path: root/include
2013-06-20libceph: wrap auth methods in a mutexSage Weil
commit e9966076cdd952e19f2dd4854cd719be0d7cbebc upstream. The auth code is called from a variety of contexts, include the mon_client (protected by the monc's mutex) and the messenger callbacks (currently protected by nothing). Avoid chaos by protecting all auth state with a mutex. Nothing is blocking, so this should be simple and lightweight. Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20libceph: wrap auth ops in wrapper functionsSage Weil
commit 27859f9773e4a0b2042435b13400ee2c891a61f4 upstream. Use wrapper functions that check whether the auth op exists so that callers do not need a bunch of conditional checks. Simplifies the external interface. Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20libceph: add update_authorizer auth methodSage Weil
commit 0bed9b5c523d577378b6f83eab5835fe30c27208 upstream. Currently the messenger calls out to a get_authorizer con op, which will create a new authorizer if it doesn't yet have one. In the meantime, when we rotate our service keys, the authorizer doesn't get updated. Eventually it will be rejected by the server on a new connection attempt and get invalidated, and we will then rebuild a new authorizer, but this is not ideal. Instead, if we do have an authorizer, call a new update_authorizer op that will verify that the current authorizer is using the latest secret. If it is not, we will build a new one that does. This avoids the transient failure. This fixes one of the sorry sequence of events for bug http://tracker.ceph.com/issues/4282 Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20mm: migration: add migrate_entry_wait_huge()Naoya Horiguchi
commit 30dad30922ccc733cfdbfe232090cf674dc374dc upstream. When we have a page fault for the address which is backed by a hugepage under migration, the kernel can't wait correctly and do busy looping on hugepage fault until the migration finishes. As a result, users who try to kick hugepage migration (via soft offlining, for example) occasionally experience long delay or soft lockup. This is because pte_offset_map_lock() can't get a correct migration entry or a correct page table lock for hugepage. This patch introduces migration_entry_wait_huge() to solve this. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20CPU hotplug: provide a generic helper to disable/enable CPU hotplugSrivatsa S. Bhat
commit 16e53dbf10a2d7e228709a7286310e629ede5e45 upstream. There are instances in the kernel where we would like to disable CPU hotplug (from sysfs) during some important operation. Today the freezer code depends on this and the code to do it was kinda tailor-made for that. Restructure the code and make it generic enough to be useful for other usecases too. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20Bluetooth: Fix mgmt handling of power on failuresJohan Hedberg
commit 96570ffcca0b872dc8626e97569d2697f374d868 upstream. If hci_dev_open fails we need to ensure that the corresponding mgmt_set_powered command gets an appropriate response. This patch fixes the missing response by adding a new mgmt_set_powered_failed function that's used to indicate a power on failure to mgmt. Since a situation with the device being rfkilled may require special handling in user space the patch uses a new dedicated mgmt status code for this. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13ftrace: Move ftrace_filter_lseek out of CONFIG_DYNAMIC_FTRACE sectionSteven Rostedt
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream. As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the ftrace_pid_fops is defined when DYNAMIC_FTRACE is not. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Namhyung Kim <namhyung@kernel.org> [ lizf: adjust context ] Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13tracing: Fix possible NULL pointer dereferencesNamhyung Kim
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream. Currently set_ftrace_pid and set_graph_function files use seq_lseek for their fops. However seq_open() is called only for FMODE_READ in the fops->open() so that if an user tries to seek one of those file when she open it for writing, it sees NULL seq_file and then panic. It can be easily reproduced with following command: $ cd /sys/kernel/debug/tracing $ echo 1234 | sudo tee -a set_ftrace_pid In this example, GNU coreutils' tee opens the file with fopen(, "a") and then the fopen() internally calls lseek(). Link: http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> [ lizf: adjust context ] Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07wait: fix false timeouts when using wait_event_timeout()Imre Deak
commit 4c663cfc523a88d97a8309b04a089c27dc57fd7e upstream. Many callers of the wait_event_timeout() and wait_event_interruptible_timeout() expect that the return value will be positive if the specified condition becomes true before the timeout elapses. However, at the moment this isn't guaranteed. If the wake-up handler is delayed enough, the time remaining until timeout will be calculated as 0 - and passed back as a return value - even if the condition became true before the timeout has passed. Fix this by returning at least 1 if the condition becomes true. This semantic is in line with what wait_for_condition_timeout() does; see commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious failure under heavy load"). Daniel said "We have 3 instances of this bug in drm/i915. One case even where we switch between the interruptible and not interruptible wait_event_timeout variants, foolishly presuming they have the same semantics. I very much like this." One such bug is reported at https://bugs.freedesktop.org/show_bug.cgi?id=64133 Signed-off-by: Imre Deak <imre.deak@intel.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Dave Jones <davej@redhat.com> Cc: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19hugetlbfs: fix mmap failure in unaligned size requestNaoya Horiguchi
commit af73e4d9506d3b797509f3c030e7dcd554f7d9c4 upstream. The current kernel returns -EINVAL unless a given mmap length is "almost" hugepage aligned. This is because in sys_mmap_pgoff() the given length is passed to vm_mmap_pgoff() as it is without being aligned with hugepage boundary. This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix alignment of huge page requests"), where alignment code is pushed into hugetlb_file_setup() and the variable len in caller side is not changed. To fix this, this patch partially reverts that commit, and adds alignment code in caller side. And it also introduces hstate_sizelog() in order to get proper hstate to specified hugepage size. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881 [akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: <iceman_dvd@yahoo.com> Cc: Steven Truelove <steven.truelove@utoronto.ca> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ipv6: do not clear pinet6 fieldEric Dumazet
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ] We have seen multiple NULL dereferences in __inet6_lookup_established() After analysis, I found that inet6_sk() could be NULL while the check for sk_family == AF_INET6 was true. Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP and TCP stacks. Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash table, we no longer can clear pinet6 field. This patch extends logic used in commit fcbdf09d9652c891 ("net: fix nulls list corruptions in sk_prot_alloc") TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method to make sure we do not clear pinet6 field. At socket clone phase, we do not really care, as cloning the parent (non NULL) pinet6 is not adding a fatal race. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19macvlan: fix passthru mode race between dev removal and rx pathJiri Pirko
[ Upstream commit 233c7df0821c4190e2d3f4be0f2ca0ab40a5ed8c, note that I had to add list_first_or_null_rcu to rculist.h in order to accomodate this fix. ] Currently, if macvlan in passthru mode is created and data are rxed and you remove this device, following panic happens: NULL pointer dereference at 0000000000000198 IP: [<ffffffffa0196058>] macvlan_handle_frame+0x153/0x1f7 [macvlan] I'm using following script to trigger this: <script> while [ 1 ] do ip link add link e1 name macvtap0 type macvtap mode passthru ip link set e1 up ip link set macvtap0 up IFINDEX=`ip link |grep macvtap0 | cut -f 1 -d ':'` cat /dev/tap$IFINDEX >/dev/null & ip link del dev macvtap0 done </script> I run this script while "ping -f" is running on another machine to send packets to e1 rx. Reason of the panic is that list_first_entry() is blindly called in macvlan_handle_frame() even if the list was empty. vlan is set to incorrect pointer which leads to the crash. I'm fixing this by protecting port->vlans list by rcu and by preventing from getting incorrect pointer in case the list is empty. Introduced by: commit eb06acdc85585f2 "macvlan: Introduce 'passthru' mode to takeover the underlying device" Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19if_cablemodem.h: Add parenthesis around ioctl macrosJosh Boyer
[ Upstream commit 4f924b2aa4d3cb30f07e57d6b608838edcbc0d88 ] Protect the SIOCGCM* ioctl macros with parenthesis. Reported-by: Paul Wouters <pwouters@redhat.com> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19tcp: force a dst refcount when prequeue packetEric Dumazet
[ Upstream commit 093162553c33e9479283e107b4431378271c735d ] Before escaping RCU protected section and adding packet into prequeue, make sure the dst is refcounted. Reported-by: Mike Galbraith <bitbucket@online.de> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19audit: Syscall rules are not applied to existing processes on non-x86Anton Blanchard
commit cdee3904b4ce7c03d1013ed6dd704b43ae7fc2e9 upstream. Commit b05d8447e782 (audit: inline audit_syscall_entry to reduce burden on archs) changed audit_syscall_entry to check for a dummy context before calling __audit_syscall_entry. Unfortunately the dummy context state is maintained in __audit_syscall_entry so once set it never gets cleared, even if the audit rules change. As a result, if there are no auditing rules when a process starts then it will never be subject to any rules added later. x86 doesn't see this because it has an assembly fast path that calls directly into __audit_syscall_entry. I noticed this issue when working on audit performance optimisations. I wrote a set of simple test cases available at: http://ozlabs.org/~anton/junkcode/audit_tests.tar.gz 02_new_rule.py fails without the patch and passes with it. The test case clears all rules, starts a process, adds a rule then verifies the process produces a syscall audit record. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: add new richland pci idsAlex Deucher
commit 62d1f92e06aef9665d71ca7e986b3047ecf0b3c7 upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: add some new SI PCI idsAlex Deucher
commit 18932a28419596bc9403770f5d8a108c5433fe59 upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07jbd2: fix race between jbd2_journal_remove_checkpoint and ->j_commit_callbackDmitry Monakhov
commit 794446c6946513c684d448205fbd76fa35f38b72 upstream. The following race is possible: [kjournald2] other_task jbd2_journal_commit_transaction() j_state = T_FINISHED; spin_unlock(&journal->j_list_lock); ->jbd2_journal_remove_checkpoint() ->jbd2_journal_free_transaction(); ->kmem_cache_free(transaction) ->j_commit_callback(journal, transaction); -> USE_AFTER_FREE WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250() Hardware name: list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107 Call Trace: [<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0 [<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0 [<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250 [<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0 [<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570 [<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0 [<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0 [<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0 [<ffffffff810ad630>] ? wake_up_bit+0x40/0x40 [<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80 [<ffffffff810ac6be>] kthread+0x10e/0x120 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 [<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 In order to demonstrace this issue one should mount ext4 with mount -o discard option on SSD disk. This makes callback longer and race window becomes wider. In order to fix this we should mark transaction as finished only after callbacks have completed Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ipc: sysv shared memory limited to 8TiBRobin Holt
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream. Trying to run an application which was trying to put data into half of memory using shmget(), we found that having a shmall value below 8EiB-8TiB would prevent us from using anything more than 8TiB. By setting kernel.shmall greater than 8EiB-8TiB would make the job work. In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX. ipc/shm.c: 458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params) 459 { ... 465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT; ... 474 if (ns->shm_tot + numpages > ns->shm_ctlall) 475 return -ENOSPC; [akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int] Signed-off-by: Robin Holt <holt@sgi.com> Reported-by: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07mm: allow arch code to control the user page table ceilingHugh Dickins
commit 6ee8630e02be6dd89926ca0fbc21af68b23dc087 upstream. On architectures where a pgd entry may be shared between user and kernel (e.g. ARM+LPAE), freeing page tables needs a ceiling other than 0. This patch introduces a generic USER_PGTABLES_CEILING that arch code can override. It is the responsibility of the arch code setting the ceiling to ensure the complete freeing of the page tables (usually in pgd_free()). [catalin.marinas@arm.com: commit log; shift_arg_pages(), asm-generic/pgtables.h changes] Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01net: fix incorrect credentials passingLinus Torvalds
[ Upstream commit 83f1b4ba917db5dc5a061a44b3403ddb6e783494 ] Commit 257b5358b32f ("scm: Capture the full credentials of the scm sender") changed the credentials passing code to pass in the effective uid/gid instead of the real uid/gid. Obviously this doesn't matter most of the time (since normally they are the same), but it results in differences for suid binaries when the wrong uid/gid ends up being used. This just undoes that (presumably unintentional) part of the commit. Reported-by: Andy Lutomirski <luto@amacapital.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serge@hallyn.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01netfilter: don't reset nf_trace in nf_reset()Patrick McHardy
[ Upstream commit 124dff01afbdbff251f0385beca84ba1b9adda68 ] Commit 130549fe ("netfilter: reset nf_trace in nf_reset") added code to reset nf_trace in nf_reset(). This is wrong and unnecessary. nf_reset() is used in the following cases: - when passing packets up the the socket layer, at which point we want to release all netfilter references that might keep modules pinned while the packet is queued. nf_trace doesn't matter anymore at this point. - when encapsulating or decapsulating IPsec packets. We want to continue tracing these packets after IPsec processing. - when passing packets through virtual network devices. Only devices on that encapsulate in IPv4/v6 matter since otherwise nf_trace is not used anymore. Its not entirely clear whether those packets should be traced after that, however we've always done that. - when passing packets through virtual network devices that make the packet cross network namespace boundaries. This is the only cases where we clearly want to reset nf_trace and is also what the original patch intended to fix. Add a new function nf_reset_trace() and use it in dev_forward_skb() to fix this properly. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01net: count hw_addr syncs so that unsync works properly.Vlad Yasevich
[ Upstream commit 4543fbefe6e06a9e40d9f2b28d688393a299f079 ] A few drivers use dev_uc_sync/unsync to synchronize the address lists from master down to slave/lower devices. In some cases (bond/team) a single address list is synched down to multiple devices. At the time of unsync, we have a leak in these lower devices, because "synced" is treated as a boolean and the address will not be unsynced for anything after the first device/call. Treat "synced" as a count (same as refcount) and allow all unsync calls to work. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25vm: add vm_iomap_memory() helper functionLinus Torvalds
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e upstream. Various drivers end up replicating the code to mmap() their memory buffers into user space, and our core memory remapping function may be very flexible but it is unnecessarily complicated for the common cases to use. Our internal VM uses pfn's ("page frame numbers") which simplifies things for the VM, and allows us to pass physical addresses around in a denser and more efficient format than passing a "phys_addr_t" around, and having to shift it up and down by the page size. But it just means that drivers end up doing that shifting instead at the interface level. It also means that drivers end up mucking around with internal VM things like the vma details (vm_pgoff, vm_start/end) way more than they really need to. So this just exports a function to map a certain physical memory range into user space (using a phys_addr_t based interface that is much more natural for a driver) and hides all the complexity from the driver. Some drivers will still end up tweaking the vm_page_prot details for things like prefetching or cacheability etc, but that's actually relevant to the driver, rather than caring about what the page offset of the mapping is into the particular IO memory region. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-25ssb: implement spurious tone avoidanceRafał Miłecki
commit 46fc4c909339f5a84d1679045297d9d2fb596987 upstream. And make use of it in b43. This fixes a regression introduced with 49d55cef5b1925a5c1efb6aaddaa40fc7c693335 b43: N-PHY: implement spurious tone avoidance This commit made BCM4322 use only MCS 0 on channel 13, which of course resulted in performance drop (down to 0.7Mb/s). Reported-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25KVM: Allow cross page reads and writes from cached translations.Andrew Honig
commit 8f964525a121f2ff2df948dac908dcc65be21b5b upstream. This patch adds support for kvm_gfn_to_hva_cache_init functions for reads and writes that will cross a page. If the range falls within the same memslot, then this will be a fast operation. If the range is split between two memslots, then the slower kvm_read_guest and kvm_write_guest are used. Tested: Test against kvm_clock unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16kref: Implement kref_get_unless_zero v3Thomas Hellstrom
commit 4b20db3de8dab005b07c74161cb041db8c5ff3a7 upstream. This function is intended to simplify locking around refcounting for objects that can be looked up from a lookup structure, and which are removed from that lookup structure in the object destructor. Operations on such objects require at least a read lock around lookup + kref_get, and a write lock around kref_put + remove from lookup structure. Furthermore, RCU implementations become extremely tricky. With a lookup followed by a kref_get_unless_zero *with return value check* locking in the kref_put path can be deferred to the actual removal from the lookup structure and RCU lookups become trivial. v2: Formatting fixes. v3: Invert the return value. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12spinlocks and preemption points need to be at least compiler barriersLinus Torvalds
commit 386afc91144b36b42117b0092893f15bc8798a80 upstream. In UP and non-preempt respectively, the spinlocks and preemption disable/enable points are stubbed out entirely, because there is no regular code that can ever hit the kind of concurrency they are meant to protect against. However, while there is no regular code that can cause scheduling, we _do_ end up having some exceptional (literally!) code that can do so, and that we need to make sure does not ever get moved into the critical region by the compiler. In particular, get_user() and put_user() is generally implemented as inline asm statements (even if the inline asm may then make a call instruction to call out-of-line), and can obviously cause a page fault and IO as a result. If that inline asm has been scheduled into the middle of a preemption-safe (or spinlock-protected) code region, we obviously lose. Now, admittedly this is *very* unlikely to actually ever happen, and we've not seen examples of actual bugs related to this. But partly exactly because it's so hard to trigger and the resulting bug is so subtle, we should be extra careful to get this right. So make sure that even when preemption is disabled, and we don't have to generate any actual *code* to explicitly tell the system that we are in a preemption-disabled region, we need to at least tell the compiler not to move things around the critical region. This patch grew out of the same discussion that caused commits 79e5f05edcbf ("ARC: Add implicit compiler barrier to raw_local_irq* functions") and 3e2e0d2c222b ("tile: comment assumption about __insn_mtspr for <asm/irqflags.h>") to come about. Note for stable: use discretion when/if applying this. As mentioned, this bug may never have actually bitten anybody, and gcc may never have done the required code motion for it to possibly ever trigger in practice. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12libata: Set max sector to 65535 for Slimtype DVD A DS8A8SH driveShan Hai
commit a32450e127fc6e5ca6d958ceb3cfea4d30a00846 upstream. The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than 65535, and the blow backtrace is observed on locking up: INFO: task flush-8:32:1130 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000 ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000 ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000 ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000 Call Trace: [<ffffffff8168fc2d>] schedule+0x5d/0x70 [<ffffffff8168fccc>] io_schedule+0x8c/0xd0 [<ffffffff81324461>] get_request+0x731/0x7d0 [<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90 [<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40 [<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110 [<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0 [<ffffffff81322176>] generic_make_request+0xc6/0x120 [<ffffffff81322308>] submit_bio+0x138/0x160 [<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120 [<ffffffff811d1f61>] submit_bh+0x1f1/0x220 [<ffffffff811d48b8>] __block_write_full_page+0x228/0x340 [<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100 [<ffffffff811d4ae5>] block_write_full_page+0x15/0x20 [<ffffffff811d9268>] blkdev_writepage+0x18/0x20 [<ffffffff81142527>] __writepage+0x17/0x40 [<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0 [<ffffffff81142510>] ? set_page_dirty+0x70/0x70 [<ffffffff81143a61>] generic_writepages+0x51/0x80 [<ffffffff81143ab0>] do_writepages+0x20/0x50 [<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0 [<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0 [<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0 [<ffffffff811cad43>] wb_writeback+0x1a3/0x330 [<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50 [<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70 [<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260 [<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240 [<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0 [<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260 [<ffffffff81083550>] kthread+0xc0/0xd0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 [<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 The above trace was triggered by "dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768" It was previously working by accident, since another bug introduced by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused all drives to use maxsect=65535. Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12libata: Use integer return value for atapi_command_packet_setShan Hai
commit d8668fcb0b257d9fdcfbe5c172a99b8d85e1cd82 upstream. The function returns type of ATAPI drives so it should return integer value. The commit 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) since v2.6.39 changed the type of return value from int to bool, the change would cause all of the ATAPI class drives to be treated as TYPE_TAPE and the max_sectors of the drives to be set to 65535 because of the commit f8d8e5799b7(libata: increase 128 KB / cmd limit for ATAPI tape drives), for the function would return true for all ATAPI class drives and the TYPE_TAPE is defined as 0x01. Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05net: fix *_DIAG_MAX constantsAndrey Vagin
[ Upstream commit ae5fc98728c8bbbd6d7cab0b9781671fc4419c1b ] Follow the common pattern and define *_DIAG_MAX like: [...] __XXX_DIAG_MAX, }; Because everyone is used to do: struct nlattr *attrs[XXX_DIAG_MAX+1]; nla_parse([...], XXX_DIAG_MAX, [...] Reported-by: Thomas Graf <tgraf@suug.ch> Cc: "David S. Miller" <davem@davemloft.net> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Eric Dumazet <edumazet@google.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05thermal: shorten too long mcast group nameMasatake YAMATO
[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter adds an assertion to genetlink to prevent this from happening again in the future. ] The original name is too long. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05xen/blkback: correctly respond to unknown, non-native requestsDavid Vrabel
commit 0e367ae46503cfe7791460c8ba8434a5d60b2bd5 upstream. If the frontend is using a non-native protocol (e.g., a 64-bit frontend with a 32-bit backend) and it sent an unrecognized request, the request was not translated and the response would have the incorrect ID. This may cause the frontend driver to behave incorrectly or crash. Since the ID field in the request is always in the same place, regardless of the request type we can get the correct ID and make a valid response (which will report BLKIF_RSP_EOPNOTSUPP). This bug affected 64-bit SLES 11 guests when using a 32-bit backend. This guest does a BLKIF_OP_RESERVED_1 (BLKIF_OP_PACKET in the SLES source) and would crash in blkif_int() as the ID in the response would be invalid. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05signal: Define __ARCH_HAS_SA_RESTORER so we know whether to clear sa_restorerBen Hutchings
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side struct sigaction declarations'. flush_signal_handlers() needs to know whether sigaction::sa_restorer is defined, not whether SA_RESTORER is defined. Define the __ARCH_HAS_SA_RESTORER macro to indicate this. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28exec: use -ELOOP for max recursion depthKees Cook
commit d740269867021faf4ce38a449353d2b986c34a67 upstream. To avoid an explosion of request_module calls on a chain of abusive scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon as maximum recursion depth is hit, the error will fail all the way back up the chain, aborting immediately. This also has the side-effect of stopping the user's shell from attempting to reexecute the top-level file as a shell script. As seen in the dash source: if (cmd != path_bshell && errno == ENOEXEC) { *argv-- = cmd; *argv = cmd = path_bshell; goto repeat; } The above logic was designed for running scripts automatically that lacked the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC, things continue to behave as the shell expects. Additionally, when tracking recursion, the binfmt handlers should not be involved. The recursion being tracked is the depth of calls through search_binary_handler(), so that function should be exclusively responsible for tracking the depth. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: halfdog <me@halfdog.net> Cc: P J P <ppandit@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28drm/radeon: add Richland pci idsAlex Deucher
commit b75bbaa038ffc426e88ea3df6c4ae11834fc3e4f upstream. Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28inet: limit length of fragment queue hash table bucket listsHannes Frederic Sowa
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ] This patch introduces a constant limit of the fragment queue hash table bucket list lengths. Currently the limit 128 is choosen somewhat arbitrary and just ensures that we can fill up the fragment cache with empty packets up to the default ip_frag_high_thresh limits. It should just protect from list iteration eating considerable amounts of cpu. If we reach the maximum length in one hash bucket a warning is printed. This is implemented on the caller side of inet_frag_find to distinguish between the different users of inet_fragment.c. I dropped the out of memory warning in the ipv4 fragment lookup path, because we already get a warning by the slab allocator. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28tcp: fix skb_availroom()Eric Dumazet
[ Upstream commit 16fad69cfe4adbbfa813de516757b87bcae36d93 ] Chrome OS team reported a crash on a Pixel ChromeBook in TCP stack : https://code.google.com/p/chromium/issues/detail?id=182056 commit a21d45726acac (tcp: avoid order-1 allocations on wifi and tx path) did a poor choice adding an 'avail_size' field to skb, while what we really needed was a 'reserved_tailroom' one. It would have avoided commit 22b4a4f22da (tcp: fix retransmit of partially acked frames) and this commit. Crash occurs because skb_split() is not aware of the 'avail_size' management (and should not be aware) Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Mukesh Agrawal <quiche@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28ipv4: fix definition of FIB_TABLE_HASHSZDenis V. Lunev
[ Upstream commit 5b9e12dbf92b441b37136ea71dac59f05f2673a9 ] a long time ago by the commit commit 93456b6d7753def8760b423ac6b986eb9d5a4a95 Author: Denis V. Lunev <den@openvz.org> Date: Thu Jan 10 03:23:38 2008 -0800 [IPV4]: Unify access to the routing tables. the defenition of FIB_HASH_TABLE size has obtained wrong dependency: it should depend upon CONFIG_IP_MULTIPLE_TABLES (as was in the original code) but it was depended from CONFIG_IP_ROUTE_MULTIPATH This patch returns the situation to the original state. The problem was spotted by Tingwei Liu. Signed-off-by: Denis V. Lunev <den@openvz.org> CC: Tingwei Liu <tingw.liu@gmail.com> CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20atmel_lcdfb: fix 16-bpp modes on older SOCsJohan Hovold
commit a79eac7165ed62114e6ca197195aa5060a54f137 upstream. Fix regression introduced by commit 787f9fd23283 ("atmel_lcdfb: support 16bit BGR:565 mode, remove unsupported 15bit modes") which broke 16-bpp modes for older SOCs which use IBGR:555 (msb is intensity) rather than BGR:565. Use SOC-type to determine the pixel layout. Tested on at91sam9263 and at91sam9g45. Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20perf,x86: fix link failure for non-Intel configsDavid Rientjes
commit 6c4d3bc99b3341067775efd4d9d13cc8e655fd7c upstream. Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after suspend/resume") introduces a link failure since perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL: arch/x86/power/built-in.o: In function `restore_processor_state': (.text+0x45c): undefined reference to `perf_restore_debug_store' Fix it by defining the dummy function appropriately. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20perf,x86: fix kernel crash with PEBS/BTS after suspend/resumeStephane Eranian
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream. This patch fixes a kernel crash when using precise sampling (PEBS) after a suspend/resume. Turns out the CPU notifier code is not invoked on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly by the kernel and keeps it power-on/resume value of 0 causing any PEBS measurement to crash when running on CPU0. The workaround is to add a hook in the actual resume code to restore the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0, the DS_AREA will be restored twice but this is harmless. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04pstore: Avoid deadlock in panic and emergency-restart pathSeiji Aguchi
commit 9f244e9cfd70c7c0f82d3c92ce772ab2a92d9f64 upstream. [Issue] When pstore is in panic and emergency-restart paths, it may be blocked in those paths because it simply takes spin_lock. This is an example scenario which pstore may hang up in a panic path: - cpuA grabs psinfo->buf_lock - cpuB panics and calls smp_send_stop - smp_send_stop sends IRQ to cpuA - after 1 second, cpuB gives up on cpuA and sends an NMI instead - cpuA is now in an NMI handler while still holding buf_lock - cpuB is deadlocked This case may happen if a firmware has a bug and cpuA is stuck talking with it more than one second. Also, this is a similar scenario in an emergency-restart path: - cpuA grabs psinfo->buf_lock and stucks in a firmware - cpuB kicks emergency-restart via either sysrq-b or hangcheck timer. And then, cpuB is deadlocked by taking psinfo->buf_lock again. [Solution] This patch avoids the deadlocking issues in both panic and emergency_restart paths by introducing a function, is_non_blocking_path(), to check if a cpu can be blocked in current path. With this patch, pstore is not blocked even if another cpu has taken a spin_lock, in those paths by changing from spin_lock_irqsave to spin_trylock_irqsave. In addition, according to a comment of emergency_restart() in kernel/sys.c, spin_lock shouldn't be taken in an emergency_restart path to avoid deadlock. This patch fits the comment below. <snip> /** * emergency_restart - reboot the system * * Without shutting down any hardware or taking any locks * reboot the system. This is called when we know we are in * trouble so this is our best effort to reboot. This is * safe to call in interrupt context. */ void emergency_restart(void) <snip> Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04unbreak automounter support on 64-bit kernel with 32-bit userspace (v2)Helge Deller
commit 4f4ffc3a5398ef9bdbb32db04756d7d34e356fcf upstream. automount-support is broken on the parisc architecture, because the existing #if list does not include a check for defined(__hppa__). The HPPA (parisc) architecture is similiar to other 64bit Linux targets where we have to define autofs_wqt_t (which is passed back and forth to user space) as int type which has a size of 32bit across 32 and 64bit kernels. During the discussion on the mailing list, H. Peter Anvin suggested to invert the #if list since only specific platforms (specifically those who do not have a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned long type. This suggestion is probably the best way to go, since Arm64 (and maybe others?) seems to have a non-working automounter. So in the long run even for other new upcoming architectures this inverted check seem to be the best solution, since it will not require them to change this #if again (unless they are 64bit only). Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Ian Kent <raven@themaw.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> CC: James Bottomley <James.Bottomley@HansenPartnership.com> CC: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04quota: autoload the quota_v2 module for QFMT_VFS_V1 quota formatTheodore Ts'o
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream. Otherwise, ext4 file systems with the quota featured enable will get a very confusing "No such process" error message if the quota code is built as a module and the quota_v2 module has not been loaded. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28vlan: adjust vlan_set_encap_proto() for its callersCong Wang
[ Upstream commit da8c87241c26aac81a64c7e4d21d438a33018f4e ] There are two places to call vlan_set_encap_proto(): vlan_untag() and __pop_vlan_tci(). vlan_untag() assumes skb->data points after mac addr, otherwise the following code vhdr = (struct vlan_hdr *) skb->data; vlan_tci = ntohs(vhdr->h_vlan_TCI); __vlan_hwaccel_put_tag(skb, vlan_tci); skb_pull_rcsum(skb, VLAN_HLEN); won't be correct. But __pop_vlan_tci() assumes points _before_ mac addr. In vlan_set_encap_proto(), it looks for some magic L2 value after mac addr: rawp = skb->data; if (*(unsigned short *) rawp == 0xFFFF) ... Therefore __pop_vlan_tci() is obviously wrong. A quick fix is avoiding using skb->data in vlan_set_encap_proto(), use 'vhdr+1' is always correct in both cases. Signed-off-by: Cong Wang <amwang@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ipv6: use a stronger hash for tcpEric Dumazet
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ] It looks like its possible to open thousands of TCP IPv6 sessions on a server, all landing in a single slot of TCP hash table. Incoming packets have to lookup sockets in a very long list. We should hash all bits from foreign IPv6 addresses, using a salt and hash mix, not a simple XOR. inet6_ehashfn() can also separately use the ports, instead of xoring them. Reported-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28net: fix a compile error when SOCK_REFCNT_DEBUG is enabledYing Xue
[ Upstream commit dec34fb0f5b7873de45132a84a3af29e61084a6b ] When SOCK_REFCNT_DEBUG is enabled, below build error is met: kernel/sysctl_binary.o: In function `sk_refcnt_debug_release': include/net/sock.h:1025: multiple definition of `sk_refcnt_debug_release' kernel/sysctl.o:include/net/sock.h:1025: first defined here kernel/audit.o: In function `sk_refcnt_debug_release': include/net/sock.h:1025: multiple definition of `sk_refcnt_debug_release' kernel/sysctl.o:include/net/sock.h:1025: first defined here make[1]: *** [kernel/built-in.o] Error 1 make: *** [kernel] Error 2 So we decide to make sk_refcnt_debug_release static to eliminate the error. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: Yet another band-aid for fixing lockdep messTakashi Iwai
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream. I've still got lockdep warnings even after Alan's patch, and it seems that yet more band aids are required to paper over similar paths for unbind_con_driver() and unregister_con_driver(). After this hack, lockdep warnings are finally gone. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: rework locking to fix lock ordering on takeoverAlan Cox
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream. Adjust the console layer to allow a take over call where the caller already holds the locks. Make the fb layer lock in order. This is partly a band aid, the fb layer is terminally confused about the locking rules it uses for its notifiers it seems. [akpm@linux-foundation.org: remove stray non-ascii char, tidy comment] [akpm@linux-foundation.org: export do_take_over_console()] [airlied: cleanup another non-ascii char] Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
