Namely "brightness", "contrast" and "flicker reduction".
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
The existing TV connector types are often unsuitable either because
there is no way to probe them until they're actually plugged in or
because they can change during run time (e.g. 7-pin DIN connectors
that behave as S-Video, Component, Composite or SCART depending on the
adaptor plugged in).
Define some helper functions to make easier to detach a KMS encoder
implementation from the drm module of the GPU it's used in. This is
mainly useful for some external I2C encoders known to be present on
cards with GPUs from several different manufacturers.
Add the explanation about DRM debug level in the drmP header file. This is to
explain how/where to use the different DRM debug level.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Two macro definitions of DRM_DEBUG_KMS/MODE can be used to add the debug
info related with KMS. It is confusing.
So remove the macro definition of DRM_DEBUG_MODE. Instead it can be replaced
by the DRM_DEBUG_KMS.
Acked-by: Ian Romanick <ian.d.romanick@intel.com>
We will have to add a prefix when using the macro defintion of DRM_DEBUG_KMS
/DRM_DEBUG_DRIVER/MODE. It is not convenient. We should use the DRM_NAME
as default prefix.
So remove the prefix in the macro definition of DRM_DEBUG_KMS/DRIVER/MODE.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
A regression was added through patch a4ed90d6:
"cfg80211: respect API on orig_flags on channel for beacon hint"
We did indeed respect _orig flags but the intention was not clearly
stated in the commit log. This patch fixes firmware issues picked
up by iwlwifi when we lift passive scan of beaconing restrictions
on channels its EEPROM has been configured to always enable.
By doing so though we also disallowed beacon hints on devices
registering their wiphy with custom world regulatory domains
enabled, this happens to be currently ath5k, ath9k and ar9170.
The passive scan and beacon restrictions on those devices would
never be lifted even if we did find a beacon and the hardware did
support such enhancements when world roaming.
Since Johannes indicates iwlwifi firmware cannot be changed to
allow beacon hinting we set up a flag now to specifically allow
drivers to disable beacon hints for devices which cannot use them.
We enable the flag on iwlwifi to disable beacon hints and by default
enable it for all other drivers. It should be noted beacon hints lift
passive scan flags and beacon restrictions when we receive a beacon from
an AP on any 5 GHz non-DFS channels, and channels 12-14 on the 2.4 GHz
band. We don't bother with channels 1-11 as those channels are allowed
world wide.
This should fix world roaming for ath5k, ath9k and ar9170, thereby
improving scan time when we receive the first beacon from any AP,
and also enabling beaconing operation (AP/IBSS/Mesh) on cards which
would otherwise not be allowed to do so. Drivers not using custom
regulatory stuff (wiphy_apply_custom_regulatory()) were not affected
by this as the orig_flags for the channels would have been cleared
upon wiphy registration.
I tested this with a world roaming ath5k card.
Cc: Jouni Malinen <jouni.malinen@atheros.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
rfcomm tty may be used before rfcomm_tty_driver initilized,
The problem is that now socket layer init before tty layer, if userspace
program do socket callback right here then oops will happen.
reporting in:
http://marc.info/?l=linux-bluetooth&m=124404919324542&w=2
make 3 changes:
1. remove #ifdef in rfcomm/core.c,
make it blank function when rfcomm tty not selected in rfcomm.h
2. tune the rfcomm_init error patch to ensure
tty driver initilized before rfcomm socket usage.
3. remove __exit for rfcomm_cleanup_sockets
because above change need call it in a __init function.
Reported-by: Oliver Hartkopp <oliver@hartkopp.net>
Tested-by: Oliver Hartkopp <oliver@hartkopp.net>
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
The patch fixes a bug when converting dev to mtd_info by using the
drvdata of the dev, the previous code used
container_of(dev, struct mtd_info, dev), but won't work for the mtdXro
devices as they created without being contained inside mtd_info structure.
Signed-off-by: Saeed Bishara <saeed@marvell.com>
When declaring static MTD partitions in board specific code, only
including <include/linux/mtd/partitions.h> should suffice without
gcc nagging us with:
In file included from arch/arm/mach-kirkwood/sheevaplug-setup.c:14:
include/linux/mtd/partitions.h:50: warning: 'struct mtd_info' declared inside parameter list
include/linux/mtd/partitions.h:50: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/mtd/partitions.h:51: warning: 'struct mtd_info' declared inside parameter list
include/linux/mtd/partitions.h:61: warning: 'struct mtd_info' declared inside parameter list
include/linux/mtd/partitions.h:67: warning: 'struct mtd_info' declared inside parameter list
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
In order to be able to distinguish between no samples due to
inactivity and no samples due to task ended, Arjan asked for
PERF_EVENT_EXIT events. This is useful to the boot delay
instrumentation (bootchart) app.
This patch changes the PERF_EVENT_FORK to be emitted on every
clone, and adds PERF_EVENT_EXIT to be emitted on task exit,
after the task's counters have been closed.
This task tracing is controlled through: attr.comm || attr.mmap
and through the new attr.task field.
Suggested-by: Arjan van de Ven <arjan@linux.intel.com>
[ cleaned up perf_counter.h a bit ]
Introduce blk_limits_io_min() and make blk_queue_io_min() call it.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
io context: fix ref counting
block: make the end_io functions be non-GPL exports
block: fix improper kobject release in blk_integrity_unregister
block: always assign default lock to queues
mg_disk: Add missing ready status check on mg_write()
mg_disk: fix issue with data integrity on error in mg_write()
mg_disk: fix reading invalid status when use polling driver
mg_disk: remove prohibited sleep operation
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: Save mult_orig in clocksource_disable()
To fix the common case where ->enable() does not set up
mult, make sure mult_orig is saved in mult on disable.
Also add comments to explain why we do this.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Cc: johnstul@us.ibm.com
Cc: lethal@linux-sh.org
Cc: akpm@linux-foundation.org
LKML-Reference: <20090618152432.10136.9932.sendpatchset@rx1.opensource.se>
the code allready uses flush_kernel_dcache_page(). This patch updates the
driver to the recent sg API changes which require that either SG_MITER_TO_SG
or SG_MITER_FROM_SG is set. SG_MITER_TO_SG calls flush_kernel_dcache_page()
in sg_mitter_stop()
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
sg_miter_start() is currently unaware of the direction of the copy
process (to or from the scatter list). It is important to know the
direction because the page has to be flushed in case the data written
is seen on a different mapping in user land on cache incoherent
architectures.
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Tejun Heo <tj@kernel.org>
Commit d9c7d394a8ebacb60097b192939ae9f15235225e
("block: prevent possible io_context->refcount overflow") mistakenly
changed atomic_inc(&ioc->nr_tasks) to atomic_long_inc(&ioc->refcount).
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Nikanth Karthikesan <knikanth@suse.de>
I've been doing this for years, and akpm picked me up on it about 12
months ago. lguest partly serves as example code, so let's do it Right.
Also, remove two unused fields in struct vblk_info in the example launcher.
I don't really notice it (except to begrudge the extra vertical
space), but Ingo does. And he pointed out that one excuse of lguest
is as a teaching tool, it should set a good example.
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / Hibernate: Replace bdget call with simple atomic_inc of i_count
PM / ACPI: HP G7000 Notebook needs a SCI_EN resume quirk
To avoid userspace build failures such as:
.../linux/uio.h:37: error: expected `=', `,', `;', `asm' or `__attribute__' before `iov_length'
.../linux/uio.h:47: error: expected declaration specifiers or `...' before `size_t'
move uio functions inside a __KERNEL__ block.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Once a structure goes over PAGE_SIZE*2, we see occasional allocation
failures. Some people have chosen to switch over to things like vmalloc()
that will let them keep array-like access to such a large structures.
But, vmalloc() has plenty of downsides.
Here's an alternative. I think it's what Andrew was suggesting here:
http://lkml.org/lkml/2009/7/2/518
I call it a flexible array. It does all of its work in PAGE_SIZE bits, so
never does an order>0 allocation. The base level has
PAGE_SIZE-2*sizeof(int) bytes of storage for pointers to the second level.
So, with a 32-bit arch, you get about 4MB (4183112 bytes) of total
storage when the objects pack nicely into a page. It is half that on
64-bit because the pointers are twice the size. There's a table detailing
this in the code.
There are kerneldocs for the functions, but here's an
overview:
flex_array_alloc() - dynamically allocate a base structure
flex_array_free() - free the array and all of the
second-level pages
flex_array_free_parts() - free the second-level pages, but
not the base (for static bases)
flex_array_put() - copy into the array at the given index
flex_array_get() - copy out of the array at the given index
flex_array_prealloc() - preallocate the second-level pages
between the given indexes to
guarantee no allocs will occur at
put() time.
We could also potentially just pass the "element_size" into each of the
API functions instead of storing it internally. That would get us one
more base pointer on 32-bit.
I've been testing this by running it in userspace. The header and patch
that I've been using are here, as well as the little script I'm using to
generate the size table which goes in the kerneldocs.
http://sr71.net/~dave/linux/flexarray/
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Found with make headers_check
/usr/include/linux/pps.h:52: found __[us]{8,16,32,64} type without #include <linux/types.h>
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Rodolfo Giometti <giometti@linux.it>
After commit ec64f51545fffbc4cb968f0cea56341a4b07e85a ("cgroup: fix
frequent -EBUSY at rmdir"), cgroup's rmdir (especially against memcg)
doesn't return -EBUSY by temporary ref counts. That commit expects all
refs after pre_destroy() is temporary but...it wasn't. Then, rmdir can
wait permanently. This patch tries to fix that and change followings.
- set CGRP_WAIT_ON_RMDIR flag before pre_destroy().
- clear CGRP_WAIT_ON_RMDIR flag when the subsys finds racy case.
if there are sleeping ones, wakes them up.
- rmdir() sleeps only when CGRP_WAIT_ON_RMDIR flag is set.
Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reviewed-by: Paul Menage <menage@google.com>
Acked-by: Balbir Sigh <balbir@linux.vnet.ibm.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
The bug was introduced by commit cc31edceee04a7b87f2be48f9489ebb72d264844
("cgroups: convert tasks file to use a seq_file with shared pid array").
We cache a pid array for all threads that are opening the same "tasks"
file, but the pids in the array are always from the namespace of the
last process that opened the file, so all other threads will read pids
from that namespace instead of their own namespaces.
To fix it, we maintain a list of pid arrays, which is keyed by pid_ns.
The list will be of length 1 at most time.
Reported-by: Paul Menage <menage@google.com>
Idea-by: Paul Menage <menage@google.com>
Reviewed-by: Serge Hallyn <serue@us.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-radeon-kms' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (35 commits)
drm/radeon: set fb aperture sizes for framebuffer handoff.
drm/ttm: fix highuser vs dma32 confusion.
drm/radeon: Fix size used for benchmarking BO copies.
drm/radeon: Add radeon.test parameter for running BO GPU copy tests.
drm/radeon/kms: allow interruptible waits for objects.
drm/ttm: powerpc: Fix Highmem cache flushing.
x86: Export kmap_atomic_prot() needed for TTM.
drm/ttm: Fix ttm in-kernel copying of pages with non-standard caching attributes.
drm/ttm: Fix an oops and sync object leak.
drm/radeon/kms: vram sizing on certain r100 chips needs workaround.
drm/radeon: Pay more attention to object placement requested by userspace.
drm/radeon: Fall back to evicting BOs with memcpy if necessary.
drm/radeon: Don't unreserve twice on failure to validate.
drm/radeon/kms: fix bandwidth computation on avivo hardware
drm/radeon/kms: add initial colortiling support.
drm/radeon/kms: fix hotspot handling on pre-avivo chips
drm/radeon/kms: enable frac fb divs on rs600/rs690/rs740
drm/radeon/kms: add PLL flag to prefer frequencies <= the target freq
drm/radeon/kms: block RN50 from using 3D engine.
drm/radeon/kms: fix VRAM sizing like DDX does it.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: accept late unlocking of HPA
libata: Updates and fixes for pata_at91 driver
ata_piix: Add new short cable ID
ata_piix: Add new laptop short cable IDs
ahci: add device IDs for Ibex Peak ahci controllers
libata: remove superfluous NULL pointer checks
libata: add missing NULL pointer check to ata_eh_reset()
pata_pcmcia: add CNF-CDROM-ID
We really don't want to mark the pty as a low-latency device, because as
Alan points out, the ->write method can be called from an IRQ (ppp?),
and that means we can't use ->low_latency=1 as we take mutexes in the
low_latency case.
So rather than using low_latency to force the written data to be pushed
to the ldisc handling at 'write()' time, just make the reader side (or
the poll function) do the flush when it checks whether there is data to
be had.
This also fixes the problem with lost data in an emacs compile buffer
(bugzilla 13815), and we can thus revert the low_latency pty hack
(commit 3a54297478e6578f96fd54bf4daa1751130aca86: "pty: quickfix for the
pty ENXIO timing problems").
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
[ Modified to do the tty_flush_to_ldisc() inside input_available_p() so
that it triggers for both read and poll() - Linus]
Create bdgrab(). This function copies an existing reference to a
block_device. It is safe to call from any context.
Hibernation code wishes to copy a reference to the active swap device.
Right now it calls bdget() under a spinlock, but this is wrong because
bdget() can sleep. It doesn't need a full bdget() because we already
hold a reference to active swap devices (and the spinlock protects
against swapoff).
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=13827
Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
This adds new set/get tiling interfaces where the pitch
and macro/micro tiling enables can be set. Along with
a flag to decide if this object should have a surface when mapped.
The only thing we need to allocate with a mapped surface should be
the frontbuffer. Note rotate scanout shouldn't require one, and
back/depth shouldn't either, though mesa needs some fixes.
It fixes the TTM interfaces along Thomas's suggestions, and I've tested
the surface stealing code with two X servers and not seen any lockdep issues.
I've stopped tiling the fbcon frontbuffer, as I don't see there being
any advantage other than testing, I've left the testing commands in there,
just flip the fb_tiled to true in radeon_fb.c
Open: Can we integrate endian swapping in with this?
Future features:
texture tiling - need to relocate texture registers TXOFFSET* with tiling info.
This also merges Michel's cleanup surfaces regs at init time patch
even though it makes sense on its own, this patch really relies on it.
Some PowerMac firmwares set up a tiling surface at the beginning of VRAM
which messes us up otherwise.
that patch is:
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
On certain configurations, HPA isn't or can't be unlocked during
probing but it somehow ends up unlocked afterwards. In the following
thread, the problem can be reliably reproduced after resuming from
STR. The BIOS turns on HPA during boot but forgets to do it during
resume.
http://thread.gmane.org/gmane.linux.kernel/858310
This patch updates libata revalidation such that it considers native
n_sectors. If the device size has increased to match native
n_sectors, it's assumed that HPA has been unlocked involuntarily and
the device is recognized as the same one. This should be fairly safe
while nicely working around the problem.
Reported-by: Christof Warlich <christof@warlich.name>
Even though reverse path filter was changed from simple boolean to
trinary control, the loose mode only works if both all and device are
configured because of this logic error.
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
inotify: use GFP_NOFS under potential memory pressure
fsnotify: fix inotify tail drop check with path entries
inotify: check filename before dropping repeat events
fsnotify: use def_bool in kconfig instead of letting the user choose
inotify: fix error paths in inotify_update_watch
inotify: do not leak inode marks in inotify_add_watch
inotify: drop user watch count when a watch is removed
This reverts commit f9ca058430333c9a24c5ca926aa445125f88df18.
which caused a regression:
http://bugzilla.kernel.org/show_bug.cgi?id=13620
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (45 commits)
cnic: Fix ISCSI_KEVENT_IF_DOWN message handling.
net: irda: init spinlock after memcpy
ixgbe: fix for 82599 errata marking UDP checksum errors
r8169: WakeOnLan fix for the 8168
netxen: reset ring consumer during cleanup
net/bridge: use kobject_put to release kobject in br_add_if error path
smc91x.h: add config for Nomadik evaluation kit
NET: ROSE: Don't use static buffer.
eepro: Read buffer overflow
tokenring: Read buffer overflow
at1700: Read buffer overflow
fealnx: Write outside array bounds
ixgbe: remove unnecessary call to device_init_wakeup
ixgbe: Don't priority tag control frames in DCB mode
ixgbe: Enable FCoE offload when DCB is enabled for 82599
net: Rework mdio-ofgpio driver to use of_mdio infrastructure
register at91_ether using platform_driver_probe
skge: Enable WoL by default if supported
net: KS8851 needs to depend on MII
be2net: Bug fix in the non-lro path. Size of received packet was not updated in statistics properly.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (34 commits)
V4L/DVB (12303): cx23885: check pointers before dereferencing in dprintk macro
V4L/DVB (12302): cx23885-417: fix broken IOCTL handling
V4L/DVB (12300): bttv: fix regression: tvaudio must be loaded before tuner
V4L/DVB (12291): b2c2: fix frontends compiled into kernel
V4L/DVB (12286): sn9c20x: reorder includes to be like other drivers
V4L/DVB (12284): gspca - jpeg subdrivers: Check the result of kmalloc(jpeg header).
V4L/DVB (12283): gspca - sn9c20x: New subdriver for sn9c201 and sn9c202 bridges.
V4L/DVB (12282): gspca - main: Support for vidioc_g_chip_ident and vidioc_g/s_register.
V4L/DVB (12269): af9013: auto-detect parameters in case of garbage given by app
V4L/DVB (12267): gspca - sonixj: Bad sensor init of non ov76xx sensors.
V4L/DVB (12265): em28xx: fix tuning problem in HVR-900 (R1)
V4L/DVB (12263): em28xx: set demod profile for Pinnacle Hybrid Pro 320e
V4L/DVB (12262): em28xx: Make sure the tuner is initialized if generic empia USB id was used
V4L/DVB (12261): em28xx: set GPIO properly for Pinnacle Hybrid Pro analog support
V4L/DVB (12260): em28xx: make support work for the Pinnacle Hybrid Pro (eb1a:2881)
V4L/DVB (12258): em28xx: fix typo in mt352 init sequence for Terratec Cinergy T XS USB
V4L/DVB (12257): em28xx: make tuning work for Terratec Cinergy T XS USB (mt352 variant)
V4L/DVB (12245): em28xx: add support for mt9m001 webcams
V4L/DVB (12244): em28xx: adjust vinmode/vinctl based on the stream input format
V4L/DVB (12243): em28xx: allow specifying sensor xtal frequency
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm table: pass correct dev area size to device_area_is_valid
dm: remove queue next_ordered workaround for barriers
dm raid1: wake kmirrord when requeueing delayed bios after remote recovery
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
jbd: fix race between write_metadata_buffer and get_write_access
ext3: Get rid of extenddisksize parameter of ext3_get_blocks_handle()
jbd: Fix a race between checkpointing code and journal_get_write_access()
ext3: Fix truncation of symlinks after failed write
jbd: Fail to load a journal if it is too short
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()
Upcoming paches to support the new 64-bit "BookE" powerpc architecture
will need to have the virtual address corresponding to PTE page when
freeing it, due to the way the HW table walker works.
Basically, the TLB can be loaded with "large" pages that cover the whole
virtual space (well, sort-of, half of it actually) represented by a PTE
page, and which contain an "indirect" bit indicating that this TLB entry
RPN points to an array of PTEs from which the TLB can then create direct
entries. Thus, in order to invalidate those when PTE pages are deleted,
we need the virtual address to pass to tlbilx or tlbivax instructions.
The old trick of sticking it somewhere in the PTE page struct page sucks
too much, the address is almost readily available in all call sites and
almost everybody implemets these as macros, so we may as well add the
argument everywhere. I added it to the pmd and pud variants for consistency.
Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV]
Acked-by: Nick Piggin <npiggin@suse.de>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390]
The use of a static buffer in rose2asc() to return its result is not
threadproof and can result in corruption if multiple threads are trying
to use one of the procfs files based on rose2asc().
Signed-off-by: Brian Johnson <brijohn@gmail.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Incorrect device area lengths are being passed to device_area_is_valid().
The regression appeared in 2.6.31-rc1 through commit
754c5fc7ebb417b23601a6222a6005cc2e7f2913.
With the dm-stripe target, the size of the target (ti->len) was used
instead of the stripe_width (ti->len/#stripes). An example of a
consequent incorrect error message is:
device-mapper: table: 254:0: sdb too small for target
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-perf
* 'perf-counters-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-perf: (31 commits)
perf_counter tools: Give perf top inherit option
perf_counter tools: Fix vmlinux symbol generation breakage
perf_counter: Detect debugfs location
perf_counter: Add tracepoint support to perf list, perf stat
perf symbol: C++ demangling
perf: avoid structure size confusion by using a fixed size
perf_counter: Fix throttle/unthrottle event logging
perf_counter: Improve perf stat and perf record option parsing
perf_counter: PERF_SAMPLE_ID and inherited counters
perf_counter: Plug more stack leaks
perf: Fix stack data leak
perf_counter: Remove unused variables
perf_counter: Make call graph option consistent
perf_counter: Add perf record option to log addresses
perf_counter: Log vfork as a fork event
perf_counter: Synthesize VDSO mmap event
perf_counter: Make sure we dont leak kernel memory to userspace
perf_counter tools: Fix index boundary check
perf_counter: Fix the tracepoint channel to perfcounters
perf_counter, x86: Extend perf_counter Pentium M support
* 'core-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
softirq: introduce tasklet_hrtimer infrastructure
