[ Upstream commit 1363074667a6b7d0507527742ccd7bbed5e3ceaa ]
Add a new NO_REPORT_LUNS quirk and set it for Seagate drives with
an usb-id of: 0bc2:331a, as these will fail to respond to a
REPORT_LUNS command.
Cc: stable@vger.kernel.org
Reported-and-tested-by: David Webb <djw@noc.ac.uk>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit 95272c29378ee7dc15f43fa2758cb28a5913a06d ]
-ftracer can duplicate asm blocks causing compilation to fail in
noclone functions. For example, KVM declares a global variable
in an asm like
asm("2: ... \n
.pushsection data \n
.global vmx_return \n
vmx_return: .long 2b");
and -ftracer causes a double declaration.
Cc: Michal Marek <mmarek@suse.cz>
Cc: kvm@vger.kernel.org
Reported-by: Linda Walsh <lkml@tlinx.org>
[ Upstream commit cb984d101b30eb7478d32df56a0023e4603cba7f ]
As gcc major version numbers are going to advance rather rapidly in the
future, there's no real value in separate files for each compiler
version.
Deduplicate some of the macros #defined in each file too.
Neaten comments using normal kernel commenting style.
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Sasha Levin <levinsasha928@gmail.com>
Cc: Alan Modra <amodra@gmail.com>
[ Upstream commit d00181b96eb86c914cb327d1de974a1b71366e1b ]
Let's try to be consistent about data type of page order.
[sfr@canb.auug.org.au: fix build (type of pageblock_order)]
[hughd@google.com: some configs end up with MAX_ORDER and pageblock_order having different types]
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
[ Upstream commit 378c6520e7d29280f400ef2ceaf155c86f05a71a ]
This commit fixes the following security hole affecting systems where
all of the following conditions are fulfilled:
- The fs.suid_dumpable sysctl is set to 2.
- The kernel.core_pattern sysctl's value starts with "/". (Systems
where kernel.core_pattern starts with "|/" are not affected.)
- Unprivileged user namespace creation is permitted. (This is
true on Linux >=3.8, but some distributions disallow it by
default using a distro patch.)
Under these conditions, if a program executes under secure exec rules,
causing it to run with the SUID_DUMP_ROOT flag, then unshares its user
namespace, changes its root directory and crashes, the coredump will be
written using fsuid=0 and a path derived from kernel.core_pattern - but
this path is interpreted relative to the root directory of the process,
allowing the attacker to control where a coredump will be written with
root privileges.
To fix the security issue, always interpret core_pattern for dumps that
are written under SUID_DUMP_ROOT relative to the root directory of init.
Signed-off-by: Jann Horn <jann@thejh.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit 3debb0a9ddb16526de8b456491b7db60114f7b5e ]
The trace_printk() code will allocate extra buffers if the compile detects
that a trace_printk() is used. To do this, the format of the trace_printk()
is saved to the __trace_printk_fmt section, and if that section is bigger
than zero, the buffers are allocated (along with a message that this has
happened).
If trace_printk() uses a format that is not a constant, and thus something
not guaranteed to be around when the print happens, the compiler optimizes
the fmt out, as it is not used, and the __trace_printk_fmt section is not
filled. This means the kernel will not allocate the special buffers needed
for the trace_printk() and the trace_printk() will not write anything to the
tracing buffer.
Adding a "__used" to the variable in the __trace_printk_fmt section will
keep it around, even though it is set to NULL. This will keep the string
from being printed in the debugfs/tracing/printk_formats section as it is
not needed.
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Fixes: 07d777fe8c398 "tracing: Add percpu buffers for trace_printk()"
Cc: stable@vger.kernel.org # v3.5+
[ Upstream commit f75d48644c56a31731d17fa693c8175328957e1d ]
__clear_bit_unlock() is a special little snowflake. While it carries the
non-atomic '__' prefix, it is specifically documented to pair with
test_and_set_bit() and therefore should be 'somewhat' atomic.
Therefore the generic implementation of __clear_bit_unlock() cannot use
the fully non-atomic __clear_bit() as a default.
If an arch is able to do better; is must provide an implementation of
__clear_bit_unlock() itself.
Specifically, this came up as a result of hackbench livelock'ing in
slab_lock() on ARC with SMP + SLUB + !LLSC.
The issue was incorrect pairing of atomic ops.
slab_lock() -> bit_spin_lock() -> test_and_set_bit()
slab_unlock() -> __bit_spin_unlock() -> __clear_bit()
The non serializing __clear_bit() was getting "lost"
80543b8e: ld_s r2,[r13,0] <--- (A) Finds PG_locked is set
80543b90: or r3,r2,1 <--- (B) other core unlocks right here
80543b94: st_s r3,[r13,0] <--- (C) sets PG_locked (overwrites unlock)
Fixes ARC STAR 9000817404 (and probably more).
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Tested-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Helge Deller <deller@gmx.de>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Noam Camus <noamc@ezchip.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/20160309114054.GJ6356@twins.programming.kicks-ass.net
[ Upstream commit 81ad4276b505e987dd8ebbdf63605f92cd172b52 ]
In some cases, platform thermal driver may report invalid trip points,
thermal core should not take any action for these trip points.
This fixed a regression that bogus trip point starts to screw up thermal
control on some Lenovo laptops, after
commit bb431ba26c5cd0a17c941ca6c3a195a3a6d5d461
Author: Zhang Rui <rui.zhang@intel.com>
Date: Fri Oct 30 16:31:47 2015 +0800
Thermal: initialize thermal zone device correctly
After thermal zone device registered, as we have not read any
temperature before, thus tz->temperature should not be 0,
which actually means 0C, and thermal trend is not available.
In this case, we need specially handling for the first
thermal_zone_device_update().
Both thermal core framework and step_wise governor is
enhanced to handle this. And since the step_wise governor
is the only one that uses trends, so it's the only thermal
governor that needs to be updated.
Tested-by: Manuel Krause <manuelkrause@netscape.net>
Tested-by: szegad <szegadlo@poczta.onet.pl>
Tested-by: prash <prash.n.rao@gmail.com>
Tested-by: amish <ammdispose-arch@yahoo.com>
Tested-by: Matthias <morpheusxyz123@yahoo.de>
Reviewed-by: Javi Merino <javi.merino@arm.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Chen Yu <yu.c.chen@intel.com>
CC: <stable@vger.kernel.org> #3.18+
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1317190
Link: https://bugzilla.kernel.org/show_bug.cgi?id=114551
[ Upstream commit 74843787158e9dff249f0528e7d4806102cc2c26 ]
Commit ecb89f2f5f3e7 ("mmc: atmel-mci: remove compat for non DT board
when requesting dma chan") broke dma on AVR32 and any other boards not
using DT. This restores a fallback mechanism for such cases.
Signed-off-by: Mans Rullgard <mans@mansr.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit fbce23a0b95763dfc4961ce6240e055c39f497ed ]
This patch changes the return type of snd_hdac_power_up/down() and
variants to pass the error code from the underlying
pm_runtime_get/put() calls. Currently they are ignored, but in most
places, these should be handled properly.
As an example, the regmap handler is updated to check the return value
and accesses the register only when the wakeup succeeds.
[ Upstream commit b84106b4e2290c081cdab521fa832596cdfea246 ]
The PCI config header (first 64 bytes of each device's config space) is
defined by the PCI spec so generic software can identify the device and
manage its usage of I/O, memory, and IRQ resources.
Some non-spec-compliant devices put registers other than BARs where the
BARs should be. When the PCI core sizes these "BARs", the reads and writes
it does may have unwanted side effects, and the "BAR" may appear to
describe non-sensical address space.
Add a flag bit to mark non-compliant devices so we don't touch their BARs.
Turn off IO/MEM decoding to prevent the devices from consuming address
space, since we can't read the BARs to find out what that address space
would be.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Tested-by: Andi Kleen <ak@linux.intel.com>
CC: stable@vger.kernel.org
[ Upstream commit d0751b98dfa391f862e02dc36a233a54615e3f1d ]
A PCIe Port is an interface to a Link. A Root Port is a PCI-PCI bridge in
a Root Complex and has a Link on its secondary (downstream) side. For
other Ports, the Link may be on either the upstream (closer to the Root
Complex) or downstream side of the Port.
The usual topology has a Root Port connected to an Upstream Port. We
previously assumed this was the only possible topology, and that a
Downstream Port's Link was always on its downstream side, like this:
+------+ | Downstream |
| Root | | Upstream Port +--Link--
| Port +--Link--+ Port |
| Port +--Link--
But systems do exist (see URL below) where the Root Port is connected to a
Downstream Port. In this case, a Downstream Port's Link may be on either
the upstream or downstream side:
+------+ | Upstream |
| Root | | Downstream Port +--Link--
| Port +--Link--
We can't use the Port type to determine which side the Link is on, so add a
bit in struct pci_dev to keep track.
A Root Port's Link is always on the Port's secondary side. A component
(Endpoint or Port) on the other end of the Link obviously has the Link on
its upstream side. If that component is a Port, it is part of a Switch or
a Bridge. A Bridge has a PCI or PCI-X bus on its secondary side, not a
Link. The internal bus of a Switch connects the Port to another Port whose
Link is on the downstream side.
[bhelgaas: changelog, comment, cache "type", use if/else]
Link: http://lkml.kernel.org/r/54EB81B2.4050904@pobox.com
Link: https://bugzilla.kernel.org/show_bug.cgi?id=94361
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
[ Upstream commit f33798deecbd59a2955f40ac0ae2bc7dff54c069 ]
commit 9ce119f318ba ("tty: Fix GPF in flush_to_ldisc()") fixed a
GPF caused by a line discipline which does not define a receive_buf()
method.
However, the vt driver (and speakup driver also) pushes selection
data directly to the line discipline receive_buf() method via
tty_ldisc_receive_buf(). Fix the same problem in tty_ldisc_receive_buf().
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
[ Upstream commit 8a5e5e02fc83aaf67053ab53b359af08c6c49aaf ]
Poison pointer values should be small enough to find a room in
non-mmap'able/hardly-mmap'able space. E.g. on x86 "poison pointer space"
is located starting from 0x0. Given unprivileged users cannot mmap
anything below mmap_min_addr, it should be safe to use poison pointers
lower than mmap_min_addr.
The current poison pointer values of LIST_POISON{1,2} might be too big for
mmap_min_addr values equal or less than 1 MB (common case, e.g. Ubuntu
uses only 0x10000). There is little point to use such a big value given
the "poison pointer space" below 1 MB is not yet exhausted. Changing it
to a smaller value solves the problem for small mmap_min_addr setups.
The values are suggested by Solar Designer:
http://www.openwall.com/lists/oss-security/2015/05/02/6
Signed-off-by: Vasily Kulikov <segoon@openwall.com>
Cc: Solar Designer <solar@openwall.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
[ Upstream commit 8244062ef1e54502ef55f54cced659913f244c3e ]
For CONFIG_KALLSYMS, we keep two symbol tables and two string tables.
There's one full copy, marked SHF_ALLOC and laid out at the end of the
module's init section. There's also a cut-down version that only
contains core symbols and strings, and lives in the module's core
section.
After module init (and before we free the module memory), we switch
the mod->symtab, mod->num_symtab and mod->strtab to point to the core
versions. We do this under the module_mutex.
However, kallsyms doesn't take the module_mutex: it uses
preempt_disable() and rcu tricks to walk through the modules, because
it's used in the oops path. It's also used in /proc/kallsyms.
There's nothing atomic about the change of these variables, so we can
get the old (larger!) num_symtab and the new symtab pointer; in fact
this is what I saw when trying to reproduce.
By grouping these variables together, we can use a
carefully-dereferenced pointer to ensure we always get one or the
other (the free of the module init section is already done in an RCU
callback, so that's safe). We allocate the init one at the end of the
module init section, and keep the core one inside the struct module
itself (it could also have been allocated at the end of the module
core, but that's probably overkill).
Reported-by: Weilong Chen <chenweilong@huawei.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111541
Cc: stable@kernel.org
[ Upstream commit 5e93b8208d3c419b515fb75e2601931c027e12ab ]
Previous implementation does not handle case below: boot up one MST branch
to DP connector of ASIC. After boot up, hot plug 2nd MST branch to DP output
of 1st MST, GUID is not created for 2nd MST branch. When downstream port of
2nd MST branch send upstream request, it fails because 2nd MST branch GUID
is not available.
New Implementation: only create GUID for MST branch and save it within Branch.
Signed-off-by: Hersen Wu <hersenxs.wu@amd.com>
Reviewed-by: Harry Wentland <harry.wentland@amd.com>
Acked-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 ]
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
[ Upstream commit 8282f5d9c17fe15a9e658c06e3f343efae1a2a2f ]
All the variables in this list so far are defined to be in the global
namespace in the UEFI spec, so this just further ensures we're
validating the variables we think we are.
Including the guid for entries will become more important in future
patches when we decide whether or not to allow deletion of variables
based on presence in this list.
[ Upstream commit 73500267c930baadadb0d02284909731baf151f7 ]
This adds ucs2_utf8size(), which tells us how big our ucs2 string is in
bytes, and ucs2_as_utf8, which translates from ucs2 to utf8..
[ Upstream commit e842f2903908934187af7232fb5b21da527d1757 ]
dax_fault() currently relies on the get_block callback to attach an
io completion callback to the mapping buffer head so that it can
run unwritten extent conversion after zeroing allocated blocks.
Instead of this hack, pass the conversion callback directly into
dax_fault() similar to the get_block callback. When the filesystem
allocates unwritten extents, it will set the buffer_unwritten()
flag, and hence the dax_fault code can call the completion function
in the contexts where it is necessary without overloading the
mapping buffer head.
Note: The changes to ext4 to use this interface are suspect at best.
In fact, the way ext4 did this end_io assignment in the first place
looks suspect because it only set a completion callback when there
wasn't already some other write() call taking place on the same
inode. The ext4 end_io code looks rather intricate and fragile with
all it's reference counting and passing to different contexts for
modification via inode private pointers that aren't protected by
locks...
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Dave Chinner <david@fromorbit.com>
[ Upstream commit caaee6234d05a58c5b4d05e7bf766131b810a657 ]
By checking the effective credentials instead of the real UID / permitted
capabilities, ensure that the calling process actually intended to use its
credentials.
To ensure that all ptrace checks use the correct caller credentials (e.g.
in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS
flag), use two new flags and require one of them to be set.
The problem was that when a privileged task had temporarily dropped its
privileges, e.g. by calling setreuid(0, user_uid), with the intent to
perform following syscalls with the credentials of a user, it still passed
ptrace access checks that the user would not be able to pass.
While an attacker should not be able to convince the privileged task to
perform a ptrace() syscall, this is a problem because the ptrace access
check is reused for things in procfs.
In particular, the following somewhat interesting procfs entries only rely
on ptrace access checks:
/proc/$pid/stat - uses the check for determining whether pointers
should be visible, useful for bypassing ASLR
/proc/$pid/maps - also useful for bypassing ASLR
/proc/$pid/cwd - useful for gaining access to restricted
directories that contain files with lax permissions, e.g. in
this scenario:
lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar
drwx------ root root /root
drwxr-xr-x root root /root/foobar
-rw-r--r-- root root /root/foobar/secret
Therefore, on a system where a root-owned mode 6755 binary changes its
effective credentials as described and then dumps a user-specified file,
this could be used by an attacker to reveal the memory layout of root's
processes or reveal the contents of files he is not allowed to access
(through /proc/$pid/cwd).
[akpm@linux-foundation.org: fix warning]
Cc: Casey Schaufler <casey@schaufler-ca.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Willy Tarreau <w@1wt.eu>
[ Upstream commit dc17147de328a74bbdee67c1bf37d2f1992de756 ]
Commit f37755490fe9b ("tracepoints: Do not trace when cpu is offline") added
a check to make sure that tracepoints only get called when the cpu is
online, as it uses rcu_read_lock_sched() for protection.
Commit 3a630178fd5f3 ("tracing: generate RCU warnings even when tracepoints
are disabled") added lockdep checks (including rcu checks) for events that
are not enabled to catch possible RCU issues that would only be triggered if
a trace event was enabled. Commit f37755490fe9b only stopped the warnings
when the trace event was enabled but did not prevent warnings if the trace
event was called when disabled.
To fix this, the cpu online check is moved to where the condition is added
to the trace event. This will place the cpu online check in all places that
it may be used now and in the future.
Cc: stable@vger.kernel.org # v3.18+
Fixes: f37755490fe9b ("tracepoints: Do not trace when cpu is offline")
Fixes: 3a630178fd5f3 ("tracing: generate RCU warnings even when tracepoints are disabled")
Reported-by: Sudeep Holla <sudeep.holla@arm.com>
Tested-by: Sudeep Holla <sudeep.holla@arm.com>
[ Upstream commit cb150b9d23be6ee7f3a0fff29784f1c5b5ac514d ]
Since cfg80211 frequently takes actions from its netdev notifier
call, wireless extensions messages could still be ordered badly
since the wext netdev notifier, since wext is built into the
kernel, runs before the cfg80211 netdev notifier. For example,
the following can happen:
5: wlan1: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default
link/ether 02:00:00:00:01:00 brd ff:ff:ff:ff:ff:ff
5: wlan1: <BROADCAST,MULTICAST,UP>
link/ether
when setting the interface down causes the wext message.
To also fix this, export the wireless_nlevent_flush() function
and also call it from the cfg80211 notifier.
[ Upstream commit a528aca7f359f4b0b1d72ae406097e491a5ba9ea ]
Games with ordering and barriers are way too brittle. Just
bump ->d_seq before and after updating ->d_inode and ->d_flags
type bits, so that verifying ->d_seq would guarantee they are
coherent.
Cc: stable@vger.kernel.org # v3.13+
[ Upstream commit a7c6f571ff51cc77d90dd54968f7c5c938c43998 ]
I'll shortly be introducing another seqcount primitive that's useful
to provide ordering semantics and would like to use the
write_seqcount_barrier() name for that.
Seeing how there's only one user of the current primitive, lets rename
it to invalidate, as that appears what its doing.
While there, employ lockdep_assert_held() instead of
assert_spin_locked() to not generate debug code for regular kernels.
Cc: ktkhai@parallels.com
Cc: rostedt@goodmis.org
Cc: juri.lelli@gmail.com
Cc: pang.xunlei@linaro.org
Cc: wanpeng.li@linux.intel.com
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: umgwanakikbuti@gmail.com
Link: http://lkml.kernel.org/r/20150611124743.279926217@infradead.org
[ Upstream commit 4ee34ea3a12396f35b26d90a094c75db95080baa ]
The id buffer in ata_device is a DMA target, but it isn't explicitly
cacheline aligned. Due to this, adjacent fields can be overwritten with
stale data from memory on non coherent architectures. As a result, the
kernel is sometimes unable to communicate with an ATA device.
Fix this by ensuring that the id buffer is cacheline aligned.
This issue is similar to that fixed by Commit 84bda12af31f
("libata: align ap->sector_buf").
Signed-off-by: Harvey Hunt <harvey.hunt@imgtec.com>
Cc: <stable@vger.kernel.org> # 2.6.18
[ Upstream commit 287e6611ab1eac76c2c5ebf6e345e04c80ca9c61 ]
As reported by Soohoon Lee, the HDIO_GET_32BIT ioctl does not
work correctly in compat mode with libata.
I have investigated the issue further and found multiple problems
that all appeared with the same commit that originally introduced
HDIO_GET_32BIT handling in libata back in linux-2.6.8 and presumably
also linux-2.4, as the code uses "copy_to_user(arg, &val, 1)" to copy
a 'long' variable containing either 0 or 1 to user space.
The problems with this are:
* On big-endian machines, this will always write a zero because it
stores the wrong byte into user space.
* In compat mode, the upper three bytes of the variable are updated
by the compat_hdio_ioctl() function, but they now contain
uninitialized stack data.
* The hdparm tool calling this ioctl uses a 'static long' variable
to store the result. This means at least the upper bytes are
initialized to zero, but calling another ioctl like HDIO_GET_MULTCOUNT
would fill them with data that remains stale when the low byte
is overwritten. Fortunately libata doesn't implement any of the
affected ioctl commands, so this would only happen when we query
both an IDE and an ATA device in the same command such as
"hdparm -N -c /dev/hda /dev/sda"
* The libata code for unknown reasons started using ATA_IOC_GET_IO32
and ATA_IOC_SET_IO32 as aliases for HDIO_GET_32BIT and HDIO_SET_32BIT,
while the ioctl commands that were added later use the normal
HDIO_* names. This is harmless but rather confusing.
This addresses all four issues by changing the code to use put_user()
on an 'unsigned long' variable in HDIO_GET_32BIT, like the IDE subsystem
does, and by clarifying the names of the ioctl commands.
Reported-by: Soohoon Lee <Soohoon.Lee@f5.com>
Tested-by: Soohoon Lee <Soohoon.Lee@f5.com>
[ Upstream commit 50ab8ec74a153eb30db26529088bc57dd700b24c ]
See http: //www.infradead.org/rpr.html
X-Evolution-Source: 1451162204.2173.11@leira.trondhjem.org
Content-Transfer-Encoding: 8bit
Mime-Version: 1.0
We support OFFSET_MAX just fine, so don't round down below it. Also
switch to using min_t to make the helper more readable.
Fixes: 433c92379d9c ("NFS: Clean up nfs_size_to_loff_t()")
Cc: stable@vger.kernel.org # 2.6.23+
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 0f4a943168f31d29a1701908931acaba518b131a upstream.
To address the bug where fabric driver level shutdown
of se_cmd occurs at the same time when TMR CMD_T_ABORTED
is happening resulting in a -1 ->cmd_kref, this patch
adds a CMD_T_FABRIC_STOP bit that is used to determine
when TMR + driver I_T nexus shutdown is happening
concurrently.
It changes target_sess_cmd_list_set_waiting() to obtain
se_cmd->cmd_kref + set CMD_T_FABRIC_STOP, and drop local
reference in target_wait_for_sess_cmds() and invoke extra
target_put_sess_cmd() during Task Aborted Status (TAS)
when necessary.
Also, it adds a new target_wait_free_cmd() wrapper around
transport_wait_for_tasks() for the special case within
transport_generic_free_cmd() to set CMD_T_FABRIC_STOP,
and is now aware of CMD_T_ABORTED + CMD_T_TAS status
bits to know when an extra transport_put_cmd() during
TAS is required.
Note transport_generic_free_cmd() is expected to block on
cmd->cmd_wait_comp in order to follow what iscsi-target
expects during iscsi_conn context se_cmd shutdown.
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Himanshu Madhani <himanshu.madhani@qlogic.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
Cc: Mike Christie <mchristi@redhat.com>
Signed-off-by: Nicholas Bellinger <nab@daterainc.com>
commit febe562c20dfa8f33bee7d419c6b517986a5aa33 upstream.
This patch fixes a NULL pointer se_cmd->cmd_kref < 0
refcount bug during TMR LUN_RESET with active se_cmd
I/O, that can be triggered during se_cmd descriptor
shutdown + release via core_tmr_drain_state_list() code.
To address this bug, add common __target_check_io_state()
helper for ABORT_TASK + LUN_RESET w/ CMD_T_COMPLETE
checking, and set CMD_T_ABORTED + obtain ->cmd_kref for
both cases ahead of last target_put_sess_cmd() after
TFO->aborted_task() -> transport_cmd_finish_abort()
callback has completed.
It also introduces SCF_ACK_KREF to determine when
transport_cmd_finish_abort() needs to drop the second
extra reference, ahead of calling target_put_sess_cmd()
for the final kref_put(&se_cmd->cmd_kref).
It also updates transport_cmd_check_stop() to avoid
holding se_cmd->t_state_lock while dropping se_cmd
device state via target_remove_from_state_list(), now
that core_tmr_drain_state_list() is holding the
se_device lock while checking se_cmd state from
within TMR logic.
Finally, move transport_put_cmd() release of SGL +
TMR + extended CDB memory into target_free_cmd_mem()
in order to avoid potential resource leaks in TMR
ABORT_TASK + LUN_RESET code-paths. Also update
target_release_cmd_kref() accordingly.
Reviewed-by: Quinn Tran <quinn.tran@qlogic.com>
[ Upstream commit 057085e522f8bf94c2e691a5b76880f68060f8ba ]
This patch addresses a race + use after free where the first
stage of COMPARE_AND_WRITE in compare_and_write_callback()
is rescheduled after the backend sends the secondary WRITE,
resulting in second stage compare_and_write_post() callback
completing in target_complete_ok_work() before the first
can return.
Because current code depends on checking se_cmd->se_cmd_flags
after return from se_cmd->transport_complete_callback(),
this results in first stage having SCF_COMPARE_AND_WRITE_POST
set, which incorrectly falls through into second stage CAW
processing code, eventually triggering a NULL pointer
dereference due to use after free.
To address this bug, pass in a new *post_ret parameter into
se_cmd->transport_complete_callback(), and depend upon this
value instead of ->se_cmd_flags to determine when to return
or fall through into ->queue_status() code for CAW.
[ Upstream commit deed49df7390d5239024199e249190328f1651e7 ]
Since the gc of ipv4 route was removed, the route cached would has
no chance to be removed, and even it has been timeout, it still could
be used, cause no code to check it's expires.
Fix this issue by checking and removing route cache when we get route.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 5f74f82ea34c0da80ea0b49192bb5ea06e063593 ]
Devices may have limits on the number of fragments in an skb they support.
Current codebase uses a constant as maximum for number of fragments one
skb can hold and use.
When enabling scatter/gather and running traffic with many small messages
the codebase uses the maximum number of fragments and may thereby violate
the max for certain devices.
The patch introduces a global variable as max number of fragments.
Signed-off-by: Hans Westgaard Ry <hans.westgaard.ry@oracle.com>
Reviewed-by: Håkon Bugge <haakon.bugge@oracle.com>
[ Upstream commit 415e3d3e90ce9e18727e8843ae343eda5a58fad6 ]
The commit referenced in the Fixes tag incorrectly accounted the number
of in-flight fds over a unix domain socket to the original opener
of the file-descriptor. This allows another process to arbitrary
deplete the original file-openers resource limit for the maximum of
open files. Instead the sending processes and its struct cred should
be credited.
To do so, we add a reference counted struct user_struct pointer to the
scm_fp_list and use it to account for the number of inflight unix fds.
Fixes: 712f4aad406bb1 ("unix: properly account for FDs passed over unix sockets")
Reported-by: David Herrmann <dh.herrmann@gmail.com>
Cc: David Herrmann <dh.herrmann@gmail.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
[ Upstream commit 8013d1d7eafb0589ca766db6b74026f76b7f5cb4 ]
Commit 6fd99094de2b ("ipv6: Don't reduce hop limit for an interface")
disabled accept hop limit from RA if it is smaller than the current hop
limit for security stuff. But this behavior kind of break the RFC definition.
RFC 4861, 6.3.4. Processing Received Router Advertisements
A Router Advertisement field (e.g., Cur Hop Limit, Reachable Time,
and Retrans Timer) may contain a value denoting that it is
unspecified. In such cases, the parameter should be ignored and the
host should continue using whatever value it is already using.
If the received Cur Hop Limit value is non-zero, the host SHOULD set
its CurHopLimit variable to the received value.
So add sysctl option accept_ra_min_hop_limit to let user choose the minimum
hop limit value they can accept from RA. And set default to 1 to meet RFC
standards.
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Acked-by: YOSHIFUJI Hideaki <hideaki.yoshifuji@miraclelinux.com>
[ Upstream commit 6f21c96a78b835259546d8f3fb4edff0f651d478 ]
The current implementation of ip6_dst_lookup_tail basically
ignore the egress ifindex match: if the saddr is set,
ip6_route_output() purposefully ignores flowi6_oif, due
to the commit d46a9d678e4c ("net: ipv6: Dont add RT6_LOOKUP_F_IFACE
flag if saddr set"), if the saddr is 'any' the first route lookup
in ip6_dst_lookup_tail fails, but upon failure a second lookup will
be performed with saddr set, thus ignoring the ifindex constraint.
This commit adds an output route lookup function variant, which
allows the caller to specify lookup flags, and modify
ip6_dst_lookup_tail() to enforce the ifindex match on the second
lookup via said helper.
ip6_route_output() becames now a static inline function build on
top of ip6_route_output_flags(); as a side effect, out-of-tree
modules need now a GPL license to access the output route lookup
functionality.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit b33c8ff4431a343561e2319f17c14286f2aa52e2 ]
In my randconfig tests, I came across a bug that involves several
components:
* gcc-4.9 through at least 5.3
* CONFIG_GCOV_PROFILE_ALL enabling -fprofile-arcs for all files
* CONFIG_PROFILE_ALL_BRANCHES overriding every if()
* The optimized implementation of do_div() that tries to
replace a library call with an division by multiplication
* code in drivers/media/dvb-frontends/zl10353.c doing
u32 adc_clock = 450560; /* 45.056 MHz */
if (state->config.adc_clock)
adc_clock = state->config.adc_clock;
do_div(value, adc_clock);
In this case, gcc fails to determine whether the divisor
in do_div() is __builtin_constant_p(). In particular, it
concludes that __builtin_constant_p(adc_clock) is false, while
__builtin_constant_p(!!adc_clock) is true.
That in turn throws off the logic in do_div() that also uses
__builtin_constant_p(), and instead of picking either the
constant- optimized division, and the code in ilog2() that uses
__builtin_constant_p() to figure out whether it knows the answer at
compile time. The result is a link error from failing to find
multiple symbols that should never have been called based on
the __builtin_constant_p():
dvb-frontends/zl10353.c:138: undefined reference to `____ilog2_NaN'
dvb-frontends/zl10353.c:138: undefined reference to `__aeabi_uldivmod'
ERROR: "____ilog2_NaN" [drivers/media/dvb-frontends/zl10353.ko] undefined!
ERROR: "__aeabi_uldivmod" [drivers/media/dvb-frontends/zl10353.ko] undefined!
This patch avoids the problem by changing __trace_if() to check
whether the condition is known at compile-time to be nonzero, rather
than checking whether it is actually a constant.
I see this one link error in roughly one out of 1600 randconfig builds
on ARM, and the patch fixes all known instances.
Link: http://lkml.kernel.org/r/1455312410-1058841-1-git-send-email-arnd@arndb.de
Acked-by: Nicolas Pitre <nico@linaro.org>
Fixes: ab3c9c686e22 ("branch tracer, intel-iommu: fix build with CONFIG_BRANCH_TRACER=y")
Cc: stable@vger.kernel.org # v2.6.30+
[ Upstream commit f37755490fe9bf76f6ba1d8c6591745d3574a6a6 ]
The tracepoint infrastructure uses RCU sched protection to enable and
disable tracepoints safely. There are some instances where tracepoints are
used in infrastructure code (like kfree()) that get called after a CPU is
going offline, and perhaps when it is coming back online but hasn't been
registered yet.
This can probuce the following warning:
[ INFO: suspicious RCU usage. ]
4.4.0-00006-g0fe53e8-dirty #34 Tainted: G S
include/trace/events/kmem.h:141 suspicious rcu_dereference_check() usage!
RCU used illegally from offline CPU! rcu_scheduler_active = 1, debug_locks = 1
no locks held by swapper/8/0.
stack backtrace:
CPU: 8 PID: 0 Comm: swapper/8 Tainted: G S 4.4.0-00006-g0fe53e8-dirty #34
Call Trace:
[c0000005b76c78d0] [c0000000008b9540] .dump_stack+0x98/0xd4 (unreliable)
[c0000005b76c7950] [c00000000010c898] .lockdep_rcu_suspicious+0x108/0x170
[c0000005b76c79e0] [c00000000029adc0] .kfree+0x390/0x440
[c0000005b76c7a80] [c000000000055f74] .destroy_context+0x44/0x100
[c0000005b76c7b00] [c0000000000934a0] .__mmdrop+0x60/0x150
[c0000005b76c7b90] [c0000000000e3ff0] .idle_task_exit+0x130/0x140
[c0000005b76c7c20] [c000000000075804] .pseries_mach_cpu_die+0x64/0x310
[c0000005b76c7cd0] [c000000000043e7c] .cpu_die+0x3c/0x60
[c0000005b76c7d40] [c0000000000188d8] .arch_cpu_idle_dead+0x28/0x40
[c0000005b76c7db0] [c000000000101e6c] .cpu_startup_entry+0x50c/0x560
[c0000005b76c7ed0] [c000000000043bd8] .start_secondary+0x328/0x360
[c0000005b76c7f90] [c000000000008a6c] start_secondary_prolog+0x10/0x14
This warning is not a false positive either. RCU is not protecting code that
is being executed while the CPU is offline.
Instead of playing "whack-a-mole(TM)" and adding conditional statements to
the tracepoints we find that are used in this instance, simply add a
cpu_online() test to the tracepoint code where the tracepoint will be
ignored if the CPU is offline.
Use of raw_smp_processor_id() is fine, as there should never be a case where
the tracepoint code goes from running on a CPU that is online and suddenly
gets migrated to a CPU that is offline.
Link: http://lkml.kernel.org/r/1455387773-4245-1-git-send-email-kda@linux-powerpc.org
Reported-by: Denis Kirjanov <kda@linux-powerpc.org>
Fixes: 97e1c18e8d17b ("tracing: Kernel Tracepoints")
Cc: stable@vger.kernel.org # v2.6.28+
[ Upstream commit 1f55c718c290616889c04946864a13ef30f64929 ]
Considering current pty code and multiple devpts instances, it's possible
to umount a devpts file system while a program still has /dev/tty opened
pointing to a previosuly closed pty pair in that instance. In the case all
ptmx and pts/N files are closed, umount can be done. If the program closes
/dev/tty after umount is done, devpts_kill_index will use now an invalid
super_block, which was already destroyed in the umount operation after
running ->kill_sb. This is another "use after free" type of issue, but now
related to the allocated super_block instance.
To avoid the problem (warning at ida_remove and potential crashes) for
this specific case, I added two functions in devpts which grabs additional
references to the super_block, which pty code now uses so it makes sure
the super block structure is still valid until pty shutdown is done.
I also moved the additional inode references to the same functions, which
also covered similar case with inode being freed before /dev/tty final
close/shutdown.
Signed-off-by: Herton R. Krzesinski <herton@redhat.com>
Cc: stable@vger.kernel.org # 2.6.29+
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
[ Upstream commit afc16604c06414223478df3e42301ab630b9960a ]
The first argument of these two functions is always identical
to se_cmd->se_sess. Hence remove the first argument.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Cc: <qla2xxx-upstream@qlogic.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 0f26922fe5dc5724b1adbbd54b21bad03590b4f3 ]
The datatype __kernel_time_t is u32 on 32bit platform, so its subject to
overflows in the timeval/timespec to cputime conversion.
Currently the following functions are affected:
1. setitimer()
2. timer_create/timer_settime()
3. sys_clock_nanosleep
This can happen on MIPS32 and ARM32 with "Full dynticks CPU time accounting"
enabled, which is required for CONFIG_NO_HZ_FULL.
Enforce u64 conversion to prevent the overflow.
Fixes: 31c1fc818715 ("ARM: Kconfig: allow full nohz CPU accounting")
Signed-off-by: zengtao <prime.zeng@huawei.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Cc: <fweisbec@gmail.com>
Link: http://lkml.kernel.org/r/1454384314-154784-1-git-send-email-prime.zeng@huawei.com
[ Upstream commit aa226ff4a1ce79f229c6b7a4c0a14e17fececd01 ]
There are three subsystem callbacks in css shutdown path -
css_offline(), css_released() and css_free(). Except for
css_released(), cgroup core didn't guarantee the order of invocation.
css_offline() or css_free() could be called on a parent css before its
children. This behavior is unexpected and led to bugs in cpu and
memory controller.
This patch updates offline path so that a parent css is never offlined
before its children. Each css keeps online_cnt which reaches zero iff
itself and all its children are offline and offline_css() is invoked
only after online_cnt reaches zero.
This fixes the memory controller bug and allows the fix for cpu
controller.
Reported-and-tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reported-by: Brian Christiansen <brian.o.christiansen@gmail.com>
Link: http://lkml.kernel.org/g/5698A023.9070703@de.ibm.com
Link: http://lkml.kernel.org/g/CAKB58ikDkzc8REt31WBkD99+hxNzjK4+FBmhkgS+NVrC9vjMSg@mail.gmail.com
[ Upstream commit b4a04ab7a37b490cad48e69abfe14288cacb669c ]
From 2d728f74bfc071df06773e2fd7577dd5dab6425d Mon Sep 17 00:00:00 2001
Date: Wed, 13 May 2015 15:37:01 -0400
This patch separates out cgroup-defs.h from cgroup.h which has grown a
lot of dependencies. cgroup-defs.h currently only contains constant
and type definitions and can be used to break circular include
dependency. While moving, definitions are reordered so that
cgroup-defs.h has consistent logical structure.
This patch is pure reorganization.
[ Upstream commit 732042821cfa106b3c20b9780e4c60fee9d68900 ]
Helper radix_tree_iter_retry() resets next_index to the current index.
In following radix_tree_next_slot current chunk size becomes zero. This
isn't checked and it tries to dereference null pointer in slot.
Tagged iterator is fine because retry happens only at slot 0 where tag
bitmask in iter->tags is filled with single bit.
Fixes: 46437f9a554f ("radix-tree: fix race in gang lookup")
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Jeremiah Mahler <jmmahler@gmail.com>
[ Upstream commit 12352d3cae2cebe18805a91fab34b534d7444231 ]
Sequence vma_lock_anon_vma() - vma_unlock_anon_vma() isn't safe if
anon_vma appeared between lock and unlock. We have to check anon_vma
first or call anon_vma_prepare() to be sure that it's here. There are
only few users of these legacy helpers. Let's get rid of them.
This patch fixes anon_vma lock imbalance in validate_mm(). Write lock
isn't required here, read lock is enough.
And reorders expand_downwards/expand_upwards: security_mmap_addr() and
wrapping-around check don't have to be under anon vma lock.
Link: https://lkml.kernel.org/r/CACT4Y+Y908EjM2z=706dv4rV6dWtxTLK9nFg9_7DhRMLppBo2g@mail.gmail.com
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
[ Upstream commit 4772ff03df8094fd99d28de5fcf5df3a3e9c68bb ]
The port is removed synchronously, but the connector delayed.
This causes a use after free which can cause a kernel BUG with
slug_debug=FPZU. This is fixed by freeing the port after the
connector.
This fixes a regression introduced with
6b8eeca65b18ae77e175cc2b6571731f0ee413bf
"drm/dp/mst: close deadlock in connector destruction."
Cc: Dave Airlie <airlied@redhat.com>
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
[ Upstream commit 64566b5e767f9bc3161055ca1b443a51afb52aad ]
drm_fixp_from_fraction allows us to create a fixed point directly
from a fraction, rather than creating fixed point values and dividing
later. This avoids overflow of our 64 bit value for large numbers.
drm_fixp2int_ceil allows us to return the ceiling of our fixed point
value.
[airlied: squash Jordan's fix]
32-bit-build-fix: Jordan Lazare <Jordan.Lazare@amd.com>
Signed-off-by: Harry Wentland <harry.wentland@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 46437f9a554fbe3e110580ca08ab703b59f2f95a ]
If the indirect_ptr bit is set on a slot, that indicates we need to redo
the lookup. Introduce a new function radix_tree_iter_retry() which
forces the loop to retry the lookup by setting 'slot' to NULL and
turning the iterator back to point at the problematic entry.
This is a pretty rare problem to hit at the moment; the lookup has to
race with a grow of the radix tree from a height of 0. The consequences
of hitting this race are that gang lookup could return a pointer to a
radix_tree_node instead of a pointer to whatever the user had inserted
in the tree.
Fixes: cebbd29e1c2f ("radix-tree: rewrite gang lookup using iterator")
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
[ Upstream commit 06ab30034ed9c200a570ab13c017bde248ddb2a6 ]
A kernel WARNING in snd_rawmidi_transmit_ack() is triggered by
syzkaller fuzzer:
WARNING: CPU: 1 PID: 20739 at sound/core/rawmidi.c:1136
Call Trace:
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffff82999e2d>] dump_stack+0x6f/0xa2 lib/dump_stack.c:50
[<ffffffff81352089>] warn_slowpath_common+0xd9/0x140 kernel/panic.c:482
[<ffffffff813522b9>] warn_slowpath_null+0x29/0x30 kernel/panic.c:515
[<ffffffff84f80bd5>] snd_rawmidi_transmit_ack+0x275/0x400 sound/core/rawmidi.c:1136
[<ffffffff84fdb3c1>] snd_virmidi_output_trigger+0x4b1/0x5a0 sound/core/seq/seq_virmidi.c:163
[< inline >] snd_rawmidi_output_trigger sound/core/rawmidi.c:150
[<ffffffff84f87ed9>] snd_rawmidi_kernel_write1+0x549/0x780 sound/core/rawmidi.c:1223
[<ffffffff84f89fd3>] snd_rawmidi_write+0x543/0xb30 sound/core/rawmidi.c:1273
[<ffffffff817b0323>] __vfs_write+0x113/0x480 fs/read_write.c:528
[<ffffffff817b1db7>] vfs_write+0x167/0x4a0 fs/read_write.c:577
[< inline >] SYSC_write fs/read_write.c:624
[<ffffffff817b50a1>] SyS_write+0x111/0x220 fs/read_write.c:616
[<ffffffff86336c36>] entry_SYSCALL_64_fastpath+0x16/0x7a arch/x86/entry/entry_64.S:185
Also a similar warning is found but in another path:
Call Trace:
[<ffffffff82be2c0d>] dump_stack+0x6f/0xa2 lib/dump_stack.c:50
[<ffffffff81355139>] warn_slowpath_common+0xd9/0x140 kernel/panic.c:482
[<ffffffff81355369>] warn_slowpath_null+0x29/0x30 kernel/panic.c:515
[<ffffffff8527e69a>] rawmidi_transmit_ack+0x24a/0x3b0 sound/core/rawmidi.c:1133
[<ffffffff8527e851>] snd_rawmidi_transmit_ack+0x51/0x80 sound/core/rawmidi.c:1163
[<ffffffff852d9046>] snd_virmidi_output_trigger+0x2b6/0x570 sound/core/seq/seq_virmidi.c:185
[<ffffffff85285a0b>] snd_rawmidi_kernel_write1+0x4bb/0x760 sound/core/rawmidi.c:1252
[<ffffffff85287b73>] snd_rawmidi_write+0x543/0xb30 sound/core/rawmidi.c:1302
[<ffffffff817ba5f3>] __vfs_write+0x113/0x480 fs/read_write.c:528
[<ffffffff817bc087>] vfs_write+0x167/0x4a0 fs/read_write.c:577
[<ffffffff817bf371>] SyS_write+0x111/0x220 fs/read_write.c:616
[<ffffffff86660276>] entry_SYSCALL_64_fastpath+0x16/0x7a arch/x86/entry/entry_64.S:185
In the former case, the reason is that virmidi has an open code
calling snd_rawmidi_transmit_ack() with the value calculated outside
the spinlock. We may use snd_rawmidi_transmit() in a loop just for
consuming the input data, but even there, there is a race between
snd_rawmidi_transmit_peek() and snd_rawmidi_tranmit_ack().
Similarly in the latter case, it calls snd_rawmidi_transmit_peek() and
snd_rawmidi_tranmit_ack() separately without protection, so they are
racy as well.
The patch tries to address these issues by the following ways:
- Introduce the unlocked versions of snd_rawmidi_transmit_peek() and
snd_rawmidi_transmit_ack() to be called inside the explicit lock.
- Rewrite snd_rawmidi_transmit() to be race-free (the former case).
- Make the split calls (the latter case) protected in the rawmidi spin
lock.
BugLink: http://lkml.kernel.org/r/CACT4Y+YPq1+cYLkadwjWa5XjzF1_Vki1eHnVn-Lm0hzhSpu5PA@mail.gmail.com
BugLink: http://lkml.kernel.org/r/CACT4Y+acG4iyphdOZx47Nyq_VHGbpJQK-6xNpiqUjaZYqsXOGw@mail.gmail.com
Tested-by: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit 4b0e4e4af6c6dc8354dcb72182d52c1bc55f12fc ]
Reviewed-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
