The first argument should be called ha, not mclist. All callers use the
name "ha", but if they used a different name, there would be a compile
error.
Signed-off-by: Pavel Roskin <proski@gnu.org>
__xfrm_lookup() is called for each packet transmitted out of
system. The xfrm_find_bundle() does a linear search which can
kill system performance depending on how many bundles are
required per policy.
This modifies __xfrm_lookup() to store bundles directly in
the flow cache. If we did not get a hit, we just create a new
bundle instead of doing slow search. This means that we can now
get multiple xfrm_dst's for same flow (on per-cpu basis).
Signed-off-by: Timo Teras <timo.teras@iki.fi>
This allows to validate the cached object before returning it.
It also allows to destruct object properly, if the last reference
was held in flow cache. This is also a prepartion for caching
bundles in the flow cache.
In return for virtualizing the methods, we save on:
- not having to regenerate the whole flow cache on policy removal:
each flow matching a killed policy gets refreshed as the getter
function notices it smartly.
- we do not have to call flow_cache_flush from policy gc, since the
flow cache now properly deletes the object if it had any references
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
drivers/net/bonding/bond_main.c
drivers/net/via-velocity.c
drivers/net/wireless/iwlwifi/iwl-agn.c
This patch makes it explicit in the API that all fields in subscriptions and events exchanged with the Topology Server must be in
network byte order.
It also ensures that all fields of a subscription are compared when cancelling a subscription, in order to avoid inadvertent
cancelling of the wrong subscription.
Finally, the tipc module version is updated to 2.0.0, to reflect the API change.
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
When ip_append() fails because of socket limit or memory shortage,
increment ICMP_MIB_OUTERRORS counter, so that "netstat -s" can report
these errors.
LANG=C netstat -s | grep "ICMP messages failed"
0 ICMP messages failed
For IPV6, implement ICMP6_MIB_OUTERRORS counter as well.
# grep Icmp6OutErrors /proc/net/dev_snmp6/*
/proc/net/dev_snmp6/eth0:Icmp6OutErrors 0
/proc/net/dev_snmp6/lo:Icmp6OutErrors 0
In L2TPv3, we need to create/delete/modify/query L2TP tunnel and
session contexts. The number of parameters is significant. So let's
use netlink. Userspace uses this API to control L2TP tunnel/session
contexts in the kernel.
The previous pppol2tp driver was managed using [gs]etsockopt(). This
API is retained for backwards compatibility. Unlike L2TPv2 which
carries only PPP frames, L2TPv3 can carry raw ethernet frames or other
frame types and these do not always have an associated socket
family. Therefore, we need a way to use L2TP sessions that doesn't
require a socket type for each supported frame type. Hence netlink is
used.
Signed-off-by: James Chapman <jchapman@katalix.com>
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
This lets kernel modules which use genl netlink APIs serialize netlink
processing.
This patch adds a new L2TPIP socket family and modifies the core to
handle the case where there is no UDP header in the L2TP
packet. L2TP/IP uses IP protocol 115. Since L2TP/UDP and L2TP/IP
packets differ in layout, the datapath packet handling code needs
changes too. Userspace uses an L2TPIP socket instead of a UDP socket
when IP encapsulation is required.
We can't use raw sockets for this because the semantics of raw sockets
don't lend themselves to the socket-per-tunnel model - we need to
This patch makes changes to the L2TP PPP code for L2TPv3.
The existing code has some assumptions about the L2TP header which are
broken by L2TPv3. Also the sockaddr_pppol2tp structure of the original
code is too small to support the increased size of the L2TPv3 tunnel
and session id, so a new sockaddr_pppol2tpv3 structure is needed. In
the socket calls, the size of this structure is used to tell if the
operation is for L2TPv2 or L2TPv3.
ppp_dev_name() gives PPP users visibility of a ppp channel's device
name. This can be used by L2TP drivers to dump the assigned PPP
interface name.
This patch splits the pppol2tp driver into separate L2TP and PPP parts
to prepare for L2TPv3 support. In L2TPv3, protocols other than PPP can
be carried, so this split creates a common L2TP core that will handle
the common L2TP bits which protocol support modules such as PPP will
use.
Note that the existing pppol2tp module is split into l2tp_core and
l2tp_ppp by this change.
There are no feature changes here. Internally, however, there are
significant changes, mostly to handle the separation of PPP-specific
data from the L2TP session and to provide hooks in the core for
modules like PPP to access.
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
+little renaming of unicast functions to be smooth with multicast ones
We don't use the normal hotplug mechanism because it doesn't work. It will
load the module some time after the device appears, but that's not good
enough for us -- we need the driver loaded _immediately_ because otherwise
the NIC driver may just abort and then the phy 'device' goes away.
[bwh: s/phy/mdio/ in module alias, kerneldoc for struct mdio_device_id]
Acked-by: Andy Fleming <afleming@freescale.com>
The head element of rt6_info{} is dst_entry{}, and
IPv6 specific elements follow.
Because elements at the end of dst_entry{} are frequently
updated, it is not good to put frequently-used static
elements, such as rt6i_idev, rt6i_dst or rt6i_flags in the
same cache line.
On the other hand, fib6_table, rt6i_node or rt6i_gateway are
rarely used, so it is okay to stay in the same cache line.
Let's rearrange rt6_info{}.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
One of my test machine got a deadlock during "tc" sessions,
adding/deleting classes & filters, using traffic estimators.
After some analysis, I believe we have a potential use after free case
in est_timer() :
spin_lock(e->stats_lock); << HERE >>
read_lock(&est_lock);
if (e->bstats == NULL) << TEST >>
goto skip;
Test is done a bit late, because after estimator is killed, and before
rcu grace period elapsed, we might already have freed/reuse memory where
e->stats_locks points to (some qdisc->q.lock)
A possible fix is to respect a rcu grace period at Qdisc dismantle time.
On 64bit, sizeof(struct Qdisc) is exactly 192 bytes. Adding 16 bytes to
it (for struct rcu_head) is a problem because it might change
performance, given QDISC_ALIGNTO is 32 bytes.
This is why I also change QDISC_ALIGNTO to 64 bytes, to satisfy most
current alignment requirements.
Chip model can now be selected directly by matching the modalias name
(instead of filling the .model field in platform_data), and allows the
module to be auto-loaded. Previous behaviour is of course still supported.
Convert the two in-tree users to this feature (icontrol & zeus).
Tested on an Zeus platform (mcp2515).
Signed-off-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Christian Pellegrin <chripell@fsfe.org>
Cc: Edwin Peer <epeer@tmtservices.co.za>
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
This adds ethtool and device feature flag to allow control
of receive hashing offload.
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Because we have ensured that the argument is non-zero,
it is better to use __fls() and generate better code.
Add CAIF Serial driver. This driver is implemented as a line discipline.
caif_serial uses the following module parameters:
ser_use_stx - specifies if STart of frame eXtension is in use.
ser_loop - sets the interface in loopback mode.
Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
Header files for CAIF Link layer net-device,
and link-layer registration.
Add include files for the CAIF Core protocol stack.
caif_layer.h - Defines the structure of the CAIF protocol layers
cfcnfg.h - CAIF Configuration Module for services and link layers
cfctrl.h - CAIF Control Protocol Layer
cffrml.h - CAIF Framing Layer
cfmuxl.h - CAIF Muxing Layer
cfpkt.h - CAIF Packet layer (skb helper functions)
cfserl.h - CAIF Serial Layer
cfsrvl.h - CAIF Service Layer
Add CAIF types for Socket Address, Socket Options,
and configuration parameters for the GPRS IP network interface.
Add CAIF definitions to existing header files.
Files: if_arp.h, if_ether.h, socket.h.
Types: ARPHRD_CAIF, ETH_P_CAIF, AF_CAIF, PF_CAIF, SOL_CAIF, N_CAIF
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Unlike the ipv4 side, these are completely unused.
Add new flag MSG_WAITFORONE for the recvmmsg() syscall.
When this flag is specified for a blocking socket, recvmmsg()
will only block until at least 1 packet is available. The
default behavior is to block until all vlen packets are
available. This flag has no effect on non-blocking sockets
or when used in combination with MSG_DONTWAIT.
Signed-off-by: Brandon L Black <blblack@gmail.com>
Acked-by: Ulrich Drepper <drepper@redhat.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
RPS currently depends on SMP and SYSFS
Adding a CONFIG_RPS makes sense in case this requirement changes in the
future. This patch saves about 1500 bytes of kernel text in case SMP is
on but SYSFS is off.
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
The order of the IPv6 raw table is currently reversed, that makes impossible
to use the NOTRACK target in IPv6: for example if someone enters
ip6tables -t raw -A PREROUTING -p tcp --dport 80 -j NOTRACK
and if we receive fragmented packets then the first fragment will be
untracked and thus skip nf_ct_frag6_gather (and conntrack), while all
subsequent fragments enter nf_ct_frag6_gather and reassembly will never
successfully be finished.
Singed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
In nl80211.h, be a little more elaborate in the docs for the definitions
NL80211_ATTR_CQM_RSSI_THOLD and NL80211_ATTR_CQM_RSSI_HYST.
Reported-by: Luis R. Rodriguez <mcgrof@gmail.com>
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
Add support for the set_cqm_config op. This op function configures the
requested connection quality monitor rssi threshold and rssi hysteresis
values to the hardware if the hardware supports
IEEE80211_HW_SUPPORTS_CQM.
For unsupported hardware, currently -EOPNOTSUPP is returned, so the mac80211
is currently not doing connection quality monitoring on the host. This could be
added later, if needed.
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Add support for basic configuration of a connection quality monitoring to the
nl80211 interface, and basic support for notifying about triggered monitoring
events.
Via this interface a user-space connection manager may configure and receive
pre-warning events of deteriorating WLAN connection quality, and start
preparing for roaming in advance, before the connection is already lost.
An example usage of such a trigger is starting scanning for nearby AP's in
an attempt to find one with better connection quality, and associate to it
before the connection characteristics of the existing connection become too bad
or the association is even lost, leading in a prolonged delay in connectivity.
The interface currently supports only RSSI, but it could be later extended
to include other parameters, such as signal-to-noise ratio, if need for that
arises.
The dma map fields in the skb_shared_info structure no longer has any users
and can be dropped since it is making the skb_shared_info unecessarily larger.
Running slabtop show that we were using 4K slabs for the skb->head on x86_64 w/
an allocation size of 1522. It turns out that the dma_head and dma_maps array
made skb_shared large enough that we had crossed over the 2k boundary with
standard frames and as such we were using 4k blocks of memory for all skbs.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
This patch is based on a RFC patch by Kalle Valo.
The wl1271 has a feature which handles the connection monitor logic
in hardware, basically sending periodically nullfunc frames and reporting
to the host if AP is lost, after attempting to recover by sending
probe-requests to the AP.
Add support to mac80211 by adding a new flag IEEE80211_HW_CONNECTION_MONITOR
which prevents conn_mon_timer from triggering during idle periods, and
prevents sending probe-requests to the AP if beacon-loss is indicated by the
hardware.
Cc: Kalle Valo <kalle.valo@nokia.com>
These two #defines use the same value, but
SIOCIWFIRST makes more sense in this use.
Copied the idea from orinoco
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ath5k/phy.c
Commit 45575f5a426c ("ppc64 sys_ipc breakage in 2.6.34-rc2") fixed the
definition of the sys_ipc() helper, but didn't fix the prototype in
<linux/syscalls.h>
Reported-and-tested-by: Andreas Schwab <schwab@linux-m68k.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (38 commits)
ip_gre: include route header_len in max_headroom calculation
if_tunnel.h: add missing ams/byteorder.h include
ipv4: Don't drop redirected route cache entry unless PTMU actually expired
net: suppress lockdep-RCU false positive in FIB trie.
Bluetooth: Fix kernel crash on L2CAP stress tests
Bluetooth: Convert debug files to actually use debugfs instead of sysfs
Bluetooth: Fix potential bad memory access with sysfs files
netfilter: ctnetlink: fix reliable event delivery if message building fails
netlink: fix NETLINK_RECV_NO_ENOBUFS in netlink_set_err()
NET_DMA: free skbs periodically
netlink: fix unaligned access in nla_get_be64()
tcp: Fix tcp_mark_head_lost() with packets == 0
net: ipmr/ip6mr: fix potential out-of-bounds vif_table access
KS8695: update ksp->next_rx_desc_read at the end of rx loop
igb: Add support for 82576 ET2 Quad Port Server Adapter
ixgbevf: Message formatting cleanups
ixgbevf: Shorten up delay timer for watchdog task
ixgbevf: Fix VF Stats accounting after reset
ixgbe: Set IXGBE_RSC_CB(skb)->DMA field to zero after unmapping the address
ixgbe: fix for real_num_tx_queues update issue
When compiling userspace application which includes
if_tunnel.h and uses GRE_* defines you will get undefined
reference to __cpu_to_be16.
Fix this by adding missing #include <asm/byteorder.h>
Cc: stable@kernel.org
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com>
There is no point to align or pad mibs to cache lines, they are per cpu
allocated with a 8 bytes alignment anyway.
This wastes space for no gain. This patch removes __SNMP_MIB_ALIGN__
Since SNMP mibs contain "unsigned long" fields only, we can relax the
allocation alignment from "unsigned long long" to "unsigned long"
Its currently hard to diagnose when ACK frames are dropped because an
application set TCP_DEFER_ACCEPT on its listening socket.
See http://bugzilla.kernel.org/show_bug.cgi?id=15507
This patch adds a SNMP value, named TCPDeferAcceptDrop
netstat -s | grep TCPDeferAcceptDrop
TCPDeferAcceptDrop: 0
This counter is incremented every time we drop a pure ACK frame received
by a socket in SYN_RECV state because its SYNACK retrans count is lower
than defer_accept value.
After the type change, addresses in unicast and multicast lists wouldn't make
sense, not to mention possible different lenghts. So flush both lists here.
Note "dev_addr_discard" will be very soon replaced by "dev_mc_flush" (once
mc_list conversion will be done).
Ignore the new NETDEV_PRE_TYPE_CHANGE event in rtnetlink_event() since
there have been no changes userspace needs to be notified of.
Also add a comment to the netdev notifier event definitions to remind
people to update the exclusion list when adding new event types.
Some of the debug files ended up wrongly in sysfs, because at that point
of time, debugfs didn't exist. Convert these files to use debugfs and
also seq_file. This patch converts all of these files at once and then
removes the exported symbol for the Bluetooth sysfs class.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Convert to list macro's for the list of addresses per interface
in IPv6.
Convert from reader/writer lock to RCU and spinlock for addrconf
hash list.
Adds an additional helper macro for hlist_for_each_entry_continue_rcu
to handle the continue case.
Using hash list macros, simplifies code and helps later RCU.
This patch includes some initialization that is not strictly necessary,
since an empty hlist node/list is all zero; and list is in BSS
and node is allocated with kzalloc.
