git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging / IIO fixes from Greg KH:
"Here are some IIO and Staging driver fixes for 3.17-rc6. They are all
pretty simple, and resolve reported issues"
* tag 'staging-3.17-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: vt6655: buffer overflow in ioctl
iio:magnetometer: bugfix magnetometers gain values
iio: adc: at91: don't use the last converted data register
iio: adc: xilinx-xadc: assign auxiliary channels address correctly
iio: meter: ade7758: Fix indio_dev->trig assignment
iio: inv_mpu6050: Fix indio_dev->trig assignment
iio: gyro: itg3200: Fix indio_dev->trig assignment
iio: st_sensors: Fix indio_dev->trig assignment
iio: hid_sensor_hub: Fix indio_dev->trig assignment
iio: adc: ad_sigma_delta: Fix indio_dev->trig assignment
iio: accel: bma180: Fix indio_dev->trig assignment
iio:trigger: modify return value for iio_trigger_get
iio:inkern: fix overwritten -EPROBE_DEFER in of_iio_channel_get_by_name
Pull drm fixes from Dave Airlie:
"A bunch of radeon fixes for oops on module unload, and problems with
resetting the dma engine, one nouveau fix for black boxes in rendering
on my mbp retina, one sti fix, and a couple of intel fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nouveau: ltc/gf100-: fix cbc issues on certain boards
drm/bochs: add missing drm_connector_register call
drm/cirrus: add missing drm_connector_register call
drm/radeon: Fix typo 'addr' -> 'entry' in rs400_gart_set_page
drm/nouveau/runpm: fix module unload
drm/radeon/px: fix module unload
vgaswitcheroo: add vga_switcheroo_fini_domain_pm_ops
drm/radeon: don't reset dma on r6xx-evergreen init
drm/radeon: don't reset sdma on CIK init
drm/radeon: don't reset dma on NI/SI init
drm/radeon/dpm: fix resume on mullins
drm/radeon: Disable HDP flush before every CS again for < r600
drm/radeon: delete unused PTE_* defines
drm/i915: Add limited color range readout for HDMI/DP ports on g4x/vlv/chv
drm: sti: do not iterate over the info frame array
drm/i915: Fix SRC_COPY width on 830/845g
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
First round of IIO fixes for the 3.17 cycle.
* Fix an overwritten error return that can prevent deferred probing when
using of_iio_channel_get_by_name
* A series that deals with an incorrect reference count when the default
trigger is set within the main probe routine for a driver. Can result
in a double free if the trigger is changed.
* Fix a buglet with xilinx-xadc concerning setup of the address for an
aux channel.
* At91 adc driver could sometimes get a touchscreen reading rather than
the intended adc channel. This is fixed by using the channel data register
instead.
* Fix some ST magnetometer gain values that differ in production parts from
the prerelease ones used for driver development.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"These fix:
- Boot video device detection on dual-GPU Apple systems
- Hotplug fiascos on VGA switcheroo with radeon & nouveau drivers
- Boot hang on Freescale i.MX6 systems
- Excessive "no hotplug settings from platform" warnings
In particular:
Enumeration
- Don't default exclusively to first video device (Bruno Prémont)
PCI device hotplug
- Remove "no hotplug settings from platform" warning (Bjorn Helgaas)
- Add pci_ignore_hotplug() for VGA switcheroo (Bjorn Helgaas)
Freescale i.MX6
- Put LTSSM in "Detect" state before disabling (Lucas Stach)"
* tag 'pci-v3.17-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
vgaarb: Drop obsolete #ifndef
vgaarb: Don't default exclusively to first video device with mem+io
ACPIPHP / radeon / nouveau: Remove acpi_bus_no_hotplug()
PCI: Remove "no hotplug settings from platform" warning
PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device
PCI: imx6: Put LTSSM in "Detect" state before disabling it
MAINTAINERS: Add Lucas Stach as co-maintainer for i.MX6 PCI driver
The scsi blk-mq support accidentally flipped a conditional, which lead to
never enabling block based tcq when using the legacy request path.
Fixes: d285203cf647d7c9 scsi: add support for a blk-mq based I/O path.
Reported-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
* pci/vga:
* commit '6a73336bde29':
into drm-fixes
- fix a resume hang on mullins
- fix an oops on module unload with vgaswitcheroo (radeon and nouveau)
- fix possible hangs DMA engine hangs due to hw bugs
* 'drm-fixes-3.17' of git://people.freedesktop.org/~agd5f/linux:
Drivers should call this on unload to unregister pmops.
Bug:
https://bugzilla.kernel.org/show_bug.cgi?id=84431
Reviewed-by: Ben Skeggs <bskeggs@redhat.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Commit 20cde694027e ("x86, ia64: Move EFI_FB vga_default_device()
initialization to pci_vga_fixup()") moved boot video device detection from
efifb to x86 and ia64 pci/fixup.c.
Remove the left-over #ifndef check that will always match since the
corresponding arch-specific define is gone with above patch.
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Matthew Garrett <matthew.garrett@nebula.com>
Revert parts of f244d8b623da ("ACPIPHP / radeon / nouveau: Fix VGA
switcheroo problem related to hotplug").
A previous commit 5493b31f0b55 ("PCI: Add pci_ignore_hotplug() to ignore
hotplug events for a device") added equivalent functionality implemented in
a different way for both acpiphp and pciehp.
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Acked-by: Dave Airlie <airlied@redhat.com>
Acked-by: Rajat Jain <rajatxjain@gmail.com>
Pull crypto fixes from Herbert Xu:
"This fixes the newly added drbg generator so that it actually works on
32-bit machines. Previously the code was only tested on 64-bit and on
32-bit it overflowed and simply doesn't work"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: drbg - remove check for uninitialized DRBG handle
crypto: drbg - backport "fix maximum value checks on 32 bit systems"
The performance regression that Josef Bacik reported in the pathname
lookup (see commit 99d263d4c5b2 "vfs: fix bad hashing of dentries") made
me look at performance stability of the dcache code, just to verify that
the problem was actually fixed. That turned up a few other problems in
this area.
There are a few cases where we exit RCU lookup mode and go to the slow
serializing case when we shouldn't, Al has fixed those and they'll come
in with the next VFS pull.
But my performance verification also shows that link_path_walk() turns
out to have a very unfortunate 32-bit store of the length and hash of
the name we look up, followed by a 64-bit read of the combined hash_len
field. That screws up the processor store to load forwarding, causing
an unnecessary hickup in this critical routine.
It's caused by the ugly calling convention for the "hash_name()"
function, and easily fixed by just making hash_name() fill in the whole
'struct qstr' rather than passing it a pointer to just the hash value.
With that, the profile for this function looks much smoother.
Pull futex and timer fixes from Thomas Gleixner:
"A oneliner bugfix for the jinxed futex code:
- Drop hash bucket lock in the error exit path. I really could slap
myself for intruducing that bug while fixing all the other horror
in that code three month ago ...
and the timer department is not too proud about the following fixes:
- Deal with a long standing rounding bug in the timeval to jiffies
conversion. It's a real issue and this fix fell through the cracks
for quite some time.
- Another round of alarmtimer fixes. Finally this code gets used
more widely and the subtle issues hidden for quite some time are
noticed and fixed. Nothing really exciting, just the itty bitty
details which bite the serious users here and there"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
futex: Unlock hb->lock in futex_wait_requeue_pi() error path
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
alarmtimer: Lock k_itimer during timer callback
alarmtimer: Do not signal SIGEV_NONE timers
alarmtimer: Return relative times in timer_gettime
jiffies: Fix timeval conversion to jiffies
The hash_64() function historically does the multiply by the
GOLDEN_RATIO_PRIME_64 number with explicit shifts and adds, because
unlike the 32-bit case, gcc seems unable to turn the constant multiply
into the more appropriate shift and adds when required.
However, that means that we generate those shifts and adds even when the
architecture has a fast multiplier, and could just do it better in
hardware.
Use the now-cleaned-up CONFIG_ARCH_HAS_FAST_MULTIPLIER (together with
"is it a 64-bit architecture") to decide whether to use an integer
multiply or the explicit sequence of shift/add instructions.
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen ARM bugfix from Stefano Stabellini:
"The patches fix the "xen_add_mach_to_phys_entry: cannot add" bug that
has been affecting xen on arm and arm64 guests since 3.16. They
require a few hypervisor side changes that just went in xen-unstable.
A couple of days ago David sent out a pull request with a few other
Xen fixes (it is already in master). Sorry we didn't synchronized
better among us"
* tag 'stable/for-linus-3.17-b-rc4-arm-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/arm: remove mach_to_phys rbtree
xen/arm: reimplement xen_dma_unmap_page & friends
xen/arm: introduce XENFEAT_grant_map_identity
timeval_to_jiffies tried to round a timeval up to an integral number
of jiffies, but the logic for doing so was incorrect: intervals
corresponding to exactly N jiffies would become N+1. This manifested
itself particularly repeatedly stopping/starting an itimer:
setitimer(ITIMER_PROF, &val, NULL);
setitimer(ITIMER_PROF, NULL, &val);
would add a full tick to val, _even if it was exactly representable in
terms of jiffies_ (say, the result of a previous rounding.) Doing
this repeatedly would cause unbounded growth in val. So fix the math.
Here's what was wrong with the conversion: we essentially computed
(eliding seconds)
jiffies = usec * (NSEC_PER_USEC/TICK_NSEC)
by using scaling arithmetic, which took the best approximation of
NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC =
x/(2^USEC_JIFFIE_SC), and computed:
jiffies = (usec * x) >> USEC_JIFFIE_SC
and rounded this calculation up in the intermediate form (since we
can't necessarily exactly represent TICK_NSEC in usec.) But the
scaling arithmetic is a (very slight) *over*approximation of the true
value; that is, instead of dividing by (1 usec/ 1 jiffie), we
effectively divided by (1 usec/1 jiffie)-epsilon (rounding
down). This would normally be fine, but we want to round timeouts up,
and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this
would be fine if our division was exact, but dividing this by the
slightly smaller factor was equivalent to adding just _over_ 1 to the
final result (instead of just _under_ 1, as desired.)
In particular, with HZ=1000, we consistently computed that 10000 usec
was 11 jiffies; the same was true for any exact multiple of
TICK_NSEC.
We could possibly still round in the intermediate form, adding
something less than 2^USEC_JIFFIE_SC - 1, but easier still is to
convert usec->nsec, round in nanoseconds, and then convert using
time*spec*_to_jiffies. This adds one constant multiplication, and is
not observably slower in microbenchmarks on recent x86 hardware.
Tested: the following program:
int main() {
struct itimerval zero = {{0, 0}, {0, 0}};
/* Initially set to 10 ms. */
struct itimerval initial = zero;
initial.it_interval.tv_usec = 10000;
setitimer(ITIMER_PROF, &initial, NULL);
/* Save and restore several times. */
for (size_t i = 0; i < 10; ++i) {
struct itimerval prev;
setitimer(ITIMER_PROF, &zero, &prev);
/* on old kernels, this goes up by TICK_USEC every iteration */
printf("previous value: %ld %ld %ld %ld\n",
prev.it_interval.tv_sec, prev.it_interval.tv_usec,
prev.it_value.tv_sec, prev.it_value.tv_usec);
setitimer(ITIMER_PROF, &prev, NULL);
return 0;
Cc: Paul Turner <pjt@google.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Paul Turner <pjt@google.com>
Reported-by: Aaron Jacobs <jacobsa@google.com>
Signed-off-by: Andrew Hunter <ahh@google.com>
[jstultz: Tweaked to apply to 3.17-rc]
Signed-off-by: John Stultz <john.stultz@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some USB and PHY fixes for 3.17-rc5.
Nothing major here, just a number of tiny fixes for reported issues,
and some new device ids as well.
All have been tested in linux-next"
* tag 'usb-3.17-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (46 commits)
xhci: fix oops when xhci resumes from hibernate with hw lpm capable devices
usb: xhci: Fix OOPS in xhci error handling code
xhci: Fix null pointer dereference if xhci initialization fails
storage: Add single-LUN quirk for Jaz USB Adapter
uas: Add missing le16_to_cpu calls to asm1051 / asm1053 usb-id check
usb: chipidea: msm: Initialize PHY on reset event
usb: chipidea: msm: Use USB PHY API to control PHY state
usb: hub: take hub->hdev reference when processing from eventlist
uas: Disable uas on ASM1051 devices
usb: dwc2/gadget: avoid disabling ep0
usb: dwc2/gadget: delay enabling irq once hardware is configured properly
usb: dwc2/gadget: do not call disconnect method in pullup
usb: dwc2/gadget: break infinite loop in endpoint disable code
usb: dwc2/gadget: fix phy initialization sequence
usb: dwc2/gadget: fix phy disable sequence
uwb: init beacon cache entry before registering uwb device
USB: ftdi_sio: Add support for GE Healthcare Nemo Tracker device
USB: document the 'u' flag for usb-storage quirks parameter
usb: host: xhci: fix compliance mode workaround
usb: dwc3: fix TRB completion when multiple TRBs are started
The flag tells us that the hypervisor maps a grant page to guest
physical address == machine address of the page in addition to the
normal grant mapping address. It is needed to properly issue cache
maintenance operation at the completion of a DMA operation involving a
foreign grant.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Tested-by: Denis Schneider <v1ne2go@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"An update to Synaptics PS/2 driver to handle "ForcePads" (currently
found in HP EliteBook 1040 laptops), a change for Elan PS/2 driver to
detect newer touchpads, bunch of devices get annotated as Trackpoint
and/or Pointer to help userspace classify and handle them, plus
assorted driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: serport - add compat handling for SPIOCSTYPE ioctl
Input: atmel_mxt_ts - fix double free of input device
Input: synaptics - add support for ForcePads
Input: matrix_keypad - use request_any_context_irq()
Input: atmel_mxt_ts - downgrade warning about empty interrupts
Input: wm971x - fix typo in module parameter description
Input: cap1106 - fix register definition
Input: add missing POINTER / DIRECT properties to a bunch of drivers
Input: add INPUT_PROP_POINTING_STICK property
Input: elantech - fix detection of touchpad on ASUS s301l
The new header file memfd.h from commit 9183df25fe7b ("shm: add
memfd_create() syscall") should be exported.
Signed-off-by: David Drysdale <drysdale@google.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Powering off a hot-pluggable device, e.g., with pci_set_power_state(D3cold),
normally generates a hot-remove event that unbinds the driver.
Some drivers expect to remain bound to a device even while they power it
off and back on again. This can be dangerous, because if the device is
removed or replaced while it is powered off, the driver doesn't know that
anything changed. But some drivers accept that risk.
Add pci_ignore_hotplug() for use by drivers that know their device cannot
be removed. Using pci_ignore_hotplug() tells the PCI core that hot-plug
events for the device should be ignored.
The radeon and nouveau drivers use this to switch between a low-power,
integrated GPU and a higher-power, higher-performance discrete GPU. They
power off the unused GPU, but they want to remain bound to it.
This is a reimplementation of f244d8b623da ("ACPIPHP / radeon / nouveau:
Fix VGA switcheroo problem related to hotplug") but extends it to work with
This fixes a problem where systems with dual GPUs using the radeon drivers
become unusable, freezing every few seconds (see bugzillas below). The
resume of the radeon device may also fail, e.g.,
This fixes problems on dual GPU systems where the radeon driver becomes
unusable because of problems while suspending the device, as in bug 79701:
[drm] radeon: finishing device.
radeon 0000:01:00.0: Userspace still has active objects !
radeon 0000:01:00.0: ffff8800cb4ec288 ffff8800cb4ec000 16384 4294967297 force free
WARNING: CPU: 0 PID: 67 at /home/apw/COD/linux/drivers/gpu/drm/radeon/radeon_gart.c:234 radeon_gart_unbind+0xd2/0xe0 [radeon]()
trying to unbind memory from uninitialized GART !
or while resuming it, as in bug 77261:
radeon 0000:01:00.0: ring 0 stalled for more than 10158msec
radeon 0000:01:00.0: GPU lockup ...
radeon 0000:01:00.0: GPU pci config reset
pciehp 0000:00:01.0:pcie04: Card not present on Slot(1-1)
radeon 0000:01:00.0: GPU reset succeeded, trying to resume
*ERROR* radeon: dpm resume failed
radeon 0000:01:00.0: Wait for MC idle timedout !
Link: https://bugzilla.kernel.org/show_bug.cgi?id=77261
Link: https://bugzilla.kernel.org/show_bug.cgi?id=79701
Reported-by: Shawn Starr <shawn.starr@rogers.com>
Reported-by: Jose P. <lbdkmjdf@sharklasers.com>
CC: stable@vger.kernel.org # v3.15+
It is useful for userspace to know that there not dealing with a regular
mouse but rather with a pointing stick (e.g. a trackpoint) so that
userspace can e.g. automatically enable middle button scrollwheel
emulation.
It is impossible to tell the difference from the evdev info without
resorting to putting a list of device / driver names in userspace, this is
undesirable.
Add a property which allows userspace to see if a device is a pointing
stick, and set it on all the pointing stick drivers.
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
Pull networking fixes from David Miller:
1) Fix skb leak in mac802154, from Martin Townsend
2) Use select not depends on NF_NAT for NFT_NAT, from Pablo Neira
Ayuso
3) Fix union initializer bogosity in vxlan, from Gerhard Stenzel
4) Fix RX checksum configuration in stmmac driver, from Giuseppe
CAVALLARO
5) Fix TSO with non-accelerated VLANs in e1000, e1000e, bna, ehea,
i40e, i40evf, mvneta, and qlge, from Vlad Yasevich
6) Fix capability checks in phy_init_eee(), from Giuseppe CAVALLARO
7) Try high order allocations more sanely for SKBs, specifically if a
high order allocation fails, fall back directly to zero order pages
rather than iterating down one order at a time. From Eric Dumazet
8) Fix a memory leak in openvswitch, from Li RongQing
9) amd-xgbe initializes wrong spinlock, from Thomas Lendacky
10) RTNL locking was busted in setsockopt for anycast and multicast, fix
from Sabrina Dubroca
11) Fix peer address refcount leak in ipv6, from Nicolas Dichtel
12) DocBook typo fixes, from Masanari Iida
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (101 commits)
ipv6: restore the behavior of ipv6_sock_ac_drop()
amd-xgbe: Enable interrupts for all management counters
amd-xgbe: Treat certain counter registers as 64 bit
greth: moved TX ring cleaning to NAPI rx poll func
cnic : Cleanup CONFIG_IPV6 & VLAN check
net: treewide: Fix typo found in DocBook/networking.xml
bnx2x: Fix link problems for 1G SFP RJ45 module
3c59x: avoid panic in boomerang_start_xmit when finding page address:
netfilter: add explicit Kconfig for NETFILTER_XT_NAT
ipv6: use addrconf_get_prefix_route() to remove peer addr
ipv6: fix a refcnt leak with peer addr
net-timestamp: only report sw timestamp if reporting bit is set
drivers/net/fddi/skfp/h/skfbi.h: Remove useless PCI_BASE_2ND macros
l2tp: fix race while getting PMTU on PPP pseudo-wire
ipv6: fix rtnl locking in setsockopt for anycast and multicast
VMXNET3: Check for map error in vmxnet3_set_mc
openvswitch: distinguish between the dropped and consumed skb
amd-xgbe: Fix initialization of the wrong spin lock
openvswitch: fix a memory leak
netfilter: fix missing dependencies in NETFILTER_XT_TARGET_LOG
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
pull request: wireless 2014-09-05
Please pull this batch of fixes intended for the 3.17 stream...
For the mac80211 bits, Johannes says:
"Here are a few fixes for mac80211. One has been discussed for a while
and adds a terminating NUL-byte to the alpha2 sent to userspace, which
shouldn't be necessary but since many places treat it as a string we
couldn't move to just sending two bytes.
In addition to that, we have two VLAN fixes from Felix, a mesh fix, a
fix for the recently introduced RX aggregation offload, a revert for
a broken patch (that luckily didn't really cause any harm) and a small
fix for alignment in debugfs."
For the iwlwifi bits, Emmanuel says:
"I revert a patch that disabled CTS to self in dvm because users
reported issues. The revert is CCed to stable since the offending
patch was sent to stable too. I also bump the firmware API versions
since a new firmware is coming up. On top of that, Marcel fixes a
bug I introduced while fixing a bug in our Kconfig file."
Please let me know if there are problems!
Pull ACPI and power management fixes from Rafael Wysocki:
"These are regression fixes (ACPI sysfs, ACPI video, suspend test),
ACPI cpuidle deadlock fix, missing runtime validation of ACPI _DSD
output, a fix and a new CPU ID for the RAPL driver, new blacklist
entry for the ACPI EC driver and a couple of trivial cleanups
(intel_pstate and generic PM domains).
Specifics:
- Fix for recently broken test_suspend= command line argument (Rafael
Wysocki).
- Fixes for regressions related to the ACPI video driver caused by
switching the default to native backlight handling in 3.16 from
Hans de Goede.
- Fix for a sysfs attribute of ACPI device objects that returns stale
values sometimes due to the fact that they are cached instead of
executing the appropriate method (_SUN) every time (broken in
3.14). From Yasuaki Ishimatsu.
- Fix for a deadlock between cpuidle_lock and cpu_hotplug.lock in the
ACPI processor driver from Jiri Kosina.
- Runtime output validation for the ACPI _DSD device configuration
object missing from the support for it that has been introduced
recently. From Mika Westerberg.
- Fix for an unuseful and misleading RAPL (Running Average Power
Limit) domain detection message in the RAPL driver from Jacob Pan.
- New Intel Haswell CPU ID for the RAPL driver from Jason Baron.
- New Clevo W350etq blacklist entry for the ACPI EC driver from Lan
Tianyu.
- Cleanup for the intel_pstate driver and the core generic PM domains
code from Gabriele Mazzotta and Geert Uytterhoeven"
* tag 'pm+acpi-3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / cpuidle: fix deadlock between cpuidle_lock and cpu_hotplug.lock
ACPI / scan: not cache _SUN value in struct acpi_device_pnp
cpufreq: intel_pstate: Remove unneeded variable
powercap / RAPL: change domain detection message
powercap / RAPL: add support for CPU model 0x3f
PM / domains: Make generic_pm_domain.name const
PM / sleep: Fix test_suspend= command line option
ACPI / EC: Add msi quirk for Clevo W350etq
ACPI / video: Disable native_backlight on HP ENVY 15 Notebook PC
ACPI / video: Add a disable_native_backlight quirk
ACPI / video: Fix use_native_backlight selection logic
ACPICA: ACPI 5.1: Add support for runtime validation of _DSD package.
Pull timer fixes from Thomas Gleixner:
"Three fixlets from the timer departement:
- Update the timekeeper before updating vsyscall and pvclock. This
fixes the kvm-clock regression reported by Chris and Paolo.
- Use the proper irq work interface from NMI. This fixes the
regression reported by Catalin and Dave.
- Clarify the compat_nanosleep error handling mechanism to avoid
future confusion"
timekeeping: Update timekeeper before updating vsyscall and pvclock
compat: nanosleep: Clarify error handling
nohz: Restore NMI safe local irq work for local nohz kick
Pull mtd fixes from Brian Norris:
"Two trivial MTD updates for 3.17-rc4:
- a tiny comment tweak, to kill a bunch of DocBook warnings added
during the merge window
- a small fixup to the OTP routines' error handling"
* tag 'for-linus-20140905' of git://git.infradead.org/linux-mtd:
mtd: nand: fix DocBook warnings on nand_sdr_timings doc
mtd: cfi_cmdset_0002: check return code for get_chip()
This patch fix spelling typo found in DocBook/networking.xml.
It is because the neworking.xml is generated from comments
in the source, I have to fix typo in comments within the source.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
The timestamping API has separate bits for generating and reporting
timestamps. A software timestamp should only be reported for a packet
when the packet has the relevant generation flag (SKBTX_..) set
and the socket has reporting bit SOF_TIMESTAMPING_SOFTWARE set.
The second check was accidentally removed. Reinstitute the original
behavior.
Tested:
Without this patch, Documentation/networking/txtimestamp reports
timestamps regardless of whether SOF_TIMESTAMPING_SOFTWARE is set.
After the patch, it only reports them when the flag is set.
Fixes: f24b9be5957b ("net-timestamp: extend SCM_TIMESTAMPING ancillary data struct")
Signed-off-by: Willem de Bruijn <willemb@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator documentation fixes from Mark Brown:
"All the fixes people have found for the regulator API have been
documentation fixes, avoiding warnings while building the kerneldoc,
fixing some errors in one of the DT bindings documents and fixing some
typos in the header"
* tag 'regulator-v3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: fix kernel-doc warnings in header files
regulator: Proofread documentation
regulator: tps65090: Fix tps65090 typos in example
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
- some documentation sync
- resource leak in the bt8xx driver
- again fix the way varargs are used to handle the optional flags on
the gpiod_* accessors. Now hopefully nailed the entire problem.
* tag 'gpio-v3.17-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: move varargs hack outside #ifdef GPIOLIB
gpio: bt8xx: fix release of managed resources
Documentation: gpio: documentation for optional getters functions
* pm-sleep:
* powercap:
* pm-domains:
* pm-cpufreq:
'regulator/fix/tps65090' into regulator-linus
This is a backport of commit b9347aff91ce4789619168539f08202d8d6a1177.
This backport is needed as without it the code will crash on 32-bit
systems.
The maximum values for additional input string or generated blocks is
larger than 1<<32. To ensure a sensible value on 32 bit systems, return
SIZE_MAX on 32 bit systems. This value is lower than the maximum
allowed values defined in SP800-90A. The standard allow lower maximum
values, but not larger values.
SIZE_MAX - 1 is used for drbg_max_addtl to allow
drbg_healthcheck_sanity to check the enforcement of the variable
without wrapping.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Fixes: 588b48caf65c ("usbip: move usbip userspace code out of staging")
which introduced build failure by not changing uapi/usbip.h include path
according to new location.
Signed-off-by: Piotr Król <piotr.krol@3mdeb.com>
The local nohz kick is currently used by perf which needs it to be
NMI-safe. Recent commit though (7d1311b93e58ed55f3a31cc8f94c4b8fe988a2b9)
changed its implementation to fire the local kick using the remote kick
API. It was convenient to make the code more generic but the remote kick
isn't NMI-safe.
As a result:
WARNING: CPU: 3 PID: 18062 at kernel/irq_work.c:72 irq_work_queue_on+0x11e/0x140()
CPU: 3 PID: 18062 Comm: trinity-subchil Not tainted 3.16.0+ #34
0000000000000009 00000000903774d1 ffff880244e06c00 ffffffff9a7f1e37
0000000000000000 ffff880244e06c38 ffffffff9a0791dd ffff880244fce180
0000000000000003 ffff880244e06d58 ffff880244e06ef8 0000000000000000
Call Trace:
<NMI> [<ffffffff9a7f1e37>] dump_stack+0x4e/0x7a
[<ffffffff9a0791dd>] warn_slowpath_common+0x7d/0xa0
[<ffffffff9a07930a>] warn_slowpath_null+0x1a/0x20
[<ffffffff9a17ca1e>] irq_work_queue_on+0x11e/0x140
[<ffffffff9a10a2c7>] tick_nohz_full_kick_cpu+0x57/0x90
[<ffffffff9a186cd5>] __perf_event_overflow+0x275/0x350
[<ffffffff9a184f80>] ? perf_event_task_disable+0xa0/0xa0
[<ffffffff9a01a4cf>] ? x86_perf_event_set_period+0xbf/0x150
[<ffffffff9a187934>] perf_event_overflow+0x14/0x20
[<ffffffff9a020386>] intel_pmu_handle_irq+0x206/0x410
[<ffffffff9a0b54d3>] ? arch_vtime_task_switch+0x63/0x130
[<ffffffff9a01937b>] perf_event_nmi_handler+0x2b/0x50
[<ffffffff9a007b72>] nmi_handle+0xd2/0x390
[<ffffffff9a007aa5>] ? nmi_handle+0x5/0x390
[<ffffffff9a0d131b>] ? lock_release+0xab/0x330
[<ffffffff9a008062>] default_do_nmi+0x72/0x1c0
[<ffffffff9a0c925f>] ? cpuacct_account_field+0xcf/0x200
[<ffffffff9a008268>] do_nmi+0xb8/0x100
Lets fix this by restoring the use of local irq work for the nohz local
kick.
Reported-by: Catalin Iacob <iacobcatalin@gmail.com>
Reported-and-tested-by: Dave Jones <davej@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Johannes Berg <johannes@sipsolutions.net> says:
Signed-off-by: John W. Linville <linville@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"This time it contains a bunch of small ASoC fixes that slipped from in
previous updates, in addition to the usual HD-audio fixes and the
regression fixes for FireWire updates in 3.17.
All commits are reasonably small fixes"
* tag 'sound-3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Fix COEF setups for ALC1150 codec
ASoC: simple-card: Fix bug of wrong decrement DT node's refcount
ALSA: hda - Fix digital mic on Acer Aspire 3830TG
ASoC: omap-twl4030: Fix typo in 2nd dai link's platform_name
ALSA: firewire-lib/dice: add arrangements of PCM pointer and interrupts for Dice quirk
ALSA: dice: fix wrong channel mappping at higher sampling rate
ASoC: cs4265: Fix setting of functional mode and clock divider
ASoC: cs4265: Fix clock rates in clock map table
ASoC: rt5677: correct mismatch widget name
ASoC: rt5640: Do not allow regmap to use bulk read-write operations
ASoC: tegra: Fix typo in include guard
ASoC: da732x: Fix typo in include guard
ASoC: core: fix .info for SND_SOC_BYTES_TLV
ASoC: rcar: Use && instead of & for boolean expressions
ASoC: Use dev_set_name() instead of init_name
ASoC: axi: Fix ADI AXI SPDIF specification
The _SUN device indentification object is not guaranteed to return
the same value every time it is executed, so we should not cache its
return value, but rather execute it every time as needed. If it is
cached, an incorrect stale value may be used in some situations.
This issue was exposed by commit 202317a573b2 (ACPI / scan: Add
acpi_device objects for all device nodes in the namespace). Fix it
by avoiding to cache the return value of _SUN.
Fixes: 202317a573b2 (ACPI / scan: Add acpi_device objects for all device nodes in the namespace)
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: 3.14+ <stable@vger.kernel.org> # 3.14+
[ rjw: Changelog ]
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs bug fixes from Jaegeuk Kim:
"This series includes patches to:
- fix recovery routines
- fix bugs related to inline_data/xattr
- fix when casting the dentry names
- handle EIO or ENOMEM correctly
- fix memory leak
- fix lock coverage"
* tag 'for-f2fs-3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (28 commits)
f2fs: reposition unlock_new_inode to prevent accessing invalid inode
f2fs: fix wrong casting for dentry name
f2fs: simplify by using a literal
f2fs: truncate stale block for inline_data
f2fs: use macro for code readability
f2fs: introduce need_do_checkpoint for readability
f2fs: fix incorrect calculation with total/free inode num
f2fs: remove rename and use rename2
f2fs: skip if inline_data was converted already
f2fs: remove rewrite_node_page
f2fs: avoid double lock in truncate_blocks
f2fs: prevent checkpoint during roll-forward
f2fs: add WARN_ON in f2fs_bug_on
f2fs: handle EIO not to break fs consistency
f2fs: check s_dirty under cp_mutex
f2fs: unlock_page when node page is redirtied out
f2fs: introduce f2fs_cp_error for readability
f2fs: give a chance to mount again when encountering errors
f2fs: trigger release_dirty_inode in f2fs_put_super
f2fs: don't skip checkpoint if there is no dirty node pages
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Pablo Neira Ayuso says:
pull request: Netfilter/IPVS fixes for net
The following patchset contains seven Netfilter fixes for your net
tree, they are:
1) Make the NAT infrastructure independent of x_tables, some users are
already starting to test nf_tables with NAT without enabling x_tables.
Without this patch for Kconfig, there's a superfluous dependency
between NAT and x_tables.
2) Allow to use 0 in the cgroup match, the kernel rejects with -EINVAL
with no good reason. From Daniel Borkmann.
3) Select CONFIG_NF_NAT from the nf_tables NAT expression, this also
resolves another NAT dependency with x_tables.
4) Use HAVE_JUMP_LABEL instead of CONFIG_JUMP_LABEL in the Netfilter hook
code as elsewhere in the kernel to resolve toolchain problems, from
Zhouyi Zhou.
5) Use iptunnel_handle_offloads() to set up tunnel encapsulation
depending on the offload capabilities, reported by Alex Gartrell
patch from Julian Anastasov.
6) Fix wrong family when registering the ip_vs_local_reply6() hook,
also from Julian.
7) Select the NF_LOG_* symbols from NETFILTER_XT_TARGET_LOG. Rafał
Miłecki reported that when jumping from 3.16 to 3.17-rc, his log
target is not selected anymore due to changes in the previous
development cycle to accomodate the full logging support for
nf_tables.
This reverts commit 8b37e1bef5a6b60e949e28a4db3006e4b00bd758.
It's broken as it changes led_blink_set() in a way that it can now sleep
(while synchronously waiting for workqueue to be cancelled). That's a
problem, because it's possible that this function gets called from atomic
context (tpt_trig_timer() takes a readlock and thus disables preemption).
This has been brought up 3 weeks ago already [1] but no proper fix has
materialized, and I keep seeing the problem since 3.17-rc1.
[1] https://lkml.org/lkml/2014/8/16/128
BUG: sleeping function called from invalid context at kernel/workqueue.c:2650
in_atomic(): 1, irqs_disabled(): 0, pid: 2335, name: wpa_supplicant
5 locks held by wpa_supplicant/2335:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff814c7c92>] rtnl_lock+0x12/0x20
#1: (&wdev->mtx){+.+.+.}, at: [<ffffffffc06e649c>] cfg80211_mgd_wext_siwessid+0x5c/0x180 [cfg80211]
#2: (&local->mtx){+.+.+.}, at: [<ffffffffc0817dea>] ieee80211_prep_connection+0x17a/0x9a0 [mac80211]
#3: (&local->chanctx_mtx){+.+.+.}, at: [<ffffffffc08081ed>] ieee80211_vif_use_channel+0x5d/0x2a0 [mac80211]
#4: (&trig->leddev_list_lock){.+.+..}, at: [<ffffffffc081e68c>] tpt_trig_timer+0xec/0x170 [mac80211]
CPU: 0 PID: 2335 Comm: wpa_supplicant Not tainted 3.17.0-rc3 #1
Hardware name: LENOVO 7470BN2/7470BN2, BIOS 6DET38WW (2.02 ) 12/19/2008
ffff8800360b5a50 ffff8800751f76d8 ffffffff8159e97f ffff8800360b5a30
ffff8800751f76e8 ffffffff810739a5 ffff8800751f77b0 ffffffff8106862f
ffffffff810685d0 0aa2209200000000 ffff880000000004 ffff8800361c59d0
Call Trace:
[<ffffffff8159e97f>] dump_stack+0x4d/0x66
[<ffffffff810739a5>] __might_sleep+0xe5/0x120
[<ffffffff8106862f>] flush_work+0x5f/0x270
[<ffffffff810685d0>] ? mod_delayed_work_on+0x80/0x80
[<ffffffff810945ca>] ? mark_held_locks+0x6a/0x90
[<ffffffff81068a5f>] ? __cancel_work_timer+0x6f/0x100
[<ffffffff810946ed>] ? trace_hardirqs_on_caller+0xfd/0x1c0
[<ffffffff81068a6b>] __cancel_work_timer+0x7b/0x100
[<ffffffff81068b0e>] cancel_delayed_work_sync+0xe/0x10
[<ffffffff8147cf3b>] led_blink_set+0x1b/0x40
[<ffffffffc081e6b0>] tpt_trig_timer+0x110/0x170 [mac80211]
[<ffffffffc081ecdd>] ieee80211_mod_tpt_led_trig+0x9d/0x160 [mac80211]
[<ffffffffc07e4278>] __ieee80211_recalc_idle+0x98/0x140 [mac80211]
[<ffffffffc07e59ce>] ieee80211_idle_off+0xe/0x10 [mac80211]
[<ffffffffc0804e5b>] ieee80211_add_chanctx+0x3b/0x220 [mac80211]
[<ffffffffc08062e4>] ieee80211_new_chanctx+0x44/0xf0 [mac80211]
[<ffffffffc080838a>] ieee80211_vif_use_channel+0x1fa/0x2a0 [mac80211]
[<ffffffffc0817df8>] ieee80211_prep_connection+0x188/0x9a0 [mac80211]
[<ffffffffc081c246>] ieee80211_mgd_auth+0x256/0x2e0 [mac80211]
[<ffffffffc07eab33>] ieee80211_auth+0x13/0x20 [mac80211]
[<ffffffffc06cb006>] cfg80211_mlme_auth+0x106/0x270 [cfg80211]
[<ffffffffc06ce085>] cfg80211_conn_do_work+0x155/0x3b0 [cfg80211]
[<ffffffffc06cf670>] cfg80211_connect+0x3f0/0x540 [cfg80211]
[<ffffffffc06e6148>] cfg80211_mgd_wext_connect+0x158/0x1f0 [cfg80211]
[<ffffffffc06e651e>] cfg80211_mgd_wext_siwessid+0xde/0x180 [cfg80211]
[<ffffffffc06e36c0>] ? cfg80211_wext_giwessid+0x50/0x50 [cfg80211]
[<ffffffffc06e36dd>] cfg80211_wext_siwessid+0x1d/0x40 [cfg80211]
[<ffffffff81584d0c>] ioctl_standard_iw_point+0x14c/0x3e0
[<ffffffff8158502a>] ioctl_standard_call+0x8a/0xd0
[<ffffffff81584fa0>] ? ioctl_standard_iw_point+0x3e0/0x3e0
[<ffffffff81584b76>] wireless_process_ioctl.constprop.10+0xb6/0x100
[<ffffffff8158521d>] wext_handle_ioctl+0x5d/0xb0
[<ffffffff814cfb29>] dev_ioctl+0x329/0x620
[<ffffffff8149c7f2>] sock_ioctl+0x142/0x2e0
[<ffffffff811b0140>] do_vfs_ioctl+0x300/0x520
[<ffffffff815a67fb>] ? sysret_check+0x1b/0x56
[<ffffffff811b03e1>] SyS_ioctl+0x81/0xa0
[<ffffffff815a67d6>] system_call_fastpath+0x1a/0x1f
wlan0: send auth to 00:0b:6b:3c:8c:e4 (try 1/3)
wlan0: authenticated
wlan0: associate with 00:0b:6b:3c:8c:e4 (try 1/3)
wlan0: RX AssocResp from 00:0b:6b:3c:8c:e4 (capab=0x431 status=0 aid=2)
wlan0: associated
IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
cfg80211: Calling CRDA for country: NA
wlan0: Limiting TX power to 27 (27 - 0) dBm as advertised by 00:0b:6b:3c:8c:e4
[ INFO: inconsistent lock state ]
3.17.0-rc3 #1 Not tainted
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
swapper/0/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
((&(&led_cdev->blink_work)->work)){+.?...}, at: [<ffffffff810685d0>] flush_work+0x0/0x270
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff81094dbe>] __lock_acquire+0x30e/0x1a30
[<ffffffff81096c81>] lock_acquire+0x91/0x110
[<ffffffff81068608>] flush_work+0x38/0x270
irq event stamp: 493416
hardirqs last enabled at (493416): [<ffffffff81068a5f>] __cancel_work_timer+0x6f/0x100
hardirqs last disabled at (493415): [<ffffffff81067e9f>] try_to_grab_pending+0x1f/0x160
softirqs last enabled at (493408): [<ffffffff81053ced>] _local_bh_enable+0x1d/0x50
softirqs last disabled at (493409): [<ffffffff81054c75>] irq_exit+0xa5/0xb0
Possible unsafe locking scenario:
CPU0
lock((&(&led_cdev->blink_work)->work));
<Interrupt>
*** DEADLOCK ***
2 locks held by swapper/0/0:
#0: (((&tpt_trig->timer))){+.-...}, at: [<ffffffff810b4c50>] call_timer_fn+0x0/0x180
#1: (&trig->leddev_list_lock){.+.?..}, at: [<ffffffffc081e68c>] tpt_trig_timer+0xec/0x170 [mac80211]
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.17.0-rc3 #1
ffffffff8246eb30 ffff88007c203b00 ffffffff8159e97f ffffffff81a194c0
ffff88007c203b50 ffffffff81599c29 0000000000000001 ffffffff00000001
ffff880000000000 0000000000000006 ffffffff81a194c0 ffffffff81093ad0
Call Trace:
<IRQ> [<ffffffff8159e97f>] dump_stack+0x4d/0x66
[<ffffffff81599c29>] print_usage_bug+0x1f4/0x205
[<ffffffff81093ad0>] ? check_usage_backwards+0x140/0x140
[<ffffffff810944d3>] mark_lock+0x223/0x2b0
[<ffffffff81094d60>] __lock_acquire+0x2b0/0x1a30
[<ffffffffc081e5a0>] ? __ieee80211_get_rx_led_name+0x10/0x10 [mac80211]
[<ffffffff8109469d>] ? trace_hardirqs_on_caller+0xad/0x1c0
[<ffffffff810b4cc5>] call_timer_fn+0x75/0x180
[<ffffffff810b4c50>] ? process_timeout+0x10/0x10
[<ffffffff810b50ac>] run_timer_softirq+0x1fc/0x2f0
[<ffffffff81054805>] __do_softirq+0x115/0x2e0
[<ffffffff810049b3>] do_IRQ+0x53/0xf0
[<ffffffff815a74af>] common_interrupt+0x6f/0x6f
<EOI> [<ffffffff8147b56e>] ? cpuidle_enter_state+0x6e/0x180
[<ffffffff8147b732>] cpuidle_enter+0x12/0x20
[<ffffffff8108bba0>] cpu_startup_entry+0x330/0x360
[<ffffffff8158fb51>] rest_init+0xc1/0xd0
[<ffffffff8158fa90>] ? csum_partial_copy_generic+0x170/0x170
[<ffffffff81af3ff2>] start_kernel+0x44f/0x45a
[<ffffffff81af399c>] ? set_init_arg+0x53/0x53
[<ffffffff81af35ad>] x86_64_start_reservations+0x2a/0x2c
[<ffffffff81af36a0>] x86_64_start_kernel+0xf1/0xf4
Cc: Vincent Donnefort <vdonnefort@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Signed-off-by: Bryan Wu <cooloney@gmail.com>
commit 39b2bbe3d715cf5013b5c48695ccdd25bd3bf120
"gpio: add flags argument to gpiod_get*() functions"
added a dynamic flags argument to all the GPIOD getter
functions, however this did not cover the stubs so
when people used gpiod stubs to compile out descriptor
code, compilation failed.
Solve this by:
- Also rename all the stub functions __gpiod_*
- Moving the vararg hack outside of #ifdef CONFIG_GPIOLIB
so these will always be available.
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
pull request: wireless 2014-08-28
For the Bluetooth/6LowPAN/802.15.4 bits, Johan says:
'It contains a connection reference counting fix for LE where a
connection might stay up even though it should get disconnected.
The other 802.15.4 6LoWPAN related patches were sent to the bluetooth
tree by Alexander Aring and described as follows by him:
these patches contains patches for the bluetooth branch.
This series includes memory leak fixes and an errno value fix.
Also there are two patches for sending and receiving 1280 6LoWPAN
packets, which makes the IEEE 802.15.4 6LoWPAN stack more RFC
compliant.
Along with that...
Alexey Khoroshilov fixes a use-after-free bug on at76c50x-usb.
Hauke Mehrtens adds a PCI ID to bcma.
Himangi Saraogi fixes a silly "A || A" test in rtlwifi.
Larry Finger adds a device ID to rtl8192cu.
Maks Naumov fixes a strncmp argument in ath9k.
Álvaro Fernández Rojas adds a PCI ID to ssb.
Pull ARM SoC fixes from Olof Johansson:
"Here's the weekly batch of fixes from arm-soc.
The delta is a largeish negative delta, due to revert of SMP support
for Broadcom's STB SoC -- it was accidentally merged before some
issues had been addressed, so they will make a new attempt for 3.18.
I didn't see a need for a full revert of the whole platform due to
this, we're keeping the rest enabled.
The rest is mostly:
- a handful of DT fixes for i.MX (Hummingboard/Cubox-i in particular)
- some MTD/NAND fixes for OMAP
- minor DT fixes for shmobile
- warning fix for UP builds on vexpress/spc
There's also a couple of patches that wires up hwmod on TI's DRA7 SoC
so it can boot. Drivers and the rest had landed for 3.17, and it's
small and isolated so it made sense to pick up now even if it's not a
bugfix"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
vexpress/spc: fix a build warning on array bounds
ARM: DRA7: hwmod: Add dra74x and dra72x specific ocp interface lists
ARM: DRA7: Add support for soc_is_dra74x() and soc_is_dra72x() variants
MAINTAINERS: catch special Rockchip code locations
ARM: dts: microsom-ar8035: MDIO pad must be set open drain
ARM: dts: omap54xx-clocks: Fix the l3 and l4 clock rates
ARM: brcmstb: revert SMP support
ARM: OMAP2+: hwmod: Rearm wake-up interrupts for DT when MUSB is idled
ARM: dts: Enable UART wake-up events for beagleboard
ARM: dts: Remove twl6030 clk32g "regulator"
ARM: OMAP2+: omap_device: remove warning that clk alias already exists
ARM: OMAP: fix %d confusingly prefixed with 0x in format string
ARM: dts: DRA7: fix interrupt-cells for GPIO
mtd: nand: omap: Fix 1-bit Hamming code scheme, omap_calculate_ecc()
ARM: dts: omap3430-sdp: Revert to using software ECC for NAND
ARM: OMAP2+: GPMC: Support Software ECC scheme via DT
mtd: nand: omap: Revert to using software ECC by default
ARM: dts: hummingboard/cubox-i: change SPDIF output to be more descriptive
ARM: dts: hummingboard/cubox-i: add USB OC pinctrl configuration
ARM: shmobile: r8a7791: add missing 0x0100 for SDCKCR
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi bugfixes from Mark Brown:
"A smattering of bug fixes for the SPI subsystem, all in driver code
which has seen active work recently and none of them with any great
global impact.
There's also a new ACPI ID for the pxa2xx driver which required no
code changes and the addition of kerneldoc for some structure fields
that were missing it and generating warnings during documentation
builds as a result"
* tag 'spi-v3.17-rc3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: sh-msiof: Fix transmit-only DMA transfers
spi/rockchip: Avoid accidentally turning off the clock
spi: dw: fix kernel crash due to NULL pointer dereference
spi: dw-pci: fix bug when regs left uninitialized
spi: davinci: fix SPI_NO_CS functionality
spi/rockchip: fixup incorrect dma direction setting
spi/pxa2xx: Add ACPI ID for Intel Braswell
spi: spi-au1550: fix build failure
spi: rspi: Fix leaking of unused DMA descriptors
spi: sh-msiof: Fix leaking of unused DMA descriptors
spi: Add missing kerneldoc bits
spi/omap-mcspi: Fix the spi task hangs waiting dma_rx
'spi/fix/doc', 'spi/fix/dw', 'spi/fix/omap-mcspi', 'spi/fix/pxa2xx', 'spi/fix/rockchip' and 'spi/fix/rspi' into spi-linus
Since SCTP day 1, that is, 19b55a2af145 ("Initial commit") from lksctp
tree, the official <netinet/sctp.h> header carries a copy of enum
sctp_sstat_state that looks like (compared to the current in-kernel
enumeration):
User definition: Kernel definition:
enum sctp_sstat_state { typedef enum {
SCTP_EMPTY = 0, <removed>
SCTP_CLOSED = 1, SCTP_STATE_CLOSED = 0,
SCTP_COOKIE_WAIT = 2, SCTP_STATE_COOKIE_WAIT = 1,
SCTP_COOKIE_ECHOED = 3, SCTP_STATE_COOKIE_ECHOED = 2,
SCTP_ESTABLISHED = 4, SCTP_STATE_ESTABLISHED = 3,
SCTP_SHUTDOWN_PENDING = 5, SCTP_STATE_SHUTDOWN_PENDING = 4,
SCTP_SHUTDOWN_SENT = 6, SCTP_STATE_SHUTDOWN_SENT = 5,
SCTP_SHUTDOWN_RECEIVED = 7, SCTP_STATE_SHUTDOWN_RECEIVED = 6,
SCTP_SHUTDOWN_ACK_SENT = 8, SCTP_STATE_SHUTDOWN_ACK_SENT = 7,
}; } sctp_state_t;
This header was later on also placed into the uapi, so that user space
programs can compile without having <netinet/sctp.h>, but the shipped
with <linux/sctp.h> instead.
While RFC6458 under 8.2.1.Association Status (SCTP_STATUS) says that
sstat_state can range from SCTP_CLOSED to SCTP_SHUTDOWN_ACK_SENT, we
nevertheless have a what it appears to be dummy SCTP_EMPTY state from
the very early days.
While it seems to do just nothing, commit 0b8f9e25b0aa ("sctp: remove
completely unsed EMPTY state") did the right thing and removed this dead
code. That however, causes an off-by-one when the user asks the SCTP
stack via SCTP_STATUS API and checks for the current socket state thus
yielding possibly undefined behaviour in applications as they expect
the kernel to tell the right thing.
The enumeration had to be changed however as based on the current socket
state, we access a function pointer lookup-table through this. Therefore,
I think the best way to deal with this is just to add a helper function
sctp_assoc_to_state() to encapsulate the off-by-one quirk.
Reported-by: Tristan Su <sooqing@gmail.com>
Fixes: 0b8f9e25b0aa ("sctp: remove completely unsed EMPTY state")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
