path: root/include
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04tcp: Use defaults when no route options are availableGilad Ben-Yossef
Trying to parse the option of a SYN packet that we have no route entry for should just use global wide defaults for route entry options. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Tested-by: Valdis.Kletnieks@vt.edu Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: Introduce for_each_netdev_rcu() iteratorEric Dumazet
Adds RCU management to the list of netdevices. Convert some for_each_netdev() users to RCU version, if it can avoid read_lock-ing dev_base_lock Ie: read_lock(&dev_base_loack); for_each_netdev(net, dev) some_action(); read_unlock(&dev_base_lock); becomes : rcu_read_lock(); for_each_netdev_rcu(net, dev) some_action(); rcu_read_unlock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/netEric Dumazet
2009-11-02gianfar: Basic Support for programming hash rulesSandeep Gopalpet
This patch provides basic hash rules programming via the ethtool interface. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Optionally disable TXC if no linkMatt Carlson
This patch adds code to disable the TXC and RXC reference clocks if link is not available. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add code to disable rxc refclkMatt Carlson
The 5785 does not use the RXC reference clock. Turning it off is desirable as it saves power. By default, the 50610 enables the RXC reference clock and the 50610M disables it. Presumably this is one of the reasons why the hardware architect chose one over the other. Adding a "rx reference clock disable" flag is not the ideal way to describe the option, as it would force the MAC using a 50610M to set the flag. Ideally we want the flags to represent opt-in behavior that deviates from hardware defaults. Furthermore, the lack of a "disable" flag implies that the requester wants the rx reference clock enabled, which doesn't necessarily follow. By presenting the option as a passive statement (rx reference clock unused) rather than a command, I hope to convey an opt-in option to disable the rx reference clock that falls back to hardware defaults if not set. A secondary benefit of this is that it keeps the intelligence about phy defaults in the broadcom module where it belongs and allows the broadcom module more latitude should a bug arise. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add PHY_BRCM_CLEAR_RGMII_MODE flagMatt Carlson
Broadcom 50610M parts changed the default definitions of the RGMII mode shadow register. The 5785 needs the RGMII mode selection bits [4:3] cleared. The default value of the remaining bits in this register are zero. Rather than unnecessarily burn an extra bit in the dev_flags member in an attempt to enumerate all possible combinations, this patch take a more course grained approach and labels the option as "clear all bits". Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Consolidate dev_flags definitionsMatt Carlson
This patch moves all the dev_flags enumerations outside the broadcom.c file to include/linux/brcmphy.h. The existing flags were not used yet and have been re-enumerated to avoid conflicts. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-01net: Introduce dev_get_by_name_rcu()Eric Dumazet
Some workloads hit dev_base_lock rwlock pretty hard. We can use RCU lookups to avoid touching this rwlock (and avoid touching netdevice refcount) netdevices are already freed after a RCU grace period, so this patch adds no penalty at device dismantle time. However, it adds a synchronize_rcu() call in dev_change_name() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30RDS: Add GET_MR_FOR_DEST sockoptAndy Grover
RDS currently supports a GET_MR sockopt to establish a memory region (MR) for a chunk of memory. However, the fastreg method ties a MR to a particular destination. The GET_MR_FOR_DEST sockopt allows the remote machine to be specified, and thus support for fastreg (aka FRWRs). Note that this patch does *not* do all of this - it simply implements the new sockopt in terms of the old one, so applications can begin to use the new sockopt in preparation for cutover to FRWRs. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30net: Allow devices to specify a device specific sysfs group.Eric W. Biederman
This isn't beautifully abstracted, but it is simple, simplifies uses and so far is only needed for the bonding driver. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gro: Change all receive functions to return GRO result codesBen Hutchings
This will allow drivers to adjust their receive path dynamically based on whether GRO is being applied successfully. Currently all in-tree callers ignore the return values of these functions and do not need to be changed. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gro: Name the GRO result enumeration typeBen Hutchings
This clarifies which return and parameter types are GRO result codes and not RX result codes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29net,socket: introduce DECLARE_SOCKADDR helper to catch overflow at build timeCyrill Gorcunov
proto_ops->getname implies copying protocol specific data into storage unit (particulary to __kernel_sockaddr_storage). So when we implement new protocol support we should keep such a detail in mind (which is easy to forget about). Lets introduce DECLARE_SOCKADDR helper which check if storage unit is not overfowed at build time. Eventually inet_getname is switched to use DECLARE_SOCKADDR (to show example of usage). Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-10-29net: Introduce dev_get_by_index_rcu()Eric Dumazet
Some workloads hit dev_base_lock rwlock pretty hard. We can use RCU lookups to avoid touching this rwlock. netdevices are already freed after a RCU grace period, so this patch adds no penalty at device dismantle time. dev_ifname() converted to dev_get_by_index_rcu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow disabling of DSACK TCP option per routeGilad Ben-Yossef
Add and use no DSCAK bit in the features field. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow to turn off TCP window scale opt per routeGilad Ben-Yossef
Add and use no window scale bit in the features field. Note that this is not the same as setting a window scale of 0 as would happen with window limit on route. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow disabling TCP timestamp options per routeGilad Ben-Yossef
Implement querying and acting upon the no timestamp bit in the feature field. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Add the no SACK route option featureGilad Ben-Yossef
Implement querying and acting upon the no sack bit in the features field. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Add dst_feature to query route entry featuresGilad Ben-Yossef
Adding an accessor to existing dst_entry feautres field and refactor the only supported feature (allfrag) to use it. Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow tcp_parse_options to consult dst entryGilad Ben-Yossef
We need tcp_parse_options to be aware of dst_entry to take into account per dst_entry TCP options settings Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29net: Add ndo_fcoe_get_wwn to net_device_opsYi Zou
Add ndo_fcoe_get_wwn so Fiber Channel over Ethernet (FCoE) can make use of the provided World Wide Port Name (WWPN) and World Wide Node Name (WWNN) from the underlying network interface driver. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28vlan: Optimize multiple unregistrationEric Dumazet
Use unregister_netdevice_many() to speedup master device unregister. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28net: add a list_head parameter to dellink() methodEric Dumazet
Adding a list_head parameter to rtnl_link_ops->dellink() methods allow us to queue devices on a list, in order to dismantle them all at once. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28net: Introduce unregister_netdevice_many()Eric Dumazet
Introduce rollback_registered_many() and unregister_netdevice_many() rollback_registered_many() is able to perform necessary steps at device dismantle time, factorizing two expensive synchronize_net() calls. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28net: Introduce unregister_netdevice_queue()Eric Dumazet
This patchs adds an unreg_list anchor to struct net_device, and introduces an unregister_netdevice_queue() function, able to queue a net_device to a list instead of immediately unregister it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27mac80211: add ieee80211_rx_ni()Kalle Valo
ieee80211_rx() must be called with bottom halves disabled. To simplify driver development implement ieee80211_rx_ni() which disables BH. This function must be used when in process context. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27cfg80211: no cookies in cfg80211_send_XXX()Holger Schurig
Get rid of cookies in cfg80211_send_XXX() functions. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27ssb: Put host pointers into a unionMichael Buesch
This slightly shrinks the structure. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-27vlan: allow null VLAN ID to be usedEric Dumazet
We currently use a 16 bit field (vlan_tci) to store VLAN ID/PRIO on a skb. Null value is used as a special value, meaning vlan tagging not enabled. This forbids use of null vlan ID. As pointed by David, some drivers use the 3 high order bits (PRIO) As VLAN ID is 12 bits, we can use the remaining bit (CFI) as a flag, and allow null VLAN ID. In case future code really wants to use VLAN_CFI_MASK, we'll have to use a bit outside of vlan_tci. #define VLAN_PRIO_MASK 0xe000 /* Priority Code Point */ #define VLAN_PRIO_SHIFT 13 #define VLAN_CFI_MASK 0x1000 /* Canonical Format Indicator */ #define VLAN_TAG_PRESENT VLAN_CFI_MASK #define VLAN_VID_MASK 0x0fff /* VLAN Identifier */ Reported-by: Gertjan Hofman <gertjan_hofman@yahoo.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24rtnetlink: speedup rtnl_dump_ifinfo()Eric Dumazet
When handling large number of netdevice, rtnl_dump_ifinfo() is very slow because it has O(N^2) complexity. Instead of scanning one single list, we can use the 256 sub lists of the dev_index hash table. This considerably speedups "ip link" operations Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24ipv6 sit: RCU conversion phase IEric Dumazet
SIT tunnels use one rwlock to protect their prl entries. This first patch adds RCU locking for prl management, with standard call_rcu() calls. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-22pkt_sched: skbedit add support for setting markjamal
This adds support for setting the skb mark. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20net: Fix for dst_negative_adviceKrishna Kumar
dst_negative_advice() should check for changed dst and reset sk_tx_queue_mapping accordingly. Pass sock to the callers of dst_negative_advice. (sk_reset_txq is defined just for use by dst_negative_advice. The only way I could find to get around this is to move dst_negative_() from dst.h to dst.c, include sock.h in dst.c, etc) Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20net: Introduce sk_tx_queue_mappingKrishna Kumar
Introduce sk_tx_queue_mapping; and functions that set, test and get this value. Reset sk_tx_queue_mapping to -1 whenever the dst cache is set/reset, and in socket alloc. Setting txq to -1 and using valid txq=<0 to n-1> allows the tx path to use the value of sk_tx_queue_mapping directly instead of subtracting 1 on every tx. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20net: Fix struct inet_timewait_sock bitfield annotationEric Dumazet
commit 9e337b0f (net: annotate inet_timewait_sock bitfields) added 4/8 bytes in struct inet_timewait_sock. Fix this by declaring tw_ipv6_offset in the 'flags' bitfield The 14 bits hole is named tw_pad to make it cleary apparent. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20net: Avoid compiler warning for mmsghdr when CONFIG_COMPAT is not selectedArnaldo Carvalho de Melo
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20filter: Add SKF_AD_QUEUE instructionEric Dumazet
It can help being able to filter packets on their queue_mapping. If filter performance is not good, we could add a "numqueue" field in struct packet_type, so that netif_nit_deliver() and other functions can directly ignore packets with not expected queue number. Lets experiment this simple filter extension first. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20can: provide library functions for skb allocationWolfgang Grandegger
This patch makes the private functions alloc_can_skb() and alloc_can_err_skb() of the at91_can driver public and adapts all drivers to use these. While making the patch I realized, that the skb's are *not* setup consistently. It's now done as shown below: skb->protocol = htons(ETH_P_CAN); skb->pkt_type = PACKET_BROADCAST; skb->ip_summed = CHECKSUM_UNNECESSARY; *cf = (struct can_frame *)skb_put(skb, sizeof(struct can_frame)); memset(*cf, 0, sizeof(struct can_frame)); The frame is zeroed out to avoid uninitialized data to be passed to user space. Some drivers or library code did not set "pkt_type" or "ip_summed". Also, "__constant_htons()" should not be used for runtime invocations, as pointed out by David Miller. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-19pkt_sched: ingress socket filter by markjamal
Allow bpf to set a filter to drop packets that dont match a specific mark Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18xfrm: remove skb_icv_walkSteffen Klassert
The last users of skb_icv_walk are converted to ahash now, so skb_icv_walk is unused and can be removed. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18ah: Remove obsolete codeSteffen Klassert
ah4 and ah6 are converted to ahash now, so we can remove the code for the obsolete hash algorithm. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18ah: Add struct crypto_ahash to ah_dataSteffen Klassert
To support for ahash algorithms, we add a pointer to a crypto_ahash to ah_data. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14Phonet: routing table Netlink interfaceRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
