This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add mfd core driver for TPS6586x PMICs family.
The driver provides I/O access for the sub-device drivers and performs
regstration of the sub-devices based on the platform requirements.
In addition it implements GPIOlib interface for the chip GPIOs.
TODO:
- add interrupt support
- add platform data for PWM, backlight leds and charger
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com>
This adds all remaining definitions that are used by the core driver
to the .c file.
This is needed for the mc13783-adc driver to decide if a touch screen is
connected. If so some channels are not available as generic hwmon inputs.
Some STMPE devices support entering sleep mode automatically on a
specified timeout of inactivity on the I2C bus with the host system.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Rabin Vincent <rabin.vincent@stericsson.com>
Signed-off-by: Sundar R Iyer <sundar.iyer@stericsson.com>
Later revisions of the WM8994 add some more GPIO functions, define them
in the header file.
This patch adds a MFD driver for the JZ4740 ADC unit. The driver is used to
demultiplex IRQs and synchronize access to shared registers between the
battery, hwmon and (future) touchscreen driver.
Add support for the STMPE family of I/O Expanders from
STMicroelectronics. These devices include upto 24 gpios and a varying
selection of blocks, including PWM, keypad, and touchscreen controllers.
This patch adds the MFD core.
[l.fu@pengutronix.de: fix stmpe811 enable hook]
[l.fu@pengutronix.de: add touchscreen platform data]
Acked-by: Luotao Fu <l.fu@pengutronix.de>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Split max_io_len_target_boundary out of max_io_len so that the discard
support can make use of it without duplicating max_io_len code.
Avoiding max_io_len's split_io logic enables DM's discard support to
submit the entire discard request to a target. But discards must still
be split on target boundaries.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Allow discards to be passed through to linear mappings if at least one
underlying device supports it. Discards will be forwarded only to
devices that support them.
A target that supports discards should set num_discard_requests to
indicate how many times each discard request must be submitted to it.
Verify table's underlying devices support discards prior to setting the
associated DM device as capable of discards (via QUEUE_FLAG_DISCARD).
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Reviewed-by: Joe Thornber <thornber@redhat.com>
Add devname:mapper/control and MAPPER_CTRL_MINOR module alias
to support dm-mod module autoloading.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Peter Rajnoha <prajnoha@redhat.com>
'target_request_nr' is a more generic name that reflects the fact that
it will be used for both flush and discard support.
Determine whether a mapped device is bio-based or request-based when
loading its first (inactive) table and don't allow that to be changed
later.
This patch performs different device initialisation in each of the two
cases. (We don't think it's necessary to add code to support changing
between the two types.)
Allowed md->type transitions:
DM_TYPE_NONE to DM_TYPE_BIO_BASED
DM_TYPE_NONE to DM_TYPE_REQUEST_BASED
We now prevent table_load from replacing the inactive table with a
conflicting type of table even after an explicit table_clear.
Introduce 'type_lock' into the struct mapped_device to protect md->type
and to prepare for the next patch that will change the queue
initialization and allocate memory while md->type_lock is held.
Acked-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
drivers/md/dm-ioctl.c | 15 +++++++++++++++
drivers/md/dm.c | 37 ++++++++++++++++++++++++++++++-------
drivers/md/dm.h | 5 +++++
include/linux/dm-ioctl.h | 4 ++--
4 files changed, 52 insertions(+), 9 deletions(-)
nouveau starting using these APIs, the first on non-x86 hw, and this
include isn't required on anything with real amounts of vmalloc space.
this fixes a build problem on powerpc.
We don't actually need this include on any platform.
built on powerpc + x86, reported on m68k.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Some bit-rot needs to be cleaned out.
Signed-off-by: NeilBrown <neilb@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
isofs: Fix lseek() to position beyond 4 GB
vfs: remove unused MNT_STRICTATIME
vfs: show unreachable paths in getcwd and proc
vfs: only add " (deleted)" where necessary
vfs: add prepend_path() helper
vfs: __d_path: dont prepend the name of the root dentry
ia64: perfmon: add d_dname method
vfs: add helpers to get root and pwd
cachefiles: use path_get instead of lone dget
fs/sysv/super.c: add support for non-PDP11 v7 filesystems
V7: Adjust sanity checks for some volumes
Add v7 alias
v9fs: fixup for inode_setattr being removed
Manual merge to take Al's version of the fs/sysv/super.c file: it merged
cleanly, but Al had removed an unnecessary header include, so his side
was better.
I2C driver for PCA954x I2C multiplexer series.
Signed-off-by: Michael Lawnick <ml.lawnick@gmx.de>
Acked-by: Rodolfo Giometti <giometti@linux.it>
Add multiplexed bus core support. I2C multiplexer and switches
like pca954x get instantiated as new adapters per port.
Moving userspace-instantiated clients to separate lists wasn't nearly
enough to avoid deadlocks in multiplexed bus cases. We also want to
have a dedicated mutex to protect each list.
Cc: Michael Lawnick <ml.lawnick@gmx.de>
Uninline i2c adapter locking helper functions, move them to i2c-core,
and use them in i2c-core itself. The functions are still exported for
external users. This makes future updates to the locking model (which
will be needed for multiplexing support) possible and transparent.
Now that i2c-core offers the possibility to provide custom probing
function for I2C devices, let's make use of it.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
The probe method used by i2c_new_probed_device() may not be suitable
for all cases. Let the caller provide its own, optional probe
function.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits)
ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions}
ARM: 6324/1: cam60: move cam60_spi_devices to .init.data
ARM: 6322/1: imx/pca100: Fix name of spi platform data
ARM: 6321/1: fix syntax error in main Kconfig file
ARM: 6297/1: move U300 timer to dynamic clock lookup
ARM: 6296/1: clock U300 intcon and timer properly
ARM: 6295/1: fix U300 apb_pclk split
ARM: 6306/1: fix inverted MMC card detect in U300
ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID
ARM: 6294/1: etm: do a dummy read from OSSRR during initialization
ARM: 6292/1: coresight: add ETM management registers
ARM: 6288/1: ftrace: document mcount formats
ARM: 6287/1: ftrace: clean up mcount assembly indentation
ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR"
ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE
ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h>
ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3
ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig
ARM: S5PV210: Override FIMC driver name on Aquila board
ARM: S5PC100: enable FIMC on SMDKC100
Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to
different subsystem 'setname' calls, and trivial port types in
include/linux/serial_core.h
Simply replace the whole kfifo.c and kfifo.h files with the new generic
version and fix the kerneldoc API template file.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Cc: Greg KH <greg@kroah.com>
Add the new version of the kfifo API files kfifo.c and kfifo.h.
For consistency with other kfifo routines, return bool, not int.
Cc: Stefani Seibold <stefani@seibold.net>
Newly mkfs-ed filesystems from Seventh Edition have last modification time
set to zero, but are otherwise perfectly valid.
Also, tighten up other sanity checks to filter out most filesystems with
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
We are missing the oops end marker for the exception based WARN implementation
in lib/bug.c. This is useful for logfile analysis tools.
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
To keep panic_timeout accuracy when running under a hypervisor, the
current implementation only spins on long time (1 second) calls to mdelay.
That brings a good effect, but the problem is the keyboard LEDs don't
blink at all on that situation.
This patch changes to call to panic_blink_enter() between every mdelay and
keeps blinking in spite of long spin timer mode.
The time to call to mdelay is now 100ms. Even this change will keep
panic_timeout accuracy enough when running under a hypervisor.
Signed-off-by: TAMUKI Shoichi <tamuki@linet.gr.jp>
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Architectures implement dma_is_consistent() in different ways (some
misinterpret the definition of API in DMA-API.txt). So it hasn't been so
useful for drivers. We have only one user of the API in tree. Unlikely
out-of-tree drivers use the API.
Even if we fix dma_is_consistent() in some architectures, it doesn't look
useful at all. It was invented long ago for some old systems that can't
allocate coherent memory at all. It's better to export only APIs that are
definitely necessary for drivers.
Let's remove this API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <linux-arch@vger.kernel.org>
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we
can unify dma_get_cache_alignment implementations.
Note that some architectures implement dma_get_cache_alignment wrongly.
dma_get_cache_alignment() should return the minimum DMA alignment. So
fully-coherent architectures should return 1. This patch also fixes this
issue.
Now each architecture has the own dma_get_cache_alignment implementation.
define it as ARCH_KMALLOC_MINALIGN (it's used to make sure that malloc'ed
buffer is DMA-safe; the buffer doesn't share a cache with the others). So
we can unify dma_get_cache_alignment implementations.
This patch:
dma_get_cache_alignment() needs to know if an architecture defines
ARCH_KMALLOC_MINALIGN or not (needs to know if architecture has DMA
alignment restriction). However, slab.h define ARCH_KMALLOC_MINALIGN if
architectures doesn't define it.
Let's rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN.
ARCH_KMALLOC_MINALIGN is used only in the internals of slab/slob/slub
(except for crypto).
mem_cgroup_soft_limit_reclaim() has zone, nid and zid argument. but nid
and zid can be calculated from zone. So remove it.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp>
Currently mem_cgroup_shrink_node_zone() call shrink_zone() directly. thus
it doesn't need to initialize sc.nodemask because shrink_zone() doesn't
use it at all.
When the OOM killer scans task, it check a task is under memcg or
not when it's called via memcg's context.
But, as Oleg pointed out, a thread group leader may have NULL ->mm
and task_in_mem_cgroup() may do wrong decision. We have to use
find_lock_task_mm() in memcg as generic OOM-Killer does.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Add support for Semtech SX150-series I2C GPIO expanders. Compatible
models include:
8 bits: sx1508q
16 bits: sx1509q
Signed-off-by: Gregory Bean <gbean@codeaurora.org>
Cc: David Brownell <david-b@pacbell.net>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Trilok Soni <tsoni@codeaurora.org>
The gpios on the max730x chips have support for internal pullups while in
input mode.
This patch adds support for configuring these pullups via platform data.
A new member ("input_pullup_active") to the platform data struct is
introduced. A set bit in this variable activates the pullups while the
respective port is in input mode. This is a compatible enhancement since
unset bits lead to disables pullups which was the default in the original
driver.
_Note_: the 4 lowest bits in "input_pullup_active" are unused because the
first 4 ports of the controller are not used, too.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
There are some chips (like TI WL12xx series) that can be interfaced over
SDIO but don't support the SDIO specification, meaning that they are
missing CIA (Common I/O Area) with all it's registers. Current Linux SDIO
implementation relies on those registers to identify and configure the
card, so non-standard cards can not function and cause lots of warnings
from the core when it reads invalid data from non-existent registers.
After this patch, init_card() host callback can now set new quirk
MMC_QUIRK_NONSTD_SDIO, which means that SDIO core should not try to access
any standard SDIO registers and rely on init_card() to fill all SDIO
structures instead. As those cards are usually embedded chips, all the
required information can be obtained from machine board files by the host
driver when it's called through init_card() callback.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Cc: Adrian Hunter <adrian.hunter@nokia.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Bob Copeland <me@bobcopeland.com>
Cc: Kalle Valo <kvalo@adurom.com>
Cc: Madhusudhan Chikkature <madhu.cr@ti.com>
Cc: Kishore Kadiyala <kishore.kadiyala@ti.com>
Cc: <linux-mmc@vger.kernel.org>
If you don't use CONFIG_MMC_UNSAFE_RESUME, as soon as you attempt to
suspend, the card will be removed, therefore this patch doesn't change the
behavior of this option.
However the removal will be done by pm notifier, which runs while
userspace is still not frozen and thus can freely use del_gendisk, without
the risk of deadlock which would happen otherwise.
Card detect workqueue is now disabled while userspace is frozen, Therefore
if you do use CONFIG_MMC_UNSAFE_RESUME, and remove the card during
suspend, the removal will be detected as soon as userspace is unfrozen,
again at the moment it is safe to call del_gendisk.
Tested with and without CONFIG_MMC_UNSAFE_RESUME with suspend and hibernate.
[akpm@linux-foundation.org: clean up function prototype]
[akpm@linux-foundation.org: fix CONFIG_PM-n linkage, small cleanups]
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>
Cc: Chris Ball <cjb@laptop.org>
The eMMC spec 4.4 and 4.3 + additional feature chips has CSD structure
version 3 and version 3 have to check the CSD_STRUCTURE byte in the
EXT_CSD register.
Also fix EXT_CSD revision message.
[akpm@linux-foundation.org: fix comment, per Chris Ball]
The O_* bit numbers are defined in 20+ arch/*, and can silently overlap.
Add a compile time check to ensure the uniqueness as suggested by David
Miller.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Eric Paris <eparis@redhat.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Jamie Lokier <jamie@shareable.org>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Add <linux/types.h> to <linux/virtio_9p.h> so that types are explicitly
defined:
linux/virtio_9p.h:15: found __[us]{8,16,32,64} type without #include <linux/types.h>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Commit 9e4f5e29 ("FC Pass Thru support") exported a number of header files
in include/scsi to user space, but didn't change the uX types to the
userspace-compatible __uX types. Without that you'll get compile errors
when including them - E.G.:
include/scsi/scsi.h:145: error: expected specifier-qualifier-list before `u8'
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: James Smart <james.smart@emulex.com>
One straggler which was missed due to merge ordering issues.
Cc: Wu Fengguang <fengguang.wu@intel.com>
gcc allows this when arg is a function, but sparse complains:
drivers/char/ipmi/ipmi_watchdog.c:303:1: error: cannot dereference this type
drivers/char/ipmi/ipmi_watchdog.c:307:1: error: cannot dereference this type
drivers/char/ipmi/ipmi_watchdog.c:311:1: error: cannot dereference this type
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Also reorders the macros with the most common ones at the top.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
There may be cases (most obviously, sysfs-writable charp parameters) where
a module needs to prevent sysfs access to parameters.
Rather than express this in terms of a big lock, the functions are
expressed in terms of what they protect against. This is clearer, esp.
if the implementation changes to a module-level or even param-level lock.
Since this section can be read-only (they're in .rodata), they should
always have been const. Minor flow-through various functions.
