KVM_REQ_KICK poisons vcpu->requests by having a bit set during normal
operation. This causes the fast path check for a clear vcpu->requests
to fail all the time, triggering tons of atomic operations.
Fix by replacing KVM_REQ_KICK with a vcpu->guest_mode atomic.
Signed-off-by: Avi Kivity <avi@redhat.com>
In common cases, guest SRAO MCE will cause corresponding poisoned page
be un-mapped and SIGBUS be sent to QEMU-KVM, then QEMU-KVM will relay
the MCE to guest OS.
But it is reported that if the poisoned page is accessed in guest
after unmapping and before MCE is relayed to guest OS, userspace will
be killed.
The reason is as follows. Because poisoned page has been un-mapped,
guest access will cause guest exit and kvm_mmu_page_fault will be
called. kvm_mmu_page_fault can not get the poisoned page for fault
address, so kernel and user space MMIO processing is tried in turn. In
user MMIO processing, poisoned page is accessed again, then userspace
is killed by force_sig_info.
To fix the bug, kvm_mmu_page_fault send HWPOISON signal to QEMU-KVM
and do not try kernel and user space MMIO processing for poisoned
page.
[xiao: fix warning introduced by avi]
Reported-by: Max Asbock <masbock@linux.vnet.ibm.com>
Signed-off-by: Huang Ying <ying.huang@intel.com>
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6:
davinci: da850/omap-l138 evm: account for DEFDCDC{2,3} being tied high
regulator: tps6507x: allow driver to use DEFDCDC{2,3}_HIGH register
wm8350-regulator: fix wm8350_register_regulator error handling
ab3100: fix off-by-one value range checking for voltage selector
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
In TPS6507x, depending on the status of DEFDCDC{2,3} pin either
DEFDCDC{2,3}_LOW or DEFDCDC{2,3}_HIGH register needs to be read or
programmed to change the output voltage.
The current driver assumes DEFDCDC{2,3} pins are always tied low
and thus operates only on DEFDCDC{2,3}_LOW register. This need
not always be the case (as is found on OMAP-L138 EVM).
Unfortunately, software cannot read the status of DEFDCDC{2,3} pins.
So, this information is passed through platform data depending on
how the board is wired.
Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
s2io: fixing DBG_PRINT() macro
ath9k: fix dma direction for map/unmap in ath_rx_tasklet
net: dev_forward_skb should call nf_reset
net sched: fix race in mirred device removal
tun: avoid BUG, dump packet on GSO errors
bonding: set device in RLB ARP packet handler
wimax/i2400m: Add PID & VID for Intel WiMAX 6250
ipv6: Don't add routes to ipv6 disabled interfaces.
net: Fix skb_copy_expand() handling of ->csum_start
net: Fix corruption of skb csum field in pskb_expand_head() of net/core/skbuff.c
macvtap: Limit packet queue length
ixgbe/igb: catch invalid VF settings
bnx2x: Advance a module version
bnx2x: Protect statistics ramrod and sequence number
bnx2x: Protect a SM state change
wireless: use netif_rx_ni in ieee80211_send_layer2_update
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI / Sleep: Allow the NVS saving to be skipped during suspend to RAM
ACPI: create "processor.bm_check_disable" boot param
ACPI: skip checking BM_STS if the BIOS doesn't ask for it
ACPI: fix unused function warning
ACPI: processor: fix processor_physically_present on UP
ACPI video: fix string mismatch for Sony SR290 laptop
ACPI battery: don't invoke power_supply_changed twice when battery is hot-added
ACPI: handle systems which asynchoronously enable ACPI mode
This fixes hang when target device of mirred packet classifier
action is removed.
If a mirror or redirection action is configured to cause packets
to go to another device, the classifier holds a ref count, but was assuming
the adminstrator cleaned up all redirections before removing. The fix
is to add a notifier and cleanup during unregister.
The new list is implicitly protected by RTNL mutex because
it is held during filter add/delete as well as notifier.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
Commit 2a6b69765ad794389f2fc3e14a0afa1a995221c2
(ACPI: Store NVS state even when entering suspend to RAM) caused the
ACPI suspend code save the NVS area during suspend and restore it
during resume unconditionally, although it is known that some systems
need to use acpi_sleep=s4_nonvs for hibernation to work. To allow
the affected systems to avoid saving and restoring the NVS area
during suspend to RAM and resume, introduce kernel command line
option acpi_sleep=nonvs and make acpi_sleep=s4_nonvs work as its
alias temporarily (add acpi_sleep=s4_nonvs to the feature removal
file).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16396 .
Reported-and-tested-by: tomas m <tmezzadra@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
vmlinux.lds: fix .data..init_task output section (fix popwerpc boot)
powerpc: Fix erroneous lmb->memblock conversions
powerpc/mm: Add some debug output when hash insertion fails
powerpc/mm: Fix bugs in huge page hashing
powerpc/mm: Move around testing of _PAGE_PRESENT in hash code
powerpc/mm: Handle hypervisor pte insert failure in __hash_page_huge
powerpc/kexec: Fix boundary case for book-e kexec memory limits
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Fix fallback to cplus_demangle() when bfd_demangle() is not available
perf annotate: Fix handling of goto labels that are valid hex numbers
tracing: Properly align linker defined symbols
perf symbols: Fix directory descriptor leaking
perf: Fix various display bugs with parent filtering
The .data..init_task output section was missing
a load offset causing a popwerpc target to fail to boot.
Sean MacLennan tracked it down to the definition of
INIT_TASK_DATA_SECTION().
There are only two users of INIT_TASK_DATA_SECTION()
in the kernel today: cris and popwerpc.
cris do not support relocatable kernels and is thus not
impacted by this change.
Fix INIT_TASK_DATA_SECTION() to specify load offset like
all other output sections.
Reported-by: Sean MacLennan <smaclennan@pikatech.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
It turns out that there is a bit in the _CST for Intel FFH C3
that tells the OS if we should be checking BM_STS or not.
Linux has been unconditionally checking BM_STS.
If the chip-set is configured to enable BM_STS,
it can retard or completely prevent entry into
deep C-states -- as illustrated by turbostat:
http://userweb.kernel.org/~lenb/acpi/utils/pmtools/turbostat/
ref: Intel Processor Vendor-Specific ACPI Interface Specification
table 4 "_CST FFH GAS Field Encoding"
Bit 1: Set to 1 if OSPM should use Bus Master avoidance for this C-state
https://bugzilla.kernel.org/show_bug.cgi?id=15886
Mark Wagner reported OOM symptoms when sending UDP traffic over
a macvtap link to a kvm receiver.
This appears to be caused by the fact that macvtap packet queues
are unlimited in length. This means that if the receiver can't
keep up with the rate of flow, then we will hit OOM. Of course
it gets worse if the OOM killer then decides to kill the receiver.
This patch imposes a cap on the packet queue length, in the same
way as the tuntap driver, using the device TX queue length.
Please note that macvtap currently has no way of giving congestion
notification, that means the software device TX queue cannot be
used and packets will always be dropped once the macvtap driver
queue fills up.
This shouldn't be a great problem for the scenario where macvtap
is used to feed a kvm receiver, as the traffic is most likely
external in origin so congestion notification can't be applied
anyway.
Of course, if anybody decides to complain about guest-to-guest
UDP packet loss down the track, then we may have to revisit this.
Incidentally, this patch also fixes a real memory leak when
macvtap_get_queue fails.
Chris Wright noticed that for this patch to work, we need a
non-zero TX queue length. This patch includes his work to change
the default macvtap TX queue length to 500.
Reported-by: Mark Wagner <mwagner@redhat.com>
Acked-by: Chris Wright <chrisw@sous-sol.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
sysrq,kdb: Use __handle_sysrq() for kdb's sysrq function
debug_core,kdb: fix kgdb_connected bit set in the wrong place
Fix merge regression from external kdb to upstream kdb
repair gdbstub to match the gdbserial protocol specification
kdb: break out of kdb_ll() when command is terminated
The kdb code should not toggle the sysrq state in case an end user
wants to try and resume the normal kernel execution.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
math-emu: correct test for downshifting fraction in _FP_FROM_INT()
perf: Add DWARF register lookup for sparc
MAINTAINERS: Add SBUS driver path to sparc entry.
drivers/sbus: Remove unnecessary casts of private_data
sparc: remove homegrown L1_CACHE_ALIGN macro
sparc64: fix the build error due to smp_kgdb_capture_client()
sparc64: Fix maybe_change_configuration() PCR setting.
arch/sparc/kernel: Eliminate what looks like a NULL pointer dereference
sparc64: Update defconfig.
sunsu: Fix use after free in su_remove().
sunserial: Don't call add_preferred_console() when console= is specified.
sparc32: Kill none_mask, it's bogus.
The kernel's math-emu code contains a macro _FP_FROM_INT() which is
used to convert an integer to a raw normalized floating-point value.
It does this basically in three steps:
1. Compute the exponent from the number of leading zero bits.
2. Downshift large fractions to put the MSB in the right position
for normalized fractions.
3. Upshift small fractions to put the MSB in the right position.
There is an boundary error in step 2, causing a fraction with its
MSB exactly one bit above the normalized MSB position to not be
downshifted. This results in a non-normalized raw float, which when
packed becomes a massively inaccurate representation for that input.
The impact of this depends on a number of arch-specific factors,
but it is known to have broken emulation of FXTOD instructions
on UltraSPARC III, which was originally reported as GCC bug 44631
<http://gcc.gnu.org/bugzilla/show_bug.cgi?id=44631>.
Any arch which uses math-emu to emulate conversions from integers to
same-size floats may be affected.
The fix is simple: the exponent comparison used to determine if the
fraction should be downshifted must be "<=" not "<".
I'm sending a kernel module to test this as a reply to this message.
There are also SPARC user-space test cases in the GCC bug entry.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/r600: fix possible NULL pointer derefernce
drm/radeon/kms: add quirk for ASUS HD 3600 board
include/linux/vgaarb.h: add missing part of include guard
drm/nouveau: Fix crashes during fbcon init on single head cards.
drm/nouveau: fix pcirom vbios shadow breakage from acpi rom patch
drm/radeon/kms: fix shared ddc harder
drm/i915: enable low power render writes on GEN3 hardware.
drm/i915: Define MI_ARB_STATE bits
vmwgfx: return -EFAULT if copy_to_user fails
fb: handle allocation failure in alloc_apertures()
drm: radeon: check kzalloc() result
drm/ttm: Fix build on architectures without AGP
drm/radeon/kms: fix gtt MC base alignment on rs4xx/rs690/rs740 asics
drm/radeon/kms: fix possible mis-detection of sideport on rs690/rs740
drm/radeon/kms: fix legacy tv-out pal mode
vgaarb.h was missing the #define of the #ifndef at the top for the guard
to prevent multiple #include's from causing re-define errors
Signed-off-by: Doug Goldstein <cardoe@gentoo.org>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits)
bridge: Partially disable netpoll support
tcp: fix crash in tcp_xmit_retransmit_queue
IPv6: fix CoA check in RH2 input handler (mip6_rthdr_input())
ibmveth: lost IRQ while closing/opening device leads to service loss
rt2x00: Fix lockdep warning in rt2x00lib_probe_dev()
vhost: avoid pr_err on condition guest can trigger
ipmr: Don't leak memory if fib lookup fails.
vhost-net: avoid flush under lock
net: fix problem in reading sock TX queue
net/core: neighbour update Oops
net: skb_tx_hash() fix relative to skb_orphan_try()
rfs: call sock_rps_record_flow() in tcp_splice_read()
xfrm: do not assume that template resolving always returns xfrms
hostap_pci: set dev->base_addr during probe
axnet_cs: use spin_lock_irqsave in ax_interrupt
dsa: Fix Kconfig dependencies.
act_nat: not all of the ICMP packets need an IP header payload
r8169: incorrect identifier for a 8168dp
Phonet: fix skb leak in pipe endpoint accept()
Bluetooth: Update sec_level/auth_type for already existing connections
If a single-threaded process does a file-descriptor operation, and some
other process accesses that same file descriptor via /proc, the current
rcu_dereference_check_fdtable() can give a false-positive RCU-lockdep
splat due to the reference count being increased by the /proc access after
the reference-count check in fget_light() but before the check in
rcu_dereference_check_fdtable().
This commit prevents this false positive by checking for a single-threaded
process. To avoid #include hell, this commit uses the wrapper for
thread_group_empty(current) defined by rcu_my_thread_group_empty()
provided in a separate commit.
Located-by: Miles Lane <miles.lane@gmail.com>
Located-by: Eric Dumazet <eric.dumazet@gmail.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
We define a number of symbols in the linker scipt like this:
__start_syscalls_metadata = .;
*(__syscalls_metadata)
But we do not know the alignment of "." when we assign
the __start_syscalls_metadata symbol.
gcc started to uses bigger alignment for structs (32 bytes),
so we saw situations where the linker due to alignment
constraints increased the value of "." after the symbol assignment.
This resulted in boot fails.
Fix this by forcing a 32 byte alignment of "." before the
assignment.
This patch introduces the forced alignment for
ftrace_events and syscalls_metadata.
It may be required in more places.
Reported-by: Zeev Tarantov <zeev.tarantov@gmail.com>
LKML-Reference: <20100710063459.GA14596@merkur.ravnborg.org>
If the kzalloc() fails we should return NULL. All the places that call
alloc_apertures() check for this already.
Acked-by: James Simmons <jsimmons@infradead.org>
Acked-by: Marcin Slusarz <marcin.slusarz@gmail.com>
The current shrinker implementation requires the registered callback
to have global state to work from. This makes it difficult to shrink
caches that are not global (e.g. per-filesystem caches). Pass the shrinker
structure to the callback so that users can embed the shrinker structure
in the context the shrinker needs to operate on and get back to it in the
callback via container_of().
Signed-off-by: Dave Chinner <dchinner@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: fall back to original BIOS BAR addresses
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2: Silence gcc warning in ocfs2_write_zero_page().
jbd2/ocfs2: Fix block checksumming when a buffer is used in several transactions
ocfs2/dlm: Remove BUG_ON from migration in the rare case of a down node
ocfs2: Don't duplicate pages past i_size during CoW.
ocfs2: tighten up strlen() checking
ocfs2: Make xattr reflink work with new local alloc reservation.
ocfs2: make xattr extension work with new local alloc reservation.
ocfs2: Remove the redundant cpu_to_le64.
ocfs2/dlm: don't access beyond bitmap size
ocfs2: No need to zero pages past i_size.
ocfs2: Zero the tail cluster when extending past i_size.
ocfs2: When zero extending, do it by page.
ocfs2: Limit default local alloc size within bitmap range.
ocfs2: Move orphan scan work to ocfs2_wq.
fs/ocfs2/dlm: Add missing spin_unlock
If we fail to assign resources to a PCI BAR, this patch makes us try the
original address from BIOS rather than leaving it disabled.
Linux tries to make sure all PCI device BARs are inside the upstream
PCI host bridge or P2P bridge apertures, reassigning BARs if necessary.
Windows does similar reassignment.
Before this patch, if we could not move a BAR into an aperture, we left
the resource unassigned, i.e., at address zero. Windows leaves such BARs
at the original BIOS addresses, and this patch makes Linux do the same.
This is a bit ugly because we disable the resource long before we try to
reassign it, so we have to keep track of the BIOS BAR address somewhere.
For lack of a better place, I put it in the struct pci_dev.
I think it would be cleaner to attempt the assignment immediately when the
claim fails, so we could easily remember the original address. But we
currently claim motherboard resources in the middle, after attempting to
claim PCI resources and before assigning new PCI resources, and changing
that is a fairly big job.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16263
Reported-by: Andrew <nitr0@seti.kr.ua>
Tested-by: Andrew <nitr0@seti.kr.ua>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
tracing: Add alignment to syscall metadata declarations
perf: Sync callchains with period based hits
perf: Resurrect flat callchains
perf: Version String fix, for fallback if not from git
perf: Version String fix, using kernel version
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: w90p910_ts - fix call to setup_timer()
Input: synaptics - fix wrong dimensions check
Input: i8042 - mark stubs in i8042.h "static inline"
OCFS2 uses t_commit trigger to compute and store checksum of the just
committed blocks. When a buffer has b_frozen_data, checksum is computed
for it instead of b_data but this can result in an old checksum being
written to the filesystem in the following scenario:
1) transaction1 is opened
2) handle1 is opened
3) journal_access(handle1, bh)
- This sets jh->b_transaction to transaction1
4) modify(bh)
5) journal_dirty(handle1, bh)
6) handle1 is closed
7) start committing transaction1, opening transaction2
8) handle2 is opened
9) journal_access(handle2, bh)
- This copies off b_frozen_data to make it safe for transaction1 to commit.
jh->b_next_transaction is set to transaction2.
10) jbd2_journal_write_metadata() checksums b_frozen_data
11) the journal correctly writes b_frozen_data to the disk journal
12) handle2 is closed
- There was no dirty call for the bh on handle2, so it is never queued for
any more journal operation
13) Checkpointing finally happens, and it just spools the bh via normal buffer
writeback. This will write b_data, which was never triggered on and thus
contains a wrong (old) checksum.
This patch fixes the problem by calling the trigger at the moment data is
frozen for journal commit - i.e., either when b_frozen_data is created by
do_get_write_access or just before we write a buffer to the log if
b_frozen_data does not exist. We also rename the trigger to t_frozen as
that better describes when it is called.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
Fix problem in reading the tx_queue recorded in a socket. In
dev_pick_tx, the TX queue is read by doing a check with
sk_tx_queue_recorded on the socket, followed by a sk_tx_queue_get.
The problem is that there is not mutual exclusion across these
calls in the socket so it it is possible that the queue in the
sock can be invalidated after sk_tx_queue_recorded is called so
that sk_tx_queue get returns -1, which sets 65535 in queue_index
and thus dev_pick_tx returns 65536 which is a bogus queue and
can cause crash in dev_queue_xmit.
We fix this by only calling sk_tx_queue_get which does the proper
checks. The interface is that sk_tx_queue_get returns the TX queue
if the sock argument is non-NULL and TX queue is recorded, else it
returns -1. sk_tx_queue_recorded is no longer used so it can be
completely removed.
Signed-off-by: Tom Herbert <therbert@google.com>
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB: uvc: Fix multiple symbols definitions with UVC gadget and host drivers
V4L/DVB: v4l: mem2mem_testdev: fix g_fmt NULL pointer dereference
V4L/DVB: uvcvideo: Power line frequency control doesn't support GET_MIN/MAX/RES
V4L/DVB: ivtv: Add delay to ensure the decoder always restarts with a blank screen
V4L/DVB: Documentation: Add the Philips FQ1236 MK5 to video4linux/CARDLIST.tuner
V4L/DVB: tveeprom: Add an entry for tuner code 168: a TCL M30WTP-4N-E tuner
V4L/DVB: tuner: Add a definition for the Philips FQ1236 MK5 NTSC tuner
V4L/DVB: OMAP_VOUT: fix: Module params were not working through bootargs
V4L/DVB: OMAP_VOUT: fix: Replaced dma-sg with dma-contig
V4L/DVB: OMAP_VOUT:Build FIX: Rebased against latest DSS2 changes
For some reason if we declare a static variable and then assign it
later, and the assignment contains a __attribute__((__aligned__(#))),
some versions of gcc will ignore it.
This caused the syscall meta data to not be compact in its section
and caused a kernel oops when the section was being read.
The fix for these versions of gcc seems to be to add the aligned
attribute to the declaration as well.
This fixes the BZ regression:
https://bugzilla.kernel.org/show_bug.cgi?id=16353
Tested-by: Zeev Tarantov <zeev.tarantov@gmail.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <AANLkTinkKVmB0fpVeqUkMeqe3ZYeXJdI8xDuzJEOjYwh@mail.gmail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
writeback: simplify the write back thread queue
writeback: split writeback_inodes_wb
writeback: remove writeback_inodes_wbc
fs-writeback: fix kernel-doc warnings
splice: check f_mode for seekable file
splice: direct_splice_actor() should not use pos in sd
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (35 commits)
NET: SB1250: Initialize .owner
vxge: show startup message with KERN_INFO
ll_temac: Fix missing iounmaps
bridge: Clear IPCB before possible entry into IP stack
bridge br_multicast: BUG: unable to handle kernel NULL pointer dereference
net: Fix definition of netif_vdbg() when VERBOSE_DEBUG is defined
net/ne: fix memory leak in ne_drv_probe()
xfrm: fix xfrm by MARK logic
virtio_net: fix oom handling on tx
virtio_net: do not reschedule rx refill forever
s2io: resolve statistics issues
linux/net.h: fix kernel-doc warnings
net: decreasing real_num_tx_queues needs to flush qdisc
sched: qdisc_reset_all_tx is calling qdisc_reset without qdisc_lock
qlge: fix a eeh handler to not add a pending timer
qlge: Replacing add_timer() to mod_timer()
usbnet: Set parent device early for netdev_printk()
net: Revert "rndis_host: Poll status channel before control channel"
netfilter: ip6t_REJECT: fix a dst leak in ipv6 REJECT
drivers: bluetooth: bluecard_cs.c: Fixed include error, changed to linux/io.h
drm: correctly update connector DPMS status in drm_fb_helper
drm/radeon/kms: fix shared ddc handling
drm/ttm: Allocate the page pool manager in the heap.
Repeated ttm_page_alloc_init/fini fails noisily because the pool
manager kobj isn't zeroed out between uses (we could do just that but
statically allocated kobjects are generally considered a bad thing).
Move it to kzalloc'ed memory.
Note that this patch drops the refcounting behavior of the pool
allocator init/fini functions: it would have led to a race condition
in its current form, and anyway it was never exploited.
This fixes a regression with reloading kms modules at runtime, since
page allocator was introduced.
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
This patch introduces 3 VFS accessors: 'sb_mark_dirty()',
'sb_mark_clean()', and 'sb_is_dirty()'. They simply
set 'sb->s_dirt' or test 'sb->s_dirt'. The plan is to make
every FS use these accessors later instead of manipulating
the 'sb->s_dirt' flag directly.
Ultimately, this change is a preparation for the periodic
superblock synchronization optimization which is about
preventing the "sync_supers" kernel thread from waking up
even if there is nothing to synchronize.
This patch does not do any functional change, just adds
accessor functions.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rbtree: Undo augmented trees performance damage and regression
x86, Calgary: Limit the max PHB number to 256
First remove items from work_list as soon as we start working on them. This
means we don't have to track any pending or visited state and can get
rid of all the RCU magic freeing the work items - we can simply free
them once the operation has finished. Second use a real completion for
tracking synchronous requests - if the caller sets the completion pointer
we complete it, otherwise use it as a boolean indicator that we can free
the work item directly. Third unify struct wb_writeback_args and struct
bdi_work into a single data structure, wb_writeback_work. Previous we
set all parameters into a struct wb_writeback_args, copied it into
struct bdi_work, copied it again on the stack to use it there. Instead
of just allocate one structure dynamically or on the stack and use it
all the way through the stack.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
The case where we have a superblock doesn't require a loop here as we scan
over all inodes in writeback_sb_inodes. Split it out into a separate helper
to make the code simpler. This also allows to get rid of the sb member in
struct writeback_control, which was rather out of place there.
Also update the comments in writeback_sb_inodes that explain the handling
of inodes from wrong superblocks.
This was just an odd wrapper around writeback_inodes_wb. Removing this
also allows to get rid of the bdi member of struct writeback_control
netif_vdbg() was originally defined as entirely equivalent to
netdev_vdbg(), but I assume that it was intended to take the same
parameters as netif_dbg() etc. (Currently it is only used by the
sfc driver, in which I worked on that assumption.)
In commit a4ed89c I changed the definition used when VERBOSE_DEBUG is
not defined, but I failed to notice that the definition used when
VERBOSE_DEBUG is defined was also not as I expected. Change that to
match netif_dbg() as well.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Reimplement augmented RB-trees without sprinkling extra branches
all over the RB-tree code (which lives in the scheduler hot path).
This approach is 'borrowed' from Fabio's BFQ implementation and
relies on traversing the rebalance path after the RB-tree-op to
correct the heap property for insertion/removal and make up for
the damage done by the tree rotations.
For insertion the rebalance path is trivially that from the new
node upwards to the root, for removal it is that from the deepest
node in the path from the to be removed node that will still
be around after the removal.
[ This patch also fixes a video driver regression reported by
Ali Gholami Rudi - the memtype->subtree_max_end was updated
incorrectly. ]
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Venkatesh Pallipadi <venki@google.com>
Tested-by: Ali Gholami Rudi <ali@rudi.ir>
Cc: Fabio Checconi <fabio@gandalf.sssup.it>
LKML-Reference: <1275414172.27810.27961.camel@twins>
We should initialize the module dynamic debug datastructures
only after determining that the module is not loaded yet. This
fixes a bug that introduced in 2.6.35-rc2, where when a trying
to load a module twice, we also load it's dynamic printing data
twice which causes all sorts of nasty issues. Also handle
the dynamic debug cleanup later on failure.
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef)
Fix kernel-doc warnings in linux/net.h:
Warning(include/linux/net.h:151): No description found for parameter 'wq'
Warning(include/linux/net.h:151): Excess struct/union/enum/typedef member 'fasync_list' description in 'socket'
Warning(include/linux/net.h:151): Excess struct/union/enum/typedef member 'wait' description in 'socket'
