commit ae491542cbbbcca0ec8938c37d4079a985e58440 upstream.
This zeroes the msg so no random stack data ends up getting
sent, it also limits the function to not accepting > 4
i2c msgs.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
[ Upstream commit c7c49b8fde26b74277188bdc6c9dca38db6fa35b ]
Greg reported crashes hitting the following check in __sk_backlog_rcv()
BUG_ON(!sock_flag(sk, SOCK_MEMALLOC));
The pfmemalloc bit is currently checked in sk_filter().
This works correctly for TCP, because sk_filter() is ran in
tcp_v[46]_rcv() before hitting the prequeue or backlog checks.
For UDP or other protocols, this does not work, because the sk_filter()
is ran from sock_queue_rcv_skb(), which might be called _after_ backlog
queuing if socket is owned by user by the time packet is processed by
softirq handler.
Fixes: b4b9e35585089 ("netvm: set PF_MEMALLOC as appropriate during SKB processing")
Reported-by: Greg Thelen <gthelen@google.com>
[ Upstream commit 31b33dfb0a144469dd805514c9e63f4993729a48 ]
Earlier patch 6ae459bda tried to detect void ckecksum partial
skb by comparing pull length to checksum offset. But it does
not work for all cases since checksum-offset depends on
updates to skb->data.
Following patch fixes it by validating checksum start offset
after skb-data pointer is updated. Negative value of checksum
offset start means there is no need to checksum.
Fixes: 6ae459bda ("skbuff: Fix skb checksum flag on skb pull")
Reported-by: Andrew Vagin <avagin@odin.com>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
[ Upstream commit 6ae459bdaaeebc632b16e54dcbabb490c6931d61 ]
VXLAN device can receive skb with checksum partial. But the checksum
offset could be in outer header which is pulled on receive. This results
in negative checksum offset for the skb. Such skb can cause the assert
failure in skb_checksum_help(). Following patch fixes the bug by setting
checksum-none while pulling outer header.
Following is the kernel panic msg from old kernel hitting the bug.
kernel BUG at net/core/dev.c:1906!
RIP: 0010:[<ffffffff81518034>] skb_checksum_help+0x144/0x150
Call Trace:
<IRQ>
[<ffffffffa0164c28>] queue_userspace_packet+0x408/0x470 [openvswitch]
[<ffffffffa016614d>] ovs_dp_upcall+0x5d/0x60 [openvswitch]
[<ffffffffa0166236>] ovs_dp_process_packet_with_key+0xe6/0x100 [openvswitch]
[<ffffffffa016629b>] ovs_dp_process_received_packet+0x4b/0x80 [openvswitch]
[<ffffffffa016c51a>] ovs_vport_receive+0x2a/0x30 [openvswitch]
[<ffffffffa0171383>] vxlan_rcv+0x53/0x60 [openvswitch]
[<ffffffffa01734cb>] vxlan_udp_encap_recv+0x8b/0xf0 [openvswitch]
[<ffffffff8157addc>] udp_queue_rcv_skb+0x2dc/0x3b0
[<ffffffff8157b56f>] __udp4_lib_rcv+0x1cf/0x6c0
[<ffffffff8157ba7a>] udp_rcv+0x1a/0x20
[<ffffffff8154fdbd>] ip_local_deliver_finish+0xdd/0x280
[<ffffffff81550128>] ip_local_deliver+0x88/0x90
[<ffffffff8154fa7d>] ip_rcv_finish+0x10d/0x370
[<ffffffff81550365>] ip_rcv+0x235/0x300
[<ffffffff8151ba1d>] __netif_receive_skb+0x55d/0x620
[<ffffffff8151c360>] netif_receive_skb+0x80/0x90
[<ffffffff81459935>] virtnet_poll+0x555/0x6f0
[<ffffffff8151cd04>] net_rx_action+0x134/0x290
[<ffffffff810683d8>] __do_softirq+0xa8/0x210
[<ffffffff8162fe6c>] call_softirq+0x1c/0x30
[<ffffffff810161a5>] do_softirq+0x65/0xa0
[<ffffffff810687be>] irq_exit+0x8e/0xb0
[<ffffffff81630733>] do_IRQ+0x63/0xe0
[<ffffffff81625f2e>] common_interrupt+0x6e/0x6e
Reported-by: Anupam Chanda <achanda@vmware.com>
Acked-by: Tom Herbert <tom@herbertland.com>
[ Upstream commit 4613012db1d911f80897f9446a49de817b2c4c47 ]
As suggested by Eric Dumazet this change replaces the
#define with a static inline function to enjoy
complaints by the compiler when misusing the API.
Signed-off-by: Aaron Conole <aconole@bytheb.org>
commit fe32d3cd5e8eb0f82e459763374aa80797023403 upstream.
These functions check should_resched() before unlocking spinlock/bh-enable:
preempt_count always non-zero => should_resched() always returns false.
cond_resched_lock() worked iff spin_needbreak is set.
This patch adds argument "preempt_offset" to should_resched().
preempt_count offset constants for that:
PREEMPT_DISABLE_OFFSET - offset after preempt_disable()
PREEMPT_LOCK_OFFSET - offset after spin_lock()
SOFTIRQ_DISABLE_OFFSET - offset after local_bh_distable()
SOFTIRQ_LOCK_OFFSET - offset after spin_lock_bh()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Alexander Graf <agraf@suse.de>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Fixes: bdb438065890 ("sched: Extract the basic add/sub preempt_count modifiers")
Link: http://lkml.kernel.org/r/20150715095204.12246.98268.stgit@buzz
commit b7f76ea2ef6739ee484a165ffbac98deb855d3d3 upstream.
Signed-off-by: Jann Horn <jann@thejh.net>
Reviewed-by: Andy Lutomirski <luto@kernel.org>
commit 9cf94eab8b309e8bcc78b41dd1561c75b537dd0b upstream.
Commit 0838aa7fcfcd ("netfilter: fix netns dependencies with conntrack
templates") migrated templates to the new allocator api, but forgot to
update error paths for them in CT and synproxy to use nf_ct_tmpl_free()
instead of nf_conntrack_free().
Due to that, memory is being freed into the wrong kmemcache, but also
we drop the per net reference count of ct objects causing an imbalance.
In Brad's case, this leads to a wrap-around of net->ct.count and thus
lets __nf_conntrack_alloc() refuse to create a new ct object:
[ 10.340913] xt_addrtype: ipv6 does not support BROADCAST matching
[ 10.810168] nf_conntrack: table full, dropping packet
[ 11.917416] r8169 0000:07:00.0 eth0: link up
[ 11.917438] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.815902] nf_conntrack: table full, dropping packet
[ 15.688561] nf_conntrack: table full, dropping packet
[ 15.689365] nf_conntrack: table full, dropping packet
[ 15.690169] nf_conntrack: table full, dropping packet
[ 15.690967] nf_conntrack: table full, dropping packet
With slab debugging, it also reports the wrong kmemcache (kmalloc-512 vs.
nf_conntrack_ffffffff81ce75c0) and reports poison overwrites, etc. Thus,
to fix the problem, export and use nf_ct_tmpl_free() instead.
Fixes: 0838aa7fcfcd ("netfilter: fix netns dependencies with conntrack templates")
Reported-by: Brad Jackson <bjackson0971@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit bf798657eb5ba57552096843c315f096fdf9b715 upstream.
nft_type_to_reg() needs to return the register in the new 32 bit addressing,
otherwise we hit EINVAL when using mappings.
Fixes: 49499c3 ("netfilter: nf_tables: switch registers to 32 bit addressing")
Reported-by: Andreas Schultz <aschultz@tpip.net>
commit 18e1db67e93ed75d9dc0d34c8d783ccf10547c2b upstream.
230ac490f7fba introduced a dependency to CONFIG_IPV6 which breaks bridging
of IPv6 packets on a bridge with CONFIG_IPV6=n.
Sysctl entry /proc/sys/net/bridge/bridge-nf-call-ip6tables defaults to 1,
for this reason packets are handled by br_nf_pre_routing_ipv6(). When compiled
with CONFIG_IPV6=n this function returns NF_DROP but should return NF_ACCEPT
to let packets through.
Change CONFIG_IPV6=n br_nf_pre_routing_ipv6() return value to NF_ACCEPT.
Tested with a simple bridge with two interfaces and IPv6 packets trying
to pass from host on left side to host on right side of the bridge.
Fixes: 230ac490f7fba ("netfilter: bridge: split ipv6 code into separated file")
Signed-off-by: Bernhard Thaler <bernhard.thaler@wvnet.at>
commit 0610c25daa3e76e38ad5a8fae683a89ff9f71798 upstream.
The problem starts with a file backed dirty page which is charged to a
memcg. Then page migration is used to move oldpage to newpage.
Migration:
- copies the oldpage's data to newpage
- clears oldpage.PG_dirty
- sets newpage.PG_dirty
- uncharges oldpage from memcg
- charges newpage to memcg
Clearing oldpage.PG_dirty decrements the charged memcg's dirty page
count.
However, because newpage is not yet charged, setting newpage.PG_dirty
does not increment the memcg's dirty page count. After migration
completes newpage.PG_dirty is eventually cleared, often in
account_page_cleaned(). At this time newpage is charged to a memcg so
the memcg's dirty page count is decremented which causes underflow
because the count was not previously incremented by migration. This
underflow causes balance_dirty_pages() to see a very large unsigned
number of dirty memcg pages which leads to aggressive throttling of
buffered writes by processes in non root memcg.
This issue:
- can harm performance of non root memcg buffered writes.
- can report too small (even negative) values in
memory.stat[(total_)dirty] counters of all memcg, including the root.
To avoid polluting migrate.c with #ifdef CONFIG_MEMCG checks, introduce
page_memcg() and set_page_memcg() helpers.
Test:
0) setup and enter limited memcg
mkdir /sys/fs/cgroup/test
echo 1G > /sys/fs/cgroup/test/memory.limit_in_bytes
echo $$ > /sys/fs/cgroup/test/cgroup.procs
1) buffered writes baseline
dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k
sync
grep ^dirty /sys/fs/cgroup/test/memory.stat
2) buffered writes with compaction antagonist to induce migration
yes 1 > /proc/sys/vm/compact_memory &
rm -rf /data/tmp/foo
kill %
sync
3) buffered writes without antagonist, should match baseline
sync
(speed, dirty residue)
unpatched patched
1) 841 MB/s 0 dirty pages 886 MB/s 0 dirty pages
2) 611 MB/s -33427456 dirty pages 793 MB/s 0 dirty pages
3) 114 MB/s -33427456 dirty pages 891 MB/s 0 dirty pages
Notice that unpatched baseline performance (1) fell after
migration (3): 841 -> 114 MB/s. In the patched kernel, post
migration performance matches baseline.
Fixes: c4843a7593a9 ("memcg: add per cgroup dirty page accounting")
Signed-off-by: Greg Thelen <gthelen@google.com>
Reported-by: Dave Hansen <dave.hansen@intel.com>
percpu_rwsem"
commit 0c986253b939cc14c69d4adbe2b4121bdf4aa220 upstream.
This reverts commit d59cfc09c32a2ae31f1c3bc2983a0cd79afb3f14.
d59cfc09c32a ("sched, cgroup: replace signal_struct->group_rwsem with
a global percpu_rwsem") and b5ba75b5fc0e ("cgroup: simplify
threadgroup locking") changed how cgroup synchronizes against task
fork and exits so that it uses global percpu_rwsem instead of
per-process rwsem; unfortunately, the write [un]lock paths of
percpu_rwsem always involve synchronize_rcu_expedited() which turned
out to be too expensive.
Improvements for percpu_rwsem are scheduled to be merged in the coming
v4.4-rc1 merge window which alleviates this issue. For now, revert
the two commits to restore per-process rwsem. They will be re-applied
for the v4.4-rc1 merge window.
Link: http://lkml.kernel.org/g/55F8097A.7000206@de.ibm.com
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit 0b34a166f291d255755be46e43ed5497cdd194f2 upstream.
Currently there is a number of issues preventing PVHVM Xen guests from
doing successful kexec/kdump:
- Bound event channels.
- Registered vcpu_info.
- PIRQ/emuirq mappings.
- shared_info frame after XENMAPSPACE_shared_info operation.
- Active grant mappings.
Basically, newly booted kernel stumbles upon already set up Xen
interfaces and there is no way to reestablish them. In Xen-4.7 a new
feature called 'soft reset' is coming. A guest performing kexec/kdump
operation is supposed to call SCHEDOP_shutdown hypercall with
SHUTDOWN_soft_reset reason before jumping to new kernel. Hypervisor
(with some help from toolstack) will do full domain cleanup (but
keeping its memory and vCPU contexts intact) returning the guest to
the state it had when it was first booted and thus allowing it to
start over.
Doing SHUTDOWN_soft_reset on Xen hypervisors which don't support it is
probably OK as by default all unknown shutdown reasons cause domain
destroy with a message in toolstack log: 'Unknown shutdown reason code
5. Destroying domain.' which gives a clue to what the problem is and
eliminates false expectations.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 43b3f02899f74ae9914a39547cc5492156f0027a upstream.
Dave ran into horrible performance on a VM without PARAVIRT_SPINLOCKS
set and Linus noted that the test-and-set implementation was retarded.
One should spin on the variable with a load, not a RMW.
While there, remove 'queued' from the name, as the lock isn't queued
at all, but a simple test-and-set.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Dave Chinner <david@fromorbit.com>
Tested-by: Dave Chinner <david@fromorbit.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Link: http://lkml.kernel.org/r/20150904152523.GR18673@twins.programming.kicks-ass.net
commit 76c28f1fcfeb42b47f798fe498351ee1d60086ae upstream.
Revert commit 1997e6259, which causes double brackets on ipv6
inaddr_any addresses.
Since we have np_sockaddr, if we need a textual representation we can
use "%pISc".
Change iscsit_add_network_portal() and iscsit_add_np() signatures to remove
*ip_str parameter.
Fix and extend some comments earlier in the function.
Tested to work for :: and ::1 via iscsiadm, previously :: failed, see
https://bugzilla.redhat.com/show_bug.cgi?id=1249107 .
Signed-off-by: Andy Grover <agrover@redhat.com>
commit 841df7df196237ea63233f0f9eaa41db53afd70f upstream.
Commit 6f6a6fda2945 "jbd2: fix ocfs2 corrupt when updating journal
superblock fails" changed jbd2_cleanup_journal_tail() to return EIO
when the journal is aborted. That makes logic in
jbd2_log_do_checkpoint() bail out which is fine, except that
jbd2_journal_destroy() expects jbd2_log_do_checkpoint() to always make
a progress in cleaning the journal. Without it jbd2_journal_destroy()
just loops in an infinite loop.
Fix jbd2_journal_destroy() to cleanup journal checkpoint lists of
jbd2_log_do_checkpoint() fails with error.
Reported-by: Eryu Guan <guaneryu@gmail.com>
Tested-by: Eryu Guan <guaneryu@gmail.com>
Fixes: 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a
Signed-off-by: Jan Kara <jack@suse.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 11cec15bf3fb498206ef63b1fa26c27689e02d0e upstream.
The number of TLB lines was increased from 16 on Tegra30 to 32 on
Tegra114 and later. Parameterize the value so that the initial default
can be set accordingly.
On Tegra30, initializing the value to 32 would effectively disable the
TLB and hence cause massive latencies for memory accesses translated
through the SMMU. This is especially noticeable for isochronuous clients
such as display, whose FIFOs would continuously underrun.
Fixes: 891846516317 ("memory: Add NVIDIA Tegra memory controller support")
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 0fdea1e8a2853f79d39b8555cc9de16a7e0ab26f upstream.
Commit 718ba5b87343, moved the responsibility for unlocking the socket to
xs_tcp_setup_socket, meaning that the socket will be unlocked before we
know that it has finished trying to connect. The following patch is based on
an initial patch by Russell King to ensure that we delay clearing the
XPRT_CONNECTING flag until we either know that we failed to initiate
a connection attempt, or the connection attempt itself failed.
Fixes: 718ba5b87343 ("SUNRPC: Add helpers to prevent socket create from racing")
Reported-by: Russell King <linux@arm.linux.org.uk>
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
Tested-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 051ac3848a94f21cfdec899cc9c65ce7f9f116fa upstream.
`perf stat -e sunrpc:svc_xprt_do_enqueue true` results in
Warning: unknown op '->'
Warning: [sunrpc:svc_xprt_do_enqueue] unknown op '->'
Similar warning for svc_handle_xprt as well.
Actually TP_printk() should never dereference an address saved in the ring
buffer that points somewhere in the kernel. There's no guarantee that that
object still exists (with the exception of static strings).
Therefore change all the arguments for TP_printk(), so that it references
values existing in the ring buffer only.
While doing that, also fix another possible bug when argument xprt could be
NULL and TP_fast_assign() tries to access it's elements.
Signed-off-by: Pratyush Anand <panand@redhat.com>
Reviewed-by: Jeff Layton <jeff.layton@primarydata.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Fixes: 83a712e0afef "sunrpc: add some tracepoints around ..."
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit cc9a903d915c21626b6b2fbf8ed0ff16a7f82210 upstream.
Both commit 0380a3f375 ("svcrdma: Add a separate "max data segs"
macro for svcrdma") and commit 7e5be28827bf ("svcrdma: advertise
the correct max payload") are incorrect. This commit reverts both
changes, restoring the server's maximum payload size to 1MB.
Commit 7e5be28827bf based the server's maximum payload on the
_client's_ RPCRDMA_MAX_DATA_SEGS value. That was wrong.
Commit 0380a3f375 tried to fix this so that the client maximum
payload size could be raised without affecting the server, but
managed to confuse matters more on the server side.
More importantly, limiting the advertised maximum payload size was
meant to be a workaround, not the actual fix. We need to revisit
https://bugzilla.linux-nfs.org/show_bug.cgi?id=270
A Linux client on a platform with 64KB pages can overrun and crash
an x86_64 NFS/RDMA server when the r/wsize is 1MB. An x86/64 Linux
client seems to work fine using 1MB reads and writes when the Linux
server's maximum payload size is restored to 1MB.
BugLink: https://bugzilla.linux-nfs.org/show_bug.cgi?id=270
Fixes: 0380a3f375 ("svcrdma: Add a separate "max data segs" macro")
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit 6869de380e8c11c31b608bb2502dcacd634eda13 upstream.
This seems overlooked.
Fixes: 98d8fc6c5d36 ('ALSA: hda - Move hda_i915.c from sound/pci/hda to sound/hda')
commit 76b733d15874128ee2d0365b4cbe7d51decd8d37 upstream.
commit "nfc: st-nci: Rename st21nfcb to st-nci" adds
include/linux/platform_data/st_nci.h duplicated with
include/linux/platform_data/st-nci.h.
Only drivers/nfc/st-nci/i2c.c uses platform_data/st_nci.h.
Reported-by: Hauke Mehrtens <hauke@hauke-m.de>
Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
commit bd49784fd1e8f42c7600fbfa206361324857f373 upstream.
If the user selected the precise_timestamps or histogram options, report
it in the @stats_list message output.
If the user didn't select these options, no extra tokens are reported,
thus it is backward compatible with old software that doesn't know about
precise timestamps and histogram.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@vger.kernel.org # 4.2
commit 5d0ddfebb93069061880fc57ee4ba7246bd1e1ee upstream.
Nick Meier reported a regression with HyperV that "
After rebooting the VM, the following messages are logged in syslog
when trying to load the tulip driver:
tulip: Linux Tulip drivers version 1.1.15 (Feb 27, 2007)
tulip: 0000:00:0a.0: PCI INT A: failed to register GSI
tulip: Cannot enable tulip board #0, aborting
tulip: probe of 0000:00:0a.0 failed with error -16
Errors occur in 3.19.0 kernel
Works in 3.17 kernel.
According to the ACPI dump file posted by Nick at
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1440072
The ACPI MADT table includes an interrupt source overridden entry for
ACPI SCI:
[236h 0566 1] Subtable Type : 02 <Interrupt Source Override>
[237h 0567 1] Length : 0A
[238h 0568 1] Bus : 00
[239h 0569 1] Source : 09
[23Ah 0570 4] Interrupt : 00000009
[23Eh 0574 2] Flags (decoded below) : 000D
Polarity : 1
Trigger Mode : 3
And in DSDT table, we have _PRT method to define PCI interrupts, which
eventually goes to:
Name (PRSA, ResourceTemplate ()
IRQ (Level, ActiveLow, Shared, )
{3,4,5,7,9,10,11,12,14,15}
Name (PRSB, ResourceTemplate ()
Name (PRSC, ResourceTemplate ()
Name (PRSD, ResourceTemplate ()
According to the MADT and DSDT tables, IRQ 9 may be used for:
1) ACPI SCI in level, high mode
2) PCI legacy IRQ in level, low mode
So there's a conflict in polarity setting for IRQ 9.
Prior to commit cd68f6bd53cf ("x86, irq, acpi: Get rid of special
handling of GSI for ACPI SCI"), ACPI SCI is handled specially and
there's no check for conflicts between ACPI SCI and PCI legagy IRQ.
And it seems that the HyperV hypervisor doesn't make use of the
polarity configuration in IOAPIC entry, so it just works.
Commit cd68f6bd53cf gets rid of the specially handling of ACPI SCI,
and then the pin attribute checking code discloses the conflicts
between ACPI SCI and PCI legacy IRQ on HyperV virtual machine,
and rejects the request to assign IRQ9 to PCI devices.
So penalize legacy IRQ used by ACPI SCI and mark it unusable if ACPI
SCI attributes conflict with PCI IRQ attributes.
Please refer to following links for more information:
https://bugzilla.kernel.org/show_bug.cgi?id=101301
Fixes: cd68f6bd53cf ("x86, irq, acpi: Get rid of special handling of GSI for ACPI SCI")
Reported-and-tested-by: Nick Meier <nmeier@microsoft.com>
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
commit 932c435caba8a2ce473a91753bad0173269ef334 upstream.
Add a dev_flags bit, PCI_DEV_FLAGS_VPD_REF_F0, to access VPD through
function 0 to provide VPD access on other functions. This is for hardware
devices that provide copies of the same VPD capability registers in
multiple functions. Because the kernel expects that each function has its
own registers, both the locking and the state tracking are affected by VPD
accesses to different functions.
On such devices for example, if a VPD write is performed on function 0,
*any* later attempt to read VPD from any other function of that device will
hang. This has to do with how the kernel tracks the expected value of the
F bit per function.
Concurrent accesses to different functions of the same device can not only
hang but also corrupt both read and write VPD data.
When hangs occur, typically the error message:
vpd r/w failed. This is likely a firmware bug on this device.
will be seen.
Never set this bit on function 0 or there will be an infinite recursion.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
commit c689a923c867eac40ed3826c1d9328edea8b6bc7 upstream.
Add inverse unit conversion macro to convert from standard IIO units to
units that might be used by some devices.
Those are useful in combination with scale factors that are specified as
IIO_VAL_FRACTIONAL. Typically the denominator for those specifications will
contain the maximum raw value the sensor will generate and the numerator
the value it maps to in a specific unit. Sometimes datasheets specify those
in different units than the standard IIO units (e.g. degree/s instead of
rad/s) and so we need to do a unit conversion.
From a mathematical point of view it does not make a difference whether we
apply the unit conversion to the numerator or the inverse unit conversion
to the denominator since (x / y) / z = x / (y * z). But as the denominator
is typically a larger value and we are rounding both the numerator and
denominator to integer values using the later method gives us a better
precision (E.g. the relative error is smaller if we round 8000.3 to 8000
rather than rounding 8.3 to 8).
This is where in inverse unit conversion macros will be used.
Marked for stable as used by some upcoming fixes.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Commit 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel
doesn't support MSI") changed the location of the code that initialises
dev->msi_cap/msix_cap and then disables MSI/MSI-X interrupts at PCI
probe time in devices that have this flag set. It moved the code from
pci_msi_init_pci_dev() to a new function named pci_msi_setup_pci_dev(),
called by pci_setup_device().
The pseries PCI probing code does not call pci_setup_device(), so since
the aforementioned commit the function pci_msi_setup_pci_dev() is not
called and MSI/MSI-X interrupts are left enabled. Additionally because
dev->msi_cap/msix_cap are not initialised no driver can ever enable
MSI/MSI-X.
To fix this, the pseries PCI probe should manually call
pci_msi_setup_pci_dev(), so this patch makes it non-static.
Fixes: 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel doesn't support MSI")
[mpe: Update change log to mention dev->msi_cap/msix_cap]
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
Pull irq fixes from Thomas Gleixner:
"A series of small fixlets for a regression visible on OMAP devices
caused by the conversion of the OMAP interrupt chips to hierarchical
interrupt domains. Mostly one liners on the driver side plus a small
helper function in the core to avoid open coded mess in the drivers"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/crossbar: Restore set_wake functionality
irqchip/crossbar: Restore the mask on suspend behaviour
ARM: OMAP: wakeupgen: Restore the irq_set_type() mechanism
irqchip/crossbar: Restore the irq_set_type() mechanism
genirq: Introduce irq_chip_set_type_parent() helper
genirq: Don't return ENOSYS in irq_chip_retrigger_hierarchy
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
Cc: <stable@vger.kernel.org> [3.6+]
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
- a regression fix at the videobuf2 core driver
- fix error handling at mantis probing code
- revert the IR encode patches, as the API is not mature enough.
So, better to postpone the changes to a latter Kernel
- fix Kconfig breakages on some randconfig scenarios.
* tag 'media/v4.2-3' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] mantis: Fix error handling in mantis_dma_init()
Revert "[media] rc: rc-ir-raw: Add scancode encoder callback"
Revert "[media] rc: rc-ir-raw: Add Manchester encoder (phase encoder) helper"
Revert "[media] rc: ir-rc5-decoder: Add encode capability"
Revert "[media] rc: ir-rc6-decoder: Add encode capability"
Revert "[media] rc: rc-core: Add support for encode_wakeup drivers"
Revert "[media] rc: rc-loopback: Add loopback of filter scancodes"
Revert "[media] rc: nuvoton-cir: Add support for writing wakeup samples via sysfs filter callback"
[media] vb2: Fix compilation breakage when !CONFIG_BUG
[media] vb2: Only requeue buffers immediately once streaming is started
[media] media/pci/cobalt: fix Kconfig and build when SND is not enabled
[media] media/dvb: fix ts2020.c Kconfig and build
Pull drm fixes from Dave Airlie:
"A bunch of i915 fixes, one revert a VBT fix that was a bit premature,
and some braswell feature removal that the hw actually didn't support.
One radeon race fix at boot, and one hlcdc build fix, one fix from
Russell that fixes build as well with new audio features.
This is hopefully all I have until -next"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/radeon: fix hotplug race at startup
drm/edid: add function to help find SADs
drm/i915: Avoid TP3 on CHV
drm/i915: remove HBR2 from chv supported list
Revert "drm/i915: Add eDP intermediate frequencies for CHV"
Revert "drm/i915: Allow parsing of variable size child device entries from VBT"
drm/atmel-hlcdc: Compile suspend/resume for PM_SLEEP only
drm/i915: Flag the execlists context object as dirty after every use
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Here are a small collecton of sound fix patches.
The most significant one is the disablement of newly introduced
topology API. Its ABI couldn't be stabilized enough, so we decided to
delay for 4.3 in the end. Other than that, all oneliner fixes: a
USB-audio runtime PM fix and a couple of HD-audio quirks"
* tag 'sound-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Add dock support for Thinkpad W541 (17aa:2211)
ALSA: usb-audio: Fix runtime PM unbalance
ASoC: topology: Disable use from userspace
ASoC: topology: Add Kconfig option for topology
ALSA: hda - Fix the white noise on Dell laptop
Add a function to find the start of the SADs in the ELD. This
complements the helper to retrieve the SAD count.
[airlied: this fixes a build problem with the alsa eld helper
which required this].
This helper is required for irq chips which do not implement a
irq_set_type callback and need to call down the irq domain hierarchy
for the actual trigger type change.
This helper is required to fix further wreckage caused by the
conversion of TI OMAP to hierarchical irq domains and therefor tagged
for stable.
[ tglx: Massaged changelog ]
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: <linux@arm.linux.org.uk>
Cc: <nsekhar@ti.com>
Cc: <jason@lakedaemon.net>
Cc: <balbi@ti.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: <tony@atomide.com>
Cc: <marc.zyngier@arm.com>
Cc: stable@vger.kernel.org # 4.1
Link: http://lkml.kernel.org/r/1439554830-19502-3-git-send-email-grygorii.strashko@ti.com
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Disable topology support for v4.2
The topology code merged in the v4.2 merge window introduced a new ABI
which was believed to be suitable for use but subsequently additional
work by the developers of this feature have revealed some problems that
need to be addressed. In order to allow this to be done without having
to support the initial ABI add Kconfig to disable the build and also add
some #error statements to the UAPI header so users can't use them.
This reverts commit 9869da5bacc5c9b865a183bd36c04be76cdd325d.
The current code is not mature enough, the API should allow a single
protocol to be specified. Also, the current code contains heuristics
that will depend on module load order.
Signed-off-by: David Härdeman <david@hardeman.nu>
Acked-by: Antti Seppälä <a.seppala@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
This reverts commit 0d830b2d1295fee82546d57185da5a6604f11ae2.
This reverts commit da7ee60b03bd66bb10974d7444aa444de6391312.
Since the topology API is still in sufficient flux for changes to be
identified disable the use of the userspace ABI by adding #error
statements to the code, ensuring that nobody relies on the headers as
currently defined. It is expected that this change will be reverted for
v4.3.
Signed-off-by: Mark Brown <broonie@kernel.org>
"These came in late last week, I wanted to look over the mst one before
forwarding, but it seems good.
Just three i915 and one MST fix"
drm/i915: Commit planes on each crtc separately.
drm/i915: calculate primary visibility changes instead of calling from set_config
drm/i915: Only dither on 6bpc panels
drm/dp/mst: Remove port after removing connector.
Allow the topology code to be compiled out so that users who don't need
topology don't need to havve the code compiled in, saving them some
memory.
Some more configuration could be added to remove some of the hooks into
the core data structures but that is probably best done with some
refactoring to use functions to do the updates of the data structures
rather than ifdefing in the code as we'd need to do at the minute.
Suggested-by: Takashi Iwai <tiwai@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"Three minor device-specific fixes and revert of NCQ autosense added
during this -rc1.
It turned out that NCQ autosense as currently implemented interferes
with the usual error handling behavior. It will be revisited in the
near future"
* 'for-4.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ata: ahci_brcmstb: Fix misuse of IS_ENABLED
sata_sx4: Check return code from pdc20621_i2c_read()
Revert "libata: Implement NCQ autosense"
Revert "libata: Implement support for sense data reporting"
Revert "libata-eh: Set 'information' field for autosense"
ata: ahci_brcmstb: Fix warnings with CONFIG_PM_SLEEP=n
git://anongit.freedesktop.org/drm-intel into drm-next
single MST fixes from Maarten.
* tag 'topic/drm-fixes-2015-08-14' of git://anongit.freedesktop.org/drm-intel:
Pull networking fixes from David Miller:
1) Workaround hw bug when acquiring PCI bos ownership of iwlwifi
devices, from Emmanuel Grumbach.
2) Falling back to vmalloc in conntrack should not emit a warning, from
Pablo Neira Ayuso.
3) Fix NULL deref when rtlwifi driver is used as an AP, from Luis
Felipe Dominguez Vega.
4) Rocker doesn't free netdev on device removal, from Ido Schimmel.
5) UDP multicast early sock demux has route handling races, from Eric
Dumazet.
6) Fix L4 checksum handling in openvswitch, from Glenn Griffin.
7) Fix use-after-free in skb_set_peeked, from Herbert Xu.
8) Don't advertize NETIF_F_FRAGLIST in virtio_net driver, this can lead
to fraglists longer than the driver can support. From Jason Wang.
9) Fix mlx5 on non-4k-pagesize systems, from Carol L Soto.
10) Fix interrupt storm in bna driver, from Ivan Vecera.
11) Don't propagate -EBUSY from netlink_insert(), from Daniel Borkmann.
12) Fix inet request sock leak, from Eric Dumazet.
13) Fix TX interrupt masking and marking in TX descriptors of fs_enet
driver, from LEROY Christophe.
14) Get rid of rule optimizer in gianfar driver, it's buggy and unlikely
to get fixed any time soon. From Jakub Kicinski
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits)
cosa: missing error code on failure in probe()
gianfar: remove faulty filer optimizer
gianfar: correct list membership accounting
gianfar: correct filer table writing
bonding: Gratuitous ARP gets dropped when first slave added
net: dsa: Do not override PHY interface if already configured
net: fs_enet: mask interrupts for TX partial frames.
net: fs_enet: explicitly remove I flag on TX partial frames
inet: fix possible request socket leak
inet: fix races with reqsk timers
mkiss: Fix error handling in mkiss_open()
bnx2x: Free NVRAM lock at end of each page
bnx2x: Prevent null pointer dereference on SKB release
cxgb4: missing curly braces in t4_setup_debugfs()
net-timestamp: Update skb_complete_tx_timestamp comment
ipv6: don't reject link-local nexthop on other interface
netlink: make sure -EBUSY won't escape from netlink_insert
bna: fix interrupts storm caused by erroneous packets
net: mvpp2: replace TX coalescing interrupts with hrtimer
net: mvpp2: enable proper per-CPU TX buffers unmapping
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
The port is removed synchronously, but the connector delayed.
This causes a use after free which can cause a kernel BUG with
slug_debug=FPZU. This is fixed by freeing the port after the
connector.
This fixes a regression introduced with
6b8eeca65b18ae77e175cc2b6571731f0ee413bf
"drm/dp/mst: close deadlock in connector destruction."
Cc: Dave Airlie <airlied@redhat.com>
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
After "62bccb8 net-timestamp: Make the clone operation stand-alone from phy
timestamping" the hwtstamps parameter of skb_complete_tx_timestamp() may no
longer be NULL.
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
"The only bulk changes in this request is ABI updates for ASoC topology
API. It's a new API that was introduced in 4.2, and we'd like to
avoid ABI change after the release, so it's taken now. As there is no
real in-tree user for this API, it should be fairly safe.
Other than that, the usual small fixes are found in various drivers:
ASoC cs4265, rt5645, intel-sst, firewire, oxygen and HD-audio"
* tag 'sound-4.2-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: topology: Add private data type and bump ABI version to 3
ASoC: topology: Add ops support to byte controls UAPI
ASoC: topology: Update TLV support so we can support more TLV types
ASoC: topology: add private data to manifest
ASoC: topology: Add subsequence in topology
ALSA: hda - one Dell machine needs the headphone white noise fixup
ALSA: fireworks/firewire-lib: add support for recent firmware quirk
Revert "ALSA: fireworks: add support for AudioFire2 quirk"
ASoC: topology: fix typo in soc_tplg_kcontrol_bind_io()
ALSA: HDA: Dont check return for snd_hdac_chip_readl
ALSA: HDA: Fix stream assignment for host in decoupled mode
ASoC: rt5645: Fix lost pin setting for DMIC1
ALSA: oxygen: Fix logical-not-parentheses warning
ASoC: Intel: sst_byt: fix initialize 'NULL device *' issue
ASoC: Intel: haswell: fix initialize 'NULL device *' issue
ASoC: cs4265: Fix setting dai format for Left/Right Justified
Pull drm fixes from Daniel Vetter:
"One i915 regression fix and a drm core one since Dave's not around,
both introduced in 4.2 so not cc: stable.
The fix for the warning Ted reported isn't in here yet since he didn't
yet supply a tested-by and I can't repro this one myself (it's in
fixup code that needs firmware doing something i915 wouldn't do)"
* tag 'drm-intel-fixes-2015-08-07' of git://anongit.freedesktop.org/drm-intel:
drm/vblank: Use u32 consistently for vblank counters
