The mqueuefs filesystem will use this helper as well. Proc's main get_sb
could also be made to use it, but that will require a bit more rework.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
The I2C functionality provided by the i2c-voodoo3 driver is moved into the
tdfxfb (frame buffer driver for Voodoo3 cards). This way there is no
conflict between the i2c driver and the fb driver.
The tdfxfb does not make use from the DDC functionality yet but provides
all the functionality of the i2c-voodoo3 driver.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Acked-by: Jean Delvare <khali@linux-fr.org>
Add disable/enable_kretprobe() and disable/enable_jprobe().
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Add disable_kprobe() and enable_kprobe() to disable/enable kprobes
temporarily.
disable_kprobe() asynchronously disables probe handlers of specified
kprobe. So, after calling it, some handlers can be called at a while.
enable_kprobe() enables specified kprobe.
aggr_pre_handler and aggr_post_handler check disabled probes. On the
other hand aggr_break_handler and aggr_fault_handler don't check it
because these handlers will be called while executing pre or post handlers
and usually those help error handling.
Fix comment style in kprobes.h.
Some SPI controllers have restrictions on DMAable buffers alignemt.
Currently if the buffer supplied by protocol driver is not properly
aligned, the controller silently performs transfer in PIO mode. Addition
of dma_alignment field to spi_master allows protocol drivers to perform
proper alignment.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Cc: Bryan Wu <bryan.wu@analog.com>
Cc: David Brownell <david-b@pacbell.net>
Add /proc entries to give the admin the ability to control the minimum and
maximum number of pdflush threads. This allows finer control of pdflush
on both large and small machines.
The rationale is simply one size does not fit all. Admins on large and/or
small systems may want to tune the min/max pdflush thread count to best
suit their needs. Right now the min/max is hardcoded to 2/8. While
probably a fair estimate for smaller machines, large machines with large
numbers of CPUs and large numbers of filesystems/block devices may benefit
from larger numbers of threads working on different block devices.
Even if the background flushing algorithm is radically changed, it is
still likely that multiple threads will be involved and admins would still
desire finer control on the min/max other than to have to recompile the
kernel.
The patch adds '/proc/sys/vm/nr_pdflush_threads_min' and
'/proc/sys/vm/nr_pdflush_threads_max' with r/w permissions.
The minimum value for nr_pdflush_threads_min is 1 and the maximum value is
the current value of nr_pdflush_threads_max. This minimum is required
since additional thread creation is performed in a pdflush thread itself.
The minimum value for nr_pdflush_threads_max is the current value of
nr_pdflush_threads_min and the maximum value can be 1000.
Documentation/sysctl/vm.txt is also updated.
[akpm@linux-foundation.org: fix comment, fix whitespace, use __read_mostly]
Signed-off-by: Peter W Morreale <pmorreale@novell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (28 commits)
powerpc: Fix oops when loading modules
powerpc: Wire up preadv and pwritev
powerpc/ftrace: Fix printf format warning
powerpc/ftrace: Fix #if that should be #ifdef
powerpc: Fix ptrace compat wrapper for FPU register access
powerpc: Print information about mapping hw irqs to virtual irqs
powerpc: Correct dependency of KEXEC
powerpc: Disable VSX or current process in giveup_fpu/altivec
powerpc/pseries: Enable relay in pseries_defconfig
powerpc/pseries: Fix ibm,client-architecture comment
powerpc/pseries: Scan for all events in rtasd
powerpc/pseries: Add dispatch dispersion statistics
powerpc: Clean up some prom printouts
powerpc: Print progress of ibm,client-architecture method
powerpc: Remove duplicated #include's
powerpc/pmac: Fix internal modem IRQ on Wallstreet PowerBook
powerpc/wdrtas: Update wdrtas_get_interval to use rtas_data_buf
fsl-diu-fb: Pass the proper device for dma mapping routines
powerpc/pq2fads: Update device tree for use with device-tree-aware u-boot.
cpm_uart: Disable CPM udbg when re-initing CPM uart, even if not the console.
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (120 commits)
cx231xx: Convert to snd_card_create()
V4L/DVB (11440): PWC: fix build error when CONFIG_INPUT=m
V4L/DVB (11439): UVC: uvc_status_cleanup(): undefined reference to `input_unregister_device'
V4L/DVB (11438): au0828: fix Kconfig dependance
V4L/DVB (11437): pvrusb2: Drop client_register/unregister stubs
V4L/DVB (11436): radio-mr800: convert to to v4l2_device
V4L/DVB (11435): dsbr100 radio: convert to to v4l2_device
V4L/DVB: zr364xx: remove unused #include <version.h>
V4L/DVB: usbvision: remove unused #include <version.h>
V4L/DVB (11427): gspca - m5602: Minor cleanups
V4L/DVB (11426): gspca - m5602: Don't touch hflip/vflip register on Read/Modify/Write
V4L/DVB (11425): gspca - m5602: Move the vflip quirk to probe stage.
V4L/DVB (11424): gspca - m5602-ov9650: Use the local ctrl cache. Adjust image on vflip.
V4L/DVB (11423): gspca - m5602-ov9650: Add a disconnect hook, setup a ctrl cache ctrl.
V4L/DVB (11422): gspca - m5602-ov9650: Replace a magic constant with a define
V4L/DVB (11421): gspca - m5602-ov9650: Synthesize modesetting.
V4L/DVB (11420): gspca - m5602: Improve error handling in the ov9650 driver
V4L/DVB (11419): gspca - m5602-ov9650: Don't read exposure data from COM1.
V4L/DVB (11418): gspca - m5602-ov9650: Auto white balancing is on by default
V4L/DVB (11417): gspca - m5602-ov9650: Autogain is on by default
Add support to the SQ-905 driver to pass back to user space the
sensor orientation information obtained from the camera during init.
Modifies gspca and the videodev2.h header to create the necessary
API.
[mchehab@redhat.com: Changed "Output is" to "Frames are" at the comments, as suggested at LMML]
Signed-off-by: Adam Baker <linux@baker-net.org.uk>
Remove support for the debug call VIDIOC_INT_S_AUDIO_ROUTING from cx18
and ivtv. These internal ioctls shouldn't be exposed. These were only
used through the cx18-ctl and ivtv-ctl utilities, and only when testing
a new card variant.
This cleanup allows the removal of this ioctl from v4l2-common.h.
Cc: Andy Walls <awalls@radix.net>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
It is no longer needed to use a struct pointer as argument, since v4l2_subdev
doesn't require that ioctl-like approach anymore. Instead just pass the input,
output and config (new!) arguments directly.
v4l2_subdev.
With all the v4l2_subdev changes that were made to these drivers it is a
good idea to increase the version number of each driver.
It's just the patch level that is increased, except for the zoran and saa7146
drivers where the minor number was increased due to the more substantial
changes that were made to those two drivers.
possible i2c addrs.
Rather than duplicating this list everywhere, just put it in tvaudio.h.
to new_(probed)_subdev
The functions v4l2_i2c_new_subdev and v4l2_i2c_new_probed_subdev relied on
i2c_get_adapdata to return the v4l2_device. However, this is not always
possible on embedded platforms. So modify the API to pass the v4l2_device
pointer explicitly.
Add utility function to probe for a single address, rather than a list
of addresses.
< 2.6.22
Originally the intention was to switch to the new style i2c API starting with
the introduction of the API in 2.6.22. However, the i2c_new_probed_device()
function has a lethal bug that wasn't fixed until 2.6.25. Or more accurately,
it was only fixed in the stable series of 2.6.25 and 2.6.26.
Given the fact that the new i2c API also changed starting with 2.6.26 (the
addition of i2c_device_id), it is easiest to switch APIs starting with
2.6.26.
This patch updates all the legacy code accordingly.
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
core->init.
The init callback was used in several places to load firmware. Make a separate
load_fw callback for that. This makes the code a lot more understandable.
s_standby is only used to put the tuner in powersaving mode, so move it
from core to tuner.
Now that all drivers are converted to v4l2_subdev we can remove legacy code
in v4l2-common. Also move the documentation of the internal API to
v4l2-subdev.h where it really belongs.
v4l2-subdev.c and v4l2-i2c-drv-legacy.h were used to support the old i2c
API. All v4l drivers are now converted to v4l2_subdev, so these two files
can be removed.
Signed-off-by: Srinivasa Deevi <srinivasa.deevi@conexant.com>
[mchehab@redhat.com: Remove the Kconfig changes, to avoid git breakages]
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
* git://git.infradead.org/mtd-2.6: (53 commits)
[MTD] struct device - replace bus_id with dev_name(), dev_set_name()
[MTD] [NOR] Fixup for Numonyx M29W128 chips
[MTD] mtdpart: Make ecc_stats more realistic.
powerpc/85xx: TQM8548: Update DTS file for multi-chip support
powerpc: NAND: FSL UPM: document new bindings
[MTD] [NAND] FSL-UPM: Add wait flags to support board/chip specific delays
[MTD] [NAND] FSL-UPM: add multi chip support
[MTD] [NOR] Add device parent info to physmap_of
[MTD] [NAND] Add support for NAND on the Socrates board
[MTD] [NAND] Add support for 4KiB pages.
[MTD] sysfs support should not depend on CONFIG_PROC_FS
[MTD] [NAND] Add parent info for CAFÉ controller
[MTD] support driver model updates
[MTD] driver model updates (part 2)
[MTD] [NAND] move gen_nand's probe function to .devinit.text
[MTD] [MAPS] move sa1100 flash's probe function to .devinit.text
[MTD] fix use after free in register_mtd_blktrans
[MTD] [MAPS] Drop now unused sharpsl-flash map
[MTD] ofpart: Check name property to determine partition nodes.
Manually fix trivial conflict in drivers/mtd/maps/Makefile
Fixes:
In file included from drivers/serial/mux.c:37:
include/linux/serial_core.h: In function 'uart_handle_sysrq_char':
include/linux/serial_core.h:467: error: 'struct uart_port' has no member named 'sysrq'
include/linux/serial_core.h:468: error: 'struct uart_port' has no member named 'sysrq'
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Will Page <will.page@ni.com>
Signed-off-by: Shawn Bohrer <shawn.bohrer@ni.com>
This implements basic support for all 843x RS232 devices, but does not
add DMA support. This means that sustained data transfers at high baud
rates may not be possible on multiple ports simultaneously.
* git://git.infradead.org/iommu-2.6:
drivers/pci/intr_remapping.c: include acpi.h
intel-iommu: Fix oops in device_to_iommu() when devices not found.
intel-iommu: Handle PCI domains appropriately.
intel-iommu: Fix device-to-iommu mapping for PCI-PCI bridges.
x2apic/intr-remap: decouple interrupt remapping from x2apic
x86, dmar: check if it's initialized before disable queue invalidation
intel-iommu: set compatibility format interrupt
Intel IOMMU Suspend/Resume Support - Interrupt Remapping
Intel IOMMU Suspend/Resume Support - Queued Invalidation
Intel IOMMU Suspend/Resume Support - DMAR
intel-iommu: Add for_each_iommu() and for_each_active_iommu() macros
* 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: add stack dumps to asserts
hrtimer: fix rq->lock inversion (again)
* 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kmemtrace: trace kfree() calls with NULL or zero-length objects
kmemtrace: small cleanups
kmemtrace: restore original tracing data binary format, improve ABI
kmemtrace: kmemtrace_alloc() must fill type_id
kmemtrace: use tracepoints
kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints
kmemtrace, rcu: fix rcupreempt.c data structure dependencies
kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies
kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies
kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c
kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c
kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c
kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c
kmemtrace, squashfs: fix slab.h dependency problem in squasfs
kmemtrace, befs: fix slab.h dependency problem
kmemtrace, security: fix linux/key.h header file dependencies
kmemtrace, fs: fix linux/fdtable.h header file dependencies
kmemtrace, fs: uninline simple_transaction_set()
kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
* 'for-2.6.30' of git://linux-nfs.org/~bfields/linux: (81 commits)
nfsd41: define nfsd4_set_statp as noop for !CONFIG_NFSD_V4
nfsd41: define NFSD_DRC_SIZE_SHIFT in set_max_drc
nfsd41: Documentation/filesystems/nfs41-server.txt
nfsd41: CREATE_EXCLUSIVE4_1
nfsd41: SUPPATTR_EXCLCREAT attribute
nfsd41: support for 3-word long attribute bitmask
nfsd: dynamically skip encoded fattr bitmap in _nfsd4_verify
nfsd41: pass writable attrs mask to nfsd4_decode_fattr
nfsd41: provide support for minor version 1 at rpc level
nfsd41: control nfsv4.1 svc via /proc/fs/nfsd/versions
nfsd41: add OPEN4_SHARE_ACCESS_WANT nfs4_stateid bmap
nfsd41: access_valid
nfsd41: clientid handling
nfsd41: check encode size for sessions maxresponse cached
nfsd41: stateid handling
nfsd: pass nfsd4_compound_state* to nfs4_preprocess_{state,seq}id_op
nfsd41: destroy_session operation
nfsd41: non-page DRC for solo sequence responses
nfsd41: Add a create session replay cache
nfsd41: create_session operation
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
i2c: Delete unused i2c-algo-sgi helper module
i2c: Delete many unused driver IDs
i2c: Deprecate client_register and client_unregister methods
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (74 commits)
[SCSI] sg: fix q->queue_lock on scsi_error_handler path
[SCSI] replace __inline with inline
[SCSI] a2091: make 2 functions static
[SCSI] a3000: make 2 functions static
[SCSI] ses: #if 0 the unused ses_match_host()
[SCSI] use kmem_cache_zalloc instead of kmem_cache_alloc/memset
[SCSI] sg: fix iovec bugs introduced by the block layer conversion
[SCSI] qlogicpti: use request_firmware
[SCSI] advansys: use request_firmware
[SCSI] qla1280: use request_firmware
[SCSI] libiscsi: fix iscsi pool error path
[SCSI] cxgb3i: call ddp release function directly
[SCSI] cxgb3i: merge cxgb3i_ddp into cxgb3i module
[SCSI] cxgb3i: close all tcp connections upon chip reset
[SCSI] cxgb3i: re-read ddp settings information after chip reset
[SCSI] cxgb3i: re-initialize ddp settings after chip reset
[SCSI] cxgb3i: subscribe to error notification from cxgb3 driver
[SCSI] aacraid driver update
[SCSI] mptsas: remove unneeded check
[SCSI] config: Make need for SCSI_CDROM clearer
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds:
leds: introduce lp5521 led driver
leds: just ignore invalid GPIOs in leds-gpio
leds: Fix &&/|| confusion in leds-pca9532.c
leds: move h1940-leds's probe function to .devinit.text
leds: remove an unnecessary "goto" on drivers/leds/leds-s3c24.c
leds: add BD2802GU LED driver
leds: remove experimental flag from leds-clevo-mail
leds: Prevent multiple LED triggers with the same name
leds: Add gpio-led trigger
leds: Add rb532 LED driver for the User LED
leds: Add suspend/resume state flags to leds-gpio
leds: simple driver for pwm driven LEDs
leds: Fix leds-gpio driver multiple module_init/exit usage
leds: Add dac124s085 driver
leds: allow led-drivers to use a variable range of brightness values
leds: Add openfirmware platform device support
Fixes following modpost error:
ERROR: "nfsd4_set_statp" [fs/nfsd/nfsd.ko] undefined!
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Fixes the following compiler error:
fs/nfsd/nfssvc.c: In function 'set_max_drc':
fs/nfsd/nfssvc.c:240: error: 'NFSD_DRC_SIZE_SHIFT' undeclared
CONFIG_NFSD_V4 is not set
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
The i2c-algo-sgi code was merged into the vino driver, so we can
delete it now.
Delete many unused I2C driver IDs. We should be able to get rid of
i2c_driver.id pretty soon now.
The new i2c binding model makes the client_register and
client_unregister methods of struct i2c_adapter useless, so we can
remove them with the rest of the legacy model.
ROHM BD2802GU is a RGB LED controller attached to i2c bus and specifically
engineered for decoration purposes. This RGB controller incorporates
lighting patterns and illuminates.
This driver is designed to minimize power consumption, so when there is no
emitting LED, it enters to reset state. And because the BD2802GU has lots
of features that can't be covered by the current LED framework, it
provides Advanced Configuration Function(ADF) mode, so that user
applications can set registers of BD2802GU directly.
Here are basic usage examples :
; to turn on LED (not blink)
$ echo 1 > /sys/class/leds/led1_R/brightness
; to blink LED
$ echo timer > /sys/class/leds/led1_R/trigger
$ echo 1 > /sys/class/leds/led1_R/delay_on
$ echo 1 > /sys/class/leds/led1_R/delay_off
; to turn off LED
$ echo 0 > /sys/class/leds/led1_R/brightness
Signed-off-by: Kim Kyuwon <chammoru@gmail.com>
Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
Add an option to preserve LED state when suspending/resuming to the LED
gpio driver. Based on a suggestion from Robert Jarzmik.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Add a simple driver for pwm driver LEDs. pwm_id and period can be defined
in board file. It is developed for pxa, however it is probably generic
enough to be used on other platforms with pwm.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
This patch allows drivers to override the default maximum brightness value
of 255. We take care to preserve backwards-compatibility as much as
possible, so that user-space ABI doesn't change for existing drivers.
LED trigger code has also been updated to use the per-LED maximum.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
By default, CFQ will anticipate more IO from a given io context if the
previously completed IO was sync. This used to be fine, since the only
sync IO was reads and O_DIRECT writes. But with more "normal" sync writes
being used now, we don't want to anticipate for those.
Add a bio/request flag that informs the IO scheduler that this is a sync
request that we should not idle for. Introduce WRITE_ODIRECT specifically
for O_DIRECT writes, and make sure that the other sync writes set this
flag.
(S)WRITE_SYNC always unplugs the device right after IO submission.
Sometimes we want to build up a queue before doing so, so add
variants that explicitly DON'T unplug the queue. The caller must
then do that after submitting all the IO.
This makes sure that we never wait on async IO for sync requests, instead
of doing the split on writes vs reads.
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
