Signed-off-by: Miloslav Trmač <mitr@redhat.com>
A lot of crypto algorithms implement their own chaining function.
So add a generic one that can be used from all the algorithms that
need scatterlist chaining.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
This patch creates the backbone of the user-space interface for
the Crypto API, through a new socket family AF_ALG.
Each session corresponds to one or more connections obtained from
that socket. The number depends on the number of inputs/outputs
of that particular type of operation. For most types there will
be a s ingle connection/file descriptor that is used for both input
and output. AEAD is one of the few that require two inputs.
Each algorithm type will provide its own implementation that plugs
into af_alg. They're keyed using a string such as "skcipher" or
"hash".
IOW this patch only contains the boring bits that is required
to hold everything together.
Thakns to Miloslav Trmac for reviewing this and contributing
fixes and improvements.
Tested-by: Martin Willi <martin@strongswan.org>
This patch adds the socket family/level macros for the yet-to-be-born
AF_ALG family. The AF_ALG family provides the user-space interface
for the kernel crypto API.
fs/ext4/inode.c
fs/ext4/mballoc.c
include/trace/events/ext4.h
Unfortunately perf can't deal with anything other than direct structure
accesses in the TP_printk() section. It will drop dead when it sees
jbd2_dev_to_name() in the "print fmt" section of the tracepoint.
Addresses-Google-Bug: 3138508
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits)
DMAENGINE: move COH901318 to arch_initcall
dma: imx-dma: fix signedness bug
dma/timberdale: simplify conditional
ste_dma40: remove channel_type
ste_dma40: remove enum for endianess
ste_dma40: remove TIM_FOR_LINK option
ste_dma40: move mode_opt to separate config
ste_dma40: move channel mode to a separate field
ste_dma40: move priority to separate field
ste_dma40: add variable to indicate valid dma_cfg
async_tx: make async_tx channel switching opt-in
move async raid6 test to lib/Kconfig.debug
dmaengine: Add Freescale i.MX1/21/27 DMA driver
intel_mid_dma: change the slave interface
intel_mid_dma: fix the WARN_ONs
intel_mid_dma: Add sg list support to DMA driver
intel_mid_dma: Allow DMAC2 to share interrupt
intel_mid_dma: Allow IRQ sharing
intel_mid_dma: Add runtime PM support
DMAENGINE: define a dummy filter function for ste_dma40
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: (44 commits)
MN10300: Save frame pointer in thread_info struct rather than global var
MN10300: Change "Matsushita" to "Panasonic".
MN10300: Create a defconfig for the ASB2364 board
MN10300: Update the ASB2303 defconfig
MN10300: ASB2364: Add support for SMSC911X and SMC911X
MN10300: ASB2364: Handle the IRQ multiplexer in the FPGA
MN10300: Generic time support
MN10300: Specify an ELF HWCAP flag for MN10300 Atomic Operations Unit support
MN10300: Map userspace atomic op regs as a vmalloc page
MN10300: And Panasonic AM34 subarch and implement SMP
MN10300: Delete idle_timestamp from irq_cpustat_t
MN10300: Make various interrupt priority settings configurable
MN10300: Optimise do_csum()
MN10300: Implement atomic ops using atomic ops unit
MN10300: Make the FPU operate in non-lazy mode under SMP
MN10300: SMP TLB flushing
MN10300: Use the [ID]PTEL2 registers rather than [ID]PTEL for TLB control
MN10300: Make the use of PIDR to mark TLB entries controllable
MN10300: Rename __flush_tlb*() to local_flush_tlb*()
MN10300: AM34 erratum requires MMUCTR read and write on exception entry
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits)
perf python scripting: Add futex-contention script
perf python scripting: Fixup cut'n'paste error in sctop script
perf scripting: Shut up 'perf record' final status
perf record: Remove newline character from perror() argument
perf python scripting: Support fedora 11 (audit 1.7.17)
perf python scripting: Improve the syscalls-by-pid script
perf python scripting: print the syscall name on sctop
perf python scripting: Improve the syscalls-counts script
perf python scripting: Improve the failed-syscalls-by-pid script
kprobes: Remove redundant text_mutex lock in optimize
x86/oprofile: Fix uninitialized variable use in debug printk
tracing: Fix 'faild' -> 'failed' typo
perf probe: Fix format specified for Dwarf_Off parameter
perf trace: Fix detection of script extension
perf trace: Use $PERF_EXEC_PATH in canned report scripts
perf tools: Document event modifiers
perf tools: Remove direct slang.h include
perf_events: Fix for transaction recovery in group_sched_in()
perf_events: Revert: Fix transaction recovery in group_sched_in()
perf, x86: Use NUMA aware allocations for PEBS/BTS/DS allocations
* akpm-incoming-2: (139 commits)
epoll: make epoll_wait() use the hrtimer range feature
select: rename estimate_accuracy() to select_estimate_accuracy()
Remove duplicate includes from many files
ramoops: use the platform data structure instead of module params
kernel/resource.c: handle reinsertion of an already-inserted resource
kfifo: fix kfifo_alloc() to return a signed int value
w1: don't allow arbitrary users to remove w1 devices
alpha: remove dma64_addr_t usage
mips: remove dma64_addr_t usage
sparc: remove dma64_addr_t usage
fuse: use release_pages()
taskstats: use real microsecond granularity for CPU times
taskstats: split fill_pid function
taskstats: separate taskstats commands
delayacct: align to 8 byte boundary on 64-bit systems
delay-accounting: reimplement -c for getdelays.c to report information on a target command
namespaces Kconfig: move namespace menu location after the cgroup
namespaces Kconfig: remove the cgroup device whitelist experimental tag
namespaces Kconfig: remove pointless cgroup dependency
namespaces Kconfig: make namespace a submenu
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
percpu: Remove the multi-page alignment facility
x86-32: Allocate irq stacks seperate from percpu area
x86-32, mm: Remove duplicated #include
x86, printk: Get rid of <0> from stack output
x86, kexec: Make sure to stop all CPUs before exiting the kernel
x86/vsmp: Eliminate kconfig dependency warning
Commit 84061e0 fixed an accounting bug only to introduce the
possibility of a kernel OOPS if the journal has a non-zero j_errno
field indicating that the file system had detected a fs inconsistency.
After the journal replay, if the journal superblock indicates that the
file system has an error, this indication is transfered to the file
system and then ext4_commit_super() is called to write this to the
disk.
But since the percpu counters are now initialized after the journal
replay, the call to ext4_commit_super() will cause a kernel oops since
it needs to use the percpu counters the ext4 superblock structure.
The fix is to skip setting the ext4 free block and free inode fields
if the percpu counter has not been set.
Thanks to Ken Sumrall for reporting and analyzing the root causes of
this bug.
Addresses-Google-Bug: #3054080
This is analogous to Jan Kara's commit,
f446daaea9d4a420d16c606f755f3689dcb2d0ce
mm: implement writeback livelock avoidance using page tagging
but since we forked write_cache_pages, we need to reimplement
it there (and in ext4_da_writepages, since range_cyclic handling
was moved to there)
If you start a large buffered IO to a file, and then set
fsync after it, you'll find that fsync does not complete
until the other IO stops.
If you continue re-dirtying the file (say, putting dd
with conv=notrunc in a loop), when fsync finally completes
(after all IO is done), it reports via tracing that
it has written many more pages than the file contains;
in other words it has synced and re-synced pages in
the file multiple times.
This then leads to problems with our writeback_index
update, since it advances it by pages written, and
essentially sets writeback_index off the end of the
file...
With the following patch, we only sync as much as was
dirty at the time of the sync.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Adds an filesystem independent ioctl to allow implementation of file
system batched discard support. I takes fstrim_range structure as an
argument. fstrim_range is definec in the include/fs.h and its
definition is as follows.
struct fstrim_range {
start;
len;
minlen;
start - first Byte to trim
len - number of Bytes to trim from start
minlen - minimum extent length to trim, free extents shorter than this
number of Bytes will be ignored. This will be rounded up to fs
block size.
It is also possible to specify NULL as an argument. In this case the
arguments will set itself as follows:
start = 0;
len = ULLONG_MAX;
minlen = 0;
So it will trim the whole file system at one run.
After the FITRIM is done, the number of actually discarded Bytes is stored
in fstrim_range.len to give the user better insight on how much storage
space has been really released for wear-leveling.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Reviewed-by: Dmitry Monakhov <dmonakhov@openvz.org>
Many tracepoints were populating an ext4_allocation_context
to pass in, but this requires a slab allocation even when
tracepoints are off. In fact, 4 of 5 of these allocations
were only for tracing. In addition, we were only using a
small fraction of the 144 bytes of this structure for this
purpose.
We can do away with all these alloc/frees of the ac and
simply pass in the bits we care about, instead.
I tested this by turning on tracing and running through
xfstests on x86_64. I did not actually do anything with
the trace output, however.
Our QA reported an oops in the ext4_mb_release_group_pa tracing,
and Josef Bacik pointed out that it was because we may have a
non-null but uninitialized ac_inode in the allocation context.
I can reproduce it when running xfstests with ext4 tracepoints on,
on a CONFIG_SLAB_DEBUG kernel.
We call trace_ext4_mb_release_group_pa from 2 places,
ext4_mb_discard_group_preallocations and
ext4_mb_discard_lg_preallocations
In both cases we allocate an ac as a container just for tracing (!)
and never fill in the ac_inode. There's no reason to be assigning,
testing, or printing it as far as I can see, so just remove it from
the tracepoint.
Reviewed-by: Josef Bacik <josef@redhat.com>
This is done the same way as helper sb_issue_discard for
blkdev_issue_discard.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits)
ehea: Fixing statistics
bonding: Fix lockdep warning after bond_vlan_rx_register()
tunnels: Fix tunnels change rcu protection
caif-u5500: Build config for CAIF shared mem driver
caif-u5500: CAIF shared memory mailbox interface
caif-u5500: CAIF shared memory transport protocol
caif-u5500: Adding shared memory include
drivers/isdn: delete double assignment
drivers/net/typhoon.c: delete double assignment
drivers/net/sb1000.c: delete double assignment
qlcnic: define valid vlan id range
qlcnic: reduce rx ring size
qlcnic: fix mac learning
ehea: fix use after free
inetpeer: __rcu annotations
fib_rules: __rcu annotates ctarget
tunnels: add __rcu annotations
net: add __rcu annotations to protocol
ipv4: add __rcu annotations to routes.c
qlge: bugfix: Restoring the vlan setting.
ac->inode is set to null in function ext4_mb_release_group_pa(),
and then trace_ext4_mballoc_discard(ac) is called, the kernel
will panic.
BUG: unable to handle kernel NULL pointer dereference at 000000a4
IP: [<f87e1714>] ftrace_raw_event_ext4__mballoc+0x54/0xc0 [ext4]
*pdpt = 0000000000abd001 *pde = 0000000000000000
Oops: 0000 [#1] SMP
Pid: 550, comm: flush-8:16 Not tainted 2.6.36-rc1 #1 SE7320EP2/Altos G530
EIP: 0060:[<f87e1714>] EFLAGS: 00010206 CPU: 1
EIP is at ftrace_raw_event_ext4__mballoc+0x54/0xc0 [ext4]
EAX: f32ac840 EBX: f3f1cf88 ECX: f32ac840 EDX: 00000000
ESI: f32ac83c EDI: f880b9d8 EBP: 00000000 ESP: f4b77ae4
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process flush-8:16 (pid: 550, ti=f4b76000 task=f613e540 task.ti=f4b76000)
Call Trace:
[<f87f5ac1>] ? ext4_mb_release_group_pa+0x121/0x150 [ext4]
[<f87f8356>] ? ext4_mb_discard_group_preallocations+0x336/0x400 [ext4]
[<f87fb7f1>] ? ext4_mb_new_blocks+0x3d1/0x4f0 [ext4]
[<c05a6c5b>] ? __make_request+0x10b/0x440
[<f87f1fb4>] ? ext4_ext_map_blocks+0x1334/0x1980 [ext4]
[<c04ac78a>] ? rb_reserve_next_event+0xaa/0x3b0
[<f87d18d6>] ? ext4_map_blocks+0xd6/0x1d0 [ext4]
[<f87d2da7>] ? mpage_da_map_blocks+0xc7/0x8a0 [ext4]
[<c04c8a68>] ? find_get_pages_tag+0x38/0x110
[<c04d23a5>] ? __pagevec_release+0x15/0x20
[<f87d3ca5>] ? ext4_da_writepages+0x2b5/0x5d0 [ext4]
[<c04cfbe0>] ? __writepage+0x0/0x30
[<c04d0e34>] ? do_writepages+0x14/0x30
[<c0526600>] ? writeback_single_inode+0xa0/0x240
[<c0526971>] ? writeback_sb_inodes+0xc1/0x180
[<c0526ab8>] ? writeback_inodes_wb+0x88/0x140
[<c0526d7b>] ? wb_writeback+0x20b/0x320
[<c045aca7>] ? lock_timer_base+0x27/0x50
[<c0526fe0>] ? wb_do_writeback+0x150/0x190
[<c05270a8>] ? bdi_writeback_thread+0x88/0x1f0
[<c043b680>] ? complete+0x40/0x60
[<c0527020>] ? bdi_writeback_thread+0x0/0x1f0
[<c0469474>] ? kthread+0x74/0x80
[<c0469400>] ? kthread+0x0/0x80
[<c040a23e>] ? kernel_thread_helper+0x6/0x10
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
This fixes a hang seen in jbd2_journal_release_jbd_inode
on a lot of Power 6 systems running with ext4. When we get
in the hung state, all I/O to the disk in question gets blocked
where we stay indefinitely. Looking at the task list, I can see
we are stuck in jbd2_journal_release_jbd_inode waiting on a
wake up. I added some debug code to detect this scenario and
dump additional data if we were stuck in jbd2_journal_release_jbd_inode
for longer than 30 minutes. When it hit, I was able to see that
i_flags was 0, suggesting we missed the wake up.
This patch changes i_flags to be an unsigned long, uses bit operators
to access it, and adds barriers around the accesses. Prior to applying
this patch, we were regularly hitting this hang on numerous systems
in our test environment. After applying the patch, the hangs no longer
occur.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
* 'flock' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
locks: turn lock_flocks into a spinlock
fasync: re-organize fasync entry insertion to allow it under a spinlock
locks/nfsd: allocate file lock outside of spinlock
lockd: fix nlmsvc_notify_blocked locking
lockd: push lock_flocks down
This make epoll use hrtimers for the timeout value which prevents
epoll_wait() from timing out up to a millisecond early.
This mirrors the behavior of select() and poll().
Signed-off-by: Shawn Bohrer <shawn.bohrer@gmail.com>
Acked-by: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: Zimny Lech <napohybelskurwysynom2010@gmail.com>
As each board and system has different memory for ramoops. It's better to
define the platform data instead of module params.
[akpm@linux-foundation.org: fix ramoops_remove() return type]
Cc: Marco Stornelli <marco.stornelli@gmail.com>
Add a new __kfifo_int_must_check_helper() helper function, which is needed
for kfifo_alloc() to return the right signed integer value.
The origin __kfifo_must_check_helper() helper was renamed into
__kfifo_uint_must_check_helper() to show the sign which is expected and
returned.
(And revert the temporary disabling of __kfifo_must_check_helper())
Signed-off-by: Stefani Seibold <stefani@seibold.net>
The taskstats interface uses microsecond granularity for the user and
system time values. The conversion from cputime to the taskstats values
uses the cputime_to_msecs primitive which effectively limits the
granularity to milliseconds. Add the cputime_to_usecs primitive for
architectures that have better, more precise CPU time values. Remove
cputime_to_msecs primitive because there are no more users left.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Luck Tony <tony.luck@intel.com>
Cc: Shailabh Nagar <nagar1234@in.ibm.com>
Cc: Shailabh Nagar <nagar@us.ibm.com>
RapidIO spec v.2.1 adds Idle Sequence 2 into LP-Serial Physical Layer.
The fix ensures that corresponding bits are not corrupted during error
handling.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Thomas Moll <thomas.moll@sysgo.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Micha Nelissen <micha@neli.hopto.org>
Detects RIO link to the already enumerated device and properly sets links
between device objects. Changes to the enumeration/discovery logic:
1. Use Master Enable bit to signal end of the enumeration - agents may
start their discovery process as soon as they see this bit set
(Component Tag register was used before for this purpose).
2. Enumerator sets Component Tag (!= 0) immediately during device
setup. This allows to identify the device if the redundant route
exists in a RIO system.
Add the RIO switch driver and definitions for IDT CPS-1848 and CPS-1616
Gen2 devices.
1. Change to create attribute "routes" only for switches.
2. Add a switch-specific callback to create/remove proprietary attributes.
The default error-stopped state handler provides recovery mechanism as
defined by RIO specification.
Create back and forward links between RIO devices. These links are
intended for use by error management and hot-plug extensions. Links for
redundant RIO connections between switches are not set (will be fixed in a
separate patch).
The switch port information is obtained and stored during RIO device
setup. Therefore repeated reads from Switch Port Information CAR may be
removed.
This set of RapidIO patches extends support for standard error recovery
mechanism and adds new IDT Gen2 sRIO switch devices - CPS-1848 and
CPS-1616. Implementation of the standard error-stopped state recovery
mechanism (as defined by the RapidIO specification) is required for the
new switches.
Version 2 of this set of patches addresses received comments and fixes an
error notification setup issue found in the idt_gen2.c after the first
version was released.
This patch:
Make RapidIO devices appear in /sys/devices/rapidio directory instead of
top of /sys/devices directory.
Add support for extended byte synchronous mode feature of hardware.
Signed-off-by: Paul Fulghum <paulkf@microgate.com>
In /proc/stat, the number of per-IRQ event is shown by making a sum each
irq's events on all cpus. But we can make use of kstat_irqs().
kstat_irqs() do the same calculation, If !CONFIG_GENERIC_HARDIRQ,
it's not a big cost. (Both of the number of cpus and irqs are small.)
If a system is very big and CONFIG_GENERIC_HARDIRQ, it does
for_each_irq()
for_each_cpu()
- look up a radix tree
- read desc->irq_stat[cpu]
This seems not efficient. This patch adds kstat_irqs() for
CONFIG_GENRIC_HARDIRQ and change the calculation as
for_each_irq()
look up radix tree
for_each_cpu()
This reduces cost.
A test on (4096cpusp, 256 nodes, 4592 irqs) host (by Jack Steiner)
%time cat /proc/stat > /dev/null
Before Patch: 2.459 sec
After Patch : .561 sec
[akpm@linux-foundation.org: unexport kstat_irqs, coding-style tweaks]
[akpm@linux-foundation.org: fix unused variable 'per_irq_sum']
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Tested-by: Jack Steiner <steiner@sgi.com>
Acked-by: Jack Steiner <steiner@sgi.com>
Cc: Yinghai Lu <yinghai@kernel.org>
/proc/stat shows the total number of all interrupts to each cpu. But when
the number of IRQs are very large, it take very long time and 'cat
/proc/stat' takes more than 10 secs. This is because sum of all irq
events are counted when /proc/stat is read. This patch adds "sum of all
irq" counter percpu and reduce read costs.
The cost of reading /proc/stat is important because it's used by major
applications as 'top', 'ps', 'w', etc....
A test on a mechin (4096cpu, 256 nodes, 4592 irqs) shows
Before Patch: 12.627 sec
After Patch: 2.459 sec
Oleg Nesterov pointed out we have to prevent multiple-threads-inside-exec
itself and we can reuse ->cred_guard_mutex for it. Yes, concurrent
execve() has no worth.
Let's move ->cred_guard_mutex from task_struct to signal_struct. It
naturally prevent multiple-threads-inside-exec.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Roland McGrath <roland@redhat.com>
lock_task_sighand() grabs sighand->siglock in case of returning non-NULL
but unlock_task_sighand() releases it unconditionally. This leads sparse
to complain about the lock context imbalance. Rename and wrap
lock_task_sighand() using __cond_lock() macro to make sparse happy.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Roland McGrath <roland@redhat.com>
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Cc: <linux-arch@vger.kernel.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Since userspace API of ptrace syscall defines @addr and @data as void
pointers, it would be more appropriate to define them as unsigned long in
kernel. Therefore related functions are changed also.
'unsigned long' is typically used in other places in kernel as an opaque
data type and that using this helps cleaning up a lot of warnings from
sparse.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
The ns_cgroup is a control group interacting with the namespaces. When a
new namespace is created, a corresponding cgroup is automatically created
too. The cgroup name is the pid of the process who did 'unshare' or the
child of 'clone'.
This cgroup is tied with the namespace because it prevents a process to
escape the control group and use the post_clone callback, so the child
cgroup inherits the values of the parent cgroup.
Unfortunately, the more we use this cgroup and the more we are facing
problems with it:
(1) when a process unshares, the cgroup name may conflict with a
previous cgroup with the same pid, so unshare or clone return -EEXIST
(2) the cgroup creation is out of control because there may have an
application creating several namespaces where the system will
automatically create several cgroups in his back and let them on the
cgroupfs (eg. a vrf based on the network namespace).
(3) the mix of (1) and (2) force an administrator to regularly check
and clean these cgroups.
This patchset removes the ns_cgroup by adding a new flag to the cgroup and
the cgroupfs mount option. It enables the copy of the parent cgroup when
a child cgroup is created. We can then safely remove the ns_cgroup as
this flag brings a compatibility. We have now to manually create and add
the task to a cgroup, which is consistent with the cgroup framework.
This patch:
Sent as an answer to a previous thread around the ns_cgroup.
https://lists.linux-foundation.org/pipermail/containers/2009-June/018627.html
It adds a control file 'clone_children' for a cgroup. This control file
is a boolean specifying if the child cgroup should be a clone of the
parent cgroup or not. The default value is 'false'.
This flag makes the child cgroup to call the post_clone callback of all
the subsystem, if it is available.
At present, the cpuset is the only one which had implemented the
post_clone callback.
The option can be set at mount time by specifying the 'clone_children'
mount option.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Acked-by: Paul Menage <menage@google.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Jamal Hadi Salim <hadi@cyberus.ca>
Cc: Matt Helsley <matthltc@us.ibm.com>
fb_{read,write} access the framebuffer using lots of fb_{read,write}l's
but don't check that the file position is aligned which can cause problems
on some architectures which do not support unaligned accesses.
Since the operations are essentially memcpy_{from,to}io, new
fb_memcpy_{from,to}fb macros have been defined and these are used instead.
For Sparc, fb_{read,write} macros use sbus_{read,write}, so this defines
new sbus_memcpy_{from,to}io functions the same as memcpy_{from,to}io but
using sbus_{read,write}b instead of {read,write}b.
Signed-off-by: James Hogan <james@albanarts.com>
Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Some ADP5588 functions take a pointer to an i2c_client, but if the i2c
header doesn't happen to be included first, we hit the standard "struct
declared inside parameter list" warnings from gcc. So add a simple
forward decl of the i2c_client struct.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Common code interprets this as a signed value (a negative value is used to
request dynamic ID allocation), so make sure the platform data has proper
types to support that.
Implement irq_chip functionality on ADP5588/5587 GPIO expanders. Only
level sensitive interrupts are supported. Interrupts provided by this
irq_chip must be requested using request_threaded_irq().
Add support for generic 74x164 serial-in/parallel-out 8-bits shift
register. This driver can be used as a GPIO output expander.
[akpm@linux-foundation.org: remove unused local `refresh']
Signed-off-by: Miguel Gaio <miguel.gaio@efixo.com>
Signed-off-by: Juhos Gabor <juhosg@openwrt.org>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
commit 7444a72effa632fcd8edc566f88 ("gpiolib: allow user-selection")
removed HAVE_GPIO_LIB Kconfig symbol, but the header file still uses the
name [to confuse readers wrt #ifdef/#else/#endif location].
The real Kconfig symbol nowadays is CONFIG_GPIOLIB.
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
Cc: David Brownell <david-b@pacbell.net>
The basic GPIO controllers may be found in various on-board FPGA and ASIC
solutions that are used to control board's switches, LEDs, chip-selects,
Ethernet/USB PHY power, etc.
These controllers may not provide any means of pin setup
(in/out/open drain).
The driver supports:
- 8/16/32/64 bits registers;
- GPIO controllers with clear/set registers;
- GPIO controllers with a single "data" register;
- Big endian bits/GPIOs ordering (mostly used on PowerPC).
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>,
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Christoph reported a nice splat which illustrated a race in the new stack
based kmap_atomic implementation.
The problem is that we pop our stack slot before we're completely done
resetting its state -- in particular clearing the PTE (sometimes that's
CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear
the PTE used for the last slot, that interrupt can reuse the slot in a
dirty state, which triggers a BUG in kmap_atomic().
Fix this by introducing kmap_atomic_idx() which reports the current slot
index without actually releasing it and use that to find the PTE and delay
the _pop() until after we're completely done.
Reported-by: Christoph Hellwig <hch@infradead.org>
