path: root/include
2015-10-14mmc: core: Disable HPI for certain Hynix eMMC cardsMarcel Ziswiler
Certain Hynix eMMC 4.41 cards might get broken when HPI feature is used and hence this patch disables the HPI feature for such buggy cards. As some of the other features like BKOPs/Cache/Sanitize are dependent on HPI feature, those features would also get disabled if HPI is disabled. Change-Id: I6a638ce089cbd977122e47aecb721bc3f0adf7b0 Signed-off-by: Pratibhasagar V <pratibha@codeaurora.org> Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org> Fix ported from the following Android MSM kernel commit: https://www.codeaurora.org/cgit/quic/la/kernel/msm/commit/?id=84af3731019921a28d595dbf6cbf00539706a42c
2015-10-11mmc: sdhci: handle busy-end interrupt during commandChanho Min
It is fully legal for a controller to start handling busy-end interrupt before it has signaled that the command has completed. So make sure we do things in the proper order, Or it results that command interrupt is ignored so it can cause unexpected operations. This is founded at some toshiba emmc with the bellow warning. "mmc0: Got command interrupt 0x00000001 even though no command operation was in progress." This issue has been also reported by Youssef TRIKI: It is not specific to Toshiba devices, and happens with eMMC devices as well as SD card which support Auto-CMD12 rather than CMD23. Also, similar patch is submitted by: Gwendal Grignou <gwendal@chromium.org> Changes since v1: Fixed conflict with the next of git.linaro.org/people/ulf.hansson/mmc.git and Tested if issue is fixed again. Signed-off-by: Hankyung Yu <hankyung.yu@lge.com> Signed-off-by: Chanho Min <chanho.min@lge.com> Tested-by: Youssef TRIKI <youssef.triki@st.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit e99783a45220a2c5f5a598e0e81213ecf2dbcf2f)
2015-10-09mmc: sdhci-pci: add runtime pm supportAdrian Hunter
Ths patch allows runtime PM for sdhci-pci, runtime suspending after inactivity of 50ms and ensuring runtime resume before SDHC registers are accessed. During runtime suspend, interrupts are masked. The host controller state is restored at runtime resume. For Medfield, the host controller's card detect mechanism is supplanted by an always-on GPIO which provides for card detect wake-up. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit 66fd8ad5100b5003046aa744a4f12fa31bb831f9)
2015-03-30Merge remote-tracking branch 'remotes/ubifs-v3.1/master' into tegra-nand-nextMarcel Ziswiler
Conflicts: drivers/mtd/ubi/ubi.h drivers/mtd/ubi/wl.c
2015-02-03mmc: Add tracepoints of mmc block operationsKen Sumrall
Add tracepoints to record the start and end of each mmc block operation. This includes read, write, erase, secure erase, trim, secure trim1 and secure trim 2, discard and sanitize commands. Change-Id: Ic5d1cbdb9adb940d8b1a2a13c73970023575df50 Signed-off-by: Ken Sumrall <ksumrall@android.com> Signed-off-by: Iliyan Malchev <malchev@google.com> Conflicts: drivers/mmc/card/block.c drivers/mmc/core/core.c (cherry picked from commit 4de9a433c26e47d9b4a93105eb92935321100786)
2015-02-03mmc: core: new discard feature support at Samsung eMMC v4.41+.singhome_lee
Support discard feature if MID field in the CID register is 0x15, EXT.CSD[192] (device version) is 5 and Bit 0 in the EXT.CSD[64] is 1. Also removed REQ_SECURE flag check to avoid kernel hang. This patch is released from samsung. Change-Id: I4023a900680e9bca10c40311b09ed077a22617db (cherry picked from commit 4acc227edfb631d377e14911287c1b73682fc9c2) Conflicts: drivers/mmc/card/block.c
2015-02-03eMMC: Add Product revision, Sector count and driver init logban_feng
Change-Id: I89b544afbb0a109a222621a9948399fba8f77693 Change-Id: Ie366a152100a478e7811b4395f3fae9794bb1386 Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45221 Reviewed-by: Ban Feng <Ban_Feng@asus.com> Tested-by: Ban Feng <Ban_Feng@asus.com> Reviewed-by: Sam hblee <Sam_hblee@asus.com> Conflicts: drivers/mmc/core/mmc.c include/linux/mmc/card.h asdf
2015-01-16Merge remote-tracking branch 'remotes/nvidia/l4t/l4t-r16-r2' into tegra-nextMarcel Ziswiler
(tegra-l4t-r16-16.5) Conflicts: drivers/media/video/tegra_v4l2_camera.c drivers/mmc/host/sdhci.c drivers/watchdog/tegra_wdt.c include/media/tegra_v4l2_camera.h
2015-01-09media: Added Analog Devices ADV7280 video decoder driverWojciech Bieganski
2014-07-31video: tegra: nvhost: validate nvmap_handle_refBibek Basu
nvhost_job_unpin should always get the nvmap_handle_ref from rb_entry after validating handle and presence in the tree. Bug 1478467 Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448 Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: http://git-master/r/436076 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2014-06-04Added continuous mode capture supportAlex Feinman
Signed-off-by: Bryan Wu <pengw@nvidia.com> Change-Id: I67c50ff86b53a6c1001d2b688251dc55bd2eff55 Reviewed-on: http://git-master/r/419070 Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2014-05-28mmc: sdhci: add quirk for lack of 1.8v supportJeetesh Burman
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Bug 1402031 Change-Id: I7ca070a13241e6403eb2e243ebbc441a311110bc Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Jeetesh Burman <jburman@nvidia.com> Reviewed-on: http://git-master/r/346323 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2014-04-22media: added camera settings per decoderWojciech Bieganski
This commit adds settings such as: - values of horizontal/vertical active start, - enabling/disabling internal sync, to the private data of decoders: MAX9526, ADV7180, TVP5150, OV7670 and AS0260. The feature is available through *_tegra_camera_platform_data struct initialised in board-*.c files.
2014-03-31ptp: Add a method for obtaining the device index.Richard Cochran
This commit adds a method that MAC drivers may call in order to find out the device number of their associated PTP Hardware Clock. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-31ethtool: Introduce a method for getting time stamping capabilities.Richard Cochran
This commit adds a new ethtool ioctl that exposes the SO_TIMESTAMPING capabilities of a network interface. In addition, user space programs can use this ioctl to discover the PTP Hardware Clock (PHC) device associated with the interface. Since software receive time stamps are handled by the stack, the generic ethtool code can answer the query correctly in case the MAC or PHY drivers lack special time stamping features. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-31ethtool: Centralise validation of ETHTOOL_{G, S}RXFHINDIR parametersBen Hutchings
Add a new ethtool operation (get_rxfh_indir_size) to get the indirectional table size. Use this to validate the user buffer size before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get the number of RX rings, and validate the contents of the new indirection table before calling set_rxfh_indir. Remove this validation from drivers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: drivers/media/video/tegra_v4l2_camera.c reverted to current driver supporting ACM rather than CSI2 drivers/media/video/videobuf2-dma-nvmap.c drivers/video/tegra/host/Makefile
2014-01-29input: touchscreen: added platform data for Fusion touchscreenStefan Agner
Added platform data struct to define interrupt and reset GPIO. This allows to initialize the touchscreen controller inside the driver rather then in each platform and use the driver as a module.
2013-12-09mfd: stmpe: add ADC block resourcesStefan Agner
In order to use the auxiliar ADC inputs of STMPE811 devices we need to add resources for the ADC block. Also move the ADC macros from the touchscreen driver to the general header file. We will need them for the ADC driver in future.
2013-07-05UBI: document UBI_IOCVOLUP better in user headerMike Frysinger
The current ioctl define implies that this func expects to be passed a 64bit number directly rather than a pointer to a 64bit. The code that processes this ioctl shows that it clearly expects a pointer. It'd be best if we could change the type to "__s64*", but that would change the generated ioctl number thus breaking the userland ABI. So just add a comment for intrepid developers. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-06-24hwmon: lm95245: add local critical shutdown temp hookMax Krummenacher
export access to the 'Local Shared OS and T_Crit Limit' register.
2013-04-18mmc: sdhci: add quirk for lack of 1.8v supportDaniel Drake
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-03-05media: soc_camera: add OV5650 SoC camera I2C device driverBryan Wu
OV5650 is a RAW sensor outputing Bayer RAW 8 or RAW 10 data. This driver uses SoC camera interface and supports several different resolution. Change-Id: I8075b63b42f7949a264bdef446f5ed8bdc0a9eee Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/200223 GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-03-05tegra: Make tegra_vi01_device accessibleAndrew Chew
Make it accessible outside of drivers/video/tegra. V4L2 driver needs to set some platform_data. Add suport for T20. Change-Id: I98353c2874ea28cfa0a7a5dd8a1dc4c586af4dd7 Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/200220 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2013-03-03Make it accessible outside of drivers/video/tegra. V4L2 driver needs toAndrew Chew
set some platform_data. Signed-off-by: Andrew Chew <achew@nvidia.com>
2013-03-03Conflicts:Marcel Ziswiler
arch/arm/mach-tegra/common.c drivers/ata/ahci-tegra.c
2013-02-22prandom: introduce prandom_bytes() and prandom_bytes_state()Akinobu Mita
Add functions to get the requested number of pseudo-random bytes. The difference from get_random_bytes() is that it generates pseudo-random numbers by prandom_u32(). It doesn't consume the entropy pool, and the sequence is reproducible if the same rnd_state is used. So it is suitable for generating random bytes for testing. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: David Laight <david.laight@aculab.com> Cc: Michel Lespinasse <walken@google.com> Cc: Robert Love <robert.w.love@intel.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22random32: rename random32 to prandomAkinobu Mita
This renames all random32 functions to have 'prandom_' prefix as follows: void prandom_seed(u32 seed); /* rename from srandom32() */ u32 prandom_u32(void); /* rename from random32() */ void prandom_seed_state(struct rnd_state *state, u64 seed); /* rename from prandom32_seed() */ u32 prandom_u32_state(struct rnd_state *state); /* rename from prandom32() */ The purpose of this renaming is to prevent some kernel developers from assuming that prandom32() and random32() might imply that only prandom32() was the one using a pseudo-random number generator by prandom32's "p", and the result may be a very embarassing security exposure. This concern was expressed by Theodore Ts'o. And furthermore, I'm going to introduce new functions for getting the requested number of pseudo-random bytes. If I continue to use both prandom32 and random32 prefixes for these functions, the confusion is getting worse. As a result of this renaming, "prandom_" is the common prefix for pseudo-random number library. Currently, srandom32() and random32() are preserved because it is difficult to rename too many users at once. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Robert Love <robert.w.love@intel.com> Cc: Michel Lespinasse <walken@google.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: David Laight <david.laight@aculab.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-25fbcon: logo: allow easy integration of a custom Linux boot logoT30_LinuxImageV2.0Beta1_20130314T20_LinuxImageV2.0_20130305T20_LinuxImageV2.0Beta2_20130129Marcel Ziswiler
This patch allows for easy integration of a custom Linux boot logo to replace the Tux' being shown by default. Use gimp or the like to create a raw PPM in your desired resolution. Reduce the number of colours in the image to 224: user@host:~$ ppmquant 224 Toradex-640x480.ppm > \ Toradex-640x480-224.ppm ppmquant: making histogram... ppmquant: 370 colors found ppmquant: choosing 224 colors... ppmquant: mapping image to new colors... Convert it from raw PPM to ASCII format: user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \ Toradex-640x480-ascii-224.ppm Copy it into the Linux sources: cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\ logo_custom_clut224.ppm Activate exclusively custom Linux logo in the kernel configuration: Device Drivers -> Graphics support -> Bootup logo -> Custom 224-color Linux logo And re-compile the kernel.
2013-01-09hwmon: lm95245: add local temp and remote critical shutdown temp hooksMarcel Ziswiler
In order to allow tighter integration with external thermal throttling code add local temperature and remote critical shutdown temperature hooks. Rename the existing hooks for clarity.
2013-01-07hwmon: lm95245: add probe callback and remote OS hooksMarcel Ziswiler
In order to allow integrating with external thermal throttling code add a probe callback and remote over-temperature shutdown hooks.
2013-01-07hwmon: lm95245: implement remote over-temperature shutdown alarm limitMarcel Ziswiler
In addition to the critical temperature alarm limit this chip features a second alarm limit called remote over-temperature shutdown ROS with a separate pin configurable as trigger output. Implement this feature and add platform data to allow configuring respective pin as output.
2012-12-17media: ov5640: Add Omnivision OV5640 supportAndrew Chew
Based on ov5642 driver. There seem to be some register differences, so forking the driver to make those changes. Change-Id: Idb4a79757cbbcd15d5456ce82a708f433faaff7a Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/169836 Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17tegra: Add nvmap_mark_global()Andrew Chew
Add this function, to be able to set the global field of an nvmap_handle while preserving the nvmap API's encapsulation mechanisms. Change-Id: I62de773a65119722f059b114e2d0e906c7e04e83 Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/169834 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17media: tegra: Tegra videobuf2Andrew Chew
This is based off of videobuf2-dma-contig, except we use Tegra's nvmap for the buffer allocations. Signed-off-by: Andrew Chew <achew@nvidia.com> Change-Id: I15e689c33ee7b4fc0aade794c78701c82483df3f Reviewed-on: http://git-master/r/145345 (cherry picked from commit 70a4f20fbdd6c2c719400d6c59ef58d845657031) Signed-off-by: Bryan Wu <pengw@nvidia.com> Change-Id: Ia0632d7fcb28415e33fbb22c48f29117d7436f1d Reviewed-on: http://git-master/r/170824 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Andrew Chew <achew@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17media: tegra: Tegra V4L2 cameraAndrew Chew
This is the Tegra V4L2 camera host driver, for Tegra2/Tegra3's VI/CSI controller. Signed-off-by: Andrew Chew <achew@nvidia.com> Change-Id: If2d9eefe53c2119c1a6ae518216e1a3c3ed216ef Reviewed-on: http://git-master/r/145346 (cherry picked from commit 5a9bfd588b755f354ae21471a3a2a3e559ca6fae) Signed-off-by: Bryan Wu <pengw@nvidia.com> Change-Id: I4db33b17efdb401938603cb2153d73bf3421ba61 Reviewed-on: http://git-master/r/170823 Reviewed-by: Andrew Chew <achew@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-17tegra_camera: fix building error when disable CONFIG_TEGRA_CAMERABryan Wu
LD vmlinux.o drivers/built-in.o: In function `is_tegra_camera_on': /home/roc/Work/bug_vip/source_vibrante/kernel/include/media/ tegra_camera.h:59: multiple definition of `is_tegra_camera_on' arch/arm/mach-tegra/built-in.o:/home/roc/Work/bug_vip/source_vibrante /kernel/include/media/tegra_camera.h:59: first defined here make: *** [vmlinux.o] Error 1 Commit '678708d WAR: gr3d: limit 3d clock when camera is on' introduced a function is_tegra_camera_on(), which is dummy when CONFIG_TEGRA_CAMERA is disabled. But it will be multiple defined when includ this header file in multiple C files. So marking it as static will kill this error. Change-Id: I9dbcf1231f744c23e761d70da0bfc874fb286e4a Signed-off-by: Bryan Wu <pengw@nvidia.com> Reviewed-on: http://git-master/r/167510 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2012-12-04bluetooth: hid: make Android code conditionalMursalin Akon
Commit 7c786ce33a1b4194cb95aa1e68bc38d552eda932 introduced couple of fields, which are not used in standard bluez user space stack. However, Android bluez use them. This CL, conditionally builds the part of the code introduced in the above commit. Bug 1178960 Change-Id: I7254fe83c7fb4bbfd14e00dda3ec3a14afc1b234 Signed-off-by: Mursalin Akon <makon@nvidia.com> (cherry picked from commit e3375fd96fa5e0d7cfcda848d797cd512c12b7a6) Reviewed-on: http://git-master/r/167540 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Eric Brower <ebrower@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2012-11-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: arch/arm/mach-tegra/tegra3_usb_phy.c arch/arm/mach-tegra/usb_phy.c drivers/usb/gadget/tegra_udc.c drivers/usb/otg/Makefile drivers/video/tegra/fb.c sound/soc/tegra/tegra_pcm.c
2012-10-05sched/x86: Fix overflow in cyc2ns_offsetSalman Qazi
Artem: only left the 'mult_frac' addition from this patch, as we need it in ubi. Signed-off-by: Salman Qazi <sqazi@google.com> Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Turner <pjt@google.com> Cc: john stultz <johnstul@us.ibm.com> Link: http://lkml.kernel.org/r/20120310004027.19291.88460.stgit@dungbeetle.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-10-05UBI: add max_beb_per1024 to attach ioctlRichard Genoud
This patch provides a possibility to set the "maximum expected number of bad blocks per 1024 blocks" (max_beb_per1024) for each mtd device using the UBI_IOCATT ioctl. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05mtd: mtdparts: introduce mtd_get_device_sizeRichard Genoud
'mtd_get_device_size()' returns the size of the whole MTD device, that is the mtd_info master size. This will be used by UBI to calculate the maximum number of bad blocks (MBB) on a MTD device. Artem: amended the patch a bit. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05mtd: mark mtd_is_partition argument as constantRichard Genoud
'struct mtd_info' is not modified by 'mtd_is_partition()' so it can be marked as "const". Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-09-10WAR: gr3d: limit 3d clock when camera is onJihoon Bang
As WAR, limit 3d clock frequency and emc clock frequency when camera is on and chip is AP37. 3d clock is set to 361MHz and 437MHz is requested for emc clock with this change. This change allows 3d to request 1.1V in Core instead of 1.3V in AP37. Bug 1001262 Bug 1019309 Change-Id: I9f46f93d8da0fcf5afe05839177bf0d6e43a5840 Signed-off-by: Jihoon Bang <jbang@nvidia.com> Reviewed-on: http://git-master/r/130945 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-09-10Merge branch 'l4t/l4t-r16' into colibriMarcel Ziswiler
Merge with latest NVIDIA L4T R16. Only real conflict concerning inverted VBUS gpio support.
2012-09-04usbnet: fix skb traversing races during unlink(v2)Ming Lei
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid recursive locking in usbnet_stop()) fixes the recursive locking problem by releasing the skb queue lock before unlink, but may cause skb traversing races: - after URB is unlinked and the queue lock is released, the refered skb and skb->next may be moved to done queue, even be released - in skb_queue_walk_safe, the next skb is still obtained by next pointer of the last skb - so maybe trigger oops or other problems This patch extends the usage of entry->state to describe 'start_unlink' state, so always holding the queue(rx/tx) lock to change the state if the referd skb is in rx or tx queue because we need to know if the refered urb has been started unlinking in unlink_urbs. The other part of this patch is based on Huajun's patch: always traverse from head of the tx/rx queue to get skb which is to be unlinked but not been started unlinking. Signed-off-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: Oliver Neukum <oneukum@suse.de> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> (cherry picked from commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa) Bug 1040642 Change-Id: I1a8c248016529bebf71d540738ad4726cf3f59b7 Signed-off-by: Steve Lin <stlin@nvidia.com> Reviewed-on: http://git-master/r/128693 GVS: Gerrit_Virtual_Submit
2012-09-04ASoC: dapm: Use DAPM mutex for DAPM ops instead of codec mutexLiam Girdwood
It has now become necessary to use a DAPM mutex instead of the codec mutex to lock the DAPM operations. This is due to the recent multi component support and forth coming Dynamic PCM updates. Currently we lock DAPM operations with the codec mutex of the calling RTD context. However, DAPM operations can span the whole card context and all components. This patch updates the DAPM operations that use the codec mutex to now use the DAPM mutex PCM subclass for all DAPM ops. We also add a mutex subclass for DAPM init and PCM operations. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> (cherry picked from commit a73fb2df01866b772a48fab93401fe3edbe0b38d) Updated call sequences Bug 1039523 Change-Id: If079bbe5032971251d6b5426c752cbcc6ad6bcf5 Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com> Reviewed-on: http://git-master/r/128937 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-08-29video: tegra: host: Disable irq when clock gatingTerje Bergstrom
Disable host1x interrupts when clock gating host1x. This fixes a race where host1x interrupt was raised at the same time when host1x clock is turned off. Bug 1031724 Change-Id: I169cd5796608b8888a6b48ed99bb5da754559b2c Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/125129 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-08-28E1853 BRINGUP Linux Snor: Micron SupportBob Johnston
Expanding NOR functionality to work with ADMUX and Burst mode for Micron Support in E1853. Bug 989919 Bug 966833 - Adding fields for picking MUX vs NONMUX and picking Async, Paging, Burst mode for reads - Added run time decision between them - 1853 specific settings for Async NOR - 1852 specific settings for NOR - 1853 NOR timings changed Reviewed-on: http://git-master/r/122286 (cherry picked from commit a242e7194c7de559d22fe5b275a8782086f10e50) Change-Id: I79de1d52d4c7199c83b380c2fa6d8cae6b35f09d Signed-off-by: Bob Johnston <BJohnston@nvidia.com> Reviewed-on: http://git-master/r/124946 Tested-by: Bob Johnston <bjohnston@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-08-27drivers: mfd: Add support for TI aic3262 driverManoj Gangwal
Bug 1034241 Change-Id: I5607d53cf0bdd25c5e2b8447cd7e676b64cd32a2 Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/125169 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
