path: root/include
2017-01-26swiotlb: Add swiotlb=noforce debug optionGeert Uytterhoeven
commit fff5d99225107f5f13fe4a9805adc2a1c4b5fb00 upstream. On architectures like arm64, swiotlb is tied intimately to the core architecture DMA support. In addition, ZONE_DMA cannot be disabled. To aid debugging and catch devices not supporting DMA to memory outside the 32-bit address space, add a kernel command line option "swiotlb=noforce", which disables the use of bounce buffers. If specified, trying to map memory that cannot be used with DMA will fail, and a rate-limited warning will be printed. Note that io_tlb_nslabs is set to 1, which is the minimal supported value. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26swiotlb: Convert swiotlb_force from int to enumGeert Uytterhoeven
commit ae7871be189cb41184f1e05742b4a99e2c59774d upstream. Convert the flag swiotlb_force from an int to an enum, to prepare for the advent of more possible values. Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26sunrpc: don't call sleeping functions from the notifier block callbacksScott Mayhew
commit 546125d1614264d26080817d0c8cddb9b25081fa upstream. The inet6addr_chain is an atomic notifier chain, so we can't call anything that might sleep (like lock_sock)... instead of closing the socket from svc_age_temp_xprts_now (which is called by the notifier function), just have the rpc service threads do it instead. Fixes: c3d4879e01be "sunrpc: Add a function to close..." Signed-off-by: Scott Mayhew <smayhew@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26rcu: Narrow early boot window of illegal synchronous grace periodsPaul E. McKenney
commit 52d7e48b86fc108e45a656d8e53e4237993c481d upstream. The current preemptible RCU implementation goes through three phases during bootup. In the first phase, there is only one CPU that is running with preemption disabled, so that a no-op is a synchronous grace period. In the second mid-boot phase, the scheduler is running, but RCU has not yet gotten its kthreads spawned (and, for expedited grace periods, workqueues are not yet running. During this time, any attempt to do a synchronous grace period will hang the system (or complain bitterly, depending). In the third and final phase, RCU is fully operational and everything works normally. This has been OK for some time, but there has recently been some synchronous grace periods showing up during the second mid-boot phase. This code worked "by accident" for awhile, but started failing as soon as expedited RCU grace periods switched over to workqueues in commit 8b355e3bc140 ("rcu: Drive expedited grace periods from workqueue"). Note that the code was buggy even before this commit, as it was subject to failure on real-time systems that forced all expedited grace periods to run as normal grace periods (for example, using the rcu_normal ksysfs parameter). The callchain from the failure case is as follows: early_amd_iommu_init() |-> acpi_put_table(ivrs_base); |-> acpi_tb_put_table(table_desc); |-> acpi_tb_invalidate_table(table_desc); |-> acpi_tb_release_table(...) |-> acpi_os_unmap_memory |-> acpi_os_unmap_iomem |-> acpi_os_map_cleanup |-> synchronize_rcu_expedited The kernel showing this callchain was built with CONFIG_PREEMPT_RCU=y, which caused the code to try using workqueues before they were initialized, which did not go well. This commit therefore reworks RCU to permit synchronous grace periods to proceed during this mid-boot phase. This commit is therefore a fix to a regression introduced in v4.9, and is therefore being put forward post-merge-window in v4.10. This commit sets a flag from the existing rcu_scheduler_starting() function which causes all synchronous grace periods to take the expedited path. The expedited path now checks this flag, using the requesting task to drive the expedited grace period forward during the mid-boot phase. Finally, this flag is updated by a core_initcall() function named rcu_exp_runtime_mode(), which causes the runtime codepaths to be used. Note that this arrangement assumes that tasks are not sent POSIX signals (or anything similar) from the time that the first task is spawned through core_initcall() time. Fixes: 8b355e3bc140 ("rcu: Drive expedited grace periods from workqueue") Reported-by: "Zheng, Lv" <lv.zheng@intel.com> Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Stan Kain <stan.kain@gmail.com> Tested-by: Ivan <waffolz@hotmail.com> Tested-by: Emanuel Castelo <emanuel.castelo@gmail.com> Tested-by: Bruno Pesavento <bpesavento@infinito.it> Tested-by: Borislav Petkov <bp@suse.de> Tested-by: Frederic Bezies <fredbezies@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26ARM: dts: r8a7794: remove Z clockSergei Shtylyov
commit 68cc085a4daaa32f7138de1e918331c05165a484 upstream. R8A7794 doesn't have Cortex-A15 CPUs, thus there's no Z clock... Fixes: 0dce5454d5c2 ("ARM: shmobile: Initial r8a7794 SoC device tree") Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19power: supply: bq27xxx_battery: Fix register map for BQ27510 and BQ27520Andrew F. Davis
commit 3bee9ea1de687925d116670f036599cbed8b66b0 upstream. The BQ27510 and BQ27520 use a slightly different register map than the BQ27500, add a new type enum and add these gauges to it. Fixes: d74534c27775 ("power: bq27xxx_battery: Add support for additional bq27xxx family devices") Based-on-patch-by: Kenneth R. Crudup <kenny@panix.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Sebastian Reichel <sre@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19block: Change extern inline to static inlineTobias Klauser
commit 9a05e7541c39680d28ecf91892338e074738d5fd upstream. With compilers which follow the C99 standard (like modern versions of gcc and clang), "extern inline" does the opposite thing from older versions of gcc (emits code for an externally linkable version of the inline function). "static inline" does the intended behavior in all cases instead. Description taken from commit 6d91857d4826 ("staging, rtl8192e, LLVMLinux: Change extern inline to static inline"). This also fixes the following GCC warning when building with CONFIG_PM disabled: ./include/linux/blkdev.h:1143:20: warning: no previous prototype for 'blk_set_runtime_active' [-Wmissing-prototypes] Fixes: d07ab6d11477 ("block: Add blk_set_runtime_active()") Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19ASoC: hdmi-codec: use unsigned type to structure members with bit-fieldTakashi Sakamoto
commit 9e4d59ada4d602e78eee9fb5f898ce61fdddb446 upstream. This is a fix for Linux 4.10-rc1. In C language specification, a bit-field is interpreted as a signed or unsigned integer type consisting of the specified number of bits. In GCC manual, the range of a signed bit field of N bits is from -(2^N) / 2 to ((2^N) / 2) - 1 https://www.gnu.org/software/gnu-c-manual/gnu-c-manual.html#Bit-Fields Therefore, when defined as 1 bit-field with signed type, variables can represents -1 and 0. The snd-soc-hdmi-codec module includes a structure which has signed type members with bit-fields. Codes of this module assign 0 and 1 to the members. This seems to result in implementation-dependent behaviours. As of v4.10-rc1 merge window, outside of sound subsystem, this structure is referred by below GPU modules. - tda998x - sti-drm - mediatek-drm-hdmi - msm As long as I review their codes relevant to the structure, the structure members are used just for condition statements and printk formats. My proposal of change is a bit intrusive to the printk formats but this may be acceptable. Totally, it's reasonable to use unsigned type for the structure members. This bug is detected by Sparse, static code analyzer with below warnings. ./include/sound/hdmi-codec.h:39:26: error: dubious one-bit signed bitfield ./include/sound/hdmi-codec.h:40:28: error: dubious one-bit signed bitfield ./include/sound/hdmi-codec.h:41:29: error: dubious one-bit signed bitfield ./include/sound/hdmi-codec.h:42:31: error: dubious one-bit signed bitfield Fixes: 09184118a8ab ("ASoC: hdmi-codec: Add hdmi-codec for external HDMI-encoders") Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Arnaud Pouliquen <arnaud.pouliquen@st.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19btrfs: fix crash when tracepoint arguments are freed by wq callbacksDavid Sterba
commit ac0c7cf8be00f269f82964cf7b144ca3edc5dbc4 upstream. Enabling btrfs tracepoints leads to instant crash, as reported. The wq callbacks could free the memory and the tracepoints started to dereference the members to get to fs_info. The proposed fix https://marc.info/?l=linux-btrfs&m=148172436722606&w=2 removed the tracepoints but we could preserve them by passing only the required data in a safe way. Fixes: bc074524e123 ("btrfs: prefix fsid to all trace events") Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Reviewed-by: Qu Wenruo <quwenruo@cn.fujitsu.com> Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19x86/efi: Don't allocate memmap through memblock after mm_init()Nicolai Stange
commit 20b1e22d01a4b0b11d3a1066e9feb04be38607ec upstream. With the following commit: 4bc9f92e64c8 ("x86/efi-bgrt: Use efi_mem_reserve() to avoid copying image data") ... efi_bgrt_init() calls into the memblock allocator through efi_mem_reserve() => efi_arch_mem_reserve() *after* mm_init() has been called. Indeed, KASAN reports a bad read access later on in efi_free_boot_services(): BUG: KASAN: use-after-free in efi_free_boot_services+0xae/0x24c at addr ffff88022de12740 Read of size 4 by task swapper/0/0 page:ffffea0008b78480 count:0 mapcount:-127 mapping: (null) index:0x1 flags: 0x5fff8000000000() [...] Call Trace: dump_stack+0x68/0x9f kasan_report_error+0x4c8/0x500 kasan_report+0x58/0x60 __asan_load4+0x61/0x80 efi_free_boot_services+0xae/0x24c start_kernel+0x527/0x562 x86_64_start_reservations+0x24/0x26 x86_64_start_kernel+0x157/0x17a start_cpu+0x5/0x14 The instruction at the given address is the first read from the memmap's memory, i.e. the read of md->type in efi_free_boot_services(). Note that the writes earlier in efi_arch_mem_reserve() don't splat because they're done through early_memremap()ed addresses. So, after memblock is gone, allocations should be done through the "normal" page allocator. Introduce a helper, efi_memmap_alloc() for this. Use it from efi_arch_mem_reserve(), efi_free_boot_services() and, for the sake of consistency, from efi_fake_memmap() as well. Note that for the latter, the memmap allocations cease to be page aligned. This isn't needed though. Tested-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Nicolai Stange <nicstange@gmail.com> Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Dave Young <dyoung@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Mika Penttilä <mika.penttila@nextfour.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Fixes: 4bc9f92e64c8 ("x86/efi-bgrt: Use efi_mem_reserve() to avoid copying image data") Link: http://lkml.kernel.org/r/20170105125130.2815-1-nicstange@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19efi/x86: Prune invalid memory map entries and fix boot regressionPeter Jones
commit 0100a3e67a9cef64d72cd3a1da86f3ddbee50363 upstream. Some machines, such as the Lenovo ThinkPad W541 with firmware GNET80WW (2.28), include memory map entries with phys_addr=0x0 and num_pages=0. These machines fail to boot after the following commit, commit 8e80632fb23f ("efi/esrt: Use efi_mem_reserve() and avoid a kmalloc()") Fix this by removing such bogus entries from the memory map. Furthermore, currently the log output for this case (with efi=debug) looks like: [ 0.000000] efi: mem45: [Reserved | | | | | | | | | | | | ] range=[0x0000000000000000-0xffffffffffffffff] (0MB) This is clearly wrong, and also not as informative as it could be. This patch changes it so that if we find obviously invalid memory map entries, we print an error and skip those entries. It also detects the display of the address range calculation overflow, so the new output is: [ 0.000000] efi: [Firmware Bug]: Invalid EFI memory map entries: [ 0.000000] efi: mem45: [Reserved | | | | | | | | | | | | ] range=[0x0000000000000000-0x0000000000000000] (invalid) It also detects memory map sizes that would overflow the physical address, for example phys_addr=0xfffffffffffff000 and num_pages=0x0200000000000001, and prints: [ 0.000000] efi: [Firmware Bug]: Invalid EFI memory map entries: [ 0.000000] efi: mem45: [Reserved | | | | | | | | | | | | ] range=[phys_addr=0xfffffffffffff000-0x20ffffffffffffffff] (invalid) It then removes these entries from the memory map. Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> [ardb: refactor for clarity with no functional changes, avoid PAGE_SHIFT] Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> [Matt: Include bugzilla info in commit log] Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: https://bugzilla.kernel.org/show_bug.cgi?id=191121 Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19jump_labels: API for flushing deferred jump label updatesDavid Matlack
commit b6416e61012429e0277bd15a229222fd17afc1c1 upstream. Modules that use static_key_deferred need a way to synchronize with any delayed work that is still pending when the module is unloaded. Introduce static_key_deferred_flush() which flushes any pending jump label updates. Signed-off-by: David Matlack <dmatlack@google.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19mm: support anonymous stable pageMinchan Kim
commit f05714293a591038304ddae7cb0dd747bb3786cc upstream. During developemnt for zram-swap asynchronous writeback, I found strange corruption of compressed page, resulting in: Modules linked in: zram(E) CPU: 3 PID: 1520 Comm: zramd-1 Tainted: G E 4.8.0-mm1-00320-ge0d4894c9c38-dirty #3274 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014 task: ffff88007620b840 task.stack: ffff880078090000 RIP: set_freeobj.part.43+0x1c/0x1f RSP: 0018:ffff880078093ca8 EFLAGS: 00010246 RAX: 0000000000000018 RBX: ffff880076798d88 RCX: ffffffff81c408c8 RDX: 0000000000000018 RSI: 0000000000000000 RDI: 0000000000000246 RBP: ffff880078093cb0 R08: 0000000000000000 R09: 0000000000000000 R10: ffff88005bc43030 R11: 0000000000001df3 R12: ffff880076798d88 R13: 000000000005bc43 R14: ffff88007819d1b8 R15: 0000000000000001 FS: 0000000000000000(0000) GS:ffff88007e380000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007fc934048f20 CR3: 0000000077b01000 CR4: 00000000000406e0 Call Trace: obj_malloc+0x22b/0x260 zs_malloc+0x1e4/0x580 zram_bvec_rw+0x4cd/0x830 [zram] page_requests_rw+0x9c/0x130 [zram] zram_thread+0xe6/0x173 [zram] kthread+0xca/0xe0 ret_from_fork+0x25/0x30 With investigation, it reveals currently stable page doesn't support anonymous page. IOW, reuse_swap_page can reuse the page without waiting writeback completion so it can overwrite page zram is compressing. Unfortunately, zram has used per-cpu stream feature from v4.7. It aims for increasing cache hit ratio of scratch buffer for compressing. Downside of that approach is that zram should ask memory space for compressed page in per-cpu context which requires stricted gfp flag which could be failed. If so, it retries to allocate memory space out of per-cpu context so it could get memory this time and compress the data again, copies it to the memory space. In this scenario, zram assumes the data should never be changed but it is not true unless stable page supports. So, If the data is changed under us, zram can make buffer overrun because second compression size could be bigger than one we got in previous trial and blindly, copy bigger size object to smaller buffer which is buffer overrun. The overrun breaks zsmalloc free object chaining so system goes crash like above. I think below is same problem. https://bugzilla.suse.com/show_bug.cgi?id=997574 Unfortunately, reuse_swap_page should be atomic so that we cannot wait on writeback in there so the approach in this patch is simply return false if we found it needs stable page. Although it increases memory footprint temporarily, it happens rarely and it should be reclaimed easily althoug it happened. Also, It would be better than waiting of IO completion, which is critial path for application latency. Fixes: da9556a2367c ("zram: user per-cpu compression streams") Link: http://lkml.kernel.org/r/20161120233015.GA14113@bbox Link: http://lkml.kernel.org/r/1482366980-3782-2-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Hugh Dickins <hughd@google.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Darrick J. Wong <darrick.wong@oracle.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Hyeoncheol Lee <cheol.lee@lge.com> Cc: <yjay.kim@lge.com> Cc: Sangseok Lee <sangseok.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19mm, memcg: fix the active list aging for lowmem requests when memcg is enabledMichal Hocko
commit b4536f0c829c8586544c94735c343f9b5070bd01 upstream. Nils Holland and Klaus Ethgen have reported unexpected OOM killer invocations with 32b kernel starting with 4.8 kernels kworker/u4:5 invoked oom-killer: gfp_mask=0x2400840(GFP_NOFS|__GFP_NOFAIL), nodemask=0, order=0, oom_score_adj=0 kworker/u4:5 cpuset=/ mems_allowed=0 CPU: 1 PID: 2603 Comm: kworker/u4:5 Not tainted 4.9.0-gentoo #2 [...] Mem-Info: active_anon:58685 inactive_anon:90 isolated_anon:0 active_file:274324 inactive_file:281962 isolated_file:0 unevictable:0 dirty:649 writeback:0 unstable:0 slab_reclaimable:40662 slab_unreclaimable:17754 mapped:7382 shmem:202 pagetables:351 bounce:0 free:206736 free_pcp:332 free_cma:0 Node 0 active_anon:234740kB inactive_anon:360kB active_file:1097296kB inactive_file:1127848kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:29528kB dirty:2596kB writeback:0kB shmem:0kB shmem_thp: 0kB shmem_pmdmapped: 184320kB anon_thp: 808kB writeback_tmp:0kB unstable:0kB pages_scanned:0 all_unreclaimable? no DMA free:3952kB min:788kB low:984kB high:1180kB active_anon:0kB inactive_anon:0kB active_file:7316kB inactive_file:0kB unevictable:0kB writepending:96kB present:15992kB managed:15916kB mlocked:0kB slab_reclaimable:3200kB slab_unreclaimable:1408kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB lowmem_reserve[]: 0 813 3474 3474 Normal free:41332kB min:41368kB low:51708kB high:62048kB active_anon:0kB inactive_anon:0kB active_file:532748kB inactive_file:44kB unevictable:0kB writepending:24kB present:897016kB managed:836248kB mlocked:0kB slab_reclaimable:159448kB slab_unreclaimable:69608kB kernel_stack:1112kB pagetables:1404kB bounce:0kB free_pcp:528kB local_pcp:340kB free_cma:0kB lowmem_reserve[]: 0 0 21292 21292 HighMem free:781660kB min:512kB low:34356kB high:68200kB active_anon:234740kB inactive_anon:360kB active_file:557232kB inactive_file:1127804kB unevictable:0kB writepending:2592kB present:2725384kB managed:2725384kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:800kB local_pcp:608kB free_cma:0kB the oom killer is clearly pre-mature because there there is still a lot of page cache in the zone Normal which should satisfy this lowmem request. Further debugging has shown that the reclaim cannot make any forward progress because the page cache is hidden in the active list which doesn't get rotated because inactive_list_is_low is not memcg aware. The code simply subtracts per-zone highmem counters from the respective memcg's lru sizes which doesn't make any sense. We can simply end up always seeing the resulting active and inactive counts 0 and return false. This issue is not limited to 32b kernels but in practice the effect on systems without CONFIG_HIGHMEM would be much harder to notice because we do not invoke the OOM killer for allocations requests targeting < ZONE_NORMAL. Fix the issue by tracking per zone lru page counts in mem_cgroup_per_node and subtract per-memcg highmem counts when memcg is enabled. Introduce helper lruvec_zone_lru_size which redirects to either zone counters or mem_cgroup_get_zone_lru_size when appropriate. We are losing empty LRU but non-zero lru size detection introduced by ca707239e8a7 ("mm: update_lru_size warn and reset bad lru_size") because of the inherent zone vs. node discrepancy. Fixes: f8d1a31163fc ("mm: consider whether to decivate based on eligible zones inactive ratio") Link: http://lkml.kernel.org/r/20170104100825.3729-1-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Nils Holland <nholland@tisys.org> Tested-by: Nils Holland <nholland@tisys.org> Reported-by: Klaus Ethgen <Klaus@Ethgen.de> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Vladimir Davydov <vdavydov.dev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15gro: Disable frag0 optimization on IPv6 ext headersHerbert Xu
[ Upstream commit 57ea52a865144aedbcd619ee0081155e658b6f7d ] The GRO fast path caches the frag0 address. This address becomes invalid if frag0 is modified by pskb_may_pull or its variants. So whenever that happens we must disable the frag0 optimization. This is usually done through the combination of gro_header_hard and gro_header_slow, however, the IPv6 extension header path did the pulling directly and would continue to use the GRO fast path incorrectly. This patch fixes it by disabling the fast path when we enter the IPv6 extension header path. Fixes: 78a478d0efd9 ("gro: Inline skb_gro_header and cache frag0 virtual address") Reported-by: Slava Shwartsman <slavash@mellanox.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12clocksource/dummy_timer: Move hotplug callback after the real timersThomas Gleixner
commit 9bf11ecce5a2758e5a097c2f3a13d08552d0d6f9 upstream. When the dummy timer callback is invoked before the real timer callbacks, then it tries to install that timer for the starting CPU. If the platform does not have a broadcast timer installed the installation fails with a kernel crash. The crash happens due to a unconditional deference of the non available broadcast device. This needs to be fixed in the timer core code. But even when this is fixed in the core code then installing the dummy timer before the real timers is a pointless exercise. Move it to the end of the callback list. Fixes: 00c1d17aab51 ("clocksource/dummy_timer: Convert to hotplug state machine") Reported-and-tested-by: Mason <slash.tmp@free.fr> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: Richard Cochran <rcochran@linutronix.de> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Peter Zijlstra <peterz@infradead.org>, Cc: Sebastian Frias <sf84@laposte.net> Cc: Thibaud Cornic <thibaud_cornic@sigmadesigns.com> Cc: Robin Murphy <robin.murphy@arm.com> Link: http://lkml.kernel.org/r/1147ef90-7877-e4d2-bb2b-5c4fa8d3144b@free.fr Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12PCI: Add Mellanox device IDsNoa Osherovich
commit 7254383341bc6e1a61996accd836009f0c922b21 upstream. Add Mellanox device IDs for use by the mlx4 driver and INTx quirks. [bhelgaas: sorted and adapted from http://lkml.kernel.org/r/1478011644-12080-1-git-send-email-noaos@mellanox.com] Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12debugfs: improve DEFINE_DEBUGFS_ATTRIBUTE for !CONFIG_DEBUG_FSArnd Bergmann
commit 7f847dd31736f1284538e54f46cf10e63929eb7f upstream. The slp_s0_residency_usec debugfs file currently uses DEFINE_DEBUGFS_ATTRIBUTE(), but that macro cannot really be used to define files outside of the debugfs code, as it has no reference to the get/set functions if CONFIG_DEBUG_FS is not defined: drivers/platform/x86/intel_pmc_core.c:80:12: error: ‘pmc_core_dev_state_get’ defined but not used [-Werror=unused-function] This fixes the macro to always contain the reference, and instead rely on the stubbed-out debugfs_create_file to not actually refer to its arguments so the compiler can still drop the reference. This works because the attribute definition is always 'static', and the dead-code removal silently drops all static symbols that are not used. Fixes: c64688081490 ("debugfs: add support for self-protecting attribute file fops") Fixes: df2294fb6428 ("intel_pmc_core: Convert to DEFINE_DEBUGFS_ATTRIBUTE") Signed-off-by: Arnd Bergmann <arnd@arndb.de> [nicstange@gmail.com: Add dummy implementations of debugfs_attr_read() and debugfs_attr_write() in order to protect against possibly broken dead code elimination and to improve readability. Correct CONFIG_DEBUGFS_FS -> CONFIG_DEBUG_FS typo in changelog.] Signed-off-by: Nicolai Stange <nicstange@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12nl80211: Use different attrs for BSSID and random MAC addr in scan reqVamsi Krishna
commit 2fa436b3a2a7009c11a3bc03fe0ff4c26e80fd87 upstream. NL80211_ATTR_MAC was used to set both the specific BSSID to be scanned and the random MAC address to be used when privacy is enabled. When both the features are enabled, both the BSSID and the local MAC address were getting same value causing Probe Request frames to go with unintended DA. Hence, this has been fixed by using a different NL80211_ATTR_BSSID attribute to set the specific BSSID (which was the more recent addition in cfg80211) for a scan. Backwards compatibility with old userspace software is maintained to some extent by allowing NL80211_ATTR_MAC to be used to set the specific BSSID when scanning without enabling random MAC address use. Scanning with random source MAC address was introduced by commit ad2b26abc157 ("cfg80211: allow drivers to support random MAC addresses for scan") and the issue was introduced with the addition of the second user for the same attribute in commit 818965d39177 ("cfg80211: Allow a scan request for a specific BSSID"). Fixes: 818965d39177 ("cfg80211: Allow a scan request for a specific BSSID") Signed-off-by: Vamsi Krishna <vamsin@qti.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12iio: accel: st_accel: fix LIS3LV02 reading and scalingLinus Walleij
commit 65e4345c8ef8811bbb4860fe5f2df10646b7f2e1 upstream. The LIS3LV02 has a special bit that need to be set to get the read values left aligned. Before this patch we get gibberish like this: iio_generic_buffer -a -c10 -n lis3lv02dl_accel (...) 0.000000 -0.010042 -0.642688 19155832931907 0.000000 -0.010042 -0.642688 19155858751073 Which is because we read a raw value for 1g as 64 which is the nominal 1024 for 1g shifted 4 bits to the left by being right-aligned rather than left aligned. Since all other sensors are left aligned, add some code to set the special DAS (data alignment setting) bit to 1 so that the right value is now read like this: iio_generic_buffer -a -c10 -n lis3lv02dl_accel (...) 0.000000 -0.147095 -10.120135 24761614364956 -0.029419 -0.176514 -10.120135 24761631624540 The scaling was weird as well: we have a gain of 1000 for 1g and 3000 for 6g. I don't even remember how I came up with the old values but they are wrong. Fixes: 3acddf74f807 ("iio: st-sensors: add support for lis3lv02d accelerometer") Cc: Lorenzo Bianconi <lorenzo.bianconi@st.com> Cc: Giuseppe Barba <giuseppe.barba@st.com> Cc: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12usb: gadget: fix request length error for isoc transferPeter Chen
commit 982555fc26f9d8bcdbd5f9db0378fe0682eb4188 upstream. For isoc endpoint descriptor, the wMaxPacketSize is not real max packet size (see Table 9-13. Standard Endpoint Descriptor, USB 2.0 specifcation), it may contain the number of packet, so the real max packet should be ep->desc->wMaxPacketSize && 0x7ff. Cc: Felipe F. Tonello <eu@felipetonello.com> Cc: Felipe Balbi <felipe.balbi@linux.intel.com> Fixes: 16b114a6d797 ("usb: gadget: fix usb_ep_align_maybe endianness and new usb_ep_aligna") Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12asm-prototypes: Clear any CPP defines before declaring the functionsMichal Marek
commit c7858bf16c0b2cc62f475f31e6df28c3a68da1d6 upstream. The asm-prototypes.h file is used to provide dummy function declarations for genksyms, when processing asm files with EXPORT_SYMBOL. Make sure that any architecture defines get out of our way. x86 currently has an issue with memcpy on 64bit with CONFIG_KMEMCHECK=y and with memset/__memset on 32bit: $ cat init/test.c #include <asm/asm-prototypes.h> $ make -s init/test.o In file included from ./arch/x86/include/asm/string.h:4:0, from ./include/linux/string.h:18, from ./include/linux/bitmap.h:8, from ./include/linux/cpumask.h:11, from ./arch/x86/include/asm/cpumask.h:4, from ./arch/x86/include/asm/msr.h:10, from ./arch/x86/include/asm/processor.h:20, from ./arch/x86/include/asm/cpufeature.h:4, from ./arch/x86/include/asm/thread_info.h:52, from ./include/linux/thread_info.h:25, from ./arch/x86/include/asm/preempt.h:6, from ./include/linux/preempt.h:59, from ./include/linux/spinlock.h:50, from ./include/linux/seqlock.h:35, from ./include/linux/time.h:5, from ./include/uapi/linux/timex.h:56, from ./include/linux/timex.h:56, from ./include/linux/sched.h:19, from ./include/linux/uaccess.h:4, from ./arch/x86/include/asm/asm-prototypes.h:2, from init/test.c:1: ./arch/x86/include/asm/string_64.h:52:47: error: expected declaration specifiers or ‘...’ before ‘(’ token #define memcpy(dst, src, len) __inline_memcpy((dst), (src), (len)) ./include/asm-generic/asm-prototypes.h:6:14: note: in expansion of macro ‘memcpy’ extern void *memcpy(void *, const void *, __kernel_size_t); ^ ... During real build, this manifests itself by genksyms segfaulting. Fixes: 334bb7738764 ("x86/kbuild: enable modversions for symbols exported from asm") Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Cc: Adam Borowski <kilobyte@angband.pl> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09IB/cma: Fix a race condition in iboe_addr_get_sgid()Bart Van Assche
commit fba332b079029c2f4f7e84c1c1cd8e3867310c90 upstream. Code that dereferences the struct net_device ip_ptr member must be protected with an in_dev_get() / in_dev_put() pair. Hence insert calls to these functions. Fixes: commit 7b85627b9f02 ("IB/cma: IBoE (RoCE) IP-based GID addressing") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Moni Shoua <monis@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09cfg80211/mac80211: fix BSS leaks when abandoning assoc attemptsJohannes Berg
commit e6f462df9acd2a3295e5d34eb29e2823220cf129 upstream. When mac80211 abandons an association attempt, it may free all the data structures, but inform cfg80211 and userspace about it only by sending the deauth frame it received, in which case cfg80211 has no link to the BSS struct that was used and will not cfg80211_unhold_bss() it. Fix this by providing a way to inform cfg80211 of this with the BSS entry passed, so that it can clean up properly, and use this ability in the appropriate places in mac80211. This isn't ideal: some code is more or less duplicated and tracing is missing. However, it's a fairly small change and it's thus easier to backport - cleanups can come later. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06x86/kbuild: enable modversions for symbols exported from asmAdam Borowski
commit 334bb773876403eae3457d81be0b8ea70f8e4ccc upstream. Commit 4efca4ed ("kbuild: modversions for EXPORT_SYMBOL() for asm") adds modversion support for symbols exported from asm files. Architectures must include C-style declarations for those symbols in asm/asm-prototypes.h in order for them to be versioned. Add these declarations for x86, and an architecture-independent file that can be used for common symbols. With f27c2f6 reverting 8ab2ae6 ("default exported asm symbols to zero") we produce a scary warning on x86, this commit fixes that. Signed-off-by: Adam Borowski <kilobyte@angband.pl> Tested-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Nicholas Piggin <npiggin@gmail.com> Tested-by: Peter Wu <peter@lekensteyn.nl> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06PM / OPP: Pass opp_table to dev_pm_opp_put_regulator()Stephen Boyd
commit 91291d9ad92faa65a56a9a19d658d8049b78d3d4 upstream. Joonyoung Shim reported an interesting problem on his ARM octa-core Odoroid-XU3 platform. During system suspend, dev_pm_opp_put_regulator() was failing for a struct device for which dev_pm_opp_set_regulator() is called earlier. This happened because an earlier call to dev_pm_opp_of_cpumask_remove_table() function (from cpufreq-dt.c file) removed all the entries from opp_table->dev_list apart from the last CPU device in the cpumask of CPUs sharing the OPP. But both dev_pm_opp_set_regulator() and dev_pm_opp_put_regulator() routines get CPU device for the first CPU in the cpumask. And so the OPP core failed to find the OPP table for the struct device. This patch attempts to fix this problem by returning a pointer to the opp_table from dev_pm_opp_set_regulator() and using that as the parameter to dev_pm_opp_put_regulator(). This ensures that the dev_pm_opp_put_regulator() doesn't fail to find the opp table. Note that similar design problem also exists with other dev_pm_opp_put_*() APIs, but those aren't used currently by anyone and so we don't need to update them for now. Reported-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> [ Viresh: Wrote commit log and tested on exynos 5250 ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ptrace: Don't allow accessing an undumpable mmEric W. Biederman
commit 84d77d3f06e7e8dea057d10e8ec77ad71f721be3 upstream. It is the reasonable expectation that if an executable file is not readable there will be no way for a user without special privileges to read the file. This is enforced in ptrace_attach but if ptrace is already attached before exec there is no enforcement for read-only executables. As the only way to read such an mm is through access_process_vm spin a variant called ptrace_access_vm that will fail if the target process is not being ptraced by the current process, or the current process did not have sufficient privileges when ptracing began to read the target processes mm. In the ptrace implementations replace access_process_vm by ptrace_access_vm. There remain several ptrace sites that still use access_process_vm as they are reading the target executables instructions (for kernel consumption) or register stacks. As such it does not appear necessary to add a permission check to those calls. This bug has always existed in Linux. Fixes: v1.0 Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ptrace: Capture the ptracer's creds not PT_PTRACE_CAPEric W. Biederman
commit 64b875f7ac8a5d60a4e191479299e931ee949b67 upstream. When the flag PT_PTRACE_CAP was added the PTRACE_TRACEME path was overlooked. This can result in incorrect behavior when an application like strace traces an exec of a setuid executable. Further PT_PTRACE_CAP does not have enough information for making good security decisions as it does not report which user namespace the capability is in. This has already allowed one mistake through insufficient granulariy. I found this issue when I was testing another corner case of exec and discovered that I could not get strace to set PT_PTRACE_CAP even when running strace as root with a full set of caps. This change fixes the above issue with strace allowing stracing as root a setuid executable without disabling setuid. More fundamentaly this change allows what is allowable at all times, by using the correct information in it's decision. Fixes: 4214e42f96d4 ("v2.4.9.11 -> v2.4.9.12") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06mm: Add a user_ns owner to mm_struct and fix ptrace permission checksEric W. Biederman
commit bfedb589252c01fa505ac9f6f2a3d5d68d707ef4 upstream. During exec dumpable is cleared if the file that is being executed is not readable by the user executing the file. A bug in ptrace_may_access allows reading the file if the executable happens to enter into a subordinate user namespace (aka clone(CLONE_NEWUSER), unshare(CLONE_NEWUSER), or setns(fd, CLONE_NEWUSER). This problem is fixed with only necessary userspace breakage by adding a user namespace owner to mm_struct, captured at the time of exec, so it is clear in which user namespace CAP_SYS_PTRACE must be present in to be able to safely give read permission to the executable. The function ptrace_may_access is modified to verify that the ptracer has CAP_SYS_ADMIN in task->mm->user_ns instead of task->cred->user_ns. This ensures that if the task changes it's cred into a subordinate user namespace it does not become ptraceable. The function ptrace_attach is modified to only set PT_PTRACE_CAP when CAP_SYS_PTRACE is held over task->mm->user_ns. The intent of PT_PTRACE_CAP is to be a flag to note that whatever permission changes the task might go through the tracer has sufficient permissions for it not to be an issue. task->cred->user_ns is always the same as or descendent of mm->user_ns. Which guarantees that having CAP_SYS_PTRACE over mm->user_ns is the worst case for the tasks credentials. To prevent regressions mm->dumpable and mm->user_ns are not considered when a task has no mm. As simply failing ptrace_may_attach causes regressions in privileged applications attempting to read things such as /proc/<pid>/stat Acked-by: Kees Cook <keescook@chromium.org> Tested-by: Cyrill Gorcunov <gorcunov@openvz.org> Fixes: 8409cca70561 ("userns: allow ptrace from non-init user namespaces") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06exec: Ensure mm->user_ns contains the execed filesEric W. Biederman
commit f84df2a6f268de584a201e8911384a2d244876e3 upstream. When the user namespace support was merged the need to prevent ptrace from revealing the contents of an unreadable executable was overlooked. Correct this oversight by ensuring that the executed file or files are in mm->user_ns, by adjusting mm->user_ns. Use the new function privileged_wrt_inode_uidgid to see if the executable is a member of the user namespace, and as such if having CAP_SYS_PTRACE in the user namespace should allow tracing the executable. If not update mm->user_ns to the parent user namespace until an appropriate parent is found. Reported-by: Jann Horn <jann@thejh.net> Fixes: 9e4a36ece652 ("userns: Fail exec for suid and sgid binaries with ids outside our user namespace.") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06hotplug: Make register and unregister notifier API symmetricMichal Hocko
commit 777c6e0daebb3fcefbbd6f620410a946b07ef6d0 upstream. Yu Zhao has noticed that __unregister_cpu_notifier only unregisters its notifiers when HOTPLUG_CPU=y while the registration might succeed even when HOTPLUG_CPU=n if MODULE is enabled. This means that e.g. zswap might keep a stale notifier on the list on the manual clean up during the pool tear down and thus corrupt the list. Resulting in the following [ 144.964346] BUG: unable to handle kernel paging request at ffff880658a2be78 [ 144.971337] IP: [<ffffffffa290b00b>] raw_notifier_chain_register+0x1b/0x40 <snipped> [ 145.122628] Call Trace: [ 145.125086] [<ffffffffa28e5cf8>] __register_cpu_notifier+0x18/0x20 [ 145.131350] [<ffffffffa2a5dd73>] zswap_pool_create+0x273/0x400 [ 145.137268] [<ffffffffa2a5e0fc>] __zswap_param_set+0x1fc/0x300 [ 145.143188] [<ffffffffa2944c1d>] ? trace_hardirqs_on+0xd/0x10 [ 145.149018] [<ffffffffa2908798>] ? kernel_param_lock+0x28/0x30 [ 145.154940] [<ffffffffa2a3e8cf>] ? __might_fault+0x4f/0xa0 [ 145.160511] [<ffffffffa2a5e237>] zswap_compressor_param_set+0x17/0x20 [ 145.167035] [<ffffffffa2908d3c>] param_attr_store+0x5c/0xb0 [ 145.172694] [<ffffffffa290848d>] module_attr_store+0x1d/0x30 [ 145.178443] [<ffffffffa2b2b41f>] sysfs_kf_write+0x4f/0x70 [ 145.183925] [<ffffffffa2b2a5b9>] kernfs_fop_write+0x149/0x180 [ 145.189761] [<ffffffffa2a99248>] __vfs_write+0x18/0x40 [ 145.194982] [<ffffffffa2a9a412>] vfs_write+0xb2/0x1a0 [ 145.200122] [<ffffffffa2a9a732>] SyS_write+0x52/0xa0 [ 145.205177] [<ffffffffa2ff4d97>] entry_SYSCALL_64_fastpath+0x12/0x17 This can be even triggered manually by changing /sys/module/zswap/parameters/compressor multiple times. Fix this issue by making unregister APIs symmetric to the register so there are no surprises. Fixes: 47e627bc8c9a ("[PATCH] hotplug: Allow modules to use the cpu hotplug notifiers even if !CONFIG_HOTPLUG_CPU") Reported-and-tested-by: Yu Zhao <yuzhao@google.com> Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: linux-mm@kvack.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dan Streetman <ddstreet@ieee.org> Link: http://lkml.kernel.org/r/20161207135438.4310-1-mhocko@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Limit the number of can filters to avoid > MAX_ORDER allocations. Fix from Marc Kleine-Budde. 2) Limit GSO max size in netvsc driver to avoid problems with NVGRE configurations. From Stephen Hemminger. 3) Return proper error when memory allocation fails in ser_gigaset_init(), from Dan Carpenter. 4) Missing linkage undo in error paths of ipvlan_link_new(), from Gao Feng. 5) Missing necessayr SET_NETDEV_DEV in lantiq and cpmac drivers, from Florian Fainelli. 6) Handle probe deferral properly in smsc911x driver. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: mlx5: Fix Kconfig help text net: smsc911x: back out silently on probe deferrals ibmveth: set correct gso_size and gso_type net: ethernet: cpmac: Call SET_NETDEV_DEV() net: ethernet: lantiq_etop: Call SET_NETDEV_DEV() vhost-vsock: fix orphan connection reset cxgb4/cxgb4vf: Assign netdev->dev_port with port ID driver: ipvlan: Unlink the upper dev when ipvlan_link_new failed ser_gigaset: return -ENOMEM on error instead of success NET: usb: cdc_mbim: add quirk for supporting Telit LE922A can: peak: fix bad memory access and free sequence phy: Don't increment MDIO bus refcount unless it's a different owner netvsc: reduce maximum GSO size drivers: net: cpsw-phy-sel: Clear RGMII_IDMODE on "rgmii" links can: raw: raw_setsockopt: limit number of can_filter that can be set
2016-12-09Merge branch 'libnvdimm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm fixes from Dan Williams: "Several fixes to the DSM (ACPI device specific method) marshaling implementation. I consider these urgent enough to send for 4.9 consideration since they fix the kernel's handling of ARS (Address Range Scrub) commands. Especially for platforms without machine-check-recovery capabilities, successful execution of ARS commands enables the platform to potentially break out of an infinite reboot problem if a media error is present in the boot path. There is also a one line fix for a device-dax read-only mapping regression. Commits 9a901f5495e2 ("acpi, nfit: fix extended status translations for ACPI DSMs") and 325896ffdf90 ("device-dax: fix private mapping restriction, permit read-only") are true regression fixes for changes introduced this cycle. Commit efda1b5d87cb ("acpi, nfit, libnvdimm: fix / harden ars_status output length handling") fixes the kernel's handling of zero-length results, this never would have worked in the past, but we only just recently discovered a BIOS implementation that emits this arguably spec non-compliant result. The remaining two commits are additional fall out from thinking through the implications of a zero / truncated length result of the ARS Status command. In order to mitigate the risk that these changes introduce yet more regressions they are backstopped by a new unit test in commit a7de92dac9f0 ("tools/testing/nvdimm: unit test acpi_nfit_ctl()") that mocks up inputs to acpi_nfit_ctl()" * 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: device-dax: fix private mapping restriction, permit read-only tools/testing/nvdimm: unit test acpi_nfit_ctl() acpi, nfit: fix bus vs dimm confusion in xlat_status acpi, nfit: validate ars_status output buffer size acpi, nfit, libnvdimm: fix / harden ars_status output length handling acpi, nfit: fix extended status translations for ACPI DSMs
2016-12-08NET: usb: cdc_mbim: add quirk for supporting Telit LE922ADaniele Palmas
Telit LE922A MBIM based composition does not work properly with altsetting toggle done in cdc_ncm_bind_common. This patch adds CDC_MBIM_FLAG_AVOID_ALTSETTING_TOGGLE quirk to avoid this procedure that, instead, is mandatory for other modems. Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Reviewed-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-07Revert "default exported asm symbols to zero"Linus Torvalds
This reverts commit 8ab2ae655bfe384335c5b6b0d6041e0ddce26b00. I loved that commit because of how it explained what the problem with newer versions of binutils were, but the actual patch itself turns out to not work very well. It has two problems: - a zero CRC value isn't actually right. It happens to work for the case where both sides of the equation fail at giving the symbol a crc, but there are cases where the users of the exported symbol get the right crc (due to seeing the C declarations), but the actual exporting itself does not (due to the whole weak asm symbol issue). So then the module load fails after all - we did have a crc for the symbol, but we couldn't match it with the loaded module. - it seems that the alpha assembler has special semantics for the '.set' directive, and on alpha it doesn't actually set the value of the specified symbol at all, it is instead used to set various assembly modes (eg ".set noat" and ".set noreorder"). So using ".set" to set the symbol value would just cause build failures on alpha. I'm sure we'll find some other workaround for these issues (hopefully that involves getting rid of modversions entirely some day, but people are also talking about just using smarter tools). But for now we'll just fall back on commit faaae2a58143 ("Re-enable CONFIG_MODVERSIONS in a slightly weaker form") that just let's a missing crc through. Reported-by: Jan Stancek <jstancek@redhat.com> Reported-by: Philip Müller <philm@manjaro.org> Reported-by: Guenter Roeck <linux@roeck-us.net> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-07can: raw: raw_setsockopt: limit number of can_filter that can be setMarc Kleine-Budde
This patch adds a check to limit the number of can_filters that can be set via setsockopt on CAN_RAW sockets. Otherwise allocations > MAX_ORDER are not prevented resulting in a warning. Reference: https://lkml.org/lkml/2016/12/2/230 Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Cc: linux-stable <stable@vger.kernel.org> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2016-12-06acpi, nfit, libnvdimm: fix / harden ars_status output length handlingDan Williams
Given ambiguities in the ACPI 6.1 definition of the "Output (Size)" field of the ARS (Address Range Scrub) Status command, a firmware implementation may in practice return 0, 4, or 8 to indicate that there is no output payload to process. The specification states "Size of Output Buffer in bytes, including this field.". However, 'Output Buffer' is also the name of the entire payload, and earlier in the specification it states "Max Query ARS Status Output Buffer Size: Maximum size of buffer (including the Status and Extended Status fields)". Without this fix if the BIOS happens to return 0 it causes memory corruption as evidenced by this result from the acpi_nfit_ctl() unit test. ars_status00000000: 00020000 00000000 ........ BUG: stack guard page was hit at ffffc90001750000 (stack is ffffc9000174c000..ffffc9000174ffff) kernel stack overflow (page fault): 0000 [#1] SMP DEBUG_PAGEALLOC task: ffff8803332d2ec0 task.stack: ffffc9000174c000 RIP: 0010:[<ffffffff814cfe72>] [<ffffffff814cfe72>] __memcpy+0x12/0x20 RSP: 0018:ffffc9000174f9a8 EFLAGS: 00010246 RAX: ffffc9000174fab8 RBX: 0000000000000000 RCX: 000000001fffff56 RDX: 0000000000000000 RSI: ffff8803231f5a08 RDI: ffffc90001750000 RBP: ffffc9000174fa88 R08: ffffc9000174fab0 R09: ffff8803231f54b8 R10: 0000000000000008 R11: 0000000000000001 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000003 R15: ffff8803231f54a0 FS: 00007f3a611af640(0000) GS:ffff88033ed00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffc90001750000 CR3: 0000000325b20000 CR4: 00000000000406e0 Stack: ffffffffa00bc60d 0000000000000008 ffffc90000000001 ffffc9000174faac 0000000000000292 ffffffffa00c24e4 ffffffffa00c2914 0000000000000000 0000000000000000 ffffffff00000003 ffff880331ae8ad0 0000000800000246 Call Trace: [<ffffffffa00bc60d>] ? acpi_nfit_ctl+0x49d/0x750 [nfit] [<ffffffffa01f4fe0>] nfit_test_probe+0x670/0xb1b [nfit_test] Cc: <stable@vger.kernel.org> Fixes: 747ffe11b440 ("libnvdimm, tools/testing/nvdimm: fix 'ars_status' output buffer sizing") Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2016-12-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) When dcbnl_cee_fill() fails to be able to push a new netlink attribute, it return 0 instead of an error code. From Pan Bian. 2) Two suffix handling fixes to FIB trie code, from Alexander Duyck. 3) bnxt_hwrm_stat_ctx_alloc() goes through all the trouble of setting and maintaining a return code 'rc' but fails to actually return it. Also from Pan Bian. 4) ping socket ICMP handler needs to validate ICMP header length, from Kees Cook. 5) caif_sktinit_module() has this interesting logic: int err = sock_register(...); if (!err) return err; return 0; Just return sock_register()'s return value directly which is the only possible correct thing to do. 6) Two bnx2x driver fixes from Yuval Mintz, return a reasonable estimate from get_ringparam() ethtool op when interface is down and avoid trying to use UDP port based tunneling on 577xx chips. 7) Fix ep93xx_eth crash on module unload from Florian Fainelli. 8) Missing uapi exports, from Stephen Hemminger. 9) Don't schedule work from sk_destruct(), because the socket will be freed upon return from that function. From Herbert Xu. 10) Buggy drivers, of which we know there is at least one, can send a huge packet into the TCP stack but forget to set the gso_size in the SKB, which causes all kinds of problems. Correct this when it happens, and emit a one-time warning with the device name included so that it can be diagnosed more easily. From Marcelo Ricardo Leitner. 11) virtio-net does DMA off the stack causes hiccups with VMAP_STACK, fix from Andy Lutomirski. 12) Fix fec driver compilation with CONFIG_M5272, from Nikita Yushchenko. 13) mlx5 fixes from Kamal Heib, Saeed Mahameed, and Mohamad Haj Yahia. (erroneously flushing queues on error, module parameter validation, etc) * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (34 commits) net/mlx5e: Change the SQ/RQ operational state to positive logic net/mlx5e: Don't flush SQ on error net/mlx5e: Don't notify HW when filling the edge of ICO SQ net/mlx5: Fix query ISSI flow net/mlx5: Remove duplicate pci dev name print net/mlx5: Verify module parameters net: fec: fix compile with CONFIG_M5272 be2net: Add DEVSEC privilege to SET_HSW_CONFIG command. virtio-net: Fix DMA-from-the-stack in virtnet_set_mac_address() tcp: warn on bogus MSS and try to amend it uapi glibc compat: fix outer guard of net device flags enum net: stmmac: clear reset value of snps, wr_osr_lmt/snps, rd_osr_lmt before writing netlink: Do not schedule work from sk_destruct uapi: export nf_log.h uapi: export tc_skbmod.h net: ep93xx_eth: Do not crash unloading module bnx2x: Prevent tunnel config for 577xx bnx2x: Correct ringparam estimate when DOWN isdn: hisax: set error code on failure net: bnx2x: fix improper return value ...
2016-12-06uapi glibc compat: fix outer guard of net device flags enumJonas Gorski
Fix a wrong condition preventing the higher net device flags IFF_LOWER_UP etc to be defined if net/if.h is included before linux/if.h. The comment makes it clear the intention was to allow partial definition with either parts. This fixes compilation of userspace programs trying to use IFF_LOWER_UP, IFF_DORMANT or IFF_ECHO. Fixes: 4a91cb61bb99 ("uapi glibc compat: fix compile errors when glibc net/if.h included before linux/if.h") Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com> Reviewed-by: Mikko Rapeli <mikko.rapeli@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-05uapi: export nf_log.hstephen hemminger
File is in uapi directory but not being copied on make install_headers Fixes commit 4ec9c8fbbc22 ("netfilter: nft_log: complete NFTA_LOG_FLAGS attr support"). Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-05uapi: export tc_skbmod.hstephen hemminger
Fixes commit 735cffe5d800 ("net_sched: Introduce skbmod action") Not used by iproute2 but maybe in future. Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-05Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fixes from Herbert Xu: "This fixes the following issues: - Intermittent build failure in RSA - Memory corruption in chelsio crypto driver - Regression in DRBG due to vmalloced stack" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: rsa - Add Makefile dependencies to fix parallel builds crypto: chcr - Fix memory corruption crypto: drbg - prevent invalid SG mappings
2016-12-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Lots more phydev and probe error path leaks in various drivers by Johan Hovold. 2) Fix race in packet_set_ring(), from Philip Pettersson. 3) Use after free in dccp_invalid_packet(), from Eric Dumazet. 4) Signnedness overflow in SO_{SND,RCV}BUFFORCE, also from Eric Dumazet. 5) When tunneling between ipv4 and ipv6 we can be left with the wrong skb->protocol value as we enter the IPSEC engine and this causes all kinds of problems. Set it before the output path does any dst_output() calls, from Eli Cooper. 6) bcmgenet uses wrong device struct pointer in DMA API calls, fix from Florian Fainelli. 7) Various netfilter nat bug fixes from FLorian Westphal. 8) Fix memory leak in ipvlan_link_new(), from Gao Feng. 9) Locking fixes, particularly wrt. socket lookups, in l2tp from Guillaume Nault. 10) Avoid invoking rhash teardowns in atomic context by moving netlink cb->done() dump completion from a worker thread. Fix from Herbert Xu. 11) Buffer refcount problems in tun and macvtap on errors, from Jason Wang. 12) We don't set Kconfig symbol DEFAULT_TCP_CONG properly when the user selects BBR. Fix from Julian Wollrath. 13) Fix deadlock in transmit path on altera TSE driver, from Lino Sanfilippo. 14) Fix unbalanced reference counting in dsa_switch_tree, from Nikita Yushchenko. 15) tc_tunnel_key needs to be properly exported to userspace via uapi, fix from Roi Dayan. 16) rds_tcp_init_net() doesn't unregister notifier in error path, fix from Sowmini Varadhan. 17) Stale packet header pointer access after pskb_expand_head() in genenve driver, fix from Sabrina Dubroca. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits) net: avoid signed overflows for SO_{SND|RCV}BUFFORCE geneve: avoid use-after-free of skb->data tipc: check minimum bearer MTU net: renesas: ravb: unintialized return value sh_eth: remove unchecked interrupts for RZ/A1 net: bcmgenet: Utilize correct struct device for all DMA operations NET: usb: qmi_wwan: add support for Telit LE922A PID 0x1040 cdc_ether: Fix handling connection notification ip6_offload: check segs for NULL in ipv6_gso_segment. RDS: TCP: unregister_netdevice_notifier() in error path of rds_tcp_init_net Revert: "ip6_tunnel: Update skb->protocol to ETH_P_IPV6 in ip6_tnl_xmit()" ipv6: Set skb->protocol properly for local output ipv4: Set skb->protocol properly for local output packet: fix race condition in packet_set_ring net: ethernet: altera: TSE: do not use tx queue lock in tx completion handler net: ethernet: altera: TSE: Remove unneeded dma sync for tx buffers net: ethernet: stmmac: fix of-node and fixed-link-phydev leaks net: ethernet: stmmac: platform: fix outdated function header net: ethernet: stmmac: dwmac-meson8b: fix probe error path net: ethernet: stmmac: dwmac-generic: fix probe error path ...
2016-12-02default exported asm symbols to zeroArnd Bergmann
With binutils-2.26 and before, a weak missing symbol was kept during the final link, and a missing CRC for an export would lead to that CRC being treated as zero implicitly. With binutils-2.27, the crc symbol gets dropped, and any module trying to use it will fail to load. This sets the weak CRC symbol to zero explicitly, making it defined in vmlinux, which in turn lets us load the modules referring to that CRC. The comment above the __CRC_SYMBOL macro suggests that this was always the intention, although it also seems that all symbols defined in C have a correct CRC these days, and only the exports that are now done in assembly need this. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Adam Borowski <kilobyte@angband.pl> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-01Merge tag 'pci-v4.9-fixes-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "PCI fixes: - Fix Read Completion Boundary setting, which fixes a boot failure on IBM x3850 with Mellanox MT27500 ConnectX-3 - Update some MAINTAINERS entries and email addresses" * tag 'pci-v4.9-fixes-4' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Set Read Completion Boundary to 128 iff Root Port supports it (_HPX) PCI: Export pcie_find_root_port PCI: designware-plat: Update author email PCI: designware: Change maintainer to Joao Pinto MAINTAINERS: Add devicetree binding to PCI i.MX6 entry MAINTAINERS: Update Richard Zhu's email address
2016-12-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input fixes from Dmitry Torokhov: "We are disabling automatic probing of BYD touchpads as it results in too many false positives, and the hardware is not terribly popular and having the protocol support does not result in significantly improved user experience. We also change keycode for KEY_DATA to avoid clashing with KEY_FASTREVERSE. Luckily this newish code is used by CEC framework that is still in staging, so it is extremely unlikely that someone has already started using this keycode" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: change KEY_DATA from 0x275 to 0x277 Input: psmouse - disable automatic probing of BYD touchpads
2016-12-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter fixes for net This is a large batch of Netfilter fixes for net, they are: 1) Three patches to fix NAT conversion to rhashtable: Switch to rhlist structure that allows to have several objects with the same key. Moreover, fix wrong comparison logic in nf_nat_bysource_cmp() as this is expecting a return value similar to memcmp(). Change location of the nat_bysource field in the nf_conn structure to avoid zeroing this as it breaks interaction with SLAB_DESTROY_BY_RCU and lead us to crashes. From Florian Westphal. 2) Don't allow malformed fragments go through in IPv6, drop them, otherwise we hit GPF, patch from Florian Westphal. 3) Fix crash if attributes are missing in nft_range, from Liping Zhang. 4) Fix arptables 32-bits userspace 64-bits kernel compat, from Hongxu Jia. 5) Two patches from David Ahern to fix netfilter interaction with vrf. From David Ahern. 6) Fix element timeout calculation in nf_tables, we take milliseconds from userspace, but we use jiffies from kernelspace. Patch from Anders K. Pedersen. 7) Missing validation length netlink attribute for nft_hash, from Laura Garcia. 8) Fix nf_conntrack_helper documentation, we don't default to off anymore for a bit of time so let's get this in sync with the code. I know is late but I think these are important, specifically the NAT bits, as they are mostly addressing fallout from recent changes. I also read there are chances to have -rc8, if that is the case, that would also give us a bit more time to test this. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-30mm: fix false-positive WARN_ON() in truncate/invalidate for hugetlbKirill A. Shutemov
Hugetlb pages have ->index in size of the huge pages (PMD_SIZE or PUD_SIZE), not in PAGE_SIZE as other types of pages. This means we cannot user page_to_pgoff() to check whether we've got the right page for the radix-tree index. Let's introduce page_to_index() which would return radix-tree index for given page. We will be able to get rid of this once hugetlb will be switched to multi-order entries. Fixes: fc127da085c2 ("truncate: handle file thp") Link: http://lkml.kernel.org/r/20161123093053.mjbnvn5zwxw5e6lk@black.fi.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Doug Nelson <doug.nelson@intel.com> Tested-by: Doug Nelson <doug.nelson@intel.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-30kasan: update kasan_global for gcc 7Dmitry Vyukov
kasan_global struct is part of compiler/runtime ABI. gcc revision 241983 has added a new field to kasan_global struct. Update kernel definition of kasan_global struct to include the new field. Without this patch KASAN is broken with gcc 7. Link: http://lkml.kernel.org/r/1479219743-28682-1-git-send-email-dvyukov@google.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: <stable@vger.kernel.org> [4.0+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-30l2tp: lock socket before checking flags in connect()Guillaume Nault
Socket flags aren't updated atomically, so the socket must be locked while reading the SOCK_ZAPPED flag. This issue exists for both l2tp_ip and l2tp_ip6. For IPv6, this patch also brings error handling for __ip6_datagram_connect() failures. Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
