Gang and Syam Sidhardhan. - ACPI initialization and error messages fix from Joe Perches. - Operating Performance Points documentation improvement from Nishanth Menon. - Fixes for memory leaks and potential concurrency issues and sysfs attributes leaks during device removal in the core device PM QoS code from Rafael J Wysocki. - Calxeda Highbank cpufreq driver simplification from Emilio López. - cpufreq comment cleanup from Namhyung Kim. - Fix for a section mismatch in Calxeda Highbank interprocessor communication code from Mark Langsdorf (this is not a PM fix strictly speaking, but the code in question went in through the PM tree). * tag 'pm+acpi-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq / intel_pstate: Do not load on VM that does not report max P state. cpufreq / intel_pstate: Fix intel_pstate_init() error path ACPI / glue: Drop .find_bridge() callback from struct acpi_bus_type ACPI / glue: Add .match() callback to struct acpi_bus_type ACPI / porocessor: Beautify code, pr->id is u32 which is never < 0 ACPI / processor: Remove redundant NULL check before kfree ACPI / Sleep: Avoid interleaved message on errors PM / QoS: Remove device PM QoS sysfs attributes at the right place PM / QoS: Fix concurrency issues and memory leaks in device PM QoS cpufreq: highbank: do not initialize array with a loop PM / OPP: improve introductory documentation cpufreq: Fix a typo in comment mailbox, pl320-ipc: remove __init from probe function
2013-03-08drm: Documentation typo fixesChristopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-03-07Merge tag 'regulator-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "A few small things here and there, nothing major here really. The conversion of twl4030ldo_ops to get_voltage_sel is a fix, as covered in the commit log it fixes inconsistency in handling of the IS_UNSUP() feature in the driver." * tag 'regulator-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: fixed regulator_bulk_enable unwinding code regulator: twl: Convert twl4030ldo_ops to get_voltage_sel regulator: palmas: fix number of SMPS voltages regulator: core: fix documentation error in regulator_allow_bypass regulator: core: update kernel documentation for regulator_desc regulator: db8500-prcmu - remove incorrect __exit markup
2013-03-07Merge tag 'ecryptfs-3.9-rc2-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: "Minor code cleanups and new Kconfig option to disable /dev/ecryptfs The code cleanups fix up W=1 compiler warnings and some unnecessary checks. The new Kconfig option, defaulting to N, allows the rarely used eCryptfs kernel to userspace communication channel to be compiled out. This may be the first step in it being eventually removed." Hmm. I'm not sure whether these should be called "fixes", and it probably should have gone in the merge window. But I'll let it slide. * tag 'ecryptfs-3.9-rc2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: allow userspace messaging to be disabled eCryptfs: Fix redundant error check on ecryptfs_find_daemon_by_euid() ecryptfs: ecryptfs_msg_ctx_alloc_to_free(): remove kfree() redundant null check eCryptfs: decrypt_pki_encrypted_session_key(): remove kfree() redundant null check eCryptfs: remove unneeded checks in virt_to_scatterlist() eCryptfs: Fix -Wmissing-prototypes warnings eCryptfs: Fix -Wunused-but-set-variable warnings eCryptfs: initialize payload_len in keystore.c
2013-03-06acpi: Export the acpi_processor_get_performance_infoKonrad Rzeszutek Wilk
The git commit d5aaffa9dd531c978c6f3fea06a2972653bd7fc8 (cpufreq: handle cpufreq being disabled for all exported function) tightens the cpufreq API by returning errors when disable_cpufreq() had been called. The problem we are hitting is that the module xen-acpi-processor which uses the ACPI's functions: acpi_processor_register_performance, acpi_processor_preregister_performance, and acpi_processor_notify_smm fails at acpi_processor_register_performance with -22. Note that earlier during bootup in arch/x86/xen/setup.c there is also an call to cpufreq's API: disable_cpufreq(). This is b/c we want the Linux kernel to parse the ACPI data, but leave the cpufreq decisions to the hypervisor. In v3.9 all the checks that d5aaffa9dd531c978c6f3fea06a2972653bd7fc8 added are now hit and the calls to cpufreq_register_notifier will now fail. This means that acpi_processor_ppc_init ends up printing: "Warning: Processor Platform Limit not supported" and the acpi_processor_ppc_status is not set. The repercussions of that is that the call to acpi_processor_register_performance fails right away at: if (!(acpi_processor_ppc_status & PPC_REGISTERED)) and we don't progress any further on parsing and extracting the _P* objects. The only reason the Xen code called that function was b/c it was exported and the only way to gather the P-states. But we can also just make acpi_processor_get_performance_info be exported and not use acpi_processor_register_performance. This patch does so. Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A moderately sized pile of fixes, some specifically for merge window introduced regressions although others are for longer standing items and have been queued up for -stable. I'm kind of tired of all the RDS protocol bugs over the years, to be honest, it's way out of proportion to the number of people who actually use it. 1) Fix missing range initialization in netfilter IPSET, from Jozsef Kadlecsik. 2) ieee80211_local->tim_lock needs to use BH disabling, from Johannes Berg. 3) Fix DMA syncing in SFC driver, from Ben Hutchings. 4) Fix regression in BOND device MAC address setting, from Jiri Pirko. 5) Missing usb_free_urb in ISDN Hisax driver, from Marina Makienko. 6) Fix UDP checksumming in bnx2x driver for 57710 and 57711 chips, fix from Dmitry Kravkov. 7) Missing cfgspace_lock initialization in BCMA driver. 8) Validate parameter size for SCTP assoc stats getsockopt(), from Guenter Roeck. 9) Fix SCTP association hangs, from Lee A Roberts. 10) Fix jumbo frame handling in r8169, from Francois Romieu. 11) Fix phy_device memory leak, from Petr Malat. 12) Omit trailing FCS from frames received in BGMAC driver, from Hauke Mehrtens. 13) Missing socket refcount release in L2TP, from Guillaume Nault. 14) sctp_endpoint_init should respect passed in gfp_t, rather than use GFP_KERNEL unconditionally. From Dan Carpenter. 15) Add AISX AX88179 USB driver, from Freddy Xin. 16) Remove MAINTAINERS entries for drivers deleted during the merge window, from Cesar Eduardo Barros. 17) RDS protocol can try to allocate huge amounts of memory, check that the user's request length makes sense, from Cong Wang. 18) SCTP should use the provided KMALLOC_MAX_SIZE instead of it's own, bogus, definition. From Cong Wang. 19) Fix deadlocks in FEC driver by moving TX reclaim into NAPI poll, from Frank Li. Also, fix a build error introduced in the merge window. 20) Fix bogus purging of default routes in ipv6, from Lorenzo Colitti. 21) Don't double count RTT measurements when we leave the TCP receive fast path, from Neal Cardwell." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits) tcp: fix double-counted receiver RTT when leaving receiver fast path CAIF: fix sparse warning for caif_usb rds: simplify a warning message net: fec: fix build error in no MXC platform net: ipv6: Don't purge default router if accept_ra=2 net: fec: put tx to napi poll function to fix dead lock sctp: use KMALLOC_MAX_SIZE instead of its own MAX_KMALLOC_SIZE rds: limit the size allocated by rds_message_alloc() MAINTAINERS: remove eexpress MAINTAINERS: remove drivers/net/wan/cycx* MAINTAINERS: remove 3c505 caif_dev: fix sparse warnings for caif_flow_cb ax88179_178a: ASIX AX88179_178A USB 3.0/2.0 to gigabit ethernet adapter driver sctp: use the passed in gfp flags instead GFP_KERNEL ipv[4|6]: correct dropwatch false positive in local_deliver_finish l2tp: Restore socket refcount when sendmsg succeeds net/phy: micrel: Disable asymmetric pause for KSZ9021 bgmac: omit the fcs phy: Fix phy_device_free memory leak bnx2x: Fix KR2 work-around condition ...
2013-03-05Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes and cleanups from Thomas Gleixner: "Commit e5ab012c3271 ("nohz: Make tick_nohz_irq_exit() irq safe") is the first commit in the series and the minimal necessary bugfix, which needs to go back into stable. The remanining commits enforce irq disabling in irq_exit(), sanitize the hardirq/softirq preempt count transition and remove a bunch of no longer necessary conditionals." I personally love getting rid of the very subtle and confusing IRQ_EXIT_OFFSET thing. Even apart from the whole "more lines removed than added" thing. * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irq: Don't re-enable interrupts at the end of irq_exit irq: Remove IRQ_EXIT_OFFSET workaround Revert "nohz: Make tick_nohz_irq_exit() irq safe" irq: Sanitize invoke_softirq irq: Ensure irq_exit() code runs with interrupts disabled nohz: Make tick_nohz_irq_exit() irq safe
2013-03-05Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull smpboot bugfix from Thomas Gleixner: "A single bugfix for a regression introduced with the conversion of the stop machine threads to the generic smpboot thread management facility" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: stop_machine: Mark per cpu stopper enabled early
2013-03-06Merge tag 'iio-fixes-for-3.9a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: "First round of iio fixes post the 3.9 merge window. 1) Some little fixes for the ad5064 dac driver. 2) A build warning 'fix' for a false positive in st_sensors 3) A couple of missing dependencies on IIO_BUFFER. So nothing major and these mostly showed the advantages of the randconfig builds various people have performed."
2013-03-05usb: gadget: composite: fix kernel-doc warningsNishanth Menon
A few trivial fixes for composite driver: Warning(include/linux/usb/composite.h:165): No description found for parameter 'fs_descriptors' Warning(include/linux/usb/composite.h:165): Excess struct/union/enum/typedef member 'descriptors' description in 'usb_function' Warning(include/linux/usb/composite.h:321): No description found for parameter 'gadget_driver' Warning(drivers/usb/gadget/composite.c:1777): Excess function parameter 'bind' description in 'usb_composite_probe' Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-usb@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-03-05Merge remote-tracking branch 'regulator/fix/doc' into tmpMark Brown
2013-03-04ACPI / glue: Drop .find_bridge() callback from struct acpi_bus_typeRafael J. Wysocki
After PCI and USB have stopped using the .find_bridge() callback in struct acpi_bus_type, the only remaining user of it is SATA, but SATA only pretends to be a user, because it points that callback to a stub always returning -ENODEV. For this reason, drop the SATA's dummy .find_bridge() callback and remove .find_bridge(), which is not used any more, from struct acpi_bus_type entirely. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2013-03-04ACPI / glue: Add .match() callback to struct acpi_bus_typeRafael J. Wysocki
USB uses the .find_bridge() callback from struct acpi_bus_type incorrectly, because as a result of the way it is used by USB every device in the system that doesn't have a bus type or parent is passed to usb_acpi_find_device() for inspection. What USB actually needs, though, is to call usb_acpi_find_device() for USB ports that don't have a bus type defined, but have usb_port_device_type as their device type, as well as for USB devices. To fix that replace the struct bus_type pointer in struct acpi_bus_type used for matching devices to specific subsystems with a .match() callback to be used for this purpose and update the users of struct acpi_bus_type, including USB, accordingly. Define the .match() callback routine for USB, usb_acpi_bus_match(), in such a way that it will cover both USB devices and USB ports and remove the now redundant .find_bridge() callback pointer from usb_acpi_bus. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2013-03-03eCryptfs: allow userspace messaging to be disabledKees Cook
When the userspace messaging (for the less common case of userspace key wrap/unwrap via ecryptfsd) is not needed, allow eCryptfs to build with it removed. This saves on kernel code size and reduces potential attack surface by removing the /dev/ecryptfs node. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-03Merge tag 'disintegrate-fbdev-20121220' of ↵Linus Torvalds
git://git.infradead.org/users/dhowells/linux-headers Pull fbdev UAPI disintegration from David Howells: "You'll be glad to here that the end is nigh for the UAPI patches. Only the fbdev/framebuffer piece remains now that the SCSI stuff has gone in. Here are the UAPI disintegration bits for the fbdev drivers. It appears that Florian hasn't had time to deal with my patch, but back in December he did say he didn't mind if I pushed it forward." Yay. No more uapi movement. And hopefully no more big header file cleanups coming up either, it just tends to be very painful. * tag 'disintegrate-fbdev-20121220' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: (Scripted) Disintegrate include/video
2013-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more VFS bits from Al Viro: "Unfortunately, it looks like xattr series will have to wait until the next cycle ;-/ This pile contains 9p cleanups and fixes (races in v9fs_fid_add() etc), fixup for nommu breakage in shmem.c, several cleanups and a bit more file_inode() work" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: constify path_get/path_put and fs_struct.c stuff fix nommu breakage in shmem.c cache the value of file_inode() in struct file 9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry 9p: make sure ->lookup() adds fid to the right dentry 9p: untangle ->lookup() a bit 9p: double iput() in ->lookup() if d_materialise_unique() fails 9p: v9fs_fid_add() can't fail now v9fs: get rid of v9fs_dentry 9p: turn fid->dlist into hlist 9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine more file_inode() open-coded instances selinux: opened file can't have NULL or negative ->f_path.dentry (In the meantime, the hlist traversal macros have changed, so this required a semantic conflict fixup for the newly hlistified fid->dlist)
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-03Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This contains: - fixes and improvements - devicetree bindings - conversion to watchdog generic framework of the following drivers: - booke_wdt - bcm47xx_wdt.c - at91sam9_wdt - Removal of old STMP3xxx driver - Addition of following new drivers: - new driver for STMP3xxx and i.MX23/28 - Retu watchdog driver" * git://www.linux-watchdog.org/linux-watchdog: (30 commits) watchdog: sp805_wdt depends on ARM watchdog: davinci_wdt: update to devm_* API watchdog: davinci_wdt: use devm managed clk get watchdog: at91rm9200: add DT support watchdog: add timeout-sec property binding watchdog: at91sam9_wdt: Convert to use the watchdog framework watchdog: omap_wdt: Add option nowayout watchdog: core: dt: add support for the timeout-sec dt property watchdog: bcm47xx_wdt.c: add hard timer watchdog: bcm47xx_wdt.c: rename wdt_time to timeout watchdog: bcm47xx_wdt.c: rename ops methods watchdog: bcm47xx_wdt.c: use platform device watchdog: bcm47xx_wdt.c: convert to watchdog core api watchdog: Convert BookE watchdog driver to watchdog infrastructure watchdog: s3c2410_wdt: Use devm_* functions watchdog: remove old STMP3xxx driver watchdog: add new driver for STMP3xxx and i.MX23/28 rtc: stmp3xxx: add wdt-accessor function watchdog: introduce retu_wdt driver watchdog: intel_scu_watchdog: fix Kconfig dependency ...
2013-03-03Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull second set of slave-dmaengine updates from Vinod Koul: "Arnd's patch moves the dw_dmac to use generic DMA binding. I agreed to merge this late as it will avoid the conflicts between trees. The second patch from Matt adding a dma_request_slave_channel_compat API was supposed to be picked up, but somehow never got picked up. Some patches dependent on this are already in -next :(" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: dw_dmac: move to generic DMA binding dmaengine: add dma_request_slave_channel_compat()
2013-03-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 bug fixes from Ted Ts'o: "Various bug fixes for ext4. The most important is a fix for the new extent cache's slab shrinker which can cause significant, user-visible pauses when the system is under memory pressure." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: enable quotas before orphan cleanup ext4: don't allow quota mount options when quota feature enabled ext4: fix a warning from sparse check for ext4_dir_llseek ext4: convert number of blocks to clusters properly ext4: fix possible memory leak in ext4_remount() jbd2: fix ERR_PTR dereference in jbd2__journal_start ext4: use percpu counter for extent cache count ext4: optimize ext4_es_shrink()
2013-03-02Merge tag 'nfs-for-3.9-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "We've just concluded another Connectathon interoperability testing week, and so here are the fixes for the bugs that were discovered: - Don't allow NFS silly-renamed files to be deleted - Don't start the retransmission timer when out of socket space - Fix a couple of pnfs-related Oopses. - Fix one more NFSv4 state recovery deadlock - Don't loop forever when LAYOUTGET returns NFS4ERR_LAYOUTTRYLATER" * tag 'nfs-for-3.9-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: SUNRPC: One line comment fix NFSv4.1: LAYOUTGET EDELAY loops timeout to the MDS SUNRPC: add call to get configured timeout PNFS: set the default DS timeout to 60 seconds NFSv4: Fix another open/open_recovery deadlock nfs: don't allow nfs_find_actor to match inodes of the wrong type NFSv4.1: Hold reference to layout hdr in layoutget pnfs: fix resend_to_mds for directio SUNRPC: Don't start the retransmission timer when out of socket space NFS: Don't allow NFS silly-renamed files to be deleted, no signal
2013-03-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs update from Chris Mason: "The biggest feature in the pull is the new (and still experimental) raid56 code that David Woodhouse started long ago. I'm still working on the parity logging setup that will avoid inconsistent parity after a crash, so this is only for testing right now. But, I'd really like to get it out to a broader audience to hammer out any performance issues or other problems. scrub does not yet correct errors on raid5/6 either. Josef has another pass at fsync performance. The big change here is to combine waiting for metadata with waiting for data, which is a big latency win. It is also step one toward using atomics from the hardware during a commit. Mark Fasheh has a new way to use btrfs send/receive to send only the metadata changes. SUSE is using this to make snapper more efficient at finding changes between snapshosts. Snapshot-aware defrag is also included. Otherwise we have a large number of fixes and cleanups. Eric Sandeen wins the award for removing the most lines, and I'm hoping we steal this idea from XFS over and over again." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (118 commits) btrfs: fixup/remove module.h usage as required Btrfs: delete inline extents when we find them during logging btrfs: try harder to allocate raid56 stripe cache Btrfs: cleanup to make the function btrfs_delalloc_reserve_metadata more logic Btrfs: don't call btrfs_qgroup_free if just btrfs_qgroup_reserve fails Btrfs: remove reduplicate check about root in the function btrfs_clean_quota_tree Btrfs: return ENOMEM rather than use BUG_ON when btrfs_alloc_path fails Btrfs: fix missing deleted items in btrfs_clean_quota_tree btrfs: use only inline_pages from extent buffer Btrfs: fix wrong reserved space when deleting a snapshot/subvolume Btrfs: fix wrong reserved space in qgroup during snap/subv creation Btrfs: remove unnecessary dget_parent/dput when creating the pending snapshot btrfs: remove a printk from scan_one_device Btrfs: fix NULL pointer after aborting a transaction Btrfs: fix memory leak of log roots Btrfs: copy everything if we've created an inline extent btrfs: cleanup for open-coded alignment Btrfs: do not change inode flags in rename Btrfs: use reserved space for creating a snapshot clear chunk_alloc flag on retryable failure ...
2013-03-02Merge tag 'for-linus-20130301' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from David Woodhouse: "Fairly unexciting MTD merge for 3.9: - misc clean-ups in the MTD command-line partitioning parser (cmdlinepart) - add flash locking support for STmicro chips serial flash chips, as well as for CFI command set 2 chips. - new driver for the ELM error correction HW module found in various TI chips, enable the OMAP NAND driver to use the ELM HW error correction - added number of new serial flash IDs - various fixes and improvements in the gpmi NAND driver - bcm47xx NAND driver improvements - make the mtdpart module actually removable" * tag 'for-linus-20130301' of git://git.infradead.org/linux-mtd: (45 commits) mtd: map: BUG() in non handled cases mtd: bcm47xxnflash: use pr_fmt for module prefix in messages mtd: davinci_nand: Use managed resources mtd: mtd_torturetest can cause stack overflows mtd: physmap_of: Convert device allocation to managed devm_kzalloc() mtd: at91: atmel_nand: for PMECC, add code to check the ONFI parameter ECC requirement. mtd: atmel_nand: make pmecc-cap, pmecc-sector-size in dts is optional. mtd: atmel_nand: avoid to report an error when lookup table offset is 0. mtd: bcm47xxsflash: adjust names of bus-specific functions mtd: bcm47xxpart: improve probing of nvram partition mtd: bcm47xxpart: add support for other erase sizes mtd: bcm47xxnflash: register this as normal driver mtd: bcm47xxnflash: fix message mtd: bcm47xxsflash: register this as normal driver mtd: bcm47xxsflash: write number of written bytes mtd: gpmi: add sanity check for the ECC mtd: gpmi: set the Golois Field bit for mx6q's BCH mtd: devices: elm: Removes <xx> literals in elm DT node mtd: gpmi: fix a dereferencing freed memory error mtd: fix the wrong timeo for panic_nand_wait() ...
2013-03-02mm: define VM_GROWSUP for CONFIG_METAGJames Hogan
Commit cc2383ec06be093789469852e1fe96e1148e9a2c ("mm: introduce arch-specific vma flag VM_ARCH_1") merged in v3.7-rc1. The above commit combined several arch-specific vma flags into one, and in the process it changed the VM_GROWSUP definition to depend on specific architectures rather than CONFIG_STACK_GROWSUP. Therefore add an ifdef for CONFIG_METAG to also set VM_GROWSUP. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michel Lespinasse <walken@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-mm@kvack.org
