commit 3cea4c3071d4e55e9d7356efe9d0ebf92f0c2204 upstream.
Rename front_max field of struct ceph_msg to front_alloc_len to make
its purpose more clear.
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
commit 9566d6742852c527bf5af38af5cbb878dad75705 upstream.
While invesgiating the issue where in "mount --bind -oremount,ro ..."
would result in later "mount --bind -oremount,rw" succeeding even if
the mount started off locked I realized that there are several
additional mount flags that should be locked and are not.
In particular MNT_NOSUID, MNT_NODEV, MNT_NOEXEC, and the atime
flags in addition to MNT_READONLY should all be locked. These
flags are all per superblock, can all be changed with MS_BIND,
and should not be changable if set by a more privileged user.
The following additions to the current logic are added in this patch.
- nosuid may not be clearable by a less privileged user.
- nodev may not be clearable by a less privielged user.
- noexec may not be clearable by a less privileged user.
- atime flags may not be changeable by a less privileged user.
The logic with atime is that always setting atime on access is a
global policy and backup software and auditing software could break if
atime bits are not updated (when they are configured to be updated),
and serious performance degradation could result (DOS attack) if atime
updates happen when they have been explicitly disabled. Therefore an
unprivileged user should not be able to mess with the atime bits set
The additional restrictions are implemented with the addition of
MNT_LOCK_NOSUID, MNT_LOCK_NODEV, MNT_LOCK_NOEXEC, and MNT_LOCK_ATIME
mnt flags.
Taken together these changes and the fixes for MNT_LOCK_READONLY
should make it safe for an unprivileged user to create a user
namespace and to call "mount --bind -o remount,... ..." without
the danger of mount flags being changed maliciously.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
commit a6138db815df5ee542d848318e5dae681590fccd upstream.
Kenton Varda <kenton@sandstorm.io> discovered that by remounting a
read-only bind mount read-only in a user namespace the
MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user
to the remount a read-only mount read-write.
Correct this by replacing the mask of mount flags to preserve
with a mask of mount flags that may be changed, and preserve
all others. This ensures that any future bugs with this mask and
remount will fail in an easy to detect way where new mount flags
simply won't change.
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream.
The current code always selects XPRT_TRANSPORT_BC_TCP for the back
channel, even when the forward channel was not TCP (eg, RDMA). When
a 4.1 mount is attempted with RDMA, the server panics in the TCP BC
code when trying to send CB_NULL.
Instead, construct the transport protocol number from the forward
channel transport or'd with XPRT_TRANSPORT_BC. Transports that do
not support bi-directional RPC will not have registered a "BC"
transport, causing create_backchannel_client() to fail immediately.
Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 37dbeab788a8f23fd946c0be083e5484d6f929a1 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 04ca6973f7c1a0d8537f2d9906a0cf8e69886d75 ]
In "Counting Packets Sent Between Arbitrary Internet Hosts", Jeffrey and
Jedidiah describe ways exploiting linux IP identifier generation to
infer whether two machines are exchanging packets.
With commit 73f156a6e8c1 ("inetpeer: get rid of ip_id_count"), we
changed IP id generation, but this does not really prevent this
side-channel technique.
This patch adds a random amount of perturbation so that IP identifiers
for a given destination [1] are no longer monotonically increasing after
an idle period.
Note that prandom_u32_max(1) returns 0, so if generator is used at most
once per jiffy, this patch inserts no hole in the ID suite and do not
increase collision probability.
This is jiffies based, so in the worst case (HZ=1000), the id can
rollover after ~65 seconds of idle time, which should be fine.
We also change the hash used in __ip_select_ident() to not only hash
on daddr, but also saddr and protocol, so that ICMP probes can not be
used to infer information for other protocols.
For IPv6, adds saddr into the hash as well, but not nexthdr.
If I ping the patched target, we can see ID are now hard to predict.
21:57:11.008086 IP (...)
A > target: ICMP echo request, seq 1, length 64
21:57:11.010752 IP (... id 2081 ...)
target > A: ICMP echo reply, seq 1, length 64
21:57:12.013133 IP (...)
A > target: ICMP echo request, seq 2, length 64
21:57:12.015737 IP (... id 3039 ...)
target > A: ICMP echo reply, seq 2, length 64
21:57:13.016580 IP (...)
A > target: ICMP echo request, seq 3, length 64
21:57:13.019251 IP (... id 3437 ...)
target > A: ICMP echo reply, seq 3, length 64
[1] TCP sessions uses a per flow ID generator not changed by this patch.
Reported-by: Jeffrey Knockel <jeffk@cs.unm.edu>
Reported-by: Jedidiah R. Crandall <crandall@cs.unm.edu>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Hannes Frederic Sowa <hannes@redhat.com>
[ Upstream commit 73f156a6e8c1074ac6327e0abd1169e95eb66463 ]
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
commit aac74dc495456412c4130a1167ce4beb6c1f0b38 upstream.
After learning we'll need some sort of deferred printk functionality in
the timekeeping core, Peter suggested we rename the printk_sched function
so it can be reused by needed subsystems.
This only changes the function name. No logic changes.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jiri Bohac <jbohac@suse.cz>
commit 1a112d10f03e83fb3a2fdc4c9165865dec8a3ca6 upstream.
1871ee134b73 ("libata: support the ata host which implements a queue
depth less than 32") directly used ata_port->scsi_host->can_queue from
ata_qc_new() to determine the number of tags supported by the host;
unfortunately, SAS controllers doing SATA don't initialize ->scsi_host
leading to the following oops.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
PGD 0
Oops: 0002 [#1] SMP
Modules linked in: isci libsas scsi_transport_sas mgag200 drm_kms_helper ttm
CPU: 1 PID: 518 Comm: udevd Not tainted 3.16.0-rc6+ #62
Hardware name: Intel Corporation S2600CO/S2600CO, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013
task: ffff880c1a00b280 ti: ffff88061a000000 task.ti: ffff88061a000000
RIP: 0010:[<ffffffff814e0618>] [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
RSP: 0018:ffff88061a003ae8 EFLAGS: 00010012
RAX: 0000000000000001 RBX: ffff88000241ca80 RCX: 00000000000000fa
RDX: 0000000000000020 RSI: 0000000000000020 RDI: ffff8806194aa298
RBP: ffff88061a003ae8 R08: ffff8806194a8000 R09: 0000000000000000
R10: 0000000000000000 R11: ffff88000241ca80 R12: ffff88061ad58200
R13: ffff8806194aa298 R14: ffffffff814e67a0 R15: ffff8806194a8000
FS: 00007f3ad7fe3840(0000) GS:ffff880627620000(0000) knlGS:0000000000000000
CR2: 0000000000000058 CR3: 000000061a118000 CR4: 00000000001407e0
Stack:
ffff88061a003b20 ffffffff814e96e1 ffff88000241ca80 ffff88061ad58200
ffff8800b6bf6000 ffff880c1c988000 ffff880619903850 ffff88061a003b68
ffffffffa0056ce1 ffff88061a003b48 0000000013d6e6f8 ffff88000241ca80
Call Trace:
[<ffffffff814e96e1>] ata_sas_queuecmd+0xa1/0x430
[<ffffffffa0056ce1>] sas_queuecommand+0x191/0x220 [libsas]
[<ffffffff8149afee>] scsi_dispatch_cmd+0x10e/0x300 [<ffffffff814a3bc5>] scsi_request_fn+0x2f5/0x550
[<ffffffff81317613>] __blk_run_queue+0x33/0x40
[<ffffffff8131781a>] queue_unplugged+0x2a/0x90
[<ffffffff8131ceb4>] blk_flush_plug_list+0x1b4/0x210
[<ffffffff8131d274>] blk_finish_plug+0x14/0x50
[<ffffffff8117eaa8>] __do_page_cache_readahead+0x198/0x1f0
[<ffffffff8117ee21>] force_page_cache_readahead+0x31/0x50
[<ffffffff8117ee7e>] page_cache_sync_readahead+0x3e/0x50
[<ffffffff81172ac6>] generic_file_read_iter+0x496/0x5a0
[<ffffffff81219897>] blkdev_read_iter+0x37/0x40
[<ffffffff811e307e>] new_sync_read+0x7e/0xb0
[<ffffffff811e3734>] vfs_read+0x94/0x170
[<ffffffff811e43c6>] SyS_read+0x46/0xb0
[<ffffffff811e33d1>] ? SyS_lseek+0x91/0xb0
[<ffffffff8171ee29>] system_call_fastpath+0x16/0x1b
Code: 00 00 00 88 50 29 83 7f 08 01 19 d2 83 e2 f0 83 ea 50 88 50 34 c6 81 1d 02 00 00 40 c6 81 17 02 00 00 00 5d c3 66 0f 1f 44 00 00 <89> 14 25 58 00 00 00
Fix it by introducing ata_host->n_tags which is initialized to
ATA_MAX_QUEUE - 1 in ata_host_init() for SAS controllers and set to
scsi_host_template->can_queue in ata_host_register() for !SAS ones.
As SAS hosts are never registered, this will give them the same
ATA_MAX_QUEUE - 1 as before. Note that we can't use
scsi_host->can_queue directly for SAS hosts anyway as they can go
higher than the libata maximum.
Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Reported-by: Jesse Brandeburg <jesse.brandeburg@gmail.com>
Reported-by: Peter Hurley <peter@hurleysoftware.com>
Reported-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Fixes: 1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32")
Cc: Kevin Hao <haokexin@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
[ Upstream commit 5925a0555bdaf0b396a84318cbc21ba085f6c0d3 ]
sk_dst_cache has __rcu annotation, so we need a cast to avoid
following sparse error :
include/net/sock.h:1774:19: warning: incorrect type in initializer (different address spaces)
include/net/sock.h:1774:19: expected struct dst_entry [noderef] <asn:4>*__ret
include/net/sock.h:1774:19: got struct dst_entry *dst
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Fixes: 7f502361531e ("ipv4: irq safe sk_dst_[re]set() and ipv4_sk_update_pmtu() fix")
[ Upstream commit 7f502361531e9eecb396cf99bdc9e9a59f7ebd7f ]
We have two different ways to handle changes to sk->sk_dst
First way (used by TCP) assumes socket lock is owned by caller, and use
no extra lock : __sk_dst_set() & __sk_dst_reset()
Another way (used by UDP) uses sk_dst_lock because socket lock is not
always taken. Note that sk_dst_lock is not softirq safe.
These ways are not inter changeable for a given socket type.
ipv4_sk_update_pmtu(), added in linux-3.8, added a race, as it used
the socket lock as synchronization, but users might be UDP sockets.
Instead of converting sk_dst_lock to a softirq safe version, use xchg()
as we did for sk_rx_dst in commit e47eb5dfb296b ("udp: ipv4: do not use
sk_dst_lock from softirq context")
In a follow up patch, we probably can remove sk_dst_lock, as it is
only used in IPv6.
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Fixes: 9cb3a50c5f63e ("ipv4: Invalidate the socket cached route on pmtu events if possible")
[ Upstream commit f88649721268999bdff09777847080a52004f691 ]
When IP route cache had been removed in linux-3.6, we broke assumption
that dst entries were all freed after rcu grace period. DST_NOCACHE
dst were supposed to be freed from dst_release(). But it appears
we want to keep such dst around, either in UDP sockets or tunnels.
In sk_dst_get() we need to make sure dst refcount is not 0
before incrementing it, or else we might end up freeing a dst
twice.
DST_NOCACHE set on a dst does not mean this dst can not be attached
to a socket or a tunnel.
Then, before actual freeing, we need to observe a rcu grace period
to make sure all other cpus can catch the fact the dst is no longer
usable.
Reported-by: Dormando <dormando@rydia.net>
commit 8b8b36834d0fff67fc8668093f4312dd04dcf21d upstream.
The per_cpu buffers are created one per possible CPU. But these do
not mean that those CPUs are online, nor do they even exist.
With the addition of the ring buffer polling, it assumes that the
caller polls on an existing buffer. But this is not the case if
the user reads trace_pipe from a CPU that does not exist, and this
causes the kernel to crash.
Simple fix is to check the cpu against buffer bitmask against to see
if the buffer was allocated or not and return -ENODEV if it is
not.
More updates were done to pass the -ENODEV back up to userspace.
Link: http://lkml.kernel.org/r/5393DB61.6060707@oracle.com
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 4af4206be2bd1933cae20c2b6fb2058dbc887f7c upstream.
syscall_regfunc() and syscall_unregfunc() should set/clear
TIF_SYSCALL_TRACEPOINT system-wide, but do_each_thread() can race
with copy_process() and miss the new child which was not added to
the process/thread lists yet.
Change copy_process() to update the child's TIF_SYSCALL_TRACEPOINT
under tasklist.
Link: http://lkml.kernel.org/p/20140413185854.GB20668@redhat.com
Fixes: a871bd33a6c0 "tracing: Add syscall tracepoints"
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
commit b9cd18de4db3c9ffa7e17b0dc0ca99ed5aa4d43a upstream.
The 'sysret' fastpath does not correctly restore even all regular
registers, much less any segment registers or reflags values. That is
very much part of why it's faster than 'iret'.
Normally that isn't a problem, because the normal ptrace() interface
catches the process using the signal handler infrastructure, which
always returns with an iret.
However, some paths can get caught using ptrace_event() instead of the
signal path, and for those we need to make sure that we aren't going to
return to user space using 'sysret'. Otherwise the modifications that
may have been done to the register set by the tracer wouldn't
necessarily take effect.
Fix it by forcing IRET path by setting TIF_NOTIFY_RESUME from
arch_ptrace_stop_needed() which is invoked from ptrace_stop().
Reported-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 1e77d0a1ed7417d2a5a52a7b8d32aea1833faa6c upstream.
Till reported that the spurious interrupt detection of threaded
interrupts is broken in two ways:
- note_interrupt() is called for each action thread of a shared
interrupt line. That's wrong as we are only interested whether none
of the device drivers felt responsible for the interrupt, but by
calling multiple times for a single interrupt line we account
IRQ_NONE even if one of the drivers felt responsible.
- note_interrupt() when called from the thread handler is not
serialized. That leaves the members of irq_desc which are used for
the spurious detection unprotected.
To solve this we need to defer the spurious detection of a threaded
interrupt to the next hardware interrupt context where we have
implicit serialization.
If note_interrupt is called with action_ret == IRQ_WAKE_THREAD, we
check whether the previous interrupt requested a deferred check. If
not, we request a deferred check for the next hardware interrupt and
return.
If set, we check whether one of the interrupt threads signaled
success. Depending on this information we feed the result into the
spurious detector.
If one primary handler of a shared interrupt returns IRQ_HANDLED we
disable the deferred check of irq threads on the same line, as we have
found at least one device driver who cared.
Reported-by: Till Straumann <strauman@slac.stanford.edu>
Tested-by: Austin Schuh <austin@peloton-tech.com>
Cc: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: linux-can@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1303071450130.22263@ionos
commit 2426bd456a61407388b6e61fc5f98dbcbebc50e2 upstream.
When an initiator sends an allocation length bigger than what its
command consumes, the target should only return the actual response data
and set the residual length to the unused part of the allocation length.
Add a helper function that command handlers (INQUIRY, READ CAPACITY,
etc) can use to do this correctly, and use this code to get the correct
residual for commands that don't use the full initiator allocation in the
handlers for READ CAPACITY, READ CAPACITY(16), INQUIRY, MODE SENSE and
REPORT LUNS.
This addresses a handful of failures as reported by Christophe with
the Windows Certification Kit:
http://permalink.gmane.org/gmane.linux.scsi.target.devel/6515
Signed-off-by: Roland Dreier <roland@purestorage.com>
Tested-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr>
commit 4e52365f279564cef0ddd41db5237f0471381093 upstream.
When tracing a process in another pid namespace, it's important for fork
event messages to contain the child's pid as seen from the tracer's pid
namespace, not the parent's. Otherwise, the tracer won't be able to
correlate the fork event with later SIGTRAP signals it receives from the
child.
We still risk a race condition if a ptracer from a different pid
namespace attaches after we compute the pid_t value. However, sending a
bogus fork event message in this unlikely scenario is still a vast
improvement over the status quo where we always send bogus fork event
messages to debuggers in a different pid namespace than the forking
process.
Signed-off-by: Matthew Dempsky <mdempsky@chromium.org>
Cc: Julien Tinnes <jln@chromium.org>
Cc: Roland McGrath <mcgrathr@chromium.org>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
commit 07f4d9d74a04aa7c72c5dae0ef97565f28f17b92 upstream.
The user-control put and get handlers as well as the tlv do not protect against
concurrent access from multiple threads. Since the state of the control is not
updated atomically it is possible that either two write operations or a write
and a read operation race against each other. Both can lead to arbitrary memory
disclosure. This patch introduces a new lock that protects user-controls from
concurrent access. Since applications typically access controls sequentially
than in parallel a single lock per card should be fine.
Acked-by: Jaroslav Kysela <perex@perex.cz>
struct for all platform.
commit 2bd0ae464a6cf7363bbf72c8545e0aa43caa57f0 upstream.
Cancel the optimization of compiler for struct snd_compr_avail
which size will be 0x1c in 32bit kernel while 0x20 in 64bit
kernel under the optimizer. That will make compaction between
32bit and 64bit. So add packed to fix the size of struct
snd_compr_avail to 0x1c for all platform.
Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com>
Signed-off-by: xiaoming wang <xiaoming.wang@intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 9d0d68faea6962d62dd501cd6e71ce5cc8ed262b ]
Now it is not possible to set mtu to team device which has a port
enslaved to it. The reason is that when team_change_mtu() calls
dev_set_mtu() for port device, notificator for NETDEV_PRECHANGEMTU
event is called and team_device_event() returns NOTIFY_BAD forbidding
the change. So fix this by returning NOTIFY_DONE here in case team is
changing mtu in team_change_mtu().
Introduced-by: 3d249d4c "net: introduce ethernet teaming device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 39c36094d78c39e038c1e499b2364e13bce36f54 ]
I noticed we were sending wrong IPv4 ID in TCP flows when MTU discovery
is disabled.
Note how GSO/TSO packets do not have monotonically incrementing ID.
06:37:41.575531 IP (id 14227, proto: TCP (6), length: 4396)
06:37:41.575534 IP (id 14272, proto: TCP (6), length: 65212)
06:37:41.575544 IP (id 14312, proto: TCP (6), length: 57972)
06:37:41.575678 IP (id 14317, proto: TCP (6), length: 7292)
06:37:41.575683 IP (id 14361, proto: TCP (6), length: 63764)
It appears I introduced this bug in linux-3.1.
inet_getid() must return the old value of peer->ip_id_count,
not the new one.
Lets revert this part, and remove the prevention of
a null identification field in IPv6 Fragment Extension Header,
which is dubious and not even done properly.
Fixes: 87c48fa3b463 ("ipv6: make fragment identifications less predictable")
[ Upstream commit 2d7a85f4b06e9c27ff629f07a524c48074f07f81 ]
It was possible to get a setuid root or setcap executable to write to
it's stdout or stderr (which has been set made a netlink socket) and
inadvertently reconfigure the networking stack.
To prevent this we check that both the creator of the socket and
the currentl applications has permission to reconfigure the network
stack.
Unfortunately this breaks Zebra which always uses sendto/sendmsg
and creates it's socket without any privileges.
To keep Zebra working don't bother checking if the creator of the
socket has privilege when a destination address is specified. Instead
rely exclusively on the privileges of the sender of the socket.
Note from Andy: This is exactly Eric's code except for some comment
clarifications and formatting fixes. Neither I nor, I think, anyone
else is thrilled with this approach, but I'm hesitant to wait on a
better fix since 3.15 is almost here.
Note to stable maintainers: This is a mess. An earlier series of
patches in 3.15 fix a rather serious security issue (CVE-2014-0181),
but they did so in a way that breaks Zebra. The offending series
includes:
commit aa4cf9452f469f16cea8c96283b641b4576d4a7b
Author: Eric W. Biederman <ebiederm@xmission.com>
Date: Wed Apr 23 14:28:03 2014 -0700
net: Add variants of capable for use on netlink messages
If a given kernel version is missing that series of fixes, it's
probably worth backporting it and this patch. if that series is
present, then this fix is critical if you care about Zebra.
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit aa4cf9452f469f16cea8c96283b641b4576d4a7b ]
netlink_net_capable - The common case use, for operations that are safe on a network namespace
netlink_capable - For operations that are only known to be safe for the global root
netlink_ns_capable - The general case of capable used to handle special cases
__netlink_ns_capable - Same as netlink_ns_capable except taking a netlink_skb_parms instead of
the skbuff of a netlink message.
[ Upstream commit a3b299da869d6e78cf42ae0b1b41797bcb8c5e4b ]
sk_net_capable - The common case, operations that are safe in a network namespace.
sk_capable - Operations that are not known to be safe in a network namespace
sk_ns_capable - The general case for special cases.
[ Upstream commit a53b72c83a4216f2eb883ed45a0cbce014b8e62d ]
The permission check in sock_diag_put_filterinfo is wrong, and it is so removed
from it's sources it is not clear why it is wrong. Move the computation
into packet_diag_dump and pass a bool of the result into sock_diag_filterinfo.
This does not yet correct the capability check but instead simply moves it to make
it clear what is going on.
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream.
This patch keeps track of how long perf's NMI handler is taking,
and also calculates how many samples perf can take a second. If
the sample length times the expected max number of samples
exceeds a configurable threshold, it drops the sample rate.
This way, we don't have a runaway sampling process eating up the
CPU.
This patch can tend to drop the sample rate down to level where
perf doesn't work very well. *BUT* the alternative is that my
system hangs because it spends all of its time handling NMIs.
I'll take a busted performance tool over an entire system that's
busted and undebuggable any day.
BTW, my suspicion is that there's still an underlying bug here.
Using the HPET instead of the TSC is definitely a contributing
factor, but I suspect there are some other things going on.
But, I can't go dig down on a bug like that with my machine
hanging all the time.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: paulus@samba.org
Cc: acme@ghostprotocols.net
Cc: Dave Hansen <dave@sr71.net>
[ Prettified it a bit. ]
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit 7ac3764fcafc06e72e1a79a9d998b9fdd900b2a6 upstream.
The file include/uapi/linux/usb/cdc-wdm.h uses a __u16 so it needs to
include types.h as well to make the build system happy.
Fixes: 3edce1cf813a ("USB: cdc-wdm: implement IOCTL_WDM_MAX_COMMAND")
Cc: Bjørn Mork <bjorn@mork.no>
commit 7d1896360f4d055d68565ef8ed56a677580f1a39 upstream.
The include/uapi/linux/usb/cdc-wdm.h header defines cdc-wdm
userspace APIs and should be exported by make headers_install.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 4c88d7f9b0d5fb0588c3386be62115cc2eaa8f9f upstream.
Patch 01f8fa4f01d "genirq: Allow forcing cpu affinity of interrupts" added
an irq_force_affinity() function, and 30ccf03b4a6 "clocksource: Exynos_mct:
Use irq_force_affinity() in cpu bringup" subsequently uses it. However, the
driver can be used with CONFIG_SMP disabled, but the function declaration
is only available for CONFIG_SMP, leading to this build error:
drivers/clocksource/exynos_mct.c:431:3: error: implicit declaration of function 'irq_force_affinity' [-Werror=implicit-function-declaration]
irq_force_affinity(mct_irqs[MCT_L0_IRQ + cpu], cpumask_of(cpu));
This patch introduces a dummy helper function for the non-SMP case
that always returns success, to get rid of the build error.
Since the patches causing the problem are marked for stable backports,
this one should be as well.
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Link: http://lkml.kernel.org/r/5619084.0zmrrIUZLV@wuerfel
commit 098507ae3ec2331476fb52e85d4040c1cc6d0ef4 upstream.
The replacement of the 'count' variable by two variables 'incs' and
'decs' to resolve some race conditions during module unloading was done
in parallel with some cleanup in the trace subsystem, and was integrated
as a merge.
Unfortunately, the formula for this replacement was wrong in the tracing
code, and the refcount in the traces was not usable as a result.
Use 'count = incs - decs' to compute the user count.
Link: http://lkml.kernel.org/p/1393924179-9147-1-git-send-email-romain.izard.pro@gmail.com
Acked-by: Ingo Molnar <mingo@kernel.org>
Fixes: c1ab9cab7509 "merge conflict resolution"
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
commit 03367ef5ea811475187a0732aada068919e14d61 upstream.
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality
is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the
VMBUS protocol.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit cbfbbabb89b37f6bad05f478d906a385149f288d upstream.
The version of the drm_tegra_submit structure that was merged all the
way back in 3.10 contains a pad field that was originally intended to
properly pad the following __u64 field. Unfortunately it seems like a
different field was dropped during review that caused this padding to
become unnecessary, but the pad field wasn't removed at that time.
One possible side-effect of this is that since the __u64 following the
pad is now no longer properly aligned, the compiler may (or may not)
introduce padding itself, which results in no predictable ABI.
Rectify this by removing the pad field so that all fields are again
naturally aligned. Technically this is breaking existing userspace ABI,
but given that there aren't any (released) userspace drivers that make
use of this yet, the fallout should be minimal.
Fixes: d43f81cbaf43 ("drm/tegra: Add gr2d device")
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream.
The current implementation of irq_set_affinity() refuses rightfully to
route an interrupt to an offline cpu.
But there is a special case, where this is actually desired. Some of
the ARM SoCs have per cpu timers which require setting the affinity
during cpu startup where the cpu is not yet in the online mask.
If we can't do that, then the local timer interrupt for the about to
become online cpu is routed to some random online cpu.
The developers of the affected machines tried to work around that
issue, but that results in a massive mess in that timer code.
We have a yet unused argument in the set_affinity callbacks of the irq
chips, which I added back then for a similar reason. It was never
required so it got not used. But I'm happy that I never removed it.
That allows us to implement a sane handling of the above scenario. So
the affected SoC drivers can add the required force handling to their
interrupt chip, switch the timer code to irq_force_affinity() and
things just work.
This does not affect any existing user of irq_set_affinity().
Tagged for stable to allow a simple fix of the affected SoC clock
event drivers.
Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>,
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>,
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: linux-arm-kernel@lists.infradead.org,
Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de
commit a949ae560a511fe4e3adf48fa44fefded93e5c2b upstream.
A race exists between module loading and enabling of function tracer.
CPU 1 CPU 2
load_module()
module->state = MODULE_STATE_COMING
register_ftrace_function()
mutex_lock(&ftrace_lock);
ftrace_startup()
update_ftrace_function();
ftrace_arch_code_modify_prepare()
set_all_module_text_rw();
<enables-ftrace>
ftrace_arch_code_modify_post_process()
set_all_module_text_ro();
[ here all module text is set to RO,
including the module that is
loading!! ]
blocking_notifier_call_chain(MODULE_STATE_COMING);
ftrace_init_module()
[ tries to modify code, but it's RO, and fails!
ftrace_bug() is called]
When this race happens, ftrace_bug() will produces a nasty warning and
all of the function tracing features will be disabled until reboot.
The simple solution is to treate module load the same way the core
kernel is treated at boot. To hardcode the ftrace function modification
of converting calls to mcount into nops. This is done in init/main.c
there's no reason it could not be done in load_module(). This gives
a better control of the changes and doesn't tie the state of the
module to its notifiers as much. Ftrace is special, it needs to be
treated as such.
The reason this would work, is that the ftrace_module_init() would be
called while the module is in MODULE_STATE_UNFORMED, which is ignored
by the set_all_module_text_ro() call.
Link: http://lkml.kernel.org/r/1395637826-3312-1-git-send-email-indou.takao@jp.fujitsu.com
Reported-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
[ Upstream commit 78541c1dc60b65ecfce5a6a096fc260219d6784e ]
The caller needs capabilities on the namespace being queried, not on
their own namespace. This is a security bug, although it likely has
only a minor impact.
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit b14878ccb7fac0242db82720b784ab62c467c0dc ]
Currently, it is possible to create an SCTP socket, then switch
auth_enable via sysctl setting to 1 and crash the system on connect:
Oops[#1]:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.1-mipsgit-20140415 #1
task: ffffffff8056ce80 ti: ffffffff8055c000 task.ti: ffffffff8055c000
Call Trace:
[<ffffffff8043c4e8>] sctp_auth_asoc_set_default_hmac+0x68/0x80
[<ffffffff8042b300>] sctp_process_init+0x5e0/0x8a4
[<ffffffff8042188c>] sctp_sf_do_5_1B_init+0x234/0x34c
[<ffffffff804228c8>] sctp_do_sm+0xb4/0x1e8
[<ffffffff80425a08>] sctp_endpoint_bh_rcv+0x1c4/0x214
[<ffffffff8043af68>] sctp_rcv+0x588/0x630
[<ffffffff8043e8e8>] sctp6_rcv+0x10/0x24
[<ffffffff803acb50>] ip6_input+0x2c0/0x440
[<ffffffff8030fc00>] __netif_receive_skb_core+0x4a8/0x564
[<ffffffff80310650>] process_backlog+0xb4/0x18c
[<ffffffff80313cbc>] net_rx_action+0x12c/0x210
[<ffffffff80034254>] __do_softirq+0x17c/0x2ac
[<ffffffff800345e0>] irq_exit+0x54/0xb0
[<ffffffff800075a4>] ret_from_irq+0x0/0x4
[<ffffffff800090ec>] rm7k_wait_irqoff+0x24/0x48
[<ffffffff8005e388>] cpu_startup_entry+0xc0/0x148
[<ffffffff805a88b0>] start_kernel+0x37c/0x398
Code: dd0900b8 000330f8 0126302d <dcc60000> 50c0fff1 0047182a a48306a0
03e00008 00000000
---[ end trace b530b0551467f2fd ]---
Kernel panic - not syncing: Fatal exception in interrupt
What happens while auth_enable=0 in that case is, that
ep->auth_hmacs is initialized to NULL in sctp_auth_init_hmacs()
when endpoint is being created.
After that point, if an admin switches over to auth_enable=1,
the machine can crash due to NULL pointer dereference during
reception of an INIT chunk. When we enter sctp_process_init()
via sctp_sf_do_5_1B_init() in order to respond to an INIT chunk,
the INIT verification succeeds and while we walk and process
all INIT params via sctp_process_param() we find that
net->sctp.auth_enable is set, therefore do not fall through,
but invoke sctp_auth_asoc_set_default_hmac() instead, and thus,
dereference what we have set to NULL during endpoint
initialization phase.
The fix is to make auth_enable immutable by caching its value
during endpoint initialization, so that its original value is
being carried along until destruction. The bug seems to originate
from the very first days.
Fix in joint work with Daniel Borkmann.
Reported-by: Joshua Kinard <kumba@gentoo.org>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Joshua Kinard <kumba@gentoo.org>
[ Upstream commit 30f78d8ebf7f514801e71b88a10c948275168518 ]
Francois reported that setting big mtu on loopback device could prevent
tcp sessions making progress.
We do not support (yet ?) IPv6 Jumbograms and cook corrupted packets.
We must limit the IPv6 MTU to (65535 + 40) bytes in theory.
Tested:
ifconfig lo mtu 70000
netperf -H ::1
Before patch : Throughput : 0.05 Mbits
After patch : Throughput : 35484 Mbits
Reported-by: Francois WELLENREITER <f.wellenreiter@gmail.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 008208c6b26f21c2648c250a09c55e737c02c5f8 ]
Add two trivial helpers list_next_entry() and list_prev_entry(), they
can have a lot of users including list.h itself. In fact the 1st one is
already defined in events/core.c and bnx2x_sp.c, so the patch simply
moves the definition to list.h.
Cc: Eilon Greenstein <eilong@broadcom.com>
commit 29c7787075c92ca8af353acd5301481e6f37082f upstream.
David Vrabel identified a regression when using automatic NUMA balancing
under Xen whereby page table entries were getting corrupted due to the
use of native PTE operations. Quoting him
Xen PV guest page tables require that their entries use machine
addresses if the preset bit (_PAGE_PRESENT) is set, and (for
successful migration) non-present PTEs must use pseudo-physical
addresses. This is because on migration MFNs in present PTEs are
translated to PFNs (canonicalised) so they may be translated back
to the new MFN in the destination domain (uncanonicalised).
pte_mknonnuma(), pmd_mknonnuma(), pte_mknuma() and pmd_mknuma()
set and clear the _PAGE_PRESENT bit using pte_set_flags(),
pte_clear_flags(), etc.
In a Xen PV guest, these functions must translate MFNs to PFNs
when clearing _PAGE_PRESENT and translate PFNs to MFNs when setting
_PAGE_PRESENT.
His suggested fix converted p[te|md]_[set|clear]_flags to using
paravirt-friendly ops but this is overkill. He suggested an alternative
of using p[te|md]_modify in the NUMA page table operations but this is
does more work than necessary and would require looking up a VMA for
protections.
This patch modifies the NUMA page table operations to use paravirt
friendly operations to set/clear the flags of interest. Unfortunately
this will take a performance hit when updating the PTEs on
CONFIG_PARAVIRT but I do not see a way around it that does not break
Xen.
Acked-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Steven Noonan <steven@uplinklabs.net>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
commit 223b02d923ecd7c84cf9780bb3686f455d279279 upstream.
"len" contains sizeof(nf_ct_ext) and size of extensions. In a worst
case it can contain all extensions. Bellow you can find sizes for all
types of extensions. Their sum is definitely bigger than 256.
nf_ct_ext_types[0]->len = 24
nf_ct_ext_types[1]->len = 32
nf_ct_ext_types[2]->len = 24
nf_ct_ext_types[3]->len = 32
nf_ct_ext_types[4]->len = 152
nf_ct_ext_types[5]->len = 2
nf_ct_ext_types[6]->len = 16
nf_ct_ext_types[7]->len = 8
I have seen "len" up to 280 and my host has crashes w/o this patch.
The right way to fix this problem is reducing the size of the ecache
extension (4) and Florian is going to do this, but these changes will
be quite large to be appropriate for a stable tree.
Fixes: 5b423f6a40a0 (netfilter: nf_conntrack: fix racy timer handling with reliable)
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
commit af5040da01ef980670b3741b3e10733ee3e33566 upstream.
trace_block_rq_complete does not take into account that request can
be partially completed, so we can get the following incorrect output
of blkparser:
C R 232 + 240 [0]
C R 240 + 232 [0]
C R 248 + 224 [0]
C R 256 + 216 [0]
but should be:
C R 232 + 8 [0]
C R 240 + 8 [0]
C R 248 + 8 [0]
C R 256 + 8 [0]
Also, the whole output summary statistics of completed requests and
final throughput will be incorrect.
This patch takes into account real completion size of the request and
fixes wrong completion accounting.
Signed-off-by: Roman Pen <r.peniaev@gmail.com>
CC: Steven Rostedt <rostedt@goodmis.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
CC: Ingo Molnar <mingo@redhat.com>
CC: linux-kernel@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
commit e63ed0d7a98014fdfc2cfeb3f6dada313dcabb59 upstream.
This patch eliminates the reap_ref and replaces it with a proper kref.
On last put of this kref, the target is removed from visibility in
sysfs. The final call to scsi_target_reap() for the device is done from
__scsi_remove_device() and only if the device was made visible. This
ensures that the target disappears as soon as the last device is gone
rather than waiting until final release of the device (which is often
too long).
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 8a4aeec8d2d6a3edeffbdfae451cdf05cbf0fefd upstream.
The AHCI spec allows implementations to issue commands in tag order
rather than FIFO order:
5.3.2.12 P:SelectCmd
HBA sets pSlotLoc = (pSlotLoc + 1) mod (CAP.NCS + 1)
or HBA selects the command to issue that has had the
PxCI bit set to '1' longer than any other command
pending to be issued.
The result is that commands posted sequentially (time-wise) may play out
of sequence when issued by hardware.
This behavior has likely been hidden by drives that arrange for commands
to complete in issue order. However, it appears recent drives (two from
different vendors that we have found so far) inflict out-of-order
completions as a matter of course. So, we need to take care to maintain
ordered submission, otherwise we risk triggering a drive to fall out of
sequential-io automation and back to random-io processing, which incurs
large latency and degrades throughput.
This issue was found in simple benchmarks where QD=2 seq-write
performance was 30-50% *greater* than QD=32 seq-write performance.
Tagging for -stable and making the change globally since it has a low
risk-to-reward ratio. Also, word is that recent versions of an unnamed
OS also does it this way now. So, drives in the field are already
experienced with this tag ordering scheme.
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Ed Ciechanowski <ed.ciechanowski@intel.com>
Reviewed-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
commit 3064639423c48d6e0eb9ecc27c512a58e38c6c57 upstream.
There could be a case, when NFSd file system is mounted in network, different
to socket's one, like below:
"ip netns exec" creates new network and mount namespace, which duplicates NFSd
mount point, created in init_net context. And thus NFS server stop in nested
network context leads to RPCBIND client destruction in init_net.
Then, on NFSd start in nested network context, rpc.nfsd process creates socket
in nested net and passes it into "write_ports", which leads to RPCBIND sockets
creation in init_net context because of the same reason (NFSd monut point was
created in init_net context). An attempt to register passed socket in nested
net leads to panic, because no RPCBIND client present in nexted network
namespace.
This patch add check that passed socket's net matches NFSd superblock's one.
And returns -EINVAL error to user psace otherwise.
v2: Put socket on exit.
Reported-by: Weng Meiling <wengmeiling.weng@huawei.com>
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
commit 5acda9d12dcf1ad0d9a5a2a7c646de3472fa7555 upstream.
After commit 839a8e8660b6 ("writeback: replace custom worker pool
implementation with unbound workqueue") when device is removed while we
are writing to it we crash in bdi_writeback_workfn() ->
set_worker_desc() because bdi->dev is NULL.
This can happen because even though bdi_unregister() cancels all pending
flushing work, nothing really prevents new ones from being queued from
balance_dirty_pages() or other places.
Fix the problem by clearing BDI_registered bit in bdi_unregister() and
checking it before scheduling of any flushing work.
Fixes: 839a8e8660b6777e7fe4e80af1a048aebe2b5977
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: Derek Basehore <dbasehore@chromium.org>
commit 95731ebb114c5f0c028459388560fc2a72fe5049 upstream.
Cpufreq governors' stop and start operations should be carried out
in sequence. Otherwise, there will be unexpected behavior, like in
the example below.
Suppose there are 4 CPUs and policy->cpu=CPU0, CPU1/2/3 are linked
to CPU0. The normal sequence is:
1) Current governor is userspace. An application tries to set the
governor to ondemand. It will call __cpufreq_set_policy() in
which it will stop the userspace governor and then start the
ondemand governor.
2) Current governor is userspace. The online of CPU3 runs on CPU0.
It will call cpufreq_add_policy_cpu() in which it will first
stop the userspace governor, and then start it again.
If the sequence of the above two cases interleaves, it becomes:
1) Application stops userspace governor
2) Hotplug stops userspace governor
which is a problem, because the governor shouldn't be stopped twice
in a row. What happens next is:
3) Application starts ondemand governor
4) Hotplug starts a governor
In step 4, the hotplug is supposed to start the userspace governor,
but now the governor has been changed by the application to ondemand,
so the ondemand governor is started once again, which is incorrect.
The solution is to prevent policy governors from being stopped
multiple times in a row. A governor should only be stopped once for
one policy. After it has been stopped, no more governor stop
operations should be executed.
Also add a mutex to serialize governor operations.
[rjw: Changelog. And you owe me a beverage of my choice.]
Signed-off-by: Xiaoguang Chen <chenxg@marvell.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream.
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
[geert: Backported to v3.10..v3.13]
