commit 3243367b209faed5c320a4e5f9a565ee2a2ba958 upstream.
Some USB 2.0 devices erroneously report millisecond values in
bInterval. The generic config code manages to catch most of them,
but in some cases it's not completely enough.
The case at stake here is a USB 2.0 braille device, which wants to
announce 10ms and thus sets bInterval to 10, but with the USB 2.0
computation that yields to 64ms. It happens that one can type fast
enough to reach this interval and get the device buffers overflown,
leading to problematic latencies. The generic config code does not
catch this case because the 64ms is considered a sane enough value.
This change thus adds a USB_QUIRK_LINEAR_FRAME_INTR_BINTERVAL quirk
to mark devices which actually report milliseconds in bInterval,
and marks Vario Ultra devices as needing it.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 6f8830f5bbab16e54f261de187f3df4644a5b977 upstream.
There's a rather long standing regression from the commit "libiscsi:
Reduce locking contention in fast path"
Depending on iSCSI target behavior, it's possible to hit the case in
iscsi_complete_task where the task is still on a pending list
(!list_empty(&task->running)). When that happens the task is removed
from the list while holding the session back_lock, but other task list
modification occur under the frwd_lock. That leads to linked list
corruption and eventually a panicked system.
Rather than back out the session lock split entirely, in order to try
and keep some of the performance gains this patch adds another lock to
maintain the task lists integrity.
Major enterprise supported kernels have been backing out the lock split
for while now, thanks to the efforts at IBM where a lab setup has the
most reliable reproducer I've seen on this issue. This patch has been
tested there successfully.
Signed-off-by: Chris Leech <cleech@redhat.com>
Fixes: 659743b02c41 ("[SCSI] libiscsi: Reduce locking contention in fast path")
Reported-by: Prashantha Subbarao <psubbara@us.ibm.com>
Reviewed-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c upstream.
gcc-7 has an "optimization" pass that completely screws up, and
generates the code expansion for the (impossible) case of calling
ilog2() with a zero constant, even when the code gcc compiles does not
actually have a zero constant.
And we try to generate a compile-time error for anybody doing ilog2() on
a constant where that doesn't make sense (be it zero or negative). So
now gcc7 will fail the build due to our sanity checking, because it
created that constant-zero case that didn't actually exist in the source
code.
There's a whole long discussion on the kernel mailing about how to work
around this gcc bug. The gcc people themselevs have discussed their
"feature" in
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785
but it's all water under the bridge, because while it looked at one
point like it would be solved by the time gcc7 was released, that was
not to be.
So now we have to deal with this compiler braindamage.
And the only simple approach seems to be to just delete the code that
tries to warn about bad uses of ilog2().
So now "ilog2()" will just return 0 not just for the value 1, but for
any non-positive value too.
It's not like I can recall anybody having ever actually tried to use
this function on any invalid value, but maybe the sanity check just
meant that such code never made it out in public.
Reported-by: Laura Abbott <labbott@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Jiri Slaby <jslaby@suse.cz>
commit feb26ac31a2a5cb88d86680d9a94916a6343e9e6 upstream.
The XHCI controller presents two USB buses to the system - one for USB2
and one for USB3. The hub init code (hub_port_init) is reentrant but
only locks one bus per thread, leading to a race condition failure when
two threads attempt to simultaneously initialise a USB2 and USB3 device:
[ 8.034843] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[ 13.183701] usb 3-3: device descriptor read/all, error -110
On a test system this failure occurred on 6% of all boots.
The call traces at the point of failure are:
Call Trace:
[<ffffffff81b9bab7>] schedule+0x37/0x90
[<ffffffff817da7cd>] usb_kill_urb+0x8d/0xd0
[<ffffffff8111e5e0>] ? wake_up_atomic_t+0x30/0x30
[<ffffffff817dafbe>] usb_start_wait_urb+0xbe/0x150
[<ffffffff817db10c>] usb_control_msg+0xbc/0xf0
[<ffffffff817d07de>] hub_port_init+0x51e/0xb70
[<ffffffff817d4697>] hub_event+0x817/0x1570
[<ffffffff810f3e6f>] process_one_work+0x1ff/0x620
[<ffffffff810f3dcf>] ? process_one_work+0x15f/0x620
[<ffffffff810f4684>] worker_thread+0x64/0x4b0
[<ffffffff810f4620>] ? rescuer_thread+0x390/0x390
[<ffffffff810fa7f5>] kthread+0x105/0x120
[<ffffffff810fa6f0>] ? kthread_create_on_node+0x200/0x200
[<ffffffff81ba183f>] ret_from_fork+0x3f/0x70
Call Trace:
[<ffffffff817fd36d>] xhci_setup_device+0x53d/0xa40
[<ffffffff817fd87e>] xhci_address_device+0xe/0x10
[<ffffffff817d047f>] hub_port_init+0x1bf/0xb70
[<ffffffff811247ed>] ? trace_hardirqs_on+0xd/0x10
Which results from the two call chains:
hub_port_init
usb_get_device_descriptor
usb_get_descriptor
usb_control_msg
usb_internal_control_msg
usb_start_wait_urb
usb_submit_urb / wait_for_completion_timeout / usb_kill_urb
hub_port_init
hub_set_address
xhci_address_device
xhci_setup_device
Mathias Nyman explains the current behaviour violates the XHCI spec:
hub_port_reset() will end up moving the corresponding xhci device slot
to default state.
As hub_port_reset() is called several times in hub_port_init() it
sounds reasonable that we could end up with two threads having their
xhci device slots in default state at the same time, which according to
xhci 4.5.3 specs still is a big no no:
"Note: Software shall not transition more than one Device Slot to the
Default State at a time"
So both threads fail at their next task after this.
One fails to read the descriptor, and the other fails addressing the
device.
Fix this in hub_port_init by locking the USB controller (instead of an
individual bus) to prevent simultaneous initialisation of both buses.
Fixes: 638139eb95d2 ("usb: hub: allow to process more usb hub events in parallel")
Link: https://lkml.org/lkml/2016/2/8/312
Link: https://lkml.org/lkml/2016/2/4/748
Signed-off-by: Chris Bainbridge <chris.bainbridge@gmail.com>
Cc: stable <stable@vger.kernel.org>
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
[sumits: minor merge conflict resolution for linux-4.4.y]
[ Upstream commit 745cb7f8a5de0805cade3de3991b7a95317c7c73 ]
Replace MAX_ADDR_LEN with its numeric value to fix the following
linux/packet_diag.h userspace compilation error:
/usr/include/linux/packet_diag.h:67:17: error: 'MAX_ADDR_LEN' undeclared here (not in a function)
__u8 pdmc_addr[MAX_ADDR_LEN];
This is not the first case in the UAPI where the numeric value
of MAX_ADDR_LEN is used instead of symbolic one, uapi/linux/if_link.h
already does the same:
$ grep MAX_ADDR_LEN include/uapi/linux/if_link.h
__u8 mac[32]; /* MAX_ADDR_LEN */
There are no UAPI headers besides these two that use MAX_ADDR_LEN.
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
Acked-by: Pavel Emelyanov <xemul@virtuozzo.com>
[ Upstream commit 62f8f4d9066c1c6f2474845d1ca7e2891f2ae3fd ]
Dmitry reported crashes in DCCP stack [1]
Problem here is that when I got rid of listener spinlock, I missed the
fact that DCCP stores a complex state in struct dccp_request_sock,
while TCP does not.
Since multiple cpus could access it at the same time, we need to add
protection.
[1]
BUG: KASAN: use-after-free in dccp_feat_activate_values+0x967/0xab0
net/dccp/feat.c:1541 at addr ffff88003713be68
Read of size 8 by task syz-executor2/8457
CPU: 2 PID: 8457 Comm: syz-executor2 Not tainted 4.10.0-rc7+ #127
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:15 [inline]
dump_stack+0x292/0x398 lib/dump_stack.c:51
kasan_object_err+0x1c/0x70 mm/kasan/report.c:162
print_address_description mm/kasan/report.c:200 [inline]
kasan_report_error mm/kasan/report.c:289 [inline]
kasan_report.part.1+0x20e/0x4e0 mm/kasan/report.c:311
kasan_report mm/kasan/report.c:332 [inline]
__asan_report_load8_noabort+0x29/0x30 mm/kasan/report.c:332
dccp_feat_activate_values+0x967/0xab0 net/dccp/feat.c:1541
dccp_create_openreq_child+0x464/0x610 net/dccp/minisocks.c:121
dccp_v6_request_recv_sock+0x1f6/0x1960 net/dccp/ipv6.c:457
dccp_check_req+0x335/0x5a0 net/dccp/minisocks.c:186
dccp_v6_rcv+0x69e/0x1d00 net/dccp/ipv6.c:711
ip6_input_finish+0x46d/0x17a0 net/ipv6/ip6_input.c:279
NF_HOOK include/linux/netfilter.h:257 [inline]
ip6_input+0xdb/0x590 net/ipv6/ip6_input.c:322
dst_input include/net/dst.h:507 [inline]
ip6_rcv_finish+0x289/0x890 net/ipv6/ip6_input.c:69
ipv6_rcv+0x12ec/0x23d0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x1ae5/0x3400 net/core/dev.c:4190
__netif_receive_skb+0x2a/0x170 net/core/dev.c:4228
process_backlog+0xe5/0x6c0 net/core/dev.c:4839
napi_poll net/core/dev.c:5202 [inline]
net_rx_action+0xe70/0x1900 net/core/dev.c:5267
__do_softirq+0x2fb/0xb7d kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902
</IRQ>
do_softirq.part.17+0x1e8/0x230 kernel/softirq.c:328
do_softirq kernel/softirq.c:176 [inline]
__local_bh_enable_ip+0x1f2/0x200 kernel/softirq.c:181
local_bh_enable include/linux/bottom_half.h:31 [inline]
rcu_read_unlock_bh include/linux/rcupdate.h:971 [inline]
ip6_finish_output2+0xbb0/0x23d0 net/ipv6/ip6_output.c:123
ip6_finish_output+0x302/0x960 net/ipv6/ip6_output.c:148
NF_HOOK_COND include/linux/netfilter.h:246 [inline]
ip6_output+0x1cb/0x8d0 net/ipv6/ip6_output.c:162
ip6_xmit+0xcdf/0x20d0 include/net/dst.h:501
inet6_csk_xmit+0x320/0x5f0 net/ipv6/inet6_connection_sock.c:179
dccp_transmit_skb+0xb09/0x1120 net/dccp/output.c:141
dccp_xmit_packet+0x215/0x760 net/dccp/output.c:280
dccp_write_xmit+0x168/0x1d0 net/dccp/output.c:362
dccp_sendmsg+0x79c/0xb10 net/dccp/proto.c:796
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744
sock_sendmsg_nosec net/socket.c:635 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:645
SYSC_sendto+0x660/0x810 net/socket.c:1687
SyS_sendto+0x40/0x50 net/socket.c:1655
entry_SYSCALL_64_fastpath+0x1f/0xc2
RIP: 0033:0x4458b9
RSP: 002b:00007f8ceb77bb58 EFLAGS: 00000282 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000000017 RCX: 00000000004458b9
RDX: 0000000000000023 RSI: 0000000020e60000 RDI: 0000000000000017
RBP: 00000000006e1b90 R08: 00000000200f9fe1 R09: 0000000000000020
R10: 0000000000008010 R11: 0000000000000282 R12: 00000000007080a8
R13: 0000000000000000 R14: 00007f8ceb77c9c0 R15: 00007f8ceb77c700
Object at ffff88003713be50, in cache kmalloc-64 size: 64
Allocated:
PID = 8446
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:57
save_stack+0x43/0xd0 mm/kasan/kasan.c:502
set_track mm/kasan/kasan.c:514 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:605
kmem_cache_alloc_trace+0x82/0x270 mm/slub.c:2738
kmalloc include/linux/slab.h:490 [inline]
dccp_feat_entry_new+0x214/0x410 net/dccp/feat.c:467
dccp_feat_push_change+0x38/0x220 net/dccp/feat.c:487
__feat_register_sp+0x223/0x2f0 net/dccp/feat.c:741
dccp_feat_propagate_ccid+0x22b/0x2b0 net/dccp/feat.c:949
dccp_feat_server_ccid_dependencies+0x1b3/0x250 net/dccp/feat.c:1012
dccp_make_response+0x1f1/0xc90 net/dccp/output.c:423
dccp_v6_send_response+0x4ec/0xc20 net/dccp/ipv6.c:217
dccp_v6_conn_request+0xaba/0x11b0 net/dccp/ipv6.c:377
dccp_rcv_state_process+0x51e/0x1650 net/dccp/input.c:606
dccp_v6_do_rcv+0x213/0x350 net/dccp/ipv6.c:632
sk_backlog_rcv include/net/sock.h:893 [inline]
__sk_receive_skb+0x36f/0xcc0 net/core/sock.c:479
dccp_v6_rcv+0xba5/0x1d00 net/dccp/ipv6.c:742
Freed:
PID = 15
kasan_slab_free+0x73/0xc0 mm/kasan/kasan.c:578
slab_free_hook mm/slub.c:1355 [inline]
slab_free_freelist_hook mm/slub.c:1377 [inline]
slab_free mm/slub.c:2954 [inline]
kfree+0xe8/0x2b0 mm/slub.c:3874
dccp_feat_entry_destructor.part.4+0x48/0x60 net/dccp/feat.c:418
dccp_feat_entry_destructor net/dccp/feat.c:416 [inline]
dccp_feat_list_pop net/dccp/feat.c:541 [inline]
dccp_feat_activate_values+0x57f/0xab0 net/dccp/feat.c:1543
Memory state around the buggy address:
ffff88003713bd00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88003713bd80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff88003713be00: fc fc fc fc fc fc fc fc fc fc fb fb fb fb fb fb
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit d1b4c689d4130bcfd3532680b64db562300716b6 upstream.
mmapped netlink has a number of unresolved issues:
- TX zerocopy support had to be disabled more than a year ago via
commit 4682a0358639b29cf ("netlink: Always copy on mmap TX.")
because the content of the mmapped area can change after netlink
attribute validation but before message processing.
- RX support was implemented mainly to speed up nfqueue dumping packet
payload to userspace. However, since commit ae08ce0021087a5d812d2
("netfilter: nfnetlink_queue: zero copy support") we avoid one copy
with the socket-based interface too (via the skb_zerocopy helper).
The other problem is that skbs attached to mmaped netlink socket
behave different from normal skbs:
- they don't have a shinfo area, so all functions that use skb_shinfo()
(e.g. skb_clone) cannot be used.
- reserving headroom prevents userspace from seeing the content as
it expects message to start at skb->head.
See for instance
commit aa3a022094fa ("netlink: not trim skb for mmaped socket when dump").
- skbs handed e.g. to netlink_ack must have non-NULL skb->sk, else we
crash because it needs the sk to check if a tx ring is attached.
Also not obvious, leads to non-intuitive bug fixes such as 7c7bdf359
("netfilter: nfnetlink: use original skbuff when acking batches").
mmaped netlink also didn't play nicely with the skb_zerocopy helper
used by nfqueue and openvswitch. Daniel Borkmann fixed this via
commit 6bb0fef489f6 ("netlink, mmap: fix edge-case leakages in nf queue
zero-copy")' but at the cost of also needing to provide remaining
length to the allocation function.
nfqueue also has problems when used with mmaped rx netlink:
- mmaped netlink doesn't allow use of nfqueue batch verdict messages.
Problem is that in the mmap case, the allocation time also determines
the ordering in which the frame will be seen by userspace (A
allocating before B means that A is located in earlier ring slot,
but this also means that B might get a lower sequence number then A
since seqno is decided later. To fix this we would need to extend the
spinlocked region to also cover the allocation and message setup which
isn't desirable.
- nfqueue can now be configured to queue large (GSO) skbs to userspace.
Queing GSO packets is faster than having to force a software segmentation
in the kernel, so this is a desirable option. However, with a mmap based
ring one has to use 64kb per ring slot element, else mmap has to fall back
to the socket path (NL_MMAP_STATUS_COPY) for all large packets.
To use the mmap interface, userspace not only has to probe for mmap netlink
support, it also has to implement a recv/socket receive path in order to
handle messages that exceed the size of an rx ring element.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Shi Yuejie <shiyuejie@outlook.com>
commit 86ef58a4e35e8fa66afb5898cf6dec6a3bb29f67 upstream.
The interleave-set cookie is a sum that sanity checks the composition of
an interleave set has not changed from when the namespace was initially
created. The checksum is calculated by sorting the DIMMs by their
location in the interleave-set. The comparison for the sort must be
64-bit wide, not byte-by-byte as performed by memcmp() in the broken
case.
Fix the implementation to accept correct cookie values in addition to
the Linux "memcmp" order cookies, but only allow correct cookies to be
generated going forward. It does mean that namespaces created by
third-party-tooling, or created by newer kernels with this fix, will not
validate on older kernels. However, there are a couple mitigating
conditions:
1/ platforms with namespace-label capable NVDIMMs are not widely
available.
2/ interleave-sets with a single-dimm are by definition not affected
(nothing to sort). This covers the QEMU-KVM NVDIMM emulation case.
The cookie stored in the namespace label will be fixed by any write the
namespace label, the most straightforward way to achieve this is to
write to the "alt_name" attribute of a namespace in sysfs.
Fixes: eaf961536e16 ("libnvdimm, nfit: add interleave-set state-tracking infrastructure")
Reported-by: Nicholas Moulin <nicholas.w.moulin@linux.intel.com>
Tested-by: Nicholas Moulin <nicholas.w.moulin@linux.intel.com>
commit bf7165cfa23695c51998231c4efa080fe1d3548d upstream.
There are several trace include files that define TRACE_INCLUDE_FILE.
Include several of them in the same .c file (as I currently have in
some code I am working on), and the compile will blow up with a
"warning: "TRACE_INCLUDE_FILE" redefined #define TRACE_INCLUDE_FILE syscalls"
Every other include file in include/trace/events/ avoids that issue
by having a #undef TRACE_INCLUDE_FILE before the #define; syscalls.h
should have one, too.
Link: http://lkml.kernel.org/r/20160928225554.13bd7ac6@annuminas.surriel.com
Fixes: b8007ef74222 ("tracing: Separate raw syscall from syscall tracer")
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit d24cdcd3e40a6825135498e11c20c7976b9bf545 upstream.
I ran into this compile warning, which is the result of BUG_ON(1)
not always leading to the compiler treating the code path as
unreachable:
include/linux/ceph/osdmap.h: In function 'ceph_can_shift_osds':
include/linux/ceph/osdmap.h:62:1: error: control reaches end of non-void function [-Werror=return-type]
Using BUG() here avoids the warning.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
commit 251af29c320d86071664f02c76f0d063a19fefdf upstream.
It is not sufficient to just check that the lock pids match when
granting a callback, we also need to ensure that we're granting
the callback on the right file.
Reported-by: Pankaj Singh <psingh.ait@gmail.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit bd4e2d2907fa23a11d46217064ecf80470ddae10 upstream.
When transport_clear_lun_ref() is shutting down a se_lun via
configfs with new I/O in-flight, it's possible to trigger a
NULL pointer dereference in transport_lookup_cmd_lun() due
to the fact percpu_ref_get() doesn't do any __PERCPU_REF_DEAD
checking before incrementing lun->lun_ref.count after
lun->lun_ref has switched to atomic_t mode.
This results in a NULL pointer dereference as LUN shutdown
code in core_tpg_remove_lun() continues running after the
existing ->release() -> core_tpg_lun_ref_release() callback
completes, and clears the RCU protected se_lun->lun_se_dev
pointer.
During the OOPs, the state of lun->lun_ref in the process
which triggered the NULL pointer dereference looks like
the following on v4.1.y stable code:
struct se_lun {
lun_link_magic = 4294932337,
lun_status = TRANSPORT_LUN_STATUS_FREE,
lun_se_dev = 0x0,
lun_sep = 0x0,
lun_ref = {
count = {
counter = 1
percpu_count_ptr = 3,
release = 0xffffffffa02fa1e0 <core_tpg_lun_ref_release>,
confirm_switch = 0x0,
force_atomic = false,
rcu = {
next = 0xffff88154fa1a5d0,
func = 0xffffffff8137c4c0 <percpu_ref_switch_to_atomic_rcu>
To address this bug, use percpu_ref_tryget_live() to ensure
once __PERCPU_REF_DEAD is visable on all CPUs and ->lun_ref
has switched to atomic_t, all new I/Os will fail to obtain
a new lun->lun_ref reference.
Also use an explicit percpu_ref_kill_and_confirm() callback
to block on ->lun_ref_comp to allow the first stage and
associated RCU grace period to complete, and then block on
->lun_ref_shutdown waiting for the final percpu_ref_put()
to drop the last reference via transport_lun_remove_cmd()
before continuing with core_tpg_remove_lun() shutdown.
Reported-by: Rob Millner <rlm@daterainc.com>
Tested-by: Rob Millner <rlm@daterainc.com>
Cc: Rob Millner <rlm@daterainc.com>
Tested-by: Vaibhav Tandon <vst@datera.io>
Cc: Vaibhav Tandon <vst@datera.io>
Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
commit 55efcfcd7776165b294f8b5cd6e05ca00ec89b7c upstream.
The RDMA core uses ib_pack() to convert from unpacked CPU structs
to on-the-wire bitpacked structs.
This process requires that 1 bit fields are declared as u8 in the
unpacked struct, otherwise the packing process does not read the
value properly and the packed result is wired to 0. Several
places wrongly used int.
Crucially this means the kernel has never, set reversible
correctly in the path record request. It has always asked for
irreversible paths even if the ULP requests otherwise.
When the kernel is used with a SM that supports this feature, it
completely breaks communication management if reversible paths are
not properly requested.
The only reason this ever worked is because opensm ignores the
reversible bit.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 01d4d673558985d9a118e1e05026633c3e2ade9b upstream.
This patch addresses a long-standing bug with multi-session
(eg: iscsi-target + iser-target) se_node_acl dynamic free
withini transport_deregister_session().
This bug is caused when a storage endpoint is configured with
demo-mode (generate_node_acls = 1 + cache_dynamic_acls = 1)
initiators, and initiator login creates a new dynamic node acl
and attaches two sessions to it.
After that, demo-mode for the storage instance is disabled via
configfs (generate_node_acls = 0 + cache_dynamic_acls = 0) and
the existing dynamic acl is never converted to an explicit ACL.
The end result is dynamic acl resources are released twice when
the sessions are shutdown in transport_deregister_session().
If the storage instance is not changed to disable demo-mode,
or the dynamic acl is converted to an explict ACL, or there
is only a single session associated with the dynamic ACL,
the bug is not triggered.
To address this big, move the release of dynamic se_node_acl
memory into target_complete_nacl() so it's only freed once
when se_node_acl->acl_kref reaches zero.
(Drop unnecessary list_del_init usage - HCH)
commit 21aaa23b0ebbd19334fa461370c03cbb076b3295 upstream.
This patch addresses a long standing race where obtaining
se_node_acl->acl_kref in __transport_register_session()
happens a bit too late, and leaves open the potential
for core_tpg_del_initiator_node_acl() to hit a NULL
pointer dereference.
Instead, take ->acl_kref in core_tpg_get_initiator_node_acl()
while se_portal_group->acl_node_mutex is held, and move the
final target_put_nacl() from transport_deregister_session()
into transport_free_session() so that fabric driver login
failure handling using the modern method to still work
as expected.
Also, update core_tpg_get_initiator_node_acl() to take
an extra reference for dynamically generated acls for
demo-mode, before returning to fabric caller. Also
update iscsi-target sendtargets special case handling
to use target_tpg_has_node_acl() when checking if
demo_mode_discovery == true during discovery lookup.
Note the existing wait_for_completion(&acl->acl_free_comp)
in core_tpg_del_initiator_node_acl() does not change.
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
commit 857de6e00778738dc3d61f75acbac35bdc48e533 upstream.
The device handler needs to check if a given queue belongs to a scsi
device; only then does it make sense to attach a device handler.
[mkp: dropped flags]
Signed-off-by: Hannes Reinecke <hare@suse.com>
commit aaa59306b0b7e0ca4ba92cc04c5db101cbb1c096 upstream.
Some of the macros are incorrect with wrong bit-shifts resulting in picking
the incorrect invalidation granularity. Incorrect Source-ID in extended
devtlb invalidation caused device side errors.
To: Joerg Roedel <joro@8bytes.org>
To: David Woodhouse <dwmw2@infradead.org>
Cc: iommu@lists.linux-foundation.org
Cc: CQ Tang <cq.tang@intel.com>
Cc: Ashok Raj <ashok.raj@intel.com>
Fixes: 2f26e0a9 ("iommu/vt-d: Add basic SVM PASID support")
Signed-off-by: CQ Tang <cq.tang@intel.com>
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Tested-by: CQ Tang <cq.tang@intel.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit e3f0a4017c2143b4b813df6a93e8cf79e3f76936 upstream.
The Atmel MPDDR controller support LPDDR2 and LPDDR3 memories, add their
types.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
[ Upstream commit 217e6fa24ce28ec87fca8da93c9016cb78028612 ]
The stack must not pass packets to device drivers that are shorter
than the minimum link layer header length.
Previously, packet sockets would drop packets smaller than or equal
to dev->hard_header_len, but this has false positives. Zero length
payload is used over Ethernet. Other link layer protocols support
variable length headers. Support for validation of these protocols
removed the min length check for all protocols.
Introduce an explicit dev->min_header_len parameter and drop all
packets below this value. Initially, set it to non-zero only for
Ethernet and loopback. Other protocols can follow in a patch to
net-next.
Fixes: 9ed988cd5915 ("packet: validate variable length ll headers")
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
[ Upstream commit d71b7896886345c53ef1d84bda2bc758554f5d61 ]
syzkaller found another out of bound access in ip_options_compile(),
or more exactly in cipso_v4_validate()
Fixes: 20e2a8648596 ("cipso: handle CIPSO options correctly when NetLabel is disabled")
Fixes: 446fda4f2682 ("[NetLabel]: CIPSOv4 engine")
Cc: Paul Moore <paul@paul-moore.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit f1712c73714088a7252d276a57126d56c7d37e64 ]
Zhang Yanmin reported crashes [1] and provided a patch adding a
synchronize_rcu() call in can_rx_unregister()
The main problem seems that the sockets themselves are not RCU
protected.
If CAN uses RCU for delivery, then sockets should be freed only after
one RCU grace period.
Recent kernels could use sock_set_flag(sk, SOCK_RCU_FREE), but let's
ease stable backports with the following fix instead.
[1]
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81495e25>] selinux_socket_sock_rcv_skb+0x65/0x2a0
Call Trace:
<IRQ>
[<ffffffff81485d8c>] security_sock_rcv_skb+0x4c/0x60
[<ffffffff81d55771>] sk_filter+0x41/0x210
[<ffffffff81d12913>] sock_queue_rcv_skb+0x53/0x3a0
[<ffffffff81f0a2b3>] raw_rcv+0x2a3/0x3c0
[<ffffffff81f06eab>] can_rcv_filter+0x12b/0x370
[<ffffffff81f07af9>] can_receive+0xd9/0x120
[<ffffffff81f07beb>] can_rcv+0xab/0x100
[<ffffffff81d362ac>] __netif_receive_skb_core+0xd8c/0x11f0
[<ffffffff81d36734>] __netif_receive_skb+0x24/0xb0
[<ffffffff81d37f67>] process_backlog+0x127/0x280
[<ffffffff81d36f7b>] net_rx_action+0x33b/0x4f0
[<ffffffff810c88d4>] __do_softirq+0x184/0x440
[<ffffffff81f9e86c>] do_softirq_own_stack+0x1c/0x30
<EOI>
[<ffffffff810c76fb>] do_softirq.part.18+0x3b/0x40
[<ffffffff810c8bed>] do_softirq+0x1d/0x20
[<ffffffff81d30085>] netif_rx_ni+0xe5/0x110
[<ffffffff8199cc87>] slcan_receive_buf+0x507/0x520
[<ffffffff8167ef7c>] flush_to_ldisc+0x21c/0x230
[<ffffffff810e3baf>] process_one_work+0x24f/0x670
[<ffffffff810e44ed>] worker_thread+0x9d/0x6f0
[<ffffffff810e4450>] ? rescuer_thread+0x480/0x480
[<ffffffff810ebafc>] kthread+0x12c/0x150
[<ffffffff81f9ccef>] ret_from_fork+0x3f/0x70
Reported-by: Zhang Yanmin <yanmin.zhang@intel.com>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
commit 4d59b6ccf000862beed6fc0765d3209f98a8d8a2 upstream.
Commit 513e3d2d11c9 ("cpumask: always use nr_cpu_ids in formatting and
parsing functions") converted both cpumask printing and parsing
functions to use nr_cpu_ids instead of nr_cpumask_bits. While this was
okay for the printing functions as it just picked one of the two output
formats that we were alternating between depending on a kernel config,
doing the same for parsing wasn't okay.
nr_cpumask_bits can be either nr_cpu_ids or NR_CPUS. We can always use
nr_cpu_ids but that is a variable while NR_CPUS is a constant, so it can
be more efficient to use NR_CPUS when we can get away with it.
Converting the printing functions to nr_cpu_ids makes sense because it
affects how the masks get presented to userspace and doesn't break
anything; however, using nr_cpu_ids for parsing functions can
incorrectly leave the higher bits uninitialized while reading in these
masks from userland. As all testing and comparison functions use
nr_cpumask_bits which can be larger than nr_cpu_ids, the parsed cpumasks
can erroneously yield false negative results.
This made the taskstats interface incorrectly return -EINVAL even when
the inputs were correct.
Fix it by restoring the parse functions to use nr_cpumask_bits instead
of nr_cpu_ids.
Link: http://lkml.kernel.org/r/20170206182442.GB31078@htj.duckdns.org
Fixes: 513e3d2d11c9 ("cpumask: always use nr_cpu_ids in formatting and parsing functions")
Reported-by: Martin Steigerwald <martin.steigerwald@teamix.de>
Debugged-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit a96dfddbcc04336bbed50dc2b24823e45e09e80c upstream.
Reading a sysfs "memoryN/valid_zones" file leads to the following oops
when the first page of a range is not backed by struct page.
show_valid_zones() assumes that 'start_pfn' is always valid for
page_zone().
BUG: unable to handle kernel paging request at ffffea017a000000
IP: show_valid_zones+0x6f/0x160
This issue may happen on x86-64 systems with 64GiB or more memory since
their memory block size is bumped up to 2GiB. [1] An example of such
systems is desribed below. 0x3240000000 is only aligned by 1GiB and
this memory block starts from 0x3200000000, which is not backed by
struct page.
BIOS-e820: [mem 0x0000003240000000-0x000000603fffffff] usable
Since test_pages_in_a_zone() already checks holes, fix this issue by
extending this function to return 'valid_start' and 'valid_end' for a
given range. show_valid_zones() then proceeds with the valid range.
[1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on
large-memory x86-64 systems")'
Link: http://lkml.kernel.org/r/20170127222149.30893-3-toshi.kani@hpe.com
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: <stable@vger.kernel.org> [4.4+]
commit 966d2b04e070bc040319aaebfec09e0144dc3341 upstream.
percpu_ref_tryget() and percpu_ref_tryget_live() should return
"true" IFF they acquire a reference. But the return value from
atomic_long_inc_not_zero() is a long and may have high bits set,
e.g. PERCPU_COUNT_BIAS, and the return value of the tryget routines
is bool so the reference may actually be acquired but the routines
return "false" which results in a reference leak since the caller
assumes it does not need to do a corresponding percpu_ref_put().
This was seen when performing CPU hotplug during I/O, as hangs in
blk_mq_freeze_queue_wait where percpu_ref_kill (blk_mq_freeze_queue_start)
raced with percpu_ref_tryget (blk_mq_timeout_work).
Sample stack trace:
__switch_to+0x2c0/0x450
__schedule+0x2f8/0x970
schedule+0x48/0xc0
blk_mq_freeze_queue_wait+0x94/0x120
blk_mq_queue_reinit_work+0xb8/0x180
blk_mq_queue_reinit_prepare+0x84/0xa0
cpuhp_invoke_callback+0x17c/0x600
cpuhp_up_callbacks+0x58/0x150
_cpu_up+0xf0/0x1c0
do_cpu_up+0x120/0x150
cpu_subsys_online+0x64/0xe0
device_online+0xb4/0x120
online_store+0xb4/0xc0
dev_attr_store+0x68/0xa0
sysfs_kf_write+0x80/0xb0
kernfs_fop_write+0x17c/0x250
__vfs_write+0x6c/0x1e0
vfs_write+0xd0/0x270
SyS_write+0x6c/0x110
system_call+0x38/0xe0
Examination of the queue showed a single reference (no PERCPU_COUNT_BIAS,
and __PERCPU_REF_DEAD, __PERCPU_REF_ATOMIC set) and no requests.
However, conditions at the time of the race are count of PERCPU_COUNT_BIAS + 0
and __PERCPU_REF_DEAD and __PERCPU_REF_ATOMIC set.
The fix is to make the tryget routines use an actual boolean internally instead
of the atomic long result truncated to a int.
Fixes: e625305b3907 percpu-refcount: make percpu_ref based on longs instead of ints
Link: https://bugzilla.kernel.org/show_bug.cgi?id=190751
Signed-off-by: Douglas Miller <dougmill@linux.vnet.ibm.com>
Reviewed-by: Jens Axboe <axboe@fb.com>
Fixes: e625305b3907 ("percpu-refcount: make percpu_ref based on longs instead of ints")
[ Upstream commit 003c941057eaa868ca6fedd29a274c863167230d ]
Fix up a data alignment issue on sparc by swapping the order
of the cookie byte array field with the length field in
struct tcp_fastopen_cookie, and making it a proper union
to clean up the typecasting.
This addresses log complaints like these:
log_unaligned: 113 callbacks suppressed
Kernel unaligned access at TPC[976490] tcp_try_fastopen+0x2d0/0x360
Kernel unaligned access at TPC[9764ac] tcp_try_fastopen+0x2ec/0x360
Kernel unaligned access at TPC[9764c8] tcp_try_fastopen+0x308/0x360
Kernel unaligned access at TPC[9764e4] tcp_try_fastopen+0x324/0x360
Signed-off-by: Shannon Nelson <shannon.nelson@oracle.com>
commit c929ea0b910355e1876c64431f3d5802f95b3d75 upstream.
After removing sunrpc module, I get many kmemleak information as,
unreferenced object 0xffff88003316b1e0 (size 544):
comm "gssproxy", pid 2148, jiffies 4294794465 (age 4200.081s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffffb0cfb58a>] kmemleak_alloc+0x4a/0xa0
[<ffffffffb03507fe>] kmem_cache_alloc+0x15e/0x1f0
[<ffffffffb0639baa>] ida_pre_get+0xaa/0x150
[<ffffffffb0639cfd>] ida_simple_get+0xad/0x180
[<ffffffffc06054fb>] nlmsvc_lookup_host+0x4ab/0x7f0 [lockd]
[<ffffffffc0605e1d>] lockd+0x4d/0x270 [lockd]
[<ffffffffc06061e5>] param_set_timeout+0x55/0x100 [lockd]
[<ffffffffc06cba24>] svc_defer+0x114/0x3f0 [sunrpc]
[<ffffffffc06cbbe7>] svc_defer+0x2d7/0x3f0 [sunrpc]
[<ffffffffc06c71da>] rpc_show_info+0x8a/0x110 [sunrpc]
[<ffffffffb044a33f>] proc_reg_write+0x7f/0xc0
[<ffffffffb038e41f>] __vfs_write+0xdf/0x3c0
[<ffffffffb0390f1f>] vfs_write+0xef/0x240
[<ffffffffb0392fbd>] SyS_write+0xad/0x130
[<ffffffffb0d06c37>] entry_SYSCALL_64_fastpath+0x1a/0xa9
[<ffffffffffffffff>] 0xffffffffffffffff
I found, the ida information (dynamic memory) isn't cleanup.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Fixes: 2f048db4680a ("SUNRPC: Add an identifier for struct rpc_clnt")
commit 059aa734824165507c65fd30a55ff000afd14983 upstream.
Xuan Qi reports that the Linux NFSv4 client failed to lock a file
that was migrated. The steps he observed on the wire:
1. The client sent a LOCK request to the source server
2. The source server replied NFS4ERR_MOVED
3. The client switched to the destination server
4. The client sent the same LOCK request to the destination
server with a bumped lock sequence ID
5. The destination server rejected the LOCK request with
NFS4ERR_BAD_SEQID
RFC 3530 section 8.1.5 provides a list of NFS errors which do not
bump a lock sequence ID.
However, RFC 3530 is now obsoleted by RFC 7530. In RFC 7530 section
9.1.7, this list has been updated by the addition of NFS4ERR_MOVED.
Reported-by: Xuan Qi <xuan.qi@oracle.com>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit b6416e61012429e0277bd15a229222fd17afc1c1 upstream.
Modules that use static_key_deferred need a way to synchronize with
any delayed work that is still pending when the module is unloaded.
Introduce static_key_deferred_flush() which flushes any pending
jump label updates.
Signed-off-by: David Matlack <dmatlack@google.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
[ Upstream commit 57ea52a865144aedbcd619ee0081155e658b6f7d ]
The GRO fast path caches the frag0 address. This address becomes
invalid if frag0 is modified by pskb_may_pull or its variants.
So whenever that happens we must disable the frag0 optimization.
This is usually done through the combination of gro_header_hard
and gro_header_slow, however, the IPv6 extension header path did
the pulling directly and would continue to use the GRO fast path
incorrectly.
This patch fixes it by disabling the fast path when we enter the
IPv6 extension header path.
Fixes: 78a478d0efd9 ("gro: Inline skb_gro_header and cache frag0 virtual address")
Reported-by: Slava Shwartsman <slavash@mellanox.com>
commit 0335695dfa4df01edff5bb102b9a82a0668ee51e upstream.
The current_user_ns() macro currently returns &init_user_ns when user
namespaces are disabled, and that causes several warnings when building
with gcc-6.0 in code that compares the result of the macro to
&init_user_ns itself:
fs/xfs/xfs_ioctl.c: In function 'xfs_ioctl_setattr_check_projid':
fs/xfs/xfs_ioctl.c:1249:22: error: self-comparison always evaluates to true [-Werror=tautological-compare]
if (current_user_ns() == &init_user_ns)
This is a legitimate warning in principle, but here it isn't really
helpful, so I'm reprasing the definition in a way that shuts up the
warning. Apparently gcc only warns when comparing identical literals,
but it can figure out that the result of an inline function can be
identical to a constant expression in order to optimize a condition yet
not warn about the fact that the condition is known at compile time.
This is exactly what we want here, and it looks reasonable because we
generally prefer inline functions over macros anyway.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Yaowei Bai <baiyaowei@cmss.chinamobile.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit fba332b079029c2f4f7e84c1c1cd8e3867310c90 upstream.
Code that dereferences the struct net_device ip_ptr member must be
protected with an in_dev_get() / in_dev_put() pair. Hence insert
calls to these functions.
Fixes: commit 7b85627b9f02 ("IB/cma: IBoE (RoCE) IP-based GID addressing")
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Moni Shoua <monis@mellanox.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Roland Dreier <roland@purestorage.com>
commit e6f462df9acd2a3295e5d34eb29e2823220cf129 upstream.
When mac80211 abandons an association attempt, it may free
all the data structures, but inform cfg80211 and userspace
about it only by sending the deauth frame it received, in
which case cfg80211 has no link to the BSS struct that was
used and will not cfg80211_unhold_bss() it.
Fix this by providing a way to inform cfg80211 of this with
the BSS entry passed, so that it can clean up properly, and
use this ability in the appropriate places in mac80211.
This isn't ideal: some code is more or less duplicated and
tracing is missing. However, it's a fairly small change and
it's thus easier to backport - cleanups can come later.
commit f84df2a6f268de584a201e8911384a2d244876e3 upstream.
When the user namespace support was merged the need to prevent
ptrace from revealing the contents of an unreadable executable
was overlooked.
Correct this oversight by ensuring that the executed file
or files are in mm->user_ns, by adjusting mm->user_ns.
Use the new function privileged_wrt_inode_uidgid to see if
the executable is a member of the user namespace, and as such
if having CAP_SYS_PTRACE in the user namespace should allow
tracing the executable. If not update mm->user_ns to
the parent user namespace until an appropriate parent is found.
Reported-by: Jann Horn <jann@thejh.net>
Fixes: 9e4a36ece652 ("userns: Fail exec for suid and sgid binaries with ids outside our user namespace.")
commit 64b875f7ac8a5d60a4e191479299e931ee949b67 upstream.
When the flag PT_PTRACE_CAP was added the PTRACE_TRACEME path was
overlooked. This can result in incorrect behavior when an application
like strace traces an exec of a setuid executable.
Further PT_PTRACE_CAP does not have enough information for making good
security decisions as it does not report which user namespace the
capability is in. This has already allowed one mistake through
insufficient granulariy.
I found this issue when I was testing another corner case of exec and
discovered that I could not get strace to set PT_PTRACE_CAP even when
running strace as root with a full set of caps.
This change fixes the above issue with strace allowing stracing as
root a setuid executable without disabling setuid. More fundamentaly
this change allows what is allowable at all times, by using the correct
information in it's decision.
Fixes: 4214e42f96d4 ("v2.4.9.11 -> v2.4.9.12")
commit bfedb589252c01fa505ac9f6f2a3d5d68d707ef4 upstream.
During exec dumpable is cleared if the file that is being executed is
not readable by the user executing the file. A bug in
ptrace_may_access allows reading the file if the executable happens to
enter into a subordinate user namespace (aka clone(CLONE_NEWUSER),
unshare(CLONE_NEWUSER), or setns(fd, CLONE_NEWUSER).
This problem is fixed with only necessary userspace breakage by adding
a user namespace owner to mm_struct, captured at the time of exec, so
it is clear in which user namespace CAP_SYS_PTRACE must be present in
to be able to safely give read permission to the executable.
The function ptrace_may_access is modified to verify that the ptracer
has CAP_SYS_ADMIN in task->mm->user_ns instead of task->cred->user_ns.
This ensures that if the task changes it's cred into a subordinate
user namespace it does not become ptraceable.
The function ptrace_attach is modified to only set PT_PTRACE_CAP when
CAP_SYS_PTRACE is held over task->mm->user_ns. The intent of
PT_PTRACE_CAP is to be a flag to note that whatever permission changes
the task might go through the tracer has sufficient permissions for
it not to be an issue. task->cred->user_ns is always the same
as or descendent of mm->user_ns. Which guarantees that having
CAP_SYS_PTRACE over mm->user_ns is the worst case for the tasks
credentials.
To prevent regressions mm->dumpable and mm->user_ns are not considered
when a task has no mm. As simply failing ptrace_may_attach causes
regressions in privileged applications attempting to read things
such as /proc/<pid>/stat
Tested-by: Cyrill Gorcunov <gorcunov@openvz.org>
Fixes: 8409cca70561 ("userns: allow ptrace from non-init user namespaces")
commit 777c6e0daebb3fcefbbd6f620410a946b07ef6d0 upstream.
Yu Zhao has noticed that __unregister_cpu_notifier only unregisters its
notifiers when HOTPLUG_CPU=y while the registration might succeed even
when HOTPLUG_CPU=n if MODULE is enabled. This means that e.g. zswap
might keep a stale notifier on the list on the manual clean up during
the pool tear down and thus corrupt the list. Resulting in the following
[ 144.964346] BUG: unable to handle kernel paging request at ffff880658a2be78
[ 144.971337] IP: [<ffffffffa290b00b>] raw_notifier_chain_register+0x1b/0x40
<snipped>
[ 145.122628] Call Trace:
[ 145.125086] [<ffffffffa28e5cf8>] __register_cpu_notifier+0x18/0x20
[ 145.131350] [<ffffffffa2a5dd73>] zswap_pool_create+0x273/0x400
[ 145.137268] [<ffffffffa2a5e0fc>] __zswap_param_set+0x1fc/0x300
[ 145.143188] [<ffffffffa2944c1d>] ? trace_hardirqs_on+0xd/0x10
[ 145.149018] [<ffffffffa2908798>] ? kernel_param_lock+0x28/0x30
[ 145.154940] [<ffffffffa2a3e8cf>] ? __might_fault+0x4f/0xa0
[ 145.160511] [<ffffffffa2a5e237>] zswap_compressor_param_set+0x17/0x20
[ 145.167035] [<ffffffffa2908d3c>] param_attr_store+0x5c/0xb0
[ 145.172694] [<ffffffffa290848d>] module_attr_store+0x1d/0x30
[ 145.178443] [<ffffffffa2b2b41f>] sysfs_kf_write+0x4f/0x70
[ 145.183925] [<ffffffffa2b2a5b9>] kernfs_fop_write+0x149/0x180
[ 145.189761] [<ffffffffa2a99248>] __vfs_write+0x18/0x40
[ 145.194982] [<ffffffffa2a9a412>] vfs_write+0xb2/0x1a0
[ 145.200122] [<ffffffffa2a9a732>] SyS_write+0x52/0xa0
[ 145.205177] [<ffffffffa2ff4d97>] entry_SYSCALL_64_fastpath+0x12/0x17
This can be even triggered manually by changing
/sys/module/zswap/parameters/compressor multiple times.
Fix this issue by making unregister APIs symmetric to the register so
there are no surprises.
Fixes: 47e627bc8c9a ("[PATCH] hotplug: Allow modules to use the cpu hotplug notifiers even if !CONFIG_HOTPLUG_CPU")
Reported-and-tested-by: Yu Zhao <yuzhao@google.com>
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: linux-mm@kvack.org
Cc: Dan Streetman <ddstreet@ieee.org>
Link: http://lkml.kernel.org/r/20161207135438.4310-1-mhocko@kernel.org
commit 332b05ca7a438f857c61a3c21a88489a21532364 upstream.
This patch adds a check to limit the number of can_filters that can be
set via setsockopt on CAN_RAW sockets. Otherwise allocations > MAX_ORDER
are not prevented resulting in a warning.
Reference: https://lkml.org/lkml/2016/12/2/230
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit b57332b4105abf1d518d93886e547ee2f98cd414 upstream.
[stable note, need this to prevent build warning in commit
a0ac402cfcdc904f9772e1762b3fda112dcc56a0]
commit e784930bd645e7df78c66e7872fec282b0620075 upstream.
Export pcie_find_root_port() so we can use it outside of PCIe-AER error
injection.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 045d599a286bc01daa3510d59272440a17b23c2e upstream.
kasan_global struct is part of compiler/runtime ABI. gcc revision
241983 has added a new field to kasan_global struct. Update kernel
definition of kasan_global struct to include the new field.
Without this patch KASAN is broken with gcc 7.
Link: http://lkml.kernel.org/r/1479219743-28682-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
commit 910170442944e1f8674fd5ddbeeb8ccd1877ea98 upstream.
Somehow I ended up with an off-by-three error in calculating the size of
the PASID and PASID State tables, which triggers allocations failures as
those tables unfortunately have to be physically contiguous.
In fact, even the *correct* maximum size of 8MiB is problematic and is
wont to lead to allocation failures. Since I have extracted a promise
that this *will* be fixed in hardware, I'm happy to limit it on the
current hardware to a maximum of 0x20000 PASIDs, which gives us 1MiB
tables — still not ideal, but better than before.
Reported by Mika Kuoppala <mika.kuoppala@linux.intel.com> and also by
Xunlei Pang <xlpang@redhat.com> who submitted a simpler patch to fix
only the allocation (and not the free) to the "correct" limit... which
was still problematic.
[ Upstream commit ac6e780070e30e4c35bd395acfe9191e6268bdd3 ]
With syzkaller help, Marco Grassi found a bug in TCP stack,
crashing in tcp_collapse()
Root cause is that sk_filter() can truncate the incoming skb,
but TCP stack was not really expecting this to happen.
It probably was expecting a simple DROP or ACCEPT behavior.
We first need to make sure no part of TCP header could be removed.
Then we need to adjust TCP_SKB_CB(skb)->end_seq
Many thanks to syzkaller team and Marco for giving us a reproducer.
Reported-by: Marco Grassi <marco.gra@gmail.com>
Reported-by: Vladis Dronov <vdronov@redhat.com>
[ Upstream commit 23f4ffedb7d751c7e298732ba91ca75d224bc1a6 ]
skb->cb may contain data from previous layers. In the observed scenario,
the garbage data were misinterpreted as IP6CB(skb)->frag_max_size, so
that small packets sent through the tunnel are mistakenly fragmented.
This patch unconditionally clears the control buffer in ip6tunnel_xmit(),
which affects ip6_tunnel, ip6_udp_tunnel and ip6_gre. Currently none of
these tunnels set IP6CB(skb)->flags, otherwise it needs to be done earlier.
Cc: stable@vger.kernel.org
Signed-off-by: Eli Cooper <elicooper@gmx.com>
[ Upstream commit 10df8e6152c6c400a563a673e9956320bfce1871 ]
First bug was added in commit ad6f939ab193 ("ip: Add offset parameter to
ip_cmsg_recv") : Tom missed that ipv4 udp messages could be received on
AF_INET6 socket. ip_cmsg_recv(msg, skb) should have been replaced by
ip_cmsg_recv_offset(msg, skb, sizeof(struct udphdr));
Then commit e6afc8ace6dd ("udp: remove headers from UDP packets before
queueing") forgot to adjust the offsets now UDP headers are pulled
before skb are put in receive queue.
Fixes: ad6f939ab193 ("ip: Add offset parameter to ip_cmsg_recv")
Fixes: e6afc8ace6dd ("udp: remove headers from UDP packets before queueing")
Cc: Sam Kumar <samanthakumar@google.com>
Cc: Willem de Bruijn <willemb@google.com>
Tested-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit fcd91dd449867c6bfe56a81cabba76b829fd05cd ]
Currently, GRO can do unlimited recursion through the gro_receive
handlers. This was fixed for tunneling protocols by limiting tunnel GRO
to one level with encap_mark, but both VLAN and TEB still have this
problem. Thus, the kernel is vulnerable to a stack overflow, if we
receive a packet composed entirely of VLAN headers.
This patch adds a recursion counter to the GRO layer to prevent stack
overflow. When a gro_receive function hits the recursion limit, GRO is
aborted for this skb and it is processed normally. This recursion
counter is put in the GRO CB, but could be turned into a percpu counter
if we run out of space in the CB.
Thanks to Vladimír Beneš <vbenes@redhat.com> for the initial bug report.
Fixes: CVE-2016-7039
Fixes: 9b174d88c257 ("net: Add Transparent Ethernet Bridging GRO support.")
Fixes: 66e5133f19e9 ("vlan: Add GRO support for non hardware accelerated vlan")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Tom Herbert <tom@herbertland.com>
[ Upstream commit 85dda4e5b0ee1f5b4e8cc93d39e475006bc61ccd ]
The offload flag is a status flag and should not be used by
FIB semantics for comparison.
Fixes: 37ed9493699c ("rtnetlink: add RTNH_F_EXTERNAL flag for fib offload")
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: Andy Gospodarek <andy@greyhouse.net>
functions
[ Upstream commit f39acc84aad10710e89835c60d3b6694c43a8dd9 ]
Generic skb_vlan_push/skb_vlan_pop functions don't properly handle the
case where the input skb data pointer does not point at the mac header:
- They're doing push/pop, but fail to properly unwind data back to its
original location.
For example, in the skb_vlan_push case, any subsequent
'skb_push(skb, skb->mac_len)' calls make the skb->data point 4 bytes
BEFORE start of frame, leading to bogus frames that may be transmitted.
- They update rcsum per the added/removed 4 bytes tag.
Alas if data is originally after the vlan/eth headers, then these
bytes were already pulled out of the csum.
OTOH calling skb_vlan_push/skb_vlan_pop with skb->data at mac_header
present no issues.
act_vlan is the only caller to skb_vlan_*() that has skb->data pointing
at network header (upon ingress).
Other calles (ovs, bpf) already adjust skb->data at mac_header.
This patch fixes act_vlan to point to the mac_header prior calling
skb_vlan_*() functions, as other callers do.
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Cc: Pravin Shelar <pshelar@ovn.org>
Cc: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 2cf750704bb6d7ed8c7d732e071dd1bc890ea5e8 ]
Since the commit below the ipmr/ip6mr rtnl_unicast() code uses the portid
instead of the previous dst_pid which was copied from in_skb's portid.
Since the skb is new the portid is 0 at that point so the packets are sent
to the kernel and we get scheduling while atomic or a deadlock (depending
on where it happens) by trying to acquire rtnl two times.
Also since this is RTM_GETROUTE, it can be triggered by a normal user.
Here's the sleeping while atomic trace:
[ 7858.212557] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:620
[ 7858.212748] in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper/0
[ 7858.212881] 2 locks held by swapper/0/0:
[ 7858.213013] #0: (((&mrt->ipmr_expire_timer))){+.-...}, at: [<ffffffff810fbbf5>] call_timer_fn+0x5/0x350
[ 7858.213422] #1: (mfc_unres_lock){+.....}, at: [<ffffffff8161e005>] ipmr_expire_process+0x25/0x130
[ 7858.213807] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.8.0-rc7+ #179
[ 7858.213934] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 7858.214108] 0000000000000000 ffff88005b403c50 ffffffff813a7804 0000000000000000
[ 7858.214412] ffffffff81a1338e ffff88005b403c78 ffffffff810a4a72 ffffffff81a1338e
[ 7858.214716] 000000000000026c 0000000000000000 ffff88005b403ca8 ffffffff810a4b9f
[ 7858.215251] Call Trace:
[ 7858.215412] <IRQ> [<ffffffff813a7804>] dump_stack+0x85/0xc1
[ 7858.215662] [<ffffffff810a4a72>] ___might_sleep+0x192/0x250
[ 7858.215868] [<ffffffff810a4b9f>] __might_sleep+0x6f/0x100
[ 7858.216072] [<ffffffff8165bea3>] mutex_lock_nested+0x33/0x4d0
[ 7858.216279] [<ffffffff815a7a5f>] ? netlink_lookup+0x25f/0x460
[ 7858.216487] [<ffffffff8157474b>] rtnetlink_rcv+0x1b/0x40
[ 7858.216687] [<ffffffff815a9a0c>] netlink_unicast+0x19c/0x260
[ 7858.216900] [<ffffffff81573c70>] rtnl_unicast+0x20/0x30
[ 7858.217128] [<ffffffff8161cd39>] ipmr_destroy_unres+0xa9/0xf0
[ 7858.217351] [<ffffffff8161e06f>] ipmr_expire_process+0x8f/0x130
[ 7858.217581] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217785] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217990] [<ffffffff810fbc95>] call_timer_fn+0xa5/0x350
[ 7858.218192] [<ffffffff810fbbf5>] ? call_timer_fn+0x5/0x350
[ 7858.218415] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.218656] [<ffffffff810fde10>] run_timer_softirq+0x260/0x640
[ 7858.218865] [<ffffffff8166379b>] ? __do_softirq+0xbb/0x54f
[ 7858.219068] [<ffffffff816637c8>] __do_softirq+0xe8/0x54f
[ 7858.219269] [<ffffffff8107a948>] irq_exit+0xb8/0xc0
[ 7858.219463] [<ffffffff81663452>] smp_apic_timer_interrupt+0x42/0x50
[ 7858.219678] [<ffffffff816625bc>] apic_timer_interrupt+0x8c/0xa0
[ 7858.219897] <EOI> [<ffffffff81055f16>] ? native_safe_halt+0x6/0x10
[ 7858.220165] [<ffffffff810d64dd>] ? trace_hardirqs_on+0xd/0x10
[ 7858.220373] [<ffffffff810298e3>] default_idle+0x23/0x190
[ 7858.220574] [<ffffffff8102a20f>] arch_cpu_idle+0xf/0x20
[ 7858.220790] [<ffffffff810c9f8c>] default_idle_call+0x4c/0x60
[ 7858.221016] [<ffffffff810ca33b>] cpu_startup_entry+0x39b/0x4d0
[ 7858.221257] [<ffffffff8164f995>] rest_init+0x135/0x140
[ 7858.221469] [<ffffffff81f83014>] start_kernel+0x50e/0x51b
[ 7858.221670] [<ffffffff81f82120>] ? early_idt_handler_array+0x120/0x120
[ 7858.221894] [<ffffffff81f8243f>] x86_64_start_reservations+0x2a/0x2c
[ 7858.222113] [<ffffffff81f8257c>] x86_64_start_kernel+0x13b/0x14a
Fixes: 2942e9005056 ("[RTNETLINK]: Use rtnl_unicast() for rtnetlink unicasts")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 20c64d5cd5a2bdcdc8982a06cb05e5e1bd851a3d ]
A malicious TCP receiver, sending SACK, can force the sender to split
skbs in write queue and increase its memory usage.
Then, when socket is closed and its write queue purged, we might
overflow sk_forward_alloc (It becomes negative)
sk_mem_reclaim() does nothing in this case, and more than 2GB
are leaked from TCP perspective (tcp_memory_allocated is not changed)
Then warnings trigger from inet_sock_destruct() and
sk_stream_kill_queues() seeing a not zero sk_forward_alloc
All TCP stack can be stuck because TCP is under memory pressure.
A simple fix is to preemptively reclaim from sk_mem_uncharge().
This makes sure a socket wont have more than 2 MB forward allocated,
after burst and idle period.
commit 0733424c9ba9f42242409d1ece780777272f7ea1 upstream.
Exported pwm channels aren't removed before the pwmchip and are
leaked. This results in invalid sysfs files. This fix removes
all exported pwm channels before chip removal.
Signed-off-by: David Hsu <davidhsu@google.com>
Fixes: 76abbdde2d95 ("pwm: Add sysfs interface")
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
