path: root/include
2008-06-23Merge branch 'linus' into x86/threadinfotip-x86-threadinfo-2008-06-23_09.53_MonIngo Molnar
2008-06-21Add return value to reserve_bootmem_node()Bernhard Walle
This patch changes the function reserve_bootmem_node() from void to int, returning -ENOMEM if the allocation fails. This fixes a build problem on x86 with CONFIG_KEXEC=y and CONFIG_NEED_MULTIPLE_NODES=y Signed-off-by: Bernhard Walle <bwalle@suse.de> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: Don't receive new packets in a dead network namespace. sctp: Make sure N * sizeof(union sctp_addr) does not overflow. pppoe: warning fix ipv6: Drop packets for loopback address from outside of the box. ipv6: Remove options header when setsockopt's optlen is 0 mac80211: detect driver tx bugs
2008-06-20netns: Don't receive new packets in a dead network namespace.Eric W. Biederman
Alexey Dobriyan <adobriyan@gmail.com> writes: > Subject: ICMP sockets destruction vs ICMP packets oops > After icmp_sk_exit() nuked ICMP sockets, we get an interrupt. > icmp_reply() wants ICMP socket. > > Steps to reproduce: > > launch shell in new netns > move real NIC to netns > setup routing > ping -i 0 > exit from shell > > BUG: unable to handle kernel NULL pointer dereference at 0000000000000000 > IP: [<ffffffff803fce17>] icmp_sk+0x17/0x30 > PGD 17f3cd067 PUD 17f3ce067 PMD 0 > Oops: 0000 [1] PREEMPT SMP DEBUG_PAGEALLOC > CPU 0 > Modules linked in: usblp usbcore > Pid: 0, comm: swapper Not tainted 2.6.26-rc6-netns-ct #4 > RIP: 0010:[<ffffffff803fce17>] [<ffffffff803fce17>] icmp_sk+0x17/0x30 > RSP: 0018:ffffffff8057fc30 EFLAGS: 00010286 > RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff81017c7db900 > RDX: 0000000000000034 RSI: ffff81017c7db900 RDI: ffff81017dc41800 > RBP: ffffffff8057fc40 R08: 0000000000000001 R09: 000000000000a815 > R10: 0000000000000000 R11: 0000000000000001 R12: ffffffff8057fd28 > R13: ffffffff8057fd00 R14: ffff81017c7db938 R15: ffff81017dc41800 > FS: 0000000000000000(0000) GS:ffffffff80525000(0000) knlGS:0000000000000000 > CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b > CR2: 0000000000000000 CR3: 000000017fcda000 CR4: 00000000000006e0 > DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 > DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 > Process swapper (pid: 0, threadinfo ffffffff8053a000, task ffffffff804fa4a0) > Stack: 0000000000000000 ffff81017c7db900 ffffffff8057fcf0 ffffffff803fcfe4 > ffffffff804faa38 0000000000000246 0000000000005a40 0000000000000246 > 000000000001ffff ffff81017dd68dc0 0000000000005a40 0000000055342436 > Call Trace: > <IRQ> [<ffffffff803fcfe4>] icmp_reply+0x44/0x1e0 > [<ffffffff803d3a0a>] ? ip_route_input+0x23a/0x1360 > [<ffffffff803fd645>] icmp_echo+0x65/0x70 > [<ffffffff803fd300>] icmp_rcv+0x180/0x1b0 > [<ffffffff803d6d84>] ip_local_deliver+0xf4/0x1f0 > [<ffffffff803d71bb>] ip_rcv+0x33b/0x650 > [<ffffffff803bb16a>] netif_receive_skb+0x27a/0x340 > [<ffffffff803be57d>] process_backlog+0x9d/0x100 > [<ffffffff803bdd4d>] net_rx_action+0x18d/0x250 > [<ffffffff80237be5>] __do_softirq+0x75/0x100 > [<ffffffff8020c97c>] call_softirq+0x1c/0x30 > [<ffffffff8020f085>] do_softirq+0x65/0xa0 > [<ffffffff80237af7>] irq_exit+0x97/0xa0 > [<ffffffff8020f198>] do_IRQ+0xa8/0x130 > [<ffffffff80212ee0>] ? mwait_idle+0x0/0x60 > [<ffffffff8020bc46>] ret_from_intr+0x0/0xf > <EOI> [<ffffffff80212f2c>] ? mwait_idle+0x4c/0x60 > [<ffffffff80212f23>] ? mwait_idle+0x43/0x60 > [<ffffffff8020a217>] ? cpu_idle+0x57/0xa0 > [<ffffffff8040f380>] ? rest_init+0x70/0x80 > Code: 10 5b 41 5c 41 5d 41 5e c9 c3 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 e5 53 > 48 83 ec 08 48 8b 9f 78 01 00 00 e8 2b c7 f1 ff 89 c0 <48> 8b 04 c3 48 83 c4 08 > 5b c9 c3 66 66 66 66 66 2e 0f 1f 84 00 > RIP [<ffffffff803fce17>] icmp_sk+0x17/0x30 > RSP <ffffffff8057fc30> > CR2: 0000000000000000 > ---[ end trace ea161157b76b33e8 ]--- > Kernel panic - not syncing: Aiee, killing interrupt handler! Receiving packets while we are cleaning up a network namespace is a racy proposition. It is possible when the packet arrives that we have removed some but not all of the state we need to fully process it. We have the choice of either playing wack-a-mole with the cleanup routines or simply dropping packets when we don't have a network namespace to handle them. Since the check looks inexpensive in netif_receive_skb let's just drop the incoming packets. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-20alpha: fix compile failures with gcc-4.3 (bug #10438)Ivan Kokshaysky
Vast majority of these build failures are gcc-4.3 warnings about static functions and objects being referenced from non-static (read: "extern inline") functions, in conjunction with our -Werror. We cannot just convert "extern inline" to "static inline", as people keep suggesting all the time, because "extern inline" logic is crucial for generic kernel build. So - just make sure that all callees of critical "extern inline" functions are also "extern inline"; - use "static inline", wherever it's possible. traps.c: work around gcc-4.3 being too smart about array bounds-checking. TODO: add "gnu_inline" attribute to all our "extern inline" functions to ensure desired behaviour with future compilers. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20alpha: fix module load failures on smp (bug #10926)Ivan Kokshaysky
To calculate addresses of locally defined variables, GCC uses 32-bit displacement from the GP. Which doesn't work for per cpu variables in modules, as an offset to the kernel per cpu area is way above 4G. The workaround is to force allocation of a GOT entry for per cpu variable using ldq instruction with a 'literal' relocation. I had to use custom asm/percpu.h, as a required argument magic doesn't work with asm-generic/percpu.h macros. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, geode: add a VSA2 ID for General Software x86: use BOOTMEM_EXCLUSIVE on 32-bit x86, 32-bit: fix boot failure on TSC-less processors x86: fix NULL pointer deref in __switch_to x86: set PAE PHYSICAL_MASK_SHIFT to 44 bits.
2008-06-19ipv6: Drop packets for loopback address from outside of the box.YOSHIFUJI Hideaki
[ Based upon original report and patch by Karsten Keil. Karsten has verified that this fixes the TAHI test case "ICMPv6 test v6LC.5.1.2 Part F". -DaveM ] Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19x86, geode: add a VSA2 ID for General SoftwareJordan Crouse
General Software writes their own VSA2 module for their version of the Geode BIOS, which returns a different ID then the standard VSA2. This was causing the framebuffer driver to break for most GSW boards. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: tglx@linutronix.de Cc: linux-geode@lists.infradead.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19Blackfin Serial Driver: Use timer to poll CTS PIN instead of workqueue.Sonic Zhang
This allows other threads to run when the serial driver polls the CTS PIN in a loop. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-06-19Blackfin arch: fix typo error in bf548 serial header fileSonic Zhang
2008-06-19x86: set PAE PHYSICAL_MASK_SHIFT to 44 bits.Jeremy Fitzhardinge
When a 64-bit x86 processor runs in 32-bit PAE mode, a pte can potentially have the same number of physical address bits as the 64-bit host ("Enhanced Legacy PAE Paging"). This means, in theory, we could have up to 52 bits of physical address in a pte. The 32-bit kernel uses a 32-bit unsigned long to represent a pfn. This means that it can only represent physical addresses up to 32+12=44 bits wide. Rather than widening pfns everywhere, just set 2^44 as the Linux x86_32-PAE architectural limit for physical address size. This is a bugfix for two cases: 1. running a 32-bit PAE kernel on a machine with more than 64GB RAM. 2. running a 32-bit PAE Xen guest on a host machine with more than 64GB RAM In both cases, a pte could need to have more than 36 bits of physical, and masking it to 36-bits will cause fairly severe havoc. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jan Beulich <jbeulich@novell.com> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-18Merge branch 'agp-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp/intel: cleanup some serious whitespace badness [AGP] intel_agp: Add support for Intel 4 series chipsets [AGP] intel_agp: extra stolen mem size available for IGD_GM chipset agp: more boolean conversions. drivers/char/agp - use bool agp: two-stage page destruction issue agp/via: fixup pci ids
2008-06-19agp: more boolean conversions.Dave Airlie
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits) netlink: genl: fix circular locking Revert "mac80211: Use skb_header_cloned() on TX path." af_unix: fix 'poll for write'/ connected DGRAM sockets tun: Proper handling of IPv6 header in tun driver when TUN_NO_PI is set atl1: relax eeprom mac address error check net/enc28j60: low power mode net/enc28j60: section fix sky2: 88E8040T pci device id netxen: download firmware in pci probe netxen: cleanup debug messages netxen: remove global physical_port array netxen: fix portnum for hp mezz cards ibm_newemac: select CRC32 in Kconfig xfrm: fix fragmentation for ipv4 xfrm tunnel netfilter: nf_conntrack_h323: fix module unload crash netfilter: nf_conntrack_h323: fix memory leak in module initialization error path netfilter: nf_nat: fix RCU races atm: [he] send idle cells instead of unassigned when in SDH mode atm: [he] limit queries to the device's register space atm: [br2864] fix routed vcmux support ...
2008-06-17netfilter: nf_nat: fix RCU racesPatrick McHardy
Fix three ct_extend/NAT extension related races: - When cleaning up the extension area and removing it from the bysource hash, the nat->ct pointer must not be set to NULL since it may still be used in a RCU read side - When replacing a NAT extension area in the bysource hash, the nat->ct pointer must be assigned before performing the replacement - When reallocating extension storage in ct_extend, the old memory must not be freed immediately since it may still be used by a RCU read side Possibly fixes https://bugzilla.redhat.com/show_bug.cgi?id=449315 and/or http://bugzilla.kernel.org/show_bug.cgi?id=10875 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16ipv6 sit: Avoid extra need for compat layer in PRL management.YOSHIFUJI Hideaki
We've introduced extra need of compat layer for ip_tunnel_prl{} for PRL (Potential Router List) management. Though compat_ioctl is still missing in ipv4/ipv6, let's make the interface more straight-forward and eliminate extra need for nasty compat layer anyway since the interface is new for 2.6.26. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix CONFIG_IA64_SGI_UV build error [IA64] Update check_sal_cache_flush to use platform_send_ipi() [IA64] perfmon: fix async exit bug
2008-06-16Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (21 commits) [POWERPC] Turn on ATA_SFF so we get SATA_SVW back in defconfigs [POWERPC] Remove ppc32's export of console_drivers [POWERPC] Fix -Os kernel builds with newer gcc versions [POWERPC] Fix bootwrapper builds with newer gcc versions [POWERPC] Build fix for drivers/macintosh/mediabay.c [POWERPC] Fix warning in pseries/eeh_driver.c [POWERPC] Add missing of_node_put in drivers/macintosh/therm_adt746x.c [POWERPC] Add missing of_node_put in drivers/macintosh/smu.c [POWERPC] Add missing of_node_put in pseries/nvram.c [POWERPC] Fix return value check logic in debugfs virq_mapping setup [POWERPC] Fix rmb to order cacheable vs. noncacheable powerpc/spufs: fix missed stop-and-signal event powerpc/spufs: synchronize interaction between spu exception handling and time slicing powerpc/spufs: remove class_0_dsisr from spu exception handling powerpc/spufs: wait for stable spu status in spu_stopped() [POWERPC] bootwrapper: add simpleImage* to list of boot targets [POWERPC] 83xx: MPC837xRDB's VSC7385 ethernet switch isn't on the MDIO bus [POWERPC] Updated Freescale PPC defconfigs [POWERPC] 8610: Update defconfig for MPC8610 HPCD [POWERPC] 85xx: MPC8548CDS - Fix size of PCIe IO space ...
2008-06-16Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Au1200: MMC resource size off by one [MIPS] TANBAC: Update defconfig [MIPS] Vr41xx: Initialize PCI io_map_base [MIPS] Malta: Always compile MTD platform device registration code. [MIPS] Malta: Fix build errors for 64-bit kernels [MIPS] Lasat: sysctl fixup [MIPS] Fix buggy use of kmap_coherent. [MIPS] Lasat: bring back from the dead [MIPS] vpe_id is required for VSMP and SMTC builds [MIPS] Export smp_call_function and smp_call_function_single. [MIPS] Bring the SWARM defconfig up to date [MIPS] Sibyte: Build RTC support as an object [MIPS] Fix the fix for divide by zero error in build_{clear,copy}_page [MIPS] Fix build for PNX platforms. [MIPS] Add RM200 with R5000 CPU to known ARC machines [MIPS] Better load address for big endian SNI RM [MIPS] SB1250: Initialize io_map_base [MIPS] Alchemy: Add au1500 reserved interrupt [MIPS] Export empty_zero_page for sake of the ext4 module.
2008-06-16Export <linux/a.out.h> to userspace again.David Woodhouse
This seems to have been removed accidentally in commit ed7b1889da256977574663689b598d88950bbd23 ("Unexport asm/page.h"), but wasn't supposed to have been -- the original patch at http://lkml.org/lkml/2007/10/30/144 just moved it from $(header-y) to $(unifdef-y) Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-16Remove #ifdef CONFIG_ARCH_SUPPORTS_AOUT from <linux/a.out.h>David Woodhouse
This file is only included where it makes sense now, so there's no need for the CONFIG_ARCH_SUPPORTS_AOUT conditional -- and that conditional is bad, because we want to export <linux/a.out.h> to userspace. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-16[IA64] Fix CONFIG_IA64_SGI_UV build errorJack Steiner
Fix build error in CONFIG_IA64_SGI_UV config. (GENERIC builds are ok). Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-16[MIPS] Malta: Fix build errors for 64-bit kernelsThomas Bogendoerfer
Fix 64-bit Malta by using CKSEG0ADDR and correct casts. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] Lasat: bring back from the deadThomas Horsten
After the common MIPS CPU interrupt controller (for irq0-7) was introduced the Lasat boards didn't get their interrupts right, so nothing worked. The old routines need to be offset by the new 8 hardware interrupts common to all MIPS CPU's. Signed-off-by: Thomas Horsten <thomas@horsten.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] vpe_id is required for VSMP and SMTC buildsChris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] Fix build for PNX platforms.Ralf Baechle
Build error was caused by commit 351336929ccf222ae38ff0cb7a8dd5fd5c6236a0. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] Alchemy: Add au1500 reserved interruptbruno randolf
In the conversion done in the commits 95c4eb3ef4484ca85da5c98780d358cffd546b90 9d360ab4a7568a8d177280f651a8a772ae52b9b9 [MIPS] Alchemy: Renumber interrupts so irq_cpu can work. one reserved interrupt on au1500 was missed. this broke the au1000 ethernet driver. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[POWERPC] Build fix for drivers/macintosh/mediabay.cAdrian Bunk
This fixes the following build error with CONFIG_BLK_DEV_IDE_PMAC=n: <-- snip --> ... CC drivers/macintosh/mediabay.o /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/macintosh/mediabay.c: In function 'check_media_bay': /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/macintosh/mediabay.c:428: error: 'struct media_bay_info' has no member named 'cd_index' make[3]: *** [drivers/macintosh/mediabay.o] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-16[POWERPC] Fix rmb to order cacheable vs. noncacheableNick Piggin
lwsync is explicitly defined not to have any effect on the ordering of accesses to device memory, so it cannot be used for rmb(). sync appears to be the only barrier which fits the bill. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-16Merge branch 'linux-2.6' into mergePaul Mackerras
2008-06-16Merge branch 'merge' of ↵Paul Mackerras
git://git.kernel.org/pub/scm/linux/kernel/git/jk/spufs into merge
2008-06-16powerpc/spufs: remove class_0_dsisr from spu exception handlingLuke Browning
According to the CBEA, the SPU dsisr is not updated for class 0 exceptions. spu_stopped() is testing the dsisr that was passed to it from the class 0 exception handler, so we return a false positive here. This patch cleans up the interrupt handler and erroneous tests in spu_stopped. It also removes the fields from the csa since it is not needed to process class 0 events. Signed-off-by: Luke Browning <lukebrowning@us.ibm.com> Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
2008-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: fixup write combine comment in pci_mmap_resource x86: PAT export resource_wc in pci sysfs x86, pci-dma.c: don't always add __GFP_NORETRY to gfp suspend-vs-iommu: prevent suspend if we could not resume x86: pci-dma.c: use __GFP_NO_OOM instead of __GFP_NORETRY pci, x86: add workaround for bug in ASUS A7V600 BIOS (rev 1005) PCI: use dev_to_node in pci_call_probe PCI: Correct last two HP entries in the bfsort whitelist
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: update my email address parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3 parisc: fix off by one in setup_sigcontext32 parisc: export empty_zero_page parisc: export copy_user_page_asm parisc: move head.S to head.text section Revert "parisc: fix trivial section name warnings"
2008-06-13parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3Kyle McMartin
ip_fast_csum needs an asm "memory" clobber, otherwise the aggressive optimizations in gcc-4.3 cause it to be miscompiled. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: tcp: Revert 'process defer accept as established' changes. ipv6: Fix duplicate initialization of rawv6_prot.destroy bnx2x: Updating the Maintainer net: Eliminate flush_scheduled_work() calls while RTNL is held. drivers/net/r6040.c: correct bad use of round_jiffies() fec_mpc52xx: MPC52xx_MESSAGES_DEFAULT: 2nd NETIF_MSG_IFDOWN => IFUP ipg: fix receivemode IPG_RM_RECEIVEMULTICAST{,HASH} in ipg_nic_set_multicast_list() netfilter: nf_conntrack: fix ctnetlink related crash in nf_nat_setup_info() netfilter: Make nflog quiet when no one listen in userspace. ipv6: Fail with appropriate error code when setting not-applicable sockopt. ipv6: Check IPV6_MULTICAST_LOOP option value. ipv6: Check the hop limit setting in ancillary data. ipv6 route: Fix route lifetime in netlink message. ipv6 mcast: Check address family of gf_group in getsockopt(MS_FILTER). dccp: Bug in initial acknowledgment number assignment dccp ccid-3: X truncated due to type conversion dccp ccid-3: TFRC reverse-lookup Bug-Fix dccp ccid-2: Bug-Fix - Ack Vectors need to be ignored on request sockets dccp: Fix sparse warnings dccp ccid-3: Bug-Fix - Zero RTT is possible
2008-06-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5091/1: Add missing bitfield include to regs-lcd.h [ARM] 5090/1: Correct pxafb palette typo error [ARM] 5077/1: spi: fix list scan success verification in PXA ssp driver
2008-06-12pagemap: pass mm into pagewalkersDave Hansen
We need this at least for huge page detection for now, because powerpc needs the vm_area_struct to be able to determine whether a virtual address is referring to a huge page (its pmd_huge() doesn't work). It might also come in handy for some of the other users. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12cciss: add new hardware supportMike Miller
Add support for the next generation of HP Smart Array SAS/SATA controllers. Shipping date is late Fall 2008. Bump the driver version to 3.6.20 to reflect the new hardware support from patch 1 of this set. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12proc_fs.h: move struct mm_struct forward-declarationBen Nizette
Move the forward-declaration of struct mm_struct a little way up proc_fs.h. This fixes a bunch of "'struct mm_struct' declared inside parameter list" warnings with CONFIG_PROC_FS=n Signed-off-by: Ben Nizette <bn@niasdigital.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12m68k: Add ext2_find_{first,next}_bit() for ext4Aneesh Kumar K.V
Add ext2_find_{first,next}_bit(), which are needed for ext4. They're derived out of the ext2_find_next_zero_bit found in the same file. Compile tested with crosstools [Reworked to preserve all symmetry with ext2_find_{first,next}_zero_bit()] This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10393 [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12tcp: Revert 'process defer accept as established' changes.David S. Miller
This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87 ("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38 ("tcp: Fix slab corruption with ipv6 and tcp6fuzz"). This change causes several problems, first reported by Ingo Molnar as a distcc-over-loopback regression where connections were getting stuck. Ilpo Järvinen first spotted the locking problems. The new function added by this code, tcp_defer_accept_check(), only has the child socket locked, yet it is modifying state of the parent listening socket. Fixing that is non-trivial at best, because we can't simply just grab the parent listening socket lock at this point, because it would create an ABBA deadlock. The normal ordering is parent listening socket --> child socket, but this code path would require the reverse lock ordering. Next is a problem noticed by Vitaliy Gusev, he noted: ---------------------------------------- >--- a/net/ipv4/tcp_timer.c >+++ b/net/ipv4/tcp_timer.c >@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data) > goto death; > } > >+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) { >+ tcp_send_active_reset(sk, GFP_ATOMIC); >+ goto death; Here socket sk is not attached to listening socket's request queue. tcp_done() will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should release this sk) as socket is not DEAD. Therefore socket sk will be lost for freeing. ---------------------------------------- Finally, Alexey Kuznetsov argues that there might not even be any real value or advantage to these new semantics even if we fix all of the bugs: ---------------------------------------- Hiding from accept() sockets with only out-of-order data only is the only thing which is impossible with old approach. Is this really so valuable? My opinion: no, this is nothing but a new loophole to consume memory without control. ---------------------------------------- So revert this thing for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12Merge branch 'pci-for-jesse' of ↵Jesse Barnes
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip into for-linus
2008-06-12Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: 64-bit: fix arithmetics overflow sched: fair group: fix overflow(was: fix divide by zero) sched: fix TASK_WAKEKILL vs SIGKILL race
2008-06-12[ARM] 5091/1: Add missing bitfield include to regs-lcd.hStefan Schmidt
Macros like Fld() or FShft used in regs-lcd.h are defined in bitfield.h, but the latter is not included. Also fix one whitespace issue while being there. Signed-off-by: Antonio Ospite <ao2@openezx.org> Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-12Merge branch 'core/iter-div' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/iter-div' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: always_inline timespec_add_ns add an inlined version of iter_div_u64_rem common implementation of iterative div/mod
2008-06-12always_inline timespec_add_nstip-core-iter-div-2008-06-16_09.11_MonJeremy Fitzhardinge
timespec_add_ns is used from the x86-64 vdso, which cannot call out to other kernel code. Make sure that timespec_add_ns is always inlined (and only uses always_inlined functions) to make sure there are no unexpected calls. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12add an inlined version of iter_div_u64_remJeremy Fitzhardinge
iter_div_u64_rem is used in the x86-64 vdso, which cannot call other kernel code. For this case, provide the always_inlined version, __iter_div_u64_rem. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
