The comment introduced with the recently added pinctrl_gpio_range.pins
element was wrong. This corrects it.
Thanks to Patrice Chotard for pointing this out.
Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com>
The stubs for the !PINCTRL case were placed in the wrong
part of the file, causing breakage in linux-next when compiling
SH without pinctrl. Fix it up by moving the stubs to the right
place.
Traditionally, GPIO ranges are based on consecutive ranges of both GPIO
and pin numbers. This patch allows for GPIO ranges with arbitrary lists
of pin numbers.
This driver adds support the Cortex-A9 based SoCs from Rockchip,
so at least the RK2928, RK3066 (a and b) and RK3188.
Earlier Rockchip SoCs seem to use similar mechanics for gpio
handling so should be supportable with relative small changes.
Pull handling on the rk3188 is currently a stub, due to it being
a bit different to the earlier SoCs.
Pinmuxing as well as gpio (and interrupt-) handling tested on
a rk3066a based machine.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
If a device have sleep and idle states in addition to the
default state, look up these in the core and stash them in
the pinctrl state container.
Add accessor functions for pinctrl consumers to put the pins
into "default", "sleep" and "idle" states passing nothing but
the struct device * affected.
Solution suggested by Kevin Hilman, Mark Brown and Dmitry
Torokhov in response to a patch series from Hebbar
Gururaja.
Cc: Hebbar Gururaja <gururaja.hebbar@ti.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Mark Brown <broonie@kernel.org>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
There exist controllers that don't support to set the pull to up or down
separately but instead automatically set the pull direction based on
embedded knowledge inside the controller, for example depending on the
selected mux function of the pin.
Therefore this patch adds another config option to use this default
pull-state for a pin where it is not possible to know or decide if the
pin will be pulled up or down.
Add a new PIN_CONFIG_BIAS_BUS_HOLD pin configuration for a bus holder
pin mode (also known as bus keeper, or repeater). This is a weak latch
which drives the last value on a tristate bus. Another device on the bus
can drive the bus high or low before going tristate to change the value
driven by the pin.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing fixes from Steven Rostedt:
"This contains 4 fixes.
The first two fix the case where full RCU debugging is enabled,
enabling function tracing causes a live lock of the system. This is
due to the added debug checks in rcu_dereference_raw() that is used by
the function tracer. These checks are also traced by the function
tracer as well as cause enough overhead to the function tracer to slow
down the system enough that the time to finish an interrupt can take
longer than when the next interrupt is triggered, causing a live lock
from the timer interrupt.
Talking this over with Paul McKenney, we came up with a fix that adds
a new rcu_dereference_raw_notrace() that does not perform these added
checks, and let the function tracer use that.
The third commit fixes a failed compile when branch tracing is
enabled, due to the conversion of the trace_test_buffer() selftest
that the branch trace wasn't converted for.
The forth patch fixes a bug caught by the RCU lockdep code where a
rcu_read_lock() is performed when rcu is disabled (either going to or
from idle, or user space). This happened on the irqsoff tracer as it
calls task_uid(). The fix here was to use current_uid() when possible
that doesn't use rcu locking. Which luckily, is always used when
irqsoff calls this code."
* tag 'trace-fixes-v3.10-rc3-v3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Use current_uid() for critical time tracing
tracing: Fix bad parameter passed in branch selftest
ftrace: Use the rcu _notrace variants for rcu_dereference_raw() and friends
rcu: Add _notrace variation of rcu_dereference_raw() and hlist_for_each_entry_rcu()
Pull networking fix from David Miller:
"This is a quick one commit pull request to cure the regression
introduced by the MSG_CMSG_COMPAT change."
(Background: commit 1be374a0518a completely broke 32-bit COMPAT handling
by not only disallowing MSG_CMSG_COMPAT from user APIs, but clearing it
in our own internal use too!)
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Unbreak compat_sys_{send,recv}msg
I broke them in this commit:
commit 1be374a0518a288147c6a7398792583200a67261
Author: Andy Lutomirski <luto@amacapital.net>
Date: Wed May 22 14:07:44 2013 -0700
net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg
This patch adds __sys_sendmsg and __sys_sendmsg as common helpers that accept
MSG_CMSG_COMPAT and blocks MSG_CMSG_COMPAT at the syscall entrypoints. It
also reverts some unnecessary checks in sys_socketcall.
Apparently I was suffering from underscore blindness the first time around.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Tested-by: Eric Dumazet <edumazet@google.com>
Since the introduction of preemptible mmu_gather TLB fast mode has been
broken. TLB fast mode relies on there being absolutely no concurrency;
it frees pages first and invalidates TLBs later.
However now we can get concurrency and stuff goes *bang*.
This patch removes all tlb_fast_mode() code; it was found the better
option vs trying to patch the hole by entangling tlb invalidation with
the scheduler.
Reported-by: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Pull networking fixes from David Miller:
1) Fix timeouts with direct mode authentication in mac80211, from
Stanislaw Gruszka.
2) Aggregation sessions can deadlock in ath9k, from Felix Fietkau.
3) Netfilter's xt_addrtype doesn't work with ipv6 due to route lookups
creating undesirable cache entries, from Florian Westphal.
4) Fix netfilter's ipt_ULOG from generating non-NULL terminated
strings.
5) Fix netdev transmit queue crashes in mac80211, from Johannes Berg.
6) Fix copy and paste error in 802.11 stack that broke reporting of
64-bit station tx statistics, from Felix Fietkau.
7) When qlge_probe fails, it leaks the netdev. Fix from Wei Yongjun.
8) SKB control block (where we store the IP options information,
amongst other things) must be cleared properly otherwise ICMP
sending can crash for IP tunnels. Fix from Eric Dumazet.
9) Verification of Energy Efficient Ether support was coded wrongly,
the test was inversed. Fix from Giuseppe CAVALLARO.
10) TCP handles redirects improperly because the wrong flow key is used
for the route lookup. From Michal Kubecek.
11) Don't interpret MSG_CMSG_COMPAT from userspace, fix from Andy
Lutomirski.
12) The new AF_VSOCK was missing from the lockdep string table, fix from
Federico Vaga.
13) be2net doesn't handle checksumming of IP fragments properly, from
Somnath Kotur.
14) Fix several bugs in the device address list code that lead to
crashes and other misbehaviors. From Jay Vosburgh.
15) Fix ipv6 segmentation handling of fragmented GRE tunnel traffic,
from Pravin B Shalr.
16) Fix usage of stale policies in IPSEC layer, from Paul Moore.
17) Fix team driver dump of ports when there are a large number of them,
from Jiri Pirko.
18) Fix softlockups in UDP ipv4 socket lookup causes by and error in the
hlist_nulls_for_each_entry_rcu() macro. From Eric Dumazet.
19) Fix several regressions added by the high rate accuracy changes to
the htb packet scheduler. From Eric Dumazet.
20) Fix DMA'ing onto the stack in esd_usb2 and peak_usb CAN drivers,
from Olivier Sobrie and Marc Kleine-Budde.
21) Fix unremovable network devices due to missing route pointer
installation in the per-device ipv6 address list entries. From Gao
feng.
22) Apply the tg3 5719 DMA workaround on 5720 chips as well, otherwise
we get stalls. From Nithin Sujir.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (68 commits)
net_sched: htb: do not mix 1ns and 64ns time units
net: fix sk_buff head without data area
tg3: Add read dma workaround for 5720
net: ethernet: xilinx_emaclite: set protocol selector bits when writing ANAR
bnx2x: Fix bridged GSO for 57710/57711 chips
net: fec: add fallback to random MAC address
bnx2x: fix TCP offload for tunneling ipv4 over ipv6
ipv6: assign rt6_info to inet6_ifaddr in init_loopback
net/mlx4_core: Keep VF assigned MAC in the PF admin table
net/mlx4_en: Handle unassigned VF MAC address correctly
net/mlx4_core: Return -EPROBE_DEFER when a VF is probed before PF is sufficiently initialized
net/mlx4_en: Fix adaptive moderation cq update
net: can: peak_usb: Do not do dma on the stack
net: can: esd_usb2: Do not do dma on the stack
net: can: kvaser_usb: fix reception on "USBcan Pro" and "USBcan R" type hardware.
net_sched: restore "overhead xxx" handling
net: force a reload of first item in hlist_nulls_for_each_entry_rcu
hyperv: Fix vlan_proto setting in netvsc_recv_callback()
team: fix port list dump for big number of ports
list: introduce list_first_entry_or_null
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"Recent bug fixes, one of them touches a common code file.
It adds two #ifndef/#endif pairs to asm-generic/io.h to be able to
override xlate_dev_kmem_ptr and xlate_dev_mem_ptr."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/pgtable: Fix gmap notifier address
s390/dasd: fix handling of gone paths
s390/pgtable: Fix check for pgste/storage key handling
arch: s390: appldata: using strncpy() and strnlen() instead of sprintf()
s390/smp: lost IPIs on cpu hotplug
kernel: Fix s390 absolute memory access for /dev/mem
s390/dma: do not call debug_dma after free
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
- Fix for yet another xattr bug which may lead to NULL deref.
- A subtle bug in for_each_descendant_pre(). This bug requires quite
specific conditions to trigger and isn't too likely to actually
happen in the wild, but maybe that just makes it that much more
nastier.
- A warning message added for silly cgroup re-mount (not -o remount,
but unmount followed by mount) behavior.
* 'for-3.10-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: warn about mismatching options of a new mount of an existing hierarchy
cgroup: fix a subtle bug in descendant pre-order walk
cgroup: initialize xattr before calling d_instantiate()
commit 56b765b79 ("htb: improved accuracy at high rates")
broke the "overhead xxx" handling, as well as the "linklayer atm"
attribute.
tc class add ... htb rate X ceil Y linklayer atm overhead 10
This patch restores the "overhead xxx" handling, for htb, tbf
and act_police
The "linklayer atm" thing needs a separate fix.
Reported-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Vimalkumar <j.vimal@gmail.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Roman Gushchin discovered that udp4_lib_lookup2() was not reloading
first item in the rcu protected list, in case the loop was restarted.
This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37
rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is
ptr->field :
In some cases, gcc caches the value or ptr->field in a register.
Use a barrier() to disallow such caching, as documented in
Documentation/atomic_ops.txt line 114
Thanks a lot to Roman for providing analysis and numerous patches.
Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru>
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Pull scsi target fixes from Nicholas Bellinger:
"The highlights include:
- Re-instate sess->wait_list in target_wait_for_sess_cmds() for
active I/O shutdown handling in fabrics using se_cmd->cmd_kref
- Make ib_srpt call target_sess_cmd_list_set_waiting() during session
shutdown
- Fix FILEIO off-by-one READ_CAPACITY bug for !S_ISBLK export
- Fix iscsi-target login error heap buffer overflow (Kees)
- Fix iscsi-target active I/O shutdown handling regression in
v3.10-rc1
A big thanks to Kees Cook for fixing a long standing login error
buffer overflow bug.
All patches are CC'ed to stable with the exception of the v3.10-rc1
specific regression + other minor target cleanup."
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi-target: Fix iscsit_free_cmd() se_cmd->cmd_kref shutdown handling
target: Propigate up ->cmd_kref put return via transport_generic_free_cmd
iscsi-target: fix heap buffer overflow on error
target/file: Fix off-by-one READ_CAPACITY bug for !S_ISBLK export
ib_srpt: Call target_sess_cmd_list_set_waiting during shutdown_session
target: Re-instate sess_wait_list for target_wait_for_sess_cmds
target: Remove unused wait_for_tasks bit in target_wait_for_sess_cmds
git://git.kernel.org/pub/scm/linux/kernel/git/plagnioj/linux-fbdev
Pull fbdev fixes from Jean-Christophe PLAGNIOL-VILLARD:
"This contains some small fixes
- Atmel LCDC: fix blank the backlight on remove
- ps3fb: fix compile warning
- OMAPDSS: Fix crash with DT boot"
* tag 'fbdev-for-3.10-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/plagnioj/linux-fbdev:
atmel_lcdfb: blank the backlight on remove
trivial: atmel_lcdfb: add missing error message
fbdev/ps3fb: fix compile warning
non-rcu variant of list_first_or_null_rcu
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
In some cases after deleting a policy from the SPD the policy would
remain in the dst/flow/route cache for an extended period of time
which caused problems for SELinux as its dynamic network access
controls key off of the number of XFRM policy and state entries.
This patch corrects this problem by forcing a XFRM garbage collection
whenever a policy is sucessfully removed.
Reported-by: Ondrej Moris <omoris@redhat.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
udp6 over GRE tunnel does not work after to GRE tso changes. GRE
tso handler passes inner packet but keeps track of outer header
start in SKB_GSO_CB(skb)->mac_offset. udp6 fragment need to
take care of outer header, which start at the mac_offset, while
adding fragment header.
This bug is introduced by commit 68c3316311 (GRE: Add TCP
segmentation offload for GRE).
Reported-by: Dmitry Kravkov <dkravkov@gmail.com>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Tested-by: Dmitry Kravkov <dmitry@broadcom.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras
Pull aer error logging fix from Tony Luck:
"Can't call pci_get_domain_bus_and_slot() from interupt context"
* tag 'please-pull-aertracefix' of git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras:
aerdrv: Move cper_print_aer() call out of interrupt context
Go ahead and propigate up the ->cmd_kref put return value from
target_put_sess_cmd() -> transport_release_cmd() -> transport_put_cmd()
-> transport_generic_free_cmd().
This is useful for certain fabrics when determining the active I/O
shutdown case with SCF_ACK_KREF where a final target_put_sess_cmd()
is still required by the caller.
Pablo Neira Ayuso says:
The following patchset contains Netfilter/IPVS fixes for 3.10-rc3,
they are:
* fix xt_addrtype with IPv6, from Florian Westphal. This required
a new hook for IPv6 functions in the netfilter core to avoid
hard dependencies with the ipv6 subsystem when this match is
only used for IPv4.
* fix connection reuse case in IPVS. Currently, if an reused
connection are directed to the same server. If that server is
down, those connection would fail. Therefore, clear the
connection and choose a new server among the available ones.
* fix possible non-nul terminated string sent to user-space if
ipt_ULOG is used as the default netfilter logging stub, from
Chen Gang.
* fix mark logging of IPv6 packets in xt_LOG, from Michal Kubecek.
This bug has been there since 2.6.26.
* Fix breakage ip_vs_sh due to incorrect structure layout for
RCU, from Jan Beulich.
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen fixes from Konrad Rzeszutek Wilk:
- Use proper error paths
- Clean up APIC IPI usage (incorrect arguments)
- Delay XenBus frontend resume is backend (xenstored) is not running
- Fix build error with various combinations of CONFIG_
* tag 'stable/for-linus-3.10-rc3-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xenbus_client.c: correct exit path for xenbus_map_ring_valloc_hvm
xen-pciback: more uses of cached MSI-X capability offset
xen: Clean up apic ipi interface
xenbus: save xenstore local status for later use
xenbus: delay xenbus frontend resume if xenstored is not running
xmem/tmem: fix 'undefined variable' build error.
The following warning was seen on 3.9 when a corrected PCIe error was being
handled by the AER subsystem.
WARNING: at .../drivers/pci/search.c:214 pci_get_dev_by_id+0x8a/0x90()
This occurred because a call to pci_get_domain_bus_and_slot() was added to
cper_print_pcie() to setup for the call to cper_print_aer(). The warning
showed up because cper_print_pcie() is called in an interrupt context and
pci_get* functions are not supposed to be called in that context.
The solution is to move the cper_print_aer() call out of the interrupt
context and into aer_recover_work_func() to avoid any warnings when calling
pci_get* functions.
Signed-off-by: Lance Ortiz <lance.ortiz@hp.com>
Acked-by: Borislav Petkov <bp@suse.de>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Switch back to pre commit 1c7b13fe652 list splicing logic for active I/O
shutdown with tcm_qla2xxx + ib_srpt fabrics.
The original commit was done under the incorrect assumption that it's safe to
walk se_sess->sess_cmd_list unprotected in target_wait_for_sess_cmds() after
sess->sess_tearing_down = 1 has been set by target_sess_cmd_list_set_waiting()
during session shutdown.
So instead of adding sess->sess_cmd_lock protection around sess->sess_cmd_list
during target_wait_for_sess_cmds(), switch back to sess->sess_wait_list to
allow wait_for_completion() + TFO->release_cmd() to occur without having to
walk ->sess_cmd_list after the list_splice.
Also add a check to exit if target_sess_cmd_list_set_waiting() has already
been called, and add a WARN_ON to check for any fabric bug where new se_cmds
are added to sess->sess_cmd_list after sess->sess_tearing_down = 1 has already
been set.
Cc: Joern Engel <joern@logfs.org>
Cc: Roland Dreier <roland@kernel.org>
Cc: stable@vger.kernel.org
If the xenbus frontend is located in a domain running xenstored, the device
resume is hanging because it is happening before the process resume. This
patch adds extra logic to the resume code to check if we are the domain
running xenstored and delay the resume if needed.
Signed-off-by: Aurelien Chartier <aurelien.chartier@citrix.com>
[Changes in v2:
- Instead of bypassing the resume, process it in a workqueue]
[Changes in v3:
- Add a struct work in xenbus_device to avoid dynamic allocation
- Several small code fixes]
[Changes in v4:
- Use a dedicated workqueue]
[Changes in v5:
- Move create_workqueue error handling to xenbus_frontend_dev_resume]
Acked-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
into linux-fbdev/for-3.10-fixes
Pull Tomi fixes for ps3fb and omap2
As rcu_dereference_raw() under RCU debug config options can add quite a
bit of checks, and that tracing uses rcu_dereference_raw(), these checks
happen with the function tracer. The function tracer also happens to trace
these debug checks too. This added overhead can livelock the system.
Add a new interface to RCU for both rcu_dereference_raw_notrace() as well
as hlist_for_each_entry_rcu_notrace() as the hlist iterator uses the
rcu_dereference_raw() as well, and is used a bit with the function tracer.
Link: http://lkml.kernel.org/r/20130528184209.304356745@goodmis.org
Pull power management and ACPI fixes from Rafael Wysocki:
- Additional CPU ID for the intel_pstate driver from Dirk Brandewie.
- More cpufreq fixes related to ARM big.LITTLE support and locking from
Viresh Kumar.
- VIA C7 cpufreq build fix from Rafał Bilski.
- ACPI power management fix making it possible to use device power
states regardless of the CONFIG_PM setting from Rafael J Wysocki.
- New ACPI video blacklist item from Bastian Triller.
* tag 'pm+acpi-3.10-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / video: Add "Asus UL30A" to ACPI video detect blacklist
cpufreq: arm_big_little_dt: Instantiate as platform_driver
cpufreq: arm_big_little_dt: Register driver only if DT has valid data
cpufreq / e_powersaver: Fix linker error when ACPI processor is a module
cpufreq / intel_pstate: Add additional supported CPU ID
cpufreq: Drop rwsem lock around CPUFREQ_GOV_POLICY_EXIT
ACPI / PM: Allow device power states to be used for CONFIG_PM unset
Pull slave-dma fixes from Vinod Koul:
"We have two patches from Andy & Rafael fixing the Lynxpoint dma"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
ACPI / LPSS: register clock device for Lynxpoint DMA properly
dma: acpi-dma: parse CSRT to extract additional resources
Merge fixes from Andrew Morton:
"A bunch of fixes and one simple fbdev driver which missed the merge
window because people will still talking about it (to no great
effect)."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (30 commits)
aio: fix kioctx not being freed after cancellation at exit time
mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas
drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencing
ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap()
random: fix accounting race condition with lockless irq entropy_count update
drivers/char/random.c: fix priming of last_data
mm/memory_hotplug.c: fix printk format warnings
nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary
drivers/block/brd.c: fix brd_lookup_page() race
fbdev: FB_GOLDFISH should depend on HAS_DMA
drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq()
auditfilter.c: fix kernel-doc warnings
aio: fix io_getevents documentation
revert "selftest: add simple test for soft-dirty bit"
drivers/leds/leds-ot200.c: fix error caused by shifted mask
mm/THP: use pmd_populate() to update the pmd with pgtable_t pointer
linux/kernel.h: fix kernel-doc warning
mm compaction: fix of improper cache flush in migration code
rapidio/tsi721: fix bug in MSI interrupt handling
hfs: avoid crash in hfs_bnode_create
Pull ARM SoC fixes from Olof Johansson:
"We didn't have any fixes sent up for -rc2, so this is a slightly
larger batch. A bit all over the place platform-wise; OMAP, at91,
marvell, renesas, sunxi, ux500, etc.
I tried to summarize highlights but there isn't a whole lot to point
out. Lots of little things fixed all over. A couple of defconfig
updates due to new/changing options."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits)
ARM: at91/sama5: fix incorrect PMC pcr div definition
ARM: at91/dt: fix macb pinctrl_macb_rmii_mii_alt definition
ARM: at91: at91sam9n12: move external irq declatation to DT
ARM: shmobile: marzen: Use error values in usb_power_*
ARM: tegra: defconfig fixes
ARM: nomadik: fix IRQ assignment for SMC ethernet
ARM: vt8500: Add missing NULL terminator in dt_compat
clk: tegra: add ac97 controller clock
clk: tegra: remove USB from clk init table
ARM: dts: mvebu: Fix wrong the address reg value for the L2-cache node
ARM: plat-orion: Fix num_resources and id for ge10 and ge11
ARM: OMAP2+: hwmod: Remove sysc slave idle and auto idle apis
SERIAL: OMAP: Remove the slave idle handling from the driver
ARM: OMAP2+: serial: Remove the un-used slave idle hooks
ARM: OMAP2+: hwmod-data: UART IP needs software control to manage sidle modes
ARM: OMAP2+: hwmod: Add a new flag to handle SIDLE in SWSUP only in active
ARM: OMAP2+: hwmod: Fix sidle programming in _enable_sysc()/_idle_sysc()
arm: mvebu: fix the 'ranges' property to handle PCIe
ARM: mvebu: select ARCH_REQUIRE_GPIOLIB for mvebu platform
ARM: AM33XX: Add missing .clkdm_name to clkdiv32k_ick clock
Fix kernel-doc warning in <linux/kernel.h>:
Warning(include/linux/kernel.h:590): No description found for parameter 'ip'
scripts/kernel-doc cannot handle macros, functions, or function
prototypes between the function or macro that is being documented and
its definition, so move these prototypes above the function that is
being documented.
Many callers of the wait_event_timeout() and
wait_event_interruptible_timeout() expect that the return value will be
positive if the specified condition becomes true before the timeout
elapses. However, at the moment this isn't guaranteed. If the wake-up
handler is delayed enough, the time remaining until timeout will be
calculated as 0 - and passed back as a return value - even if the
condition became true before the timeout has passed.
Fix this by returning at least 1 if the condition becomes true. This
semantic is in line with what wait_for_condition_timeout() does; see
commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious
failure under heavy load").
Daniel said "We have 3 instances of this bug in drm/i915. One case even
where we switch between the interruptible and not interruptible
wait_event_timeout variants, foolishly presuming they have the same
semantics. I very much like this."
One such bug is reported at
https://bugs.freedesktop.org/show_bug.cgi?id=64133
Signed-off-by: Imre Deak <imre.deak@intel.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Lukas Czerner <lczerner@redhat.com>
Cc: <stable@vger.kernel.org>
Add RapidIO enumeration/discovery start from user space. User space
start allows to defer RapidIO fabric scan until the moment when all
participating endpoints are initialized avoiding mandatory synchronized
start of all endpoints (which may be challenging in systems with large
number of RapidIO endpoints).
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Andre van Herk <andre.van.herk@Prodrive.nl>
Cc: Micha Nelissen <micha.nelissen@Prodrive.nl>
Systems that use RapidIO fabric may need to implement their own
enumeration and discovery methods which are better suitable for needs of
a target application.
The following set of patches is intended to simplify process of
introduction of new RapidIO fabric enumeration/discovery methods.
The first patch offers ability to add new RapidIO enumeration/discovery
methods using kernel configuration options. This new configuration
option mechanism allows to select statically linked or modular
enumeration/discovery method(s) from the list of existing methods or use
external module(s).
This patch also updates the currently existing enumeration/discovery
code to be used as a statically linked or modular method.
The corresponding configuration option is named "Basic
enumeration/discovery" method. This is the only one configuration
option available today but new methods are expected to be introduced
after adoption of provided patches.
The second patch address a long time complaint of RapidIO subsystem
users regarding fabric enumeration/discovery start sequence. Existing
implementation offers only a boot-time enumeration/discovery start which
requires synchronized boot of all endpoints in RapidIO network. While
it works for small closed configurations with limited number of
endpoints, using this approach in systems with large number of endpoints
is quite challenging.
To eliminate requirement for synchronized start the second patch
introduces RapidIO enumeration/discovery start from user space.
For compatibility with the existing RapidIO subsystem implementation,
automatic boot time enumeration/discovery start can be configured in by
specifying "rio-scan.scan=1" command line parameter if statically linked
basic enumeration method is selected.
This patch:
Rework to implement RapidIO enumeration/discovery method selection
combined with ability to use enumeration/discovery as a kernel module.
This patch adds ability to introduce new RapidIO enumeration/discovery
methods using kernel configuration options. Configuration option
enumeration/discovery method from the list of existing methods or use
external modules. If a modular enumeration/discovery is selected each
RapidIO mport device can have its own method attached to it.
The existing enumeration/discovery code was updated to be used as
statically linked or modular method. This configuration option is named
"Basic enumeration/discovery" method.
Several common routines have been moved from rio-scan.c to make them
available to other enumeration methods and reduce number of exported
symbols.
"It's been a while since my last pull request so quite a few fixes have
piled up."
Indeed.
1) Fix nf_{log,queue} compilation with PROC_FS disabled, from Pablo
Neira Ayuso.
2) Fix data corruption on some tg3 chips with TSO enabled, from Michael
Chan.
3) Fix double insertion of VLAN tags in be2net driver, from Sarveshwar
Bandi.
4) Don't have TCP's MD5 support pass > PAGE_SIZE page offsets in
scatter-gather entries into the crypto layer, the crypto layer can't
handle that. From Eric Dumazet.
5) Fix lockdep splat in 802.1Q MRP code, also from Eric Dumazet.
6) Fix OOPS in netfilter log module when called from conntrack, from
Hans Schillstrom.
7) FEC driver needs to use netif_tx_{lock,unlock}_bh() rather than the
non-BH disabling variants. From Fabio Estevam.
8) TCP GSO can generate out-of-order packets, fix from Eric Dumazet.
9) vxlan driver doesn't update 'used' field of fdb entries when it
should, from Sridhar Samudrala.
10) ipv6 should use kzalloc() to allocate inet6 socket cork options,
otherwise we can OOPS in ip6_cork_release(). From Eric Dumazet.
11) Fix races in bonding set mode, from Nikolay Aleksandrov.
12) Fix checksum generation regression added by "r8169: fix 8168evl
frame padding.", from Francois Romieu.
13) ip_gre can look at stale SKB data pointer, fix from Eric Dumazet.
14) Fix checksum handling when GSO is enabled in bnx2x driver with
certain chips, from Yuval Mintz.
15) Fix double free in batman-adv, from Martin Hundebøll.
16) Fix device startup synchronization with firmware in tg3 driver, from
Nithin Sujit.
17) perf networking dropmonitor doesn't work at all due to mixed up
trace parameter ordering, from Ben Hutchings.
18) Fix proportional rate reduction handling in tcp_ack(), from Nandita
Dukkipati.
19) IPSEC layer doesn't return an error when a valid state is detected,
causing an OOPS. Fix from Timo Teräs.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits)
be2net: bug fix on returning an invalid nic descriptor
tcp: xps: fix reordering issues
net: Revert unused variable changes.
xfrm: properly handle invalid states as an error
virtio_net: enable napi for all possible queues during open
tcp: bug fix in proportional rate reduction.
net: ethernet: sun: drop unused variable
net: ethernet: korina: drop unused variable
net: ethernet: apple: drop unused variable
qmi_wwan: Added support for Cinterion's PLxx WWAN Interface
perf: net_dropmonitor: Remove progress indicator
perf: net_dropmonitor: Use bisection in symbol lookup
perf: net_dropmonitor: Do not assume ordering of dictionaries
perf: net_dropmonitor: Fix symbol-relative addresses
perf: net_dropmonitor: Fix trace parameter order
net: fec: use a more proper compatible string for MVF type device
qlcnic: Fix updating netdev->features
qlcnic: remove netdev->trans_start updates within the driver
qlcnic: Return proper error codes from probe failure paths
tg3: Update version to 3.132
When cgroup_next_descendant_pre() initiates a walk, it checks whether
the subtree root doesn't have any children and if not returns NULL.
Later code assumes that the subtree isn't empty. This is broken
because the subtree may become empty inbetween, which can lead to the
traversal escaping the subtree by walking to the sibling of the
subtree root.
There's no reason to have the early exit path. Remove it along with
the later assumption that the subtree isn't empty. This simplifies
the code a bit and fixes the subtle bug.
While at it, fix the comment of cgroup_for_each_descendant_pre() which
was incorrectly referring to ->css_offline() instead of
->css_online().
Reviewed-by: Michal Hocko <mhocko@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Here are some more fixes for v3.10. The Moorestown update broke Intel
Medfield devices, so I reverted it. The acpiphp change fixes a
regression: we broke hotplug notifications to host bridges when we
split acpiphp into the host-bridge related part and the
endpoint-related part.
Moorestown
Revert "x86/pci/mrst: Use configuration mechanism 1 for 00:00.0, 00:02.0, 00:03.0"
Hotplug
PCI: acpiphp: Re-enumerate devices when host bridge receives Bus Check"
* tag 'pci-v3.10-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg Kroah-Hartman:
"Here are some tty / serial driver fixes for 3.10-rc2.
Nothing huge, although the rocket driver fix looks large, it's just
moving the code around to fix the reported build issues in it. Other
than that, this has the fix for the of-reported lockdep warning from
the vt layer, as well as some other needed bugfixes.
All of these have been in linux-next for a while"
* tag 'tty-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
tty: mxser: Fix build warning introduced by dfc7b837c7f9 (Re: linux-next: build warning after merge of the tty.current tree)
tty: mxser: fix usage of opmode_ioaddr
serial: 8250_dw: add ACPI ID for Intel BayTrail
TTY: Fix tty miss restart after we turn off flow-control
tty/vt: Fix vc_deallocate() lock order
TTY: ehv_bytechan: add missing platform_driver_unregister() when module exit
TTY: rocket, fix more no-PCI warnings
serial: mcf: missing uart_unregister_driver() on error in mcf_init()
tty: serial: mpc5xxx: fix error handing in mpc52xx_uart_init()
serial: samsung: add missing platform_driver_unregister() when module exit
serial: pl011: protect attribute read from NULL platform data struct
tty: nwpserial: Pass correct pointer to free_irq()
serial: 8250_dw: Add valid clk pointer check
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg Kroah-Hartman:
"Here are a number of tiny USB bugfixes / new device ids for 3.10-rc2
The majority of these are USB gadget fixes, but they are all small.
Other than that, some USB host controller fixes, and USB serial driver
fixes for problems reported with them.
Also hopefully a fixed up USB_OTG Kconfig dependancy, that one seems
to be almost impossible to get right for all of the different
platforms these days."
* tag 'usb-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (56 commits)
USB: cxacru: potential underflow in cxacru_cm_get_array()
USB: ftdi_sio: Add support for Newport CONEX motor drivers
USB: option: add device IDs for Dell 5804 (Novatel E371) WWAN card
usb: ohci: fix goto wrong tag in err case
usb: isp1760-if: fix memleak when platform_get_resource fail
usb: ehci-s5p: fix memleak when fallback to pdata
USB: serial: clean up chars_in_buffer
USB: ti_usb_3410_5052: fix chars_in_buffer overhead
USB: io_ti: fix chars_in_buffer overhead
USB: ftdi_sio: fix chars_in_buffer overhead
USB: ftdi_sio: clean up get_modem_status
USB: serial: add generic wait_until_sent implementation
USB: serial: add wait_until_sent operation
USB: set device dma_mask without reference to global data
USB: Blacklisted Cinterion's PLxx WWAN Interface
usb: option: Add Telewell TW-LTE 4G
USB: EHCI: remove bogus #error
USB: reset resume quirk needed by a hub
USB: usb-stor: realtek_cr: Fix compile error
usb, chipidea: fix link error when USB_EHCI_HCD is a module
Quoting https://bugzilla.netfilter.org/show_bug.cgi?id=812:
[ ip6tables -m addrtype ]
When I tried to use in the nat/PREROUTING it messes up the
routing cache even if the rule didn't matched at all.
If I remove the --limit-iface-in from the non-working scenario, so just
use the -m addrtype --dst-type LOCAL it works!
This happens when LOCAL type matching is requested with --limit-iface-in,
and the default ipv6 route is via the interface the packet we test
arrived on.
Because xt_addrtype uses ip6_route_output, the ipv6 routing implementation
creates an unwanted cached entry, and the packet won't make it to the
real/expected destination.
Silently ignoring --limit-iface-in makes the routing work but it breaks
rule matching (--dst-type LOCAL with limit-iface-in is supposed to only
match if the dst address is configured on the incoming interface;
without --limit-iface-in it will match if the address is reachable
via lo).
The test should call ipv6_chk_addr() instead. However, this would add
a link-time dependency on ipv6.
There are two possible solutions:
1) Revert the commit that moved ipt_addrtype to xt_addrtype,
and put ipv6 specific code into ip6t_addrtype.
2) add new "nf_ipv6_ops" struct to register pointers to ipv6 functions.
While the former might seem preferable, Pablo pointed out that there
are more xt modules with link-time dependeny issues regarding ipv6,
so lets go for 2).
When booting with DT, there's a crash when omapfb is probed. This is
caused by the fact that omapdss+DT is not yet supported, and thus
omapdss is not probed at all. On the other hand, omapfb is always
probed. When omapfb tries to use omapdss, there's a NULL pointer
dereference crash. The same error should most likely happen with omapdrm
and omap_vout also.
To fix this, add an "initialized" state to omapdss. When omapdss has
been probed, it's marked as initialized. omapfb, omapdrm and omap_vout
check this state when they are probed to see that omapdss is actually
there.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Tested-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Pull MIPS update from Ralf Baechle:
- Fix a build error if <linux/printk.h> is included without
<linux/linkage.h> having been included before.
- Cleanup and fix the damage done by the generic idle loop patch.
- A kprobes fix that brings the MIPS code in line with what other
architectures are for quite a while already.
- Wire up the native getdents64(2) syscall for 64 bit - for some reason
it was only for the compat ABIs. This has been reported to cause an
application issue. This turned out bigger than I meant but the wait
instruction support code was driving me nuts.
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: N64: Wire getdents64(2)
kprobes/mips: Fix to check double free of insn slot
MIPS: Idle: Break r4k_wait into two functions and fix it.
MIPS: Idle: Do address fiddlery in helper functions.
MIPS: Idle: Consolidate all declarations in <asm/idle.h>.
MIPS: Idle: Don't call local_irq_disable() in cpu_wait() implementations.
MIPS: Idle: Re-enable irqs at the end of r3081, au1k and loongson2 cpu_wait.
MIPS: Idle: Make call of function pointer readable.
MIPS: Idle: Consistently reformat inline assembler.
MIPS: Idle: cleaup SMTC idle hook as per Linux coding style.
MIPS: Consolidate idle loop / WAIT instruction support in a single file.
MIPS: clock.h: Remove declaration of cpu_wait.
Add include dependencies to <linux/printk.h>.
MIPS: Rewrite pfn_valid to work in modules, too.
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into fixes
From Paul Walmsley:
Fix the OMAP serial driver to work correctly on OMAP4 when booting
with DT.
* tag 'omap-fixes-a-for-3.10-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending:
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes
Pull mfd fixes from Samuel Ortiz:
"This is the first batch of MFD fixes for 3.10.
It's bigger than I would like, most of it is due to the big ab/db8500
merge that went through during the 3.10 merge window.
So we have:
- Some build fixes for the tps65912 and ab8500 drivers.
- A couple of build fixes for the the si476x driver with pre 4.3 gcc
compilers.
- A few runtime breakage fixes (probe failures or oopses) for the
ab8500 and db8500 drivers.
- Some sparse or regular gcc warning fixes for the si476x, ab8500 and
cros_ec drivers."
* tag 'mfd-fixes-3.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes:
mfd: ab8500-sysctrl: Let sysctrl driver work without pdata
mfd: db8500-prcmu: Update stored DSI PLL divider value
mfd: ab8500-sysctrl: Always enable pm_power_off handler
mfd: ab8500-core: Pass GPADC compatible string to MFD core
mfd: db8500-prcmu: Supply the pdata_size attribute for db8500-thermal
mfd: ab8500-core: Use the correct driver name when enabling gpio/pinctrl
mfd: ab8500: Pass AB8500 IRQ to debugfs code by resource
mfd: ab8500-gpadc: Suppress 'ignoring regulator_enable() return value' warning
mfd: ab8500-sysctrl: Set sysctrl_dev during probe
mfd: ab8500-sysctrl: Fix sparse warning
mfd: abx500-core: Fix sparse warning
mfd: ab8500: Debugfs code depends on gpadc
mfd: si476x: Use get_unaligned_be16() for unaligned be16 loads
mfd: cros_ec_spi: Use %z to format pointer differences
mfd: si476x: Do not use binary constants
mfd: tps65912: Select MFD_CORE
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio fixes from Rusty Russell:
"A build fix and a uapi exposure fix. The build fix is later than I
liked, but my first version broke linux-next due to overzealous header
clean."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio_console: fix uapi header
Hoist memcpy_fromiovec/memcpy_toiovec into lib/
On s390 the prefix page and absolute zero pages are not correctly
returned when reading /dev/mem. The reason is that the s390 asm/io.h
file includes the asm-generic/io.h file which then defines
xlate_dev_mem_ptr() and therefore overwrites the s390 specific
version that does the correct swap operation for prefix and absolute
zero pages. The problem is a regression that was introduced with git
commit cd248341 (s390/pci: base support).
To fix the problem add "#ifndef xlate_dev_mem_ptr" in asm-generic/io.h
and "#define xlate_dev_mem_ptr" in asm/io.h. This ensures that the
s390 version is used. For completeness also add the "#ifndef"
construct for xlate_dev_kmem_ptr().
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
