Add a function that operates on the second doubleword in the page struct
and manipulates the object counters, the freelist and the frozen attribute.
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
We need to be able to use cmpxchg_double on the freelist and object count
field in struct page. Rearrange the fields in struct page according to
doubleword entities so that the freelist pointer comes before the counters.
Do the rearranging with a future in mind where we use more doubleword
atomics to avoid locking of updates to flags/mapping or lru pointers.
Create another union to allow access to counters in struct page as a
single unsigned long value.
The doublewords must be properly aligned for cmpxchg_double to work.
Sadly this increases the size of page struct by one word on some architectures.
But as a resultpage structs are now cacheline aligned on x86_64.
Do not use a page flag for the frozen bit. It needs to be part
of the state that is handled with cmpxchg_double(). So use a bit
in the counter struct in the page struct for that purpose.
Under heavy memory and filesystem load, users observe the assertion
mapping->nrpages == 0 in end_writeback() trigger. This can be caused by
page reclaim reclaiming the last page from a mapping in the following
race:
CPU0 CPU1
shrink_page_list()
__remove_mapping()
__delete_from_page_cache()
radix_tree_delete()
evict_inode()
truncate_inode_pages()
truncate_inode_pages_range()
pagevec_lookup() - finds nothing
end_writeback()
mapping->nrpages != 0 -> BUG
page->mapping = NULL
mapping->nrpages--
Fix the problem by doing a reliable check of mapping->nrpages under
mapping->tree_lock in end_writeback().
Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out
by Miklos Szeredi <mszeredi@suse.de>.
Cc: Jay <jinshan.xiong@whamcloud.com>
Cc: Miklos Szeredi <mszeredi@suse.de>
Cc: <stable@kernel.org>
This is required for tilegx to be able to use the compat unistd.h header
where compat_sys_sendmmsg() is now mentioned.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Although it is used (by i915) on nothing but tmpfs, read_cache_page_gfp()
is unsuited to tmpfs, because it inserts a page into pagecache before
calling the filesystem's ->readpage: tmpfs may have pages in swapcache
which only it knows how to locate and switch to filecache.
At present tmpfs provides a ->readpage method, and copes with this by
copying pages; but soon we can simplify it by removing its ->readpage.
Provide shmem_read_mapping_page_gfp() now, ready for that transition,
Export shmem_read_mapping_page_gfp() and add it to list in shmem_fs.h,
with shmem_read_mapping_page() inline for the common mapping_gfp case.
(shmem_read_mapping_page_gfp or shmem_read_cache_page_gfp? Generally the
read_mapping_page functions use the mapping's ->readpage, and the
read_cache_page functions use the supplied filler, so I think
read_cache_page_gfp was slightly misnamed.)
2.6.35's new truncate convention gave tmpfs the opportunity to control
its file truncation, no longer enforced from outside by vmtruncate().
We shall want to build upon that, to handle pagecache and swap together.
Slightly redefine the ->truncate_range interface: let it now be called
between the unmap_mapping_range()s, with the filesystem responsible for
doing the truncate_inode_pages_range() from it - just as the filesystem
is nowadays responsible for doing that from its ->setattr.
Let's rename shmem_notify_change() to shmem_setattr(). Instead of
calling the generic truncate_setsize(), bring that code in so we can
call shmem_truncate_range() - which will later be updated to perform its
own variant of truncate_inode_pages_range().
Remove the punch_hole unmap_mapping_range() from shmem_truncate_range():
now that the COW's unmap_mapping_range() comes after ->truncate_range,
there is no need to call it a third time.
Export shmem_truncate_range() and add it to the list in shmem_fs.h, so
that i915_gem_object_truncate() can call it explicitly in future; get
this patch in first, then update drm/i915 once this is available (until
then, i915 will just be doing the truncate_inode_pages() twice).
Though introduced five years ago, no other filesystem is implementing
->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we
expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly,
whereupon ->truncate_range can be removed from inode_operations -
shmem_truncate_range() will help i915 across that transition too.
Before adding any more global entry points into shmem.c, gather such
prototypes into shmem_fs.h. Remove mm's own declarations from swap.h,
but for now leave the ones in mm.h: because shmem_file_setup() and
shmem_zero_setup() are called from various places, and we should not
force other subsystems to update immediately.
Fix 'make htmldocs' warnings:
Warning(/include/linux/hrtimer.h:153): No description found for parameter 'clockid'
Warning(/include/linux/device.h:604): Excess struct/union/enum/typedef member 'of_match' description in 'device'
Warning(/include/net/sock.h:349): Excess struct/union/enum/typedef member 'sk_rmem_alloc' description in 'sock'
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
mmc: queue: bring discard_granularity/alignment into line with SCSI
mmc: queue: append partition subname to queue thread name
mmc: core: make erase timeout calculation allow for gated clock
mmc: block: switch card to User Data Area when removing the block driver
mmc: sdio: reset card during power_restore
mmc: cb710: fix #ifdef HAVE_EFFICIENT_UNALIGNED_ACCESS
mmc: sdhi: DMA slave ID 0 is invalid
mmc: tmio: fix regression in TMIO_MMC_WRPROTECT_DISABLE handling
mmc: omap_hsmmc: use original sg_len for dma_unmap_sg
mmc: omap_hsmmc: fix ocr mask usage
mmc: sdio: fix runtime PM path during driver removal
mmc: Add PCI fixup quirks for Ricoh 1180:e823 reader
mmc: sdhi: fix module unloading
mmc: of_mmc_spi: add NO_IRQ define to of_mmc_spi.c
mmc: vub300: fix null dereferences in error handling
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end
of nodes. But, it's not defined in linux/mmzone.h but defined in
/arch/???/include/mmzone.h which is included only under
CONFIG_NEED_MULTIPLE_NODES=y.
Then, we see
mm/page_cgroup.c: In function 'page_cgroup_init':
mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn'
mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn'
So, fixiing page_cgroup.c is an idea...
But node_start_pfn()/node_end_pfn() is a very generic macro and
should be implemented in the same manner for all archs.
(m32r has different implementation...)
This patch removes definitions of node_start/end_pfn() in each archs
and defines a unified one in linux/mmzone.h. It's not under
CONFIG_NEED_MULTIPLE_NODES, now.
A result of macro expansion is here (mm/page_cgroup.c)
for !NUMA
start_pfn = ((&contig_page_data)->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
for NUMA (x86-64)
start_pfn = ((node_data[nid])->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
Changelog:
- fixed to avoid using "nid" twice in node_end_pfn() macro.
Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com>
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: Remove unneeded version.h includes from sound/
ASoC: pxa-ssp: Correct check for stream presence
ASoC: imx: add missing module informations
ASoC: imx: Remove unused Kconfig SND_MXC_SOC_SSI entry
ALSA: HDA: Pinfix quirk for HP Z200 Workstation
ALSA: VIA HDA: Create a master amplifier control for VT1718S.
ALSA: VIA HDA: Mute/unmute mixer conncted to Headphone for VT1718S.
ALSA: VIA HDA: Modify initial verbs list for VT1718S.
ALSA: hda - Remove ALC268 model override for CPR2000
ALSA: HDA: Remove quirk for an HP device
ASoC: Remove unused and about to be broken SND_SOC_CUSTOM I/O bus
* 'for-linus' of git://git.kernel.dk/linux-block:
block: add REQ_SECURE to REQ_COMMON_MASK
block: use the passed in @bdev when claiming if partno is zero
block: Add __attribute__((format(printf...) and fix fallout
block: make disk_block_events() properly wait for work cancellation
block: remove non-syncing __disk_block_events() and fold it into disk_block_events()
block: don't use non-syncing event blocking in disk_check_events()
cfq-iosched: fix locking around ioc->ioc_data assignment
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PCI / PM: Block races between runtime PM and system sleep
PM / Domains: Update documentation
PM / Runtime: Handle clocks correctly if CONFIG_PM_RUNTIME is unset
PM: Fix async resume following suspend failure
PM: Free memory bitmaps if opening /dev/snapshot fails
PM: Rename dev_pm_info.in_suspend to is_prepared
PM: Update documentation regarding sysdevs
PM / Runtime: Update doc: usage count no longer incremented across system PM
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Fix decode_secinfo_maxsz
NFSv4.1: Fix an off-by-one error in pnfs_generic_pg_test
NFSv4.1: Fix some issues with pnfs_generic_pg_test
NFSv4.1: file layout must consider pg_bsize for coalescing
pnfs-obj: No longer needed to take an extra ref at add_device
SUNRPC: Ensure the RPC client only quits on fatal signals
NFSv4: Fix a readdir regression
nfs4.1: mark layout as bad on error path in _pnfs_return_layout
nfs4.1: prevent race that allowed use of freed layout in _pnfs_return_layout
NFSv4.1: need to put_layout_hdr on _pnfs_return_layout error path
NFS: (d)printks should use %zd for ssize_t arguments
NFSv4.1: fix break condition in pnfs_find_lseg
nfs4.1: fix several problems with _pnfs_return_layout
NFSv4.1: allow zero fh array in filelayout decode layout
NFSv4.1: allow nfs_fhget to succeed with mounted on fileid
NFSv4.1: Fix a refcounting issue in the pNFS device id cache
NFSv4.1: deprecate headerpadsz in CREATE_SESSION
NFS41: do not update isize if inode needs layoutcommit
NLM: Don't hang forever on NLM unlock requests
NFS: fix umount of pnfs filesystems
The PM core doesn't handle suspend failures correctly when it comes to
asynchronously suspended devices. These devices are moved onto the
dpm_suspended_list as soon as the corresponding async thread is
started up, and they remain on the list even if they fail to suspend
or the sleep transition is cancelled before they get suspended. As a
result, when the PM core unwinds the transition, it tries to resume
the devices even though they were never suspended.
This patch (as1474) fixes the problem by adding a new "is_suspended"
flag to dev_pm_info. Devices are resumed only if the flag is set.
[rjw:
* Moved the dev->power.is_suspended check into device_resume(),
because we need to complete dev->power.completion and clear
dev->power.is_prepared too for devices whose
dev->power.is_suspended flags are unset.
* Fixed __device_suspend() to avoid setting dev->power.is_suspended
if async_error is different from zero.]
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable@kernel.org
This patch (as1473) renames the "in_suspend" field in struct
dev_pm_info to "is_prepared", in preparation for an upcoming change.
The new name is more descriptive of what the field really means.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
jbd2: Fix oops in jbd2_journal_remove_journal_head()
jbd2: Remove obsolete parameters in the comments for some jbd2 functions
ext4: fixed tracepoints cleanup
ext4: use FIEMAP_EXTENT_LAST flag for last extent in fiemap
ext4: Fix max file size and logical block counting of extent format file
ext4: correct comments for ext4_free_blocks()
Commit 13e12d14e2dc ("vfs: reorganize 'struct inode' layout a bit")
moved things around a bit changed i_state to be unsigned int instead of
unsigned long. That was to help structure layout for the 64-bit case,
and shrink 'struct inode' a bit (admittedly that only happened when
spinlock debugging was on and i_flags didn't pack with i_lock).
However, Meelis Roos reports that this results in unaligned exceptions
on sprc, and it turns out that the bit-locking primitives that we use
for the I_NEW bit want to use the bitops. Which want 'unsigned long',
not 'unsigned int'.
We really should fix the bit locking code to not have that kind of
requirement, but that's a much bigger change. So for now, revert that
field back to 'unsigned long' (but keep the other re-ordering changes
from the commit that caused this).
Andi points out that we have played games with this in 'struct page', so
it's solvable with other hacks too, but since right now the struct inode
size advantage only happens with some rare config options, it's not
worth fighting.
It _would_ be worth fixing the bitlocking code, though. Especially
since there is no type safety in the bitlocking code (this never caused
any warnings, and worked fine on x86-64, because the bitlocks take a
'void *' and x86-64 doesn't care that deeply about alignment). So it's
currently a very easy problem to trigger by mistake and never notice.
Reported-by: Meelis Roos <mroos@linux.ee>
* 'for-2.6.40' of git://linux-nfs.org/~bfields/linux:
nfsd4: fix break_lease flags on nfsd open
nfsd: link returns nfserr_delay when breaking lease
nfsd: v4 support requires CRYPTO
nfsd: fix dependency of nfsd on auth_rpcgss
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits)
pxa168_eth: fix race in transmit path.
ipv4, ping: Remove duplicate icmp.h include
netxen: fix race in skb->len access
sgi-xp: fix a use after free
hp100: fix an skb->len race
netpoll: copy dev name of slaves to struct netpoll
ipv4: fix multicast losses
r8169: fix static initializers.
inet_diag: fix inet_diag_bc_audit()
gigaset: call module_put before restart of if_open()
farsync: add module_put to error path in fst_open()
net: rfs: enable RFS before first data packet is received
fs_enet: fix freescale FCC ethernet dp buffer alignment
netdev: bfin_mac: fix memory leak when freeing dma descriptors
vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan support
caif: Bugfix - XOFF removed channel from caif-mux
tun: teach the tun/tap driver to support netpoll
dp83640: drop PHY status frames in the driver.
dp83640: fix phy status frame event parsing
phylib: Allow BCM63XX PHY to be selected only on BCM63XX.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
devcgroup_inode_permission: take "is it a device node" checks to inlined wrapper
fix comment in generic_permission()
kill obsolete comment for follow_down()
proc_sys_permission() is OK in RCU mode
reiserfs_permission() doesn't need to bail out in RCU mode
proc_fd_permission() is doesn't need to bail out in RCU mode
nilfs2_permission() doesn't need to bail out in RCU mode
logfs doesn't need ->permission() at all
coda_ioctl_permission() is safe in RCU mode
cifs_permission() doesn't need to bail out in RCU mode
bad_inode_permission() is safe from RCU mode
ubifs: dereferencing an ERR_PTR in ubifs_mount()
Otherwise we end up overflowing the rpc buffer size on the receive end.
Signed-off-by: Benny Halevy <benny@tonian.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: sh_keysc - 8x8 MODE_6 fix
Input: omap-keypad - add missing input_sync()
Input: evdev - try to wake up readers only if we have full packet
Input: properly assign return value of clamp() macro.
inode_permission() calls devcgroup_inode_permission() and almost all such
calls are _not_ for device nodes; let's at least keep the common path
straight...
Add REQ_SECURE flag to REQ_COMMON_MASK so that
init_request_from_bio() can pass it to @req->cmd_flags.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: stable@kernel.org # 2.6.36 and newer
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
'timers-urgent-for-linus' and 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tools/perf: Fix static build of perf tool
tracing: Fix regression in printk_formats file
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
generic-ipi: Fix kexec boot crash by initializing call_single_queue before enabling interrupts
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: Make watchdog robust vs. interruption
timerfd: Fix wakeup of processes when timer is cancelled on clock change
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, MAINTAINERS: Add x86 MCE people
x86, efi: Do not reserve boot services regions within reserved areas
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Move RCU_BOOST #ifdefs to header file
rcu: use softirq instead of kthreads except when RCU_BOOST=y
rcu: Use softirq to address performance regression
rcu: Simplify curing of load woes
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
According to the data sheet for G4, AP4 and AG5 KEYSC MODE_6 is 8x8 keys.
Bump up MAXKEYS to 64 too.
Signed-off-by: Magnus Damm <damm@opensource.se>
Reviewed-by: Simon Horman <horms@verge.net.au>
git://git.secretlab.ca/git/linux-2.6
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6:
gpio: add GPIOF_ values regardless on kconfig settings
gpio: include linux/gpio.h where needed
gpio/omap4: Fix missing interrupts during device wakeup due to IOPAD.
* 'spi/merge' of git://git.secretlab.ca/git/linux-2.6:
spi/bfin_spi: fix handling of default bits per word setting
____call_usermodehelper() now erases any credentials set by the
subprocess_inf::init() function. The problem is that commit
17f60a7da150 ("capabilites: allow the application of capability limits
to usermode helpers") creates and commits new credentials with
prepare_kernel_cred() after the call to the init() function. This wipes
all keyrings after umh_keys_init() is called.
The best way to deal with this is to put the init() call just prior to
the commit_creds() call, and pass the cred pointer to init(). That
means that umh_keys_init() and suchlike can modify the credentials
_before_ they are published and potentially in use by the rest of the
system.
This prevents request_key() from working as it is prevented from passing
the session keyring it set up with the authorisation token to
/sbin/request-key, and so the latter can't assume the authority to
instantiate the key. This causes the in-kernel DNS resolver to fail
with ENOKEY unconditionally.
Acked-by: Eric Paris <eparis@redhat.com>
Tested-by: Jeff Layton <jlayton@redhat.com>
enabling interrupts
There is a problem that kdump(2nd kernel) sometimes hangs up due
to a pending IPI from 1st kernel. Kernel panic occurs because IPI
comes before call_single_queue is initialized.
To fix the crash, rename init_call_single_data() to call_function_init()
and call it in start_kernel() so that call_single_queue can be
initialized before enabling interrupts.
The details of the crash are:
(1) 2nd kernel boots up
(2) A pending IPI from 1st kernel comes when irqs are first enabled
in start_kernel().
(3) Kernel tries to handle the interrupt, but call_single_queue
is not initialized yet at this point. As a result, in the
generic_smp_call_function_single_interrupt(), NULL pointer
dereference occurs when list_replace_init() tries to access
&q->list.next.
Therefore this patch changes the name of init_call_single_data()
to call_function_init() and calls it before local_irq_enable()
in start_kernel().
Signed-off-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Milton Miller <miltonm@bga.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: kexec@lists.infradead.org
Link: http://lkml.kernel.org/r/D6CBEE2F420741indou.takao@jp.fujitsu.com
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon/kms: use helper functions for fence read/write
drm/radeon/kms: set DP link config properly for DP bridges
drm/radeon/kms/atom: AdjustPixelClock fixes for DP bridges
drm/radeon/kms: fix handling of DP to LVDS bridges
drm/radeon/kms: issue blank/unblank commands for ext encoders
drm/radeon/kms: fix support for DDC on dp bridges
drm/radeon/kms: add support for load detection on dp bridges
drm/radeon/kms: add missing external encoder action
drm/radeon/kms: rework atombios_get_encoder_mode()
drm/radeon/kms: fix num crtcs for Cedar and Caicos
Revert "drm/i915: Enable GMBUS for post-gen2 chipsets"
drivers/gpu/drm: use printk_ratelimited instead of printk_ratelimit
drm/radeon: workaround a hw bug on some radeon chipsets with all-0 EDIDs.
drm: make debug levels match in edid failure code.
drm/radeon/kms: clear wb memory by default
drm/radeon/kms: be more pedantic about the g5 quirk (v2)
drm/radeon/kms: signed fix for evergreen thermal
drm: populate irq_by_busid-member for pci
The clocksource watchdog code is interruptible and it has been
observed that this can trigger false positives which disable the TSC.
The reason is that an interrupt storm or a long running interrupt
handler between the read of the watchdog source and the read of the
TSC brings the two far enough apart that the delta is larger than the
unstable treshold. Move both reads into a short interrupt disabled
region to avoid that.
Reported-and-tested-by: Vernon Mauery <vernux@us.ibm.com>
AFS: Use i_generation not i_version for the vnode uniquifier
AFS: Set s_id in the superblock to the volume name
vfs: Fix data corruption after failed write in __block_write_begin()
afs: afs_fill_page reads too much, or wrong data
VFS: Fix vfsmount overput on simultaneous automount
fix wrong iput on d_inode introduced by e6bc45d65d
Delay struct net freeing while there's a sysfs instance refering to it
afs: fix sget() races, close leak on umount
ubifs: fix sget races
ubifs: split allocation of ubifs_info into a separate function
fix leak in proc_set_super()
Avoid double seq adjustment for loopback traffic
because it causes silent repetition of TCP data. One
example is passive FTP with DNAT rule and difference in the
length of IP addresses.
This patch adds check if packet is sent and
received via loopback device. As the same conntrack is
used both for outgoing and incoming direction, we restrict
seq adjustment to happen only in POSTROUTING.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Make GPIOF_ defined values available even when GPIOLIB nor GENERIC_GPIO
is enabled by moving them to <linux/gpio.h>.
Fixes these build errors in linux-next:
sound/soc/codecs/ak4641.c:524: error: 'GPIOF_OUT_INIT_LOW' undeclared (first use in this function)
sound/soc/codecs/wm8915.c:2921: error: 'GPIOF_OUT_INIT_LOW' undeclared (first use in this function)
Some RS690 chipsets seem to end up with floating connectors, either
a DVI connector isn't actually populated, or an add-in HDMI card
is available but not installed. In this case we seem to get a NULL byte
response for each byte of the i2c transaction, so we detect this
case and if we see it we don't do anymore DDC transactions on this
connector.
I've tested this on my RS690 without the HDMI card installed and
it seems to work fine.
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
The "hostname" tool falls back to setting the hostname to "localhost" if
/etc/hostname does not exist. Distribution init scripts have the same
fallback. However, if userspace never calls sethostname, such as when
booting with init=/bin/sh, or otherwise booting a minimal system without
the usual init scripts, the default hostname of "(none)" remains,
unhelpfully appearing in various places such as prompts ("root@(none):~#")
and logs. Furthermore, "(none)" doesn't typically resolve to anything
useful.
Make the default hostname configurable. This removes the need for the
standard fallback, provides a useful default for systems that never call
sethostname, and makes minimal systems that much more useful with less
configuration. Distributions could choose to use "localhost" here to
avoid the fallback, while embedded systems may wish to use a specific
target hostname.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: David Miller <davem@davemloft.net>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Kel Modderman <kel@otaku42.de>
BUILD_BUG_ON_ZERO and BUILD_BUG_ON_NULL must return values, even in the
CHECKER case otherwise various users of it become syntactically invalid.
Signed-off-by: Dr. David Alan Gilbert <linux@treblig.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Recently, Robert Mueller reported (http://lkml.org/lkml/2010/9/12/236)
that zone_reclaim_mode doesn't work properly on his new NUMA server (Dual
Xeon E5520 + Intel S5520UR MB). He is using Cyrus IMAPd and it's built on
a very traditional single-process model.
* a master process which reads config files and manages the other
process
* multiple imapd processes, one per connection
* multiple pop3d processes, one per connection
* multiple lmtpd processes, one per connection
* periodical "cleanup" processes.
There are thousands of independent processes. The problem is, recent
Intel motherboard turn on zone_reclaim_mode by default and traditional
prefork model software don't work well on it. Unfortunatelly, such models
are still typical even in the 21st century. We can't ignore them.
This patch raises the zone_reclaim_mode threshold to 30. 30 doesn't have
any specific meaning. but 20 means that one-hop QPI/Hypertransport and
such relatively cheap 2-4 socket machine are often used for traditional
servers as above. The intention is that these machines don't use
zone_reclaim_mode.
Note: ia64 and Power have arch specific RECLAIM_DISTANCE definitions.
This patch doesn't change such high-end NUMA machine behavior.
Dave Hansen said:
: I know specifically of pieces of x86 hardware that set the information
: in the BIOS to '21' *specifically* so they'll get the zone_reclaim_mode
: behavior which that implies.
: They've done performance testing and run very large and scary benchmarks
: to make sure that they _want_ this turned on. What this means for them
: is that they'll probably be de-optimized, at least on newer versions of
: the kernel.
: If you want to do this for particular systems, maybe _that_'s what we
: should do. Have a list of specific configurations that need the
: defaults overridden either because they're buggy, or they have an
: unusual hardware configuration not really reflected in the distance
: table.
And later said:
: The original change in the hardware tables was for the benefit of a
: benchmark. Said benchmark isn't going to get run on mainline until the
: next batch of enterprise distros drops, at which point the hardware where
: this was done will be irrelevant for the benchmark. I'm sure any new
: hardware will just set this distance to another yet arbitrary value to
: make the kernel do what it wants. :)
: Also, when the hardware got _set_ to this initially, I complained. So, I
: guess I'm getting my way now, with this patch. I'm cool with it.
Reported-by: Robert Mueller <robm@fastmail.fm>
Acked-by: Christoph Lameter <cl@linux.com>
Acked-by: David Rientjes <rientjes@google.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Fix <linux/kmsg_dump.h> when CONFIG_PRINTK is not enabled:
include/linux/kmsg_dump.h:56: error: 'EINVAL' undeclared (first use in this function)
include/linux/kmsg_dump.h:61: error: 'EINVAL' undeclared (first use in this function)
Looks like commit 595dd3d8bf95 ("kmsg_dump: fix build for
CONFIG_PRINTK=n") uses EINVAL without having the needed header file(s),
but I'm sure that I build tested that patch also. oh well.
While testing for memcg aware swap token, I observed a swap token was
often grabbed an intermittent running process (eg init, auditd) and they
never release a token.
Why?
Some processes (eg init, auditd, audispd) wake up when a process exiting.
And swap token can be get first page-in process when a process exiting
makes no swap token owner. Thus such above intermittent running process
often get a token.
And currently, swap token priority is only decreased at page fault path.
Then, if the process sleep immediately after to grab swap token, the swap
token priority never be decreased. That's obviously undesirable.
This patch implement very poor (and lightweight) priority aging. It only
be affect to the above corner case and doesn't change swap tendency
workload performance (eg multi process qsbench load)
This is useful for observing swap token activity.
example output:
zsh-1845 [000] 598.962716: update_swap_token_priority:
mm=ffff88015eaf7700 old_prio=1 new_prio=0
memtoy-1830 [001] 602.033900: update_swap_token_priority:
mm=ffff880037a45880 old_prio=947 new_prio=949
memtoy-1830 [000] 602.041509: update_swap_token_priority:
mm=ffff880037a45880 old_prio=949 new_prio=951
memtoy-1830 [000] 602.051959: update_swap_token_priority:
mm=ffff880037a45880 old_prio=951 new_prio=953
memtoy-1830 [000] 602.052188: update_swap_token_priority:
mm=ffff880037a45880 old_prio=953 new_prio=955
memtoy-1830 [001] 602.427184: put_swap_token:
token_mm=ffff880037a45880
zsh-1789 [000] 602.427281: replace_swap_token:
old_token_mm= (null) old_prio=0 new_token_mm=ffff88015eaf7018
new_prio=2
zsh-1789 [001] 602.433456: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=2 new_prio=4
zsh-1789 [000] 602.437613: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=4 new_prio=6
zsh-1789 [000] 602.443924: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=6 new_prio=8
zsh-1789 [000] 602.451873: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=8 new_prio=10
zsh-1789 [001] 602.462639: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=10 new_prio=12
Acked-by: Rik van Riel<riel@redhat.com>
Currently, memcg reclaim can disable swap token even if the swap token mm
doesn't belong in its memory cgroup. It's slightly risky. If an admin
creates very small mem-cgroup and silly guy runs contentious heavy memory
pressure workload, every tasks are going to lose swap token and then
system may become unresponsive. That's bad.
This patch adds 'memcg' parameter into disable_swap_token(). and if the
parameter doesn't match swap token, VM doesn't disable it.
Reviewed-by: Rik van Riel<riel@redhat.com>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
