path: root/include
2005-10-27Revert "x86-64: Avoid unnecessary double bouncing for swiotlb"Linus Torvalds
Commit id 6142891a0c0209c91aa4a98f725de0d6e2ed4918 Andi Kleen reports that it seems to break things for some people, and since it's purely a small optimization, revert it for now. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-26Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2005-10-26Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-10-26[ARM] 3032/1: sparse: complains about generic_fls() prototype in ↵Ian Campbell
asm-arm/bitops.h Patch from Ian Campbell Sparse complains about the definition of generic_fls in asm-arm/bitops.h: CHECK /home/icampbell/devel/kernel/2.6/arch/arm/mach-pxa/viper.c include2/asm/bitops.h:350:34: error: marked inline, but without a definition The definition is unnecessary since linux/bitops.h defines generic_fls before including asm/bitops.h and asm/bitops.h should not be included directly. There are still some places where asm/bitops.h is directly included, but I think that code should be fixed. I was a little wary of the patch for this reason but lubbock, mainstone and assabet all build OK and so do my in house boards... ARM is the only arch with the generic_fls prototype in this way. Signed-off-by: Ian Campbell <icampbell@arcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-25[LLC]: Strip RIF flag from source MAC addressJochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-25[PATCH] alpha: atomic dependency fixAndrew Morton
My alpha build is exploding because asm/atomic.h now needs smb_mb(), which is over in the (not included) system.h. I fear what will happen if I include system.h into atomic.h, so let's put the barriers into their own header file. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-24[SERIAL] new hp diva console portJustin Chen
Add the new ID 0x132a and configure the new PCI Diva console port. This device supports only 1 single console UART. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-24[SERIAL] support the Exsys EX-4055 4S four-port cardBjorn Helgaas
Tested by Wolfgang Denk with this device: 00:0f.0 Network controller: PLX Technology, Inc. PCI <-> IOBus Bridge (rev 01) Subsystem: Exsys EX-4055 4S(16C550) RS-232 Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- Status: Cap- 66Mhz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- Interrupt: pin A routed to IRQ 10 Region 0: Memory at 80100000 (32-bit, non-prefetchable) [size=128] Region 1: I/O ports at 7080 [size=128] Region 2: I/O ports at 7400 [size=32] 00:0f.0 Class 0280: 10b5:9050 (rev 01) Subsystem: d84d:4055 Results with this patch: Serial: 8250/16550 driver $Revision: 1.90 $ 32 ports, IRQ sharing enabled ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A PCI: Found IRQ 10 for device 0000:00:0f.0 ttyS4 at I/O 0x7400 (irq = 10) is a 16550A ttyS5 at I/O 0x7408 (irq = 10) is a 16550A ttyS6 at I/O 0x7410 (irq = 10) is a 16550A ttyS7 at I/O 0x7418 (irq = 10) is a 16550A Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-23[PATCH] inotify/idr leak fixAndrew Morton
Fix a bug which was reported and diagnosed by Stefan Jones <stefan.jones@churchillrandoms.co.uk> IDR trees include a cache of idr_layer objects. There's no way to destroy this cache, so when we discard an overall idr tree we end up leaking some memory. Add and use idr_destroy() for this. v9fs and infiniband also need to use idr_destroy() to avoid leaks. Or, we make the cache global, like radix_tree_preload(). Which is probably better. Later. Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-22[PATCH] alpha: additional smp barriersIvan Kokshaysky
As stated in Documentation/atomic_ops.txt, atomic functions returning values must have the memory barriers both before and after the operation. Thanks to DaveM for pointing that out. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-22[AX.25]: Fix signed char bugRalf Baechle
On architectures where the char type defaults to unsigned some of the arithmetic in the AX.25 stack to fail, resulting in some packets being dropped on receive. Credits for tracking this down and the original patch to Bob Brose N0QBJ <linuxhams@n0qbj-11.ampr.org>. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-21Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-10-20[ARM] 3028/1: S3C2410 - add DCLK mask definitionsBen Dooks
Patch from Ben Dooks From: Guillaume Gourat <guillaume.gourat@nexvision.fr> Add MASK definitions for DCLK0 and DCLK1 Signed-off-by: Guillaume Gourat <guillaume.gourat@nexvision.fr> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-20[ARM] 3026/1: S3C2410 - avoid possible overflow in pll calculationsBen Dooks
Patch from Ben Dooks Avoid the possiblity that if the board is using a 16.9334 or higher crystal with a high PLL multiplier, then the pll value could overflow the capability of an int. Also fix the value types of the intermediate variables to unsigned int. Rewrite of patch from Guillaume Gourat Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-20[PATCH] Fix handling spurious page fault for hugetlb regionHugh Dickins
This reverts commit 3359b54c8c07338f3a863d1109b42eebccdcf379 and replaces it with a cleaner version that is purely based on page table operations, so that the synchronization between inode size and hugetlb mappings becomes moot. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-19Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-10-19[PATCH] swiotlb: make sure initial DMA allocations really are in DMA memoryYasunori Goto
This introduces a limit parameter to the core bootmem allocator; The new parameter indicates that physical memory allocated by the bootmem allocator should be within the requested limit. We also introduce alloc_bootmem_low_pages_limit, alloc_bootmem_node_limit, alloc_bootmem_low_pages_node_limit apis, but alloc_bootmem_low_pages_limit is the only api used for swiotlb. The existing alloc_bootmem_low_pages() api could instead have been changed and made to pass right limit to the core allocator. But that would make the patch more intrusive for 2.6.14, as other arches use alloc_bootmem_low_pages(). We may be done that post 2.6.14 as a cleanup. With this, swiotlb gets memory within 4G for both x86_64 and ia64 arches. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Ravikiran G Thirumalai <kiran@scalex86.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-19[PATCH] Handle spurious page fault for hugetlb regionSeth, Rohit
The hugetlb pages are currently pre-faulted. At the time of mmap of hugepages, we populate the new PTEs. It is possible that HW has already cached some of the unused PTEs internally. These stale entries never get a chance to be purged in existing control flow. This patch extends the check in page fault code for hugepages. Check if a faulted address falls with in size for the hugetlb file backing it. We return VM_FAULT_MINOR for these cases (assuming that the arch specific page-faulting code purges the stale entry for the archs that need it). Signed-off-by: Rohit Seth <rohit.seth@intel.com> [ This is apparently arguably an ia64 port bug. But the code won't hurt, and for now it fixes a real problem on some ia64 machines ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-18[ARM] 3023/1: pxa-regs: Typo in ARM pxa register definitions.Paul Schulz
Patch from Paul Schulz The following trivial patch is to fix what looks like a typo in the PXA register definitions. The correction comes directly from the definition in the Intel Documentation. http://www.intel.com/design/pca/applicationsprocessors/manuals/278693.htm Intel(R) PXA 255 Processor - Developers Manual - Jan 2004 - Page 12-33 Neither 'UDCCS_IO_ROF' or 'UDCCS_IO_DME' are currently used elseware in the main code (from grep of tree)... The current definitions have been in the code since at lease 2.4.7. Signed-off-by: Paul Schulz <paul@mawsonlakes.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-18[ARM] 3021/1: Interrupt 0 bug fix for ixp4xxKenneth Tan
Patch from Kenneth Tan The get_irqnr_and_base subroutine of ixp4xx does not take interrupt 0 condition into account properly. We should not perform "subs" here. The Z flag will be set when interrupt 0 occur, which resulting "movne r1, sp" in the caller routine (irq_handler) not being executed. When interrupt 0 occur: o if CONFIG_CPU_IXP46X is not set, "subs" will set the Z flag and return o if CONFIG_CPU_IXP46X is set, codes in upper interrupt handling will be trigerred. But since this is not supper interrupt, the "cmp" in the upper interrupt handling portion will set the Z flag and return Signed-off-by: Kenneth Tan <chong.yin.tan@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-18[ARM] 3020/1: Fixes typo error CONFIG_CPU_IXP465, which should be ↵Kenneth Tan
CONFIG_CPU_IXP46X Patch from Kenneth Tan The cpu_is_ixp465 macro in include/asm-arm/arch-ixp4xx/hardware.h is always returning 0 because #ifdef CONFIG_CPU_IXP465 is always false. Signed-off-by: Kenneth Tan <chong.yin.tan@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-18[ARM] 3019/1: fix wrong commentsNicolas Pitre
Patch from Nicolas Pitre Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-17[PATCH] aio: revert lock_kiocb()Zach Brown
lock_kiocb() was introduced to serialize retrying and cancellation. In the process of doing so it tried to sleep waiting for KIF_LOCKED while holding the ctx_lock spinlock. Recent fixes have ensured that multiple concurrent retries won't be attempted for a given iocb. Cancel has other problems and has no significant in-tree users that have been complaining about it. So for the immediate future we'll revert sleeping with the lock held and will address proper cancellation and retry serialization in the future. Signed-off-by: Zach Brown <zach.brown@oracle.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-17[PATCH] rcu: keep rcu callback event counterEric Dumazet
This makes call_rcu() keep track of how many events there are on the RCU list, and cause a reschedule event when the list gets too long. This helps keep RCU event lists down. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-17[PATCH] list: add missing rcu_dereference on first elementHerbert Xu
It seems that all the list_*_rcu primitives are missing a memory barrier on the very first dereference. For example, #define list_for_each_rcu(pos, head) \ for (pos = (head)->next; prefetch(pos->next), pos != (head); \ pos = rcu_dereference(pos->next)) It will go something like: pos = (head)->next prefetch(pos->next) pos != (head) do stuff We're missing a barrier here. pos = rcu_dereference(pos->next) fetch pos->next barrier given by rcu_dereference(pos->next) store pos Without the missing barrier, the pos->next value may turn out to be stale. In fact, if "do stuff" were also dereferencing pos and relying on list_for_each_rcu to provide the barrier then it may also break. So here is a patch to make sure that we have a barrier for the first element in the list. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-16[PATCH]: highest_possible_processor_id() has to be a macroAl Viro
... otherwise, things like alpha and sparc64 break and break badly. They define cpu_possible_map to something else in smp.h *AFTER* having included cpumask.h. If that puppy is a macro, expansion will happen at the actual caller, when we'd already seen #define cpu_possible_map ... and we will get the right thing used. As an inline helper it will be tokenized before we get to that define and that's it; no matter what we define later, it won't affect anything. We get modules with dependency on cpu_possible_map instead of the right symbol (phys_cpu_present_map in case of sparc64), or outright link errors if they are built-in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-14Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
2005-10-14Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-10-14[PATCH] Fix copy-and-paste error in BSD accountingTim Schmielau
Fix copy and paste error in jiffies_to_AHZ conversion which leads to wrong BSD accounting information on alpha and ia64 when CONFIG_BSD_PROCESS_ACCT_V3 is turned on. Also update comment to match reorganised header files. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-14[ARM] 3011/1: pxafb: Add ability to set device parent + fix spitz compile errorRichard Purdie
Patch from Richard Purdie Add a function to allow machines to set the parent of the pxa framebuffer device. This means the power up/down sequence can be controlled where required by the machine. Update spitz to use the new function, fixing a compile error. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-14[ARM] 3009/1: S3C2410 - io.h offsets too large for LDRH/STRHBen Dooks
Patch from Ben Dooks The __inwc/__outwc calls are capable of creating LDRH and STRH instructions with offsets over 8bits as GCC does not have a constraint for an 8bit offset. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-13[SPARC64]: Eliminate PCI IOMMU dma mapping size limit.David S. Miller
The hairy fast allocator in the sparc64 PCI IOMMU code has a hard limit of 256 pages. Certain devices can exceed this when performing very large I/Os. So replace with a more simple allocator, based largely upon the arch/ppc64/kernel/iommu.c code. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-13[SPARC64]: Consolidate common PCI IOMMU init code.David S. Miller
All the PCI controller drivers were doing the same thing setting up the IOMMU software state, put it all in one spot. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-13[NETFILTER]: Fix OOPSes on machines with discontiguous cpu numbering.David S. Miller
Original patch by Harald Welte, with feedback from Herbert Xu and testing by Sébastien Bernard. EBTABLES, ARP tables, and IP/IP6 tables all assume that cpus are numbered linearly. That is not necessarily true. This patch fixes that up by calculating the largest possible cpu number, and allocating enough per-cpu structure space given that. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-13Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-10-13[ARM] 3005/1: S3C2440 - add definition for s3c2440_set_dsc() call in hardware.hBen Dooks
Patch from Ben Dooks include/asm-arm/arch-s3c2410/hardware.h was missing the definition for s3c2440_set_dsc() Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2005-10-12[NETPOLL]: wrong return for null netpoll_poll_lock()Ben Dooks
When netpoll is not being used, the macro that defines the removed routing netpoll_poll_lock defines the return as zero, but the real routine returns a `void *` Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-12[ARM] 3003/1: SSP channel map register updates for pxa2xxLiam Girdwood
Patch from Liam Girdwood This patch updates the pxa2xx channel map registers definitions in pxa-regs.h Changes:- o Added description for SSP2 registers o Added definitions for SSP3 registers Signed-off-by:Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-12[PATCH] ppc32: Tell userland about lack of standard TBBenjamin Herrenschmidt
Glibc is about to get some new high precision timer stuff that relies on the standard timebase of the PPC architecture. However, some (rare & old) CPUs do not have such timebase and it is a bit annoying to have your stuff just crash because you are running on the wrong CPU... This exposes to userland a CPU feature bit that tells that the current processor doesn't have a standard timebase. It's negative logic so that glibc will still "just work" on older kernels (it will just be unhappy on those old CPUs but that doesn't really matter as distro tend to update glibc & kernel at the same time). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-12[PATCH] ppc32: Fix timekeepingBenjamin Herrenschmidt
Interestingly enough, ppc32 had broken timekeeping for ages... It worked, but probably drifted a bit more than could be explained by the actual bad precision of the timebase calibration. We discovered that recently when somebody figured out that the common code was using CLOCK_TICK_RATE to correct the timekeeing, and ppc32 had a completely bogus value for it. This patch turns it into something saner. Probably not as good as doing something based on the actual timebase frequency precision but I'll leave that sort of math to others. This at least makes it better for the common HZ values. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-10[TWSK]: Grab the module refcount for timewait socketsArnaldo Carvalho de Melo
This is required to avoid unloading a module that has active timewait sockets, such as DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] ctnetlink: allow userspace to change TCP statePablo Neira Ayuso
This patch adds the ability of changing the state a TCP connection. I know that this must be used with care but it's required to provide a complete conntrack creation via conntrack_netlink. So I'll document this aspect on the upcoming docs. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER]: Use only 32bit counters for CONNTRACK_ACCTHarald Welte
Initially we used 64bit counters for conntrack-based accounting, since we had no event mechanism to tell userspace that our counters are about to overflow. With nfnetlink_conntrack, we now have such a event mechanism and thus can save 16bytes per connection. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] ctnetlink: add one nesting level for TCP statePablo Neira Ayuso
To keep consistency, the TCP private protocol information is nested attributes under CTA_PROTOINFO_TCP. This way the sequence of attributes to access the TCP state information looks like here below: CTA_PROTOINFO CTA_PROTOINFO_TCP CTA_PROTOINFO_TCP_STATE instead of: CTA_PROTOINFO CTA_PROTOINFO_TCP_STATE Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER]: Add missing include to ip_conntrack_tuple.hHarald Welte
Without this #include, __be16 is not defined and userspace programs will break. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] nat: remove bogus structure memberHarald Welte
When 'rustynat' was merged in 2.6.12, the use of the "helper" pointer of struct ipt_nat_info was obsoleted, but the pointer not removed from the struct. This patch removes the pointer, thereby yet again shrinking struct ip_conntrack. Discovered-by: Rusty Russell <rusty@netfilter.org> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[NETFILTER] nfnetlink: use highest bit of nfa_type to indicate nested TLVHarald Welte
As Henrik Nordstrom pointed out, all our efforts with "split endian" (i.e. host byte order tags, net byte order values) are useless, unless a parser can determine whether an attribute is nested or not. This patch steals the highest bit of nfattr.nfa_type to indicate whether the data payload contains a nested nfattr (1) or not (0). This will break userspace compatibility, but luckily no kernel with nfnetlink was released so far. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-10[PATCH] x86_64: Allocate cpu local data for all possible CPUsAndi Kleen
CPU hotplug fills up the possible map to NR_CPUs, but it did that after setting up per CPU data. This lead to CPU data not getting allocated for all possible CPUs, which lead to various side effects. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-10[PATCH] Fix signal sending in usbdevio on async URB completionHarald Welte
If a process issues an URB from userspace and (starts to) terminate before the URB comes back, we run into the issue described above. This is because the urb saves a pointer to "current" when it is posted to the device, but there's no guarantee that this pointer is still valid afterwards. In fact, there are three separate issues: 1) the pointer to "current" can become invalid, since the task could be completely gone when the URB completion comes back from the device. 2) Even if the saved task pointer is still pointing to a valid task_struct, task_struct->sighand could have gone meanwhile. 3) Even if the process is perfectly fine, permissions may have changed, and we can no longer send it a signal. So what we do instead, is to save the PID and uid's of the process, and introduce a new kill_proc_info_as_uid() function. Signed-off-by: Harald Welte <laforge@gnumonks.org> [ Fixed up types and added symbol exports ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
