imx_3.0.35_android
can_get_echo_skb() is usually called in the TX complete handler.
The stats->tx_packets and stats->tx_bytes should be updated there, too.
This patch simplifies to figure out the size of the sent CAN frame.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Use circle buf to replace old ringbuf mechanism.
Change to use circle buffer in read, write, rx isr and tx isr functions.
In first design of MLB, it's using it's own mechanism to manage ring
buffer, like in mxc_mlb.c.
And then, I saw that kernel already had a serials of circ buffer macros
which can be used to manage ring buffers.
This patch is to use circle buffer macros to manage mlb internal ring
buffers.
For detail of circle buffers, you can refer to
linux-2.6-imx/Documentation/circular-buffers.txt.
Signed-off-by: Terry Lv <r65388@freescale.com>
All of the interrupts from the ENET block are not routed to
the GPC block. Hence ENET interrupts are not able to wake
up the SOC when the system is in WAIT mode. And the ENET
interrupt gets serviced only when another interrupt causes
the SOC to exit WAIT mode. This impacts the ENET performance.
To fix the issue two options:
1. Route the ENET interrupt to a GPIO. Need to enable the
CONFIG_MX6_ENET_IRQ_TO_GPIO in the config.
2. If the GPIO mechanism cannot be used and is not enabled
by the above mentioned config, the patch will disable entry
to WAIT mode until ENET clock is active. When the ENET clock
is disabled, WAIT mode will be automatically enetered.
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
imx_3.0.35_android
During the read of NOR, the kernel actually calls the inline_map_copy_from()
to read the data out. And inline_map_copy_from() will use the memcpy_fromio()
to do the real job.
The memcpy_fromio macro maps _memcpy_fromio() in the current code.
But the _memcpy_fromio() will use readb() to do the copy work one byte
by one byte. This makes the read performance of NOR very slow(about 2~3MB/s).
A similiar discussion could be found in:
http://lists.infradead.org/pipermail/linux-arm-kernel/2009-November/003860.html
This patch replace the memcpy_fromio with memcpy which is optimized by the
kernel.
The following is the result from mtd_speedtest with M29W256GL7AN6E:
mtd_speedtest: MTD device: 2
mtd_speedtest: not NAND flash, assume page size is 512 bytes.
mtd_speedtest: MTD device size 4194304, eraseblock size 131072, page size 512,
count of eraseblocks 32, pages per eraseblock 256, OOB size 0
mtd_speedtest: testing eraseblock write speed
mtd_speedtest: eraseblock write speed is 845 KiB/s
mtd_speedtest: testing eraseblock read speed
mtd_speedtest: eraseblock read speed is 19504 KiB/s
mtd_speedtest: testing page write speed
mtd_speedtest: page write speed is 845 KiB/s
mtd_speedtest: testing page read speed
mtd_speedtest: page read speed is 19140 KiB/s
mtd_speedtest: testing 2 page write speed
mtd_speedtest: 2 page write speed is 846 KiB/s
mtd_speedtest: testing 2 page read speed
mtd_speedtest: 2 page read speed is 19320 KiB/s
mtd_speedtest: Testing erase speed
mtd_speedtest: erase speed is 233 KiB/s
mtd_speedtest: Testing 2x multi-block erase speed
mtd_speedtest: 2x multi-block erase speed is 225 KiB/s
mtd_speedtest: Testing 4x multi-block erase speed
mtd_speedtest: 4x multi-block erase speed is 224 KiB/s
mtd_speedtest: Testing 8x multi-block erase speed
mtd_speedtest: 8x multi-block erase speed is 225 KiB/s
mtd_speedtest: Testing 16x multi-block erase speed
mtd_speedtest: 16x multi-block erase speed is 225 KiB/s
mtd_speedtest: Testing 32x multi-block erase speed
mtd_speedtest: 32x multi-block erase speed is 225 KiB/s
mtd_speedtest: Testing 64x multi-block erase speed
mtd_speedtest: 64x multi-block erase speed is 224 KiB/s
mtd_speedtest: finished
Signed-off-by: Huang Shijie <b32955@freescale.com>
imx_3.0.35_android
This reverts commit 573bab0be2427d6664420eaf9d8e272dbe9d840f.
i.mx6dl/dq sabreauto/sabresd board will boot up failed
randomly with this patch-set, thus revert it. [Jason]
Signed-off-by: Jason Liu <r64343@freescale.com>
This patch provides support for routing the ENET interrupt
to GPIO_1_6. Routing to this GPIO requires no HW board mods.
If the GPIO_1_6 is being used for some other peripheral,
this patch can be followed to route the ENET interrupt to
any other GPIO though a HW mode maybe required.
imx_3.0.35_android
drivers/net/fec.c
drivers/video/mxc/ldb.c
There are so many retries happen on the per-cpu event device
when run the command 'cat /proc/timer_list', as following:
root@~$ cat /proc/timer_list
Timer List Version: v0.6
HRTIMER_MAX_CLOCK_BASES: 3
now at 3297691988044 nsecs
Tick Device: mode: 1
Per CPU device: 0
Clock Event Device: local_timer
max_delta_ns: 8624432320
min_delta_ns: 1000
mult: 2138893713
shift: 32
mode: 3
next_event: 3297700000000 nsecs
set_next_event: twd_set_next_event
set_mode: twd_set_mode
event_handler: hrtimer_interrupt
retries: 36383
the reason is that the local timer will stop when enter C3 state,
we need switch the local timer to bc timer when enter the state
and switch back when exit from the that state.The code is like this:
void arch_idle(void)
clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_ENTER, &cpu);
enter_the_wait_mode();
clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_EXIT, &cpu);
when the broadcast timer interrupt arrives(this interrupt just wakeup
the ARM, and ARM has no chance to handle it since local irq is disabled.
In fact it's disabled in cpu_idle() of arch/arm/kernel/process.c)
the broadcast timer interrupt will wake up the CPU and run:
clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_EXIT, &cpu); ->
tick_broadcast_oneshot_control(...);
tick_program_event(dev->next_event, 1);
tick_dev_program_event(dev, expires, force);
for (i = 0;;) {
int ret = clockevents_program_event(dev, expires, now);
if (!ret || !force)
return ret;
dev->retries++;
now = ktime_get();
expires = ktime_add_ns(now, dev->min_delta_ns);
delta = ktime_to_ns(ktime_sub(expires, now));
if (delta <= 0)
return -ETIME;
when the bc timer interrupt arrives, which means the last local timer
expires too. so, clockevents_program_event will return -ETIME, which will
cause the dev->retries++ when retry to program the expired timer.
Even under the worst case, after the re-program the expired timer,
then CPU enter idle quickly before the re-progam timer expired,
it will make system ping-pang forever if no interrupt happen.
We have found the ping-pang issue during the video play-back test.
system will freeze and video not playing for sometime until other interrupt
occured to break the error condition.
The detailed information, please refer to the LKML:https://lkml.org/lkml/2013/2/20/216
which posted by Jason Liu.
Tested-by: Jason Liu <r64343@freescale.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Per CPU device: 0
min_delta_ns: 1000
mult: 2138893713
shift: 32
mode: 3
retries: 36383
for (i = 0;;) {
if (!ret || !force)
return ret;
dev->retries++;
now = ktime_get();
if (delta <= 0)
return -ETIME;
arch/arm/mach-mx6/Makefile
arch/arm/mach-mx6/board-mx6dl_hdmidongle.h
arch/arm/mach-mx6/board-mx6q_hdmidongle.c
arch/arm/mach-mx6/board-mx6q_hdmidongle.h
arch/arm/mach-mx6/board-mx6q_sabreauto.c
arch/arm/mach-mx6/board-mx6q_sabrelite.c
drivers/media/video/mxc/capture/csi_v4l2_capture.c
drivers/media/video/mxc/capture/ipu_csi_enc.c
drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_hardware.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_compiler.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_enum.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_options.h
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_device.c
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_driver.c
drivers/mxc/vpu/mxc_vpu.c
drivers/usb/gadget/arcotg_udc.c
drivers/video/mxc/mxc_ipuv3_fb.c
drivers/video/mxc_hdmi.c
include/linux/mxcfb.h
sound/soc/imx/imx-wm8962.c
Add mxcfb ioctrl MXCFB_CSC_UPDATE to update IPU DP CSC matrix
for display adjustment.
This patch defines the ioctrl interface in header file.
Signed-off-by: Wayne Zou <b36644@freescale.com>
Make CARVEOUT ION heap be configured to be cachable as platform data
Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
Add deinterlace frame rate double flags for ipu header file
The PHY register 0x9 and 0xe should setting
to different value in different board to pass HCT.
Add variable phy_reg_vlev and phy_reg_cksymtx to pass
phy config data.
Signed-off-by: Sandor Yu <R01008@freescale.com>
(cherry picked from commit 844aab72e7edcdced9f8e4e0d8e54eb4b0461cd9)
phy config data.
Add check before relase ASRC pair to prevent ASRC register operation
while clock is not enabled. The ASRC clock is disable while index is not
applied.
Signed-off-by: Chen Liangjun <b36089@freescale.com>
imx_3.0.35_android
arch/arm/mach-mx6/board-mx6q_sabresd.c
arch/arm/plat-mxc/cpufreq.c
This patch add device drvier for novatek touch screen driver.
This touch screen chip will be support because it have
more populary screen size.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
ASoC ESAI machine driver and pcm platform driver use the APIs from mxc_asrc.c,
but once ASRC is used as a loadable module, these files can't find the APIs
from this ko. In this patch, we use 'asrc_p2p_hook' to hook the APIs which will
be used in ASoC ESAI machine driver and pcm platform driver.
Signed-off-by: Ge Lei <b42127@freescale.com>
In this patch, add interface to modify ASRC input/output watermark.
arch/arm/plat-mxc/dvfs_core.c
drivers/input/keyboard/mpr121.c
include/linux/i2c/mpr.h
* Add csi_tx_addr, so it can override slave addr
for adv7280 tvin decoder device
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
To finish a buffer convert in ASRC, user should 1. prepare input buffer,
2. prepare output buffer 3. wait for output buffer's completion 4.wait
for input buffer's comletion. The flow make user application ugly.
In this patch, pack steps above to 1 stop: ASRC_CONVERT.
ASRC driver use DMA to transfer data from ASRC output FIFO to memory.
However, DMA way require the data number in ASRC output FIFO being larger
than watermark level. Thus a dma request can trigger a DMA burst. For
the last period of output data, its number is possiblely less than output
FIFO watermark level. In this case, the output DMA would pending for the
last period of output data until timeout.
In this patch:
1 divide expected output data length into 2 parts: DMA part
and poll part. Using DMA to get the DMA part data and poll mode to
get the poll part.
2 to prevent user from processing these 2 parts above, kernel
buffers would be untouchable. User application only need send its data
buffer address to driver instead of query the kernel buffer.
In the origin code, ASRC driver use cyclic way to process DMA task
transfering data to/from ASRC input/output FIFO. In this case, it is
necessary that user application should promise that the input buffer
flow is continuous. If not, there would be 0 data be inserted into data
flow. The output data would be noisy.
In this patch,
1 use scatter list instead of cyclic SDMA: with scatter list,
SDMA would stop when the applied scatter list nents are finished.
2 set stall bit for ASRC "memory->ASRC->memory" convert to stop
ASRC convert when input data is not send into ASRC input FIFO in time.
For ASRC's "memory -> ASRC -> memory" using, new driver would support
model below: user input one buffer into ASRC and an corresponding output
buffer would be poped out. There is no timing requirement between this
input buffer and next input buffer. Thus driver would not use the cyclic
way to config SDMA and scatterlist is used. buffer allocated by
dma_alloc_coherent() can't support scatterlist well.
In this patch, use kzalloc to allocate buffer to support scatterlist.
SDMA driver can't promise receive all output data generated. Cause when
the data in output FIFO is less than ASRC output FIFO watermark, there
would be no DMA request generated and thus no SDMA transfer would
happens.
In this patch, add work struct to support ASRC driver receive last part
of data in OUTPUT FIFO in polling way.
According to ASRC memory->ASRC->memory requirement, driver should
satisfy the feature below: user application would passed into one buffer
and waiting until the output buffer is generated. In this case, only one
buffer is on processing and it is no necessary to use the queue to do
the convert. What is worse, queue operation would make the ASRC driver
hard to understand and maintain.
In this patch, remove the queue operation in ASRC driver.
Revert "ENGR00224245 HDMI AUDIO: stop/start PCM while unplug,blank/plug,unblank"
This reverts commit f8dd4f6fea093e46a30d5e438baa33702f626372.
This patch is for pulse audio. which is not fit for Android.
Signed-off-by: b02247 <b02247@freescale.com>
There was a mpr121_touchkey.c driver already upstream,
the orignall driver by 2.6.35 kernel development
should be removed to avoid duplicate.
This reverts commit 3d6df22ad54a14bc8cebb7753c36f7b3cd811665.
The Vsync IRQ timestamp is needed to synchronize applications with
the actual Vsync event time.
Change the IOCTL from write to read.
Signed-off-by: Oliver Brown <oliver.brown@freescale.com>
Port 3.0.35 linux kernel to iMX53 SMD for Jellybean bringup.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
In the maxim 17135 driver, the power good is confirmed by the
power good GPIO polarity change when comparing the status at
the beginning of driver probe and display regulator enabled.
However, it is not reliable since the initial value of the GPIO
is not constant. Normally, it is 1 but it can be 0 after system reset
unexpectedly. Now, it is changed to POK bit checking in FAULT register.
Signed-off-by: Jack Lee <jack.lee@freescale.com>
arch/arm/configs/imx6s_updater_defconfig
arch/arm/include/asm/hardware/coresight.h
arch/arm/kernel/etm.c
arch/arm/mach-mx6/cpu_op-mx6.c
arch/arm/mach-mx6/mx6_suspend.S
arch/arm/mach-mx6/pm.c
arch/arm/mach-mx6/system.c
drivers/mfd/mxc-hdmi-core.c
drivers/power/sabresd_battery.c
include/linux/mfd/mxc-hdmi-core.h
- Added mxcfb_elcdif_register_mode function.
- Create video mode list, and check default video mode
with video mode list before setting.
- Adjust elcdif pixel clock setting, reconfig elcdif pixel
parent clock video pll, get more accurate pixel clock
according video mode.
- Added video mode dump function for debug
drivers/cpufreq/cpufreq_interactive.c
fs/proc/base.c
IC designer had clarified that 1P1 can be turned off if we do not need support
remote wakeup. So If there is no requirement for USB remote wake up, the 1P1
can be turn off. USB driver will support dynamically turn on(off) 1P1 during
system suspend. 1P1 will be turn on depend on USB wakeup is enabled.
add platform_1p1_on platform data in head file.
Signed-off-by: make shi <b15407@freescale.com>
Adding Atkinson's dithering alorism implementation into our EPDC
Driver with Y8->Y1 and Y8->Y4 supported. Two EPDC flags have been
added to support the features. EPDC_FLAG_USE_DITHERING_Y1 and
EPDC_FLAG_USE_DITHERING_Y4.
Signed-off-by: Daiyu Ko <dko@freescale.com>
When unplug, blank happens, HDMI audio can't play properly. So in
driver, audio pcm would be disconnected when event above happens.
However, pulse audio can't process disconnect event properly and if an
blank or unplug event happens, HDMI sink would lost and can't be back
again.
In this patch, instead of disconnecting audio PCM stream, triggering
stop audio pcm while unplug and blank, triggering start again while plug
and unblank if the audio pcm is triggerd stop in the unplug/blank event.
Add battery driver support for mx6sl_evk.
Signed-off-by: Rong Dian <b38775@freescale.com>
New NAND controllers can perform read/write via HW engines which don't expose
OOB data in their DMA mode. To reflect this, we should rework the nand_chip /
nand_ecc_ctrl interfaces that assume that drivers will always read/write OOB
data in the nand_chip.oob_poi buffer. A better interface includes a boolean
argument that explicitly tells the callee when OOB data is requested by the
calling layer (for reading/writing to/from nand_chip.oob_poi).
This patch adds the 'oob_required' parameter to each relevant {read,write}_page
interface; all 'oob_required' parameters are left unused for now. The next
patch will set the parameter properly in the nand_base.c callers, and follow-up
patches will make use of 'oob_required' in some of the callee functions.
Note that currently, there is no harm in ignoring the 'oob_required' parameter
and *always* utilizing nand_chip.oob_poi, but there can be
performance/complexity/design benefits from avoiding filling oob_poi in the
common case. I will try to implement this for some drivers which can be ported
easily.
Note: I couldn't compile-test all of these easily, as some had ARCH
dependencies.
[Huang Shijie: I remove the unused code for the other drivers.]
[dwmw2: Merge later 1/0 vs. true/false cleanup]
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Acked-by: Mike Dunn <mikedunn@newsguy.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
arch/arm/mach-mx6/board-mx6sl_arm2.c
arch/arm/mach-mx6/bus_freq.c
In this patch, add support for:
1. Interface for HDMI audio to register PCM into HDMI core driver.
2. Interface for HDMI video driver to stop HDMI audio
3. Interface for HDMI video driver to inform the state of HDMI cable and
state of HDMI blank.
Add the ability to register to received beacon frames
to allow implementing OLBC logic in userspace. The
registration is per wiphy since there's no point in
receiving the same frame multiple times.
