path: root/include
2006-11-16[POWERPC] Wire up sys_move_pagesStephen Rothwell
All the infrastructure is already in place for this, so we only need to allocate a syscall number and hook it up. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-16[POWERPC] Add the thread_siblings files to sysfsStephen Rothwell
This adds the /sys/devices/system/cpu/*/topology/thread_siblings files on powerpc. These files are already available on other architectures. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-14Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: [PATCH] x86-64: Fix race in exit_idle [PATCH] x86-64: Fix vgetcpu when CONFIG_HOTPLUG_CPU is disabled [PATCH] x86: Add acpi_user_timer_override option for Asus boards [PATCH] x86-64: setup saved_max_pfn correctly (kdump) [PATCH] x86-64: Handle reserve_bootmem_generic beyond end_pfn [PATCH] x86-64: shorten the x86_64 boot setup GDT to what the comment says [PATCH] x86-64: Fix PTRACE_[SG]ET_THREAD_AREA regression with ia32 emulation. [PATCH] x86-64: Fix partial page check to ensure unusable memory is not being marked usable. Revert "[PATCH] MMCONFIG and new Intel motherboards"
2006-11-14[PATCH] hugetlb: prepare_hugepage_range check offset tooHugh Dickins
(David:) If hugetlbfs_file_mmap() returns a failure to do_mmap_pgoff() - for example, because the given file offset is not hugepage aligned - then do_mmap_pgoff will go to the unmap_and_free_vma backout path. But at this stage the vma hasn't been marked as hugepage, and the backout path will call unmap_region() on it. That will eventually call down to the non-hugepage version of unmap_page_range(). On ppc64, at least, that will cause serious problems if there are any existing hugepage pagetable entries in the vicinity - for example if there are any other hugepage mappings under the same PUD. unmap_page_range() will trigger a bad_pud() on the hugepage pud entries. I suspect this will also cause bad problems on ia64, though I don't have a machine to test it on. (Hugh:) prepare_hugepage_range() should check file offset alignment when it checks virtual address and length, to stop MAP_FIXED with a bad huge offset from unmapping before it fails further down. PowerPC should apply the same prepare_hugepage_range alignment checks as ia64 and all the others do. Then none of the alignment checks in hugetlbfs_file_mmap are required (nor is the check for too small a mapping); but even so, move up setting of VM_HUGETLB and add a comment to warn of what David Gibson discovered - if hugetlbfs_file_mmap fails before setting it, do_mmap_pgoff's unmap_region when unwinding from error will go the non-huge way, which may cause bad behaviour on architectures (powerpc and ia64) which segregate their huge mappings into a separate region of the address space. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-14[PATCH] x86-64: Fix race in exit_idleAndi Kleen
When another interrupt happens in exit_idle the exit idle notifier could be called an incorrect number of times. Add a test_and_clear_bit_pda and use it handle the bit atomically against interrupts to avoid this. Pointed out by Stephane Eranian Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-14[PATCH] x86-64: Fix vgetcpu when CONFIG_HOTPLUG_CPU is disabledAndi Kleen
The vgetcpu per CPU initialization previously relied on CPU hotplug events for all CPUs to initialize the per CPU state. That only worked only on kernels with CONFIG_HOTPLUG_CPU enabled. On the others some CPUs didn't get their state initialized properly and vgetcpu wouldn't work. Change the initialization sequence to instead run in a normal initcall (which runs after the normal CPU bootup) and initialize all running CPUs there. Later hotplug CPUs are still handled with an hotplug notifier. This actually simplifies the code somewhat. Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-14[PATCH] x86: Add acpi_user_timer_override option for Asus boardsAndi Kleen
Timer overrides are normally disabled on Nvidia board because they are commonly wrong, except on new ones with HPET support. Unfortunately there are quite some Asus boards around that don't have HPET, but need a timer override. We don't know yet how to handle this transparently, but at least add a command line option to force the timer override and let them boot. Cc: len.brown@intel.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-13Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IPVS]: More endianness fixed. [IPVS]: Compile fix for annotations in userland.
2006-11-13[PATCH] Fix missing parens in set_personality()Russell King
If you call set_personality() with an expression such as: set_personality(foo ? PERS_FOO1 : PERS_FOO2); then this evaluates to: ((current->personality == foo ? PERS_FOO1 : PERS_FOO2) ? ... which is obviously not the intended result. Add the missing parents to ensure this gets evaluated as expected: ((current->personality == (foo ? PERS_FOO1 : PERS_FOO2)) ? ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] mspec driver build fixJes Sorensen
Fix MSPEC driver to build for non SN2 enabled configs as the driver should work in cached and uncached modes (no fetchop) on these systems. In addition make MSPEC select IA64_UNCACHED_ALLOCATOR, which is required for it and move it to arch/ia64/Kconfig to avoid warnings on non ia64 architectures running allmodconfig. Once the Kconfig code is fixed, we can move it back. Signed-off-by: Jes Sorensen <jes@sgi.com> Cc: Fernando Luis Vzquez Cao <fernando@oss.ntt.co.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] vmalloc: optimization, cleanup, bugfixesEric Dumazet
- reorder 'struct vm_struct' to speedup lookups on CPUS with small cache lines. The fields 'next,addr,size' should be now in the same cache line, to speedup lookups. - One minor cleanup in __get_vm_area_node() - Bugfixes in vmalloc_user() and vmalloc_32_user() NULL returns from __vmalloc() and __find_vm_area() were not tested. [akpm@osdl.org: remove redundant BUG_ONs] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-09[IPVS]: Compile fix for annotations in userland.Simon Horman
This change makes __beXX available to user-space applications, such as ipvsadm, which include ip_vs.h Signed-Off-By: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-08[PATCH] htirq: allow buggy drivers of buggy hardware to write the registersEric W. Biederman
This patch adds a variant of ht_create_irq __ht_create_irq that takes an aditional parameter update that is a function that is called whenever we want to write to a drivers htirq configuration registers. This is needed to support the ipath_iba6110 because it's registers in the proper location are not actually conected to the hardware that controlls interrupt delivery. [bos@serpentine.com: fixes] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Cc: <olson@pathscale.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] htirq: refactor so we only have one function that writes to the chipEric W. Biederman
This refactoring actually optimizes the code a little by caching the value that we think the device is programmed with instead of reading it back from the hardware. Which simplifies the code a little and should speed things up a bit. This patch introduces the concept of a ht_irq_msg and modifies the architecture read/write routines to update this code. There is a minor consistency fix here as well as x86_64 forgot to initialize the htirq as masked. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Acked-by: Bryan O'Sullivan <bos@pathscale.com> Cc: <olson@pathscale.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] IPMI: retry messages on certain error returnsCorey Minyard
Some more errors from the IPMI send message command are retryable, but are not being retried by the IPMI code. Make sure they get retried. Signed-off-by: Corey Minyard <minyard@acm.org> Cc: Frederic Lelievre <Frederic.Lelievre@ca.kontron.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] nfsd4: fix open-create permissionsJ. Bruce Fields
In the case where an open creates the file, we shouldn't be rechecking permissions to open the file; the open succeeds regardless of what the new file's mode bits say. This patch fixes the problem, but only by introducing yet another parameter to nfsd_create_v3. This is ugly. This will be fixed by later patches. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08x86-64: clean up io-apic accessesLinus Torvalds
This is just commit 130fe05dbc0114609cfef9815c0c5580b42decfa ported to x86-64, for all the same reasons. It cleans up the IO-APIC accesses in order to then fix the ordering issues. We move the accessor functions (that were only used by io_apic.c) out of a header file, and use proper memory-mapped accesses rather than making up our own "volatile" pointers. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-07Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3927/1: Allow show_mem() to work with holes in memory map. [ARM] 3926/1: make timer led handle HZ != 100 [ARM] 3923/1: S3C24XX: update s3c2410_defconfig with new drivers [ARM] 3922/1: S3C24XX: update s3c2410_defconfig to 2.6.19-rc4 [ARM] 3921/1: S3C24XX: remove bast_defconfig [ARM] 3920/1: S3C24XX: Remove smdk2410_defconfig [ARM] 3919/1: Fixed definition of some PXA270 CIF related registers [ARM] 3918/1: ixp4xx irq-chip rework [ARM] 3912/1: Make PXA270 advertise HWCAP_IWMMXT capability [ARM] 3915/1: S3C2412: Add s3c2410_gpio_getirq() to general gpio.c [ARM] 3917/1: Fix dmabounce symbol exports
2006-11-06[MIPS] Make irq number allocator generally available for fixing EV64120.Ralf Baechle
2006-11-06Merge branch 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32Linus Torvalds
* 'for-linus' of git://www.atmel.no/~hskinnemoen/linux/kernel/avr32: AVR32: Add missing return instruction in __raw_writesb AVR32: Wire up sys_epoll_pwait AVR32: Fix thinko in generic_find_next_zero_le_bit() AVR32: Get rid of board_early_init
2006-11-06AVR32: Wire up sys_epoll_pwaitHaavard Skinnemoen
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-11-06[PATCH] sysctl: implement CTL_UNNUMBEREDEric W. Biederman
This patch takes the CTL_UNNUMBERD concept from NFS and makes it available to all new sysctl users. At the same time the sysctl binary interface maintenance documentation is updated to mention and to describe what is needed to successfully maintain the sysctl binary interface. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-06[PATCH] sysctl: allow a zero ctl_name in the middle of a sysctl tableEric W. Biederman
Since it is becoming clear that there are just enough users of the binary sysctl interface that completely removing the binary interface from the kernel will not be an option for foreseeable future, we need to find a way to address the sysctl maintenance issues. The basic problem is that sysctl requires one central authority to allocate sysctl numbers, or else conflicts and ABI breakage occur. The proc interface to sysctl does not have that problem, as names are not densely allocated. By not terminating a sysctl table until I have neither a ctl_name nor a procname, it becomes simple to add sysctl entries that don't show up in the binary sysctl interface. Which allows people to avoid allocating a binary sysctl value when not needed. I have audited the kernel code and in my reading I have not found a single sysctl table that wasn't terminated by a completely zero filled entry. So this change in behavior should not affect anything. I think this mechanism eases the pain enough that combined with a little disciple we can solve the reoccurring sysctl ABI breakage. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-05Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NETLABEL]: Fix build failure. [IPV6]: Give sit driver an appropriate module alias. [IPV6]: Add ndisc_netdev_notifier unregister. [NET]: __alloc_pages() failures reported due to fragmentation [PKTGEN]: TCI endianness fixes [TG3]: Fix 2nd ifup failure on 5752M. [NETFILTER] bug: skb->protocol is already net-endian [NETFILTER] bug: nfulnl_msg_config_mode ->copy_range is 32bit [NETFILTER] bug: NFULA_CFG_QTHRESH uses 32bit [IPV6]: Fix ECN bug on big-endian [IPX]: Annotate and fix IPX checksum [IPX]: Trivial parts of endianness annotations
2006-11-05[SPARC]: Fix robust futex syscalls and wire up migrate_pages.David S. Miller
When I added the entries for the robust futex syscall entries, I forgot to bump NR_SYSCALLS. The current situation is error-prone because NR_SYSCALLS lives in entry.S where the system call limit checks are enforced. Move the definition to asm/unistd.h in order to make this mistake much more difficult to make. And wire up sys_migrate_pages since the powerpc folks implemented the compat wrapper for us. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-05[IPV6]: Fix ECN bug on big-endianAl Viro
__constant_htons(2<<4) is not a replacement for htonl(2<<20). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-05[IPX]: Annotate and fix IPX checksumAl Viro
Calculation of IPX checksum got buggered about 2.4.0. The old variant mangled the packet; that got fixed, but calculation itself got buggered. Restored the correct logics, fixed a subtle breakage we used to have even back then: if the sum is 0 mod 0xffff, we want to return 0, not 0xffff. The latter has special meaning for IPX (cheksum disabled). Observation (and obvious fix) nicked from history of FreeBSD ipx_cksum.c... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-05[IPX]: Trivial parts of endianness annotationsAl Viro
2006-11-03[PATCH] powerpc: wire up sys_migrate_pagesStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Create compat_sys_migrate_pagesStephen Rothwell
This is needed on bigendian 64bit architectures. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] swsusp: debuggingRafael J. Wysocki
Add a swsusp debugging mode. This does everything that's needed for a suspend except for actually suspending. So we can look in the log messages and work out a) what code is being slow and b) which drivers are misbehaving. (1) # echo testproc > /sys/power/disk # echo disk > /sys/power/state This should turn off the non-boot CPU, freeze all processes, wait for 5 seconds and then thaw the processes and the CPU. (2) # echo test > /sys/power/disk # echo disk > /sys/power/state This should turn off the non-boot CPU, freeze all processes, shrink memory, suspend all devices, wait for 5 seconds, resume the devices etc. Cc: Pavel Machek <pavel@ucw.cz> Cc: Stefan Seyfried <seife@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Add printk_timed_ratelimit()Andrew Morton
printk_ratelimit() has global state which makes it not useful for callers which wish to perform ratelimiting at a particular frequency. Add a printk_timed_ratelimit() which utilises caller-provided state storage to permit more flexibility. This function can in fact be used for things other than printk ratelimiting and is perhaps poorly named. Cc: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] fix UFS superblock alignment issuesEric Sandeen
ufs2 fails to mount on x86_64, claiming bad magic. This is because ufs_super_block_third's fs_un1 member is padded out by 4 bytes for 8-byte alignment, pushing down the rest of the struct. Forcing this to be packed solves it. I took a quick look over other on-disk structures and didn't immediately find other problems. I was able to mount & ls a populated ufs2 filesystem w/ this change. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[ARM] 3919/1: Fixed definition of some PXA270 CIF related registersEnrico Scholz
Fixed definition of some CIF registers; see PXA27x Developer\'s Manual. Signed-off-by: Enrico Scholz <enrico.scholz@sigma-chemnitz.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-02pci_ids.h: Add NVIDIA PCI IDPeer Chen
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-02Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: RDMA/addr: Use client registration to fix module unload race IB/mthca: Fix MAD extended header format for MAD_IFC firmware command IB/uverbs: Return sq_draining value in query_qp response IB/amso1100: Fix incorrect pr_debug() IB/amso1100: Use dma_alloc_coherent() instead of kmalloc/dma_map_single IB/ehca: Fix eHCA driver compilation for uniprocessor RDMA/cma: rdma_bind_addr() leaks a cma_dev reference count IB/iser: Start connection after enabling iSER
2006-11-02RDMA/addr: Use client registration to fix module unload raceSean Hefty
Require registration with ib_addr module to prevent caller from unloading while a callback is in progress. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-11-02Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Do not use -msym32 option for modules. [MIPS] Don't use R10000 llsc workaround version for all llsc-full processors. [MIPS] Ocelot G: Fix : "CURRENTLY_UNUSED" is not defined warning. [MIPS] Fix warning about init_initrd() call if !CONFIG_BLK_DEV_INITRD. [MIPS] IP27: Allow SMP ;-) Another changeset messed up by patch. [MIPS] Fix merge screwup by patch(1) Revert "[MIPS] Make SPARSEMEM selectable on QEMU."
2006-11-02[MIPS] Don't use R10000 llsc workaround version for all llsc-full processors.Ralf Baechle
Found and original patch by bile@landofbile.com. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-01[SPARC64]: Fix futex_atomic_cmpxchg_inatomic implementation.David S. Miller
I copied the logic from ll/sc arch implementations, but that was wrong and makes no sense at all. Just do a straight compare-exchange instruction, just like x86. Based upon bug reports from Dennis Gilmore and Fabio Massimo. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-01Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Fix warning in mips-boards generic PCI [MIPS] SMTC: Synchronize cp0 counters on bootup. [MIPS] SMTC: Fix crash if # of TC's > # of VPE's after pt_regs irq cleanup. [MIPS] 16K & 64K page size fixes
2006-11-01[MIPS] 16K & 64K page size fixesRalf Baechle
Derived from Peter Watkins <treestem@gmail.com>'s work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-01i386: clean up io-apic accessesLinus Torvalds
This is preparation for fixing the ordering of the accesses that got broken by the commit cf4c6a2f27f5db810b69dcb1da7f194489e8ff88 when factoring out the "common" io apic routing entry accesses. Move the accessor function (that were only used by io_apic.c) out of a header file, and use proper memory-mapped accesses rather than making up our own "volatile" pointers. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-01Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Make alignment exception always check exception table [POWERPC] Disallow kprobes on emulate_step and branch_taken [POWERPC] Make mmiowb's io_sync preempt safe [POWERPC] Make high hugepage areas preempt safe [POWERPC] Make current preempt-safe [POWERPC] qe_lib: qe_issue_cmd writes wrong value to CECDR [POWERPC] Use 4kB iommu pages even on 64kB-page systems [POWERPC] Fix oprofile support for e500 in arch/powerpc [POWERPC] Fix rmb() for e500-based machines it [POWERPC] Fix various offb issues
2006-11-01[POWERPC] Make mmiowb's io_sync preempt safeHugh Dickins
If mmiowb() is always used prior to releasing spinlock as Doc suggests, then it's safe against preemption; but I'm not convinced that's always the case. If preemption occurs between sync and get_paca()->io_sync = 0, I believe there's no problem. But in the unlikely event that gcc does the store relative to another register than r13 (as it did with current), then there's a small danger of setting another cpu's io_sync to 0, after it had just set it to 1. Rewrite ppc64 mmiowb to prevent that. The remaining io_sync assignments in io.h all get_paca()->io_sync = 1, which is harmless even if preempted to the wrong cpu (the context switch itself syncs); and those in spinlock.h are while preemption is disabled. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Make current preempt-safeHugh Dickins
Repeated -j20 kernel builds on a G5 Quad running an SMP PREEMPT kernel would often collapse within a day, some exec failing with "Bad address". In each case examined, load_elf_binary was doing a kernel_read, but generic_file_aio_read's access_ok saw current->thread.fs.seg as USER_DS instead of KERNEL_DS. objdump of filemap.o shows gcc 4.1.0 emitting "mr r5,r13 ... ld r9,416(r5)" here for get_paca()->__current, instead of the expected and much more usual "ld r9,416(r13)"; I've seen other gcc4s do the same, but perhaps not gcc3s. So, if the task is preempted and rescheduled on a different cpu in between the mr and the ld, r5 will be looking at a different paca_struct from the one it's now on, pick up the wrong __current, and perhaps the wrong seg. Presumably much worse could happen elsewhere, though that split is rare. Other architectures appear to be safe (x86_64's read_pda is more limiting than get_paca), but ppc64 needs to force "current" into one instruction. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Use 4kB iommu pages even on 64kB-page systemsLinas Vepstas
The 10Gigabit ethernet device drivers appear to be able to chew up all 256MB of TCE mappings on pSeries systems, as evidenced by numerous error messages: iommu_alloc failed, tbl c0000000010d5c48 vaddr c0000000d875eff0 npages 1 Some experimentation indicates that this is essentially because one 1500 byte ethernet MTU gets mapped as a 64K DMA region when the large 64K pages are enabled. Thus, it doesn't take much to exhaust all of the available DMA mappings for a high-speed card. This patch changes the iommu allocator to work with its own unique, distinct page size. Although the patch is long, its actually quite simple: it just #defines a distinct IOMMU_PAGE_SIZE and then uses this in all the places that matter. As a side effect, it also dramatically improves network performance on platforms with H-calls on iommu translation inserts/removes (since we no longer call it 16 times for a 1500 bytes packet when the iommu HW is still 4k). In the future, we might want to make the IOMMU_PAGE_SIZE a variable in the iommu_table instance, thus allowing support for different HW page sizes in the iommu itself. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Fix oprofile support for e500 in arch/powerpcAndy Fleming
Fixed a compile error in building the 85xx support with oprofile, and in the process cleaned up some issues with the fsl_booke performance monitor code. * Reorganized FSL Book-E performance monitoring code so that the 7450 wouldn't be built if the e500 was, and cleaned it up so it was more self-contained. * Added a cpu_setup function for FSL Book-E. The original cpu_setup function prototype had no arguments, assuming that the reg_setup function would copy the required information into variables which represented the registers. This was silly for e500, since it has 1 register per counter (rather than 3 for all counters), so the code has been restructured to have cpu_setup take the current counter config array as an argument, with op_powerpc_setup() invoking op_powerpc_cpu_setup() through on_each_cpu(), and op_powerpc_cpu_setup() invoking the model-specific cpu_setup function with an argument. The argument is ignored on all other platforms at present. * Fixed a confusing line where a trinary operator only had two arguments Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Fix rmb() for e500-based machines itAndy Fleming
The e500 core generates an illegal instruction exception when it tries to execute the lwsync instruction, which we currently use for rmb(). This fixes it by using the LWSYNC macro, which turns into a plain sync on 32-bit machines. Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-31[PATCH] libata: unexport ata_dev_revalidate()Tejun Heo
ata_dev_revalidate() isn't used outside of libata core. Unexport it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
