path: root/include
2009-04-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: UIO: fix specific device driver missing statement for depmod Driver core: remove pr_fmt() from dynamic_dev_dbg() printk driver core: prevent device_for_each_child from oopsing dynamic debug: resurrect old pr_debug() semantics as pr_devel() Driver Core: early platform driver proc: mounts_poll() make consistent to mdstat_poll sysfs: sysfs poll keep the poll rule of regular file. driver core: allow non-root users to listen to uevents driver core: fix driver_match_device sysfs: don't use global workqueue in sysfs_schedule_callback()
2009-04-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (22 commits) WUSB: correct format of wusb_chid sysfs file WUSB: fix oops when completing URBs for disconnected devices WUSB: disconnect all devices when stopping a WUSB HCD USB: whci-hcd: check return value of usb_hcd_link_urb_to_ep() USB: whci-hcd: provide a endpoint_reset method USB: add reset endpoint operations USB device codes for Motorola phone. usb-storage: fix mistake in Makefile USB: usb-serial ch341: support for DTR/RTS/CTS Revert USB: usb-serial ch341: support for DTR/RTS/CTS USB: musb: fix possible panic while resuming USB: musb: fix isochronous TXDMA (take 2) USB: musb: sanitize clearing TXCSR DMA bits (take 2) USB: musb: bugfixes for multi-packet TXDMA support USB: musb_host, fix ep0 fifo flushing USB: usb-storage: augment unusual_devs entry for Simple Tech/Datafab USB: musb_host, minor enqueue locking fix (v2) USB: fix oops in cdc-wdm in case of malformed descriptors USB: qcserial: Add extra device IDs USB: option: Add ids for D-Link DWM-652 3.5G modem ...
2009-04-17USB: add reset endpoint operationsDavid Vrabel
Wireless USB endpoint state has a sequence number and a current window and not just a single toggle bit. So allow HCDs to provide a endpoint_reset method and call this or clear the software toggles as required (after a clear halt, set configuration etc.). usb_settoggle() and friends are then HCD internal and are moved into core/hcd.h and all device drivers call usb_reset_endpoint() instead. If the device endpoint state has been reset (with a clear halt) but the host endpoint state has not then subsequent data transfers will not complete. The device will only work again after it is reset or disconnected. Signed-off-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: ads7846 - fix unsafe disable_irq Input: mainstone-wm97xx - fix condition in pen_up Input: pc110pad - remove unused variable dev Input: bf54x-keys - remove depreciated IRQF_SAMPLE_RANDOM flag Input: ad7877, ad7879 - remove depreciated IRQF_SAMPLE_RANDOM flag Input: da9034-ts - make pen {down,up} events more reliable Input: da9034-ts - add Bin Yang as co-author of the driver Input: atkbd - add forced release keys quirk for Samsung NC20 Input: atkbd - add forced release keys quirk for Samsung Q45 Input: gameport - fix attach driver code Input: hp_sdc_rtc should depend on serio Input: wm97xx - don't specify IRQF_SAMPLE_RANDOM Input: ads7846 - introduce platform specific way to synchronize sampling Input: remove unnecessary synchronize_rcu() call Input: i8042 - add a DMI table for the i8042.reset option Input: i8042 - introduce a tougher reset
2009-04-17Get rid of final remnants of include/asm-$(ARCH)Linus Torvalds
This renames include/asm-h8300/timer.h into arch/h8300/include/asm: it was left over just because that file had been created in the -mm tree before the whole h8300 header subdirectory had been moved, and then got merged in the old location afterwards. (See commits e0b0f9e4ead2468f84c26332ec42b118e76af572: "h8300: update timer handler - new files" and 758db3f2118703a1e36374dae5d58bed963e7e0d: "[h8300] move include/asm-h8300 to arch/h8300/include/asm" for details). This also removes a left-over .gitignore file in include/asm-arm that became stale when the ARM header files were moved (which happened in multiple commits, just see "git log -- include/asm-arm" for details). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-17Merge branch 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_devLinus Torvalds
* 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_dev: m32r: move include/asm-m32r/* to arch/m32r/include/asm/ m32r: move include/asm-m32r headers to arch/m32r/include/asm
2009-04-17m32r: move include/asm-m32r/* to arch/m32r/include/asm/Hirokazu Takata
Move remained files, ftrace.h and swab.h, to arch/m32r/include/asm/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-04-17m32r: move include/asm-m32r headers to arch/m32r/include/asmHirokazu Takata
2009-04-16Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/softirq.c: fix sparse warning rcu: Make hierarchical RCU less IPI-happy
2009-04-16Driver core: remove pr_fmt() from dynamic_dev_dbg() printkJason Baron
When pr_fmt() was added to the pr_debug() code, we added it not only to the dynamic_pr_debug() function, but also to the dynamic_dev_dbg() funciton. However, dev_dbg() doesn't make use of pr_fmt(), so neither should dynamic_dev_dbg(). Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-16dynamic debug: resurrect old pr_debug() semantics as pr_devel()Michael Ellerman
pr_debug() used to produce zero code unless DEBUG was #defined. This is now no longer the case in practice[1]. There are places where it's useful to have debugging printks, but we don't want them to generate any code in production kernels. So add a new macro, pr_devel(), for _devel_opment, to provide the old semantics, ie. if the programmer doesn't explicitly enable debugging, no code is produced. [1]: You can turn CONFIG_DYNAMIC_DEBUG off, but it's enabled in at least one distro kernel, so it's not really a solution. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Cc: Jason Baron <jbaron@redhat.com> Cc: Greg Banks <gnb@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-16Driver Core: early platform driverMagnus Damm
V3 of the early platform driver implementation. Platform drivers are great for embedded platforms because we can separate driver configuration from the actual driver. So base addresses, interrupts and other configuration can be kept with the processor or board code, and the platform driver can be reused by many different platforms. For early devices we have nothing today. For instance, to configure early timers and early serial ports we cannot use platform devices. This because the setup order during boot. Timers are needed before the platform driver core code is available. The same goes for early printk support. Early in this case means before initcalls. These early drivers today have their configuration either hard coded or they receive it using some special configuration method. This is working quite well, but if we want to support both regular kernel modules and early devices then we need to have two ways of configuring the same driver. A single way would be better. The early platform driver patch is basically a set of functions that allow drivers to register themselves and architecture code to locate them and probe. Registration happens through early_param(). The time for the probe is decided by the architecture code. See Documentation/driver-model/platform.txt for more details. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-16ata: Report 16/32bit PIO as best we canAlan Cox
The legacy old IDE ioctl API for this is a bit primitive so we try and map stuff sensibly onto it. - Set PIO over DMA devices to report 32bit - Add ability to change the PIO32 settings if the controller permits it - Add that functionality into the sff drivers - Add that functionality into the VLB legacy driver - Turn on the 32bit PIO on the ninja32 and add support there Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-16Merge branch 'next' into for-linusDmitry Torokhov
2009-04-16Add block_write_full_page_endio for passing endio handlerChris Mason
block_write_full_page doesn't allow the caller to control what happens when the IO is over. This adds a new call named block_write_full_page_endio so the buffer head end_io handler can be provided by the caller. This will be used by the ext3 data=guarded mode to do i_size updates in a workqueue based end_io handler. end_buffer_async_write is also exported so it can be called to do the dirty work of managing page writeback for the higher level end_io handler. Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Theodore Tso <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (64 commits) phylib: Fix delay argument of schedule_delayed_work NET/ixgbe: Fix powering off during shutdown NET/e1000e: Fix powering off during shutdown NET/e1000: Fix powering off during shutdown packet: avoid warnings when high-order page allocation fails gianfar: stop send queue before resetting gianfar myr10ge: again fix lro_gen_skb() alignment declance: convert to net_device_ops bfin_mac: convert to net_device_ops au1000: convert to net_device_ops atarilance: convert to net_device_ops a2065: convert to net_device_ops ixgbe: update real_num_tx_queues on changing num_rx_queues ixgbe: fix tx queue index Revert "rose: zero length frame filtering in af_rose.c" sfc: Use correct macro to set event bitfield sfc: Match calls to netif_napi_add() and netif_napi_del() bonding: Remove debug printk e1000/e1000: fix compile warning ehea: Fix incomplete conversion to net_device_ops ...
2009-04-15The default CONFIG_BUG=n version of BUG() should have an empty do...whileDavid Howells
The default CONFIG_BUG=n version of BUG() should incorporate an empty a do...while statement to avoid compilation weirdness. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix the cmd cache keys for amp verbs ALSA: add missing definitions(letters) to HD-Audio.txt ALSA: hda - Add quirk mask for Fujitsu Amilo laptops with ALC883 [ALSA] intel8x0: add one retry to the ac97_clock measurement routine [ALSA] intel8x0: fix wrong conditions in ac97_clock measure routine ALSA: hda - Avoid call of snd_jack_report at release ALSA: add private_data to struct snd_jack ALSA: snd-usb-caiaq: rename files to remove redundant information in file pathes ALSA: snd-usb-caiaq: clean up header includes ALSA: sound/pci: use memdup_user() ALSA: sound/usb: use memdup_user() ALSA: sound/isa: use memdup_user() ALSA: sound/core: use memdup_user() [ALSA] intel8x0: do not use zero value from PICB register [ALSA] intel8x0: an attempt to make ac97_clock measurement more reliable [ALSA] pcm-midlevel: Add more strict buffer position checks based on jiffies [ALSA] hda_intel: fix unexpected ring buffer positions ASoC: Disable S3C64xx support in Kconfig ASoC: magician: remove un-necessary #include of pxa-regs.h and hardware.h
2009-04-15Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (28 commits) cfq-iosched: add close cooperator code cfq-iosched: log responsible 'cfqq' in idle timer arm cfq-iosched: tweak kick logic a bit more cfq-iosched: no need to save interrupts in cfq_kick_queue() brd: fix cacheflushing brd: support barriers swap: Remove code handling bio_alloc failure with __GFP_WAIT gfs2: Remove code handling bio_alloc failure with __GFP_WAIT ext4: Remove code handling bio_alloc failure with __GFP_WAIT dio: Remove code handling bio_alloc failure with __GFP_WAIT block: Remove code handling bio_alloc failure with __GFP_WAIT bio: add documentation to bio_alloc() splice: add helpers for locking pipe inode splice: remove generic_file_splice_write_nolock() ocfs2: fix i_mutex locking in ocfs2_splice_to_file() splice: fix i_mutex locking in generic_splice_write() splice: remove i_mutex locking in splice_from_pipe() splice: split up __splice_from_pipe() block: fix SG_IO to return a proper error value cfq-iosched: don't delay queue kick for a merged request ...
2009-04-15Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: pseries/dtl.c should include asm/firmware.h powerpc: Fix data-corrupting bug in __futex_atomic_op powerpc/pseries: Set error_state to pci_channel_io_normal in eeh_report_reset() powerpc: Allow 256kB pages with SHMEM powerpc: Document new FSL I2C bindings and cleanup powerpc/mm: Fix compile warning powerpc/85xx: TQM8548: update defconfig powerpc/85xx: TQM8548: use proper phy-handles for enet2 and enet3 powerpc/85xx: TQM85xx: correct address of LM75 I2C device nodes powerpc: Add support for early tlbilx opcode powerpc: Fix tlbilx opcode
2009-04-15splice: add helpers for locking pipe inodeMiklos Szeredi
There are lots of sequences like this, especially in splice code: if (pipe->inode) mutex_lock(&pipe->inode->i_mutex); /* do something */ if (pipe->inode) mutex_unlock(&pipe->inode->i_mutex); so introduce helpers which do the conditional locking and unlocking. Also replace the inode_double_lock() call with a pipe_double_lock() helper to avoid spreading the use of this functionality beyond the pipe code. This patch is just a cleanup, and should cause no behavioral changes. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15splice: remove generic_file_splice_write_nolock()Miklos Szeredi
Remove the now unused generic_file_splice_write_nolock() function. It's conceptually broken anyway, because splice may need to wait for pipe events so holding locks across the whole operation is wrong. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15ocfs2: fix i_mutex locking in ocfs2_splice_to_file()Miklos Szeredi
Rearrange locking of i_mutex on destination and call to ocfs2_rw_lock() so locks are only held while buffers are copied with the pipe_to_file() actor, and not while waiting for more data on the pipe. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15splice: split up __splice_from_pipe()Miklos Szeredi
Split up __splice_from_pipe() into four helper functions: splice_from_pipe_begin() splice_from_pipe_next() splice_from_pipe_feed() splice_from_pipe_end() splice_from_pipe_next() will wait (if necessary) for more buffers to be added to the pipe. splice_from_pipe_feed() will feed the buffers to the supplied actor and return when there's no more data available (or if all of the requested data has been copied). This is necessary so that implementations can do locking around the non-waiting splice_from_pipe_feed(). This patch should not cause any change in behavior. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15Merge branch 'topic/hda' into for-linusTakashi Iwai
* topic/hda: ALSA: hda - Add quirk mask for Fujitsu Amilo laptops with ALC883 ALSA: hda - Avoid call of snd_jack_report at release ALSA: add private_data to struct snd_jack
2009-04-15Merge branch 'topic/jack-free-fix' into topic/hdaTakashi Iwai
* topic/jack-free-fix: ALSA: hda - Avoid call of snd_jack_report at release ALSA: add private_data to struct snd_jack
2009-04-15Merge branch 'master' of git://git.alsa-project.org/alsa-kernel into for-linusTakashi Iwai
* 'master' of git://git.alsa-project.org/alsa-kernel: [ALSA] intel8x0: add one retry to the ac97_clock measurement routine [ALSA] intel8x0: fix wrong conditions in ac97_clock measure routine [ALSA] intel8x0: do not use zero value from PICB register [ALSA] intel8x0: an attempt to make ac97_clock measurement more reliable [ALSA] pcm-midlevel: Add more strict buffer position checks based on jiffies [ALSA] hda_intel: fix unexpected ring buffer positions
2009-04-15Document and move the various READ/WRITE typesJens Axboe
It's a somewhat twisty maze of hints and behavioural modifiers, try and clear it up a bit with some documentation. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15block: move bio list helpers into bio.hChristoph Hellwig
It's used by DM and MD and generally useful, so move the bio list helpers into bio.h. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-14Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: drm/i915: fix scheduling while holding the new active list spinlock drm/i915: Allow tiling of objects with bit 17 swizzling by the CPU. drm/i915: Correctly set the write flag for get_user_pages in pread. drm/i915: Fix use of uninitialized var in 40a5f0de drm/i915: indicate framebuffer restore key in SysRq help message drm/i915: sync hdmi detection by hdmi identifier with 2D drm/i915: Fix a mismerge of the IGD patch (new .find_pll hooks missed) drm/i915: Implement batch and ring buffer dumping
2009-04-14Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: warn about lockdep disabling after kernel taint, fix
2009-04-14tty: Update some of the USB kernel docLeandro Dorileo
Updates some usb_serial_port members documentation. Signed-off-by: Leandro Dorileo <ldorileo@gmail.com> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-14ALSA: add private_data to struct snd_jackTakashi Iwai
Added private_data and private_free fields to struct snd_jack so that the caller can assign the data. It'll be helpful for avoiding the double-free of the jack instance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-14rcu: Make hierarchical RCU less IPI-happyPaul E. McKenney
This patch fixes a hierarchical-RCU performance bug located by Anton Blanchard. The problem stems from a misguided attempt to provide a work-around for jiffies-counter failure. This work-around uses a per-CPU n_rcu_pending counter, which is incremented on each call to rcu_pending(), which in turn is called from each scheduling-clock interrupt. Each CPU then treats this counter as a surrogate for the jiffies counter, so that if the jiffies counter fails to advance, the per-CPU n_rcu_pending counter will cause RCU to invoke force_quiescent_state(), which in turn will (among other things) send resched IPIs to CPUs that have thus far failed to pass through an RCU quiescent state. Unfortunately, each CPU resets only its own counter after sending a batch of IPIs. This means that the other CPUs will also (needlessly) send -another- round of IPIs, for a full N-squared set of IPIs in the worst case every three scheduler-clock ticks until the grace period finally ends. It is not reasonable for a given CPU to reset each and every n_rcu_pending for all the other CPUs, so this patch instead simply disables the jiffies-counter "training wheels", thus eliminating the excessive IPIs. Note that the jiffies-counter IPIs do not have this problem due to the fact that the jiffies counter is global, so that the CPU sending the IPIs can easily reset things, thus preventing the other CPUs from sending redundant IPIs. Note also that the n_rcu_pending counter remains, as it will continue to be used for tracing. It may also see use to update the jiffies counter, should an appropriate kick-the-jiffies-counter API appear. Located-by: Anton Blanchard <anton@au1.ibm.com> Tested-by: Anton Blanchard <anton@au1.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: anton@samba.org Cc: akpm@linux-foundation.org Cc: dipankar@in.ibm.com Cc: manfred@colorfullife.com Cc: cl@linux-foundation.org Cc: josht@linux.vnet.ibm.com Cc: schamp@sgi.com Cc: niv@us.ibm.com Cc: dvhltc@us.ibm.com Cc: ego@in.ibm.com Cc: laijs@cn.fujitsu.com Cc: rostedt@goodmis.org Cc: peterz@infradead.org Cc: penberg@cs.helsinki.fi Cc: andi@firstfloor.org Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> LKML-Reference: <12396834793575-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14lockdep: warn about lockdep disabling after kernel taint, fixIngo Molnar
Impact: build fix for Sparc and s390 Stephen Rothwell reported that the Sparc build broke: In file included from kernel/panic.c:12: include/linux/debug_locks.h: In function '__debug_locks_off': include/linux/debug_locks.h:15: error: implicit declaration of function 'xchg' due to: 9eeba61: lockdep: warn about lockdep disabling after kernel taint There is some inconsistency between architectures about where exactly xchg() is defined. The traditional place is in system.h but the more logical point for it is in atomic.h - where most architectures (especially new ones) have it defined. These architecture also still offer it via system.h. Some, such as Sparc or s390 only have it in asm/system.h and not available via asm/atomic.h at all. Use the widest set of headers in debug_locks.h and also include asm/system.h. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20090414144317.026498df.sfr@canb.auug.org.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-13intelfb: support i854Stefan Husemann
Support the Intel 854 Chipset in fbdev. We test and use the patch on a Thomson IP1101 IPTV-Box. On the VGA-Port we get a normal signal. Here is the link to the Mambux-Project: http://www.mambux.de Cc: Keith Packard <keithp@keithp.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Stefan Husemann <shusemann@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13include/video/cyblafb.h: remove it, it's unusedJoe Perches
commit ddb53d48da5b0e691f35e703ac29118747f86c99 ("fbdev: remove cyblafb driver") removed drivers/video/cyblafb.c, but not its .h file Signed-off-by: Joe Perches <joe@perches.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Jani Monoses" <jani@ubuntu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13asm-generic/siginfo.h: update NSIGTRAP definitionAndi Kleen
Impact: (nearly) trivial The patch commit da654b74bda14c45a7d98c731bf3c1a43b6b74e2 Author: Srinivasa Ds <srinivasa@in.ibm.com> Date: Tue Sep 23 15:23:52 2008 +0530 signals: demultiplexing SIGTRAP signal forgot to update the NSIGTRAP define in asm-generic/siginfo.h to the new number of sigtrap subcodes. Nothing in the tree seems to use it, but presumably something in user space might. So update it. Cc: Srinivasa Ds <srinivasa@in.ibm.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13include/linux/fiemap.h: include types.h now that it's exportedEric Sandeen
Include <linux/types.h> in fiemap.h. Sam Ravnborg pointed out that this was missing in this newly-exported header which uses the __u32 and __u64 types. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13aio: remove INIT_KIOCTXAlexey Dobriyan
Unused after 20dcae32439384b6863c626bb3b2a09bed65b33e aka "[PATCH] aio: remove kioctx from mm_struct". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13hwmon: sht15 humidity sensor driverJonathan Cameron
Data sheet at: http://www.sensirion.ch/en/pdf/product_information/Datasheet-humidity-sensor-SHT1x.pdf These sensors communicate over a 2 wire bus running a device specific protocol. The complexity of the driver is mainly due to handling the substantial delays between requesting a reading and the device pulling the data line low to indicate that the data is available. This is handled by an interrupt that is disabled under all other conditions. I wasn't terribly clear on the best way to handle this, so comments on that aspect would be particularly welcome! Interpretation of the temperature depends on knowing the supply voltage. If configured in a board config as a regulator consumer this is obtained from the regulator subsystem. If not it should be provided in the platform data. I've placed this driver in the hwmon subsystem as it is definitely a device that may be used for hardware monitoring and with it's relatively slow response times (up to 120 millisecs to get a reading) a caching strategy certainly seems to make sense! Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13fbdev: fix color component field length documentationMichal Januszewski
The documentation about the meaning of the color component bitfield lengths in pseudocolor modes is inconsistent. Fix it, so that it indicates the correct interpretation everywhere, i.e. that 1 << length is the number of palette entries. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <syrjala@sci.fi> Acked-by: Geert Uytterhoeven <geert.uytterhoeven@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13phylib: Allow early-out in phy_changeAnatolij Gustschin
Marvell 88E1121R Dual PHY device can be hardware-configured to use shared interrupt pin for both PHY ports. For such PHY configurations using shared PHY interrupt phy_interrupt() handler will also schedule a work for PHY port which didn't cause an interrupt. This patch adds a possibility for PHY drivers to provide did_interrupt() function which reports if the PHY (or a PHY port in a multi-PHY device) generated an interrupt. This function is called in phy_change() as phy_change() shouldn't proceed if it is invoked for a PHY which didn't cause an interrupt. So check for interrupt originator in phy_change() to allow early-out. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: MAINTAINERS
2009-04-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (22 commits) Input: i8042 - add HP DV9700 to the noloop list Input: arrange drivers/input/misc/Makefile in alphabetical order Input: add AD7879 Touchscreen driver Input: add AD7877 touchscreen driver Input: bf54x-keys - fix typo in warning Input: add driver for S1 button of rb532 Input: generic driver for rotary encoders on GPIOs Input: hilkbd - fix crash when removing hilkbd module Input: atkbd - add quirk for Fujitsu Siemens Amilo PA 1510 Input: atkbd - consolidate force release quirk setup Input: add accelerated touchscreen support for Marvell Zylonite Input: ucb1400_ts, mainstone-wm97xx - add BTN_TOUCH events Input: wm97xx - use disable_irq_nosync() for Mainstone Input: wm97xx - add BTN_TOUCH event to wm97xx to use it with Android Input: fix polling of /proc/bus/input/devices Input: psmouse - add newline to OLPC HGPK touchpad debugging Input: ati_remote2 - check module params Input: ati_remote2 - add per device attrs Input: ati_remote2 - complete suspend support Input: stop autorepeat timer on key release ...
2009-04-13PM/Hibernate: Wait for SCSI devices scan to complete during resumeRafael J. Wysocki
There is a race between resume from hibernation and the asynchronous scanning of SCSI devices and to prevent it from happening we need to call scsi_complete_async_scans() during resume from hibernation. In addition, if the resume from hibernation is userland-driven, it's better to wait for all device probes in the kernel to complete before attempting to open the resume device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing/filters: return proper error code when writing filter file tracing/filters: allow user input integer to be oct or hex tracing/filters: fix NULL pointer dereference tracing/filters: NIL-terminate user input filter ftrace: Output REC->var instead of __entry->var for trace format Make __stringify support variable argument macros too tracing: fix document references tracing: fix splice return too large tracing: update file->f_pos when splice(2) it tracing: allocate page when needed tracing: disable seeking for trace_pipe_raw
2009-04-13Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: continue lock debugging despite some taints lockdep: warn about lockdep disabling after kernel taint
2009-04-13Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Let new-style drivers implement attach_adapter i2c: Fix sparse warnings for I2C_BOARD_INFO() i2c-voodoo3: Deprecate in favor of tdfxfb i2c-algo-pca: Fix use of uninitialized variable in debug message
2009-04-13add some long-missing capabilities to fs_maskSerge E. Hallyn
When POSIX capabilities were introduced during the 2.1 Linux cycle, the fs mask, which represents the capabilities which having fsuid==0 is supposed to grant, did not include CAP_MKNOD and CAP_LINUX_IMMUTABLE. However, before capabilities the privilege to call these did in fact depend upon fsuid==0. This patch introduces those capabilities into the fsmask, restoring the old behavior. See the thread starting at http://lkml.org/lkml/2009/3/11/157 for reference. Note that if this fix is deemed valid, then earlier kernel versions (2.4 and 2.2) ought to be fixed too. Changelog: [Mar 23] Actually delete old CAP_FS_SET definition... [Mar 20] Updated against J. Bruce Fields's patch Reported-by: Igor Zhbanov <izh1979@gmail.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: stable@kernel.org Cc: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
