path: root/include
2011-09-08regulator: fix kernel-doc warning in consumer.hRandy Dunlap
Fix kernel-doc warning about internal/private data by marking it as "private:" so that kernel-doc will ignore it. Warning(include/linux/regulator/consumer.h:128): No description found for parameter 'ret' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-08wireless: fix kernel-doc warning in net/cfg80211.hRandy Dunlap
Fix kernel-doc warning in net/cfg80211.h: Warning(include/net/cfg80211.h:1884): No description found for parameter 'registered' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-07Merge branch 'perf-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tipLinus Torvalds
* 'perf-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip: x86, perf: Check that current->mm is alive before getting user callchain perf_event: Fix broken calc_timer_values() perf events: Fix slow and broken cgroup context switch code
2011-09-06fs/9p: Use protocol-defined value for lock/getlock 'type' field.Jim Garlick
Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Add OS dependent open flags in 9p protocolAneesh Kumar K.V
Some of the flags are OS/arch dependent we add a 9p protocol value which maps to asm-generic/fcntl.h values in Linux Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-08-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (42 commits) netpoll: fix incorrect access to skb data in __netpoll_rx cassini: init before use in cas_interruptN. can: ti_hecc: Fix uninitialized spinlock in probe can: ti_hecc: Fix unintialized variable net: sh_eth: fix the compile error net/phy: fix DP83865 phy interrupt handler sendmmsg/sendmsg: fix unsafe user pointer access ibmveth: Fix leak when recycling skb and hypervisor returns error arp: fix rcu lockdep splat in arp_process() bridge: fix a possible use after free bridge: Pseudo-header required for the checksum of ICMPv6 mcast: Fix source address selection for multicast listener report MAINTAINERS: Update GIT trees for network development ath9k: Fix PS wrappers in ath9k_set_coverage_class carl9170: Fix mismatch in carl9170_op_set_key mutex lock-unlock wl12xx: add max_sched_scan_ssids value to the hw description wl12xx: Fix validation of pm_runtime_get_sync return value wl12xx: Remove obsolete testmode NVS push command bcma: add uevent to the bus, to autoload drivers ath9k_hw: Fix STA (AR9485) bringup issue due to incorrect MAC address ...
2011-08-29perf events: Fix slow and broken cgroup context switch codeStephane Eranian
The current cgroup context switch code was incorrect leading to bogus counts. Furthermore, as soon as there was an active cgroup event on a CPU, the context switch cost on that CPU would increase by a significant amount as demonstrated by a simple ping/pong example: $ ./pong Both processes pinned to CPU1, running for 10s 10684.51 ctxsw/s Now start a cgroup perf stat: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 100 $ ./pong Both processes pinned to CPU1, running for 10s 6674.61 ctxsw/s That's a 37% penalty. Note that pong is not even in the monitored cgroup. The results shown by perf stat are bogus: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 100 Performance counter stats for 'sleep 100': CPU1 <not counted> cycles test CPU1 16,984,189,138 cycles # 0.000 GHz The second 'cycles' event should report a count @ CPU clock (here 2.4GHz) as it is counting across all cgroups. The patch below fixes the bogus accounting and bypasses any cgroup switches in case the outgoing and incoming tasks are in the same cgroup. With this patch the same test now yields: $ ./pong Both processes pinned to CPU1, running for 10s 10775.30 ctxsw/s Start perf stat with cgroup: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 10 Run pong outside the cgroup: $ /pong Both processes pinned to CPU1, running for 10s 10687.80 ctxsw/s The penalty is now less than 2%. And the results for perf stat are correct: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 10 Performance counter stats for 'sleep 10': CPU1 <not counted> cycles test # 0.000 GHz CPU1 23,933,981,448 cycles # 0.000 GHz Now perf stat reports the correct counts for for the non cgroup event. If we run pong inside the cgroup, then we also get the correct counts: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 10 Performance counter stats for 'sleep 10': CPU1 22,297,726,205 cycles test # 0.000 GHz CPU1 23,933,981,448 cycles # 0.000 GHz 10.001457237 seconds time elapsed Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110825135803.GA4697@quad Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-26Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: omap-serial: Allow IXON and IXOFF to be disabled. TTY: serial, document ignoring of uart->ops->startup error TTY: pty, fix pty counting 8250: Fix race condition in serial8250_backup_timeout(). serial/8250_pci: delete duplicate data definition 8250_pci: add support for Rosewill RC-305 4x serial port card tty: Add "spi:" prefix for spi modalias atmel_serial: fix atmel_default_console_device serial: 8250_pnp: add Intermec CV60 touchscreen device drivers/serial/ucc_uart.c: Fix compiler warning pch_uart: Set PCIe bus number using probe parameter serial: samsung: Fix build error
2011-08-26Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: drivers:misc: ti-st: fix unexpected UART close drivers:misc: ti-st: free skb on firmware download drivers:misc: ti-st: wait for completion at fail drivers:misc: ti-st: reinit completion before send drivers:misc: ti-st: fail-safe on wrong pkt type drivers:misc: ti-st: reinit completion on ver read drivers:misc:ti-st: platform hooks for chip states drivers:misc: ti-st: avoid a misleading dbg msg base/devres.c: quiet sparse noise about context imbalance pti: add missing CONFIG_PCI dependency drivers/base/devtmpfs.c: correct annotation of `setup_done' driver core: fix kernel-doc warning in platform.c firmware: fix google/gsmi.c build warning
2011-08-26Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-08-25backlight: add a callback 'notify_after' for backlight controlDilan Lee
We need a callback to do some things after pwm_enable, pwm_disable and pwm_config. Signed-off-by: Dilan Lee <dilee@nvidia.com> Reviewed-by: Robert Morell <rmorell@nvidia.com> Reviewed-by: Arun Murthy <arun.murthy@stericsson.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25rapidio: fix use of non-compatible registersAlexandre Bounine
Replace/remove use of RIO v.1.2 registers/bits that are not forward-compatible with newer versions of RapidIO specification. RapidIO specification v.1.3 removed Write Port CSR, Doorbell CSR, Mailbox CSR and Mailbox and Doorbell bits of the PEF CAR. Use of removed (since RIO v.1.3) register bits affects users of currently available 1.3 and 2.x compliant devices who may use not so recent kernel versions. Removing checks for unsupported bits makes corresponding routines compatible with all versions of RapidIO specification. Therefore, backporting makes stable kernel versions compliant with RIO v.1.3 and later as well. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Chul Kim <chul.kim@idt.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25MAINTAINERS: Evgeniy has movedEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25lockdep: Add helper function for dir vs file i_mutex annotationJosh Boyer
Purely in-memory filesystems do not use the inode hash as the dcache tells us if an entry already exists. As a result, they do not call unlock_new_inode, and thus directory inodes do not get put into a different lockdep class for i_sem. We need the different lockdep classes, because the locking order for i_mutex is different for directory inodes and regular inodes. Directory inodes can do "readdir()", which takes i_mutex *before* possibly taking mm->mmap_sem (due to a page fault while copying the directory entry to user space). In contrast, regular inodes can be mmap'ed, which takes mm->mmap_sem before accessing i_mutex. The two cases can never happen for the same inode, so no real deadlock can occur, but without the different lockdep classes, lockdep cannot understand that. As a result, if CONFIG_DEBUG_LOCK_ALLOC is set, this can lead to false positives from lockdep like below: find/645 is trying to acquire lock: (&mm->mmap_sem){++++++}, at: [<ffffffff81109514>] might_fault+0x5c/0xac but task is already holding lock: (&sb->s_type->i_mutex_key#15){+.+.+.}, at: [<ffffffff81149f34>] vfs_readdir+0x5b/0xb4 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#15){+.+.+.}: [<ffffffff8108ac26>] lock_acquire+0xbf/0x103 [<ffffffff814db822>] __mutex_lock_common+0x4c/0x361 [<ffffffff814dbc46>] mutex_lock_nested+0x40/0x45 [<ffffffff811daa87>] hugetlbfs_file_mmap+0x82/0x110 [<ffffffff81111557>] mmap_region+0x258/0x432 [<ffffffff811119dd>] do_mmap_pgoff+0x2ac/0x306 [<ffffffff81111b4f>] sys_mmap_pgoff+0x118/0x16a [<ffffffff8100c858>] sys_mmap+0x22/0x24 [<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b -> #0 (&mm->mmap_sem){++++++}: [<ffffffff8108a4bc>] __lock_acquire+0xa1a/0xcf7 [<ffffffff8108ac26>] lock_acquire+0xbf/0x103 [<ffffffff81109541>] might_fault+0x89/0xac [<ffffffff81149cff>] filldir+0x6f/0xc7 [<ffffffff811586ea>] dcache_readdir+0x67/0x205 [<ffffffff81149f54>] vfs_readdir+0x7b/0xb4 [<ffffffff8114a073>] sys_getdents+0x7e/0xd1 [<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b This patch moves the directory vs file lockdep annotation into a helper function that can be called by in-memory filesystems and has hugetlbfs call it. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25Merge branch 'urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback * 'urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback: squeeze max-pause area and drop pass-good area
2011-08-25Merge branch '3.1-rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * '3.1-rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (21 commits) target: Convert acl_node_lock to be IRQ-disabling target: Make locking in transport_deregister_session() IRQ safe tcm_fc: init/exit functions should not be protected by "#ifdef MODULE" target: Print subpage too for unhandled MODE SENSE pages iscsi-target: Fix iscsit_allocate_se_cmd_for_tmr failure path bugs iscsi-target: Implement iSCSI target IPv6 address printing. target: Fix task SGL chaining breakage with transport_allocate_data_tasks target: Fix task count > 1 handling breakage and use max_sector page alignment target: Add missing DATA_SG_IO transport_cmd_get_valid_sectors check target: Fix SYNCHRONIZE_CACHE zero LBA + range breakage target: Remove duplicate task completions in transport_emulate_control_cdb target: Fix WRITE_SAME usage with transport_get_size target: Add WRITE_SAME (10) parsing and refactor passthrough checks target: Fix write payload exception handling with ->new_cmd_map iscsi-target: forever loop bug in iscsit_attach_ooo_cmdsn() iscsi-target: remove duplicate return target: Convert target_core_rd.c to use use BUG_ON iscsi-target: Fix leak on failure in iscsi_copy_param_list() target: Use ERR_CAST inlined function target: Make standard INQUIRY return 'not connected' for tpg_virt_lun0 ...
2011-08-25Add a personality to report 2.6.x version numbersAndi Kleen
I ran into a couple of programs which broke with the new Linux 3.0 version. Some of those were binary only. I tried to use LD_PRELOAD to work around it, but it was quite difficult and in one case impossible because of a mix of 32bit and 64bit executables. For example, all kind of management software from HP doesnt work, unless we pretend to run a 2.6 kernel. $ uname -a Linux svivoipvnx001 3.0.0-08107-g97cd98f #1062 SMP Fri Aug 12 18:11:45 CEST 2011 i686 i686 i386 GNU/Linux $ hpacucli ctrl all show Error: No controllers detected. $ rpm -qf /usr/sbin/hpacucli hpacucli-8.75-12.0 Another notable case is that Python now reports "linux3" from sys.platform(); which in turn can break things that were checking sys.platform() == "linux2": https://bugzilla.mozilla.org/show_bug.cgi?id=664564 It seems pretty clear to me though it's a bug in the apps that are using '==' instead of .startswith(), but this allows us to unbreak broken programs. This patch adds a UNAME26 personality that makes the kernel report a 2.6.40+x version number instead. The x is the x in 3.x. I know this is somewhat ugly, but I didn't find a better workaround, and compatibility to existing programs is important. Some programs also read /proc/sys/kernel/osrelease. This can be worked around in user space with mount --bind (and a mount namespace) To use: wget ftp://ftp.kernel.org/pub/linux/kernel/people/ak/uname26/uname26.c gcc -o uname26 uname26.c ./uname26 program Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: check size of FUSE_NOTIFY_INVAL_ENTRY message fuse: mark pages accessed when written to fuse: delete dead .write_begin and .write_end aops fuse: fix flock fuse: fix non-ANSI void function notation
2011-08-23TTY: pty, fix pty countingJiri Slaby
tty_operations->remove is normally called like: queue_release_one_tty ->tty_shutdown ->tty_driver_remove_tty ->tty_operations->remove However tty_shutdown() is called from queue_release_one_tty() only if tty_operations->shutdown is NULL. But for pty, it is not. pty_unix98_shutdown() is used there as ->shutdown. So tty_operations->remove of pty (i.e. pty_unix98_remove()) is never called. This results in invalid pty_count. I.e. what can be seen in /proc/sys/kernel/pty/nr. I see this was already reported at: https://lkml.org/lkml/2009/11/5/370 But it was not fixed since then. This patch is kind of a hackish way. The problem lies in ->install. We allocate there another tty (so-called tty->link). So ->install is called once, but ->remove twice, for both tty and tty->link. The fix here is to count both tty and tty->link and divide the count by 2 for user. And to have ->remove called, let's make tty_driver_remove_tty() global and call that from pty_unix98_shutdown() (tty_operations->shutdown). While at it, let's document that when ->shutdown is defined, tty_shutdown() is not called. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc:ti-st: platform hooks for chip statesPavan Savoy
Certain platform specific or Host-WiLink Interface specific actions would be required to be taken when the chip is being enabled and after the chip is disabled such as configuration of the mux modes for the GPIO of host connected to the nshutdown of the chip or relinquishing UART after the chip is disabled. Similar actions can also be taken when the chip is in deep sleep or when the chip is awake. Performance enhancements such as configuring the host to run faster when chip is awake and slower when chip is asleep can also be made here. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22target: Make standard INQUIRY return 'not connected' for tpg_virt_lun0Nicholas Bellinger
This patch changes target_emulate_inquiry_std() to set the 'not connected' (0x35) bit in standard INQUIRY response data when we are processing a request to a virtual LUN=0 mapping from struct se_device *g_lun0_dev that have been setup for us in transport_lookup_cmd_lun(). This addresses an issue where qla2xxx FC clients need to be able to create demo-mode I_T FC Nexuses by default, but should not be exposing the default set of TPG LUNs to all FC clients. This includes adding an new optional target_core_fabric_ops->tpg_check_demo_mode_login_only() caller to allow demo_mode nexuses to skip the old default of bulding a demo-mode MappedLUNs list via core_tpg_add_node_to_devs(). (roland: Add missing tpg_check_demo_mode_login_only check in core_dev_add_lun) Reported-by: Roland Dreier <roland@purestorage.com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Nicholas Bellinger <nab@risingtidesystems.com>
2011-08-22mac80211: fix suspend/resume races with unregister hwStanislaw Gruszka
Do not call ->suspend, ->resume methods after we unregister wiphy. Also delete sta_clanup timer after we finish wiphy unregister to avoid this: WARNING: at lib/debugobjects.c:262 debug_print_object+0x85/0xa0() Hardware name: 6369CTO ODEBUG: free active (active state 0) object type: timer_list hint: sta_info_cleanup+0x0/0x180 [mac80211] Modules linked in: aes_i586 aes_generic fuse bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq mperf ext2 dm_mod uinput thinkpad_acpi hwmon sg arc4 rt2800usb rt2800lib crc_ccitt rt2x00usb rt2x00lib mac80211 cfg80211 i2c_i801 iTCO_wdt iTCO_vendor_support e1000e ext4 mbcache jbd2 sd_mod crc_t10dif sr_mod cdrom yenta_socket ahci libahci pata_acpi ata_generic ata_piix i915 drm_kms_helper drm i2c_algo_bit video [last unloaded: microcode] Pid: 5663, comm: pm-hibernate Not tainted 3.1.0-rc1-wl+ #19 Call Trace: [<c0454cfd>] warn_slowpath_common+0x6d/0xa0 [<c05e05e5>] ? debug_print_object+0x85/0xa0 [<c05e05e5>] ? debug_print_object+0x85/0xa0 [<c0454dae>] warn_slowpath_fmt+0x2e/0x30 [<c05e05e5>] debug_print_object+0x85/0xa0 [<f8a808e0>] ? sta_info_alloc+0x1a0/0x1a0 [mac80211] [<c05e0bd2>] debug_check_no_obj_freed+0xe2/0x180 [<c051175b>] kfree+0x8b/0x150 [<f8a126ae>] cfg80211_dev_free+0x7e/0x90 [cfg80211] [<f8a13afd>] wiphy_dev_release+0xd/0x10 [cfg80211] [<c068d959>] device_release+0x19/0x80 [<c05d06ba>] kobject_release+0x7a/0x1c0 [<c07646a8>] ? rtnl_unlock+0x8/0x10 [<f8a13adb>] ? wiphy_resume+0x6b/0x80 [cfg80211] [<c05d0640>] ? kobject_del+0x30/0x30 [<c05d1a6d>] kref_put+0x2d/0x60 [<c05d056d>] kobject_put+0x1d/0x50 [<c08015f4>] ? mutex_lock+0x14/0x40 [<c068d60f>] put_device+0xf/0x20 [<c069716a>] dpm_resume+0xca/0x160 [<c04912bd>] hibernation_snapshot+0xcd/0x260 [<c04903df>] ? freeze_processes+0x3f/0x90 [<c049151b>] hibernate+0xcb/0x1e0 [<c048fdc0>] ? pm_async_store+0x40/0x40 [<c048fe60>] state_store+0xa0/0xb0 [<c048fdc0>] ? pm_async_store+0x40/0x40 [<c05d0200>] kobj_attr_store+0x20/0x30 [<c0575ea4>] sysfs_write_file+0x94/0xf0 [<c051e26a>] vfs_write+0x9a/0x160 [<c0575e10>] ? sysfs_open_file+0x200/0x200 [<c051e3fd>] sys_write+0x3d/0x70 [<c080959f>] sysenter_do_call+0x12/0x28 Cc: stable@kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-19Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: (23 commits) Revert "cfq: Remove special treatment for metadata rqs." block: fix flush machinery for stacking drivers with differring flush flags block: improve rq_affinity placement blktrace: add FLUSH/FUA support Move some REQ flags to the common bio/request area allow blk_flush_policy to return REQ_FSEQ_DATA independent of *FLUSH xen/blkback: Make description more obvious. cfq-iosched: Add documentation about idling block: Make rq_affinity = 1 work as expected block: swim3: fix unterminated of_device_id table block/genhd.c: remove useless cast in diskstats_show() drivers/cdrom/cdrom.c: relax check on dvd manufacturer value drivers/block/drbd/drbd_nl.c: use bitmap_parse instead of __bitmap_parse bsg-lib: add module.h include cfq-iosched: Reduce linked group count upon group destruction blk-throttle: correctly determine sync bio loop: fix deadlock when sysfs and LOOP_CLR_FD race against each other loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop devices loop: add management interface for on-demand device allocation loop: replace linked list of allocated devices with an idr index ...
2011-08-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: OF: Don't crash when bridge parent is NULL. PCI: export pcie_bus_configure_settings symbol PCI: code and comments cleanup PCI: make cardbus-bridge resources optional PCI: make SRIOV resources optional PCI : ability to relocate assigned pci-resources PCI: honor child buses add_size in hot plug configuration PCI: Set PCI-E Max Payload Size on fabric
2011-08-19squeeze max-pause area and drop pass-good areaWu Fengguang
Revert the pass-good area introduced in ffd1f609ab10 ("writeback: introduce max-pause and pass-good dirty limits") and make the max-pause area smaller and safe. This fixes ~30% performance regression in the ext3 data=writeback fio_mmap_randwrite_64k/fio_mmap_randrw_64k test cases, where there are 12 JBOD disks, on each disk runs 8 concurrent tasks doing reads+writes. Using deadline scheduler also has a regression, but not that big as CFQ, so this suggests we have some write starvation. The test logs show that - the disks are sometimes under utilized - global dirty pages sometimes rush high to the pass-good area for several hundred seconds, while in the mean time some bdi dirty pages drop to very low value (bdi_dirty << bdi_thresh). Then suddenly the global dirty pages dropped under global dirty threshold and bdi_dirty rush very high (for example, 2 times higher than bdi_thresh). During which time balance_dirty_pages() is not called at all. So the problems are 1) The random writes progress so slow that they break the assumption of the max-pause logic that "8 pages per 200ms is typically more than enough to curb heavy dirtiers". 2) The max-pause logic ignored task_bdi_thresh and thus opens the possibility for some bdi's to over dirty pages, leading to (bdi_dirty >> bdi_thresh) and then (bdi_thresh >> bdi_dirty) for others. 3) The higher max-pause/pass-good thresholds somehow leads to the bad swing of dirty pages. The fix is to allow the task to slightly dirty over task_bdi_thresh, but no way to exceed bdi_dirty and/or global dirty_thresh. Tests show that it fixed the JBOD regression completely (both behavior and performance), while still being able to cut down large pause times in balance_dirty_pages() for single-disk cases. Reported-by: Li Shaohua <shaohua.li@intel.com> Tested-by: Li Shaohua <shaohua.li@intel.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
2011-08-17Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Domains: Fix build for CONFIG_PM_RUNTIME unset
2011-08-17mm: fix __page_to_pfn for a const struct page argumentIan Campbell
This allows the cast in lowmem_page_address (introduced as a warning fixup to 33dd4e0ec911 "mm: make some struct page's const") to be removed. Propagate const'ness to page_to_section() as well since it is required by __page_to_pfn. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-17mm: make HASHED_PAGE_VIRTUAL page_address' struct page argument const.Ian Campbell
Followup to 33dd4e0ec911 "mm: make some struct page's const" which missed the HASHED_PAGE_VIRTUAL case. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-17Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtc: Limit RTC PIE frequency rtc: Fix hrtimer deadlock rtc: Handle errors correctly in rtc_irq_set_state() Fixup trivial conflicts in drivers/rtc/interface.c due to slightly trivially versions of the same patch coming in two different ways.
2011-08-17Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Track the owner of irq descriptor irq: Always set IRQF_ONESHOT if no primary handler is specified genirq: Fix wrong bit operation
2011-08-15block: fix flush machinery for stacking drivers with differring flush flagsJeff Moyer
Commit ae1b1539622fb46e51b4d13b3f9e5f4c713f86ae, block: reimplement FLUSH/FUA to support merge, introduced a performance regression when running any sort of fsyncing workload using dm-multipath and certain storage (in our case, an HP EVA). The test I ran was fs_mark, and it dropped from ~800 files/sec on ext4 to ~100 files/sec. It turns out that dm-multipath always advertised flush+fua support, and passed commands on down the stack, where those flags used to get stripped off. The above commit changed that behavior: static inline struct request *__elv_next_request(struct request_queue *q) { struct request *rq; while (1) { - while (!list_empty(&q->queue_head)) { + if (!list_empty(&q->queue_head)) { rq = list_entry_rq(q->queue_head.next); - if (!(rq->cmd_flags & (REQ_FLUSH | REQ_FUA)) || - (rq->cmd_flags & REQ_FLUSH_SEQ)) - return rq; - rq = blk_do_flush(q, rq); - if (rq) - return rq; + return rq; } Note that previously, a command would come in here, have REQ_FLUSH|REQ_FUA set, and then get handed off to blk_do_flush: struct request *blk_do_flush(struct request_queue *q, struct request *rq) { unsigned int fflags = q->flush_flags; /* may change, cache it */ bool has_flush = fflags & REQ_FLUSH, has_fua = fflags & REQ_FUA; bool do_preflush = has_flush && (rq->cmd_flags & REQ_FLUSH); bool do_postflush = has_flush && !has_fua && (rq->cmd_flags & REQ_FUA); unsigned skip = 0; ... if (blk_rq_sectors(rq) && !do_preflush && !do_postflush) { rq->cmd_flags &= ~REQ_FLUSH; if (!has_fua) rq->cmd_flags &= ~REQ_FUA; return rq; } So, the flush machinery was bypassed in such cases (q->flush_flags == 0 && rq->cmd_flags & (REQ_FLUSH|REQ_FUA)). Now, however, we don't get into the flush machinery at all. Instead, __elv_next_request just hands a request with flush and fua bits set to the scsi_request_fn, even if the underlying request_queue does not support flush or fua. The agreed upon approach is to fix the flush machinery to allow stacking. While this isn't used in practice (since there is only one request-based dm target, and that target will now reflect the flush flags of the underlying device), it does future-proof the solution, and make it function as designed. In order to make this work, I had to add a field to the struct request, inside the flush structure (to store the original req->end_io). Shaohua had suggested overloading the union with rb_node and completion_data, but the completion data is used by device mapper and can also be used by other drivers. So, I didn't see a way around the additional field. I tested this patch on an HP EVA with both ext4 and xfs, and it recovers the lost performance. Comments and other testers, as always, are appreciated. Cheers, Jeff Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: remove unused "ddr" parameter in struct mmc_ios mmc: dw_mmc: Fix DDR mode support. mmc: core: use defined R1_STATE_PRG macro for card status mmc: sdhci: use f_max instead of host->clock for timeouts mmc: sdhci: move timeout_clk calculation farther down mmc: sdhci: check host->clock before using it as a denominator mmc: Revert "mmc: sdhci: Fix SDHCI_QUIRK_TIMEOUT_USES_SDCLK" mmc: tmio: eliminate unused variable 'mmc' warning mmc: esdhc-imx: fix card interrupt loss on freescale eSDHC mmc: sdhci-s3c: Fix build for header change mmc: dw_mmc: Fix mask in IDMAC_SET_BUFFER1_SIZE macro mmc: cb710: fix possible pci_dev leak in cb710_pci_configure() mmc: core: Detect eMMC v4.5 ext_csd entries mmc: mmc_test: avoid stalled file in debugfs mmc: sdhci-s3c: add BROKEN_ADMA_ZEROLEN_DESC quirk mmc: sdhci: pxav3: controller needs 32 bit ADMA addressing mmc: sdhci: fix retuning timer wrongly deleted in sdhci_tasklet_finish
2011-08-14PM / Domains: Fix build for CONFIG_PM_RUNTIME unsetRafael J. Wysocki
Function genpd_queue_power_off_work() is not defined for CONFIG_PM_RUNTIME, so pm_genpd_poweroff_unused() causes a build error to happen in that case. Fix the problem by making pm_genpd_poweroff_unused() depend on CONFIG_PM_RUNTIME too. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-08-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Fix compile warning in wm8750.c ASoC: omap: Update e-mail address of Jarkko Nikula ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: Terminate WM8750 SPI device ID table ASoC: Add missing break in WM8994 probe ALSA: snd-usb-caiaq: Correct offset fields of outbound iso_frame_desc ALSA: azt3328 - adjust error handling code to include debugging code ALSA: hda - Add CONFIG_SND_HDA_POWER_SAVE to stac_vrefout_set() ALSA: usb-audio - Add quirk for BOSS Micro BR-80 ASoC: Fix typo in wm8750 spi_ids ASoC: Fix warning in Speyside WM8962 ASoC: Fix SPI driver binding for WM8987 ASoC: Fix binding of WM8750 on Jive ASoC: WM8903: Free IRQ on device removal ASoC: Tegra: wm8903 machine driver: Allow re-insertion of module ASoC: Tegra: tegra_pcm_deallocate_dma_buffer: Don't OOPS
2011-08-13mmc: remove unused "ddr" parameter in struct mmc_iosJaehoon Chung
"mmc: dw_mmc: Fix DDR mode support" removed the last user. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-08-12Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: dt: add empty of_get_property for non-dt
2011-08-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) e1000e: increase driver version number e1000e: alternate MAC address update e1000e: do not disable receiver on 82574/82583 e1000e: alternate MAC address does not work on device id 0x1060 PCnet: Fix section mismatch bnx2x: disable dcb on 578xx since not supported yet bnx2x: properly clean indirect addresses bnx2x: prevent race between undi_unload and load flows bnx2x: fix select_queue when FCoE is disabled bnx2x: init FCOE FP only once ipv4: some rt_iif -> rt_route_iif conversions net/bridge/netfilter/ebtables.c: use available error handling code net/netlabel/netlabel_kapi.c: add missing cleanup code net/irda: sh_sir: tidyup compile warning net/irda: sh_sir: add missing header net/irda: sh_irda: add missing header slcan: ldisc generated skbs are received in softirq context scm: Capture the full credentials of the scm sender tcp: initialize variable ecn_ok in syncookies path drivers/net/wireless/wl1251: add missing kfree ...
2011-08-12ASoC: omap: Update e-mail address of Jarkko NikulaJarkko Nikula
My gmail account got disabled and I'm not going to reopen it. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-11move RLIMIT_NPROC check from set_user() to do_execve_common()Vasiliy Kulikov
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC check in set_user() to check for NPROC exceeding via setuid() and similar functions. Before the check there was a possibility to greatly exceed the allowed number of processes by an unprivileged user if the program relied on rlimit only. But the check created new security threat: many poorly written programs simply don't check setuid() return code and believe it cannot fail if executed with root privileges. So, the check is removed in this patch because of too often privilege escalations related to buggy programs. The NPROC can still be enforced in the common code flow of daemons spawning user processes. Most of daemons do fork()+setuid()+execve(). The check introduced in execve() (1) enforces the same limit as in setuid() and (2) doesn't create similar security issues. Neil Brown suggested to track what specific process has exceeded the limit by setting PF_NPROC_EXCEEDED process flag. With the change only this process would fail on execve(), and other processes' execve() behaviour is not changed. Solar Designer suggested to re-check whether NPROC limit is still exceeded at the moment of execve(). If the process was sleeping for days between set*uid() and execve(), and the NPROC counter step down under the limit, the defered execve() failure because NPROC limit was exceeded days ago would be unexpected. If the limit is not exceeded anymore, we clear the flag on successful calls to execve() and fork(). The flag is also cleared on successful calls to set_user() as the limit was exceeded for the previous user, not the current one. Similar check was introduced in -ow patches (without the process flag). v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user(). Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11blktrace: add FLUSH/FUA supportNamhyung Kim
Add FLUSH/FUA support to blktrace. As FLUSH precedes WRITE and/or FUA follows WRITE, use the same 'F' flag for both cases and distinguish them by their (relative) position. The end results look like (other flags might be shown also): - WRITE: W - WRITE_FLUSH: FW - WRITE_FUA: WF - WRITE_FLUSH_FUA: FWF Note that we reuse TC_BARRIER due to lack of bit space of act_mask so that the older versions of blktrace tools will report flush requests as barriers from now on. Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-11Move some REQ flags to the common bio/request areaMatthew Wilcox
REQ_SECURE, REQ_FLUSH and REQ_FUA may all be set on a bio as well as on a request, so relocate them to the shared part of the enum. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-09dt: add empty of_get_property for non-dtStephen Warren
The patch adds empty function of_get_property for non-dt build, so that drivers migrating to dt can save some '#ifdef CONFIG_OF'. This also fixes the current Tegra compile problem in linux-next. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: sound: pss - don't use the deprecated function check_region ALSA: timer - Add NULL-check for invalid slave timer ALSA: timer - Fix Oops at closing slave timer ASoC: Acknowledge WM8996 interrupts before acting on them ASoC: Rename WM8915 to WM8996 ALSA: Fix dependency of CONFIG_SND_TEA575X ALSA: asihpi - use kzalloc() ALSA: snd-usb-caiaq: Fix keymap for RigKontrol3 ALSA: snd-usb: Fix uninitialized variable usage ALSA: hda - Fix a complile warning in patch_via.c ALSA: hdspm - Fix uninitialized compile warnings ALSA: usb-audio - add quirk for Keith McMillen StringPort ALSA: snd-usb: operate on given mixer interface only ALSA: snd-usb: avoid dividing by zero on invalid input ALSA: snd-usb: Accept UAC2 FORMAT_TYPE descriptors with bLength > 6 sound: oss/pas2: Remove CLOCK_TICK_RATE dependency from PAS16 driver ALSA: hda - Use auto-parser for ASUS UX50, Eee PC P901, S101 and P1005 ALSA: hda - Fix digital-mic mono recording on ASUS Eee PC ASoC: sgtl5000: fix cache handling ASoC: Disable wm_hubs periodic DC servo update
2011-08-08mm: Fix fixup_user_fault() for MMU=nPeter Zijlstra
In commit 2efaca927f5c ("mm/futex: fix futex writes on archs with SW tracking of dirty & young") we forgot about MMU=n. This patch fixes that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/1311761831.24752.413.camel@twins Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08cred: use 'const' in get_current_{user,groups}Linus Torvalds
Avoid annoying warnings from these functions ("discards qualifiers") because they assign 'current_cred()' to a non-const pointer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08CRED: Restore const to current_cred()David Howells
Commit 3295514841c2 ("fix rcu annotations noise in cred.h") accidentally dropped the const of current->cred inside current_cred() by the insertion of a cast to deal with an RCU annotation loss warning from sparce. Use an appropriate RCU wrapper instead so as not to lose the const. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08fuse: fix flockMiklos Szeredi
Commit a9ff4f87 "fuse: support BSD locking semantics" overlooked a number of issues with supporing flock locks over existing POSIX locking infrastructure: - it's not backward compatible, passing flock(2) calls to userspace unconditionally (if userspace sets FUSE_POSIX_LOCKS) - it doesn't cater for the fact that flock locks are automatically unlocked on file release - it doesn't take into account the fact that flock exclusive locks (write locks) don't need an fd opened for write. The last one invalidates the original premise of the patch that flock locks can be emulated with POSIX locks. This patch fixes the first two issues. The last one needs to be fixed in userspace if the filesystem assumed that a write lock will happen only on a file operned for write (as in the case of the current fuse library). Reported-by: Sebastian Pipping <webmaster@hartwork.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-08-07ipv4: route non-local sources for raw socketJulian Anastasov
The raw sockets can provide source address for routing but their privileges are not considered. We can provide non-local source address, make sure the FLOWI_FLAG_ANYSRC flag is set if socket has privileges for this, i.e. based on hdrincl (IP_HDRINCL) and transparent flags. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07net: Make userland include of netlink.h more sane.David S. Miller
Currently userland will barf when including linux/netlink.h unless it precisely includes sys/socket.h first. The issue is where the definition of "sa_family_t" comes from. We've been back and forth on how to fix this issue in the past, see: http://thread.gmane.org/gmane.linux.debian.devel.bugs.general/622621 http://thread.gmane.org/gmane.linux.network/143380 Ben Hutchings suggested we take a hint from how we handle the sockaddr_storage type. First we define a "__kernel_sa_family_t" to linux/socket.h that is always defined. Then if __KERNEL__ is defined, we also define "sa_family_t" as equal to "__kernel_sa_family_t". Then in places like linux/netlink.h we use __kernel_sa_family_t in user visible datastructures. Reported-by: Michel Machado <michel@digirati.com.br> Signed-off-by: David S. Miller <davem@davemloft.net>
