path: root/include
2014-10-15Merge branch 'for-3.18-consistent-ops' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu consistent-ops changes from Tejun Heo: "Way back, before the current percpu allocator was implemented, static and dynamic percpu memory areas were allocated and handled separately and had their own accessors. The distinction has been gone for many years now; however, the now duplicate two sets of accessors remained with the pointer based ones - this_cpu_*() - evolving various other operations over time. During the process, we also accumulated other inconsistent operations. This pull request contains Christoph's patches to clean up the duplicate accessor situation. __get_cpu_var() uses are replaced with with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr(). Unfortunately, the former sometimes is tricky thanks to C being a bit messy with the distinction between lvalues and pointers, which led to a rather ugly solution for cpumask_var_t involving the introduction of this_cpu_cpumask_var_ptr(). This converts most of the uses but not all. Christoph will follow up with the remaining conversions in this merge window and hopefully remove the obsolete accessors" * 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits) irqchip: Properly fetch the per cpu offset percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write. percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t Revert "powerpc: Replace __get_cpu_var uses" percpu: Remove __this_cpu_ptr clocksource: Replace __this_cpu_ptr with raw_cpu_ptr sparc: Replace __get_cpu_var uses avr32: Replace __get_cpu_var with __this_cpu_write blackfin: Replace __get_cpu_var uses tile: Use this_cpu_ptr() for hardware counters tile: Replace __get_cpu_var uses powerpc: Replace __get_cpu_var uses alpha: Replace __get_cpu_var ia64: Replace __get_cpu_var uses s390: cio driver &__get_cpu_var replacements s390: Replace __get_cpu_var uses mips: Replace __get_cpu_var uses MIPS: Replace __get_cpu_var uses in FPU emulator. arm: Replace __this_cpu_ptr with raw_cpu_ptr ...
2014-10-15Merge tag 'llvmlinux-for-v3.18' of ↵Linus Torvalds
git://git.linuxfoundation.org/llvmlinux/kernel Pull LLVM updates from Behan Webster: "These patches remove the use of VLAIS using a new SHASH_DESC_ON_STACK macro. Some of the previously accepted VLAIS removal patches haven't used this macro. I will push new patches to consistently use this macro in all those older cases for 3.19" [ More LLVM patches coming in through subsystem trees, and LLVM itself needs some fixes that are already in many distributions but not in released versions of LLVM. Some day this will all "just work" - Linus ] * tag 'llvmlinux-for-v3.18' of git://git.linuxfoundation.org/llvmlinux/kernel: crypto: LLVMLinux: Remove VLAIS usage from crypto/testmgr.c security, crypto: LLVMLinux: Remove VLAIS from ima_crypto.c crypto: LLVMLinux: Remove VLAIS usage from libcrc32c.c crypto: LLVMLinux: Remove VLAIS usage from crypto/hmac.c crypto, dm: LLVMLinux: Remove VLAIS usage from dm-crypt crypto: LLVMLinux: Remove VLAIS from crypto/.../qat_algs.c crypto: LLVMLinux: Remove VLAIS from crypto/omap_sham.c crypto: LLVMLinux: Remove VLAIS from crypto/n2_core.c crypto: LLVMLinux: Remove VLAIS from crypto/mv_cesa.c crypto: LLVMLinux: Remove VLAIS from crypto/ccp/ccp-crypto-sha.c btrfs: LLVMLinux: Remove VLAIS crypto: LLVMLinux: Add macro to remove use of VLAIS in crypto code
2014-10-15Merge tag 'iommu-updates-v3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "This pull-request includes: - change in the IOMMU-API to convert the former iommu_domain_capable function to just iommu_capable - various fixes in handling RMRR ranges for the VT-d driver (one fix requires a device driver core change which was acked by Greg KH) - the AMD IOMMU driver now assigns and deassigns complete alias groups to fix issues with devices using the wrong PCI request-id - MMU-401 support for the ARM SMMU driver - multi-master IOMMU group support for the ARM SMMU driver - various other small fixes all over the place" * tag 'iommu-updates-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (41 commits) iommu/vt-d: Work around broken RMRR firmware entries iommu/vt-d: Store bus information in RMRR PCI device path iommu/vt-d: Only remove domain when device is removed driver core: Add BUS_NOTIFY_REMOVED_DEVICE event iommu/amd: Fix devid mapping for ivrs_ioapic override iommu/irq_remapping: Fix the regression of hpet irq remapping iommu: Fix bus notifier breakage iommu/amd: Split init_iommu_group() from iommu_init_device() iommu: Rework iommu_group_get_for_pci_dev() iommu: Make of_device_id array const amd_iommu: do not dereference a NULL pointer address. iommu/omap: Remove omap_iommu unused owner field iommu: Remove iommu_domain_has_cap() API function IB/usnic: Convert to use new iommu_capable() API function vfio: Convert to use new iommu_capable() API function kvm: iommu: Convert to use new iommu_capable() API function iommu/tegra: Convert to iommu_capable() API function iommu/msm: Convert to iommu_capable() API function iommu/vt-d: Convert to iommu_capable() API function iommu/fsl: Convert to iommu_capable() API function ...
2014-10-15Merge tag 'clk-for-linus-3.18' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock tree updates from Mike Turquette: "The clk tree changes for 3.18 are dominated by clock drivers. Mostly fixes and enhancements to existing drivers as well as new drivers. This tag contains a bit more arch code than I usually take due to some OMAP2+ changes. Additionally it contains the restart notifier handlers which are merged as a dependency into several trees. The PXA changes are the only messy part. Due to having a stable tree I had to revert one patch and follow up with one more fix near the tip of this tag. Some dead code is introduced but it will soon become live code after 3.18-rc1 is released as the rest of the PXA family is converted over to the common clock framework. Another trend in this tag is that multiple vendors have started to push the complexity of changing their CPU frequency into the clock driver, whereas this used to be done in CPUfreq drivers. Changes to the clk core include a generic gpio-clock type and a clk_set_phase() function added to the top-level clk.h api. Due to some confusion on the fbdev mailing list the kernel boot parameters documentation was updated to further explain the clk_ignore_unused parameter, which is often required by users of the simplefb driver. Finally some fixes to the locking around the clock debugfs stuff was done to prevent deadlocks when interacting with other subsystems." * tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits) clk: pxa clocks build system fix Revert "arm: pxa: Transition pxa27x to clk framework" clk: samsung: register restart handlers for s3c2412 and s3c2443 clk: rockchip: add restart handler clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate doc/kernel-parameters.txt: clarify clk_ignore_unused arm: pxa: Transition pxa27x to clk framework dts: add devicetree bindings for pxa27x clocks clk: add pxa27x clock drivers arm: pxa: add clock pll selection bits clk: dts: document pxa clock binding clk: add pxa clocks infrastructure clk: gpio-gate: Ensure gpiod_ APIs are prototyped clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe clk: ti: LLVMLinux: Move __init outside of type definition clk: ti: consider the fact that of_clk_get() might return an error clk: ti: dra7-atl-clock: fix a memory leak clk: ti: change clock init to use generic of_clk_init clk: hix5hd2: add I2C clocks clk: hix5hd2: add watchdog0 clocks ...
2014-10-15Merge tag 'mfd-for-linus-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030 - Export symbols for use in modules in max14577 - Plenty of static code analysis/Coccinelle fixes throughout the SS - Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808 - Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona - Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr - IRQ fixups in arizona, stmpe, max14577 - Regulator related changes in axp20x - Pass DMA coherency information from parent => child in MFD core - Rename DT document files for consistency - Add ACPI support to the MFD core - Add Andreas Werner to MAINTAINERS for MEN F21BMC New drivers/supported devices: - New driver for MEN 14F021P00 Board Management Controller - New driver for Ricoh RN5T618 PMIC - New driver for Rockchip RK808 - New driver for HiSilicon Hi6421 PMIC - New driver for Qualcomm SPMI PMICs - Add support for Intel Braswell in lpc_ich - Add support for Intel 9 Series PCH in lpc_ich - Add support for Intel Quark ILB in lpc_sch" [ Delayed to after the poweer/reset pull due to Kconfig problems with recursive Kconfig select/depends-on chains. - Linus ] * tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits) mfd: cros_ec: wait for completion of commands that return IN_PROGRESS i2c: i2c-cros-ec-tunnel: Set retries to 3 mfd: cros_ec: move locking into cros_ec_cmd_xfer mfd: cros_ec: stop calling ->cmd_xfer() directly mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC mfd: arizona: Correct mask to allow setting micbias external cap mfd: Add ACPI support Revert "mfd: wm5102: Manually apply register patch" mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention mfd: Inherit coherent_dma_mask from parent device mfd: Document DT bindings for Qualcomm SPMI PMICs mfd: Add support for Qualcomm SPMI PMICs mfd: dt-bindings: pm8xxx: Add new compatible string mfd: axp209x: Drop the parent supplies field mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off mfd: dt-bindings: twl4030-power: Use the standard property to mark power control mfd: syscon: Add Atmel GPBR DT bindings documention ...
2014-10-15Merge tag 'for-v3.18' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply and reset updates from Sebastian Reichel: - Initial support for the following chips * max77836 (charger) * max14577 (charger) * bq27742 (battery gauge) * ltc2952 (poweroff) * stih416 (restart) * syscon-reboot (restart) * gpio-restart (restart) - cleanup of power supply core - misc fixes in power supply and reset drivers * tag 'for-v3.18' of git://git.infradead.org/battery-2.6: (48 commits) power: ab8500_fg: Fix build warning Documentation: charger: max14577: Update the date of introducing ABI power: reset: corrections for simple syscon reboot driver Documentation: power: reset: Add documentation for generic SYSCON reboot driver power: reset: Add generic SYSCON register mapped reset bq27x00_battery: Fix flag reading for bq27742 power: reset: use restart_notifier mechanism for msm-poweroff power: Add simple gpio-restart driver power: reset: st: Provide DT bindings for ST's Power Reset driver power: reset: Add restart functionality for STiH41x platforms power: charger-manager: Fix NULL pointer exception with missing cm-fuel-gauge power: max14577: Fix circular config SYSFS dependency power: gpio-charger: do not use gpio value directly power: max8925: Use of_get_child_by_name power: max8925: Fix NULL ptr dereference on memory allocation failure bq27x00_battery: Add support to bq27742 Documentation: charger: max14577: Document exported sysfs entry devicetree: mfd: max14577: Add device tree bindings document power: max17040: Add ID for MAX77836 Fuel Gauge block charger: max14577: Configure battery-dependent settings from DTS and sysfs ... Conflicts: drivers/power/reset/Kconfig drivers/power/reset/Makefile
2014-10-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates from Sage Weil: "There is the long-awaited discard support for RBD (Guangliang Zhao, Josh Durgin), a pile of RBD bug fixes that didn't belong in late -rc's (Ilya Dryomov, Li RongQing), a pile of fs/ceph bug fixes and performance and debugging improvements (Yan, Zheng, John Spray), and a smattering of cleanups (Chao Yu, Fabian Frederick, Joe Perches)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (40 commits) ceph: fix divide-by-zero in __validate_layout() rbd: rbd workqueues need a resque worker libceph: ceph-msgr workqueue needs a resque worker ceph: fix bool assignments libceph: separate multiple ops with commas in debugfs output libceph: sync osd op definitions in rados.h libceph: remove redundant declaration ceph: additional debugfs output ceph: export ceph_session_state_name function ceph: include the initial ACL in create/mkdir/mknod MDS requests ceph: use pagelist to present MDS request data libceph: reference counting pagelist ceph: fix llistxattr on symlink ceph: send client metadata to MDS ceph: remove redundant code for max file size verification ceph: remove redundant io_iter_advance() ceph: move ceph_find_inode() outside the s_mutex ceph: request xattrs if xattr_version is zero rbd: set the remaining discard properties to enable support rbd: use helpers to handle discard for layered images correctly ...
2014-10-14libceph: sync osd op definitions in rados.hIlya Dryomov
Bring in missing osd ops and strings, use macros to eliminate multiple points of maintenance. Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-10-14libceph: remove redundant declarationFabian Frederick
ceph_release_page_vector was defined twice in libceph.h Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
2014-10-14libceph: reference counting pagelistYan, Zheng
this allow pagelist to present data that may be sent multiple times. Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-10-14crypto: LLVMLinux: Add macro to remove use of VLAIS in crypto codeBehan Webster
Add a macro which replaces the use of a Variable Length Array In Struct (VLAIS) with a C99 compliant equivalent. This macro instead allocates the appropriate amount of memory using an char array. The new code can be compiled with both gcc and clang. struct shash_desc contains a flexible array member member ctx declared with CRYPTO_MINALIGN_ATTR, so sizeof(struct shash_desc) aligns the beginning of the array declared after struct shash_desc with long long. No trailing padding is required because it is not a struct type that can be used in an array. The CRYPTO_MINALIGN_ATTR is required so that desc is aligned with long long as would be the case for a struct containing a member with CRYPTO_MINALIGN_ATTR. If you want to get to the ctx at the end of the shash_desc as before you can do so using shash_desc_ctx(shash) Signed-off-by: Behan Webster <behanw@converseincode.com> Reviewed-by: Mark Charlebois <charlebm@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michał Mirosław <mirqus@gmail.com>
2014-10-14Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main git pull for the drm, I pretty much froze major pulls at -rc5/6 time, and haven't had much fallout, so will probably continue doing that. Lots of changes all over, big internal header cleanup to make it clear drm features are legacy things and what are things that modern KMS drivers should be using. Also big move to use the new generic fences in all the TTM drivers. core: atomic prep work, vblank rework changes, allows immediate vblank disables major header reworking and cleanups to better delinate legacy interfaces from what KMS drivers should be using. cursor planes locking fixes ttm: move to generic fences (affects all TTM drivers) ppc64 caching fixes radeon: userptr support, uvd for old asics, reset rework for fence changes better buffer placement changes, dpm feature enablement hdmi audio support fixes intel: Cherryview work, 180 degree rotation, skylake prep work, execlist command submission full ppgtt prep work cursor improvements edid caching, vdd handling improvements nouveau: fence reworking kepler memory clock work gt21x clock work fan control improvements hdmi infoframe fixes DP audio ast: ppc64 fixes caching fix rcar: rcar-du DT support ipuv3: prep work for capture support msm: LVDS support for mdp4, new panel, gpu refactoring exynos: exynos3250 SoC support, drop bad mmap interface, mipi dsi changes, and component match support" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (640 commits) drm/mst: rework payload table allocation to conform better. drm/ast: Fix HW cursor image drm/radeon/kv: add uvd/vce info to dpm debugfs output drm/radeon/ci: add uvd/vce info to dpm debugfs output drm/radeon: export reservation_object from dmabuf to ttm drm/radeon: cope with foreign fences inside the reservation object drm/radeon: cope with foreign fences inside display drm/core: use helper to check driver features drm/radeon/cik: write gfx ucode version to ucode addr reg drm/radeon/si: print full CS when we hit a packet 0 drm/radeon: remove unecessary includes drm/radeon/combios: declare legacy_connector_convert as static drm/radeon/atombios: declare connector convert tables as static drm/radeon: drop btc_get_max_clock_from_voltage_dependency_table drm/radeon/dpm: drop clk/voltage dependency filters for BTC drm/radeon/dpm: drop clk/voltage dependency filters for CI drm/radeon/dpm: drop clk/voltage dependency filters for SI drm/radeon/dpm: drop clk/voltage dependency filters for NI drm/radeon: disable audio when we disable hdmi (v2) drm/radeon: split audio enable between eg and r600 (v2) ...
2014-10-14Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - a few hotfixes - drivers/dma updates - MAINTAINERS updates - Quite a lot of lib/ updates - checkpatch updates - binfmt updates - autofs4 - drivers/rtc/ - various small tweaks to less used filesystems - ipc/ updates - kernel/watchdog.c changes * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (135 commits) mm: softdirty: enable write notifications on VMAs after VM_SOFTDIRTY cleared kernel/param: consolidate __{start,stop}___param[] in <linux/moduleparam.h> ia64: remove duplicate declarations of __per_cpu_start[] and __per_cpu_end[] frv: remove unused declarations of __start___ex_table and __stop___ex_table kvm: ensure hard lockup detection is disabled by default kernel/watchdog.c: control hard lockup detection default staging: rtl8192u: use %*pEn to escape buffer staging: rtl8192e: use %*pEn to escape buffer staging: wlan-ng: use %*pEhp to print SN lib80211: remove unused print_ssid() wireless: hostap: proc: print properly escaped SSID wireless: ipw2x00: print SSID via %*pE wireless: libertas: print esaped string via %*pE lib/vsprintf: add %*pE[achnops] format specifier lib / string_helpers: introduce string_escape_mem() lib / string_helpers: refactoring the test suite lib / string_helpers: move documentation to c-file include/linux: remove strict_strto* definitions arch/x86/mm/numa.c: fix boot failure when all nodes are hotpluggable fs: check bh blocknr earlier when searching lru ...
2014-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "This patch set contains the main portion of the changes for 3.18 in regard to the s390 architecture. It is a bit bigger than usual, mainly because of a new driver and the vector extension patches. The interesting bits are: - Quite a bit of work on the tracing front. Uprobes is enabled and the ftrace code is reworked to get some of the lost performance back if CONFIG_FTRACE is enabled. - To improve boot time with CONFIG_DEBIG_PAGEALLOC, support for the IPTE range facility is added. - The rwlock code is re-factored to improve writer fairness and to be able to use the interlocked-access instructions. - The kernel part for the support of the vector extension is added. - The device driver to access the CD/DVD on the HMC is added, this will hopefully come in handy to improve the installation process. - Add support for control-unit initiated reconfiguration. - The crypto device driver is enhanced to enable the additional AP domains and to allow the new crypto hardware to be used. - Bug fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (39 commits) s390/ftrace: simplify enabling/disabling of ftrace_graph_caller s390/ftrace: remove 31 bit ftrace support s390/kdump: add support for vector extension s390/disassembler: add vector instructions s390: add support for vector extension s390/zcrypt: Toleration of new crypto hardware s390/idle: consolidate idle functions and definitions s390/nohz: use a per-cpu flag for arch_needs_cpu s390/vtime: do not reset idle data on CPU hotplug s390/dasd: add support for control unit initiated reconfiguration s390/dasd: fix infinite loop during format s390/mm: make use of ipte range facility s390/setup: correct 4-level kernel page table detection s390/topology: call set_sched_topology early s390/uprobes: architecture backend for uprobes s390/uprobes: common library for kprobes and uprobes s390/rwlock: use the interlocked-access facility 1 instructions s390/rwlock: improve writer fairness s390/rwlock: remove interrupt-enabling rwlock variant. s390/mm: remove change bit override support ...
2014-10-14Merge branch 'x86-seccomp-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 seccomp changes from Ingo Molnar: "This tree includes x86 seccomp filter speedups and related preparatory work, which touches core seccomp facilities as well. The main idea is to split seccomp into two phases, to be able to enter a simple fast path for syscalls with ptrace side effects. There's no substantial user-visible (and ABI) effects expected from this, except a change in how we emit a better audit record for SECCOMP_RET_TRACE events" * 'x86-seccomp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86_64, entry: Use split-phase syscall_trace_enter for 64-bit syscalls x86_64, entry: Treat regs->ax the same in fastpath and slowpath syscalls x86: Split syscall_trace_enter into two phases x86, entry: Only call user_exit if TIF_NOHZ x86, x32, audit: Fix x32's AUDIT_ARCH wrt audit seccomp: Document two-phase seccomp and arch-provided seccomp_data seccomp: Allow arch code to provide seccomp_data seccomp: Refactor the filter callback and the API seccomp,x86,arm,mips,s390: Remove nr parameter from secure_computing
2014-10-14Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 platform updates from Ingo Molnar: "The main changes in this tree are: - fix and update Intel Quark [Galileo] SoC platform support - update IOSF chipset side band interface and make it available via debugfs - enable HPETs on Soekris net6501 and other e6xx based systems" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Add cpu_detect_cache_sizes to init_intel() add Quark legacy_cache() x86: Quark: Comment setup_arch() to document TLB/PGE bug x86/intel/quark: Switch off CR4.PGE so TLB flush uses CR3 instead x86/platform/intel/iosf: Add debugfs config option for IOSF x86/platform/intel/iosf: Add better description of IOSF driver in config x86/platform/intel/iosf: Add Braswell PCI ID x86/platform/pmc_atom: Fix warning when CONFIG_DEBUG_FS=n x86: HPET force enable for e6xx based systems x86/iosf: Add debugfs support x86/iosf: Add Kconfig prompt for IOSF_MBI selection
2014-10-14mm: softdirty: enable write notifications on VMAs after VM_SOFTDIRTY clearedPeter Feiner
For VMAs that don't want write notifications, PTEs created for read faults have their write bit set. If the read fault happens after VM_SOFTDIRTY is cleared, then the PTE's softdirty bit will remain clear after subsequent writes. Here's a simple code snippet to demonstrate the bug: char* m = mmap(NULL, getpagesize(), PROT_READ | PROT_WRITE, MAP_ANONYMOUS | MAP_SHARED, -1, 0); system("echo 4 > /proc/$PPID/clear_refs"); /* clear VM_SOFTDIRTY */ assert(*m == '\0'); /* new PTE allows write access */ assert(!soft_dirty(x)); *m = 'x'; /* should dirty the page */ assert(soft_dirty(x)); /* fails */ With this patch, write notifications are enabled when VM_SOFTDIRTY is cleared. Furthermore, to avoid unnecessary faults, write notifications are disabled when VM_SOFTDIRTY is set. As a side effect of enabling and disabling write notifications with care, this patch fixes a bug in mprotect where vm_page_prot bits set by drivers were zapped on mprotect. An analogous bug was fixed in mmap by commit c9d0bf241451 ("mm: uncached vma support with writenotify"). Signed-off-by: Peter Feiner <pfeiner@google.com> Reported-by: Peter Feiner <pfeiner@google.com> Suggested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Jamie Liu <jamieliu@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14kernel/param: consolidate __{start,stop}___param[] in <linux/moduleparam.h>Geert Uytterhoeven
Consolidate the various external const and non-const declarations of __start___param[] and __stop___param in <linux/moduleparam.h>. This requires making a few struct kernel_param pointers in kernel/params.c const. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14kernel/watchdog.c: control hard lockup detection defaultUlrich Obergfell
In some cases we don't want hard lockup detection enabled by default. An example is when running as a guest. Introduce watchdog_enable_hardlockup_detector(bool) allowing those cases to disable hard lockup detection. This must be executed early by the boot processor from e.g. smp_prepare_boot_cpu, in order to allow kernel command line arguments to override it, as well as to avoid hard lockup detection being enabled before we've had a chance to indicate that it's unwanted. In summary, initial boot: default=enabled smp_prepare_boot_cpu watchdog_enable_hardlockup_detector(false): default=disabled cmdline has 'nmi_watchdog=1': default=enabled The running kernel still has the ability to enable/disable at any time with /proc/sys/kernel/nmi_watchdog us usual. However even when the default has been overridden /proc/sys/kernel/nmi_watchdog will initially show '1'. To truly turn it on one must disable/enable it, i.e. echo 0 > /proc/sys/kernel/nmi_watchdog echo 1 > /proc/sys/kernel/nmi_watchdog This patch will be immediately useful for KVM with the next patch of this series. Other hypervisor guest types may find it useful as well. [akpm@linux-foundation.org: fix build] [dzickus@redhat.com: fix compile issues on sparc] Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrew Jones <drjones@redhat.com> Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib80211: remove unused print_ssid()Andy Shevchenko
In kernel we have %*pE specifier to print an escaped buffer. All users now switched to that approach. This fixes a bug as well. The current implementation wrongly prints octal numbers: only two first digits are used in case when 3 are required and the rest of the string ends up cut off. Additionally by default the \f, \v, \a, and \e are escaped to their alphabetic representation. It's safe to do since it is currently used for messaging only. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib / string_helpers: introduce string_escape_mem()Andy Shevchenko
This is almost the opposite function to string_unescape(). Nevertheless it handles \0 and could be used for any byte buffer. The documentation is supplied together with the function prototype. The test cases covers most of the scenarios and would be expanded later on. [akpm@linux-foundation.org: avoid 1k stack consumption] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib / string_helpers: move documentation to c-fileAndy Shevchenko
The introduced function string_escape_mem() is a kind of opposite to string_unescape. We have several users of such functionality each of them created custom implementation. The series contains clean up of test suite, adding new call, and switching few users to use it via %*pE specifier. Test suite covers all of existing and most of potential use cases. This patch (of 11): The documentation of API belongs to c-file. This patch moves it accordingly. There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14include/linux: remove strict_strto* definitionsDaniel Walter
Remove obsolete and unused strict_strto* functions Signed-off-by: Daniel Walter <dwalter@google.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib: string: Make all calls to strnicmp into calls to strncasecmpRasmus Villemoes
The previous patch made strnicmp into a wrapper for strncasecmp. This patch makes all in-tree users of strnicmp call strncasecmp directly, while still making sure that the strnicmp symbol can be used by out-of-tree modules. It should be considered a temporary hack until all in-tree callers have been converted. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14x86: optimize resource lookups for ioremapMike Travis
We have a large university system in the UK that is experiencing very long delays modprobing the driver for a specific I/O device. The delay is from 8-10 minutes per device and there are 31 devices in the system. This 4 to 5 hour delay in starting up those I/O devices is very much a burden on the customer. There are two causes for requiring a restart/reload of the drivers. First is periodic preventive maintenance (PM) and the second is if any of the devices experience a fatal error. Both of these trigger this excessively long delay in bringing the system back up to full capability. The problem was tracked down to a very slow IOREMAP operation and the excessively long ioresource lookup to insure that the user is not attempting to ioremap RAM. These patches provide a speed up to that function. The modprobe time appears to be affected quite a bit by previous activity on the ioresource list, which I suspect is due to cache preloading. While the overall improvement is impacted by other overhead of starting the devices, this drastically improves the modprobe time. Also our system is considerably smaller so the percentages gained will not be the same. Best case improvement with the modprobe on our 20 device smallish system was from 'real 5m51.913s' to 'real 0m18.275s'. This patch (of 2): Since the ioremap operation is verifying that the specified address range is NOT RAM, it will search the entire ioresource list if the condition is true. To make matters worse, it does this one 4k page at a time. For a 128M BAR region this is 32 passes to determine the entire region does not contain any RAM addresses. This patch provides another resource lookup function, region_is_ram, that searches for the entire region specified, verifying that it is completely contained within the resource region. If it is found, then it is checked to be RAM or not, within a single pass. The return result reflects if it was found or not (-1), and whether it is RAM (1) or not (0). This allows the caller to fallback to the previous page by page search if it was not found. [akpm@linux-foundation.org: fix spellos and typos in comment] Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Alex Thorlton <athorlton@sgi.com> Reviewed-by: Cliff Wickman <cpw@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Mark Salter <msalter@redhat.com> Cc: Dave Young <dyoung@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14rbtree: add comment to rb_insert_augmented()Lai Jiangshan
The comment is copied from Documentation/rbtree.txt, but this comment is so important that it should also be in the code. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14kexec: take the segment adding out of locate_mem_hole functionsBaoquan He
In locate_mem_hole functions, a memory hole is located and added as kexec_segment. But from the name of locate_mem_hole, it should only take responsibility of searching a available memory hole to contain data of a specified size. So in this patch add a new field 'mem' into kexec_buf, then take that kexec segment adding code out of locate_mem_hole_top_down and locate_mem_hole_bottom_up. This make clear of the functionality of locate_mem_hole just like it declars to do. And by this locate_mem_hole_callback chould be used later if anyone want to locate a memory hole for other use. Meanwhile Vivek suggested opening code function __kexec_add_segment(), that way we have to retreive ksegment pointer once and it is easy to read. So just do it in this patch and remove __kexec_add_segment() since no one use it anymore. Signed-off-by: Baoquan He <bhe@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14signal: use BUILD_BUG() instead of _NSIG_WORDS_is_unsupported_size()Oleg Nesterov
Kill _NSIG_WORDS_is_unsupported_size(), use BUILD_BUG() instead. This simplifies the code, avoids the nested-externs warnings, and this way we do not defer the problem to linker. Also, fix the indentation in _SIG_SET_BINOP() and _SIG_SET_OP(). Note: this patch assumes that the code like "if (0) BUILD_BUG();" is valid. If not (say __compiletime_error() is not defined and thus __compiletime_error_fallback() uses a negative array) we should fix BUILD_BUG() and/or BUILD_BUG_ON_MSG(). This code should be fine by definition, this is the documented purpose of BUILD_BUG(). [sfr@canb.auug.org.au: fix powerpc build failures] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib: remove prio_heapLai Jiangshan
The prio_heap code is unused since commit 889ed9ceaa97 ("cgroup: remove css_scan_tasks()"). It should be compiled out to shrink the binary kernel size which can be done via introducing CONFIG_PRIO_HEAD or by removing the code. We can simply recover the code from git when needed, so it would be better to remove it IMO. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Kees Cook <keescook@chromium.org> Cc: Francesco Fusco <ffusco@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: George Spelvin <linux@horizon.com> Cc: Mark Salter <msalter@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14list: include linux/kernel.hMasahiro Yamada
linux/list.h uses container_of, therefore it depends on linux/kernel.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14drivers: dma-contiguous: add initialization from device treeMarek Szyprowski
Add a function to create CMA region from previously reserved memory and add support for handling 'shared-dma-pool' reserved-memory device tree nodes. Based on previous code provided by Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Josh Cartwright <joshc@codeaurora.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14kernel: add support for gcc 5Sasha Levin
We're missing include/linux/compiler-gcc5.h which is required now because gcc branched off to v5 in trunk. Just copy the relevant bits out of include/linux/compiler-gcc4.h, no new code is added as of now. This fixes a build error when using gcc 5. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-13Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle were: - Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave Hansen) - Various sched/idle refinements for better idle handling (Nicolas Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot) - sched/numa updates and optimizations (Rik van Riel) - sysbench speedup (Vincent Guittot) - capacity calculation cleanups/refactoring (Vincent Guittot) - Various cleanups to thread group iteration (Oleg Nesterov) - Double-rq-lock removal optimization and various refactorings (Kirill Tkhai) - various sched/deadline fixes ... and lots of other changes" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits) sched/dl: Use dl_bw_of() under rcu_read_lock_sched() sched/fair: Delete resched_cpu() from idle_balance() sched, time: Fix build error with 64 bit cputime_t on 32 bit systems sched: Improve sysbench performance by fixing spurious active migration sched/x86: Fix up typo in topology detection x86, sched: Add new topology for multi-NUMA-node CPUs sched/rt: Use resched_curr() in task_tick_rt() sched: Use rq->rd in sched_setaffinity() under RCU read lock sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask' sched: Use dl_bw_of() under RCU read lock sched/fair: Remove duplicate code from can_migrate_task() sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW sched: print_rq(): Don't use tasklist_lock sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock() sched: Fix the task-group check in tg_has_rt_tasks() sched/fair: Leverage the idle state info when choosing the "idlest" cpu sched: Let the scheduler see CPU idle states sched/deadline: Fix inter- exclusive cpusets migrations sched/deadline: Clear dl_entity params when setscheduling to different class sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault() ...
2014-10-13Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Kernel side updates: - Fix and enhance poll support (Jiri Olsa) - Re-enable inheritance optimization (Jiri Olsa) - Enhance Intel memory events support (Stephane Eranian) - Refactor the Intel uncore driver to be more maintainable (Zheng Yan) - Enhance and fix Intel CPU and uncore PMU drivers (Peter Zijlstra, Andi Kleen) - [ plus various smaller fixes/cleanups ] User visible tooling updates: - Add +field argument support for --field option, so that one can add fields to the default list of fields to show, ie now one can just do: perf report --fields +pid And the pid will appear in addition to the default fields (Jiri Olsa) - Add +field argument support for --sort option (Jiri Olsa) - Honour -w in the report tools (report, top), allowing to specify the widths for the histogram entries columns (Namhyung Kim) - Properly show submicrosecond times in 'perf kvm stat' (Christian Borntraeger) - Add beautifier for mremap flags param in 'trace' (Alex Snast) - perf script: Allow callchains if any event samples them - Don't truncate Intel style addresses in 'annotate' (Alex Converse) - Allow profiling when kptr_restrict == 1 for non root users, kernel samples will just remain unresolved (Andi Kleen) - Allow configuring default options for callchains in config file (Namhyung Kim) - Support operations for shared futexes. (Davidlohr Bueso) - "perf kvm stat report" improvements by Alexander Yarygin: - Save pid string in opts.target.pid - Enable the target.system_wide flag - Unify the title bar output - [ plus lots of other fixes and small improvements. ] Tooling infrastructure changes: - Refactor unit and scale function parameters for PMU parsing routines (Matt Fleming) - Improve DSO long names lookup with rbtree, resulting in great speedup for workloads with lots of DSOs (Waiman Long) - We were not handling POLLHUP notifications for event file descriptors Fix it by filtering entries in the events file descriptor array after poll() returns, refcounting mmaps so that when the last fd pointing to a perf mmap goes away we do the unmap (Arnaldo Carvalho de Melo) - Intel PT prep work, from Adrian Hunter, including: - Let a user specify a PMU event without any config terms - Add perf-with-kcore script - Let default config be defined for a PMU - Add perf_pmu__scan_file() - Add a 'perf test' for tracking with sched_switch - Add 'flush' callback to scripting API - Use ring buffer consume method to look like other tools (Arnaldo Carvalho de Melo) - hists browser (used in top and report) refactorings, getting rid of unused variables and reducing source code size by handling similar cases in a fewer functions (Namhyung Kim). - Replace thread unsafe strerror() with strerror_r() accross the whole tools/perf/ tree (Masami Hiramatsu) - Rename ordered_samples to ordered_events and allow setting a queue size for ordering events (Jiri Olsa) - [ plus lots of fixes, cleanups and other improvements ]" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (198 commits) perf/x86: Tone down kernel messages when the PMU check fails in a virtual environment perf/x86/intel/uncore: Fix minor race in box set up perf record: Fix error message for --filter option not coming after tracepoint perf tools: Fix build breakage on arm64 targets perf symbols: Improve DSO long names lookup speed with rbtree perf symbols: Encapsulate dsos list head into struct dsos perf bench futex: Sanitize -q option in requeue perf bench futex: Support operations for shared futexes perf trace: Fix mmap return address truncation to 32-bit perf tools: Refactor unit and scale function parameters perf tools: Fix line number in the config file error message perf tools: Convert {record,top}.call-graph option to call-graph.record-mode perf tools: Introduce perf_callchain_config() perf callchain: Move some parser functions to callchain.c perf tools: Move callchain config from record_opts to callchain_param perf hists browser: Fix callchain print bug on TUI perf tools: Use ACCESS_ONCE() instead of volatile cast perf tools: Modify error code for when perf_session__new() fails perf tools: Fix perf record as non root with kptr_restrict == 1 perf stat: Fix --per-core on multi socket systems ...
2014-10-13Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Ingo Molnar: "The main updates in this cycle were: - mutex MCS refactoring finishing touches: improve comments, refactor and clean up code, reduce debug data structure footprint, etc. - qrwlock finishing touches: remove old code, self-test updates. - small rwsem optimization - various smaller fixes/cleanups" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/lockdep: Revert qrwlock recusive stuff locking/rwsem: Avoid double checking before try acquiring write lock locking/rwsem: Move EXPORT_SYMBOL() lines to follow function definition locking/rwlock, x86: Delete unused asm/rwlock.h and rwlock.S locking/rwlock, x86: Clean up asm/spinlock*.h to remove old rwlock code locking/semaphore: Resolve some shadow warnings locking/selftest: Support queued rwlock locking/lockdep: Restrict the use of recursive read_lock() with qrwlock locking/spinlocks: Always evaluate the second argument of spin_lock_nested() locking/Documentation: Update locking/mutex-design.txt disadvantages locking/Documentation: Move locking related docs into Documentation/locking/ locking/mutexes: Use MUTEX_SPIN_ON_OWNER when appropriate locking/mutexes: Refactor optimistic spinning code locking/mcs: Remove obsolete comment locking/mutexes: Document quick lock release when unlocking locking/mutexes: Standardize arguments in lock/unlock slowpaths locking: Remove deprecated smp_mb__() barriers
2014-10-13Merge branch 'locking-arch-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull arch atomic cleanups from Ingo Molnar: "This is a series kept separate from the main locking tree, which cleans up and improves various details in the atomics type handling: - Remove the unused atomic_or_long() method - Consolidate and compress atomic ops implementations between architectures, to reduce linecount and to make it easier to add new ops. - Rewrite generic atomic support to only require cmpxchg() from an architecture - generate all other methods from that" * 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read() locking, mips: Fix atomics locking, sparc64: Fix atomics locking,arch: Rewrite generic atomic support locking,arch,xtensa: Fold atomic_ops locking,arch,sparc: Fold atomic_ops locking,arch,sh: Fold atomic_ops locking,arch,powerpc: Fold atomic_ops locking,arch,parisc: Fold atomic_ops locking,arch,mn10300: Fold atomic_ops locking,arch,mips: Fold atomic_ops locking,arch,metag: Fold atomic_ops locking,arch,m68k: Fold atomic_ops locking,arch,m32r: Fold atomic_ops locking,arch,ia64: Fold atomic_ops locking,arch,hexagon: Fold atomic_ops locking,arch,cris: Fold atomic_ops locking,arch,avr32: Fold atomic_ops locking,arch,arm64: Fold atomic_ops locking,arch,arm: Fold atomic_ops ...
2014-10-13Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle were: - changes related to No-CBs CPUs and NO_HZ_FULL - RCU-tasks implementation - torture-test updates - miscellaneous fixes - locktorture updates - RCU documentation updates" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (81 commits) workqueue: Use cond_resched_rcu_qs macro workqueue: Add quiescent state between work items locktorture: Cleanup header usage locktorture: Cannot hold read and write lock locktorture: Fix __acquire annotation for spinlock irq locktorture: Support rwlocks rcu: Eliminate deadlock between CPU hotplug and expedited grace periods locktorture: Document boot/module parameters rcutorture: Rename rcutorture_runnable parameter locktorture: Add test scenario for rwsem_lock locktorture: Add test scenario for mutex_lock locktorture: Make torture scripting account for new _runnable name locktorture: Introduce torture context locktorture: Support rwsems locktorture: Add infrastructure for torturing read locks torture: Address race in module cleanup locktorture: Make statistics generic locktorture: Teach about lock debugging locktorture: Support mutexes locktorture: Add documentation ...
2014-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The big thing in this pile is Eric's unmount-on-rmdir series; we finally have everything we need for that. The final piece of prereqs is delayed mntput() - now filesystem shutdown always happens on shallow stack. Other than that, we have several new primitives for iov_iter (Matt Wilcox, culled from his XIP-related series) pushing the conversion to ->read_iter()/ ->write_iter() a bit more, a bunch of fs/dcache.c cleanups and fixes (including the external name refcounting, which gives consistent behaviour of d_move() wrt procfs symlinks for long and short names alike) and assorted cleanups and fixes all over the place. This is just the first pile; there's a lot of stuff from various people that ought to go in this window. Starting with unionmount/overlayfs mess... ;-/" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (60 commits) fs/file_table.c: Update alloc_file() comment vfs: Deduplicate code shared by xattr system calls operating on paths reiserfs: remove pointless forward declaration of struct nameidata don't need that forward declaration of struct nameidata in dcache.h anymore take dname_external() into fs/dcache.c let path_init() failures treated the same way as subsequent link_path_walk() fix misuses of f_count() in ppp and netlink ncpfs: use list_for_each_entry() for d_subdirs walk vfs: move getname() from callers to do_mount() gfs2_atomic_open(): skip lookups on hashed dentry [infiniband] remove pointless assignments gadgetfs: saner API for gadgetfs_create_file() f_fs: saner API for ffs_sb_create_file() jfs: don't hash direct inode [s390] remove pointless assignment of ->f_op in vmlogrdr ->open() ecryptfs: ->f_op is never NULL android: ->f_op is never NULL nouveau: __iomem misannotations missing annotation in fs/file.c fs: namespace: suppress 'may be used uninitialized' warnings ...
2014-10-13drm/mst: rework payload table allocation to conform better.Dave Airlie
The old code has problems with the Dell MST monitors due to some assumptions I made that weren't true. I initially thought the Virtual Channel Payload IDs had to be in the DPCD table in ascending order, however it appears that assumption is bogus. The old code also assumed it was possible to insert a member into the table and it would move other members up, like it does when you remove table entries, however reality has shown this isn't true. So the new code allocates VCPIs separate from entries in the payload tracking table, and when we remove an entry from the DPCD table, I shuffle the tracking payload entries around in the struct. This appears to make VT switch more robust (still not perfect) with an MST enabled Dell monitor. Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-10-12don't need that forward declaration of struct nameidata in dcache.h anymoreAl Viro
2014-10-12take dname_external() into fs/dcache.cAl Viro
never used outside and it's too low-level for legitimate uses outside of fs/dcache.c anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris. Mostly ima, selinux, smack and key handling updates. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) integrity: do zero padding of the key id KEYS: output last portion of fingerprint in /proc/keys KEYS: strip 'id:' from ca_keyid KEYS: use swapped SKID for performing partial matching KEYS: Restore partial ID matching functionality for asymmetric keys X.509: If available, use the raw subjKeyId to form the key description KEYS: handle error code encoded in pointer selinux: normalize audit log formatting selinux: cleanup error reporting in selinux_nlmsg_perm() KEYS: Check hex2bin()'s return when generating an asymmetric key ID ima: detect violations for mmaped files ima: fix race condition on ima_rdwr_violation_check and process_measurement ima: added ima_policy_flag variable ima: return an error code from ima_add_boot_aggregate() ima: provide 'ima_appraise=log' kernel option ima: move keyring initialization to ima_init() PKCS#7: Handle PKCS#7 messages that contain no X.509 certs PKCS#7: Better handling of unsupported crypto KEYS: Overhaul key identification when searching for asymmetric keys KEYS: Implement binary asymmetric key ID handling ...
2014-10-12Merge tag 'trace-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This set has a few minor updates, but the big change is the redesign of the trampoline logic. The trampoline logic of 3.17 required a descriptor for every function that is registered to be traced and uses a trampoline. Currently, only the function graph tracer uses a trampoline, but if you were to trace all 32,000 (give or take a few thousand) functions with the function graph tracer, it would create 32,000 descriptors to let us know that there's a trampoline associated with it. This takes up a bit of memory when there's a better way to do it. The redesign now reuses the ftrace_ops' (what registers the function graph tracer) hash tables. The hash tables tell ftrace what the tracer wants to trace or doesn't want to trace. There's two of them: one that tells us what to trace, the other tells us what not to trace. If the first one is empty, it means all functions should be traced, otherwise only the ones that are listed should be. The second hash table tells us what not to trace, and if it is empty, all functions may be traced, and if there's any listed, then those should not be traced even if they exist in the first hash table. It took a bit of massaging, but now these hashes can be used to keep track of what has a trampoline and what does not, and allows the ftrace accounting to work. Now we can trace all functions when using the function graph trampoline, and avoid needing to create any special descriptors to hold all the functions that are being traced" * tag 'trace-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace: Only disable ftrace_enabled to test buffer in selftest ftrace: Add sanity check when unregistering last ftrace_ops kernel: trace_syscalls: Replace rcu_assign_pointer() with RCU_INIT_POINTER() tracing: generate RCU warnings even when tracepoints are disabled ftrace: Replace tramp_hash with old_*_hash to save space ftrace: Annotate the ops operation on update ftrace: Grab any ops for a rec for enabled_functions output ftrace: Remove freeing of old_hash from ftrace_hash_move() ftrace: Set callback to ftrace_stub when no ops are registered ftrace: Add helper function ftrace_ops_get_func() ftrace: Add separate function for non recursive callbacks
2014-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "This set fixes a bunch of fallout from the changes that went in during this merge window, particularly: - Fix fsl_pq_mdio (Claudiu Manoil) and fm10k (Pranith Kumar) build failures. - Several networking drivers do atomic_set() on page counts where that's not exactly legal. From Eric Dumazet. - Make __skb_flow_get_ports() work cleanly with unaligned data, from Alexander Duyck. - Fix some kernel-doc buglets in rfkill and netlabel, from Fabian Frederick. - Unbalanced enable_irq_wake usage in bcmgenet and systemport drivers, from Florian Fainelli. - pxa168_eth needs to depend on HAS_DMA, from Geert Uytterhoeven. - Multi-dequeue in the qdisc layer severely bypasses the fairness limits the previous code used to enforce, reintroduce in a way that at the same time doesn't compromise bulk dequeue opportunities. From Jesper Dangaard Brouer. - macvlan receive path unnecessarily hops through a softirq by using netif_rx() instead of netif_receive_skb(). From Jason Baron" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (51 commits) net: systemport: avoid unbalanced enable_irq_wake calls net: bcmgenet: avoid unbalanced enable_irq_wake calls net: bcmgenet: fix off-by-one in incrementing read pointer net: fix races in page->_count manipulation mlx4: fix race accessing page->_count ixgbe: fix race accessing page->_count igb: fix race accessing page->_count fm10k: fix race accessing page->_count net/phy: micrel: Add clock support for KSZ8021/KSZ8031 flow-dissector: Fix alignment issue in __skb_flow_get_ports net: filter: fix the comments Documentation: replace __sk_run_filter with __bpf_prog_run macvlan: optimize the receive path macvlan: pass 'bool' type to macvlan_count_rx() drivers: net: xgene: Add 10GbE ethtool support drivers: net: xgene: Add 10GbE support drivers: net: xgene: Preparing for adding 10GbE support dtb: Add 10GbE node to APM X-Gene SoC device tree Documentation: dts: Update section header for APM X-Gene MAINTAINERS: Update APM X-Gene section ...
2014-10-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: "Here's a first pull request for powerpc updates for 3.18. The bulk of the additions are for the "cxl" driver, for IBM's Coherent Accelerator Processor Interface (CAPI). Most of it's in drivers/misc, which Greg & Arnd maintain, Greg said he was happy for us to take it through our tree. There's the usual minor cleanups and fixes, including a bit of noise in drivers from some of those. A bunch of updates to our EEH code, which has been getting more testing. Several nice speedups from Anton, including 20% in clear_page(). And a bunch of updates for freescale from Scott" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (130 commits) cxl: Fix afu_read() not doing finish_wait() on signal or non-blocking cxl: Add documentation for userspace APIs cxl: Add driver to Kbuild and Makefiles cxl: Add userspace header file cxl: Driver code for powernv PCIe based cards for userspace access cxl: Add base builtin support powerpc/mm: Add hooks for cxl powerpc/opal: Add PHB to cxl mode call powerpc/mm: Add new hash_page_mm() powerpc/powerpc: Add new PCIe functions for allocating cxl interrupts cxl: Add new header for call backs and structs powerpc/powernv: Split out set MSI IRQ chip code powerpc/mm: Export mmu_kernel_ssize and mmu_linear_psize powerpc/msi: Improve IRQ bitmap allocator powerpc/cell: Make spu_flush_all_slbs() generic powerpc/cell: Move data segment faulting code out of cell platform powerpc/cell: Move spu_handle_mm_fault() out of cell platform powerpc/pseries: Use new defines when calling H_SET_MODE powerpc: Update contact info in Documentation files powerpc/perf/hv-24x7: Simplify catalog_read() ...
2014-10-11Merge tag 'stable/for-linus-3.18-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from David Vrabel: "Features and fixes: - Add pvscsi frontend and backend drivers. - Remove _PAGE_IOMAP PTE flag, freeing it for alternate uses. - Try and keep memory contiguous during PV memory setup (reduces SWIOTLB usage). - Allow front/back drivers to use threaded irqs. - Support large initrds in PV guests. - Fix PVH guests in preparation for Xen 4.5" * tag 'stable/for-linus-3.18-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (22 commits) xen: remove DEFINE_XENBUS_DRIVER() macro xen/xenbus: Remove BUG_ON() when error string trucated xen/xenbus: Correct the comments for xenbus_grant_ring() x86/xen: Set EFER.NX and EFER.SCE in PVH guests xen: eliminate scalability issues from initrd handling xen: sync some headers with xen tree xen: make pvscsi frontend dependant on xenbus frontend arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen options xen-scsifront: don't deadlock if the ring becomes full x86: remove the Xen-specific _PAGE_IOMAP PTE flag x86/xen: do not use _PAGE_IOMAP PTE flag for I/O mappings x86: skip check for spurious faults for non-present faults xen/efi: Directly include needed headers xen-scsiback: clean up a type issue in scsiback_make_tpg() xen-scsifront: use GFP_ATOMIC under spin_lock MAINTAINERS: Add xen pvscsi maintainer xen-scsiback: Add Xen PV SCSI backend driver xen-scsifront: Add Xen PV SCSI frontend driver xen: Add Xen pvSCSI protocol description xen/events: support threaded irqs for interdomain event channels ...
2014-10-11Merge tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking related changes from Jeff Layton: "This release is a little more busy for file locking changes than the last: - a set of patches from Kinglong Mee to fix the lockowner handling in knfsd - a pile of cleanups to the internal file lease API. This should get us a bit closer to allowing for setlease methods that can block. There are some dependencies between mine and Bruce's trees this cycle, and I based my tree on top of the requisite patches in Bruce's tree" * tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linux: (26 commits) locks: fix fcntl_setlease/getlease return when !CONFIG_FILE_LOCKING locks: flock_make_lock should return a struct file_lock (or PTR_ERR) locks: set fl_owner for leases to filp instead of current->files locks: give lm_break a return value locks: __break_lease cleanup in preparation of allowing direct removal of leases locks: remove i_have_this_lease check from __break_lease locks: move freeing of leases outside of i_lock locks: move i_lock acquisition into generic_*_lease handlers locks: define a lm_setup handler for leases locks: plumb a "priv" pointer into the setlease routines nfsd: don't keep a pointer to the lease in nfs4_file locks: clean up vfs_setlease kerneldoc comments locks: generic_delete_lease doesn't need a file_lock at all nfsd: fix potential lease memory leak in nfs4_setlease locks: close potential race in lease_get_mtime security: make security_file_set_fowner, f_setown and __f_setown void return locks: consolidate "nolease" routines locks: remove lock_may_read and lock_may_write lockd: rip out deferred lock handling from testlock codepath NFSD: Get reference of lockowner when coping file_lock ...
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "The largest set of changes here come from Miao Xie. He's cleaning up and improving read recovery/repair for raid, and has a number of related fixes. I've merged another set of fsync fixes from Filipe, and he's also improved the way we handle metadata write errors to make sure we force the FS readonly if things go wrong. Otherwise we have a collection of fixes and cleanups. Dave Sterba gets a cookie for removing the most lines (thanks Dave)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (139 commits) btrfs: Fix compile error when CONFIG_SECURITY is not set. Btrfs: fix compiles when CONFIG_BTRFS_FS_RUN_SANITY_TESTS is off btrfs: Make btrfs handle security mount options internally to avoid losing security label. Btrfs: send, don't delay dir move if there's a new parent inode btrfs: add more superblock checks Btrfs: fix race in WAIT_SYNC ioctl Btrfs: be aware of btree inode write errors to avoid fs corruption Btrfs: remove redundant btrfs_verify_qgroup_counts declaration. btrfs: fix shadow warning on cmp Btrfs: fix compilation errors under DEBUG Btrfs: fix crash of btrfs_release_extent_buffer_page Btrfs: add missing end_page_writeback on submit_extent_page failure btrfs: Fix the wrong condition judgment about subset extent map Btrfs: fix build_backref_tree issue with multiple shared blocks Btrfs: cleanup error handling in build_backref_tree btrfs: move checks for DUMMY_ROOT into a helper btrfs: new define for the inline extent data start btrfs: kill extent_buffer_page helper btrfs: drop constant param from btrfs_release_extent_buffer_page btrfs: hide typecast to definition of BTRFS_SEND_TRANS_STUB ...
2014-10-11Merge tag 'vfio-v3.18-rc1' of git://github.com/awilliam/linux-vfioLinus Torvalds
Pull VFIO updates from Alex Williamson: - Nested IOMMU extension to type1 (Will Deacon) - Restore MSIx message before enabling (Gavin Shan) - Fix remove path locking (Alex Williamson) * tag 'vfio-v3.18-rc1' of git://github.com/awilliam/linux-vfio: vfio-pci: Fix remove path locking drivers/vfio: Export vfio_spapr_iommu_eeh_ioctl() with GPL vfio/pci: Restore MSIx message prior to enabling PCI: Export MSI message relevant functions vfio/iommu_type1: add new VFIO_TYPE1_NESTING_IOMMU IOMMU type iommu: introduce domain attribute for nesting IOMMUs
2014-10-11Merge tag 'devicetree-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree changes from Grant Likely: "This branch contains bug fixes and new features for the devicetree code. Most of the changes are either new testcases for the selftest code or documentation changes. The most notable change is the addition of a phandle resolver for use when grafting in a second device tree blob into the core tree. The resolver isn't currently used by anything other than the selftest module, but it will be used to support device tree overlays; probably in the v3.19 timeframe. Also note that I've moved my normal tree from git.secretlab.ca to git.kernel.org" * tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: of/selftest: Move hash table off stack to fix large frame size To remove non-ascii characters in of_selftest.txt of/selftest: Use the resolver to fixup phandles of: Introduce Device Tree resolve support. of/selftest: Add a test for duplicate phandles of: Don't try to search when phandle == 0 of/selftest: Test structure of device tree of: Fix NULL dereference in selftest removal code of: add vendor prefix for Chipidea of: Add vendor prefix for Innolux Corporation of: Add vendor prefix for Sitronix devicetree: bindings: Document Gateworks vendor prefix of: Add vendor prefix for Energy Micro dt/documentation: add specification of dma bus information
