Bug 769337
Change-Id: I61b958bbb33e548aa975844bf67e9e18ed640668
Reviewed-on: http://git-master/r/14224
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
arch/arm/mach-tegra/board-ventana-power.c
drivers/mfd/tps6586x.c
Change-Id: Ic8c46d4251d6e71fa2900b7e876f87e256299bc4
be freed""
This reverts commit d534322cb6066ae0db4790ceacba3e1a95b1ee7c.
drivers/usb/gadget/composite.c
Change-Id: I1a332ec21da62aea98912df9a01cf0282ed50ee1
synchronize_rcu can be very expensive, averaging 100 ms in
some cases. In cgroup_attach_task, it is used to prevent
a task->cgroups pointer dereferenced in an RCU read side
critical section from being invalidated, by delaying the
call to put_css_set until after an RCU grace period.
To avoid the call to synchronize_rcu, make the put_css_set
call rcu-safe by moving the deletion of the css_set links
into free_css_set_work, scheduled by the rcu callback
free_css_set_rcu.
The decrement of the cgroup refcount is no longer
synchronous with the call to put_css_set, which can result
in the cgroup refcount staying positive after the last call
to cgroup_attach_task returns. To allow the cgroup to be
deleted with cgroup_rmdir synchronously after
cgroup_attach_task, have rmdir check the refcount of all
associated css_sets. If cgroup_rmdir is called on a cgroup
for which the css_sets all have refcount zero but the
cgroup refcount is nonzero, reuse the rmdir waitqueue to
block the rmdir until free_css_set_work is called.
Signed-off-by: Colin Cross <ccross@android.com>
Changes the meaning of CGRP_RELEASABLE to be set on any cgroup
that has ever had a task or cgroup in it, or had css_get called
on it. The bit is set in cgroup_attach_task, cgroup_create,
and __css_get. It is not necessary to set the bit in
cgroup_fork, as the task is either in the root cgroup, in
which can never be released, or the task it was forked from
already set the bit in croup_attach_task.
The Tegra2 USB controller doesn't properly deal with misaligned DMA
buffers, causing corruption. This is especially prevalent with USB
network adapters, where skbuff alignment is often in the middle of a
4-byte dword.
To avoid this, allocate a temporary buffer for the DMA if the provided
buffer isn't sufficiently aligned.
Change-Id: Ica56c52c3b2152e3ba2b96506cf15105462a0602
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Reviewed-on: http://git-master/r/13382
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Janne Hellsten <jhellsten@nvidia.com>
when tps6586x is put into sleep mode, it powers off ldos. Add an
api to put tps6586x in sleep mode by resetting EXITSLREQ and
setting SLEEP_MODE in SUPPLYENE register.
Change-Id: I80fe35d541e85014bd7b5544d212573fe35d67e5
Reviewed-on: http://git-master/r/13589
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Add max8907c regulator and mfd driver.
Add max8952 regulator driver.
Change-Id: If63b724647d887a8088da0f2deb8af91e4fe3cfa
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/9902
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
These are useful in case your device has quirks involving what memory
is and is not DMAable.
Change-Id: I60b48ef8efd9f7f78eaba70d708d25b231f23d82
Reviewed-on: http://git-master/r/13381
Change-Id: I84ac6254ede2e88e8141e6ffd630eb753d9b1d91
Source files should not be with executable permission.
Change-Id: I70b6be4cf88fea4be9b092ca2f5dd08e40ee7cbd
Reviewed-on: http://git-master/r/12081
Reviewed-by: Chao Jiang <chaoj@nvidia.com>
Tested-by: Chao Jiang <chaoj@nvidia.com>
Change-Id: Ice30bc601132f829abd664c68ddc61cbcdb8668c
Also remove disconnect debouncing, which didn't actually work on some platforms
Signed-off-by: Mike Lockwood <lockwood@android.com>
Change-Id: I87de64e2c1a87c8e4da89489b4c5c18860abb0f6
Reviewed-on: http://git-master/r/11491
Reviewed-by: Robert R Collins <rcollins@nvidia.com>
Tested-by: Robert R Collins <rcollins@nvidia.com>
Reviewed-by: Maria Gutowski <mgutowski@nvidia.com>
Inegrate MPL libraries and the following sensors:
Accelerometers:
kxtf9
Compi:
ak8975
Change-Id: I450b5b7ff018249a19bb23b78e722e9a355b7bd8
Reviewed-on: http://git-master/r/11803
Change-Id: I1312ec33ba8bac38dc395d7d1a2f485b13d74c14
commit 72083646528d4887b920deb71b37e09bc7d227bb upstream.
This avoids some include-file hell, and the function isn't really
important enough to be inlined anyway.
Reported-by: Ingo Molnar <mingo@elte.hu>
commit c66fb347946ebdd5b10908866ecc9fa05ee2cf3d upstream.
And in particular, use it in 'pipe_fcntl()'.
The other pipe functions do not need to use the 'careful' version, since
they are only ever called for things that are already known to be pipes.
The normal read/write/ioctl functions are called through the file
operations structures, so if a file isn't a pipe, they'd never get
called. But pipe_fcntl() is special, and called directly from the
generic fcntl code, and needs to use the same careful function that the
splice code is using.
Cc: Jens Axboe <jaxboe@fusionio.com>
Cc: Dave Jones <davej@redhat.com>
commit 8acfe468b0384e834a303f08ebc4953d72fb690a upstream.
This helps protect us from overflow issues down in the
individual protocol sendmsg/recvmsg handlers. Once
we hit INT_MAX we truncate out the rest of the iovec
by setting the iov_len members to zero.
This works because:
1) For SOCK_STREAM and SOCK_SEQPACKET sockets, partial
writes are allowed and the application will just continue
with another write to send the rest of the data.
2) For datagram oriented sockets, where there must be a
one-to-one correspondance between write() calls and
packets on the wire, INT_MAX is going to be far larger
than the packet size limit the protocol is going to
check for and signal with -EMSGSIZE.
Based upon a patch by Linus Torvalds.
commit c9e664f1fdf34aa8cede047b206deaa8f1945af0 upstream.
There is a problem that swap pages allocated before the creation of
a hibernation image can be released and used for storing the contents
of different memory pages while the image is being saved. Since the
kernel stored in the image doesn't know of that, it causes memory
corruption to occur after resume from hibernation, especially on
systems with relatively small RAM that need to swap often.
This issue can be addressed by keeping the GFP_IOFS bits clear
in gfp_allowed_mask during the entire hibernation, including the
saving of the image, until the system is finally turned off or
the hibernation is aborted. Unfortunately, for this purpose
it's necessary to rework the way in which the hibernate and
suspend code manipulates gfp_allowed_mask.
This change is based on an earlier patch from Hugh Dickins.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit dddd3379a619a4cb8247bfd3c94ca9ae3797aa2e upstream.
It was found that sometimes children of tasks with inherited events had
one extra event. Eventually it turned out to be due to the list rotation
no being exclusive with the list iteration in the inheritance code.
Cure this by temporarily disabling the rotation while we inherit the events.
LKML-Reference: <new-submission>
commit 114279be2120a916e8a04feeb2ac976a10016f2f upstream.
Note: this patch targets 2.6.37 and tries to be as simple as possible.
That is why it adds more copy-and-paste horror into fs/compat.c and
uglifies fs/exec.c, this will be cleanuped later.
compat_copy_strings() plays with bprm->vma/mm directly and thus has
two problems: it lacks the RLIMIT_STACK check and argv/envp memory
is not visible to oom killer.
Export acct_arg_size() and get_arg_page(), change compat_copy_strings()
to use get_arg_page(), change compat_do_execve() to do acct_arg_size(0)
as do_execve() does.
Add the fatal_signal_pending/cond_resched checks into compat_count() and
compat_copy_strings(), this matches the code in fs/exec.c and certainly
makes sense.
commit 3c77f845722158206a7209c45ccddc264d19319c upstream.
Brad Spengler published a local memory-allocation DoS that
evades the OOM-killer (though not the virtual memory RLIMIT):
http://www.grsecurity.net/~spender/64bit_dos.c
execve()->copy_strings() can allocate a lot of memory, but
this is not visible to oom-killer, nobody can see the nascent
bprm->mm and take it into account.
With this patch get_arg_page() increments current's MM_ANONPAGES
counter every time we allocate the new page for argv/envp. When
do_execve() succeds or fails, we change this counter back.
Technically this is not 100% correct, we can't know if the new
page is swapped out and turn MM_ANONPAGES into MM_SWAPENTS, but
I don't think this really matters and everything becomes correct
once exec changes ->mm or fails.
Reported-by: Brad Spengler <spender@grsecurity.net>
Reviewed-and-discussed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 27d20fddc8af539464fc3ba499d6a830054c3bd6 upstream.
Salman Qazi describes the following radix-tree bug:
In the following case, we get can get a deadlock:
0. The radix tree contains two items, one has the index 0.
1. The reader (in this case find_get_pages) takes the rcu_read_lock.
2. The reader acquires slot(s) for item(s) including the index 0 item.
3. The non-zero index item is deleted, and as a consequence the other item is
moved to the root of the tree. The place where it used to be is queued for
deletion after the readers finish.
3b. The zero item is deleted, removing it from the direct slot, it remains in
the rcu-delayed indirect node.
4. The reader looks at the index 0 slot, and finds that the page has 0 ref
count
5. The reader looks at it again, hoping that the item will either be freed or
the ref count will increase. This never happens, as the slot it is looking
at will never be updated. Also, this slot can never be reclaimed because
the reader is holding rcu_read_lock and is in an infinite loop.
The fix is to re-use the same "indirect" pointer case that requires a slot
lookup retry into a general "retry the lookup" bit.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reported-by: Salman Qazi <sqazi@google.com>
commit ac5aa2e3332ec04889074afdbd1479424d0227a5 upstream.
The NF_HOOK_COND returns 0 when it shouldn't due to what I believe to be an
error in the code as the order of operations is not what was intended. C will
evalutate == before =. Which means ret is getting set to the bool result,
rather than the return value of the function call. The code says
if (ret = function() == 1)
when it meant to say:
if ((ret = function()) == 1)
Normally the compiler would warn, but it doesn't notice it because its
a actually complex conditional and so the wrong code is wrapped in an explict
set of () [exactly what the compiler wants you to do if this was intentional].
Fixing this means that errors when netfilter denies a packet get propagated
back up the stack rather than lost.
Problem introduced by commit 2249065f (netfilter: get rid of the grossness
in netfilter.h).
Signed-off-by: Eric Paris <eparis@redhat.com>
commit acfa747baf73922021a047f2d87a2d866f5dbab5 upstream.
Like in the "TTY: don't allow reopen when ldisc is changing" patch,
this one fixes a TTY WARNING as described in the option 1) there:
1) __tty_hangup from tty_ldisc_hangup to tty_ldisc_enable. During this
section tty_lock is held. However tty_lock is temporarily dropped in
the middle of the function by tty_ldisc_hangup.
The fix is to introduce a new flag which we set during the unlocked
window and check it in tty_reopen too. The flag is TTY_HUPPING and is
cleared after TTY_HUPPED is set.
While at it, remove duplicate TTY_HUPPED set_bit. The one after
calling ops->hangup seems to be more correct. But anyway, we hold
tty_lock, so there should be no difference.
Also document the function it does that kind of crap.
Nicely reproducible with two forked children:
static void do_work(const char *tty)
if (signal(SIGHUP, SIG_IGN) == SIG_ERR) exit(1);
setsid();
while (1) {
int fd = open(tty, O_RDWR|O_NOCTTY);
if (fd < 0) continue;
if (ioctl(fd, TIOCSCTTY)) continue;
if (vhangup()) continue;
close(fd);
exit(0);
Reported-by: <Valdis.Kletnieks@vt.edu>
Reported-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
commit 1d8638d4038eb8709edc80e37a0bbb77253d86e9 upstream.
Add new vendor for Broadcom 4318.
Signed-off-by: Daniel Klaffenbach <danielklaffenbach@gmail.com>
commit 52c5171214ff3327961d0ce0db7e8d2ce55004fd upstream.
This helper is wrong: it coerces signed values into unsigned ones, so code
such as
if (kfifo_alloc(...) < 0) {
error
will fail to detect the error.
So let's disable __kfifo_must_check_helper() for 2.6.36.
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Stefani Seibold <stefani@seibold.net>
commit eb7d3066cf864342e8ae6a5c1126a1602c4d06c0 upstream.
This patch fixes stale mac80211_tx_control_flags for
filtered / retried frames.
Because ieee80211_handle_filtered_frame feeds skbs back
into the tx path, they have to be stripped of some tx
flags so they won't confuse the stack, driver or device.
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 892b6f90db81cccb723d5d92f4fddc2d68b206e1 upstream.
Physical block size was declared unsigned int to accomodate the maximum
size reported by READ CAPACITY(16). Make sure we use the right type in
the related functions.
Acked-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
- Added multiple ACM instance support in Android gadget
- Fixed multiple instance naming issue in ACM function
- Increased max instances from 4 to 8
Change-Id: I65f1b0be94da859bab7ec0ad7cd804b896c7c4c5
Signed-off-by: John Michelau <john.michelau@motorola.com>
Change-Id: I7299b3bed83fbf41f5666724e328980cfcda1186
This governor is designed for latency-sensitive workloads, such as
interactive user interfaces. The interactive governor aims to be
significantly more responsive to ramp CPU quickly up when CPU-intensive
activity begins.
Existing governors sample CPU load at a particular rate, typically
every X ms. This can lead to under-powering UI threads for the period of
time during which the user begins interacting with a previously-idle system
until the next sample period happens.
The 'interactive' governor uses a different approach. Instead of sampling
the CPU at a specified rate, the governor will check whether to scale the
CPU frequency up soon after coming out of idle. When the CPU comes out of
idle, a timer is configured to fire within 1-2 ticks. If the CPU is very
busy from exiting idle to when the timer fires then we assume the CPU is
underpowered and ramp to MAX speed.
If the CPU was not sufficiently busy to immediately ramp to MAX speed, then
the governor evaluates the CPU load since the last speed adjustment,
choosing the highest value between that longer-term load or the short-term
load since idle exit to determine the CPU speed to ramp to.
A realtime thread is used for scaling up, giving the remaining tasks the
CPU performance benefit, unlike existing governors which are more likely to
schedule rampup work to occur after your performance starved tasks have
completed.
The tuneables for this governor are:
/sys/devices/system/cpu/cpufreq/interactive/min_sample_time:
The minimum amount of time to spend at the current frequency before
ramping down. This is to ensure that the governor has seen enough
historic CPU load data to determine the appropriate workload.
Default is 80000 uS.
/sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load
The CPU load at which to ramp to max speed. Default is 85.
Change-Id: Ib2b362607c62f7c56d35f44a9ef3280f98c17585
Signed-off-by: Mike Chan <mike@android.com>
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Bug: 3152864
Change-Id: Ibd208fc6b803bbf729d1f554839ebaee8c8461ce
arch/arm/mach-tegra/tegra_i2s_audio.c
Signed-off-by: Iliyan Malchev <malchev@google.com>
- Refactor DMA interactions to handle continuous single-buffered DMA
- Remove PIO support (obsolete, conflicts with new buffer management)
- Remove sample rate conversion (obsolete)
- Remove error-reporting logic
- Remove TEGRA_AUDIO_IN/OUT_GET/SET_BUF_CONFIG
- Add TEGRA_AUDIO_IN/OUT_GET/SET_NUM_BUFS
Change-Id: I8f21a0bb314aac3b7d1bb4918bda9141e58db38d
Change-Id: I127ea2a132adf2126c28194e8d778cc46b0a2e63
Reviewed-on: http://git-master/r/10573
Reviewed-by: Chien-Yu Chen <chichen@nvidia.com>
Change-Id: Iff6fb3eee3b96120f3973ccada4c0b0772dbc2b3
Change-Id: I4bed4d37bc275cca9ef69390c217498529121db0
Signed-off-by: Erik Gilling <konkers@android.com>
Change-Id: Ib01f171e7159768fc5ed3509b5a3e0b987dc57ef
For backward compatibility with PTP, MTP is limited to a 32-bit file size.
When transferring files greater than 4 gig, MTP uses 0xFFFFFFFF as the file size
and the receiver reads until it receives a short packet.
Expanded size of mtp_file_range.length to 64 bits and added support for
writing zero length packets.
Change-Id: I8f323ecc04e0ccefa31d6533b58b7878675bf8c9
Change-Id: I7dbc97aee0c0912baf4722a8756d228bf7dd1212
