path: root/include
2009-04-05Merge branch 'for-next' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-next' of git://git.o-hand.com/linux-mfd: mfd: fix da903x warning mfd: fix MAINTAINERS entry mfd: Use the value of the final spin when reading the AUXADC mfd: Storage class should be before const qualifier mfd: PASIC3: supply clock_rate to DS1WM via driver_data mfd: remove DS1WM clock handling mfd: remove unused PASIC3 bus_shift field pxa/magician: remove deprecated .bus_shift from PASIC3 platform_data mfd: convert PASIC3 to use MFD core mfd: convert DS1WM to use MFD core mfd: Support active high IRQs on WM835x mfd: Use bulk read to fill WM8350 register cache mfd: remove duplicated #include from pcf50633
2009-04-05Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (140 commits) ACPI: processor: use .notify method instead of installing handler directly ACPI: button: use .notify method instead of installing handler directly ACPI: support acpi_device_ops .notify methods toshiba-acpi: remove MAINTAINERS entry ACPI: battery: asynchronous init acer-wmi: Update copyright notice & documentation acer-wmi: Cleanup the failure cleanup handling acer-wmi: Blacklist Acer Aspire One video: build fix thinkpad-acpi: rework brightness support thinkpad-acpi: enhanced debugging messages for the fan subdriver thinkpad-acpi: enhanced debugging messages for the hotkey subdriver thinkpad-acpi: enhanced debugging messages for rfkill subdrivers thinkpad-acpi: restrict access to some firmware LEDs thinkpad-acpi: remove HKEY disable functionality thinkpad-acpi: add new debug helpers and warn of deprecated atts thinkpad-acpi: add missing log levels thinkpad-acpi: cleanup debug helpers thinkpad-acpi: documentation cleanup thinkpad-acpi: drop ibm-acpi alias ...
2009-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (714 commits) Staging: sxg: slicoss: Specify the license for Sahara SXG and Slicoss drivers Staging: serqt_usb: fix build due to proc tty changes Staging: serqt_usb: fix checkpatch errors Staging: serqt_usb: add TODO file Staging: serqt_usb: Lindent the code Staging: add USB serial Quatech driver staging: document that the wifi staging drivers a bit better Staging: echo cleanup Staging: BUG to BUG_ON changes Staging: remove some pointless conditionals before kfree_skb() Staging: line6: fix build error, select SND_RAWMIDI Staging: line6: fix checkpatch errors in variax.c Staging: line6: fix checkpatch errors in toneport.c Staging: line6: fix checkpatch errors in pcm.c Staging: line6: fix checkpatch errors in midibuf.c Staging: line6: fix checkpatch errors in midi.c Staging: line6: fix checkpatch errors in dumprequest.c Staging: line6: fix checkpatch errors in driver.c Staging: line6: fix checkpatch errors in audio.c Staging: line6: fix checkpatch errors in pod.c ...
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: (36 commits) cpumask: remove cpumask allocation from idle_balance, fix numa, cpumask: move numa_node_id default implementation to topology.h, fix cpumask: remove cpumask allocation from idle_balance x86: cpumask: x86 mmio-mod.c use cpumask_var_t for downed_cpus x86: cpumask: update 32-bit APM not to mug current->cpus_allowed x86: microcode: cleanup x86: cpumask: use work_on_cpu in arch/x86/kernel/microcode_core.c cpumask: fix CONFIG_CPUMASK_OFFSTACK=y cpu hotunplug crash numa, cpumask: move numa_node_id default implementation to topology.h cpumask: convert node_to_cpumask_map[] to cpumask_var_t cpumask: remove x86 cpumask_t uses. cpumask: use cpumask_var_t in uv_flush_tlb_others. cpumask: remove cpumask_t assignment from vector_allocation_domain() cpumask: make Xen use the new operators. cpumask: clean up summit's send_IPI functions cpumask: use new cpumask functions throughout x86 x86: unify cpu_callin_mask/cpu_callout_mask/cpu_initialized_mask/cpu_sibling_setup_mask cpumask: convert struct cpuinfo_x86's llc_shared_map to cpumask_var_t cpumask: convert node_to_cpumask_map[] to cpumask_var_t x86: unify 32 and 64-bit node_to_cpumask_map ...
2009-04-05Merge ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param * git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param: module: use strstarts() strstarts: helper function for !strncmp(str, prefix, strlen(prefix)) arm: allow usage of string functions in linux/string.h module: don't use stop_machine on module load module: create a request_module_nowait() module: include other structures in module version check module: remove the SHF_ALLOC flag on the __versions section. module: clarify the force-loading taint message. module: Export symbols needed for Ksplice Ksplice: Add functions for walking kallsyms symbols module: remove module_text_address() module: __module_address module: Make find_symbol return a struct kernel_symbol kernel/module.c: fix an unused goto label param: fix charp parameters set via sysfs Fix trivial conflicts in kernel/extable.c manually.
2009-04-05Merge branch 'printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: printk: correct the behavior of printk_timed_ratelimit() vsprintf: unify the format decoding layer for its 3 users, cleanup fix regression from "vsprintf: unify the format decoding layer for its 3 users" vsprintf: fix bug in negative value printing vsprintf: unify the format decoding layer for its 3 users vsprintf: add binary printf printk: introduce printk_once() Fix trivial conflicts (printk_once vs log_buf_kexec_setup() added near each other) in include/linux/kernel.h.
2009-04-05ACPI: support acpi_device_ops .notify methodsBjorn Helgaas
This patch adds support for ACPI device driver .notify() methods. If such a method is present, Linux/ACPI installs a handler for device notifications (but not for system notifications such as Bus Check, Device Check, etc). When a device notification occurs, Linux/ACPI passes it on to the driver's .notify() method. In most cases, this removes the need for drivers to install their own handlers for device-specific notifications. For fixed hardware devices like some power and sleep buttons, there's no notification value because there's no control method to execute a Notify opcode. When a fixed hardware device generates an event, we handle it the same as a regular device notification, except we send a ACPI_FIXED_HARDWARE_EVENT value. This is outside the normal 0x0-0xff range used by Notify opcodes. Several drivers install their own handlers for system Bus Check and Device Check notifications so they can support hot-plug. This patch doesn't affect that usage. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'x2apic' into releaseLen Brown
2009-04-05Merge branch 'constify' into releaseLen Brown
2009-04-05Merge branch 'sony-laptop' into releaseLen Brown
2009-04-05Merge branch 'video' into releaseLen Brown
Conflicts: drivers/acpi/video.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'battery' into releaseLen Brown
2009-04-05Merge branch 'thermal' into releaseLen Brown
2009-04-05Merge branch 'driver-ops-cleanup' into releaseLen Brown
2009-04-05Merge branch 'bjorn-initcall-cleanup' into releaseLen Brown
2009-04-05mfd: remove DS1WM clock handlingPhilipp Zabel
This driver requests a clock that usually is supplied by the MFD in which the DS1WM is contained. Currently, it is impossible for a MFD to register their clocks with the generic clock API due to different implementations across architectures. For now, this patch removes the clock handling from DS1WM altogether, trusting that the MFD enable/disable functions will switch the clock if needed. The clock rate is obtained from a new parameter in driver_data. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-04-05mfd: remove unused PASIC3 bus_shift fieldPhilipp Zabel
Removes the now-unused bus_shift field from pasic3_platform_data. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-04-05mfd: convert DS1WM to use MFD corePhilipp Zabel
This patch converts the DS1WM driver into an MFD cell. It also calculates the bus_shift parameter from the memory resource size. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-04-05mfd: Support active high IRQs on WM835xMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-04-04Make non-compat preadv/pwritev use native register sizeLinus Torvalds
Instead of always splitting the file offset into 32-bit 'high' and 'low' parts, just split them into the largest natural word-size - which in C terms is 'unsigned long'. This allows 64-bit architectures to avoid the unnecessary 32-bit shifting and masking for native format (while the compat interfaces will obviously always have to do it). This also changes the order of 'high' and 'low' to be "low first". Why? Because when we have it like this, the 64-bit system calls now don't use the "pos_high" argument at all, and it makes more sense for the native system call to simply match the user-mode prototype. This results in a much more natural calling convention, and allows the compiler to generate much more straightforward code. On x86-64, we now generate testq %rcx, %rcx # pos_l js .L122 #, movq %rcx, -48(%rbp) # pos_l, pos from the C source loff_t pos = pos_from_hilo(pos_h, pos_l); ... if (pos < 0) return -EINVAL; and the 'pos_h' register isn't even touched. It used to generate code like mov %r8d, %r8d # pos_low, pos_low salq $32, %rcx #, tmp71 movq %r8, %rax # pos_low, pos.386 orq %rcx, %rax # tmp71, pos.386 js .L122 #, movq %rax, -48(%rbp) # pos.386, pos which isn't _that_ horrible, but it does show how the natural word size is just a more sensible interface (same arguments will hold in the user level glibc wrapper function, of course, so the kernel side is just half of the equation!) Note: in all cases the user code wrapper can again be the same. You can just do #define HALF_BITS (sizeof(unsigned long)*4) __syscall(PWRITEV, fd, iov, count, offset, (offset >> HALF_BITS) >> HALF_BITS); or something like that. That way the user mode wrapper will also be nicely passing in a zero (it won't actually have to do the shifts, the compiler will understand what is going on) for the last argument. And that is a good idea, even if nobody will necessarily ever care: if we ever do move to a 128-bit lloff_t, this particular system call might be left alone. Of course, that will be the least of our worries if we really ever need to care, so this may not be worth really caring about. [ Fixed for lost 'loff_t' cast noticed by Andrew Morton ] Acked-by: Gerd Hoffmann <kraxel@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-api@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: Ingo Molnar <mingo@elte.hu> Cc: Ralf Baechle <ralf@linux-mips.org>> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03ACPI: constify VFTs (1/2)Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-03Merge branch 'ipi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: s390: remove arch specific smp_send_stop() panic: clean up kernel/panic.c panic, smp: provide smp_send_stop() wrapper on UP too panic: decrease oops_in_progress only after having done the panic generic-ipi: eliminate WARN_ON()s during oops/panic generic-ipi: cleanups generic-ipi: remove CSD_FLAG_WAIT generic-ipi: remove kmalloc() generic IPI: simplify barriers and locking
2009-04-03Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: rename trace_softirq_[enter|exit] => lockdep_softirq_[enter|exit] lockdep: remove duplicate CONFIG_DEBUG_LOCKDEP definitions lockdep: require framepointers for x86 lockdep: remove extra "irq" string lockdep: fix incorrect state name
2009-04-03ACPI: update x2apic commentsSuresh Siddha
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-03x86, ACPI: add support for x2apic ACPI extensionsSuresh Siddha
All logical processors with APIC ID values of 255 and greater will have their APIC reported through Processor X2APIC structure (type-9 entry type) and all logical processors with APIC ID less than 255 will have their APIC reported through legacy Processor Local APIC (type-0 entry type) only. This is the same case even for NMI structure reporting. The Processor X2APIC Affinity structure provides the association between the X2APIC ID of a logical processor and the proximity domain to which the logical processor belongs. For OSPM, Procssor IDs outside the 0-254 range are to be declared as Device() objects in the ACPI namespace. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: remove compat stuff HID: constify arrays of struct apple_key_translation HID: add support for Kye/Genius Ergo 525V HID: Support Apple mini aluminum keyboard HID: support for Kensington slimblade device HID: DragonRise game controller force feedback driver HID: add support for another version of 0e8f:0003 device in hid-pl HID: fix race between usb_register_dev() and hiddev_open() HID: bring back possibility to specify vid/pid ignore on module load HID: make HID_DEBUG defaults consistent HID: autosuspend -- fix lockup of hid on reset HID: hid_reset_resume() needs to be defined only when CONFIG_PM is set HID: fix USB HID devices after STD with autosuspend HID: do not try to compile PM code with CONFIG_PM unset HID: autosuspend support for USB HID
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-03Staging: dst: core files.Evgeniy Polyakov
This patch contains DST core files, which introduce block layer, connector and sysfs registration glue and main headers. Connector is used for the configuration of the node (its type, address, device name and so on). Sysfs provides bits of information about running devices in the following format: +/* + * DST sysfs tree for device called 'storage': + * + * /sys/bus/dst/devices/storage/ + * /sys/bus/dst/devices/storage/type : 192.168.4.80:1025 + * /sys/bus/dst/devices/storage/size : 800 + * /sys/bus/dst/devices/storage/name : storage + */ DST header contains structure definitions and protocol command description. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: dma: Add SoF and EoF debugging to ipu_idmac.c, minor cleanup dw_dmac: add cyclic API to DW DMA driver dmaengine: Add privatecnt to revert DMA_PRIVATE property dmatest: add dma interrupts and callbacks dmatest: add xor test dmaengine: allow dma support for async_tx to be toggled async_tx: provide __async_inline for HAS_DMA=n archs dmaengine: kill some unused headers dmaengine: initialize tx_list in dma_async_tx_descriptor_init dma: i.MX31 IPU DMA robustness improvements dma: improve section assignment in i.MX31 IPU DMA driver dma: ipu_idmac driver cosmetic clean-up dmaengine: fail device registration if channel registration fails
2009-04-03Merge branch 'ext3-latency-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'ext3-latency-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext3: Add replace-on-rename hueristics for data=writeback mode ext3: Add replace-on-truncate hueristics for data=writeback mode ext3: Use WRITE_SYNC for commits which are caused by fsync() block_write_full_page: Use synchronous writes for WBC_SYNC_ALL writebacks
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: (32 commits) regulator: twl4030 VAUX3 supports 3.0V regulator: Support disabling of unused regulators by machines regulator: Don't increment use_count for boot_on regulators twl4030-regulator: expose VPLL2 regulator: refcount fixes regulator: Don't warn if we failed to get a regulator regulator: Allow boot_on regulators to be disabled by clients regulator: Implement list_voltage for WM835x LDOs and DCDCs twl4030-regulator: list more VAUX4 voltages regulator: Don't warn on omitted voltage constraints regulator: Implement list_voltage() for WM8400 DCDCs and LDOs MMC: regulator utilities regulator: twl4030 voltage enumeration (v2) regulator: twl4030 regulators regulator: get_status() grows kerneldoc regulator: enumerate voltages (v2) regulator: Fix get_mode() for WM835x DCDCs regulator: Allow regulators to set the initial operating mode regulator: Suggest use of datasheet supply or pin names for consumers regulator: email - update email address and regulator webpage. ...
2009-04-03Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Fix address wrap on 32-bit kernel. intel-iommu: Enable DMAR on 32-bit kernel. intel-iommu: fix PCI device detach from virtual machine intel-iommu: VT-d page table to support snooping control bit iommu: Add domain_has_cap iommu_ops intel-iommu: Snooping control support Fixed trivial conflicts in arch/x86/Kconfig and drivers/pci/intel-iommu.c
2009-04-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-fscacheLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-fscache: (41 commits) NFS: Add mount options to enable local caching on NFS NFS: Display local caching state NFS: Store pages from an NFS inode into a local cache NFS: Read pages from FS-Cache into an NFS inode NFS: nfs_readpage_async() needs to be accessible as a fallback for local caching NFS: Add read context retention for FS-Cache to call back with NFS: FS-Cache page management NFS: Add some new I/O counters for FS-Cache doing things for NFS NFS: Invalidate FsCache page flags when cache removed NFS: Use local disk inode cache NFS: Define and create inode-level cache objects NFS: Define and create superblock-level objects NFS: Define and create server-level objects NFS: Register NFS for caching and retrieve the top-level index NFS: Permit local filesystem caching to be enabled for NFS NFS: Add FS-Cache option bit and debug bit NFS: Add comment banners to some NFS functions FS-Cache: Make kAFS use FS-Cache CacheFiles: A cache that backs onto a mounted filesystem CacheFiles: Export things for CacheFiles ...
2009-04-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (36 commits) dm: set queue ordered mode dm: move wait queue declaration dm: merge pushback and deferred bio lists dm: allow uninterruptible wait for pending io dm: merge __flush_deferred_io into caller dm: move bio_io_error into __split_and_process_bio dm: rename __split_bio dm: remove unnecessary struct dm_wq_req dm: remove unnecessary work queue context field dm: remove unnecessary work queue type field dm: bio list add bio_list_add_head dm snapshot: persistent fix dtr cleanup dm snapshot: move status to exception store dm snapshot: move ctr parsing to exception store dm snapshot: use DMEMIT macro for status dm snapshot: remove dm_snap header dm snapshot: remove dm_snap header use dm exception store: move cow pointer dm exception store: move chunk_fields dm exception store: move dm_target pointer ...
2009-04-03Fix highmem PPC build failureKumar Gala
Commit f4112de6b679d84bd9b9681c7504be7bdfb7c7d5 ("mm: introduce debug_kmap_atomic") broke PPC builds with CONFIG_HIGHMEM=y: CC init/main.o In file included from include/linux/highmem.h:25, from include/linux/pagemap.h:11, from include/linux/mempolicy.h:63, from init/main.c:53: arch/powerpc/include/asm/highmem.h: In function 'kmap_atomic_prot': arch/powerpc/include/asm/highmem.h:98: error: implicit declaration of function 'debug_kmap_atomic' In file included from include/linux/pagemap.h:11, from include/linux/mempolicy.h:63, from init/main.c:53: include/linux/highmem.h: At top level: include/linux/highmem.h:196: warning: conflicting types for 'debug_kmap_atomic' include/linux/highmem.h:196: error: static declaration of 'debug_kmap_atomic' follows non-static declaration include/asm/highmem.h:98: error: previous implicit declaration of 'debug_kmap_atomic' was here make[1]: *** [init/main.o] Error 1 make: *** [init] Error 2 Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: ixp4xx - Fix handling of chained sg buffers crypto: shash - Fix unaligned calculation with short length hwrng: timeriomem - Use phys address rather than virt
2009-04-03Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (53 commits) md/raid5 revise rules for when to update metadata during reshape md/raid5: minor code cleanups in make_request. md: remove CONFIG_MD_RAID_RESHAPE config option. md/raid5: be more careful about write ordering when reshaping. md: don't display meaningless values in sysfs files resync_start and sync_speed md/raid5: allow layout and chunksize to be changed on active array. md/raid5: reshape using largest of old and new chunk size md/raid5: prepare for allowing reshape to change layout md/raid5: prepare for allowing reshape to change chunksize. md/raid5: clearly differentiate 'before' and 'after' stripes during reshape. Documentation/md.txt update md: allow number of drives in raid5 to be reduced md/raid5: change reshape-progress measurement to cope with reshaping backwards. md: add explicit method to signal the end of a reshape. md/raid5: enhance raid5_size to work correctly with negative delta_disks md/raid5: drop qd_idx from r6_state md/raid6: move raid6 data processing to raid6_pq.ko md: raid5 run(): Fix max_degraded for raid level 4. md: 'array_size' sysfs attribute md: centralize ->array_sectors modifications ...
2009-04-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/linux-hdreg-h-cleanupLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/linux-hdreg-h-cleanup: remove <linux/ata.h> include from <linux/hdreg.h> include/linux/hdreg.h: remove unused defines isd200: use ATA_* defines instead of *_STAT and *_ERR ones include/linux/hdreg.h: cover WIN_* and friends with #ifndef/#endif __KERNEL__ aoe: WIN_* -> ATA_CMD_* isd200: WIN_* -> ATA_CMD_* include/linux/hdreg.h: cover struct hd_driveid with #ifndef/#endif __KERNEL__ xsysace: make it 'struct hd_driveid'-free ubd_kern: make it 'struct hd_driveid'-free isd200: make it 'struct hd_driveid'-free
2009-04-03NFS: nfs_readpage_async() needs to be accessible as a fallback for local cachingDavid Howells
nfs_readpage_async() needs to be non-static so that it can be used as a fallback for the local on-disk caching should an EIO crop up when reading the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Add some new I/O counters for FS-Cache doing things for NFSDavid Howells
Add some new NFS I/O counters for FS-Cache doing things for NFS. A new line is emitted into /proc/pid/mountstats if caching is enabled that looks like: fsc: <rok> <rfl> <wok> <wfl> <unc> Where <rok> is the number of pages read successfully from the cache, <rfl> is the number of failed page reads against the cache, <wok> is the number of successful page writes to the cache, <wfl> is the number of failed page writes to the cache, and <unc> is the number of NFS pages that have been disconnected from the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Use local disk inode cacheDavid Howells
Bind data storage objects in the local cache to NFS inodes. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Define and create superblock-level objectsDavid Howells
Define and create superblock-level cache index objects (as managed by nfs_server structs). Each superblock object is created in a server level index object and is itself an index into which inode-level objects are inserted. Ideally there would be one superblock-level object per server, and the former would be folded into the latter; however, since the "nosharecache" option exists this isn't possible. The superblock object key is a sequence consisting of: (1) Certain superblock s_flags. (2) Various connection parameters that serve to distinguish superblocks for sget(). (3) The volume FSID. (4) The security flavour. (5) The uniquifier length. (6) The uniquifier text. This is normally an empty string, unless the fsc=xyz mount option was used to explicitly specify a uniquifier. The key blob is of variable length, depending on the length of (6). The superblock object is given no coherency data to carry in the auxiliary data permitted by the cache. It is assumed that the superblock is always coherent. This patch also adds uniquification handling such that two otherwise identical superblocks, at least one of which is marked "nosharecache", won't end up trying to share the on-disk cache. It will be possible to manually provide a uniquifier through a mount option with a later patch to avoid the error otherwise produced. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Define and create server-level objectsDavid Howells
Define and create server-level cache index objects (as managed by nfs_client structs). Each server object is created in the NFS top-level index object and is itself an index into which superblock-level objects are inserted. Ideally there would be one superblock-level object per server, and the former would be folded into the latter; however, since the "nosharecache" option exists this isn't possible. The server object key is a sequence consisting of: (1) NFS version (2) Server address family (eg: AF_INET or AF_INET6) (3) Server port. (4) Server IP address. The key blob is of variable length, depending on the length of (4). The server object is given no coherency data to carry in the auxiliary data permitted by the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Add FS-Cache option bit and debug bitDavid Howells
Add FS-Cache option bit to nfs_server struct. This is set to indicate local on-disk caching is enabled for a particular superblock. Also add debug bit for local caching operations. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03CacheFiles: Permit the page lock state to be monitoredDavid Howells
Add a function to install a monitor on the page lock waitqueue for a particular page, thus allowing the page being unlocked to be detected. This is used by CacheFiles to detect read completion on a page in the backing filesystem so that it can then copy the data to the waiting netfs page. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03FS-Cache: Implement data I/O part of netfs APIDavid Howells
Implement the data I/O part of the FS-Cache netfs API. The documentation and API header file were added in a previous patch. This patch implements the following functions for the netfs to call: (*) fscache_attr_changed(). Indicate that the object has changed its attributes. The only attribute currently recorded is the file size. Only pages within the set file size will be stored in the cache. This operation is submitted for asynchronous processing, and will return immediately. It will return -ENOMEM if an out of memory error is encountered, -ENOBUFS if the object is not actually cached, or 0 if the operation is successfully queued. (*) fscache_read_or_alloc_page(). (*) fscache_read_or_alloc_pages(). Request data be fetched from the disk, and allocate internal metadata to track the netfs pages and reserve disk space for unknown pages. These operations perform semi-asynchronous data reads. Upon returning they will indicate which pages they think can be retrieved from disk, and will have set in progress attempts to retrieve those pages. These will return, in order of preference, -ENOMEM on memory allocation error, -ERESTARTSYS if a signal interrupted proceedings, -ENODATA if one or more requested pages are not yet cached, -ENOBUFS if the object is not actually cached or if there isn't space for future pages to be cached on this object, or 0 if successful. In the case of the multipage function, the pages for which reads are set in progress will be removed from the list and the page count decreased appropriately. If any read operations should fail, the completion function will be given an error, and will also be passed contextual information to allow the netfs to fall back to querying the server for the absent pages. For each successful read, the page completion function will also be called. Any pages subsequently tracked by the cache will have PG_fscache set upon them on return. fscache_uncache_page() must be called for such pages. If supplied by the netfs, the mark_pages_cached() cookie op will be invoked for any pages now tracked. (*) fscache_alloc_page(). Allocate internal metadata to track a netfs page and reserve disk space. This will return -ENOMEM on memory allocation error, -ERESTARTSYS on signal, -ENOBUFS if the object isn't cached, or there isn't enough space in the cache, or 0 if successful. Any pages subsequently tracked by the cache will have PG_fscache set upon them on return. fscache_uncache_page() must be called for such pages. If supplied by the netfs, the mark_pages_cached() cookie op will be invoked for any pages now tracked. (*) fscache_write_page(). Request data be stored to disk. This may only be called on pages that have been read or alloc'd by the above three functions and have not yet been uncached. This will return -ENOMEM on memory allocation error, -ERESTARTSYS on signal, -ENOBUFS if the object isn't cached, or there isn't immediately enough space in the cache, or 0 if successful. On a successful return, this operation will have queued the page for asynchronous writing to the cache. The page will be returned with PG_fscache_write set until the write completes one way or another. The caller will not be notified if the write fails due to an I/O error. If that happens, the object will become available and all pending writes will be aborted. Note that the cache may batch up page writes, and so it may take a while to get around to writing them out. The caller must assume that until PG_fscache_write is cleared the page is use by the cache. Any changes made to the page may be reflected on disk. The page may even be under DMA. (*) fscache_uncache_page(). Indicate that the cache should stop tracking a page previously read or alloc'd from the cache. If the page was alloc'd only, but unwritten, it will not appear on disk. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03FS-Cache: Implement the cookie management part of the netfs APIDavid Howells
Implement the cookie management part of the FS-Cache netfs client API. The documentation and API header file were added in a previous patch. This patch implements the following three functions: (1) fscache_acquire_cookie(). Acquire a cookie to represent an object to the netfs. If the object in question is a non-index object, then that object and its parent indices will be created on disk at this point if they don't already exist. Index creation is deferred because an index may reside in multiple caches. (2) fscache_relinquish_cookie(). Retire or release a cookie previously acquired. At this point, the object on disk may be destroyed. (3) fscache_update_cookie(). Update the in-cache representation of a cookie. This is used to update the auxiliary data for coherency management purposes. With this patch it is possible to have a netfs instruct a cache backend to look up, validate and create metadata on disk and to destroy it again. The ability to actually store and retrieve data in the objects so created is added in later patches. Note that these functions will never return an error. _All_ errors are handled internally to FS-Cache. The worst that can happen is that fscache_acquire_cookie() may return a NULL pointer - which is considered a negative cookie pointer and can be passed back to any function that takes a cookie without harm. A negative cookie pointer merely suppresses caching at that level. The stub in linux/fscache.h will detect inline the negative cookie pointer and abort the operation as fast as possible. This means that the compiler doesn't have to set up for a call in that case. See the documentation in Documentation/filesystems/caching/netfs-api.txt for more information. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03FS-Cache: Add netfs registrationDavid Howells
Add functions to register and unregister a network filesystem or other client of the FS-Cache service. This allocates and releases the cookie representing the top-level index for a netfs, and makes it available to the netfs. If the FS-Cache facility is disabled, then the calls are optimised away at compile time. Note that whilst this patch may appear to work with FS-Cache enabled and a netfs attempting to use it, it will leak the cookie it allocates for the netfs as fscache_relinquish_cookie() is implemented in a later patch. This will cause the slab code to emit a warning when the module is removed. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
