For check battery capacity, read Battery ID from ADC.
User can check with below adb commend.
"cat /sys/class/i2c-dev/i2c-0/device/0-0036/battery_capacity"
Bug 1368059
Change-Id: I49ba1216244b85258fa3ef1ec8f60fd27a81e26b
Signed-off-by: Hyongbin Kim <hyongbink@nvidia.com>
Reviewed-on: http://git-master/r/299269
Reviewed-by: Gabby Lee <galee@nvidia.com>
Tested-by: Gabby Lee <galee@nvidia.com>
Description:
version 1.4.3 TegraTab bringup v29 DVT3+;
Improvement:
Noise performance is also improved in this version.
Bug 1353325
Bug 1367501
Change-Id: I50a08845d4232e2d462c25bf0f7ae91eb166a141
Signed-off-by: Xiaohui Tao <xtao@nvidia.com>
Reviewed-on: http://git-master/r/280094
GVS: Gerrit_Virtual_Submit
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Description:
version 1.2.0 TegraTab bringup v25 DVT3+;
Changes:
* Eraser starts as being reported as pen and then switches to eraser without an intervening lift of the pen.
* Touch panel not responsive after standby resume
* Stylus events on virtual keyboard are missing with v24 build.
Bug 1357895
Bug 1353325
Bug 1360030
Change-Id: I4c01e13165074f5c0cbd5a71cf961956a66c07b1
Signed-off-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/271801
Added EMC frequency min/max as PM QoS parameters.
Bug 1346293
Change-Id: Ib9eb6977edd56420d8518231d06749b2fbf5c34c
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/263783
When low SOC, limit freq of cpu, gpu, emc by sysedp_lite.
Bug 1316595
Change-Id: I112efb815d3c57731d7478bb2ab0589c10f72865
Reviewed-on: http://git-master/r/264167
When SOC is low, we need to limit clk of cpu, gpu, emc.
For simple use, set power directly and set edp limit.
Just use cpupri table.
Bug 1316595
Change-Id: I3f2644f8564735551be6e61248e916b2981e70ef
Reviewed-on: http://git-master/r/264166
Support current threshold table for prevent sudden power off
or freeze under low SOC.
Bug 1304204
Bug 1316595
Change-Id: I4374c27a781a96d3f5b6a3f59af2ce3dcd55bbf3
Reviewed-on: http://git-master/r/249079
At low SOC, we need to limit current for system stability.
When set low value to current threshold, should set minimum cpu number
to avoid power down of current monitor.
Bug 1304204
Bug 1316595
Change-Id: I52219755a62acbb5289a6d28237b5ac57fa1a54a
Reviewed-on: http://git-master/r/249078
Tegra Profiler misc driver:
allocate memory on demand from the user space, not on boot
Bug 1312406
Change-Id: Ic50e4e29a6066cee49c60cb435ab8f46c4748cbc
Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Reviewed-on: http://git-master/r/258202
Reviewed-by: Daniel Horowitz <dhorowitz@nvidia.com>
Tested-by: Daniel Horowitz <dhorowitz@nvidia.com>
Add Tegra Profiler kernel misc driver
Bug 1312406
Change-Id: Ie5715bd0029a4d06fb20fa4ad8724827411a6c3b
Reviewed-on: http://git-master/r/250840
Add sysfs for set charging complete SOC in user space.
When soc value is not 100%, just check soc and cut charger power
when charging is done.
Set value should be between 60 and 100.
Make foraml way to use SOC check charging done.
Bug 1342684
Change-Id: Ia45a585e4709d0d109788018e38d24ffa1e42c09
Reviewed-on: http://git-master/r/261486
Changes:
- Water Rejection: Multiple Stylus cursors are getting
displayed when the water drops are there in screen
- Water Rejection: Touch screen is not responding to
stylus or manual touch in water droplet area
Bug 1301942
Bug 1302147
Change-Id: If5b403995ca2eeef0106b61553616fc0455351ff
Reviewed-on: http://git-master/r/261949
Changes:
- Fixed: Will respawn touch_fusion daemon in the event it crashes
(bug 1316502/1339998).
- Fixed: Touch linearity issues fixed (Bug 1326822).
- Improved: Linearity on edges (Bug 1333700).
Bug 1316502
Bug 1326822
Bug 1333700
Bug 1339998
Change-Id: I731da02b5912723b41da553eca19400885e10976
Reviewed-on: http://git-master/r/260856
Reviewed-by: Bo Kim <bok@nvidia.com>
Tested-by: Bo Kim <bok@nvidia.com>
NVCS can't set the full range because the ad5823 driver is
clipping position value as working range.
This is separated physical and working range
Bug 1340766
Change-Id: I61f4dbdc8572fd6b1725a9e0803656b9d0bc1ec4
Signed-off-by: Karl Kim <kkim@nvidia.com>
Reviewed-on: http://git-master/r/259886
Reviewed-by: Jake Park <jakep@nvidia.com>
Reviewed-by: Peter Kim <pekim@nvidia.com>
enable irq_wake for uart interrupt if wakeup from lp0
is required.
ex) BT host-wake pin is connected to uart3_cts.
so, making uart interrupt as wake irq.
bug 1328470
Change-Id: I11f7ea8a627a84972c5d734d256a253cad2bc0af
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/257237
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Fuel gauge need to compensate the RCOMP value according to Battery temperature
chaging. For best performance, reduce period to 10sec and apply new RCOMP
when temperature is changed over 1.5C.
Bug 1304204
Bug 1317331
Change-Id: I4e74d1e39d68297c5df9fccad0cb2879b7663e34
Reviewed-on: http://git-master/r/258671
- reduce suspend time for compass and pressure
- fix MPU possible interrupt storm
- fix MPU sample frequency overrun
- fix MPU 9250 support for sw_rev > 2 HW
- add BMP280 support to BMP180 pressure driver
- optimize MPU FIFO timestamp algorithm
- add compass self-test
- add data interface
Bug 1313284
Bug 1311053
Bug 1295128
Bug 1256470
Bug 1236893
Change-Id: I4ffa906c07ed1d07ad3b89aea9eb83fb153b765d
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/246132
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Tested-by: Robert Collins <rcollins@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
(cherry picked from commit 8cdf5b9ccfb47477229bf2cbb37f5132e81ad39e)
Signed-off-by: David Yu <davyu@nvidia.com>
Reviewed-on: http://git-master/r/258517
Changes:
- Fixes bug 1322007 We are seeing a halo of no touch/pen activity
around a thumb on the screen.
- Fixes bug 1327520 Touch strokes are missing at intermittent
soft keys on virtual keyboard soft key press.
- Improves bug 1327474 Drawing with finger suddenly starts to
act as eraser if user changes the finger while drawing.
- Improves bug 1296212 Erasing angle is not consistent using
stylus, sometimes draws during erase.
Bug 1322007
Bug 1327520
Bug 1327474
Bug 1296212
Change-Id: Ic5c909e9d3aa18e8dc5a3fb8fec06ab8ffedc7d6
Reviewed-on: http://git-master/r/258244
This reverts commit 1d3379677dc7c4c9f3304b5ac5c1d97463fe5c45
Change-Id: I2dadbc5dee06a92073ee7fdcfb5ba5d2f037aa6f
Reviewed-on: http://git-master/r/256610
into /proc/net/{tcp udp tcp6 udp6} files.
Get process's cmdline from a sock's corresponding inode pointer,
so that cmdline can't be used by Android active-standby app
to find the corresponding package name.
Bug 1185001
Change-Id: Idc8651e4bb85b8a152dfade9689a719f7d72687d
Signed-off-by: Chun Xu <chunx@nvidia.com>
Reviewed-on: http://git-master/r/253458
Tested-by: Jiukai Ma <jiukaim@nvidia.com>
This reverts commit 4b00bd31b95da2af9aa750e165239a4ab288f696
Change-Id: I1d3379677dc7c4c9f3304b5ac5c1d97463fe5c45
Reviewed-on: http://git-master/r/254837
Added getting exposure time API into ov7695 yuv sensor driver
Bug 1330342
Change-Id: Icbcacdce5c19515d0f6f6b35f5fc81fa4462f9a4
Signed-off-by: Alvin Park <apark@nvidia.com>
Reviewed-on: http://git-master/r/253247
Reviewed-by: Karl Kim <kkim@nvidia.com>
Description:
- Finger separation
- Input device split option
- V15 sensitivity degrade fix
- Handling of unexpected TSC reset
- Marginal improvements in stylus and finger recognition
- Add robustness to Netlink backlog handling
Bug 1321258
Bug 1324688
Bug 1302894
Bug 1324917
Bug 1327474
Bug 1324291
Change-Id: I3e9a16cc15351c48f0c21cc2cc2065e846237daa
Signed-off-by: Bo Kim <bok@nvidia.com>
Reviewed-on: http://git-master/r/252842
Reviewed-by: David Jung <djung@nvidia.com>
Tested-by: David Jung <djung@nvidia.com>
Add device tree support for pwm based backlight driver.
Values for platform data required by pwm backlight driver
are parsed from device tree properties, directly.
For function pointers in platform data, separate devdata
generating driver is prepared. In order to construct functions,
it also parses values from different device tree node.
Backlight output array to make linear backlight response are
parsed in separate devdata generating driver.
Bug 1240921
Change-Id: Ie2b20efa368a0caa3a8a4d316482a2153cdaadc1
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/251313
Description:
Reduce number of SPI interrupts while touch is present. Reduces
from 5000 interrupts per second to 800-1200 interrupts per
second when a touch is present.
Bug 1308711
Change-Id: I1d88a062d0538526fa24374c5d38d52813857a33
Reviewed-on: http://git-master/r/250534
Description:
Fixes bug 1301375 LP0 suspend/resume issues.
Fixes bug 1293278 by adding more manufacturing tests.
Fixes bug 1318848. Adds CPUBoost flag.
Bug 1293278
Bug 1301375
Bug 1318848
Change-Id: I78ca8f6119aa948d7d9a57a912bc9946fccba0c6
Reviewed-on: http://git-master/r/249532
When charging current is below 256mA, stop charging for preventing
over charge and safety of battery.
Change-Id: Ib6bd3f8a4951364e2653b77f7eb0f2eedadda1e8
Reviewed-on: http://git-master/r/249536
Add get current function for check charging complete.
Change-Id: Ic19cd05699855237d5b6493c8370ac8e93e17d22
Reviewed-on: http://git-master/r/249535
Set ICHG=4.1A and ISET=1 for charging 0.2C at T1~T2.
Set VSET=4.2V for 4.2V charging at T3~T5.
Bug 1324720
Change-Id: I17d144658706140bee1298edfa9792b2eb0f5605
Reviewed-on: http://git-master/r/248303
Enable wl12xx edp support config and add edp support
structures to wl12xx_platform_data.
bug 1299023
Change-Id: Icbb63229eee521f61801beaee77d86295e1e5cc9
Reviewed-on: http://git-master/r/236169
(cherry picked from commit 6436202553991f42ca27c63e2a6571f7144dabc7)
Reviewed-on: http://git-master/r/249086
Backlight EDP throttling could be selectable by platform data.
Bug 1316595
Bug 1318582
Bug 1319905
Bug 1310789
Change-Id: Idcf0893ac7554d4a525028703592b2e4954c30d2
Reviewed-on: http://git-master/r/246997
Reviewed-by: Hyong Bin Kim <hyongbink@nvidia.com>
Pull out EN_HIZ clear fuction from bq2419x_reset_wdt().
It clear EN_HIZ every 40 sec. When cut_pwr_chg_complete flag set,
Forced set EN_HIZ when charging complete.
Bug 1316646
Change-Id: I8d169fcef5f62d01a29b543a607e03a2f59622d9
Reviewed-on: http://git-master/r/245235
Change-Id: Ica93560f8eba67d5ba9975c42e0c7431f1b10ce8
Reviewed-on: http://git-master/r/244945
Various drivers end up replicating the code to mmap() their memory
buffers into user space, and our core memory remapping function may be
very flexible but it is unnecessarily complicated for the common cases
to use.
Our internal VM uses pfn's ("page frame numbers") which simplifies
things for the VM, and allows us to pass physical addresses around in a
denser and more efficient format than passing a "phys_addr_t" around,
and having to shift it up and down by the page size. But it just means
that drivers end up doing that shifting instead at the interface level.
It also means that drivers end up mucking around with internal VM things
like the vma details (vm_pgoff, vm_start/end) way more than they really
need to.
So this just exports a function to map a certain physical memory range
into user space (using a phys_addr_t based interface that is much more
natural for a driver) and hides all the complexity from the driver.
Some drivers will still end up tweaking the vm_page_prot details for
things like prefetching or cacheability etc, but that's actually
relevant to the driver, rather than caring about what the page offset of
the mapping is into the particular IO memory region.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
(cherry picked from commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e in upstream v3.9)
Change-Id: I203f48975ccd9047a588669d13173385b906ab5b
Bug 1316563
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/244439
(cherry picked from commit f1f51c1f1823e4b5254db2b80d08302df95af11e)
Change-Id: Ibf65b97e4ff4956a2e6ecb33b7926ec283648c16
Reviewed-on: http://git-master/r/245000
vde.emc is required to know whether video playback is
going on or not. Display efficiency rate is set to 45%
if both dc.emc and vde.emc is enabled.
vde.emc clock is enabled when non-zero avp.emc clock
rate is requested and is disabled when zero avp.emc clock
is requested.
Bug 1266369
Change-Id: Ic1de7145763a41a8adf11a9e1cd7a1cd723f46e2
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/232614
(cherry picked from commit 1a7d3d91d7491813b8b335f202504152ab137193)
Signed-off-by: Kenneth Kwak <kkwak@nvidia.com>
Change-Id: I491c6356800309123b9cb3ece9fb32d4dfe00d78
Reviewed-on: http://git-master/r/242227
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
voltage
When SOC 100% and disable charging, we should restart charging
when voltage is droped under some voltage. if not, it make large gap
between real SOC and current SOC(100%).
If there is no vcell_check fuction, just check soc value.
Bug 1310558
Change-Id: I23431e53678607e7c963338a85e7cdb23deba79b
Reviewed-on: http://git-master/r/243893
Chager driver need vcell value for better checking charing complete.
Bug 1310558
Change-Id: I9c19f3500e7a85478dc761668d58a5b3b1bafe5f
Reviewed-on: http://git-master/r/243892
Bug 1244384
Change-Id: Ia44451cd79a5f551f479685d4089e2398a5fc152
Reviewed-on: http://git-master/r/242293
Bug 1244384
Change-Id: Ifb5c71e26c3d2a78c38beeaf20b48b38e6e3cb3c
Reviewed-on: http://git-master/r/242292
Tegratab system can draw over charger power (5V*2A), unexpect
charging termination happen under 99% SOC.(around 93%~98%).
BQ charger occur charging termination when Vbatt is above
recharge threshold voltage(4208mA - 100mV = 4108mA) and
current is below ITERM(256mA).
So we need to disable charging termination and control charger
enable/disable with check SOC.
When SOC over 100%, disable charging and under 99% SOC, enable charger.
Bug 1310558
Bug 1316010
Change-Id: Ic3463f004171f580661595d6cd1ad2b94eb538bf
Reviewed-on: http://git-master/r/243270
Remove forced set 100% SOC code when charging done.
Sometimes, charging termination is done under 98% SOC,
when tegratab spend whole power of charger and charging current
drop under ITERM.
Charger driver will check SOC and control charging.
Bug 1310558
Bug 1316010
Change-Id: I127665fc4c1fa68584080b879f2184687c6e692b
Reviewed-on: http://git-master/r/243269
Add trace point in IRQ handler for profiling.
Bug 1313953
Change-Id: I832efacf17603ae85cd03b455c8d17828fbeeec5
Signed-off-by: Yogish Kulkarni <yogishk@nvidia.com>
Reviewed-on: http://git-master/r/242431
Added ADC reading with dual-current source for Channel3 in order to do series
resistance cancellation for thermal diode.
Bug 1287901
Change-Id: Ifaf6ae6e293d66955f5c55d9c739af94a692a30e
Reviewed-on: http://git-master/r/241375
The extended delay mode is added 400us delay to help system settles
to loaded situation.
Bug 1287901
Change-Id: I7965c89be6f5249110eae4c646c84f44e36257c8
Reviewed-on: http://git-master/r/241371
Added second value read back on read channel raw.
Bug 1287901
Change-Id: I0bde33c4cb16e1c500b0cf86b64ec3e84e9a61d7
Reviewed-on: http://git-master/r/241374
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Support second value read back on iio_st_read_channel_raw.
Bug 1287901
Change-Id: I2d5eb06ae3434fbca8a92591e8b498340371c771
Reviewed-on: http://git-master/r/241373
If flag for SMPS10 has the disable_boost_on_suspend is true then
make sure that boost of SMPS10 is disabled.
If any regulator is using this then defer the boost disable and
disable when client actually disable the smps10.
bug 1291841
Change-Id: Ia03d29f68132f87b970d4df8402b3cdd4dba95df
Reviewed-on: http://git-master/r/239722
(cherry picked from commit 368abfad3a0b27fa893df2d1b201339701df367d)
Change-Id: I9cd793bc0e8a49a0f295c1490d5bd92e9ccba57c
Reviewed-on: http://git-master/r/240921
Reviewed-by: Yong Goo Yi <yyi@nvidia.com>
Tested-by: Yong Goo Yi <yyi@nvidia.com>
Programming poweron_lpk bit of SWOFF_COLDREST register
based on poweron_lpk value in pdata.
if it's 0, the system off type by long press key is power down.
if it's 1, the system off type by long press key is restart.
bug 1308187
Change-Id: Id6944aa31b753d711626b08bbde9e51d031bfcc9
Reviewed-on: http://git-master/r/239620
Added generic ADC thermal sensor driver using ADC drivers supported by
IIO framework for thermal management.
Bug 1287901
Change-Id: Ic6fdb0fef4476c1d2a91ffcd9d18cba07dfb2d8d
Reviewed-on: http://git-master/r/238545
Reviewed-by: Edward Riegelsberger <eriegels@nvidia.com>
Added iio_maps to associate iio channels with consumers.
Bug 1287901
Change-Id: I11fdb73213dbd07d9e92a11d4c883028a37905d2
Reviewed-on: http://git-master/r/238543
