drivers/net/wireless/rtlwifi/efuse.c
drivers/net/wireless/rtlwifi/rtl8192c/fw_common.c
net/bluetooth/mgmt.c
This allows user-space monitoring of BSS parameters for the associated
station. This is useful for debugging and verifying that the paramaters
are as expected.
[Exactly the same as before but bundled into a single message]
Signed-off-by: Paul Stewart <pstew@chromium.org>
Cc: Johannes Berg <johannes@sipsolutions.net>
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-next-2.6
This patch adds a new remote_name event to the Management interface
which is sent every time the name of a remote device is resolved (over
BR/EDR).
Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
This patch adds a device_found event to the Management interface. For
now the event only maps to BR/EDR inquiry result HCI events, but in the
future the plan is to also use it for the LE device discovery process.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
IEEE Std 802.11n, Oct. 29, 2009:
7.3.2.56.5 HT Extended Capabilities field
Signed-off-by: Bing Zhao <bzhao@marvell.com>
The description for buf_size was misleading and
just said you couldn't TX larger aggregates, but
of course you can't TX aggregates in a way that
would exceed the window either, which is possible
even if the aggregates are shorter than that.
Expand the description, thanks to Emmanuel for
explaining this to me.
Cc: Emmanuel Grumbach <egrumbach@gmail.com>
auth_hmacs field of struct sctp_cookie is used for store
Requested HMAC Algorithm Parameter, and each HMAC Identifier
is 2 bytes, so the length should be:
SCTP_AUTH_NUM_HMACS * sizeof(__u16) + 2
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
dev_ethtool_get_rx_csum() won't report rx checksumming when it's not
changeable and driver is converted to hw_features and friends. Fix this.
(dev->hw_features & NETIF_F_RXCSUM) check is dropped - if the
ethtool_ops->get_rx_csum is set, then driver is not coverted, yet.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
We can't send new commands before a cmd_complete for the HCI_RESET command
shows up.
Reported-by: Mikko Vinni <mmvinni@yahoo.com>
Reported-by: Justin P. Mattock <justinmattock@gmail.com>
Reported-by: Ed Tomlinson <edt@aei.ca>
Tested-by: Justin P. Mattock <justinmattock@gmail.com>
Tested-by: Mikko Vinni <mmvinni@yahoo.com>
Tested-by: Ed Tomlinson <edt@aei.ca>
This patch adds automated creation of the local EIR data based on what
16-bit UUIDs are registered and what the device name is. This should
cover the majority use cases, however things like 32/128-bit UUIDs, TX
power and Device ID will need to be added later to be on par with what
bluetoothd is capable of doing (without the Management interface).
This patch adds commands to add and remove remote OOB data to the managment
interface. Remote data is stored in kernel and can be used by corresponding
HCI commands and events when needed.
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
This patch adds a command to read local OOB data to the managment interface.
The command maps directly to the Read Local OOB Data HCI command.
num in struct l2cap_chan_list isn't used anywhere.
This patch adds a new set_local_name management command as well as a
local_name_changed management event. With these user space can both
change the local name as well as monitor changes to it by others.
This patch adds the name of the adapter to the reply of the read_info
management command.
The management messages reserve 249 bytes for the name instead of 248
(like in the HCI spec) so that there is always a guarantee that it is
nul-terminated. That way it can safely be passed onto string
manipulation functions.
This patch adds a clear define for the maximum device name length in HCI
messages and thereby avoids magic numbers in the code.
Commits 01a16b21 (netlink: kill eff_cap from struct netlink_skb_parms)
and c53fa1ed (netlink: kill loginuid/sessionid/sid members from struct
netlink_skb_parms) removed some members from struct netlink_skb_parms
that depend on the current context, all netlink users are now required
to do synchronous message processing.
connector however queues received messages and processes them in a work
queue, which is not valid anymore. This patch converts connector to do
synchronous message processing by invoking the registered callback handler
directly from the netlink receive function.
In order to avoid invoking the callback with connector locks held, a
reference count is added to struct cn_callback_entry, the reference
is taken when finding a matching callback entry on the device's queue_list
and released after the callback handler has been invoked.
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Don't flap VCs when carrier state changes; higher-level protocols
can detect loss of connectivity and act accordingly. This is more
consistent with how other network interfaces work.
We no longer use release_vccs() so we can delete it.
release_vccs() was duplicated from net/atm/common.c; make the
corresponding function exported, since other code duplicates it
and could leverage it if it were public.
Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com>
Indicate an NL80211_CMD_DEL_STATION event when a station entry in
mac80211 is deleted to match with the NL80211_CMD_NEW_STATION event
that is used when the entry was added. This is needed, e.g., to allow
user space to remove a peer from RSN IBSS Authenticator state machine
to avoid re-authentication and re-keying delays when the peer is not
reachable anymore.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
On some devices the correct MAC address is not in the EEPROM data, but
stored somewhere else.
This adds a driver for the CDC Ethernet part of this modem. The
device's ID is blacklisted in cdc_ether.c and is white-listed in
this new driver because of the quirks needed to make it useful.
The modem's firmware exposes a CDC ACM port for modem control and a
CDC Ethernet port for network data. The descriptors look fine but
both ports actually are some sort of multiplexers requiring non-
standard headers added/removed from every packet or they get
ignored. All information is based on a usb traffic log from a
Windows machine.
On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with
this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps.
Userspace scripts are required to talk to the CDC ACM port.
Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com>
My commit 6d55cb91a0020ac0 (gre: fix hard header destination
address checking) broke multicast.
The reason is that ip_gre used to get ipgre_header() calls with
zero destination if we have NOARP or multicast destination. Instead
the actual target was decided at ipgre_tunnel_xmit() time based on
per-protocol dissection.
Instead of allowing the "abuse" of ->header() calls with invalid
destination, this creates multicast mappings for ip_gre. This also
fixes "ip neigh show nud noarp" to display the proper multicast
mappings used by the gre device.
Reported-by: Doug Kehn <rdkehn@yahoo.com>
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Acked-by: Doug Kehn <rdkehn@yahoo.com>
After commit a715dea3c8e9ef2771c534e05ee1d36f65987e64 ("net: Always
allocate at least 16 skb frags regardless of page size"), the value
of MAX_SKB_FRAGS can now take on either an "unsigned long" or an
"int" value.
This causes warnings like:
net/packet/af_packet.c: In function ‘tpacket_fill_skb’:
net/packet/af_packet.c:948: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 2 has type ‘int’
Fix by forcing the constant to be unsigned long, otherwise we have
a situation where the type of a system wide constant is variable.
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (26 commits)
mmc: SDHI should depend on SUPERH || ARCH_SHMOBILE
mmc: tmio_mmc: Move some defines into a shared header
mmc: tmio: support aggressive clock gating
mmc: tmio: fix power-mode interpretation
mmc: tmio: remove work-around for unmasked SDIO interrupts
sh: fix SDHI IO address-range
ARM: mach-shmobile: fix SDHI IO address-range
mmc: tmio: only access registers above 0xff, if available
mfd: remove now redundant sh_mobile_sdhi.h header
sh: convert boards to use linux/mmc/sh_mobile_sdhi.h
ARM: mach-shmobile: convert boards to use linux/mmc/sh_mobile_sdhi.h
mmc: tmio: convert the SDHI MMC driver from MFD to a platform driver
sh: ecovec: use the CONFIG_MMC_TMIO symbols instead of MFD
mmc: tmio: split core functionality, DMA and MFD glue
mmc: tmio: use PIO for short transfers
mmc: tmio-mmc: Improve DMA stability on sh-mobile
mmc: fix mmc_app_send_scr() for dma transfer
mmc: sdhci-esdhc: enable esdhc on imx53
mmc: sdhci-esdhc: use writel/readl as general APIs
mmc: sdhci: add the abort CMDTYPE bits definition
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv
* 'frv' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv:
FRV: Use generic show_interrupts()
FRV: Convert genirq namespace
frv: Select GENERIC_HARDIRQS_NO_DEPRECATED
frv: Convert cpu irq_chip to new functions
frv: Convert mb93493 irq_chip to new functions
frv: Convert mb93093 irq_chip to new function
frv: Convert mb93091 irq_chip to new functions
frv: Fix typo from __do_IRQ overhaul
frv: Remove stale irq_chip.end
FRV: Do some cleanups
FRV: Missing node arg in alloc_thread_info_node() macro
NOMMU: implement access_remote_vm
NOMMU: support SMP dynamic percpu_alloc
NOMMU: percpu should use is_vmalloc_addr().
* 'irq-final-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (111 commits)
gpio: ab8500: Mark broken
genirq: Remove move_*irq leftovers
genirq: Remove compat code
drivers: Final irq namespace conversion
mn10300: Use generic show_interrupts()
mn10300: Cleanup irq_desc access
mn10300: Convert genirq namespace
frv: Use generic show_interrupts()
frv: Convert genirq namespace
m68k: Convert irq function namespace
xen: Use new irq_move functions
xen: Cleanup genirq namespace
unicore32: Use generic show_interrupts()
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
xfrm: Restrict extended sequence numbers to esp
xfrm: Check for esn buffer len in xfrm_new_ae
xfrm: Assign esn pointers when cloning a state
xfrm: Move the test on replay window size into the replay check functions
netdev: bfin_mac: document TE setting in RMII modes
drivers net: Fix declaration ordering in inline functions.
cxgb3: Apply interrupt coalescing settings to all queues
net: Always allocate at least 16 skb frags regardless of page size
ipv4: Don't ip_rt_put() an error pointer in RAW sockets.
net: fix ethtool->set_flags not intended -EINVAL return value
mlx4_en: Fix loss of promiscuity
tg3: Fix inline keyword usage
tg3: use <linux/io.h> and <linux/uaccess.h> instead <asm/io.h> and <asm/uaccess.h>
net: use CHECKSUM_NONE instead of magic number
Net / jme: Do not use legacy PCI power management
myri10ge: small rx_done refactoring
bridge: notify applications if address of bridge device changes
ipv4: Fix IP timestamp option (IPOPT_TS_PRESPEC) handling in ip_options_echo()
can: c_can: Fix tx_bytes accounting
can: c_can_platform: fix irq check in probe
All users converted to new interface.
When we clone a xfrm state we have to assign the replay_esn
and the preplay_esn pointers to the state if we use the
new replay detection method. To this end, we add a
xfrm_replay_clone() function that allocates memory for
the replay detection and takes over the necessary values
from the original state.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
When analysing performance of the cxgb3 on a ppc64 box I noticed that
we weren't doing much GRO merging. It turns out we are limited by the
number of SKB frags:
#define MAX_SKB_FRAGS (65536/PAGE_SIZE + 2)
With a 4kB page size we have 18 frags, but with a 64kB page size we
only have 3 frags.
I ran a single stream TCP bandwidth test to compare the performance of
* 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
vlynq: Convert irq functions
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq; Fix cleanup fallout
genirq: Fix typo and remove unused variable
genirq: Fix new kernel-doc warnings
genirq: Add setter for AFFINITY_SET in irq_data state
genirq: Provide setter inline for IRQD_IRQ_INPROGRESS
genirq: Remove handle_IRQ_event
arm: Ns9xxx: Remove private irq flow handler
powerpc: cell: Use the core flow handler
genirq: Provide edge_eoi flow handler
genirq: Move INPROGRESS, MASKED and DISABLED state flags to irq_data
genirq: Split irq_set_affinity() so it can be called with lock held.
genirq: Add chip flag for restricting cpu_on/offline calls
genirq: Add chip hooks for taking CPUs on/off line.
genirq: Add irq disabled flag to irq_data state
genirq: Reserve the irq when calling irq_set_chip()
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus-unmerged' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (45 commits)
Btrfs: fix __btrfs_map_block on 32 bit machines
btrfs: fix possible deadlock by clearing __GFP_FS flag
btrfs: check link counter overflow in link(2)
btrfs: don't mess with i_nlink of unlocked inode in rename()
Btrfs: check return value of btrfs_alloc_path()
Btrfs: fix OOPS of empty filesystem after balance
Btrfs: fix memory leak of empty filesystem after balance
Btrfs: fix return value of setflags ioctl
Btrfs: fix uncheck memory allocations
btrfs: make inode ref log recovery faster
Btrfs: add btrfs_trim_fs() to handle FITRIM
Btrfs: adjust btrfs_discard_extent() return errors and trimmed bytes
Btrfs: make btrfs_map_block() return entire free extent for each device of RAID0/1/10/DUP
Btrfs: make update_reserved_bytes() public
btrfs: return EXDEV when linking from different subvolumes
Btrfs: Per file/directory controls for COW and compression
Btrfs: add datacow flag in inode flag
btrfs: use GFP_NOFS instead of GFP_KERNEL
Btrfs: check return value of read_tree_block()
btrfs: properly access unaligned checksum buffer
Fix up trivial conflicts in fs/btrfs/volumes.c due to plug removal in
the block layer.
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (81 commits)
xo15-ebook: Remove device.wakeup_count
ips: use interruptible waits in ips-monitor
acer-wmi: does not poll device status when WMI event is available
acer-wmi: does not set persistence state by rfkill_init_sw_state
platform-drivers: x86: fix common misspellings
acer-wmi: use pr_<level> for messages
asus-wmi: potential NULL dereference in show_call()
asus-wmi: signedness bug in read_brightness()
platform-driver-x86: samsung-laptop: make dmi_check_cb to return 1 instead of 0
platform-driver-x86: fix wrong merge for compal-laptop.c
msi-laptop: use pr_<level> for messages
Platform: add Samsung Laptop platform driver
acer-wmi: Fix WMI ID
acer-wmi: deactive mail led when power off
msi-laptop: send out touchpad on/off key
acer-wmi: set the touchpad toggle key code to KEY_TOUCHPAD_TOGGLE
platform-driver-x86: intel_mid_thermal: fix unterminated platform_device_id table
sony-laptop: potential null dereference
sony-laptop: handle allocation failures
sony-laptop: return negative on failure in sony_nc_add()
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson
* 'for-torvalds' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
mach-ux500: configure board for the TPS61052 regulator v2
mach-ux500: provide ab8500 init vector
mach-ux500: board support for AB8500 GPIO driver
gpio: driver for 42 AB8500 GPIO pins
Fix new irq-related kernel-doc warnings in 2.6.38:
Warning(kernel/irq/manage.c:149): No description found for parameter 'mask'
Warning(kernel/irq/manage.c:149): Excess function parameter 'cpumask' description in 'irq_set_affinity'
Warning(include/linux/irq.h:161): No description found for parameter 'state_use_accessors'
Warning(include/linux/irq.h:161): Excess struct/union/enum/typedef member 'state_use_accessor' description in 'irq_data'
LKML-Reference: <20110318093356.b939558d.randy.dunlap@oracle.com>
Some archs want to prevent the default affinity being set on their
chips in the reqeust_irq() path.
Special function for demultiplexing handlers which can be disabled via
disable_irq().
Last user gone.
This is a replacment for the cell flow handler which is in the way of
cleanups. Must be selected to avoid general bloat.
We really need these flags for some of the interrupt chips. Move it
from internal state to irq_data and provide proper accessors.
Cc: David Daney <ddaney@caviumnetworks.com>
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Ensure that rpc_release_resources_task() can be called twice.
NFS: Don't leak RPC clients in NFSv4 secinfo negotiation
NFS: Fix a hang in the writeback path
The percpu code requires more functions to be implemented in the mm core
which nommu currently does not provide. So add inline implementations
since these are largely meaningless on nommu systems.
Signed-off-by: Graf Yang <graf.yang@analog.com>
Acked-by: Greg Ungerer <gerg@uclinux.org>
