path: root/include
2012-01-14Merge branch 'fbdev-next' of git://github.com/schandinat/linux-2.6Linus Torvalds
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (175 commits) module_param: make bool parameters really bool (drivers/video/i810) Revert "atmel_lcdfb: Adjust HFP calculation so it matches the manual." OMAPDSS: HDMI: Disable DDC internal pull up OMAPDSS: HDMI: Move duplicate code from boardfile OMAPDSS: add OrtusTech COM43H4M10XTC display support OMAP: DSS2: Support for UMSH-8173MD TFT panel ASoC: OMAP: HDMI: Move HDMI codec trigger function to generic HDMI driver OMAPDSS: HDMI: Create function to enable HDMI audio ASoC: OMAP: HDMI: Correct signature of ASoC functions ASoC: OMAP: HDMI: Introduce driver data for audio codec grvga: fix section mismatch warnings video: s3c-fb: Don't keep device runtime active when open video: s3c-fb: Hold runtime PM references when touching registers video: s3c-fb: Take a runtime PM reference when unblanked video: s3c-fb: Disable runtime PM in error paths from probe video: s3c-fb: Use s3c_fb_enable() to enable the framebuffer video: s3c-fb: Make runtime PM functional again drivers/video: fsl-diu-fb: merge fsl_diu_alloc() into map_video_memory() drivers/video: fsl-diu-fb: add default platform ops functions drivers/video: fsl-diu-fb: remove broken reference count enabling the display ...
2012-01-14block: fail SCSI passthrough ioctls on partition devicesPaolo Bonzini
Linux allows executing the SG_IO ioctl on a partition or LVM volume, and will pass the command to the underlying block device. This is well-known, but it is also a large security problem when (via Unix permissions, ACLs, SELinux or a combination thereof) a program or user needs to be granted access only to part of the disk. This patch lets partitions forward a small set of harmless ioctls; others are logged with printk so that we can see which ioctls are actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred. Of course it was being sent to a (partition on a) hard disk, so it would have failed with ENOTTY and the patch isn't changing anything in practice. Still, I'm treating it specially to avoid spamming the logs. In principle, this restriction should include programs running with CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and /dev/sdb, it still should not be able to read/write outside the boundaries of /dev/sda2 independent of the capabilities. However, for now programs with CAP_SYS_RAWIO will still be allowed to send the ioctls. Their actions will still be logged. This patch does not affect the non-libata IDE driver. That driver however already tests for bd != bd->bd_contains before issuing some ioctl; it could be restricted further to forbid these ioctls even for programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> [ Make it also print the command name when warning - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-14block: add and use scsi_blk_cmd_ioctlPaolo Bonzini
Introduce a wrapper around scsi_cmd_ioctl that takes a block device. The function will then be enhanced to detect partition block devices and, in that case, subject the ioctls to whitelisting. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-14Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
2nd round of GPIO changes for v3.3 merge window * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: GPIO: sa1100: implement proper gpiolib gpio_to_irq conversion gpio: pl061: remove combined interrupt gpio: pl061: convert to use generic irq chip GPIO: add bindings for managed devices ARM: realview: convert pl061 no irq to 0 instead of -1 gpio: pl061: convert to use 0 for no irq gpio: pl061: use chained_irq_* functions in irq handler GPIO/pl061: Add suspend resume capability drivers/gpio/gpio-tegra.c: use devm_request_and_ioremap
2012-01-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (119 commits) MIPS: Delete unused function add_temporary_entry. MIPS: Set default pci cache line size. MIPS: Flush huge TLB MIPS: Octeon: Remove SYS_SUPPORTS_HIGHMEM. MIPS: Octeon: Add support for OCTEON II PCIe MIPS: Octeon: Update PCI Latency timer and enable more error reporting. MIPS: Alchemy: Update cpu-feature-overrides MIPS: Alchemy: db1200: Improve PB1200 detection. MIPS: Alchemy: merge Au1000 and Au1300-style IRQ controller code. MIPS: Alchemy: chain IRQ controllers to MIPS IRQ controller MIPS: Alchemy: irq: register pm at irq init time MIPS: Alchemy: Touchscreen support on DB1100 MIPS: Alchemy: Hook up IrDA on DB1000/DB1100 net/irda: convert au1k_ir to platform driver. MIPS: Alchemy: remove unused board headers MTD: nand: make au1550nd.c a platform_driver MIPS: Netlogic: Mark Netlogic chips as SMT capable MIPS: Netlogic: Add support for XLP 3XX cores MIPS: Netlogic: Merge some of XLR/XLP wakup code MIPS: Netlogic: Add default XLP config. ... Fix up trivial conflicts in arch/mips/kernel/{perf_event_mipsxx.c, traps.c} and drivers/tty/serial/Makefile
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-14Merge branch 'for-3.3' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.3' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: nfsd4_create_clid_dir return value is unused NFSD: Change name of extended attribute containing junction svcrpc: don't revert to SVC_POOL_DEFAULT on nfsd shutdown svcrpc: fix double-free on shutdown of nfsd after changing pool mode nfsd4: be forgiving in the absence of the recovery directory nfsd4: fix spurious 4.1 post-reboot failures NFSD: forget_delegations should use list_for_each_entry_safe NFSD: Only reinitilize the recall_lru list under the recall lock nfsd4: initialize special stateid's at compile time NFSd: use network-namespace-aware cache registering routines SUNRPC: create svc_xprt in proper network namespace svcrpc: update outdated BKL comment nfsd41: allow non-reclaim open-by-fh's in 4.1 svcrpc: avoid memory-corruption on pool shutdown svcrpc: destroy server sockets all at once svcrpc: make svc_delete_xprt static nfsd: Fix oops when parsing a 0 length export nfsd4: Use kmemdup rather than duplicating its implementation nfsd4: add a separate (lockowner, inode) lookup nfsd4: fix CONFIG_NFSD_FAULT_INJECTION compile error ...
2012-01-13Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: dma-buf: Documentation update for Kconfig select nouveau: Support Optimus models for vga_switcheroo nouveau: properly check for _DSM function support dma-buf: drop option text so users don't select it. radeon: Call pci_clear_master() instead of open-coding it. gma500: Discard modes that don't fit in stolen memory drm: bump DRM_CONNECTOR_MAX_ENCODER from 2 to 3 drm/radeon/kms: Fix module parameter description format drm/radeon/kms/ni: fix packet2 handling for VM IB parser ttm/dma: Remove the WARN() which is not useful.
2012-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (59 commits) rtc: max8925: Add function to work as wakeup source mfd: Add pm ops to max8925 mfd: Convert aat2870 to dev_pm_ops mfd: Still check other interrupts if we get a wm831x touchscreen IRQ mfd: Introduce missing kfree in 88pm860x probe routine mfd: Add S5M series configuration mfd: Add s5m series irq driver mfd: Add S5M core driver mfd: Improve mc13xxx dt binding document mfd: Fix stmpe section mismatch mfd: Fix stmpe build warning mfd: Fix STMPE I2c build failure mfd: Constify aat2870-core i2c_device_id table gpio: Add support for stmpe variant 801 mfd: Add support for stmpe variant 801 mfd: Add support for stmpe variant 610 mfd: Add support for STMPE SPI interface mfd: Separate out STMPE controller and interface specific code misc: Remove max8997-muic sysfs attributes mfd: Remove unused wm831x_irq_data_to_mask_reg() ... Fix up trivial conflict in drivers/leds/Kconfig due to addition of LEDS_MAX8997 and LEDS_TCA6507 next to each other.
2012-01-13Merge tag 'mmc-merge-for-3.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc MMC highlights for 3.3: Core: * Support for the HS200 high-speed eMMC mode. * Support SDIO 3.0 Ultra High Speed cards. * Kill pending block requests immediately if card is removed. * Enable the eMMC feature for locking boot partitions read-only until next power on, exposed via sysfs. Drivers: * Runtime PM support for Intel Medfield SDIO. * Suspend/resume support for sdhci-spear. * sh-mmcif now processes requests asynchronously. * tag 'mmc-merge-for-3.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (58 commits) mmc: fix a deadlock between system suspend and MMC block IO mmc: sdhci: restore the enabled dma when do reset all mmc: dw_mmc: miscaculated the fifo-depth with wrong bit operation mmc: host: Adds support for eMMC 4.5 HS200 mode mmc: core: HS200 mode support for eMMC 4.5 mmc: dw_mmc: fixed wrong bit operation for SDMMC_GET_FCNT() mmc: core: Separate the timeout value for cache-ctrl mmc: sdhci-spear: Fix compilation error mmc: sdhci: Deal with failure case in sdhci_suspend_host mmc: dw_mmc: Clear the DDR mode for non-DDR mmc: sd: Fix SDR12 timing regression mmc: sdhci: Fix tuning timer incorrect setting when suspending host mmc: core: Add option to prevent eMMC sleep command mmc: omap_hsmmc: use threaded irq handler for card-detect. mmc: sdhci-pci: enable runtime PM for Medfield SDIO mmc: sdhci: Always pass clock request value zero to set_clock host op mmc: sdhci-pci: remove SDHCI_QUIRK2_OWN_CARD_DETECTION mmc: sdhci-pci: get gpio numbers from platform data mmc: sdhci-pci: add platform data mmc: sdhci: prevent card detection activity for non-removable cards ...
2012-01-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmwLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw: GFS2: Fix nlink setting on inode creation GFS2: fail mount if journal recovery fails GFS2: let spectator mount do read only recovery GFS2: Fix a use-after-free that coverity spotted GFS2: dlm based recovery coordination
2012-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: ensure prealloc_blob is in place when removing xattr rbd: initialize snap_rwsem in rbd_add() ceph: enable/disable dentry complete flags via mount option vfs: export symbol d_find_any_alias() ceph: always initialize the dentry in open_root_dentry() libceph: remove useless return value for osd_client __send_request() ceph: avoid iput() while holding spinlock in ceph_dir_fsync ceph: avoid useless dget/dput in encode_fh ceph: dereference pointer after checking for NULL crush: fix force for non-root TAKE ceph: remove unnecessary d_fsdata conditional checks ceph: Use kmemdup rather than duplicating its implementation Fix up conflicts in fs/ceph/super.c (d_alloc_root() failure handling vs always initialize the dentry in open_root_dentry)
2012-01-13drm: bump DRM_CONNECTOR_MAX_ENCODER from 2 to 3Ben Skeggs
There exists at least one NVIDIA GPU (Quadro NVS 300) that has a DMS-59 connector which is capable of supporting DisplayPort, TMDS and VGA on a single connector. We need to bump the allowed encoder limit to support all three configs. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-12Merge branch 'akpm' (aka "Andrew's patch-bomb, take two")Linus Torvalds
Andrew explains: - various misc stuff - Most of the rest of MM: memcg, threaded hugepages, others. - cpumask - kexec - kdump - some direct-io performance tweaking - radix-tree optimisations - new selftests code A note on this: often people will develop a new userspace-visible feature and will develop userspace code to exercise/test that feature. Then they merge the patch and the selftest code dies. Sometimes we paste it into the changelog. Sometimes the code gets thrown into Documentation/(!). This saddens me. So this patch creates a bare-bones framework which will henceforth allow me to ask people to include their test apps in the kernel tree so we can keep them alive. Then when people enhance or fix the feature, I can ask them to update the test app too. The infrastruture is terribly trivial at present - let's see how it evolves. - checkpoint/restart feature work. A note on this: this is a project by various mad Russians to perform c/r mainly from userspace, with various oddball helper code added into the kernel where the need is demonstrated. So rather than some large central lump of code, what we have is little bits and pieces popping up in various places which either expose something new or which permit something which is normally kernel-private to be modified. The overall project is an ongoing thing. I've judged that the size and scope of the thing means that we're more likely to be successful with it if we integrate the support into mainline piecemeal rather than allowing it all to develop out-of-tree. However I'm less confident than the developers that it will all eventually work! So what I'm asking them to do is to wrap each piece of new code inside CONFIG_CHECKPOINT_RESTORE. So if it all eventually comes to tears and the project as a whole fails, it should be a simple matter to go through and delete all trace of it. This lot pretty much wraps up the -rc1 merge for me. * akpm: (96 commits) unlzo: fix input buffer free ramoops: update parameters only after successful init ramoops: fix use of rounddown_pow_of_two() c/r: prctl: add PR_SET_MM codes to set up mm_struct entries c/r: procfs: add start_data, end_data, start_brk members to /proc/$pid/stat v4 c/r: introduce CHECKPOINT_RESTORE symbol selftests: new x86 breakpoints selftest selftests: new very basic kernel selftests directory radix_tree: take radix_tree_path off stack radix_tree: remove radix_tree_indirect_to_ptr() dio: optimize cache misses in the submission path vfs: cache request_queue in struct block_device fs/direct-io.c: calculate fs_count correctly in get_more_blocks() drivers/parport/parport_pc.c: fix warnings panic: don't print redundant backtraces on oops sysctl: add the kernel.ns_last_pid control kdump: add udev events for memory online/offline include/linux/crash_dump.h needs elf.h kdump: fix crash_kexec()/smp_send_stop() race in panic() kdump: crashk_res init check for /sys/kernel/kexec_crash_size ...
2012-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (69 commits) pptp: Accept packet with seq zero RDS: Remove some unused iWARP code net: fsl: fec: handle 10Mbps speed in RMII mode drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c: add missing iounmap drivers/net/ethernet/tundra/tsi108_eth.c: add missing iounmap ksz884x: fix mtu for VLAN net_sched: sfq: add optional RED on top of SFQ dp83640: Fix NOHZ local_softirq_pending 08 warning gianfar: Fix invalid TX frames returned on error queue when time stamping gianfar: Fix missing sock reference when processing TX time stamps phylib: introduce mdiobus_alloc_size() net: decrement memcg jump label when limit, not usage, is changed net: reintroduce missing rcu_assign_pointer() calls inet_diag: Rename inet_diag_req_compat into inet_diag_req inet_diag: Rename inet_diag_req into inet_diag_req_v2 bond_alb: don't disable softirq under bond_alb_xmit mac80211: fix rx->key NULL pointer dereference in promiscuous mode nl80211: fix old station flags compatibility mdio-octeon: use an unique MDIO bus name. mdio-gpio: use an unique MDIO bus name. ...
2012-01-12c/r: prctl: add PR_SET_MM codes to set up mm_struct entriesCyrill Gorcunov
When we restore a task we need to set up text, data and data heap sizes from userspace to the values a task had at checkpoint time. This patch adds auxilary prctl codes for that. While most of them have a statistical nature (their values are involved into calculation of /proc/<pid>/statm output) the start_brk and brk values are used to compute an allowed size of program data segment expansion. Which means an arbitrary changes of this values might be dangerous operation. So to restrict access the following requirements applied to prctl calls: - The process has to have CAP_SYS_ADMIN capability granted. - For all opcodes except start_brk/brk members an appropriate VMA area must exist and should fit certain VMA flags, such as: - code segment must be executable but not writable; - data segment must not be executable. start_brk/brk values must not intersect with data segment and must not exceed RLIMIT_DATA resource limit. Still the main guard is CAP_SYS_ADMIN capability check. Note the kernel should be compiled with CONFIG_CHECKPOINT_RESTORE support otherwise these prctl calls will return -EINVAL. [akpm@linux-foundation.org: cache current->mm in a local, saving 200 bytes text] Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Vagin <avagin@openvz.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12radix_tree: remove radix_tree_indirect_to_ptr()Xiao Guangrong
It is not used anymore, remove it Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12vfs: cache request_queue in struct block_deviceAndi Kleen
This makes it possible to get from the inode to the request_queue with one less cache miss. Used in followon optimization. The livetime of the pointer is the same as the gendisk. This assumes that the queue will always stay the same in the gendisk while it's visible to block_devices. I think that's safe correct? Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12include/linux/crash_dump.h needs elf.hFabio Estevam
Building an ARM target we get the following warnings: CC arch/arm/kernel/setup.o In file included from arch/arm/kernel/setup.c:39: arch/arm/include/asm/elf.h:102:1: warning: "vmcore_elf64_check_arch" redefined In file included from arch/arm/kernel/setup.c:24: include/linux/crash_dump.h:30:1: warning: this is the location of the previous definition Quoting Russell King: "linux/crash_dump.h makes no attempt to include asm/elf.h, but it depends on stuff in asm/elf.h to determine how stuff inside this file is defined at parse time. So, if asm/elf.h is included after linux/crash_dump.h or not at all, you get a different result from the situation where asm/elf.h is included before." So add elf.h header to crash_dump.h to avoid this problem. The original discussion about this can be found at: http://www.spinics.net/lists/arm-kernel/msg154113.html Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <stable@vger.kernel.org> [3.2.1] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12kexec: remove KMSG_DUMP_KEXECWANG Cong
KMSG_DUMP_KEXEC is useless because we already save kernel messages inside /proc/vmcore, and it is unsafe to allow modules to do other stuffs in a crash dump scenario. [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Reported-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jarod Wilson <jarod@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: remove del_page_from_lru, add page_off_lruHugh Dickins
del_page_from_lru() repeats del_page_from_lru_list(), also working out which LRU the page was on, clearing the relevant bits. Decouple those functions: remove del_page_from_lru() and add page_off_lru(). Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: enum lru_list lruHugh Dickins
Mostly we use "enum lru_list lru": change those few "l"s to "lru"s. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: fewer underscores in ____pagevec_lru_addHugh Dickins
What's so special about ____pagevec_lru_add() that it needs four leading underscores? Nothing, it just helped to distinguish from __pagevec_lru_add() in 2.6.28 development. Cut two leading underscores. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: take pagevecs off reclaim stackHugh Dickins
Replace pagevecs in putback_lru_pages() and move_active_pages_to_lru() by lists of pages_to_free: then apply Konstantin Khlebnikov's free_hot_cold_page_list() to them instead of pagevec_release(). Which simplifies the flow (no need to drop and retake lock whenever pagevec fills up) and reduces stale addresses in stack backtraces (which often showed through the pagevecs); but more importantly, removes another 120 bytes from the deepest stacks in page reclaim. Although I've not recently seen an actual stack overflow here with a vanilla kernel, move_active_pages_to_lru() has often featured in deep backtraces. However, free_hot_cold_page_list() does not handle compound pages (nor need it: a Transparent HugePage would have been split by the time it reaches the call in shrink_page_list()), but it is possible for putback_lru_pages() or move_active_pages_to_lru() to be left holding the last reference on a THP, so must exclude the unlikely compound case before putting on pages_to_free. Remove pagevec_strip(), its work now done in move_active_pages_to_lru(). The pagevec in scan_mapping_unevictable_pages() remains in mm/vmscan.c, but that is never on the reclaim path, and cannot be replaced by a list. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: compaction: introduce sync-light migration for use by compactionMel Gorman
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT mode that avoids writing back pages to backing storage. Async compaction maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT. For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is used. This avoids sync compaction stalling for an excessive length of time, particularly when copying files to a USB stick where there might be a large number of dirty pages backed by a filesystem that does not support ->writepages. [aarcange@redhat.com: This patch is heavily based on Andrea's work] [akpm@linux-foundation.org: fix fs/nfs/write.c build] [akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: compaction: make isolate_lru_page() filter-aware againMel Gorman
Commit 39deaf85 ("mm: compaction: make isolate_lru_page() filter-aware") noted that compaction does not migrate dirty or writeback pages and that is was meaningless to pick the page and re-add it to the LRU list. This had to be partially reverted because some dirty pages can be migrated by compaction without blocking. This patch updates "mm: compaction: make isolate_lru_page" by skipping over pages that migration has no possibility of migrating to minimise LRU disruption. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel<riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: compaction: determine if dirty pages can be migrated without blocking ↵Mel Gorman
within ->migratepage Asynchronous compaction is used when allocating transparent hugepages to avoid blocking for long periods of time. Due to reports of stalling, there was a debate on disabling synchronous compaction but this severely impacted allocation success rates. Part of the reason was that many dirty pages are skipped in asynchronous compaction by the following check; if (PageDirty(page) && !sync && mapping->a_ops->migratepage != migrate_page) rc = -EBUSY; This skips over all mapping aops using buffer_migrate_page() even though it is possible to migrate some of these pages without blocking. This patch updates the ->migratepage callback with a "sync" parameter. It is the responsibility of the callback to fail gracefully if migration would block. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12vmscan/trace: Add 'file' info to trace_mm_vmscan_lru_isolate()Tao Ma
In trace_mm_vmscan_lru_isolate(), we don't output 'file' information to the trace event and it is a bit inconvenient for the user to get the real information(like pasted below). mm_vmscan_lru_isolate: isolate_mode=2 order=0 nr_requested=32 nr_scanned=32 nr_taken=32 contig_taken=0 contig_dirty=0 contig_failed=0 'active' can be obtained by analyzing mode(Thanks go to Minchan and Mel), So this patch adds 'file' to the trace event and it now looks like: mm_vmscan_lru_isolate: isolate_mode=2 order=0 nr_requested=32 nr_scanned=32 nr_taken=32 contig_taken=0 contig_dirty=0 contig_failed=0 file=0 Signed-off-by: Tao Ma <boyu.mt@taobao.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12thp: add tlb_remove_pmd_tlb_entryShaohua Li
We have tlb_remove_tlb_entry to indicate a pte tlb flush entry should be flushed, but not a corresponding API for pmd entry. This isn't a problem so far because THP is only for x86 currently and tlb_flush() under x86 will flush entire TLB. But this is confusion and could be missed if thp is ported to other arch. Also convert tlb->need_flush = 1 to a VM_BUG_ON(!tlb->need_flush) in __tlb_remove_page() as suggested by Andrea Arcangeli. The __tlb_remove_page() function is supposed to be called after tlb_remove_xxx_tlb_entry() and we can catch any misuse. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12memcg: simplify LRU handling by new ruleKAMEZAWA Hiroyuki
Now, at LRU handling, memory cgroup needs to do complicated works to see valid pc->mem_cgroup, which may be overwritten. This patch is for relaxing the protocol. This patch guarantees - when pc->mem_cgroup is overwritten, page must not be on LRU. By this, LRU routine can believe pc->mem_cgroup and don't need to check bits on pc->flags. This new rule may adds small overheads to swapin. But in most case, lru handling gets faster. After this patch, PCG_ACCT_LRU bit is obsolete and removed. [akpm@linux-foundation.org: remove unneeded VM_BUG_ON(), restore hannes's christmas tree] [akpm@linux-foundation.org: clean up code comment] [hughd@google.com: fix NULL mem_cgroup_try_charge] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Ying Han <yinghan@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12memcg: clear pc->mem_cgroup if necessary.KAMEZAWA Hiroyuki
This is a preparation before removing a flag PCG_ACCT_LRU in page_cgroup and reducing atomic ops/complexity in memcg LRU handling. In some cases, pages are added to lru before charge to memcg and pages are not classfied to memory cgroup at lru addtion. Now, the lru where the page should be added is determined a bit in page_cgroup->flags and pc->mem_cgroup. I'd like to remove the check of flag. To handle the case pc->mem_cgroup may contain stale pointers if pages are added to LRU before classification. This patch resets pc->mem_cgroup to root_mem_cgroup before lru additions. [akpm@linux-foundation.org: fix CONFIG_CGROUP_MEM_CONT=n build] [hughd@google.com: fix CONFIG_CGROUP_MEM_RES_CTLR=y CONFIG_CGROUP_MEM_RES_CTLR_SWAP=n build] [akpm@linux-foundation.org: ksm.c needs memcontrol.h, per Michal] [hughd@google.com: stop oops in mem_cgroup_reset_owner()] [hughd@google.com: fix page migration to reset_owner] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Ying Han <yinghan@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12page_cgroup: add helper function to get swap_cgroupBob Liu
There are multiple places which need to get the swap_cgroup address, so add a helper function: static struct swap_cgroup *swap_cgroup_getsc(swp_entry_t ent, struct swap_cgroup_ctrl **ctrl); to simplify the code. Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: unify remaining mem_cont, mem, etc. variable names to memcgJohannes Weiner
Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12memcg: make mem_cgroup_split_huge_fixup() more efficientKAMEZAWA Hiroyuki
In split_huge_page(), mem_cgroup_split_huge_fixup() is called to handle page_cgroup modifcations. It takes move_lock_page_cgroup() and modifies page_cgroup and LRU accounting jobs and called HPAGE_PMD_SIZE - 1 times. But thinking again, - compound_lock() is held at move_accout...then, it's not necessary to take move_lock_page_cgroup(). - LRU is locked and all tail pages will go into the same LRU as head is now on. - page_cgroup is contiguous in huge page range. This patch fixes mem_cgroup_split_huge_fixup() as to be called once per hugepage and reduce costs for spliting. [akpm@linux-foundation.org: fix typo, per Michal] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: memcg: remove unused node/section info from pc->flagsJohannes Weiner
To find the page corresponding to a certain page_cgroup, the pc->flags encoded the node or section ID with the base array to compare the pc pointer to. Now that the per-memory cgroup LRU lists link page descriptors directly, there is no longer any code that knows the struct page_cgroup of a PFN but not the struct page. [hughd@google.com: remove unused node/section info from pc->flags fix] Signed-off-by: Johannes Weiner <jweiner@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: make per-memcg LRU lists exclusiveJohannes Weiner
Now that all code that operated on global per-zone LRU lists is converted to operate on per-memory cgroup LRU lists instead, there is no reason to keep the double-LRU scheme around any longer. The pc->lru member is removed and page->lru is linked directly to the per-memory cgroup LRU lists, which removes two pointers from a descriptor that exists for every page frame in the system. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Ying Han <yinghan@google.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: collect LRU list heads into struct lruvecJohannes Weiner
Having a unified structure with a LRU list set for both global zones and per-memcg zones allows to keep that code simple which deals with LRU lists and does not care about the container itself. Once the per-memcg LRU lists directly link struct pages, the isolation function and all other list manipulations are shared between the memcg case and the global LRU case. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: move memcg hierarchy reclaim to generic reclaim codeJohannes Weiner
Memory cgroup limit reclaim and traditional global pressure reclaim will soon share the same code to reclaim from a hierarchical tree of memory cgroups. In preparation of this, move the two right next to each other in shrink_zone(). The mem_cgroup_hierarchical_reclaim() polymath is split into a soft limit reclaim function, which still does hierarchy walking on its own, and a limit (shrinking) reclaim function, which relies on generic reclaim code to walk the hierarchy. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12memcg: add mem_cgroup_replace_page_cache() to fix LRU issueKAMEZAWA Hiroyuki
Commit ef6a3c6311 ("mm: add replace_page_cache_page() function") added a function replace_page_cache_page(). This function replaces a page in the radix-tree with a new page. WHen doing this, memory cgroup needs to fix up the accounting information. memcg need to check PCG_USED bit etc. In some(many?) cases, 'newpage' is on LRU before calling replace_page_cache(). So, memcg's LRU accounting information should be fixed, too. This patch adds mem_cgroup_replace_page_cache() and removes the old hooks. In that function, old pages will be unaccounted without touching res_counter and new page will be accounted to the memcg (of old page). WHen overwriting pc->mem_cgroup of newpage, take zone->lru_lock and avoid races with LRU handling. Background: replace_page_cache_page() is called by FUSE code in its splice() handling. Here, 'newpage' is replacing oldpage but this newpage is not a newly allocated page and may be on LRU. LRU mis-accounting will be critical for memory cgroup because rmdir() checks the whole LRU is empty and there is no account leak. If a page is on the other LRU than it should be, rmdir() will fail. This bug was added in March 2011, but no bug report yet. I guess there are not many people who use memcg and FUSE at the same time with upstream kernels. The result of this bug is that admin cannot destroy a memcg because of account leak. So, no panic, no deadlock. And, even if an active cgroup exist, umount can succseed. So no problem at shutdown. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12epoll: limit pathsJason Baron
The current epoll code can be tickled to run basically indefinitely in both loop detection path check (on ep_insert()), and in the wakeup paths. The programs that tickle this behavior set up deeply linked networks of epoll file descriptors that cause the epoll algorithms to traverse them indefinitely. A couple of these sample programs have been previously posted in this thread: https://lkml.org/lkml/2011/2/25/297. To fix the loop detection path check algorithms, I simply keep track of the epoll nodes that have been already visited. Thus, the loop detection becomes proportional to the number of epoll file descriptor and links. This dramatically decreases the run-time of the loop check algorithm. In one diabolical case I tried it reduced the run-time from 15 mintues (all in kernel time) to .3 seconds. Fixing the wakeup paths could be done at wakeup time in a similar manner by keeping track of nodes that have already been visited, but the complexity is harder, since there can be multiple wakeups on different cpus...Thus, I've opted to limit the number of possible wakeup paths when the paths are created. This is accomplished, by noting that the end file descriptor points that are found during the loop detection pass (from the newly added link), are actually the sources for wakeup events. I keep a list of these file descriptors and limit the number and length of these paths that emanate from these 'source file descriptors'. In the current implemetation I allow 1000 paths of length 1, 500 of length 2, 100 of length 3, 50 of length 4 and 10 of length 5. Note that it is sufficient to check the 'source file descriptors' reachable from the newly added link, since no other 'source file descriptors' will have newly added links. This allows us to check only the wakeup paths that may have gotten too long, and not re-check all possible wakeup paths on the system. In terms of the path limit selection, I think its first worth noting that the most common case for epoll, is probably the model where you have 1 epoll file descriptor that is monitoring n number of 'source file descriptors'. In this case, each 'source file descriptor' has a 1 path of length 1. Thus, I believe that the limits I'm proposing are quite reasonable and in fact may be too generous. Thus, I'm hoping that the proposed limits will not prevent any workloads that currently work to fail. In terms of locking, I have extended the use of the 'epmutex' to all epoll_ctl add and remove operations. Currently its only used in a subset of the add paths. I need to hold the epmutex, so that we can correctly traverse a coherent graph, to check the number of paths. I believe that this additional locking is probably ok, since its in the setup/teardown paths, and doesn't affect the running paths, but it certainly is going to add some extra overhead. Also, worth noting is that the epmuex was recently added to the ep_ctl add operations in the initial path loop detection code using the argument that it was not on a critical path. Another thing to note here, is the length of epoll chains that is allowed. Currently, eventpoll.c defines: /* Maximum number of nesting allowed inside epoll sets */ #define EP_MAX_NESTS 4 This basically means that I am limited to a graph depth of 5 (EP_MAX_NESTS + 1). However, this limit is currently only enforced during the loop check detection code, and only when the epoll file descriptors are added in a certain order. Thus, this limit is currently easily bypassed. The newly added check for wakeup paths, stricly limits the wakeup paths to a length of 5, regardless of the order in which ep's are linked together. Thus, a side-effect of the new code is a more consistent enforcement of the graph depth. Thus far, I've tested this, using the sample programs previously mentioned, which now either return quickly or return -EINVAL. I've also testing using the piptest.c epoll tester, which showed no difference in performance. I've also created a number of different epoll networks and tested that they behave as expectded. I believe this solves the original diabolical test cases, while still preserving the sane epoll nesting. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Nelson Elhage <nelhage@ksplice.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm,slub,x86: decouple size of struct page from CONFIG_CMPXCHG_LOCALHeiko Carstens
While implementing cmpxchg_double() on s390 I realized that we don't set CONFIG_CMPXCHG_LOCAL despite the fact that we have support for it. However setting that option will increase the size of struct page by eight bytes on 64 bit, which we certainly do not want. Also, it doesn't make sense that a present cpu feature should increase the size of struct page. Besides that it looks like the dependency to CMPXCHG_LOCAL is wrong and that it should depend on CMPXCHG_DOUBLE instead. This patch: If an architecture supports CMPXCHG_LOCAL this shouldn't result automatically in larger struct pages if the SLUB allocator is used. Instead introduce a new config option "HAVE_ALIGNED_STRUCT_PAGE" which can be selected if a double word aligned struct page is required. Also update x86 Kconfig so that it should work as before. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12include/linux/linkage.h: remove unused ATTRIB_NORET macroJoe Perches
The uses have been renamed so delete the unused macro. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12treewide: convert uses of ATTRIB_NORETURN to __noreturnJoe Perches
Use the more commonly used __noreturn instead of ATTRIB_NORETURN. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12treewide: remove useless NORET_TYPE macro and usesJoe Perches
It's a very old and now unused prototype marking so just delete it. Neaten panic pointer argument style to keep checkpatch quiet. Signed-off-by: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12include/linux/linkage.h: remove unused NORET_AND macroJoe Perches
The only use in kernel.h is gone so remove the macro. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12kernel.h: neaten panic prototypeJoe Perches
Use __printf macro. Convert NORET_AND to ATTRIB_NORET. Use the normal kernel style for pointer arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12net_sched: sfq: add optional RED on top of SFQEric Dumazet
Adds an optional Random Early Detection on each SFQ flow queue. Traditional SFQ limits count of packets, while RED permits to also control number of bytes per flow, and adds ECN capability as well. 1) We dont handle the idle time management in this RED implementation, since each 'new flow' begins with a null qavg. We really want to address backlogged flows. 2) if headdrop is selected, we try to ecn mark first packet instead of currently enqueued packet. This gives faster feedback for tcp flows compared to traditional RED [ marking the last packet in queue ] Example of use : tc qdisc add dev $DEV parent 1:1 handle 10: est 1sec 4sec sfq \ limit 3000 headdrop flows 512 divisor 16384 \ redflowlimit 100000 min 8000 max 60000 probability 0.20 ecn qdisc sfq 10: parent 1:1 limit 3000p quantum 1514b depth 127 headdrop flows 512/16384 divisor 16384 ewma 6 min 8000b max 60000b probability 0.2 ecn prob_mark 0 prob_mark_head 4876 prob_drop 6131 forced_mark 0 forced_mark_head 0 forced_drop 0 Sent 1175211782 bytes 777537 pkt (dropped 6131, overlimits 11007 requeues 0) rate 99483Kbit 8219pps backlog 689392b 456p requeues 0 In this test, with 64 netperf TCP_STREAM sessions, 50% using ECN enabled flows, we can see number of packets CE marked is smaller than number of drops (for non ECN flows) If same test is run, without RED, we can check backlog is much bigger. qdisc sfq 10: parent 1:1 limit 3000p quantum 1514b depth 127 headdrop flows 512/16384 divisor 16384 Sent 1148683617 bytes 795006 pkt (dropped 0, overlimits 0 requeues 0) rate 98429Kbit 8521pps backlog 1221290b 841p requeues 0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Dave Taht <dave.taht@gmail.com> Tested-by: Dave Taht <dave.taht@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-12phylib: introduce mdiobus_alloc_size()Timur Tabi
Introduce function mdiobus_alloc_size() as an alternative to mdiobus_alloc(). Most callers of mdiobus_alloc() also allocate a private data structure, and then manually point bus->priv to this object. mdiobus_alloc_size() combines the two operations into one, which simplifies memory management. The original mdiobus_alloc() now just calls mdiobus_alloc_size(0). Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-13module_param: check that bool parameters really are bool.Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. This tightens the check (you'll get a warning about incompatible return type) but still allows it. Next kernel version, we'll remove it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
