commit 4ffeaf3560a52b4a69cc7909873d08c0ef5909d4 upstream.
The fair zone allocation policy round-robins allocations between zones
within a node to avoid age inversion problems during reclaim. If the
first allocation fails, the batch counts are reset and a second attempt
made before entering the slow path.
One assumption made with this scheme is that batches expire at roughly
the same time and the resets each time are justified. This assumption
does not hold when zones reach their low watermark as the batches will
be consumed at uneven rates. Allocation failure due to watermark
depletion result in additional zonelist scans for the reset and another
watermark check before hitting the slowpath.
On UMA, the benefit is negligible -- around 0.25%. On 4-socket NUMA
machine it's variable due to the variability of measuring overhead with
the vmstat changes. The system CPU overhead comparison looks like
3.16.0-rc3 3.16.0-rc3 3.16.0-rc3
vanilla vmstat-v5 lowercost-v5
User 746.94 774.56 802.00
System 65336.22 32847.27 40852.33
Elapsed 27553.52 27415.04 27368.46
However it is worth noting that the overall benchmark still completed
faster and intuitively it makes sense to take as few passes as possible
through the zonelists.
commit 0d5d823ab4e608ec7b52ac4410de4cb74bbe0edd upstream.
zone->pages_scanned is a write-intensive cache line during page reclaim
and it's also updated during page free. Move the counter into vmstat to
take advantage of the per-cpu updates and do not update it in the free
paths unless necessary.
On a small UMA machine running tiobench the difference is marginal. On
a 4-node machine the overhead is more noticable. Note that automatic
NUMA balancing was disabled for this test as otherwise the system CPU
overhead is unpredictable.
vanillarearrange-v5 vmstat-v5
User 746.94 759.78 774.56
System 65336.22 58350.98 32847.27
Elapsed 27553.52 27282.02 27415.04
Note that the overhead reduction will vary depending on where exactly
pages are allocated and freed.
reclaim lines
commit 3484b2de9499df23c4604a513b36f96326ae81ad upstream.
The arrangement of struct zone has changed over time and now it has
reached the point where there is some inappropriate sharing going on.
On x86-64 for example
o The zone->node field is shared with the zone lock and zone->node is
accessed frequently from the page allocator due to the fair zone
allocation policy.
o span_seqlock is almost never used by shares a line with free_area
o Some zone statistics share a cache line with the LRU lock so
reclaim-intensive and allocator-intensive workloads can bounce the cache
line on a stat update
This patch rearranges struct zone to put read-only and read-mostly
fields together and then splits the page allocator intensive fields, the
zone statistics and the page reclaim intensive fields into their own
cache lines. Note that the type of lowmem_reserve changes due to the
watermark calculations being signed and avoiding a signed/unsigned
conversion there.
On the test configuration I used the overall size of struct zone shrunk
by one cache line. On smaller machines, this is not likely to be
noticable. However, on a 4-node NUMA machine running tiobench the
system CPU overhead is reduced by this patch.
vanillarearrange-v5r9
User 746.94 759.78
commit 24b7e5819ad5cbef2b7c7376510862aa8319d240 upstream.
This was formerly the series "Improve sequential read throughput" which
noted some major differences in performance of tiobench since 3.0.
While there are a number of factors, two that dominated were the
introduction of the fair zone allocation policy and changes to CFQ.
The behaviour of fair zone allocation policy makes more sense than
tiobench as a benchmark and CFQ defaults were not changed due to
insufficient benchmarking.
This series is what's left. It's one functional fix to the fair zone
allocation policy when used on NUMA machines and a reduction of overhead
in general. tiobench was used for the comparison despite its flaws as
an IO benchmark as in this case we are primarily interested in the
overhead of page allocator and page reclaim activity.
On UMA, it makes little difference to overhead
vanilla lowercost-v5
User 383.61 386.77
System 403.83 401.74
Elapsed 5411.50 5413.11
On a 4-socket NUMA machine it's a bit more noticable
User 746.94 802.00
System 65336.22 40852.33
Elapsed 27553.52 27368.46
This patch (of 6):
The LRU insertion and activate tracepoints take PFN as a parameter
forcing the overhead to the caller. Move the overhead to the tracepoint
fast-assign method to ensure the cost is only incurred when the
tracepoint is active.
commit 21bda264f4243f61dfcc485174055f12ad0530b4 upstream.
Commit 71e3aac0724f ("thp: transparent hugepage core") adds
copy_pte_range prototype to huge_mm.h. I'm not sure why (or if) this
function have been used outside of memory.c, but it currently isn't.
This patch makes copy_pte_range() static again.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
possible
commit 2457aec63745e235bcafb7ef312b182d8682f0fc upstream.
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
commit 07a427884348d38a6fd56fa4d78249c407196650 upstream.
shmem_getpage_gfp uses an atomic operation to set the SwapBacked field
before it's even added to the LRU or visible. This is unnecessary as what
could it possible race against? Use an unlocked variant.
commit b745bc85f21ea707e4ea1a91948055fa3e72c77b upstream.
cold is a bool, make it one. Make the likely case the "if" part of the
block instead of the else as according to the optimisation manual this is
preferred.
commit dc4b0caff24d9b2918e9f27bc65499ee63187eba upstream.
In the free path we calculate page_to_pfn multiple times. Reduce that.
Acked-by: Vlastimil Babka <vbabka@suse.cz>
commit 7aeb09f9104b760fc53c98cb7d20d06640baf9e6 upstream.
X86 prefers the use of unsigned types for iterators and there is a
tendency to mix whether a signed or unsigned type if used for page order.
This converts a number of sites in mm/page_alloc.c to use unsigned int for
order where possible.
commit 664eeddeef6539247691197c1ac124d4aa872ab6 upstream.
If cpusets are not in use then we still check a global variable on every
page allocation. Use jump labels to avoid the overhead.
commit ea5e9539abf1258f23e725cb9cb25aa74efa29eb upstream.
This patch exposes the jump_label reference count in preparation for the
next patch. cpusets cares about both the jump_label being enabled and how
many users of the cpusets there currently are.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
commit 2329d3751b082b4fd354f334a88662d72abac52d upstream.
In mm/swap.c, __lru_cache_add() is exported, but actually there are no
users outside this file.
This patch unexports __lru_cache_add(), and makes it static. It also
exports lru_cache_add_file(), as it is use by cifs and fuse, which can
loaded as modules.
Signed-off-by: Jianyu Zhan <nasa4836@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Shaohua Li <shli@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Seth Jennings <sjenning@linux.vnet.ibm.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Khalid Aziz <khalid.aziz@oracle.com>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
commit f8c9301fa5a2a8b873c67f2a3d8230d5c13f61b7 upstream.
During compaction, update_nr_listpages() has been used to count remaining
non-migrated and free pages after a call to migrage_pages(). The
freepages counting has become unneccessary, and it turns out that
migratepages counting is also unnecessary in most cases.
The only situation when it's needed to count cc->migratepages is when
migrate_pages() returns with a negative error code. Otherwise, the
non-negative return value is the number of pages that were not migrated,
which is exactly the count of remaining pages in the cc->migratepages
list.
Furthermore, any non-zero count is only interesting for the tracepoint of
mm_compaction_migratepages events, because after that all remaining
unmigrated pages are put back and their count is set to 0.
This patch therefore removes update_nr_listpages() completely, and changes
the tracepoint definition so that the manual counting is done only when
the tracepoint is enabled, and only when migrate_pages() returns a
Furthermore, migrate_pages() and the tracepoints won't be called when
there's nothing to migrate. This potentially avoids some wasted cycles
and reduces the volume of uninteresting mm_compaction_migratepages events
where "nr_migrated=0 nr_failed=0". In the stress-highalloc mmtest, this
was about 75% of the events. The mm_compaction_isolate_migratepages event
is better for determining that nothing was isolated for migration, and
this one was just duplicating the info.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Christoph Lameter <cl@linux.com>
commit e0b9daeb453e602a95ea43853dc12d385558ce1f upstream.
We're going to want to manipulate the migration mode for compaction in the
page allocator, and currently compact_control's sync field is only a bool.
Currently, we only do MIGRATE_ASYNC or MIGRATE_SYNC_LIGHT compaction
depending on the value of this bool. Convert the bool to enum
migrate_mode and pass the migration mode in directly. Later, we'll want
to avoid MIGRATE_SYNC_LIGHT for thp allocations in the pagefault patch to
avoid unnecessary latency.
This also alters compaction triggered from sysfs, either for the entire
system or for a node, to force MIGRATE_SYNC.
[akpm@linux-foundation.org: fix build]
[iamjoonsoo.kim@lge.com: use MIGRATE_SYNC in alloc_contig_range()]
Signed-off-by: David Rientjes <rientjes@google.com>
Suggested-by: Mel Gorman <mgorman@suse.de>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit 35979ef3393110ff3c12c6b94552208d3bdf1a36 upstream.
Each zone has a cached migration scanner pfn for memory compaction so that
subsequent calls to memory compaction can start where the previous call
left off.
Currently, the compaction migration scanner only updates the per-zone
cached pfn when pageblocks were not skipped for async compaction. This
creates a dependency on calling sync compaction to avoid having subsequent
calls to async compaction from scanning an enormous amount of non-MOVABLE
pageblocks each time it is called. On large machines, this could be
potentially very expensive.
This patch adds a per-zone cached migration scanner pfn only for async
compaction. It is updated everytime a pageblock has been scanned in its
entirety and when no pages from it were successfully isolated. The cached
migration scanner pfn for sync compaction is updated only when called for
sync compaction.
commit 68711a746345c44ae00c64d8dbac6a9ce13ac54a upstream.
Memory migration uses a callback defined by the caller to determine how to
allocate destination pages. When migration fails for a source page,
however, it frees the destination page back to the system.
This patch adds a memory migration callback defined by the caller to
determine how to free destination pages. If a caller, such as memory
compaction, builds its own freelist for migration targets, this can reuse
already freed memory instead of scanning additional memory.
If the caller provides a function to handle freeing of destination pages,
it is called when page migration fails. If the caller passes NULL then
freeing back to the system will be handled as usual. This patch
introduces no functional change.
commit 29f175d125f0f3a9503af8a5596f93d714cceb08 upstream.
Commit f9acc8c7b35a ("readahead: sanify file_ra_state names") left
ra_submit with a single function call.
Move ra_submit to internal.h and inline it to save some stack. Thanks
to Andrew Morton for commenting different versions.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
commit 67f9fd91f93c582b7de2ab9325b6e179db77e4d5 upstream.
This patch removes read_cache_page_async() which wasn't really needed
anywhere and simplifies the code around it a bit.
read_cache_page_async() is useful when we want to read a page into the
cache without waiting for it to complete. This happens when the
appropriate callback 'filler' doesn't complete its read operation and
releases the page lock immediately, and instead queues a different
completion routine to do that. This never actually happened anywhere in
the code.
read_cache_page_async() had 3 different callers:
- read_cache_page() which is the sync version, it would just wait for
the requested read to complete using wait_on_page_read().
- JFFS2 would call it from jffs2_gc_fetch_page(), but the filler
function it supplied doesn't do any async reads, and would complete
before the filler function returns - making it actually a sync read.
- CRAMFS would call it using the read_mapping_page_async() wrapper, with
a similar story to JFFS2 - the filler function doesn't do anything that
reminds async reads and would always complete before the filler function
returns.
To sum it up, the code in mm/filemap.c never took advantage of having
read_cache_page_async(). While there are filler callbacks that do async
reads (such as the block one), we always called it with the
read_cache_page().
This patch adds a mandatory wait for read to complete when adding a new
page to the cache, and removes read_cache_page_async() and its wrappers.
commit 0cd6144aadd2afd19d1aca880153530c52957604 upstream.
shmem mappings already contain exceptional entries where swap slot
information is remembered.
To be able to store eviction information for regular page cache, prepare
every site dealing with the radix trees directly to handle entries other
than pages.
The common lookup functions will filter out non-page entries and return
NULL for page cache holes, just as before. But provide a raw version of
the API which returns non-page entries as well, and switch shmem over to
use it.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
commit e7b563bb2a6f4d974208da46200784b9c5b5a47e upstream.
The radix tree hole searching code is only used for page cache, for
example the readahead code trying to get a a picture of the area
surrounding a fault.
It sufficed to rely on the radix tree definition of holes, which is
"empty tree slot". But this is about to change, though, as shadow page
descriptors will be stored in the page cache after the actual pages get
evicted from memory.
Move the functions over to mm/filemap.c and make them native page cache
operations, where they can later be adapted to handle the new definition
of "page cache hole".
commit 53c59f262d747ea82e7414774c59a489501186a0 upstream.
Provide a function that does not just delete an entry at a given index,
but also allows passing in an expected item. Delete only if that item
is still located at the specified index.
This is handy when lockless tree traversals want to delete entries as
well because they don't have to do an second, locked lookup to verify
the slot has not changed under them before deleting the entry.
commit 615d6e8756c87149f2d4c1b93d471bca002bd849 upstream.
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
commit d26914d11751b23ca2e8747725f2cae10c2f2c1b upstream.
Since put_mems_allowed() is strictly optional, its a seqcount retry, we
don't need to evaluate the function if the allocation was in fact
successful, saving a smp_rmb some loads and comparisons on some relative
fast-paths.
Since the naming, get/put_mems_allowed() does suggest a mandatory
pairing, rename the interface, as suggested by Mel, to resemble the
seqcount interface.
This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(),
where it is important to note that the return value of the latter call
is inverted from its previous incarnation.
commit 943dca1a1fcbccb58de944669b833fd38a6c809b upstream.
Yasuaki Ishimatsu reported memory hot-add spent more than 5 _hours_ on
9TB memory machine since onlining memory sections is too slow. And we
found out setup_zone_migrate_reserve spent >90% of the time.
The problem is, setup_zone_migrate_reserve scans all pageblocks
unconditionally, but it is only necessary if the number of reserved
block was reduced (i.e. memory hot remove).
Moreover, maximum MIGRATE_RESERVE per zone is currently 2. It means
that the number of reserved pageblocks is almost always unchanged.
This patch adds zone->nr_migrate_reserve_block to maintain the number of
MIGRATE_RESERVE pageblocks and it reduces the overhead of
setup_zone_migrate_reserve dramatically. The following table shows time
of onlining a memory section.
Amount of memory | 128GB | 192GB | 256GB|
linux-3.12 | 23.9 | 31.4 | 44.5 |
This patch | 8.3 | 8.3 | 8.6 |
Mel's proposal patch | 10.9 | 19.2 | 31.3 |
(millisecond)
128GB : 4 nodes and each node has 32GB of memory
192GB : 6 nodes and each node has 32GB of memory
256GB : 8 nodes and each node has 32GB of memory
(*1) Mel proposed his idea by the following threads.
https://lkml.org/lkml/2013/10/30/272
[akpm@linux-foundation.org: tweak comment]
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reported-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
commit 579f82901f6f41256642936d7e632f3979ad76d4 upstream.
This is a patch to improve swap readahead algorithm. It's from Hugh and
I slightly changed it.
Hugh's original changelog:
swapin readahead does a blind readahead, whether or not the swapin is
sequential. This may be ok on harddisk, because large reads have
relatively small costs, and if the readahead pages are unneeded they can
be reclaimed easily - though, what if their allocation forced reclaim of
useful pages? But on SSD devices large reads are more expensive than
small ones: if the readahead pages are unneeded, reading them in caused
significant overhead.
This patch adds very simplistic random read detection. Stealing the
PageReadahead technique from Konstantin Khlebnikov's patch, avoiding the
vma/anon_vma sophistications of Shaohua Li's patch, swapin_nr_pages()
simply looks at readahead's current success rate, and narrows or widens
its readahead window accordingly. There is little science to its
heuristic: it's about as stupid as can be whilst remaining effective.
The table below shows elapsed times (in centiseconds) when running a
single repetitive swapping load across a 1000MB mapping in 900MB ram
with 1GB swap (the harddisk tests had taken painfully too long when I
used mem=500M, but SSD shows similar results for that).
Vanilla is the 3.6-rc7 kernel on which I started; Shaohua denotes his
Sep 3 patch in mmotm and linux-next; HughOld denotes my Oct 1 patch
which Shaohua showed to be defective; HughNew this Nov 14 patch, with
page_cluster as usual at default of 3 (8-page reads); HughPC4 this same
patch with page_cluster 4 (16-page reads); HughPC0 with page_cluster 0
(1-page reads: no readahead).
HDD for swapping to harddisk, SSD for swapping to VertexII SSD. Seq for
sequential access to the mapping, cycling five times around; Rand for
the same number of random touches. Anon for a MAP_PRIVATE anon mapping;
Shmem for a MAP_SHARED anon mapping, equivalent to tmpfs.
One weakness of Shaohua's vma/anon_vma approach was that it did not
optimize Shmem: seen below. Konstantin's approach was perhaps mistuned,
50% slower on Seq: did not compete and is not shown below.
HDD Vanilla Shaohua HughOld HughNew HughPC4 HughPC0
Seq Anon 73921 76210 75611 76904 78191 121542
Seq Shmem 73601 73176 73855 72947 74543 118322
Rand Anon 895392 831243 871569 845197 846496 841680
Rand Shmem 1058375 1053486 827935 764955 764376 756489
SSD Vanilla Shaohua HughOld HughNew HughPC4 HughPC0
Seq Anon 24634 24198 24673 25107 21614 70018
Seq Shmem 24959 24932 25052 25703 22030 69678
Rand Anon 43014 26146 28075 25989 26935 25901
Rand Shmem 45349 45215 28249 24268 24138 24332
These tests are, of course, two extremes of a very simple case: under
heavier mixed loads I've not yet observed any consistent improvement or
degradation, and wider testing would be welcome.
Shaohua Li:
Test shows Vanilla is slightly better in sequential workload than Hugh's
patch. I observed with Hugh's patch sometimes the readahead size is
shrinked too fast (from 8 to 1 immediately) in sequential workload if
there is no hit. And in such case, continuing doing readahead is good
actually.
I don't prepare a sophisticated algorithm for the sequential workload
because so far we can't guarantee sequential accessed pages are swap out
sequentially. So I slightly change Hugh's heuristic - don't shrink
readahead size too fast.
Here is my test result (unit second, 3 runs average):
Vanilla Hugh New
Seq 356 370 360
Random 4525 2447 2444
Attached graph is the swapin/swapout throughput I collected with 'vmstat
2'. The first part is running a random workload (till around 1200 of
the x-axis) and the second part is running a sequential workload.
swapin and swapout throughput are almost identical in steady state in
both workloads. These are expected behavior. while in Vanilla, swapin
is much bigger than swapout especially in random workload (because wrong
readahead).
Original patches by: Shaohua Li and Konstantin Khlebnikov.
[fengguang.wu@intel.com: swapin_nr_pages() can be static]
Signed-off-by: Shaohua Li <shli@fusionio.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
commit de6c60a6c115acaa721cfd499e028a413d1fcbf3 upstream.
Currently there are several functions to manipulate the deferred
compaction state variables. The remaining case where the variables are
touched directly is when a successful allocation occurs in direct
compaction, or is expected to be successful in the future by kswapd.
Here, the lowest order that is expected to fail is updated, and in the
case of successful allocation, the deferred status and counter is reset
completely.
Create a new function compaction_defer_reset() to encapsulate this
functionality and make it easier to understand the code. No functional
change.
commit 0eb927c0ab789d3d7d69f68acb850f69d4e7c36f upstream.
The broad goal of the series is to improve allocation success rates for
huge pages through memory compaction, while trying not to increase the
compaction overhead. The original objective was to reintroduce
capturing of high-order pages freed by the compaction, before they are
split by concurrent activity. However, several bugs and opportunities
for simple improvements were found in the current implementation, mostly
through extra tracepoints (which are however too ugly for now to be
considered for sending).
The patches mostly deal with two mechanisms that reduce compaction
overhead, which is caching the progress of migrate and free scanners,
and marking pageblocks where isolation failed to be skipped during
further scans.
Patch 1 (from mgorman) adds tracepoints that allow calculate time spent in
compaction and potentially debug scanner pfn values.
Patch 2 encapsulates the some functionality for handling deferred compactions
for better maintainability, without a functional change
type is not determined without being actually needed.
Patch 3 fixes a bug where cached scanner pfn's are sometimes reset only after
they have been read to initialize a compaction run.
Patch 4 fixes a bug where scanners meeting is sometimes not properly detected
and can lead to multiple compaction attempts quitting early without
doing any work.
Patch 5 improves the chances of sync compaction to process pageblocks that
async compaction has skipped due to being !MIGRATE_MOVABLE.
Patch 6 improves the chances of sync direct compaction to actually do anything
when called after async compaction fails during allocation slowpath.
The impact of patches were validated using mmtests's stress-highalloc
benchmark with mmtests's stress-highalloc benchmark on a x86_64 machine
with 4GB memory.
Due to instability of the results (mostly related to the bugs fixed by
patches 2 and 3), 10 iterations were performed, taking min,mean,max
values for success rates and mean values for time and vmstat-based
metrics.
First, the default GFP_HIGHUSER_MOVABLE allocations were tested with the
patches stacked on top of v3.13-rc2. Patch 2 is OK to serve as baseline
due to no functional changes in 1 and 2. Comments below.
stress-highalloc
3.13-rc2 3.13-rc2 3.13-rc2 3.13-rc2 3.13-rc2
2-nothp 3-nothp 4-nothp 5-nothp 6-nothp
Success 1 Min 9.00 ( 0.00%) 10.00 (-11.11%) 43.00 (-377.78%) 43.00 (-377.78%) 33.00 (-266.67%)
Success 1 Mean 27.50 ( 0.00%) 25.30 ( 8.00%) 45.50 (-65.45%) 45.90 (-66.91%) 46.30 (-68.36%)
Success 1 Max 36.00 ( 0.00%) 36.00 ( 0.00%) 47.00 (-30.56%) 48.00 (-33.33%) 52.00 (-44.44%)
Success 2 Min 10.00 ( 0.00%) 8.00 ( 20.00%) 46.00 (-360.00%) 45.00 (-350.00%) 35.00 (-250.00%)
Success 2 Mean 26.40 ( 0.00%) 23.50 ( 10.98%) 47.30 (-79.17%) 47.60 (-80.30%) 48.10 (-82.20%)
Success 2 Max 34.00 ( 0.00%) 33.00 ( 2.94%) 48.00 (-41.18%) 50.00 (-47.06%) 54.00 (-58.82%)
Success 3 Min 65.00 ( 0.00%) 63.00 ( 3.08%) 85.00 (-30.77%) 84.00 (-29.23%) 85.00 (-30.77%)
Success 3 Mean 76.70 ( 0.00%) 70.50 ( 8.08%) 86.20 (-12.39%) 85.50 (-11.47%) 86.00 (-12.13%)
Success 3 Max 87.00 ( 0.00%) 86.00 ( 1.15%) 88.00 ( -1.15%) 87.00 ( 0.00%) 87.00 ( 0.00%)
User 6437.72 6459.76 5960.32 5974.55 6019.67
System 1049.65 1049.09 1029.32 1031.47 1032.31
Elapsed 1856.77 1874.48 1949.97 1994.22 1983.15
Minor Faults 253952267 254581900 250030122 250507333 250157829
Major Faults 420 407 506 530 530
Swap Ins 4 9 9 6 6
Swap Outs 398 375 345 346 333
Direct pages scanned 197538 189017 298574 287019 299063
Kswapd pages scanned 1809843 1801308 1846674 1873184 1861089
Kswapd pages reclaimed 1806972 1798684 1844219 1870509 1858622
Direct pages reclaimed 197227 188829 298380 286822 298835
Kswapd efficiency 99% 99% 99% 99% 99%
Kswapd velocity 953.382 970.449 952.243 934.569 922.286
Direct efficiency 99% 99% 99% 99% 99%
Direct velocity 104.058 101.832 153.961 143.200 148.205
Percentage direct scans 9% 9% 13% 13% 13%
Zone normal velocity 347.289 359.676 348.063 339.933 332.983
Zone dma32 velocity 710.151 712.605 758.140 737.835 737.507
Zone dma velocity 0.000 0.000 0.000 0.000 0.000
Page writes by reclaim 557.600 429.000 353.600 426.400 381.800
Page writes file 159 53 7 79 48
Page writes anon 398 375 345 346 333
Page reclaim immediate 825 644 411 575 420
Sector Reads 2781750 2769780 2878547 2939128 2910483
Sector Writes 12080843 12083351 12012892 12002132 12010745
Page rescued immediate 0 0 0 0 0
Slabs scanned 1575654 1545344 1778406 1786700 1794073
Direct inode steals 9657 10037 15795 14104 14645
Kswapd inode steals 46857 46335 50543 50716 51796
Kswapd skipped wait 0 0 0 0 0
THP fault alloc 97 91 81 71 77
THP collapse alloc 456 506 546 544 565
THP splits 6 5 5 4 4
THP fault fallback 0 1 0 0 0
THP collapse fail 14 14 12 13 12
Compaction stalls 1006 980 1537 1536 1548
Compaction success 303 284 562 559 578
Compaction failures 702 696 974 976 969
Page migrate success 1177325 1070077 3927538 3781870 3877057
Page migrate failure 0 0 0 0 0
Compaction pages isolated 2547248 2306457 8301218 8008500 8200674
Compaction migrate scanned 42290478 38832618 153961130 154143900 159141197
Compaction free scanned 89199429 79189151 356529027 351943166 356326727
Compaction cost 1566 1426 5312 5156 5294
NUMA PTE updates 0 0 0 0 0
NUMA hint faults 0 0 0 0 0
NUMA hint local faults 0 0 0 0 0
NUMA hint local percent 100 100 100 100 100
NUMA pages migrated 0 0 0 0 0
AutoNUMA cost 0 0 0 0 0
Observations:
- The "Success 3" line is allocation success rate with system idle
(phases 1 and 2 are with background interference). I used to get stable
values around 85% with vanilla 3.11. The lower min and mean values came
with 3.12. This was bisected to commit 81c0a2bb ("mm: page_alloc: fair
zone allocator policy") As explained in comment for patch 3, I don't
think the commit is wrong, but that it makes the effect of compaction
bugs worse. From patch 3 onwards, the results are OK and match the 3.11
results.
- Patch 4 also clearly helps phases 1 and 2, and exceeds any results
I've seen with 3.11 (I didn't measure it that thoroughly then, but it
was never above 40%).
- Compaction cost and number of scanned pages is higher, especially due
to patch 4. However, keep in mind that patches 3 and 4 fix existing
bugs in the current design of compaction overhead mitigation, they do
not change it. If overhead is found unacceptable, then it should be
decreased differently (and consistently, not due to random conditions)
than the current implementation does. In contrast, patches 5 and 6
(which are not strictly bug fixes) do not increase the overhead (but
also not success rates). This might be a limitation of the
stress-highalloc benchmark as it's quite uniform.
Another set of results is when configuring stress-highalloc t allocate
with similar flags as THP uses:
(GFP_HIGHUSER_MOVABLE|__GFP_NOMEMALLOC|__GFP_NORETRY|__GFP_NO_KSWAPD)
stress-highalloc
2-thp 3-thp 4-thp 5-thp 6-thp
Success 1 Min 2.00 ( 0.00%) 7.00 (-250.00%) 18.00 (-800.00%) 19.00 (-850.00%) 26.00 (-1200.00%)
Success 1 Mean 19.20 ( 0.00%) 17.80 ( 7.29%) 29.20 (-52.08%) 29.90 (-55.73%) 32.80 (-70.83%)
Success 1 Max 27.00 ( 0.00%) 29.00 ( -7.41%) 35.00 (-29.63%) 36.00 (-33.33%) 37.00 (-37.04%)
Success 2 Min 3.00 ( 0.00%) 8.00 (-166.67%) 21.00 (-600.00%) 21.00 (-600.00%) 32.00 (-966.67%)
Success 2 Mean 19.30 ( 0.00%) 17.90 ( 7.25%) 32.20 (-66.84%) 32.60 (-68.91%) 35.70 (-84.97%)
Success 2 Max 27.00 ( 0.00%) 30.00 (-11.11%) 36.00 (-33.33%) 37.00 (-37.04%) 39.00 (-44.44%)
Success 3 Min 62.00 ( 0.00%) 62.00 ( 0.00%) 85.00 (-37.10%) 75.00 (-20.97%) 64.00 ( -3.23%)
Success 3 Mean 66.30 ( 0.00%) 65.50 ( 1.21%) 85.60 (-29.11%) 83.40 (-25.79%) 83.50 (-25.94%)
Success 3 Max 70.00 ( 0.00%) 69.00 ( 1.43%) 87.00 (-24.29%) 86.00 (-22.86%) 87.00 (-24.29%)
User 6547.93 6475.85 6265.54 6289.46 6189.96
System 1053.42 1047.28 1043.23 1042.73 1038.73
Elapsed 1835.43 1821.96 1908.67 1912.74 1956.38
Minor Faults 256805673 253106328 253222299 249830289 251184418
Major Faults 395 375 423 434 448
Swap Ins 12 10 10 12 9
Swap Outs 530 537 487 455 415
Direct pages scanned 71859 86046 153244 152764 190713
Kswapd pages scanned 1900994 1870240 1898012 1892864 1880520
Kswapd pages reclaimed 1897814 1867428 1894939 1890125 1877924
Direct pages reclaimed 71766 85908 153167 152643 190600
Kswapd velocity 1029.000 1067.782 1000.091 991.049 951.218
Direct velocity 38.897 49.127 80.747 79.983 96.468
Percentage direct scans 3% 4% 7% 7% 9%
Zone normal velocity 351.377 372.494 348.910 341.689 335.310
Zone dma32 velocity 716.520 744.414 731.928 729.343 712.377
Page writes by reclaim 669.300 604.000 545.700 538.900 429.900
Page writes file 138 66 58 83 14
Page writes anon 530 537 487 455 415
Page reclaim immediate 806 655 772 548 517
Sector Reads 2711956 2703239 2811602 2818248 2839459
Sector Writes 12163238 12018662 12038248 11954736 11994892
Slabs scanned 1385088 1388364 1507968 1513292 1558656
Direct inode steals 1739 2564 4622 5496 6007
Kswapd inode steals 47461 46406 47804 48013 48466
THP fault alloc 110 82 84 69 70
THP collapse alloc 445 482 467 462 539
THP splits 6 5 4 5 3
THP fault fallback 3 0 0 0 0
THP collapse fail 15 14 14 14 13
Compaction stalls 659 685 1033 1073 1111
Compaction success 222 225 410 427 456
Compaction failures 436 460 622 646 655
Page migrate success 446594 439978 1085640 1095062 1131716
Compaction pages isolated 1029475 1013490 2453074 2482698 2565400
Compaction migrate scanned 9955461 11344259 24375202 27978356 30494204
Compaction free scanned 27715272 28544654 80150615 82898631 85756132
Compaction cost 552 555 1344 1379 1436
There are some differences from the previous results for THP-like allocations:
- Here, the bad result for unpatched kernel in phase 3 is much more
consistent to be between 65-70% and not related to the "regression" in
3.12. Still there is the improvement from patch 4 onwards, which brings
it on par with simple GFP_HIGHUSER_MOVABLE allocations.
- Compaction costs have increased, but nowhere near as much as the
non-THP case. Again, the patches should be worth the gained
determininsm.
- Patches 5 and 6 somewhat increase the number of migrate-scanned pages.
This is most likely due to __GFP_NO_KSWAPD flag, which means the cached
pfn's and pageblock skip bits are not reset by kswapd that often (at
least in phase 3 where no concurrent activity would wake up kswapd) and
the patches thus help the sync-after-async compaction. It doesn't
however show that the sync compaction would help so much with success
rates, which can be again seen as a limitation of the benchmark
scenario.
This patch (of 6):
Add two tracepoints for compaction begin and end of a zone. Using this it
is possible to calculate how much time a workload is spending within
compaction and potentially debug problems related to cached pfns for
scanning. In combination with the direct reclaim and slab trace points it
should be possible to estimate most allocation-related overhead for a
workload.
commit ec65993443736a5091b68e80ff1734548944a4b8 upstream.
Bisection between 3.11 and 3.12 fingered commit 9824cf97 ("mm:
vmstats: tlb flush counters") to cause overhead problems.
The counters are undeniably useful but how often do we really
need to debug TLB flush related issues? It does not justify
taking the penalty everywhere so make it a debugging option.
Tested-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Alex Shi <alex.shi@linaro.org>
Link: http://lkml.kernel.org/n/tip-XzxjntugxuwpxXhcrxqqh53b@git.kernel.org
commit 52c8f6a5aeb0bdd396849ecaa72d96f8175528f5 upstream.
In general, every tracepoint should be zero overhead if it is disabled.
However, trace_mm_page_alloc_extfrag() is one of exception. It evaluate
"new_type == start_migratetype" even if tracepoint is disabled.
However, the code can be moved into tracepoint's TP_fast_assign() and
TP_fast_assign exist exactly such purpose. This patch does it.
commit 18ab4d4ced0817421e6db6940374cc39d28d65da upstream.
Originally get_swap_page() started iterating through the singly-linked
list of swap_info_structs using swap_list.next or highest_priority_index,
which both were intended to point to the highest priority active swap
target that was not full. The first patch in this series changed the
singly-linked list to a doubly-linked list, and removed the logic to start
at the highest priority non-full entry; it starts scanning at the highest
priority entry each time, even if the entry is full.
Replace the manually ordered swap_list_head with a plist, swap_active_head.
Add a new plist, swap_avail_head. The original swap_active_head plist
contains all active swap_info_structs, as before, while the new
swap_avail_head plist contains only swap_info_structs that are active and
available, i.e. not full. Add a new spinlock, swap_avail_lock, to protect
the swap_avail_head list.
Mel Gorman suggested using plists since they internally handle ordering
the list entries based on priority, which is exactly what swap was doing
manually. All the ordering code is now removed, and swap_info_struct
entries and simply added to their corresponding plist and automatically
ordered correctly.
Using a new plist for available swap_info_structs simplifies and
optimizes get_swap_page(), which no longer has to iterate over full
swap_info_structs. Using a new spinlock for swap_avail_head plist
allows each swap_info_struct to add or remove themselves from the
plist when they become full or not-full; previously they could not
do so because the swap_info_struct->lock is held when they change
from full<->not-full, and the swap_lock protecting the main
swap_active_head must be ordered before any swap_info_struct->lock.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Cc: Shaohua Li <shli@fusionio.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
Cc: Weijie Yang <weijieut@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit a75f232ce0fe38bd01301899ecd97ffd0254316a upstream.
Add plist_requeue(), which moves the specified plist_node after all other
same-priority plist_nodes in the list. This is essentially an optimized
plist_del() followed by plist_add().
This is needed by swap, which (with the next patch in this set) uses a
plist of available swap devices. When a swap device (either a swap
partition or swap file) are added to the system with swapon(), the device
is added to a plist, ordered by the swap device's priority. When swap
needs to allocate a page from one of the swap devices, it takes the page
from the first swap device on the plist, which is the highest priority
swap device. The swap device is left in the plist until all its pages are
used, and then removed from the plist when it becomes full.
However, as described in man 2 swapon, swap must allocate pages from swap
devices with the same priority in round-robin order; to do this, on each
swap page allocation, swap uses a page from the first swap device in the
plist, and then calls plist_requeue() to move that swap device entry to
after any other same-priority swap devices. The next swap page allocation
will again use a page from the first swap device in the plist and requeue
it, and so on, resulting in round-robin usage of equal-priority swap
devices.
Also add plist_test_requeue() test function, for use by plist_test() to
test plist_requeue() function.
commit fd16618e12a05df79a3439d72d5ffdac5d34f3da upstream.
Add PLIST_HEAD() to plist.h, equivalent to LIST_HEAD() from list.h, to
define and initialize a struct plist_head.
Add plist_for_each_continue() and plist_for_each_entry_continue(),
equivalent to list_for_each_continue() and list_for_each_entry_continue(),
to iterate over a plist continuing after the current position.
Add plist_prev() and plist_next(), equivalent to (struct list_head*)->prev
and ->next, implemented by list_prev_entry() and list_next_entry(), to
access the prev/next struct plist_node entry. These are needed because
unlike struct list_head, direct access of the prev/next struct plist_node
isn't possible; the list must be navigated via the contained struct
list_head. e.g. instead of accessing the prev by list_prev_entry(node,
node_list) it can be accessed by plist_prev(node).
commit adfab836f4908deb049a5128082719e689eed964 upstream.
The logic controlling the singly-linked list of swap_info_struct entries
for all active, i.e. swapon'ed, swap targets is rather complex, because:
- it stores the entries in priority order
- there is a pointer to the highest priority entry
- there is a pointer to the highest priority not-full entry
- there is a highest_priority_index variable set outside the swap_lock
- swap entries of equal priority should be used equally
this complexity leads to bugs such as: https://lkml.org/lkml/2014/2/13/181
where different priority swap targets are incorrectly used equally.
That bug probably could be solved with the existing singly-linked lists,
but I think it would only add more complexity to the already difficult to
understand get_swap_page() swap_list iteration logic.
The first patch changes from a singly-linked list to a doubly-linked list
using list_heads; the highest_priority_index and related code are removed
and get_swap_page() starts each iteration at the highest priority
swap_info entry, even if it's full. While this does introduce unnecessary
list iteration (i.e. Schlemiel the painter's algorithm) in the case where
one or more of the highest priority entries are full, the iteration and
manipulation code is much simpler and behaves correctly re: the above bug;
and the fourth patch removes the unnecessary iteration.
The second patch adds some minor plist helper functions; nothing new
really, just functions to match existing regular list functions. These
are used by the next two patches.
The third patch adds plist_requeue(), which is used by get_swap_page() in
the next patch - it performs the requeueing of same-priority entries
(which moves the entry to the end of its priority in the plist), so that
all equal-priority swap_info_structs get used equally.
The fourth patch converts the main list into a plist, and adds a new plist
that contains only swap_info entries that are both active and not full.
As Mel suggested using plists allows removing all the ordering code from
swap - plists handle ordering automatically. The list naming is also
clarified now that there are two lists, with the original list changed
from swap_list_head to swap_active_head and the new list named
swap_avail_head. A new spinlock is also added for the new list, so
swap_info entries can be added or removed from the new list immediately as
they become full or not full.
This patch (of 4):
Replace the singly-linked list tracking active, i.e. swapon'ed,
swap_info_struct entries with a doubly-linked list using struct
list_heads. Simplify the logic iterating and manipulating the list of
entries, especially get_swap_page(), by using standard list_head
functions, and removing the highest priority iteration logic.
The change fixes the bug:
in which different priority swap entries after the highest priority entry
are incorrectly used equally in pairs. The swap behavior is now as
advertised, i.e. different priority swap entries are used in order, and
equal priority swap targets are used concurrently.
commit 457c1b27ed56ec472d202731b12417bff023594a upstream.
Currently, I am seeing the following when I `mount -t hugetlbfs /none
/dev/hugetlbfs`, and then simply do a `ls /dev/hugetlbfs`. I think it's
related to the fact that hugetlbfs is properly not correctly setting
itself up in this state?:
Unable to handle kernel paging request for data at address 0x00000031
Faulting instruction address: 0xc000000000245710
Oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=2048 NUMA pSeries
In KVM guests on Power, in a guest not backed by hugepages, we see the
following:
AnonHugePages: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 64 kB
HPAGE_SHIFT == 0 in this configuration, which indicates that hugepages
are not supported at boot-time, but this is only checked in
hugetlb_init(). Extract the check to a helper function, and use it in a
few relevant places.
This does make hugetlbfs not supported (not registered at all) in this
environment. I believe this is fine, as there are no valid hugepages
and that won't change at runtime.
[akpm@linux-foundation.org: use pr_info(), per Mel]
[akpm@linux-foundation.org: fix build when HPAGE_SHIFT is undefined]
Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
commit db1044d458a287c18c4d413adc4ad12e92e253b5 upstream.
added struct sockaddr_storage to rdma_user_cm.h without also adding an
include for linux/socket.h to make sure it is defined. Systemtap
needs the header files to build standalone and cannot rely on other
files to pre-include other headers, so add linux/socket.h to the list
of includes in this file.
Fixes: ee7aed4528f ("RDMA/ucma: Support querying for AF_IB addresses")
Signed-off-by: Doug Ledford <dledford@redhat.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 0213436a2cc5e4a5ca2fabfaa4d3877097f3b13f upstream.
Some devices don't like REPORT SUPPORTED OPERATION CODES and will
simply timeout causing sd_mod init to take a very very long time.
Introduce BLIST_NO_RSOC scsi scan flag, that stops RSOC from being
issued. Add it to Promise Vtrak E610f entry in scsi scan
blacklist. Fixes bug #79901 reported at
https://bugzilla.kernel.org/show_bug.cgi?id=79901
Fixes: 98dcc2946adb ("SCSI: sd: Update WRITE SAME heuristics")
Signed-off-by: Janusz Dziemidowicz <rraptorr@nails.eu.org>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
commit c1d40a527e885a40bb9ea6c46a1b1145d42b66a0 upstream.
Despite supporting modern SCSI features some storage devices continue to
claim conformance to an older version of the SPC spec. This is done for
compatibility with legacy operating systems.
Linux by default will not attempt to read VPD pages on devices that
claim SPC-2 or older. Introduce a blacklist flag that can be used to
trigger VPD page inquiries on devices that are known to support them.
Reported-by: KY Srinivasan <kys@microsoft.com>
Tested-by: KY Srinivasan <kys@microsoft.com>
Reviewed-by: KY Srinivasan <kys@microsoft.com>
commit 22ffeb48b7584d6cd50f2a595ed6065d86a87459 upstream.
Sequential scan for more than 256 LUNs is very fragile as
LUNs might not be numbered sequentially after that point.
SAM revisions later than SCSI-3 impose a structure on
LUNs larger than 256, making LUN numbers between 256
and 16384 illegal.
SCSI-3, however allows for plain 64-bit numbers with
no internal structure.
So restrict sequential LUN scan to 256 LUNs and add a
new blacklist flag 'BLIST_SCSI3LUN' to scan up to
max_lun devices.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Ewan Milne <emilne@redhat.com>
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream.
The current code always selects XPRT_TRANSPORT_BC_TCP for the back
channel, even when the forward channel was not TCP (eg, RDMA). When
a 4.1 mount is attempted with RDMA, the server panics in the TCP BC
code when trying to send CB_NULL.
Instead, construct the transport protocol number from the forward
channel transport or'd with XPRT_TRANSPORT_BC. Transports that do
not support bi-directional RPC will not have registered a "BC"
transport, causing create_backchannel_client() to fail immediately.
Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit db9ee220361de03ee86388f9ea5e529eaad5323c upstream.
It turns out that there are some serious problems with the on-disk
format of journal checksum v2. The foremost is that the function to
calculate descriptor tag size returns sizes that are too big. This
causes alignment issues on some architectures and is compounded by the
fact that some parts of jbd2 use the structure size (incorrectly) to
determine the presence of a 64bit journal instead of checking the
feature flags.
Therefore, introduce journal checksum v3, which enlarges the
descriptor block tag format to allow for full 32-bit checksums of
journal blocks, fix the journal tag function to return the correct
sizes, and fix the jbd2 recovery code to use feature flags to
determine 64bitness.
Add a few function helpers so we don't have to open-code quite so
many pieces.
Switching to a 16-byte block size was found to increase journal size
overhead by a maximum of 0.1%, to convert a 32-bit journal with no
checksumming to a 32-bit journal with checksum v3 enabled.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reported-by: TR Reardon <thomas_reardon@hotmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 37dbeab788a8f23fd946c0be083e5484d6f929a1 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 5fc540edc8ea1297c76685f74bc82a2107fe6731 upstream.
commit 6dc14baf4ced769017c7a7045019c7a19f373865 upstream.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=82912
commit c6bde215acfd637708142ae671843b6f0eadbc6d upstream.
This adds a pci_upstream_bridge() interface to find the PCI-to-PCI bridge
upstream from a device. This is typically just "dev->bus->self", but in
the case of a VF on a virtual bus, we have to start from the corresponding
PF. Returns NULL if there is no upstream PCI bridge, i.e., if the device
is on a root bus.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
commit cbcd1054a1fd2aa980fc11ff28e436fc4aaa2d54 upstream.
Commit 08778795 ("block: Fix nr_vecs for inline integrity vectors") from
Martin introduces the function bip_integrity_vecs(get the useful vectors)
to fix the issue about nr_vecs for inline integrity vectors that reported
by David Milburn.
But it seems that bip_integrity_vecs() will return the wrong number if the
bio is not based on any bio_set for some reason(bio->bi_pool == NULL),
because in that case, the bip_inline_vecs[0] is malloced directly. So
here we add the bip_max_vcnt to record the count of vector slots, and
cleanup the function bip_integrity_vecs().
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Kent Overstreet <kmo@daterainc.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit cd83ce9e6195aa3ea15ab4db92892802c20df5d0 upstream.
This patch adds a usb quirk to support devices with interupt endpoints
and bInterval values expressed as microframes. The quirk causes the
parse endpoint function to modify the reported bInterval to a standards
conforming value.
There is currently code in the endpoint parser that checks for
bIntervals that are outside of the valid range (1-16 for USB 2+ high
speed and super speed interupt endpoints). In this case, the code assumes
the bInterval is being reported in 1ms frames. As well, the correction
is only applied if the original bInterval value is out of the 1-16 range.
With this quirk applied to the device, the bInterval will be
accurately adjusted from microframes to an exponent.
Signed-off-by: James P Michels III <james.p.michels@gmail.com>
commit 4aa806b771d16b810771d86ce23c4c3160888db3 upstream.
Provide a helper to set both the DMA and coherent DMA masks to the
same value - this avoids duplicated code in a number of drivers,
sometimes with buggy error handling, and also allows us identify
which drivers do things differently.
commit 9566d6742852c527bf5af38af5cbb878dad75705 upstream.
While invesgiating the issue where in "mount --bind -oremount,ro ..."
would result in later "mount --bind -oremount,rw" succeeding even if
the mount started off locked I realized that there are several
additional mount flags that should be locked and are not.
In particular MNT_NOSUID, MNT_NODEV, MNT_NOEXEC, and the atime
flags in addition to MNT_READONLY should all be locked. These
flags are all per superblock, can all be changed with MS_BIND,
and should not be changable if set by a more privileged user.
The following additions to the current logic are added in this patch.
- nosuid may not be clearable by a less privileged user.
- nodev may not be clearable by a less privielged user.
- noexec may not be clearable by a less privileged user.
- atime flags may not be changeable by a less privileged user.
The logic with atime is that always setting atime on access is a
global policy and backup software and auditing software could break if
atime bits are not updated (when they are configured to be updated),
and serious performance degradation could result (DOS attack) if atime
updates happen when they have been explicitly disabled. Therefore an
unprivileged user should not be able to mess with the atime bits set
The additional restrictions are implemented with the addition of
MNT_LOCK_NOSUID, MNT_LOCK_NODEV, MNT_LOCK_NOEXEC, and MNT_LOCK_ATIME
mnt flags.
Taken together these changes and the fixes for MNT_LOCK_READONLY
should make it safe for an unprivileged user to create a user
namespace and to call "mount --bind -o remount,... ..." without
the danger of mount flags being changed maliciously.
Cc: stable@vger.kernel.org
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
