RPS currently depends on SMP and SYSFS
Adding a CONFIG_RPS makes sense in case this requirement changes in the
future. This patch saves about 1500 bytes of kernel text in case SMP is
on but SYSFS is off.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ath5k/phy.c
There is no point to align or pad mibs to cache lines, they are per cpu
allocated with a 8 bytes alignment anyway.
This wastes space for no gain. This patch removes __SNMP_MIB_ALIGN__
Since SNMP mibs contain "unsigned long" fields only, we can relax the
allocation alignment from "unsigned long long" to "unsigned long"
Its currently hard to diagnose when ACK frames are dropped because an
application set TCP_DEFER_ACCEPT on its listening socket.
See http://bugzilla.kernel.org/show_bug.cgi?id=15507
This patch adds a SNMP value, named TCPDeferAcceptDrop
netstat -s | grep TCPDeferAcceptDrop
TCPDeferAcceptDrop: 0
This counter is incremented every time we drop a pure ACK frame received
by a socket in SYN_RECV state because its SYNACK retrans count is lower
than defer_accept value.
After the type change, addresses in unicast and multicast lists wouldn't make
sense, not to mention possible different lenghts. So flush both lists here.
Note "dev_addr_discard" will be very soon replaced by "dev_mc_flush" (once
mc_list conversion will be done).
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Ignore the new NETDEV_PRE_TYPE_CHANGE event in rtnetlink_event() since
there have been no changes userspace needs to be notified of.
Also add a comment to the netdev notifier event definitions to remind
people to update the exclusion list when adding new event types.
Convert to list macro's for the list of addresses per interface
in IPv6.
Convert from reader/writer lock to RCU and spinlock for addrconf
hash list.
Adds an additional helper macro for hlist_for_each_entry_continue_rcu
to handle the continue case.
Using hash list macros, simplifies code and helps later RCU.
This patch includes some initialization that is not strictly necessary,
since an empty hlist node/list is all zero; and list is in BSS
and node is allocated with kzalloc.
Use list macros instead of open coded linked list.
This patch fixes a bug that allows to lose events when reliable
event delivery mode is used, ie. if NETLINK_BROADCAST_SEND_ERROR
and NETLINK_RECV_NO_ENOBUFS socket options are set.
Currently, ENOBUFS errors are reported to the socket via
netlink_set_err() even if NETLINK_RECV_NO_ENOBUFS is set. However,
that should not happen. This fixes this problem and it changes the
prototype of netlink_set_err() to return the number of sockets that
have set the NETLINK_RECV_NO_ENOBUFS socket option. This return
value is used in the next patch in these bugfix series.
This patch fixes a unaligned access in nla_get_be64() that was
introduced by myself in a17c859849402315613a0015ac8fbf101acf0cc1.
When doing "ifenslave -d bond0 eth0", there is chance to get NULL
dereference in netif_receive_skb(), because dev->master suddenly becomes
NULL after we tested it.
We should use ACCESS_ONCE() to avoid this (or rcu_dereference())
This patch adds the possibility to refuse the bonding type change for
other subsystems (such as for example bridge, vlan, etc.)
Since generally there could be more netdevices changing type other
than bonding, making this event type name "bonding-unrelated"
Signed-off-by: Tom Herbert <therbert@google.com>
IEEE 802.3ae clause 45 specifies a somewhat modified MDIO protocol
for use by 10GIGE phys. The main change is a 21 bit address split into
a 5 bit device ID and a 16 bit register offset. The definition is designed
so that normal and extended devices can run on the same MDIO bus.
Extend mdio-bitbang to do the new protocol. At the MDIO bus level the
protocol is requested by or'ing MII_ADDR_C45 into the register offset.
Make phy_read/phy_write/etc pass a full 32 bit register offset.
This does not attempt to make the phy layer support C45 style PHYs, just
to provide the MDIO bus support.
Tested against a Broadcom 10GE phy with ID 0x206034, and several
Broadcom 10/100/1000 Phys in normal mode.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
`ip -s link` shows interface counters truncated to 32 bit. This is
because interface statistics are transported only in 32-bit quantity
to userspace. This commit adds a new IFLA_STATS64 attribute that
exports them in full 64 bit.
References: http://lkml.indiana.edu/hypermail/linux/kernel/0307.3/0215.html
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
This patch implements software receive side packet steering (RPS). RPS
distributes the load of received packet processing across multiple CPUs.
Problem statement: Protocol processing done in the NAPI context for received
packets is serialized per device queue and becomes a bottleneck under high
packet load. This substantially limits pps that can be achieved on a single
queue NIC and provides no scaling with multiple cores.
This solution queues packets early on in the receive path on the backlog queues
of other CPUs. This allows protocol processing (e.g. IP and TCP) to be
performed on packets in parallel. For each device (or each receive queue in
a multi-queue device) a mask of CPUs is set to indicate the CPUs that can
process packets. A CPU is selected on a per packet basis by hashing contents
of the packet header (e.g. the TCP or UDP 4-tuple) and using the result to index
into the CPU mask. The IPI mechanism is used to raise networking receive
softirqs between CPUs. This effectively emulates in software what a multi-queue
NIC can provide, but is generic requiring no device support.
Many devices now provide a hash over the 4-tuple on a per packet basis
(e.g. the Toeplitz hash). This patch allow drivers to set the HW reported hash
in an skb field, and that value in turn is used to index into the RPS maps.
Using the HW generated hash can avoid cache misses on the packet when
steering it to a remote CPU.
The CPU mask is set on a per device and per queue basis in the sysfs variable
/sys/class/net/<device>/queues/rx-<n>/rps_cpus. This is a set of canonical
bit maps for receive queues in the device (numbered by <n>). If a device
does not support multi-queue, a single variable is used for the device (rx-0).
Generally, we have found this technique increases pps capabilities of a single
queue device with good CPU utilization. Optimal settings for the CPU mask
seem to depend on architectures and cache hierarcy. Below are some results
running 500 instances of netperf TCP_RR test with 1 byte req. and resp.
Results show cumulative transaction rate and system CPU utilization.
e1000e on 8 core Intel
Without RPS: 108K tps at 33% CPU
With RPS: 311K tps at 64% CPU
forcedeth on 16 core AMD
Without RPS: 156K tps at 15% CPU
With RPS: 404K tps at 49% CPU
bnx2x on 16 core AMD
Without RPS 567K tps at 61% CPU (4 HW RX queues)
Without RPS 738K tps at 96% CPU (8 HW RX queues)
With RPS: 854K tps at 76% CPU (4 HW RX queues)
Caveats:
- The benefits of this patch are dependent on architecture and cache hierarchy.
Tuning the masks to get best performance is probably necessary.
- This patch adds overhead in the path for processing a single packet. In
a lightly loaded server this overhead may eliminate the advantages of
increased parallelism, and possibly cause some relative performance degradation.
We have found that masks that are cache aware (share same caches with
the interrupting CPU) mitigate much of this.
- The RPS masks can be changed dynamically, however whenever the mask is changed
this introduces the possibility of generating out of order packets. It's
probably best not change the masks too frequently.
include/linux/netdevice.h | 32 ++++-
include/linux/skbuff.h | 3 +
net/core/dev.c | 335 +++++++++++++++++++++++++++++++++++++--------
net/core/net-sysfs.c | 225 ++++++++++++++++++++++++++++++-
net/core/skbuff.c | 2 +
5 files changed, 538 insertions(+), 59 deletions(-)
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
Rename static get_cpu_id() to acpi_get_cpuid() and export it.
This change also gives us an opportunity to remove the
#ifndef CONFIG_SMP from processor_driver.c and into a header file
where it properly belongs.
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
Signed-off-by: Len Brown <len.brown@intel.com>
We've renamed the old processor_core.c to processor_driver.c, to
convey the idea that it can be built modular and has driver-like
bits.
Now let's re-create a processor_core.c for the bits needed
statically by the rest of the kernel. The contents of processor_pdc.c
are a good starting spot, so let's just rename that file and
complete our three card monte.
Add support for resource windows. This is for bridge resources, i.e.,
regions where a bridge forwards transactions from the primary to the
secondary side.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Add support for bus number resources. This is for bridges with a range of
bus numbers behind them.
No functional change; this just makes room for another resource type.
This file was missed in the original patch that went into Linus' tree.
Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org>
Cc: linux-i2c@vger.kernel.org
Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: i8042 - add ALDI/MEDION netbook E1222 to qurik reset table
Input: ALPS - fix stuck buttons on some touchpads
Input: wm831x-on - convert to use genirq
Input: ads7846 - add wakeup support
Input: appletouch - fix integer overflow issue
Input: ad7877 - increase pen up imeout
Input: ads7846 - add support for AD7843 parts
Input: bf54x-keys - fix system hang when pressing a key
Input: alps - add support for the touchpad on Toshiba Tecra A11-11L
Input: remove BKL, fix input_open_file() locking
Input: serio_raw - remove BKL
Input: mousedev - remove BKL
Input: add driver for TWL4030 vibrator device
Input: enable remote wakeup for PNP i8042 keyboard ports
Input: scancode in get/set_keycodes should be unsigned
Input: i8042 - use platfrom_create_bundle() helper
Input: wacom - merge out and in prox events
Input: gamecon - fix off by one range check
Input: wacom - replace WACOM_PKGLEN_PENABLED
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c-algo-bit: Add pre- and post-xfer hooks
at24: Init dynamic bin_attribute structures
i2c: Drop configure option I2C_DEBUG_CHIP
tsl2550: Move from i2c/chips to misc
i2c-i801: Don't use the block buffer for I2C block writes
i2c-powermac: Be less verbose in the absence of real errors.
i2c-smbus: Use device_lock/device_unlock
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: Skip check for mandatory locks when unlocking
9p: Fixes a simple bug enabling writes beyond 2GB.
9p: Change the name of new protocol from 9p2010.L to 9p2000.L
fs/9p: re-init the wstat in readdir loop
net/9p: Add sysfs mount_tag file for virtio 9P device
net/9p: Use the tag name in the config space for identifying mount point
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits)
bridge: ensure to unlock in error path in br_multicast_query().
drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages
sky2: Avoid rtnl_unlock without rtnl_lock
ipv6: Send netlink notification when DAD fails
drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant
ipconfig: Handle devices which take some time to come up.
mac80211: Fix memory leak in ieee80211_if_write()
mac80211: Fix (dynamic) power save entry
ipw2200: use kmalloc for large local variables
ath5k: read eeprom IQ calibration values correctly for G mode
ath5k: fix I/Q calibration (for real)
ath5k: fix TSF reset
ath5k: use fixed antenna for tx descriptors
libipw: split ieee->networks into small pieces
mac80211: Fix sta_mtx unlocking on insert STA failure path
rt2x00: remove KSEG1ADDR define from rt2x00soc.h
net: add ColdFire support to the smc91x driver
asix: fix setting mac address for AX88772
ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}.
net: Fix dev_mc_add()
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
locking: Make sparse work with inline spinlocks and rwlocks
x86/mce: Fix RCU lockdep splats
rcu: Increase RCU CPU stall timeouts if PROVE_RCU
ftrace: Replace read_barrier_depends() with rcu_dereference_raw()
rcu: Suppress RCU lockdep warnings during early boot
rcu, ftrace: Fix RCU lockdep splat in ftrace_perf_buf_prepare()
rcu: Suppress __mpol_dup() false positive from RCU lockdep
rcu: Make rcu_read_lock_sched_held() handle !PREEMPT
rcu: Add control variables to lockdep_rcu_dereference() diagnostics
rcu, cgroup: Relax the check in task_subsys_state() as early boot is now handled by lockdep-RCU
rcu: Use wrapper function instead of exporting tasklist_lock
sched, rcu: Fix rcu_dereference() for RCU-lockdep
rcu: Make task_subsys_state() RCU-lockdep checks handle boot-time use
rcu: Fix holdoff for accelerated GPs for last non-dynticked CPU
x86/gart: Unexport gart_iommu_aperture
Fix trivial conflicts in kernel/trace/ftrace.c
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Provide generic perf_sample_data initialization
MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainer
perf trace: Don't use pager if scripting
perf trace/scripting: Remove extraneous header read
perf, ARM: Modify kuser rmb() call to compile for Thumb-2
x86/stacktrace: Don't dereference bad frame pointers
perf archive: Don't try to collect files without a build-id
perf_events, x86: Fixup fixed counter constraints
perf, x86: Restrict the ANY flag
perf, x86: rename macro in ARCH_PERFMON_EVENTSEL_ENABLE
perf, x86: add some IBS macros to perf_event.h
perf, x86: make IBS macros available in perf_event.h
hw-breakpoints: Remove stub unthrottle callback
x86/hw-breakpoints: Remove the name field
perf: Remove pointless breakpoint union
perf lock: Drop the buffers multiplexing dependency
perf lock: Fix and add misc documentally things
percpu: Add __percpu sparse annotations to hw_breakpoint
Drivers might have to do random things before and/or after I2C
transfers. Add hooks to the i2c-algo-bit implementation to let them do
so.
Cc: Alex Deucher <alexdeucher@gmail.com>
This patch changes the name of the new 9P protocol from 9p2010.L to
9p2000.u. This is because we learnt that the name 9p2010 is already
being used by others.
Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
This adds a new file for virtio 9P device. The file
contain details of the mount device name that should
be used to mount the 9P file system.
Ex: /sys/devices/virtio-pci/virtio1/mount_tag file now
contian the tag name to be used to mount the 9P file system.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch use the tag name in the config space to identify the
mount device. The the virtio device name depend on the enumeration
order of the device and may not remain the same across multiple boots
So we use the tag name which is set via qemu option to uniquely identify
the mount device
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6:
fat: Fix stat->f_namelen
fat: Fix vfat_lookup()
Currently sparse does not work with inline spinlock and rwlock functions.
The problem is that they do not use the __acquires/__releases out-of-line
functions, but use inline functions with no sparse annotations.
This patch adds the appropriate annotations to make it work properly.
Signed-off-by: Luca Barbieri <luca@luca-barbieri.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
Extern declarations in sysctl.c should be moved to their own header file,
and then include them in relavant .c files.
Move epoll_table extern declaration to linux/poll.h
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Move lockdep extern declarations to linux/lockdep.h
Move max_lock_depth extern declaration to linux/rtmutex.h
Move acct_parm extern declaration to linux/acct.h
Move sg_big_buff extern declaration to scsi/sg.h
Acked-by: Doug Gilbert <dgilbert@interlog.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Move modprobe_path extern declaration to linux/kmod.h
Move modules_disabled extern declaration to linux/module.h
Move rcutorture_runnable extern declaration to linux/rcupdate.h
Acked-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Move print_fatal_signals extern declaration to linux/signal.h
Cc: Roland McGrath <roland@redhat.com>
Move C_A_D extern variable declaration to linux/reboot.h
